path: root/kernel/irq/irqdomain.c
2014-06-21genirq: Export irq_domain_disassociate() to architecture interrupt driversJiang Liu
Export irq_domain_disassociate() to architecture interrupt drivers, so it could be used to handle legacy IRQ descriptors on x86. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1402302011-23642-37-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-05-27genirq: Improve documentation to match current implementationJiang Liu
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Jiri Kosina <trivial@kernel.org> Link: http://lkml.kernel.org/r/1401178092-1228-3-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-27genirq: Include missing header file in irqdomain.cRashika Kheria
Include appropriate header file include/linux/of_irq.h in kernel/irq/irqdomain.c because it contains prototype definition of function define in kernel/irq/irqdomain.c. This eliminates the following warning in kernel/irq/irqdomain.c: kernel/irq/irqdomain.c:468:14: warning: no previous prototype for ‘irq_create_of_mapping’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Link: http://lkml.kernel.org/r/eb89aebea7ff1a46122918ac389ebecf8248be9a.1393493276.git.rashika.kheria@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-10-24of/irq: simplify args to irq_create_of_mappingGrant Likely
All the callers of irq_create_of_mapping() pass the contents of a struct of_phandle_args structure to the function. Since all the callers already have an of_phandle_args pointer, why not pass it directly to irq_create_of_mapping()? Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-13Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "MIPS updates: - All the things that didn't make 3.10. - Removes the Windriver PPMC platform. Nobody will miss it. - Remove a workaround from kernel/irq/irqdomain.c which was there exclusivly for MIPS. Patch by Grant Likely. - More small improvments for the SEAD 3 platform - Improvments on the BMIPS / SMP support for the BCM63xx series. - Various cleanups of dead leftovers. - Platform support for the Cavium Octeon-based EdgeRouter Lite. Two large KVM patchsets didn't make it for this pull request because their respective authors are vacationing" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (124 commits) MIPS: Kconfig: Add missing MODULES dependency to VPE_LOADER MIPS: BCM63xx: CLK: Add dummy clk_{set,round}_rate() functions MIPS: SEAD3: Disable L2 cache on SEAD-3. MIPS: BCM63xx: Enable second core SMP on BCM6328 if available MIPS: BCM63xx: Add SMP support to prom.c MIPS: define write{b,w,l,q}_relaxed MIPS: Expose missing pci_io{map,unmap} declarations MIPS: Malta: Update GCMP detection. Revert "MIPS: make CAC_ADDR and UNCAC_ADDR account for PHYS_OFFSET" MIPS: APSP: Remove <asm/kspd.h> SSB: Kconfig: Amend SSB_EMBEDDED dependencies MIPS: microMIPS: Fix improper definition of ISA exception bit. MIPS: Don't try to decode microMIPS branch instructions where they cannot exist. MIPS: Declare emulate_load_store_microMIPS as a static function. MIPS: Fix typos and cleanup comment MIPS: Cleanup indentation and whitespace MIPS: BMIPS: support booting from physical CPU other than 0 MIPS: Only set cpu_has_mmips if SYS_SUPPORTS_MICROMIPS MIPS: GIC: Fix gic_set_affinity infinite loop MIPS: Don't save/restore OCTEON wide multiplier state on syscalls. ...
