path: root/kernel/cpu.c
2018-08-15cpu/hotplug: Non-SMP machines do not make use of booted_onceAbel Vesa
commit 269777aa530f3438ec1781586cdac0b5fe47b061 upstream. Commit 0cc3cd21657b ("cpu/hotplug: Boot HT siblings at least once") breaks non-SMP builds. [ I suspect the 'bool' fields should just be made to be bitfields and be exposed regardless of configuration, but that's a separate cleanup that I'll leave to the owners of this file for later. - Linus ] Fixes: 0cc3cd21657b ("cpu/hotplug: Boot HT siblings at least once") Cc: Dave Hansen <dave.hansen@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Abel Vesa <abelvesa@linux.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Fix SMT supported evaluationThomas Gleixner
commit bc2d8d262cba5736332cbc866acb11b1c5748aa9 upstream Josh reported that the late SMT evaluation in cpu_smt_state_init() sets cpu_smt_control to CPU_SMT_NOT_SUPPORTED in case that 'nosmt' was supplied on the kernel command line as it cannot differentiate between SMT disabled by BIOS and SMT soft disable via 'nosmt'. That wreckages the state and makes the sysfs interface unusable. Rework this so that during bringup of the non boot CPUs the availability of SMT is determined in cpu_smt_allowed(). If a newly booted CPU is not a 'primary' thread then set the local cpu_smt_available marker and evaluate this explicitely right after the initial SMP bringup has finished. SMT evaulation on x86 is a trainwreck as the firmware has all the information _before_ booting the kernel, but there is no interface to query it. Fixes: 73d5e2b47264 ("cpu/hotplug: detect SMT disabled by BIOS") Reported-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: detect SMT disabled by BIOSJosh Poimboeuf
commit 73d5e2b472640b1fcdb61ae8be389912ef211bda upstream If SMT is disabled in BIOS, the CPU code doesn't properly detect it. The /sys/devices/system/cpu/smt/control file shows 'on', and the 'l1tf' vulnerabilities file shows SMT as vulnerable. Fix it by forcing 'cpu_smt_control' to CPU_SMT_NOT_SUPPORTED in such a case. Unfortunately the detection can only be done after bringing all the CPUs online, so we have to overwrite any previous writes to the variable. Reported-by: Joe Mario <jmario@redhat.com> Tested-by: Jiri Kosina <jkosina@suse.cz> Fixes: f048c399e0f7 ("x86/topology: Provide topology_smt_supported()") Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Set CPU_SMT_NOT_SUPPORTED earlyThomas Gleixner
commit fee0aede6f4739c87179eca76136f83210953b86 upstream The CPU_SMT_NOT_SUPPORTED state is set (if the processor does not support SMT) when the sysfs SMT control file is initialized. That was fine so far as this was only required to make the output of the control file correct and to prevent writes in that case. With the upcoming l1tf command line parameter, this needs to be set up before the L1TF mitigation selection and command line parsing happens. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Jiri Kosina <jkosina@suse.cz> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Link: https://lkml.kernel.org/r/20180713142323.121795971@linutronix.de Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Expose SMT control init functionJiri Kosina
commit 8e1b706b6e819bed215c0db16345568864660393 upstream The L1TF mitigation will gain a commend line parameter which allows to set a combination of hypervisor mitigation and SMT control. Expose cpu_smt_disable() so the command line parser can tweak SMT settings. [ tglx: Split out of larger patch and made it preserve an already existing force off state ] Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Jiri Kosina <jkosina@suse.cz> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Link: https://lkml.kernel.org/r/20180713142323.039715135@linutronix.de Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Online siblings when SMT control is turned onThomas Gleixner
commit 215af5499d9e2b55f111d2431ea20218115f29b3 upstream Writing 'off' to /sys/devices/system/cpu/smt/control offlines all SMT siblings. Writing 'on' merily enables the abilify to online them, but does not online them automatically. Make 'on' more useful by onlining all offline siblings. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15x86/KVM: Warn user if KVM is loaded SMT and L1TF CPU bug being presentKonrad Rzeszutek Wilk
commit 26acfb666a473d960f0fd971fe68f3e3ad16c70b upstream If the L1TF CPU bug is present we allow the KVM module to be loaded as the major of users that use Linux and KVM have trusted guests and do not want a broken setup. Cloud vendors are the ones that are uncomfortable with CVE 2018-3620 and as such they are the ones that should set nosmt to one. Setting 'nosmt' means that the system administrator also needs to disable SMT (Hyper-threading) in the BIOS, or via the 'nosmt' command line parameter, or via the /sys/devices/system/cpu/smt/control. See commit 05736e4ac13c ("cpu/hotplug: Provide knobs to control SMT"). Other mitigations are to use task affinity, cpu sets, interrupt binding, etc - anything to make sure that _only_ the same guests vCPUs are running on sibling threads. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Boot HT siblings at least onceThomas Gleixner
