path: root/include
2013-09-07Merge tag 'mfd-3.12-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next Pull MFD (multi-function device) updates from Samuel Ortiz: "For the 3.12 merge window we have one new driver for the DA9063 PMIC from Dialog Semiconductor. Besides that driver we also have: - Device tree support for the s2mps11 driver - More devm_* conversion for the pm8921, max89xx, menelaus, tps65010, wl1273 and pcf50633-adc drivers. - A conversion to threaded IRQ and IRQ domain for the twl6030 driver. - A fairly big update for the rtsx driver: Better power saving support, better vendor settings handling, and a few fixes. - Support for a couple more boards (COMe-bHL6 and COMe-cTH6) for the Kontron driver. - A conversion to the dev_get_platdata() API for all MFD drivers. - A removal of non-DT (legacy) support for the twl6040 driver. - A few fixes and additions (Mic detect level) to the wm5110 register tables. - Regmap support for the davinci_voicecodec driver. - The usual bunch of minor cleanups and janitorial fixes" * tag 'mfd-3.12-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next: (81 commits) mfd: ucb1x00-core: Rewrite ucb1x00_add_dev() mfd: ab8500-debugfs: Apply a check for -ENOMEM after allocating memory for event name mfd: ab8500-debugfs: Apply a check for -ENOMEM after allocating memory for sysfs mfd: timberdale: Use module_pci_driver mfd: timberdale: Remove redundant break mfd: timberdale: Staticize local variables mfd: ab8500-debugfs: Staticize local variables mfd: db8500-prcmu: Staticize clk_mgt mfd: db8500-prcmu: Use ANSI function declaration mfd: omap-usb-host: Staticize usbhs_driver_name mfd: 88pm805: Fix potential NULL pdata dereference mfd: 88pm800: Fix potential NULL pdata dereference mfd: twl6040: Use regmap for register cache mfd: davinci_voicecodec: Provide a regmap for register I/O mfd: davinci_voicecodec: Remove unused read and write functions mmc: memstick: rtsx: Modify copyright comments mmc: rtsx: Clear SD_CLK toggle enable bit if switching voltage fail mfd: mmc: rtsx: Change default tx phase mfd: pcf50633-adc: Use devm_*() functions mfd: rtsx: Copyright modifications ...
2013-09-07lockref: add ability to mark lockrefs "dead"Linus Torvalds
The only actual current lockref user (dcache) uses zero reference counts even for perfectly live dentries, because it's a cache: there may not be any users, but that doesn't mean that we want to throw away the dentry. At the same time, the dentry cache does have a notion of a truly "dead" dentry that we must not even increment the reference count of, because we have pruned it and it is not valid. Currently that distinction is not visible in the lockref itself, and the dentry cache validation uses "lockref_get_or_lock()" to either get a new reference to a dentry that already had existing references (and thus cannot be dead), or get the dentry lock so that we can then verify the dentry and increment the reference count under the lock if that verification was successful. That's all somewhat complicated. This adds the concept of being "dead" to the lockref itself, by simply using a count that is negative. This allows a usage scenario where we can increment the refcount of a dentry without having to validate it, and pushing the special "we killed it" case into the lockref code. The dentry code itself doesn't actually use this yet, and it's probably too late in the merge window to do that code (the dentry_kill() code with its "should I decrement the count" logic really is pretty complex code), but let's introduce the concept at the lockref level now. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 2 (of many) from Al Viro: "Mostly Miklos' series this time" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: constify dcache.c inlined helpers where possible fuse: drop dentry on failed revalidate fuse: clean up return in fuse_dentry_revalidate() fuse: use d_materialise_unique() sysfs: use check_submounts_and_drop() nfs: use check_submounts_and_drop() gfs2: use check_submounts_and_drop() afs: use check_submounts_and_drop() vfs: check unlinked ancestors before mount vfs: check submounts and drop atomically vfs: add d_walk() vfs: restructure d_genocide()