2013-07-06Merge tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull irqdomain refactoring from Grant Likely: "This is the long awaited simplification of irqdomain. It gets rid of the different types of irq domains and instead both linear and tree mappings can be supported in a single domain. Doing this removes a lot of special case code and makes irq domains simpler to understand overall" * tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux: irq: fix checkpatch error irqdomain: Include hwirq number in /proc/interrupts irqdomain: make irq_linear_revmap() a fast path again irqdomain: remove irq_domain_generate_simple() irqdomain: Refactor irq_domain_associate_many() irqdomain: Beef up debugfs output irqdomain: Clean up aftermath of irq_domain refactoring irqdomain: Eliminate revmap type irqdomain: merge linear and tree reverse mappings. irqdomain: Add a name field irqdomain: Replace LEGACY mapping with LINEAR irqdomain: Relax failure path on setting up mappings
2013-07-02Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core irq changes from Ingo Molnar: "The main changes: - generic-irqchip driver additions, cleanups and fixes - 3 new irqchip drivers: ARMv7-M NVIC, TB10x and Marvell Orion SoCs - irq_get_trigger_type() simplification and cross-arch cleanup - various cleanups, simplifications - documentation updates" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits) softirq: Use _RET_IP_ genirq: Add the generic chip to the genirq docbook genirq: generic-chip: Export some irq_gc_ functions genirq: Fix can_request_irq() for IRQs without an action irqchip: exynos-combiner: Staticize combiner_init irqchip: Add support for ARMv7-M NVIC irqchip: Add TB10x interrupt controller driver irqdomain: Use irq_get_trigger_type() to get IRQ flags MIPS: octeon: Use irq_get_trigger_type() to get IRQ flags arm: orion: Use irq_get_trigger_type() to get IRQ flags mfd: stmpe: use irq_get_trigger_type() to get IRQ flags mfd: twl4030-irq: Use irq_get_trigger_type() to get IRQ flags gpio: mvebu: Use irq_get_trigger_type() to get IRQ flags genirq: Add irq_get_trigger_type() to get IRQ flags genirq: Irqchip: document gcflags arg of irq_alloc_domain_generic_chips genirq: Set irq thread to RT priority on creation irqchip: Add support for Marvell Orion SoCs genirq: Add kerneldoc for irq_disable. genirq: irqchip: Add mask to block out invalid irqs genirq: Generic chip: Add linear irq domain support ...
2013-06-25irqdomain: Use irq_get_trigger_type() to get IRQ flagsJavier Martinez Canillas
Use irq_get_trigger_type() to get the IRQ trigger type flags instead calling irqd_get_trigger_type(irq_desc_get_irq_data(virq)) Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Grant Likely <grant.likely@linaro.org> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-mips@linux-mips.org Link: http://lkml.kernel.org/r/1371228049-27080-8-git-send-email-javier.martinez@collabora.co.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-06-24irq: fix checkpatch errorKefeng Wang
ERROR: space required before the open parenthesis '(' WARNING: Prefer pr_warn(... to pr_warning(... Just fix above 2 issue. Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-24irqdomain: make irq_linear_revmap() a fast path againGrant Likely
Over the years, irq_linear_revmap() gained tests and checks to make sure callers were using it safely, which while important, also make it less of a fast path. After the irqdomain refactoring done recently, it is now possible to make irq_linear_revmap() a fast path again. This patch moves irq_linear_revmap() to the header file and makes it a static inline so that interrupt controller drivers using a linear mapping can decode the virq from a hwirq in just a couple of instructions. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-24irqdomain: remove irq_domain_generate_simple()Grant Likely
Nobody calls it; remove the function Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-24irqdomain: Refactor irq_domain_associate_many()Grant Likely
Originally, irq_domain_associate_many() was designed to unwind the mapped irqs on a failure of any individual association. However, that proved to be a problem with certain IRQ controllers. Some of them only support a subset of irqs, and will fail when attempting to map a reserved IRQ. In those cases we want to map as many IRQs as possible, so instead it is better for irq_domain_associate_many() to make a best-effort attempt to map irqs, but not fail if any or all of them don't succeed. If a caller really cares about how many irqs got associated, then it should instead go back and check that all of the irqs is cares about were mapped. The original design open-coded the individual association code into the body of irq_domain_associate_many(), but with no longer needing to unwind associations, the code becomes simpler to split out irq_domain_associate() to contain the bulk of the logic, and irq_domain_associate_many() to be a simple loop wrapper. This patch also adds a new error check to the associate path to make sure it isn't called for an irq larger than the controller can handle, and adds locking so that the irq_domain_mutex is held while setting up a new association. v3: Fixup missing change to irq_domain_add_tree() v2: Fixup x86 warning. irq_domain_associate_many() no longer returns an error code, but reports errors to the printk log directly. In the majority of cases we don't actually want to fail if there is a problem, but rather log it and still try to boot the system. Signed-off-by: Grant Likely <grant.likely@linaro.org> irqdomain: Fix flubbed irq_domain_associate_many refactoring commit d39046ec72, "irqdomain: Refactor irq_domain_associate_many()" was missing the following hunk which causes a boot failure on anything using irq_domain_add_tree() to allocate an irq domain. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Michael Neuling <mikey@neuling.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>, Cc: Thomas Gleixner <tglx@linutronix.de>, Cc: Stephen Rothwell <sfr@canb.auug.org.au>