commit 0cc3cd21657be04cb0559fe8063f2130493f92cf upstream Due to the way Machine Check Exceptions work on X86 hyperthreads it's required to boot up _all_ logical cores at least once in order to set the CR4.MCE bit. So instead of ignoring the sibling threads right away, let them boot up once so they can configure themselves. After they came out of the initial boot stage check whether its a "secondary" sibling and cancel the operation which puts the CPU back into offline state. [dwmw2: Backport to 4.9] Reported-by: Dave Hansen <dave.hansen@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Tony Luck <tony.luck@intel.com> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Provide knobs to control SMTThomas Gleixner
commit 05736e4ac13c08a4a9b1ef2de26dd31a32cbee57 upstream Provide a command line and a sysfs knob to control SMT. The command line options are: 'nosmt': Enumerate secondary threads, but do not online them 'nosmt=force': Ignore secondary threads completely during enumeration via MP table and ACPI/MADT. The sysfs control file has the following states (read/write): 'on': SMT is enabled. Secondary threads can be freely onlined 'off': SMT is disabled. Secondary threads, even if enumerated cannot be onlined 'forceoff': SMT is permanentely disabled. Writes to the control file are rejected. 'notsupported': SMT is not supported by the CPU The command line option 'nosmt' sets the sysfs control to 'off'. This can be changed to 'on' to reenable SMT during runtime. The command line option 'nosmt=force' sets the sysfs control to 'forceoff'. This cannot be changed during runtime. When SMT is 'on' and the control file is changed to 'off' then all online secondary threads are offlined and attempts to online a secondary thread later on are rejected. When SMT is 'off' and the control file is changed to 'on' then secondary threads can be onlined again. The 'off' -> 'on' transition does not automatically online the secondary threads. When the control file is set to 'forceoff', the behaviour is the same as setting it to 'off', but the operation is irreversible and later writes to the control file are rejected. When the control status is 'notsupported' then writes to the control file are rejected. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Split do_cpu_down()Thomas Gleixner
commit cc1fe215e1efa406b03aa4389e6269b61342dec5 upstream Split out the inner workings of do_cpu_down() to allow reuse of that function for the upcoming SMT disabling mechanism. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Make bringup/teardown of smp threads symmetricThomas Gleixner
commit c4de65696d865c225fda3b9913b31284ea65ea96 upstream The asymmetry caused a warning to trigger if the bootup was stopped in state CPUHP_AP_ONLINE_IDLE. The warning no longer triggers as kthread_park() can now be invoked on already or still parked threads. But there is still no reason to have this be asymmetric. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15init: rename and re-order boot_cpu_state_init()Linus Torvalds
commit b5b1404d0815894de0690de8a1ab58269e56eae6 upstream. This is purely a preparatory patch for upcoming changes during the 4.19 merge window. We have a function called "boot_cpu_state_init()" that isn't really about the bootup cpu state: that is done much earlier by the similarly named "boot_cpu_init()" (note lack of "state" in name). This function initializes some hotplug CPU state, and needs to run after the percpu data has been properly initialized. It even has a comment to that effect. Except it _doesn't_ actually run after the percpu data has been properly initialized. On x86 it happens to do that, but on at least arm and arm64, the percpu base pointers are initialized by the arch-specific 'smp_prepare_boot_cpu()' hook, which ran _after_ boot_cpu_state_init(). This had some unexpected results, and in particular we have a patch pending for the merge window that did the obvious cleanup of using 'this_cpu_write()' in the cpu hotplug init code: - per_cpu_ptr(&cpuhp_state, smp_processor_id())->state = CPUHP_ONLINE; + this_cpu_write(cpuhp_state.state, CPUHP_ONLINE); which is obviously the right thing to do. Except because of the ordering issue, it actually failed miserably and unexpectedly on arm64. So this just fixes the ordering, and changes the name of the function to be 'boot_cpu_hotplug_init()' to make it obvious that it's about cpu hotplug state, because the core CPU state was supposed to have already been done earlier. Marked for stable, since the (not yet merged) patch that will show this problem is marked for stable. Reported-by: Vlastimil Babka <vbabka@suse.cz> Reported-by: Mian Yousaf Kaukab <yousaf.kaukab@suse.com> Suggested-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-13cpuhotplug: Link lock stacks for hotplug callbacksThomas Gleixner