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull namespace changes from Eric Biederman: "This is an assorted mishmash of small cleanups, enhancements and bug fixes. The major theme is user namespace mount restrictions. nsown_capable is killed as it encourages not thinking about details that need to be considered. A very hard to hit pid namespace exiting bug was finally tracked and fixed. A couple of cleanups to the basic namespace infrastructure. Finally there is an enhancement that makes per user namespace capabilities usable as capabilities, and an enhancement that allows the per userns root to nice other processes in the user namespace" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: userns: Kill nsown_capable it makes the wrong thing easy capabilities: allow nice if we are privileged pidns: Don't have unshare(CLONE_NEWPID) imply CLONE_THREAD userns: Allow PR_CAPBSET_DROP in a user namespace. namespaces: Simplify copy_namespaces so it is clear what is going on. pidns: Fix hang in zap_pid_ns_processes by sending a potentially extra wakeup sysfs: Restrict mounting sysfs userns: Better restrictions on when proc and sysfs can be mounted vfs: Don't copy mount bind mounts of /proc/<pid>/ns/mnt between namespaces kernel/nsproxy.c: Improving a snippet of code. proc: Restrict mounting the proc filesystem vfs: Lock in place mounts from more privileged users
2013-09-07Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Nothing major for this kernel, just maintenance updates" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (21 commits) apparmor: add the ability to report a sha1 hash of loaded policy apparmor: export set of capabilities supported by the apparmor module apparmor: add the profile introspection file to interface apparmor: add an optional profile attachment string for profiles apparmor: add interface files for profiles and namespaces apparmor: allow setting any profile into the unconfined state apparmor: make free_profile available outside of policy.c apparmor: rework namespace free path apparmor: update how unconfined is handled apparmor: change how profile replacement update is done apparmor: convert profile lists to RCU based locking apparmor: provide base for multiple profiles to be replaced at once apparmor: add a features/policy dir to interface apparmor: enable users to query whether apparmor is enabled apparmor: remove minimum size check for vmalloc() Smack: parse multiple rules per write to load2, up to PAGE_SIZE-1 bytes Smack: network label match fix security: smack: add a hash table to quicken smk_find_entry() security: smack: fix memleak in smk_write_rules_list() xattr: Constify ->name member of "struct xattr". ...
2013-09-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 3.12: - Added MODULE_SOFTDEP to allow pre-loading of modules. - Reinstated crct10dif driver using the module softdep feature. - Allow via rng driver to be auto-loaded. - Split large input data when necessary in nx. - Handle zero length messages correctly for GCM/XCBC in nx. - Handle SHA-2 chunks bigger than block size properly in nx. - Handle unaligned lengths in omap-aes. - Added SHA384/SHA512 to omap-sham. - Added OMAP5/AM43XX SHAM support. - Added OMAP4 TRNG support. - Misc fixes" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (66 commits) Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework" hwrng: via - Add MODULE_DEVICE_TABLE crypto: fcrypt - Fix bitoperation for compilation with clang crypto: nx - fix SHA-2 for chunks bigger than block size crypto: nx - fix GCM for zero length messages crypto: nx - fix XCBC for zero length messages crypto: nx - fix limits to sg lists for AES-CCM crypto: nx - fix limits to sg lists for AES-XCBC crypto: nx - fix limits to sg lists for AES-GCM crypto: nx - fix limits to sg lists for AES-CTR crypto: nx - fix limits to sg lists for AES-CBC crypto: nx - fix limits to sg lists for AES-ECB crypto: nx - add offset to nx_build_sg_lists() padata - Register hotcpu notifier after initialization padata - share code between CPU_ONLINE and CPU_DOWN_FAILED, same to CPU_DOWN_PREPARE and CPU_UP_CANCELED hwrng: omap - reorder OMAP TRNG driver code crypto: omap-sham - correct dma burst size crypto: omap-sham - Enable Polling mode if DMA fails crypto: tegra-aes - bitwise vs logical and crypto: sahara - checking the wrong variable ...
