path: root/kernel/fork.c
2013-07-03kernel/fork.c:copy_process(): consolidate the lockless CLONE_THREAD checksOleg Nesterov
copy_process() does a lot of "chaotic" initializations and checks CLONE_THREAD twice before it takes tasklist. In particular it sets "p->group_leader = p" and then changes it again under tasklist if !thread_group_leader(p). This looks a bit confusing, lets create a single "if (CLONE_THREAD)" block which initializes ->exit_signal, ->group_leader, and ->tgid. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Sergey Dyasly <dserrg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03kernel/fork.c:copy_process(): don't add the uninitialized child to ↵Oleg Nesterov
thread/task/pid lists copy_process() adds the new child to thread_group/init_task.tasks list and then does attach_pid(child, PIDTYPE_PID). This means that the lockless next_thread() or next_task() can see this thread with the wrong pid. Say, "ls /proc/pid/task" can list the same inode twice. We could move attach_pid(child, PIDTYPE_PID) up, but in this case find_task_by_vpid() can find the new thread before it was fully initialized. And this is already true for PIDTYPE_PGID/PIDTYPE_SID, With this patch copy_process() initializes child->pids[*].pid first, then calls attach_pid() to insert the task into the pid->tasks list. attach_pid() no longer need the "struct pid*" argument, it is always called after pid_link->pid was already set. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Sergey Dyasly <dserrg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03kernel/fork.c:copy_process(): unify CLONE_THREAD-or-thread_group_leader codeOleg Nesterov
Cleanup and preparation for the next changes. Move the "if (clone_flags & CLONE_THREAD)" code down under "if (likely(p->pid))" and turn it into into the "else" branch. This makes the process/thread initialization more symmetrical and removes one check. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Sergey Dyasly <dserrg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03fork: reorder permissions when violating number of processes limitsEric Paris
When a task is attempting to violate the RLIMIT_NPROC limit we have a check to see if the task is sufficiently priviledged. The check first looks at CAP_SYS_ADMIN, then CAP_SYS_RESOURCE, then if the task is uid=0. A result is that tasks which are allowed by the uid=0 check are first checked against the security subsystem. This results in the security subsystem auditting a denial for sys_admin and sys_resource and then the task passing the uid=0 check. This patch rearranges the code to first check uid=0, since if we pass that we shouldn't hit the security system at all. We then check sys_resource, since it is the smallest capability which will solve the problem. Lastly we check the fallback everything cap_sysadmin. We don't want to give this capability many places since it is so powerful. This will eliminate many of the false positive/needless denial messages we get when a root task tries to violate the nproc limit. (note that kthreads count against root, so on a sufficiently large machine we can actually get past the default limits before any userspace tasks are launched.) Signed-off-by: Eric Paris <eparis@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-08Merge branch 'for-3.10/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver updates from Jens Axboe: "It might look big in volume, but when categorized, not a lot of drivers are touched. The pull request contains: - mtip32xx fixes from Micron. - A slew of drbd updates, this time in a nicer series. - bcache, a flash/ssd caching framework from Kent. - Fixes for cciss" * 'for-3.10/drivers' of git://git.kernel.dk/linux-block: (66 commits) bcache: Use bd_link_disk_holder() bcache: Allocator cleanup/fixes cciss: bug fix to prevent cciss from loading in kdump crash kernel cciss: add cciss_allow_hpsa module parameter drivers/block/mg_disk.c: add CONFIG_PM_SLEEP to suspend/resume functions mtip32xx: Workaround for unaligned writes bcache: Make sure blocksize isn't smaller than device blocksize bcache: Fix merge_bvec_fn usage for when it modifies the bvm bcache: Correctly check against BIO_MAX_PAGES bcache: Hack around stuff that clones up to bi_max_vecs bcache: Set ra_pages based on backing device's ra_pages bcache: Take data offset from the bdev superblock. mtip32xx: mtip32xx: Disable TRIM support mtip32xx: fix a smatch warning bcache: Disable broken btree fuzz tester bcache: Fix a format string overflow bcache: Fix a minor memory leak on device teardown bcache: Documentation updates bcache: Use WARN_ONCE() instead of __WARN() bcache: Add missing #include <linux/prefetch.h> ...
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-04-30Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "The main changes in this development cycle were: - full dynticks preparatory work by Frederic Weisbecker - factor out the cpu time accounting code better, by Li Zefan - multi-CPU load balancer cleanups and improvements by Joonsoo Kim - various smaller fixes and cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits) sched: Fix init NOHZ_IDLE flag sched: Prevent to re-select dst-cpu in load_balance() sched: Rename load_balance_tmpmask to load_balance_mask sched: Move up affinity check to mitigate useless redoing overhead sched: Don't consider other cpus in our group in case of NEWLY_IDLE sched: Explicitly cpu_idle_type checking in rebalance_domains() sched: Change position of resched_cpu() in load_balance() sched: Fix wrong rq's runnable_avg update with rt tasks sched: Document task_struct::personality field sched/cpuacct/UML: Fix header file dependency bug on the UML build cgroup: Kill subsys.active flag sched/cpuacct: No need to check subsys active state sched/cpuacct: Initialize cpuacct subsystem earlier sched/cpuacct: Initialize root cpuacct earlier sched/cpuacct: Allocate per_cpu cpuusage for root cpuacct statically sched/cpuacct: Clean up cpuacct.h sched/cpuacct: Remove redundant NULL checks in cpuacct_acount_field() sched/cpuacct: Remove redundant NULL checks in cpuacct_charge() sched/cpuacct: Add cpuacct_acount_field() sched/cpuacct: Add cpuacct_init() ...