[ Upstream commit 49dfe2a6779717d9c18395684ee31bdc98b22e53 ] The CPU hotplug callbacks are not covered by lockdep versus the cpu hotplug rwsem. CPU0 CPU1 cpuhp_setup_state(STATE, startup, teardown); cpus_read_lock(); invoke_callback_on_ap(); kick_hotplug_thread(ap); wait_for_completion(); hotplug_thread_fn() lock(m); do_stuff(); unlock(m); Lockdep does not know about this dependency and will not trigger on the following code sequence: lock(m); cpus_read_lock(); Add a lockdep map and connect the initiators lock chain with the hotplug thread lock chain, so potential deadlocks can be detected. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20170524081549.709375845@linutronix.de Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02timers: Reinitialize per cpu bases on hotplugThomas Gleixner
commit 26456f87aca7157c057de65c9414b37f1ab881d1 upstream. The timer wheel bases are not (re)initialized on CPU hotplug. That leaves them with a potentially stale clk and next_expiry valuem, which can cause trouble then the CPU is plugged. Add a prepare callback which forwards the clock, sets next_expiry to far in the future and reset the control flags to a known state. Set base->must_forward_clk so the first timer which is queued will try to forward the clock to current jiffies. Fixes: 500462a9de65 ("timers: Switch to a non-cascading wheel") Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Anna-Maria Gleixner <anna-maria@linutronix.de> Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1712272152200.2431@nanos Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14smp/hotplug: Move step CPUHP_AP_SMPCFD_DYING to the correct placeLai Jiangshan
commit 46febd37f9c758b05cd25feae8512f22584742fe upstream. Commit 31487f8328f2 ("smp/cfd: Convert core to hotplug state machine") accidently put this step on the wrong place. The step should be at the cpuhp_ap_states[] rather than the cpuhp_bp_states[]. grep smpcfd /sys/devices/system/cpu/hotplug/states 40: smpcfd:prepare 129: smpcfd:dying "smpcfd:dying" was missing before. So was the invocation of the function smpcfd_dying_cpu(). Fixes: 31487f8328f2 ("smp/cfd: Convert core to hotplug state machine") Signed-off-by: Lai Jiangshan <jiangshanlai@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Richard Weinberger <richard@nod.at> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Link: https://lkml.kernel.org/r/20171128131954.81229-1-jiangshanlai@gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06smp/hotplug: Replace BUG_ON and react usefulThomas Gleixner
commit dea1d0f5f1284e3defee4b8484d9fc230686cd42 upstream. The move of the unpark functions to the control thread moved the BUG_ON() there as well. While it made some sense in the idle thread of the upcoming CPU, it's bogus to crash the control thread on the already online CPU, especially as the function has a return value and the callsite is prepared to handle an error return. Replace it with a WARN_ON_ONCE() and return a proper error code. Fixes: 9cd4f1a4e7a8 ("smp/hotplug: Move unparking of percpu threads to the control CPU") Rightfully-ranted-at-by: Linux Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06smp/hotplug: Move unparking of percpu threads to the control CPUThomas Gleixner
commit 9cd4f1a4e7a858849e889a081a99adff83e08e4c upstream. Vikram reported the following backtrace: BUG: scheduling while atomic: swapper/7/0/0x00000002 CPU: 7 PID: 0 Comm: swapper/7 Not tainted 4.9.32-perf+ #680 schedule schedule_hrtimeout_range_clock schedule_hrtimeout wait_task_inactive __kthread_bind_mask __kthread_bind __kthread_unpark kthread_unpark cpuhp_online_idle cpu_startup_entry secondary_start_kernel He analyzed correctly that a parked cpu hotplug thread of an offlined CPU was still on the runqueue when the CPU came back online and tried to unpark it. This causes the thread which invoked kthread_unpark() to call wait_task_inactive() and subsequently schedule() with preemption disabled. His proposed workaround was to "make sure" that a parked thread has scheduled out when the CPU goes offline, so the situation cannot happen. But that's still wrong because the root cause is not the fact that the percpu thread is still on the runqueue and neither that preemption is disabled, which could be simply solved by enabling preemption before calling kthread_unpark(). The real issue is that the calling thread is the idle task of the upcoming CPU, which is not supposed to call anything which might sleep. The moron, who wrote that code, missed completely that kthread_unpark() might end up in schedule(). The solution is simpler than