2013-06-18irqdomain: Remove temporary MIPS workaround codeGrant Likely
The MIPS interrupt controllers are all registering their own irq_domains now. Drop the MIPS specific code because it is no longer needed. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/5458/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-06-10irqdomain: Beef up debugfs outputGrant Likely
This patch increases the amount of output produced by the irq_domain_mapping debugfs file by first listing all of the registered irq domains at the beginning of the output, and then by including all mapped IRQs in the output, not just the active ones. It is very useful when debugging irqdomain issues to be able to see the entire list of mapped irqs, not just the ones that happen to be connected to devices. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-10irqdomain: Clean up aftermath of irq_domain refactoringGrant Likely
After refactoring the irqdomain code, there are a number of API functions that are merely empty wrappers around core code. Drop those wrappers out of the C file and replace them with static inlines in the header. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-10irqdomain: Eliminate revmap typeGrant Likely
The NOMAP irq_domain type is only used by a handful of interrupt controllers and it unnecessarily complicates the code by adding special cases on how to look up mappings and different revmap functions are used for each type which need to validate the correct type is passed to it before performing the reverse map. Eliminating the revmap_type and making a single reverse mapping function simplifies the code. It also shouldn't be any slower than having separate revmap functions because the type of the revmap needed to be checked anyway. The linear and tree revmap types were already merged in a previous patch. This patch rolls the NOMAP or direct mapping behaviour into the same domain code making is possible for an irq domain to do any mapping type; linear, tree or direct; and that the mapping will be transparent to the interrupt controller driver. With this change, direct mappings will get stored in the linear or tree mapping for consistency. Reverse mapping from the hwirq to virq will go through the normal lookup process. However, any controller using a direct mapping can take advantage of knowing that hwirq==virq for any mapped interrupts skip doing a revmap lookup when handling IRQs. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-10irqdomain: merge linear and tree reverse mappings.Grant Likely
Keeping them separate makes irq_domain more complex and adds a lot of code (as proven by the diffstat). Merging them simplifies the whole scheme. This change makes it so both the tree and linear methods can be used by the same irq_domain instance. If the hwirq is less than the ->linear_size, then the linear map is used to reverse map the hwirq. Otherwise the radix tree is used. The test for which map to use is no more expensive that the existing code, so the performance of fast path is preserved. It also means that complex interrupt controllers can use both the linear map and a tree in the same domain. This may be useful for an interrupt controller with a base set of core irqs and a large number of GPIOs which might be used as irqs. The linear map could cover the core irqs, and the tree used for thas irqs. The linear map could cover the core irqs, and the tree used for the gpios. v2: Drop reorganization of revmap data Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2013-06-10irqdomain: Add a name fieldGrant Likely
This patch adds a name field to the irq_domain structure to help mere mortals understand the mappings between irq domains and virqs. It also converts a number of places that have open-coded some kind of fudging an irqdomain name to use the new field. This means a more consistent display of names in irq domain log messages and debugfs output. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-10irqdomain: Replace LEGACY mapping with LINEARGrant Likely
The LEGACY mapping unnecessarily complicates the irqdomain code and can easily be implemented with a linear mapping. By ripping it out and replacing it with the LINEAR mapping the object size of irqdomain.c shrinks by about 330 bytes (ARMv7) which offsets the additional allocation required by the linear map. It also makes it possible for current LEGACY map users to pre-allocate irq_descs for a subset of the hwirqs and dynamically allocate the rest as needed. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2013-06-10irqdomain: Relax failure path on setting up mappingsGrant Likely