2013-03-23bcache: A block layer cacheKent Overstreet
Does writethrough and writeback caching, handles unclean shutdown, and has a bunch of other nifty features motivated by real world usage. See the wiki at http://bcache.evilpiepirate.org for more. Signed-off-by: Kent Overstreet <koverstreet@google.com>
2013-03-13userns: Don't allow CLONE_NEWUSER | CLONE_FSEric W. Biederman
Don't allowing sharing the root directory with processes in a different user namespace. There doesn't seem to be any point, and to allow it would require the overhead of putting a user namespace reference in fs_struct (for permission checks) and incrementing that reference count on practically every call to fork. So just perform the inexpensive test of forbidding sharing fs_struct acrosss processes in different user namespaces. We already disallow other forms of threading when unsharing a user namespace so this should be no real burden in practice. This updates setns, clone, and unshare to disallow multiple user namespaces sharing an fs_struct. Cc: stable@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-07cputime: Dynamically scale cputime for full dynticks accountingFrederic Weisbecker
The full dynticks cputime accounting is able to account either using the tick or the context tracking subsystem. This way the housekeeping CPU can keep the low overhead tick based solution. This latter mode has a low jiffies resolution granularity and need to be scaled against CFS precise runtime accounting to improve its result. We are doing this for CONFIG_TICK_CPU_ACCOUNTING, now we also need to expand it to full dynticks accounting dynamic off-case as well. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Kevin Hilman <khilman@linaro.org> Cc: Mats Liljegren <mats.liljegren@enea.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-03-03make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protectAl Viro
... and switch i386 to HAVE_SYSCALL_WRAPPERS, killing open-coded uses of asmlinkage_protect() in a bunch of syscalls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-27fork: unshare: remove dead codeAlan Cox
If new_nsproxy is set we will always call switch_task_namespaces and then set new_nsproxy back to NULL so the reassignment and fall through check are redundant Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-05Merge tag 'full-dynticks-cputime-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into sched/core Pull full-dynticks (user-space execution is undisturbed and receives no timer IRQs) preparation changes that convert the cputime accounting code to be full-dynticks ready, from Frederic Weisbecker: "This implements the cputime accounting on full dynticks CPUs. Typical cputime stats infrastructure relies on the timer tick and its periodic polling on the CPU to account the amount of time spent by the CPUs and the tasks per high level domains such as userspace, kernelspace, guest, ... Now we are preparing to implement full dynticks capability on Linux for Real Time and HPC users who want full CPU isolation. This feature requires a cputime accounting that doesn't depend on the timer tick. To implement it, this new cputime infrastructure plugs into kernel/user/guest boundaries to take snapshots of cputime and flush these to the stats when needed. This performs pretty much like CONFIG_VIRT_CPU_ACCOUNTING except that context location and cputime snaphots are synchronized between write and read side such that the latter can safely retrieve the pending tickless cputime of a task and add it to its latest cputime snapshot to return the correct result to the user." Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-27cputime: Safely read cputime of full dynticks CPUsFrederic Weisbecker
While remotely reading the cputime of a task running in a full dynticks CPU, the values stored in utime/stime fields of struct task_struct may be stale. Its values may be those of the last kernel <-> user transition time snapshot and we need to add the tickless time spent since this snapshot. To fix this, flush the cputime of the dynticks CPUs on kernel <-> user transition and record the time / context where we did this. Then on top of this snapshot and the current time, perform the fixup on the reader side from task_times() accessors. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> [fixed kvm module related build errors] Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
2013-01-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull misc syscall fixes from Al Viro: - compat syscall fixes (discussed back in December) - a couple of "make life easier for sigaltstack stuff by reducing inter-tree dependencies" - fix up compiler/asmlinkage calling convention disagreement of sys_clone() - misc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: sys_clone() needs asmlinkage_protect make sure that /linuxrc has std{in,out,err} x32: fix sigtimedwait x32: fix waitid() switch compat_sys_wait4() and compat_sys_waitid() to COMPAT_SYSCALL_DEFINE switch compat_sys_sigaltstack() to COMPAT_SYSCALL_DEFINE CONFIG_GENERIC_SIGALTSTACK build breakage with asm-generic/syscalls.h Ensure that kernel_init_freeable() is not inlined into non __init code
2013-01-19sys_clone() needs asmlinkage_protectAl Viro
Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-24pidns: Outlaw thread creation after unshare(CLONE_NEWPID)Eric W. Biederman