expected. The thread which controls the hotplug operation is waiting for the CPU to call complete() on the hotplug state completion. So the idle task of the upcoming CPU can set its state to CPUHP_AP_ONLINE_IDLE and invoke complete(). This in turn wakes the control task on a different CPU, which then can safely do the unpark and kick the now unparked hotplug thread of the upcoming CPU to complete the bringup to the final target state. Control CPU AP bringup_cpu(); __cpu_up() ------------> bringup_ap(); bringup_wait_for_ap() wait_for_completion(); cpuhp_online_idle(); <------------ complete(); unpark(AP->stopper); unpark(AP->hotplugthread); while(1) do_idle(); kick(AP->hotplugthread); wait_for_completion(); hotplug_thread() run_online_callbacks(); complete(); Fixes: 8df3e07e7f21 ("cpu/hotplug: Let upcoming cpu bring itself fully up") Reported-by: Vikram Mulukutla <markivx@codeaurora.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Sewior <bigeasy@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1707042218020.2131@nanos Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14cpu/hotplug: Drop the device lock on errorSebastian Andrzej Siewior
commit 40da1b11f01e43aad1aa6cea64681b6125e8a2a7 upstream. If a custom CPU target is specified and that one is not available _or_ can't be interrupted then the code returns to userland without dropping a lock as notices by lockdep: |echo 133 > /sys/devices/system/cpu/cpu7/hotplug/target | ================================================ | [ BUG: lock held when returning to user space! ] | ------------------------------------------------ | bash/503 is leaving the kernel with locks still held! | 1 lock held by bash/503: | #0: (device_hotplug_lock){+.+...}, at: [<ffffffff815b5650>] lock_device_hotplug_sysfs+0x10/0x40 So release the lock then. Fixes: 757c989b9994 ("cpu/hotplug: Make target state writeable") Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170602142714.3ogo25f2wbq6fjpj@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-08cpu/hotplug: Serialize callback invocations properSebastian Andrzej Siewior
commit dc434e056fe1dada20df7ba07f32739d3a701adf upstream. The setup/remove_state/instance() functions in the hotplug core code are serialized against concurrent CPU hotplug, but unfortunately not serialized against themself. As a consequence a concurrent invocation of these function results in corruption of the callback machinery because two instances try to invoke callbacks on remote cpus at the same time. This results in missing callback invocations and initiator threads waiting forever on the completion. The obvious solution to replace get_cpu_online() with cpu_hotplug_begin() is not possible because at least one callsite calls into these functions from a get_online_cpu() locked region. Extend the protection scope of the cpuhp_state_mutex from solely protecting the state arrays to cover the callback invocation machinery as well. Fixes: 5b7aa87e0482 ("cpu/hotplug: Implement setup/removal interface") Reported-and-tested-by: Bart Van Assche <Bart.VanAssche@sandisk.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: hpa@zytor.com Cc: mingo@kernel.org Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Link: http://lkml.kernel.org/r/20170314150645.g4tdyoszlcbajmna@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06hotplug: Make register and unregister notifier API symmetricMichal Hocko
commit 777c6e0daebb3fcefbbd6f620410a946b07ef6d0 upstream. Yu Zhao has noticed that __unregister_cpu_notifier only unregisters its notifiers when HOTPLUG_CPU=y while the registration might succeed even when HOTPLUG_CPU=n if MODULE is enabled. This means that e.g. zswap might keep a stale notifier on the list on the manual clean up during the pool tear down and thus corrupt the list. Resulting in the following [ 144.964346] BUG: unable to handle kernel paging request at ffff880658a2be78 [ 144.971337] IP: [<ffffffffa290b00b>] raw_notifier_chain_register+0x1b/0x40 <snipped> [ 145.122628] Call Trace: [ 145.125086] [<ffffffffa28e5cf8>] __register_cpu_notifier+0x18/0x20 [ 145.131350] [<ffffffffa2a5dd73>] zswap_pool_create+0x273/0x400 [ 145.137268] [<ffffffffa2a5e0fc>] __zswap_param_set+0x1fc/0x300 [ 145.143188] [<ffffffffa2944c1d>] ? trace_hardirqs_on+0xd/0x10 [ 145.149018] [<ffffffffa2908798>] ? kernel_param_lock+0x28/0x30 [ 145.154940] [<ffffffffa2a3e8cf>] ? __might_fault+0x4f/0xa0 [ 145.160511] [<ffffffffa2a5e237>] zswap_compressor_param_set+0x17/0x20 [ 145.167035] [<ffffffffa2908d3c>] param_attr_store+0x5c/0xb0 [ 145.172694] [<ffffffffa290848d>] module_attr_store+0x1d/0x30 [ 145.178443] [<ffffffffa2b2b41f>] sysfs_kf_write+0x4f/0x70 [ 145.183925] [<ffffffffa2b2a5b9>] kernfs_fop_write+0x149/0x180 [ 145.189761] [<ffffffffa2a99248>] __vfs_write+0x18/0x40 [ 145.194982] [<ffffffffa2a9a412>] vfs_write+0xb2/0x1a0 [ 145.200122] [<ffffffffa2a9a732>] SyS_write+0x52/0xa0 [ 145.205177] [<ffffffffa2ff4d97>] entry_SYSCALL_64_fastpath+0x12/0x17 This can be even triggered manually by changing /sys/module/zswap/parameters/compressor multiple times. Fix this issue by making unregister APIs symmetric to the register so there are no surprises. Fixes: 47e627bc8c9a ("[PATCH] hotplug: Allow modules to use the cpu hotplug notifiers even if !CONFIG_HOTPLUG_CPU") Reported-and-tested-by: Yu Zhao <yuzhao@google.com> Signed-off-by: Michal Hocko <mhocko@suse.com> Cc: linux-mm@kvack.