Commit 98aa468e, "irqdomain: Support for static IRQ mapping and association" introduced an API for directly associating blocks of hwirqs to linux irqs. However, if any irq in that block failed to map (say if the mapping functions returns an error because the irq is already mapped) then the whole thing will fail and roll back. This is probably too aggressive since there are valid reasons why a mapping may fail. ie. Firmware may have a particular IRQ marked as unusable. This patch drops the error path out of irq_domain_associate(). If a mapping fails, then it is simply skipped. There is no reason to fail the entire allocation. v2: Still output an information message on failed mappings and make sure attempted mapping gets cleared out of the irq_data structure. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-06-10Merge remote-tracking branch 'tip/irq/for-arm' into irqdomain/nextGrant Likely
2013-06-08irqdomain: document the simple domain first_irqLinus Walleij
The first_irq needs to be zero to get a linear domain and that comes with special semantics. We want to simplify this going forward but some documentation never hurts. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-08kernel/irq/irqdomain.c: before use 'irq_data', need check it whether valid.Chen Gang
Since irq_data may be NULL, if so, we WARN_ON(), and continue, 'hwirq' which related with 'irq_data' has to initialize later, or it will cause issue. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-08irqdomain: export irq_domain_add_simpleArnd Bergmann
All other irq_domain_add_* functions are exported already, and apparently this one got left out by mistake, which causes build errors for ARM allmodconfig kernels: ERROR: "irq_domain_add_simple" [drivers/gpio/gpio-rcar.ko] undefined! ERROR: "irq_domain_add_simple" [drivers/gpio/gpio-em.ko] undefined! Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-05-29genirq: Generic chip: Add linear irq domain supportThomas Gleixner
Provide infrastructure for irq chip implementations which work on linear irq domains. - Interface to allocate multiple generic chips which are associated to the irq domain. - Interface to get the generic chip pointer for a particular hardware interrupt in the domain. - irq domain mapping function to install the chip for a particular interrupt. Note: This lacks a removal function for now. [ Sebastian Hesselbarth: Mask cache and pointer math fixups ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Russell King - ARM Linux <linux@arm.linux.org.uk> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Jean-Francois Moine <moinejf@free.fr> Cc: devicetree-discuss@lists.ozlabs.org Cc: Rob Herring <rob.herring@calxeda.com> Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Cc: Gregory Clement <gregory.clement@free-electrons.com> Cc: Gerlando Falauto <gerlando.falauto@keymile.com> Cc: Rob Landley <rob@landley.net> Acked-by: Grant Likely <grant.likely@linaro.org> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: http://lkml.kernel.org/r/20130506142539.450634298@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-05-06irqdomain: Allow quiet failure modeBenjamin Herrenschmidt
Some interrupt controllers refuse to map interrupts marked as "protected" by firwmare. Since we try to map everyting in the device-tree on some platforms, we end up with a lot of nasty WARN's in the boot log for what is a normal situation on those machines. This defines a specific return code (-EPERM) from the host map() callback which cause irqdomain to fail silently. MPIC is updated to return this when hitting a protected source printing only a single line message for diagnostic purposes. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-11-30irqdomain: stop screaming about preallocated irqdescsLinus Walleij
In the simple irqdomain: don't shout warnings to the user, there is no point. An informational print is sufficient. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-10-10irqdomain: augment add_simple() to allocate descsLinus Walleij
Currently we rely on all IRQ chip instances to dynamically allocate their IRQ descriptors unless they use the linear IRQ domain. So for irqdomain_add_legacy() and irqdomain_add_simple() the caller need to make sure that descriptors are allocated. Let's slightly augment the yet unused irqdomain_add_simple() to also allocate descriptors as a means to simplify usage and avoid code duplication throughout the kernel. We warn if descriptors cannot be allocated, e.g. if a platform has the bad habit of hogging descriptors at boot time. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Lee Jones <lee.jones@linaro.org> Reviewed-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-07-24irqdomain: Improve diagnostics when a domain mapping failsMark Brown
When the map operation fails log the error code we get and add a WARN_ON() so we get a backtrace (which should help work out which interrupt is the source of the issue). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-07-24irqdomain: eliminate slow-path revmap lookupsGrant Likely