The sequence: unshare(CLONE_NEWPID) clone(CLONE_THREAD|CLONE_SIGHAND|CLONE_VM) Creates a new process in the new pid namespace without setting pid_ns->child_reaper. After forking this results in a NULL pointer dereference. Avoid this and other nonsense scenarios that can show up after creating a new pid namespace with unshare by adding a new check in copy_prodcess. Pointed-out-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "sigaltstack infrastructure + conversion for x86, alpha and um, COMPAT_SYSCALL_DEFINE infrastructure. Note that there are several conflicts between "unify SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline; resolution is trivial - just remove definitions of SS_ONSTACK and SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and include/uapi/linux/signal.h contains the unified variant." Fixed up conflicts as per Al. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to generic sigaltstack new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those generic compat_sys_sigaltstack() introduce generic sys_sigaltstack(), switch x86 and um to it new helper: compat_user_stack_pointer() new helper: restore_altstack() unify SS_ONSTACK/SS_DISABLE definitions new helper: current_user_stack_pointer() missing user_stack_pointer() instances Bury the conditionals from kernel_thread/kernel_execve series COMPAT_SYSCALL_DEFINE: infrastructure
2012-12-19Bury the conditionals from kernel_thread/kernel_execve seriesAl Viro
All architectures have CONFIG_GENERIC_KERNEL_THREAD CONFIG_GENERIC_KERNEL_EXECVE __ARCH_WANT_SYS_EXECVE None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers of kernel_execve() (which is a trivial wrapper for do_execve() now) left. Kill the conditionals and make both callers use do_execve(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-18fork: protect architectures where THREAD_SIZE >= PAGE_SIZE against fork bombsGlauber Costa
Because those architectures will draw their stacks directly from the page allocator, rather than the slab cache, we can directly pass __GFP_KMEMCG flag, and issue the corresponding free_pages. This code path is taken when the architecture doesn't define CONFIG_ARCH_THREAD_INFO_ALLOCATOR (only ia64 seems to), and has THREAD_SIZE >= PAGE_SIZE. Luckily, most - if not all - of the remaining architectures fall in this category. This will guarantee that every stack page is accounted to the memcg the process currently lives on, and will have the allocations to fail if they go over limit. For the time being, I am defining a new variant of THREADINFO_GFP, not to mess with the other path. Once the slab is also tracked by memcg, we can get rid of that flag. Tested to successfully protect against :(){ :|:& };: Signed-off-by: Glauber Costa <glommer@parallels.com> Acked-by: Frederic Weisbecker <fweisbec@redhat.com> Acked-by: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "While small this set of changes is very significant with respect to containers in general and user namespaces in particular. The user space interface is now complete. This set of changes adds support for unprivileged users to create user namespaces and as a user namespace root to create other namespaces. The tyranny of supporting suid root preventing unprivileged users from using cool new kernel features is broken. This set of changes completes the work on setns, adding support for the pid, user, mount namespaces. This set of changes includes a bunch of basic pid namespace cleanups/simplifications. Of particular significance is the rework of the pid namespace cleanup so it no longer requires sending out tendrils into all kinds of unexpected cleanup paths for operation. At least one case of broken error handling is fixed by this cleanup. The files under /proc/<pid>/ns/ have been converted from regular files to magic symlinks which prevents incorrect caching by the VFS, ensuring the files always refer to the namespace the process is currently using and ensuring that the ptrace_mayaccess permission checks are always applied. The files under /proc/<pid>/ns/ have been given stable inode numbers so it is now possible to see if different processes share the same namespaces. Through the David Miller's net tree are changes to relax many of the permission checks in the networking stack to allowing the user namespace root to usefully use the networking stack. Similar changes for the mount namespace and the pid namespace are coming through my tree. Two small changes to add user namespace support were commited here adn in David Miller's -net tree so that I could complete the work on the /proc/<pid>/ns/ files in this tree. Work remains to make it safe to build user namespaces and 9p, afs, ceph, cifs, coda, gfs2, ncpfs, nfs, nfsd, ocfs2, and xfs so the Kconfig guard remains in place preventing that user namespaces from being built when any of those filesystems are enabled. Future design work remains to allow root users outside of the initial user namespace to mount more than just /proc and /sys." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (38 commits) proc: Usable inode numbers for the namespace file descriptors. proc: Fix the namespace inode permission checks. proc: Generalize proc inode allocation userns: Allow unprivilged mounts of proc and sysfs userns: For /proc/self/{uid,gid}_map derive the lower userns from the struct file procfs: Print task uids and gids in the userns that opened the proc file userns: Implement unshare of the user namespace userns: Implent proc namespace operations userns: Kill task_user_ns userns: Make create_new_namespaces take a user_ns parameter userns: Allow unprivileged use of setns. userns: Allow unprivileged users to create new namespaces userns: Allow setting a userns mapping to your current uid. userns: Allow chown and setgid preservation userns: Allow unprivileged users to create user namespaces. userns: Ignore suid and sgid on binaries if the uid or gid can not be mapped userns: fix return value on mntns_install() failure vfs: Allow unprivileged manipulation of the mount namespace. vfs: Only support slave subtrees across different user namespaces vfs: Add a user namespace reference from struct mnt_namespace ...