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dan Streetman <ddstreet@ieee.org> Link: http://lkml.kernel.org/r/20161207135438.4310-1-mhocko@kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16cpu/hotplug: Use distinct name for cpu_hotplug.dep_mapJoonas Lahtinen
Use distinctive name for cpu_hotplug.dep_map to avoid the actual cpu_hotplug.lock appearing as cpu_hotplug.lock#2 in lockdep splats. Signed-off-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Acked-by: Gautham R. Shenoy <ego@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Gautham R . Shenoy <ego@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: intel-gfx@lists.freedesktop.org Cc: trivial@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-03Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull CPU hotplug updates from Thomas Gleixner: "Yet another batch of cpu hotplug core updates and conversions: - Provide core infrastructure for multi instance drivers so the drivers do not have to keep custom lists. - Convert custom lists to the new infrastructure. The block-mq custom list conversion comes through the block tree and makes the diffstat tip over to more lines removed than added. - Handle unbalanced hotplug enable/disable calls more gracefully. - Remove the obsolete CPU_STARTING/DYING notifier support. - Convert another batch of notifier users. The relayfs changes which conflicted with the conversion have been shipped to me by Andrew. The remaining lot is targeted for 4.10 so that we finally can remove the rest of the notifiers" * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) cpufreq: Fix up conversion to hotplug state machine blk/mq: Reserve hotplug states for block multiqueue x86/apic/uv: Convert to hotplug state machine s390/mm/pfault: Convert to hotplug state machine mips/loongson/smp: Convert to hotplug state machine mips/octeon/smp: Convert to hotplug state machine fault-injection/cpu: Convert to hotplug state machine padata: Convert to hotplug state machine cpufreq: Convert to hotplug state machine ACPI/processor: Convert to hotplug state machine virtio scsi: Convert to hotplug state machine oprofile/timer: Convert to hotplug state machine block/softirq: Convert to hotplug state machine lib/irq_poll: Convert to hotplug state machine x86/microcode: Convert to hotplug state machine sh/SH-X3 SMP: Convert to hotplug state machine ia64/mca: Convert to hotplug state machine ARM/OMAP/wakeupgen: Convert to hotplug state machine ARM/shmobile: Convert to hotplug state machine arm64/FP/SIMD: Convert to hotplug state machine ...
2016-10-03Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "The main changes in this cycle were: - Expedited grace-period changes, most notably avoiding having user threads drive expedited grace periods, using a workqueue instead. - Miscellaneous fixes, including a performance fix for lists that was sent with the lists modifications. - CPU hotplug updates, most notably providing exact CPU-online tracking for RCU. This will in turn allow removal of the checks supporting RCU's prior heuristic that was based on the assumption that CPUs would take no longer than one jiffy to come online. - Torture-test updates. - Documentation updates" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits) list: Expand list_first_entry_or_null() torture: TOROUT_STRING(): Insert a space between flag and message rcuperf: Consistently insert space between flag and message rcutorture: Print out barrier error as document says torture: Add task state to writer-task stall printk()s torture: Convert torture_shutdown() to hrtimer rcutorture: Convert to hotplug state machine cpu/hotplug: Get rid of CPU_STARTING reference rcu: Provide exact CPU-online tracking for RCU rcu: Avoid redundant quiescent-state chasing rcu: Don't use modular infrastructure in non-modular code sched: Make wake_up_nohz_cpu() handle CPUs going offline rcu: Use rcu_gp_kthread_wake() to wake up grace period kthreads rcu: Use RCU's online-CPU state for expedited IPI retry rcu: Exclude RCU-offline CPUs from expedited grace periods rcu: Make expedited RCU CPU stall warnings respond to controls rcu: Stop disabling expedited RCU CPU stall warnings rcu: Drive expedited grace periods from workqueue rcu: Consolidate expedited grace period machinery documentation: Record reason for rcu_head two-byte alignment ...