With the current state of irq_domain, the reverse map is always updated when new IRQs get mapped. This means that the irq_find_mapping() function can be simplified to execute the revmap lookup functions unconditionally This patch adds lookup functions for the revmaps that don't yet have one and removes the slow path lookup code path. v8: Broke out unrelated changes into separate patches. Rebased on Paul's irq association patches. v7: Rebased to irqdomain/next for v3.4 and applied before the removal of 'hint' v6: Remove the slow path entirely. The only place where the slow path could get called is for a linear mapping if the hwirq number is larger than the linear revmap size. There shouldn't be any interrupt controllers that do that. v5: rewrite to not use a ->revmap() callback. It is simpler, smaller, safer and faster to open code each of the revmap lookups directly into irq_find_mapping() via a switch statement. v4: Fix build failure on incorrect variable reference. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Rob Herring <rob.herring@calxeda.com>
2012-07-11irqdomain: Fix irq_create_direct_mapping() to test irq_domain type.Grant Likely
irq_create_direct_mapping can only be used with the NOMAP type. Make the function test to ensure it is passed the correct type of irq_domain. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2012-07-11irqdomain: Eliminate dedicated radix lookup functionsGrant Likely
In preparation to remove the slow revmap path, eliminate the public radix revmap lookup functions. This simplifies the code and makes the slowpath removal patch a lot simpler. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2012-07-11irqdomain: Support for static IRQ mapping and association.Grant Likely
This adds a new strict mapping API for supporting creation of linux IRQs at existing positions within the domain. The new routines are as follows: For dynamic allocation and insertion to specified ranges: - irq_create_identity_mapping() - irq_create_strict_mappings() These will allocate and associate a range of linux IRQs at the specified location. This can be used by controllers that have their own static linux IRQ definitions to map a hwirq range to, as well as for platforms that wish to establish 1:1 identity mapping between linux and hwirq space. For insertion to specified ranges by platforms that do their own irq_desc management: - irq_domain_associate() - irq_domain_associate_many() These in turn call back in to the domain's ->map() routine, for further processing by the platform. Disassociation of IRQs get handled through irq_dispose_mapping() as normal. With these in place it should be possible to begin migration of legacy IRQ domains to linear ones, without requiring special handling for static vs dynamic IRQ definitions in DT vs non-DT paths. This also makes it possible for domains with static mappings to adopt whichever tree model best fits their needs, rather than simply restricting them to linear revmaps. Signed-off-by: Paul Mundt <lethal@linux-sh.org> [grant.likely: Reorganized irq_domain_associate{,_many} to have all logic in one place] [grant.likely: Add error checking for unallocated irq_descs at associate time] Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2012-07-11irqdomain: Always update revmap when setting up a virqGrant Likely
At irq_setup_virq() time all of the data needed to update the reverse map is available, but the current code ignores it and relies upon the slow path to insert revmap records. This patch adds revmap updating to the setup path so the slow path will no longer be necessary. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2012-07-11irqdomain: Split disassociating code into separate functionGrant Likely
This patch moves the irq disassociation code out into a separate function in preparation to extend irq_setup_virq to handle multiple irqs and rename it for use by interrupt controller drivers. The new function will be used by irq_setup_virq() in its error path. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2012-07-11irq_domain: correct a minor wrong comment for linear revmapDong Aisheng
The revmap type should be linear for irq_domain_add_linear function. Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-07-11irq_domain: Standardise legacy/linear domain selectionMark Brown
A large proportion of interrupt controllers that support legacy mappings do so because non-DT systems need to use fixed IRQ numbers when registering devices via buses but can otherwise use a linear mapping. The interrupt controller itself typically is not affected by the mapping used and best practice is to use a linear mapping where possible so drivers frequently select at runtime depending on if a legacy range has been allocated to them. Standardise this behaviour by providing irq_domain_register_simple() which will allocate a linear mapping unless a positive first_irq is provided in which case it will fall back to a legacy mapping. This helps make best practice for irq_domain adoption clearer. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-06-17irqdomain: Make ops->map hook optionalGrant Likely
There isn't a really compelling reason to force ->map to be populated, so allow it to be left unset. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2012-06-15irqdomain: Remove unnecessary test for IRQ_DOMAIN_MAP_LEGACYGrant Likely
Where irq_domain_associate() is called in irq_create_mapping, there is no need to test for IRQ_DOMAIN_MAP_LEGACY because it is already tested for earlier in the routine. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2012-06-15irqdomain: Simple NUMA awareness.Paul Mundt