2012-12-16Merge tag 'balancenuma-v11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma Pull Automatic NUMA Balancing bare-bones from Mel Gorman: "There are three implementations for NUMA balancing, this tree (balancenuma), numacore which has been developed in tip/master and autonuma which is in aa.git. In almost all respects balancenuma is the dumbest of the three because its main impact is on the VM side with no attempt to be smart about scheduling. In the interest of getting the ball rolling, it would be desirable to see this much merged for 3.8 with the view to building scheduler smarts on top and adapting the VM where required for 3.9. The most recent set of comparisons available from different people are mel: https://lkml.org/lkml/2012/12/9/108 mingo: https://lkml.org/lkml/2012/12/7/331 tglx: https://lkml.org/lkml/2012/12/10/437 srikar: https://lkml.org/lkml/2012/12/10/397 The results are a mixed bag. In my own tests, balancenuma does reasonably well. It's dumb as rocks and does not regress against mainline. On the other hand, Ingo's tests shows that balancenuma is incapable of converging for this workloads driven by perf which is bad but is potentially explained by the lack of scheduler smarts. Thomas' results show balancenuma improves on mainline but falls far short of numacore or autonuma. Srikar's results indicate we all suffer on a large machine with imbalanced node sizes. My own testing showed that recent numacore results have improved dramatically, particularly in the last week but not universally. We've butted heads heavily on system CPU usage and high levels of migration even when it shows that overall performance is better. There are also cases where it regresses. Of interest is that for specjbb in some configurations it will regress for lower numbers of warehouses and show gains for higher numbers which is not reported by the tool by default and sometimes missed in treports. Recently I reported for numacore that the JVM was crashing with NullPointerExceptions but currently it's unclear what the source of this problem is. Initially I thought it was in how numacore batch handles PTEs but I'm no longer think this is the case. It's possible numacore is just able to trigger it due to higher rates of migration. These reports were quite late in the cycle so I/we would like to start with this tree as it contains much of the code we can agree on and has not changed significantly over the last 2-3 weeks." * tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits) mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable mm/rmap: Convert the struct anon_vma::mutex to an rwsem mm: migrate: Account a transhuge page properly when rate limiting mm: numa: Account for failed allocations and isolations as migration failures mm: numa: Add THP migration for the NUMA working set scanning fault case build fix mm: numa: Add THP migration for the NUMA working set scanning fault case. mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG mm: sched: numa: Control enabling and disabling of NUMA balancing mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships mm: numa: migrate: Set last_nid on newly allocated page mm: numa: split_huge_page: Transfer last_nid on tail page mm: numa: Introduce last_nid to the page frame sched: numa: Slowly increase the scanning period as NUMA faults are handled mm: numa: Rate limit setting of pte_numa if node is saturated mm: numa: Rate limit the amount of memory that is migrated between nodes mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting mm: numa: Migrate pages handled during a pmd_numa hinting fault mm: numa: Migrate on reference policy ...
2012-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull big execve/kernel_thread/fork unification series from Al Viro: "All architectures are converted to new model. Quite a bit of that stuff is actually shared with architecture trees; in such cases it's literally shared branch pulled by both, not a cherry-pick. A lot of ugliness and black magic is gone (-3KLoC total in this one): - kernel_thread()/kernel_execve()/sys_execve() redesign. We don't do syscalls from kernel anymore for either kernel_thread() or kernel_execve(): kernel_thread() is essentially clone(2) with callback run before we return to userland, the callbacks either never return or do successful do_execve() before returning. kernel_execve() is a wrapper for do_execve() - it doesn't need to do transition to user mode anymore. As a result kernel_thread() and kernel_execve() are arch-independent now - they live in kernel/fork.c and fs/exec.c resp. sys_execve() is also in fs/exec.c and it's completely architecture-independent. - daemonize() is gone, along with its parts in fs/*.c - struct pt_regs * is no longer passed to do_fork/copy_process/ copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump. - sys_fork()/sys_vfork()/sys_clone() unified; some architectures still need wrappers (ones with callee-saved registers not saved in pt_regs on syscall entry), but the main part of those suckers is in kernel/fork.c now." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits) do_coredump(): get rid of pt_regs argument print_fatal_signal(): get rid of pt_regs argument ptrace_signal(): get rid of unused arguments get rid of ptrace_signal_deliver() arguments new helper: signal_pt_regs() unify default ptrace_signal_deliver flagday: kill pt_regs argument of do_fork() death to idle_regs() don't pass regs to copy_process() flagday: don't pass regs to copy_thread() bfin: switch to generic vfork, get rid of pointless wrappers xtensa: switch to generic clone() openrisc: switch to use of generic fork and clone unicore32: switch to generic clone(2) score: switch to generic fork/vfork/clone c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone() take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h mn10300: switch to generic fork/vfork/clone h8300: switch to generic fork/vfork/clone tile: switch to generic clone() ... Conflicts: arch/microblaze/include/asm/Kbuild
