path: root/kernel/irq/manage.c
2006-04-28[PATCH] request_irq(): remove warnings from irq probingAndrew Morton
- Add new SA_PROBEIRQ which suppresses the new sharing-mismatch warning. Some drivers like to use request_irq() to find an unused interrupt slot. - Use it in i82365.c - Kill unused SA_PROBE. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] warn if free_irq() is called from IRQ contextIngo Molnar
Warn if free_irq() is called in IRQ context - free_irq() can execute /proc VFS work, which must not be done in IRQ context. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] Add SA_PERCPU_IRQ flag supportDimitri Sivanich
Add support for SA_PERCPU_IRQ (only mmtimer.c uses this at this stage). Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] Alpha: convert to generic irq framework (generic part)Ivan Kokshaysky
Thanks to Christoph for doing most of the work. This allows automatic SMP IRQ affinity assignment other than default "all interrupts on all CPUs" which is rather expensive. This might be useful if the hardware can be programmed to distribute interrupts among different CPUs, like Alpha does. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Christoph Hellwig <hch@lst.de> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-23[PATCH] Check the irq number is within boundsMatthew Wilcox
Most of the functions already check. Do the ones that didn't. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] more kernel-doc cleanups, additionsRandy Dunlap
Various core kernel-doc cleanups: - add missing function parameters in ipc, irq/manage, kernel/sys, kernel/sysctl, and mm/slab; - move description to just above function for kernel_restart() Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] x86/x86_64: deferred handling of writes to /proc/irqxx/smp_affinityAshok Raj
When handling writes to /proc/irq, current code is re-programming rte entries directly. This is not recommended and could potentially cause chipset's to lockup, or cause missing interrupts. CONFIG_IRQ_BALANCE does this correctly, where it re-programs only when the interrupt is pending. The same needs to be done for /proc/irq handling as well. Otherwise user space irq balancers are really not doing the right thing. - Changed pending_irq_balance_cpumask to pending_irq_migrate_cpumask for lack of a generic name. - added move_irq out of IRQ_BALANCE, and added this same to X86_64 - Added new proc handler for write, so we can do deferred write at irq handling time. - Display of /proc/irq/XX/smp_affinity used to display CPU_MASKALL, instead it now shows only active cpu masks, or exactly what was set. - Provided a common move_irq implementation, instead of duplicating when using generic irq framework. Tested on i386/x86_64 and ia64 with CONFIG_PCI_MSI turned on and off. Tested UP builds as well. MSI testing: tbd: I have cards, need to look for a x-over cable, although I did test an earlier version of this patch. Will test in a couple days. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Acked-by: Zwane Mwaikambo <zwane@holomorphy.com> Grudgingly-acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Coywolf Qi Hunt <coywolf@lovecn.org> Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] uml: make hw_controller_type->release exist only for archs needing itPaolo 'Blaisorblade' Giarrusso
With Chris Wedgwood <cw@f00f.org> As suggested by Chris, we can make the "just added" method ->release conditional to UML only (better: to archs requesting it, i.e. only UML currently), so that other archs don't get this unneeded crud, and if UML won't need it any more we can kill this. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> CC: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] uml: add and use generic hw_controller_type->releasePaolo 'Blaisorblade' Giarrusso
With Chris Wedgwood <cw@f00f.org> Currently UML must explicitly call the UML-specific free_irq_by_irq_and_dev() for each free_irq call it's done. This is needed because ->shutdown and/or ->disable are only called when the last "action" for that irq is removed. Instead, for UML shared IRQs (UML IRQs are very often, if not always, shared), for each dev_id some setup is done, which must be cleared on the release of that fd. For instance, for each open console a new instance (i.e. new dev_id) of the same IRQ is requested(). Exactly, a fd is stored in an array (pollfds), which is after read by a host thread and passed to poll(). Each event registered by poll() triggers an interrupt. So, for each free_irq() we must remove the corresponding host fd from the table, which we do via this -release() method. In this patch we add an appropriate hook for this, and remove all uses of it by pointing the hook to the said procedure; this is safe to do since the said procedure. Also some cosmetic improvements are included. This is heavily based on some work by Chris Wedgwood, which however didn't get the patch merged for something I'd call a "misunderstanding" (the need for this patch wasn't cleanly explained, thus adding the generic hook was felt as undesirable). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> CC: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