While common irqdesc allocation is node aware, the irqdomain code is not. Presently we observe a number of regressions/inconsistencies on NUMA-capable platforms: - Platforms using irqdomains with legacy mappings, where the irq_descs are allocated node-local and the irqdomain data structure is not. - Drivers implementing irqdomains will lose node locality regardless of the underlying struct device's node id. This plugs in NUMA node id proliferation across the various allocation callsites by way of_node_to_nid() node lookup. While of_node_to_nid() does the right thing for OF-capable platforms it doesn't presently handle the non-DT case. This is trivially dealt with by simply wraping in to numa_node_id() unconditionally. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-06-15devicetree: add helper inline for retrieving a node's full nameGrant Likely
The pattern (np ? np->full_name : "<none>") is rather common in the kernel, but can also make for quite long lines. This patch adds a new inline function, of_node_full_name() so that the test for a valid node pointer doesn't need to be open coded at all call sites. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2012-05-19irqdomain: Document size parameter of irq_domain_add_linear()Mark Brown
2012-05-19irqdomain: trivial pr_fmt conversion.Paul Mundt
Convert to pr_fmt before things start to get out of hand and some janitors start getting overly excited. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-05-19irqdomain: Make irq_domain_simple_map() static.Paul Mundt
Presently irq_domain_simple_map() isn't labelled as static, but there's no definition for it in the public irqdomain header either. At present all in-tree ->map users have meaningful work to do, and all others are using irq_domain_simple_ops directly. Make it static for now, as it can always be exported and added to the public API later. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-05-19irqdomain: Export remaining public API symbols.Paul Mundt
modules making use of irq domains at the very least need access to the add/remove/lookup routines, though there's nothing preventing them from using the remainder of the public API, either. The current set of exports seem primarily geared at DT-enabled platforms using DT-backed IRQ domains, where many of the API accesses are hidden away in OF code. The non-DT cases need to do most of this on their own. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-05-19irqdomain: Support removal of IRQ domains.Paul Mundt
Now that IRQ domains are being used by modules it's necessary to support removing them, too. This adds a new irq_domain_remove() routine for doing the bulk of the heavy lifting. It's left as an exercise to the caller to ensure all mappings have been appropriatey disposed of before attempting to remove the domain. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-04-12irq_domain: fix type mismatch in debugfs output formatGrant Likely
sizeof(void*) returns an unsigned long, but it was being used as a width parameter to a "%-*s" format string which requires an int. On 64 bit platforms this causes a type mismatch: linux/kernel/irq/irqdomain.c:575: warning: field width should have type 'int', but argument 6 has type 'long unsigned int' This change casts the size to an int so printf gets the right data type. Reported-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: David Daney <david.daney@cavium.com>
2012-04-12irq_domain: Move irq_virq_count into NOMAP revmapGrant Likely
This patch replaces the old global setting of irq_virq_count that is only used by the NOMAP mapping and instead uses a revmap_data property so that the maximum NOMAP allocation can be set per NOMAP irq_domain. There is exactly one user of irq_virq_count in-tree right now: PS3. Also, irq_virq_count is only useful for the NOMAP mapping. So, instead of having a single global irq_virq_count values, this change drops it entirely and added a max_irq argument to irq_domain_add_nomap(). That makes it a property of an individual nomap irq domain instead of a global system settting. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com>
2012-04-11irqdomain: Fix debugfs formattingGrant Likely
This patch fixes the irq_domain_mapping debugfs output to pad pointer values with leading zeros so that pointer values are displayed correctly. Otherwise you get output similar to "0x 5e0000000000000". Also, when the irq_domain is set to 'null' Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: David Daney <david.daney@cavium.com> Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
2012-04-10irq/irq_domain: Quit ignoring error returns from irq_alloc_desc_from().David Daney
In commit 4bbdd45a (irq_domain/powerpc: eliminate irq_map; use irq_alloc_desc() instead) code was added that ignores error returns from irq_alloc_desc_from() by (silently) casting the return value to unsigned. The negitive value error return now suddenly looks like a valid irq number. Commits cc79ca69 (irq_domain: Move irq_domain code from powerpc to kernel/irq) and 1bc04f2c (irq_domain: Add support for base irq and hwirq in legacy mappings) move this code to its current location in irqdomain.c The result of all of this is a null pointer dereference OOPS if one of the error cases is hit. The fix: Don't cast away the negativeness of the return value and then check for errors. Signed-off-by: David Daney <david.daney@cavium.com> Acked-by: Rob Herring <rob.herring@calxeda.com> [grant.likely: dropped addition of new 'irq' variable] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