2012-12-12Merge branch 'for-3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup changes from Tejun Heo: "A lot of activities on cgroup side. The big changes are focused on making cgroup hierarchy handling saner. - cgroup_rmdir() had peculiar semantics - it allowed cgroup destruction to be vetoed by individual controllers and tried to drain refcnt synchronously. The vetoing never worked properly and caused good deal of contortions in cgroup. memcg was the last reamining user. Michal Hocko removed the usage and cgroup_rmdir() path has been simplified significantly. This was done in a separate branch so that the memcg people can base further memcg changes on top. - The above allowed cleaning up cgroup lifecycle management and implementation of generic cgroup iterators which are used to improve hierarchy support. - cgroup_freezer updated to allow migration in and out of a frozen cgroup and handle hierarchy. If a cgroup is frozen, all descendant cgroups are frozen. - netcls_cgroup and netprio_cgroup updated to handle hierarchy properly. - Various fixes and cleanups. - Two merge commits. One to pull in memcg and rmdir cleanups (needed to build iterators). The other pulled in cgroup/for-3.7-fixes for device_cgroup fixes so that further device_cgroup patches can be stacked on top." Fixed up a trivial conflict in mm/memcontrol.c as per Tejun (due to commit bea8c150a7 ("memcg: fix hotplugged memory zone oops") in master touching code close to commit 2ef37d3fe4 ("memcg: Simplify mem_cgroup_force_empty_list error handling") in for-3.8) * 'for-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (65 commits) cgroup: update Documentation/cgroups/00-INDEX cgroup_rm_file: don't delete the uncreated files cgroup: remove subsystem files when remounting cgroup cgroup: use cgroup_addrm_files() in cgroup_clear_directory() cgroup: warn about broken hierarchies only after css_online cgroup: list_del_init() on removed events cgroup: fix lockdep warning for event_control cgroup: move list add after list head initilization netprio_cgroup: allow nesting and inherit config on cgroup creation netprio_cgroup: implement netprio[_set]_prio() helpers netprio_cgroup: use cgroup->id instead of cgroup_netprio_state->prioidx netprio_cgroup: reimplement priomap expansion netprio_cgroup: shorten variable names in extend_netdev_table() netprio_cgroup: simplify write_priomap() netcls_cgroup: move config inheritance to ->css_online() and remove .broken_hierarchy marking cgroup: remove obsolete guarantee from cgroup_task_migrate. cgroup: add cgroup->id cgroup, cpuset: remove cgroup_subsys->post_clone() cgroup: s/CGRP_CLONE_CHILDREN/CGRP_CPUSET_CLONE_CHILDREN/ cgroup: rename ->create/post_create/pre_destroy/destroy() to ->css_alloc/online/offline/free() ...
2012-12-11Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The biggest change affects group scheduling: we now track the runnable average on a per-task entity basis, allowing a smoother, exponential decay average based load/weight estimation instead of the previous binary on-the-runqueue/off-the-runqueue load weight method. This will inevitably disturb workloads that were in some sort of borderline balancing state or unstable equilibrium, so an eye has to be kept on regressions. For that reason the new load average is only limited to group scheduling (shares distribution) at the moment (which was also hurting the most from the prior, crude weight calculation and whose scheduling quality wins most from this change) - but we plan to extend this to regular SMP balancing as well in the future, which will simplify and speed up things a bit. Other changes involve ongoing preparatory work to extend NOHZ to the scheduler as well, eventually allowing completely irq-free user-space execution." * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits) Revert "sched/autogroup: Fix crash on reboot when autogroup is disabled" cputime: Comment cputime's adjusting code cputime: Consolidate cputime adjustment code cputime: Rename thread_group_times to thread_group_cputime_adjusted cputime: Move thread_group_cputime() to sched code vtime: Warn if irqs aren't disabled on system time accounting APIs vtime: No need to disable irqs on vtime_account() vtime: Consolidate a bit the ctx switch code vtime: Explicitly account pending user time on process tick vtime: Remove the underscore prefix invasion sched/autogroup: Fix crash on reboot when autogroup is disabled cputime: Separate irqtime accounting from generic vtime cputime: Specialize irq vtime hooks kvm: Directly account vtime to system on guest switch vtime: Make vtime_account_system() irqsafe vtime: Gather vtime declarations to their own header file sched: Describe CFS load-balancer sched: Introduce temporary FAIR_GROUP_SCHED dependency for load-tracking sched: Make __update_entity_runnable_avg() fast sched: Update_cfs_shares at period edge ...