2016-09-06slab: Convert to hotplug state machineSebastian Andrzej Siewior
Install the callbacks via the state machine. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: linux-mm@kvack.org Cc: rt@linutronix.de Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Lameter <cl@linux.com> Link: http://lkml.kernel.org/r/20160823125319.abeapfjapf2kfezp@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-06relayfs: Convert to hotplug state machineRichard Weinberger
Install the callbacks via the state machine. They are installed at run time but relay_prepare_cpu() does not need to be invoked by the boot CPU because relay_open() was not yet invoked and there are no pools that need to be created. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: rt@linutronix.de Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20160818125731.27256-3-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-06cpu/hotplug: Remove CPU_STARTING and CPU_DYING notifierThomas Gleixner
All users are converted to state machine, remove CPU_STARTING and the corresponding CPU_DYING. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160818125731.27256-2-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-06cpu/hotplug: Make state names consistentThomas Gleixner
We should have all names in the scheme "[subsys/]facility:state]". Fix the core to comply. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-05cpu/hotplug: Replace anon unionThomas Gleixner
Some compilers are unhappy with the anon union in the state array. Replace it with a named union. While at it align the state array initializers proper and add the missing name tags. Fixes: cf392d10b69e "cpu/hotplug: Add multi instance support" Reported-by: Ingo Molnar <mingo@kernel.org> Reported-by: Fenguang Wu <fengguang.wu@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: rt@linutronix.de
2016-09-02cpu/hotplug: Handle unbalanced hotplug enable/disableLianwei Wang
When cpu_hotplug_enable() is called unbalanced w/o a preceeding cpu_hotplug_disable() the code emits a warning, but happily decrements the disabled counter. This causes the next operations to malfunction. Prevent the decrement and just emit a warning. Signed-off-by: Lianwei Wang <lianwei.wang@gmail.com> Cc: peterz@infradead.org Cc: linux-pm@vger.kernel.org Cc: oleg@redhat.com Link: http://lkml.kernel.org/r/1465541008-12476-1-git-send-email-lianwei.wang@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-02cpu/hotplug: Add multi instance supportThomas Gleixner
This patch adds the ability for a given state to have multiple instances. Until now all states have a single instance and the startup / teardown callback use global variables. A few drivers need to perform a the same callbacks on multiple "instances". Currently we have three drivers in tree which all have a global list which they iterate over. With multi instance they support don't need their private list and the functionality has been moved into core code. Plus we hold the hotplug lock in core so no cpus comes/goes while instances are registered and we do rollback in error case :) Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/1471024183-12666-3-git-send-email-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-02cpu/hotplug: Rework callback invocation logicThomas Gleixner
This is preparation for the following patch. This rework here changes the arguments of cpuhp_invoke_callback(). It passes now `state' and whether `startup' or `teardown' callback should be invoked. The callback then is looked up by the function. The following is a clanup of callers: - cpuhp_issue_call() has one argument less - struct cpuhp_cpu_state (which is used by the hotplug thread) gets also its callback removed. The decision if it is a single callback invocation moved to the `single' variable. Also a `bringup' variable has been added to distinguish between startup and teardown callback. - take_cpu_down() needs to start one step earlier. We always get here via CPUHP_TEARDOWN_CPU callback. Before that change cpuhp_ap_states + CPUHP_TEARDOWN_CPU pointed to an empty entry because TEARDOWN is saved in bp_states for this reason. Now that we use cpuhp_get_step() to lookup the state we must explicitly skip it in order not to invoke it twice. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/1471024183-12666-2-git-send-email-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-08-26cpu/hotplug: Allow suspend/resume CPU to be specifiedJames Morse
disable_nonboot_cpus() assumes that the lowest numbered online CPU is the boot CPU, and that this is the correct CPU to run any power management code on. On x86 this is always correct, as CPU0 cannot (easily) by taken offline. On arm64 CPU0 can be taken offline. For hibernate/resume this means we may hibernate on a CPU other than CPU0. If the system is rebooted with kexec 'CPU0' will be assigned to a different physical CPU. This complicates hibernate/resume as now we can't trust the CPU numbers. Arch code can find the correct physical CPU, and ensure it is online before resume from hibernate begins, but also needs to influence disable_nonboot_cpus()s choice of CPU. Rename disable_nonboot_cpus() as freeze_secondary_cpus() and add an argument indicating which CPU should be left standing. Follow the logic in migrate_to_reboot_cpu() to use the lowest numbered online CPU if the requested CPU is not online. Add disable_nonboot_cpus() as an inline function that has the existing behaviour. Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: James Morse <james.morse@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2016-08-22cpu/hotplug: Get rid of CPU_STARTING referenceSebastian Andrzej Siewior
CPU_STARTING is scheduled for removal. There is no use of it in drivers and core code uses it only for compatibility with old-style CPU-hotplug notifiers. This patch removes therefore removes CPU_STARTING from an RCU-related comment. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2016-08-22rcu: Provide exact CPU-online tracking for RCUPaul E. McKenney