2012-12-11mm: sched: numa: Delay PTE scanning until a task is scheduled on a new nodeMel Gorman
Due to the fact that migrations are driven by the CPU a task is running on there is no point tracking NUMA faults until one task runs on a new node. This patch tracks the first node used by an address space. Until it changes, PTE scanning is disabled and no NUMA hinting faults are trapped. This should help workloads that are short-lived, do not care about NUMA placement or have bound themselves to a single node. This takes advantage of the logic in "mm: sched: numa: Implement slow start for working set sampling" to delay when the checks are made. This will take advantage of processes that set their CPU and node bindings early in their lifetime. It will also potentially allow any initial load balancing to take place. Signed-off-by: Mel Gorman <mgorman@suse.de>
2012-11-29flagday: kill pt_regs argument of do_fork()Al Viro
2012-11-28death to idle_regs()Al Viro
2012-11-28don't pass regs to copy_process()Al Viro
2012-11-28flagday: don't pass regs to copy_thread()Al Viro
2012-11-28generic sys_fork / sys_vfork / sys_cloneAl Viro
... and get rid of idiotic struct pt_regs * in asm-generic/syscalls.h prototypes of the same, while we are at it. Eventually we want those in linux/syscalls.h, of course, but that'll have to wait a bit. Note that there are *three* variants of sys_clone() order of arguments. Braindamage galore... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28cputime: Consolidate cputime adjustment codeFrederic Weisbecker
task_cputime_adjusted() and thread_group_cputime_adjusted() essentially share the same code. They just don't use the same source: * The first function uses the cputime in the task struct and the previous adjusted snapshot that ensures monotonicity. * The second adds the cputime of all tasks in the group and the previous adjusted snapshot of the whole group from the signal structure. Just consolidate the common code that does the adjustment. These functions just need to fetch the values from the appropriate source. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-11-20userns: Implement unshare of the user namespaceEric W. Biederman
- Add CLONE_THREAD to the unshare flags if CLONE_NEWUSER is selected As changing user namespaces is only valid if all there is only a single thread. - Restore the code to add CLONE_VM if CLONE_THREAD is selected and the code to addCLONE_SIGHAND if CLONE_VM is selected. Making the constraints in the code clear. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-11-19userns: Allow unprivileged users to create user namespaces.Eric W. Biederman
Now that we have been through every permission check in the kernel having uid == 0 and gid == 0 in your local user namespace no longer adds any special privileges. Even having a full set of caps in your local user namespace is safe because capabilies are relative to your local user namespace, and do not confer unexpected privileges. Over the long term this should allow much more of the kernels functionality to be safely used by non-root users. Functionality like unsharing the mount namespace that is only unsafe because it can fool applications whose privileges are raised when they are executed. Since those applications have no privileges in a user namespaces it becomes safe to spoof and confuse those applications all you want. Those capabilities will still need to be enabled carefully because we may still need things like rlimits on the number of unprivileged mounts but that is to avoid DOS attacks not to avoid fooling root owned processes. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-11-19pidns: Support unsharing the pid namespace.Eric W. Biederman
Unsharing of the pid namespace unlike unsharing of other namespaces does not take affect immediately. Instead it affects the children created with fork and clone. The first of these children becomes the init process of the new pid namespace, the rest become oddball children of pid 0. From the point of view of the new pid namespace the process that created it is pid 0, as it's pid does not map. A couple of different semantics were considered but this one was settled on because it is easy to implement and it is usable from pam modules. The core reasons for the existence of unshare. I took a survey of the callers of pam modules and the following appears to be a representative sample of their logic. { setup stuff include pam child = fork(); if (!child) { setuid() exec /bin/bash } waitpid(child); pam and other cleanup } As you can see there is a fork to create the unprivileged user space process. Which means that the unprivileged user space process will appear as pid 1 in the new pid namespace. Further most login processes do not cope with extraneous children which means shifting the duty of reaping extraneous child process to the creator of those extraneous children makes the system more comprehensible. The practical reason for this set of pid namespace semantics is that it is simple to implement and verify they work correctly. Whereas an implementation that requres changing the struct pid on a process comes with a lot more races and pain. Not the least of which is that glibc caches getpid(). These semantics are implemented by having two notions of the pid namespace of a proces. There is task_active_pid_ns which is the pid namspace the process was created with and the pid namespace that all pids are presented to that process in. The task_active_pid_ns is stored in the struct pid of the task. Then there is the pid namespace that will be used for children that pid namespace is stored in task->nsproxy->pid_ns. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-11-19pidns: Consolidate initialzation of special init task stateEric W. Biederman
Instead of setting child_reaper and SIGNAL_UNKILLABLE one way for the system init process, and another way for pid namespace init processes test pid->nr == 1 and use the same code for both. For the global init this results in SIGNAL_UNKILLABLE being set much earlier in the initialization process. This is a small cleanup and it paves the way for allowing unshare and enter of the pid namespace as that path like our global init also will not set CLONE_NEWPID. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-11-19pidns: Make the pidns proc mount/umount logic obvious.Eric W. Biederman
Track the number of pids in the proc hash table. When the number of pids goes to 0 schedule work to unmount the kernel mount of proc. Move the mount of proc into alloc_pid when we allocate the pid for init. Remove the surprising calls of pid_ns_release proc in fork and proc_flush_task. Those code paths really shouldn't know about proc namespace implementation details and people have demonstrated several times that finding and understanding those code paths is difficult and non-obvious. Because of the call path detach pid is alwasy called with the rtnl_lock held free_pid is not allowed to sleep, so the work to unmounting proc is moved to a work queue. This has the side benefit of not blocking the entire world waiting for the unnecessary rcu_barrier in deactivate_locked_super. In the process of making the code clear and obvious this fixes a bug reported by Gao feng <gaofeng@cn.fujitsu.com> where we would leak a mount of proc during clone(CLONE_NEWPID|CLONE_NEWNET) if copy_pid_ns succeeded and copy_net_ns failed. Acked-by: "Serge E. Hallyn" <serge@hallyn.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-11-19pidns: Use task_active_pid_ns where appropriateEric W. Biederman
The expressions tsk->nsproxy->pid_ns and task_active_pid_ns aka ns_of_pid(task_pid(tsk)) should have the same number of cache line misses with the practical difference that ns_of_pid(task_pid(tsk)) is released later in a processes life. Furthermore by using task_active_pid_ns it becomes trivial to write an unshare implementation for the the pid namespace. So I have used task_active_pid_ns everywhere I can. In fork since the pid has not yet been attached to the process I use ns_of_pid, to achieve the same effect. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-11-16uprobes: Use percpu_rw_semaphore to fix register/unregister vs dup_mmap() raceOleg Nesterov
This was always racy, but 268720903f87e0b84b161626c4447b81671b5d18 "uprobes: Rework register_for_each_vma() to make it O(n)" should be blamed anyway, it made everything worse and I didn't notice. register/unregister call build_map_info() and then do install/remove breakpoint for every mm which mmaps inode/offset. This can obviously race with fork()->dup_mmap() in between and we can miss the child. uprobe_register() could be easily fixed but unregister is much worse, the new mm inherits "int3" from parent and there is no way to detect this if uprobe goes away. So this patch simply adds percpu_down_read/up_read around dup_mmap(), and percpu_down_write/up_write into register_for_each_vma(). This adds 2 new hooks into dup_mmap() but we can kill uprobe_dup_mmap() and fold it into uprobe_end_dup_mmap(). Reported-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2012-10-16cgroup: cgroup_subsys->fork() should be called after the task is added to ↵Tejun Heo
css_set cgroup core has a bug which violates a basic rule about event notifications - when a new entity needs to be added, you add that to the notification list first and then make the new entity conform to the current state. If done in the reverse order, an event happening inbetween will be lost. cgroup_subsys->fork() is invoked way before the new task is added to the css_set. Currently, cgroup_freezer is the only user of ->fork() and uses it to make new tasks conform to the current state of the freezer. If FROZEN state is requested while fork is in progress between cgroup_fork_callbacks() and cgroup_post_fork(), the child could escape freezing - the cgroup isn't frozen when ->fork() is called and the freezer couldn't see the new task on the css_set. This patch moves cgroup_subsys->fork() invocation to cgroup_post_fork() after the new task is added to the css_set. cgroup_fork_callbacks() is removed. Because now a task may be migrated during cgroup_subsys->fork(), freezer_fork() is updated so that it adheres to the usual RCU locking and the rather pointless comment on why locking can be different there is removed (if it doesn't make anything simpler, why even bother?). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@vger.kernel.org
2012-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull generic execve() changes from Al Viro: "This introduces the generic kernel_thread() and kernel_execve() functions, and switches x86, arm, alpha, um and s390 over to them." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits) s390: convert to generic kernel_execve() s390: switch to generic kernel_thread() s390: fold kernel_thread_helper() into ret_from_fork() s390: fold execve_tail() into start_thread(), convert to generic sys_execve() um: switch to generic kernel_thread() x86, um/x86: switch to generic sys_execve and kernel_execve x86: split ret_from_fork alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve() alpha: switch to generic kernel_thread() alpha: switch to generic sys_execve() arm: get rid of execve wrapper, switch to generic execve() implementation arm: optimized current_pt_regs() arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve() arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk] generic sys_execve() generic kernel_execve() new helper: current_pt_regs() preparation for generic kernel_thread() um: kill thread->forking um: let signal_delivered() do SIGTRAP on singlestepping into handler ...