Up to now, RCU has assumed that the CPU-online process makes it from CPU_UP_PREPARE to set_cpu_online() within one jiffy. Given the recent rise of virtualized environments, this assumption is very clearly obsolete. Failing to meet this deadline can result in RCU paying attention to an incoming CPU for one jiffy, then ignoring it until the grace period following the one in which that CPU sets itself online. This situation might prove to be fatally disappointing to any RCU read-side critical sections that had the misfortune to execute during the time in which RCU was ignoring the slow-to-come-online CPU. This commit therefore updates RCU's internal CPU state-tracking information at notify_cpu_starting() time, thus providing RCU with an exact transition of the CPU's state from offline to online. Note that this means that incoming CPUs must not use RCU read-side critical section (other than those of SRCU) until notify_cpu_starting() time. Note also that the CPU_STARTING notifiers -are- allowed to use RCU read-side critical sections. (Of course, CPU-hotplug notifiers are rapidly becoming obsolete, so you need to act fast!) If a given architecture or CPU family needs to use RCU read-side critical sections earlier, the call to rcu_cpu_starting() from notify_cpu_starting() will need to be architecture-specific, with architectures that need early use being required to hand-place the call to rcu_cpu_starting() at some point preceding the call to notify_cpu_starting(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2016-08-10cpu/hotplug: Prevent alloc/free of irq descriptors during CPU up/down (again)Boris Ostrovsky
Now that Xen no longer allocates irqs in _cpu_up() we can restore commit: a89941816726 ("hotplug: Prevent alloc/free of irq descriptors during cpu up/down") Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Reviewed-by: Juergen Gross <jgross@suse.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Anna-Maria Gleixner <anna-maria@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: david.vrabel@citrix.com Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/1470244948-17674-3-git-send-email-boris.ostrovsky@oracle.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-28timers/core: Correct callback order during CPU hot plugRichard Cochran
On the tear-down path, the dead CPU callback for the timers was misplaced within the 'cpuhp_state' enumeration. There is a hidden dependency between the timers and block multiqueue. The timers callback must happen before the block multiqueue callback otherwise a RCU stall occurs. Move the timers callback to the proper place in the state machine. Reported-and-tested-by: Jon Hunter <jonathanh@nvidia.com> Reported-by: kbuild test robot <lkp@intel.com> Fixes: 24f73b99716a ("timers/core: Convert to hotplug state machine") Signed-off-by: Richard Cochran <rcochran@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: John Stultz <john.stultz@linaro.org> Cc: rt@linutronix.de Cc: Oleg Nesterov <oleg@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1469610498-25914-1-git-send-email-rcochran@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-15rcu: Convert rcutree to hotplug state machineThomas Gleixner
Straight forward conversion to the state machine. Though the question arises whether this needs really all these state transitions to work. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160713153337.982013161@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-15smp/cfd: Convert core to hotplug state machineRichard Weinberger
Install the callbacks via the state machine. They are installed at runtime so smpcfd_prepare_cpu() needs to be invoked by the boot-CPU. Signed-off-by: Richard Weinberger <richard@nod.at> [ Added the dropped CPU dying case back in. ] Signed-off-by: Richard Cochran <rcochran@linutronix.de> Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Davidlohr Bueso <dave@stgolabs> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160713153337.818376366@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-15timers/core: Convert to hotplug state machineRichard Cochran
When tearing down, call timers_dead_cpu() before notify_dead(). There is a hidden dependency between: - timers - block multiqueue - rcutree If timers_dead_cpu() comes later than blk_mq_queue_reinit_notify() that latter function causes a RCU stall. Signed-off-by: Richard Cochran <rcochran@linutronix.de> Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: John Stultz <john.stultz@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160713153337.566790058@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-15hrtimer: Convert to hotplug state machineThomas Gleixner
Split out the clockevents callbacks instead of piggybacking them on hrtimers. This gets rid of a POST_DEAD user. See commit: 54e88fad223c ("sched: Make sure timers have migrated before killing the migration_thread") We just move the callback state to the proper place in the state machine. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160713153337.485419196@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-14workqueue: Convert to state machine callbacksThomas Gleixner
Get rid of the prio ordering of the separate notifiers and use a proper state callback pair. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Acked-by: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Lai Jiangshan <jiangshanlai@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160713153335.197083890@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-14perf/core: Convert to hotplug state machineThomas Gleixner