2012-10-09mm: interval tree updatesMichel Lespinasse
Update the generic interval tree code that was introduced in "mm: replace vma prio_tree with an interval tree". Changes: - fixed 'endpoing' typo noticed by Andrew Morton - replaced include/linux/interval_tree_tmpl.h, which was used as a template (including it automatically defined the interval tree functions) with include/linux/interval_tree_generic.h, which only defines a preprocessor macro INTERVAL_TREE_DEFINE(), which itself defines the interval tree functions when invoked. Now that is a very long macro which is unfortunate, but it does make the usage sites (lib/interval_tree.c and mm/interval_tree.c) a bit nicer than previously. - make use of RB_DECLARE_CALLBACKS() in the INTERVAL_TREE_DEFINE() macro, instead of duplicating that code in the interval tree template. - replaced vma_interval_tree_add(), which was actually handling the nonlinear and interval tree cases, with vma_interval_tree_insert_after() which handles only the interval tree case and has an API that is more consistent with the other interval tree handling functions. The nonlinear case is now handled explicitly in kernel/fork.c dup_mmap(). Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Daniel Santos <daniel.santos@pobox.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: replace vma prio_tree with an interval treeMichel Lespinasse
Implement an interval tree as a replacement for the VMA prio_tree. The algorithms are similar to lib/interval_tree.c; however that code can't be directly reused as the interval endpoints are not explicitly stored in the VMA. So instead, the common algorithm is moved into a template and the details (node type, how to get interval endpoints from the node, etc) are filled in using the C preprocessor. Once the interval tree functions are available, using them as a replacement to the VMA prio tree is a relatively simple, mechanical job. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09oom: remove deprecated oom_adjDavidlohr Bueso
The deprecated /proc/<pid>/oom_adj is scheduled for removal this month. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Acked-by: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_EXECUTABLE and mm->num_exe_file_vmasKonstantin Khlebnikov
Currently the kernel sets mm->exe_file during sys_execve() and then tracks number of vmas with VM_EXECUTABLE flag in mm->num_exe_file_vmas, as soon as this counter drops to zero kernel resets mm->exe_file to NULL. Plus it resets mm->exe_file at last mmput() when mm->mm_users drops to zero. VMA with VM_EXECUTABLE flag appears after mapping file with flag MAP_EXECUTABLE, such vmas can appears only at sys_execve() or after vma splitting, because sys_mmap ignores this flag. Usually binfmt module sets mm->exe_file and mmaps executable vmas with this file, they hold mm->exe_file while task is running. comment from v2.6.25-6245-g925d1c4 ("procfs task exe symlink"), where all this stuff was introduced: > The kernel implements readlink of /proc/pid/exe by getting the file from > the first executable VMA. Then the path to the file is reconstructed and > reported as the result. > > Because of the VMA walk the code is slightly different on nommu systems. > This patch avoids separate /proc/pid/exe code on nommu systems. Instead of > walking the VMAs to find the first executable file-backed VMA we store a > reference to the exec'd file in the mm_struct. > > That reference would prevent the filesystem holding the executable file > from being unmounted even after unmapping the VMAs. So we track the number > of VM_EXECUTABLE VMAs and drop the new reference when the last one is > unmapped. This avoids pinning the mounted filesystem. exe_file's vma accounting is hooked into every file mmap/unmmap and vma split/merge just to fix some hypothetical pinning fs from umounting by mm, which already unmapped all its executable files, but still alive. Seems like currently nobody depends on this behaviour. We can try to remove this logic and keep mm->exe_file until final mmput(). mm->exe_file is still protected with mm->mmap_sem, because we want to change it via new sys_prctl(PR_SET_MM_EXE_FILE). Also via this syscall task can change its mm->exe_file and unpin mountpoint explicitly. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: use mm->exe_file instead of first VM_EXECUTABLE vma->vm_fileKonstantin Khlebnikov
Some security modules and oprofile still uses VM_EXECUTABLE for retrieving a task's executable file. After this patch they will use mm->exe_file directly. mm->exe_file is protected with mm->mmap_sem, so locking stays the same. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [arch/tile] Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> [tomoyo] Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) GRE now works over ipv6, from Dmitry Kozlov. 2) Make SCTP more network namespace aware, from Eric Biederman. 3) TEAM driver now works with non-ethernet devices, from Jiri Pirko. 4) Make openvswitch network namespace aware, from Pravin B Shelar. 5) IPV6 NAT implementation, from Patrick McHardy. 6) Server side support for TCP Fast Open, from Jerry Chu and others. 7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel Borkmann. 8) Increate the loopback default MTU to 64K, from Eric Dumazet. 9) Use a per-task rather than per-socket page fragment allocator for outgoing networking traffic. This benefits processes that have very many mostly idle sockets, which is quite common. From Eric Dumazet. 10) Use up to 32K for page fragment allocations, with fallbacks to smaller sizes when higher order page allocations fail. Benefits are a) less segments for driver to process b) less calls to page allocator c) less waste of space. From Eric Dumazet. 11) Allow GRO to be used on GRE tunnels, from Eric Dumazet. 12) VXLAN device driver, one way to handle VLAN issues such as the limitation of 4096 VLAN IDs yet still have some level of isolation. From Stephen Hemminger. 13) As usual there is a large boatload of driver changes, with the scale perhaps tilted towards the wireless side this time around. Fix up various fairly trivial conflicts, mostly caused by the user namespace changes. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits) hyperv: Add buffer for extended info after the RNDIS response message. hyperv: Report actual status in receive completion packet hyperv: Remove extra allocated space for recv_pkt_list elements hyperv: Fix page buffer handling in rndis_filter_send_request() hyperv: Fix the missing return value in rndis_filter_set_packet_filter() hyperv: Fix the max_xfer_size in RNDIS initialization vxlan: put UDP socket in correct namespace vxlan: Depend on CONFIG_INET sfc: Fix the reported priorities of different filter types sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP sfc: Fix loopback self-test with separate_tx_channels=1 sfc: Fix MCDI structure field lookup sfc: Add parentheses around use of bitfield macro arguments sfc: Fix null function pointer in efx_sriov_channel_type vxlan: virtual extensible lan igmp: export symbol ip_mc_leave_group netlink: add attributes to fdb interface tg3: unconditionally select HWMON support when tg3 is enabled. Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT" gre: fix sparse warning ...