Actually a nice symmetric startup/teardown pair which fits properly into the state machine concept. In the long run we should be able to invoke the startup callback for the boot CPU via the state machine and get rid of the init function which invokes it on the boot CPU. Note: This comes actually before the perf hardware callbacks. In the notifier model the hardware callbacks have a higher priority than the core callback. But that's solely for CPU offline so that hardware migration of events happens before the core is notified about the outgoing CPU. With the symetric state array model we have the following ordering: UP: core -> hardware DOWN: hardware -> core Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Reviewed-by: Sebastian Siewior <bigeasy@linutronix.de> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160713153333.587514098@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-14cpu/hotplug: Handle early registration gracefullyThomas Gleixner
We switched the hotplug machinery to smpboot threads. Early registration of hotplug callbacks, i.e. from do_pre_smp_initcalls(), happens before the threads are initialized. Instead of moving the thread init, we simply handle it in the hotplug code itself and invoke the function directly. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160713153332.896450738@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-13cpu/hotplug: Keep enough storage space if SMP=n to avoid array out of bounds ↵Thomas Gleixner
scribble Xiaolong Ye reported lock debug warnings triggered by the following commit: 8de4a0066106 ("perf/x86: Convert the core to the hotplug state machine") The bug is the following: the cpuhp_bp_states[] array is cut short when CONFIG_SMP=n, but the dynamically registered callbacks are stored nevertheless and happily scribble outside of the array bounds... We need to store them in case that the state is unregistered so we can invoke the teardown function. That's independent of CONFIG_SMP. Make sure the array is large enough. Reported-by: kernel test robot <xiaolong.ye@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Adam Borowski <kilobyte@angband.pl> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Anna-Maria Gleixner <anna-maria@linutronix.de> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Borislav Petkov <bp@suse.de> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Kan Liang <kan.liang@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Stephane Eranian <eranian@google.com> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: lkp@01.org Cc: stable@vger.kernel.org Cc: tipbuild@zytor.com Fixes: cff7d378d3fd "cpu/hotplug: Convert to a state machine for the control processor" Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1607122144560.4083@nanos Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-05-06sched/hotplug: Make activate() the last hotplug stepThomas Gleixner
The scheduler can handle per cpu threads before the cpu is set to active and it does not allow user space threads on the cpu before active is set. Attaching to the scheduling domains is also not required before user space threads can be handled. Move the activation to the end of the hotplug state space. That also means that deactivation is the first action when a cpu is shut down. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160310120025.597477199@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-05-06sched/hotplug: Move migration CPU_DYING to sched_cpu_dying()Thomas Gleixner
Remove the hotplug notifier and make it an explicit state. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160310120025.502222097@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-05-06sched/hotplug: Move sync_rcu to be with set_cpu_active(false)Peter Zijlstra
The sync_rcu stuff is specificically for clearing bits in the active mask, such that everybody will observe the bit cleared and will not consider the cleared CPU for load-balancing etc. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160310120025.169219710@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-05-06sched/hotplug: Convert cpu_[in]active notifiers to state machineThomas Gleixner
Now that we reduced everything into single notifiers, it's simple to move them into the hotplug state machine space. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: rt@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-05-06sched: Make set_cpu_rq_start_time() a built in hotplug stateThomas Gleixner
Start distangling the maze of hotplug notifiers in the scheduler. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: rt@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-04-22cpu/hotplug: Fix rollback during error-out in __cpu_disable()Sebastian Andrzej Siewior
The recent introduction of the hotplug thread which invokes the callbacks on the plugged cpu, cased the following regression: If takedown_cpu() fails, then we run into several issues: 1) The rollback of the target cpu states is not invoked. That leaves the smp threads and the hotplug thread in disabled state. 2) notify_online() is executed due to a missing skip_onerr flag. That causes that both CPU_DOWN_FAILED and CPU_ONLINE notifications are invoked which confuses quite some notifiers. 3) The CPU_DOWN_FAILED notification is not invoked on the target CPU. That's not an issue per se, but it is inconsistent and in consequence blocks the patches which rely on these states being invoked on the target CPU and not on the controlling cpu. It also does not preserve the strict call order on rollback which is problematic for the ongoing state machine conversion as well. To fix this we add a rollback flag to the remote callback machinery and invoke the rollback including the CPU_DOWN_FAILED notification on the remote cpu. Further mark the notify online state with 'skip_onerr' so we don't get a double invokation. This workaround will go away once we moved the unplug invocation to the target cpu itself. [ tglx: Massaged changelog and moved the CPU_DOWN_FAILED notifiaction to the target cpu ] Fixes: 4cb28ced23c4 ("cpu/hotplug: Create hotplug threads") Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: linux-s390@vger.kernel.org Cc: rt@linutronix.de Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Anna-Maria Gleixner <anna-maria@linutronix.de> Link: http://lkml.kernel.org/r/20160408124015.GA21960@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