2013-09-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A quick set of fixes, some to deal with fallout from yesterday's net-next merge. 1) Fix compilation of bnx2x driver with CONFIG_BNX2X_SRIOV disabled, from Dmitry Kravkov. 2) Fix a bnx2x regression caused by one of Dave Jones's mistaken braces changes, from Eilon Greenstein. 3) Add some protective filtering in the netlink tap code, from Daniel Borkmann. 4) Fix TCP congestion window growth regression after timeouts, from Yuchung Cheng. 5) Correctly adjust TCP's rcv_ssthresh for out of order packets, from Eric Dumazet" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: tcp: properly increase rcv_ssthresh for ofo packets net: add documentation for BQL helpers mlx5: remove unused MLX5_DEBUG param in Kconfig bnx2x: Restore a call to config_init bnx2x: fix broken compilation with CONFIG_BNX2X_SRIOV is not set tcp: fix no cwnd growth after timeout net: netlink: filter particular protocols from analyzers
2013-09-07Merge tag 'gpio-v3.12-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for the v3.12 series: - A new driver for the TZ1090 PDC which is used on the metag architecture. - A new driver for the Kontron ETX or COMexpress GPIO block. This is found on some ETX x86 devices. - A new driver for the Fintek Super-I/O chips, used on some x86 boards. - Added device tree probing on a few select GPIO blocks. - Drop the Exynos support from the Samsung GPIO driver. The Samsung maintainers have moved over to use the modernized pin control driver to provide GPIO for the modern platforms instead. - The usual bunch of non-critical fixes and cleanups" * tag 'gpio-v3.12-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (36 commits) gpio: return -ENOTSUPP if debounce cannot be set gpio: improve error path in gpiolib gpio: add GPIO support for F71882FG and F71889F of: add vendor prefix for Microchip Technology Inc gpio: mcp23s08: rename the device tree property gpio: samsung: Drop support for Exynos SoCs gpio: pcf857x: Remove pdata argument to pcf857x_irq_domain_init() gpio: pcf857x: Sort headers alphabetically gpio: max7301: Reverting "Do not force SPI speed when using OF Platform" gpio: Fix bit masking in Kontron PLD GPIO driver gpio: pca953x: fix gpio input on gpio offsets >= 8 drivers/gpio: simplify use of devm_ioremap_resource drivers/gpio/gpio-omap.c: convert comma to semicolon gpio-lynxpoint: Fix warning about unbalanced pm_runtime_enable gpio: Fix platform driver name in Kontron PLD GPIO driver gpio: adnp: Fix segfault if request_threaded_irq fails gpio: msm: Staticize local variable 'msm_gpio' gpio: gpiolib-of.c: make error message more meaningful by adding the node name and index gpio: use dev_get_platdata() gpio/mxc: add chained_irq_enter/exit() to mx2_gpio_irq_handler ...
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "A new driver for slidebar on Ideapad laptops and a bunch of assorted driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (32 commits) Input: add SYN_MAX and SYN_CNT constants Input: max11801_ts - convert to devm Input: egalax-ts - fix typo and improve text Input: MAINTAINERS - change maintainer for cyttsp driver Input: cyttsp4 - kill 'defined but not used' compiler warnings Input: add driver for slidebar on Lenovo IdeaPad laptops Input: omap-keypad - set up irq type from DT Input: omap-keypad - enable wakeup capability for keypad. Input: omap-keypad - clear interrupts on open Input: omap-keypad - convert to threaded IRQ Input: omap-keypad - use bitfiled instead of hardcoded values Input: cyttsp4 - remove useless NULL test from cyttsp4_watchdog_timer() Input: wacom - fix error return code in wacom_probe() Input: as5011 - fix error return code in as5011_probe() Input: keyboard, serio - simplify use of devm_ioremap_resource Input: tegra-kbc - simplify use of devm_ioremap_resource Input: htcpen - fix incorrect placement of __initdata Input: qt1070 - add power management ops Input: wistron_btns - add MODULE_DEVICE_TABLE Input: wistron_btns - mark the Medion MD96500 keymap as tested ...
2013-09-07Revert "Input: introduce BTN/ABS bits for drums and guitars"Linus Torvalds
This reverts commits 61e00655e9cb, 73f8645db191 and 8e22ecb603c8: "Input: introduce BTN/ABS bits for drums and guitars" "HID: wiimote: add support for Guitar-Hero drums" "HID: wiimote: add support for Guitar-Hero guitars" The extra new ABS_xx values resulted in ABS_MAX no longer being a power-of-two, which broke the comparison logic. It also caused the ioctl numbers to overflow into the next byte, causing problems for that. We'll try again for 3.13. Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-06Merge branch 'next' into for-linusDmitry Torokhov
Merge first round of changes for 3.12 merge window.
2013-09-07Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This patch reinstates commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Now that module softdeps are in the kernel we can use that to resolve the boot issue which cause the revert. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-09-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linuxHerbert Xu
Merge upstream tree in order to reinstate crct10dif.
2013-09-06Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board updates from Olof Johansson: "Board updates for 3.12. Again, a bit of domain overlap with SoC and DT branches, but most of this is around legacy code and board support. We've found that platform maintainers have a hard time separating all of these out and might move towards fewer branches for next release. - Removal of a number of Marvell Kirkwood board files, since contents is now common and mostly configured via DT. - Device-tree updates for Marvell Dove, including irqchip and clocksource setup. - Defconfig updates. Gotta go somewhere. One new one for Renesas Lager. - New backlight drivers for backlights used on Renesas shmobile platforms. - Removal of Renesas leds driver. - Shuffling of some of the new Broadcom platforms to give room for others in the same mach directory. More in 3.13" * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion ARM: bcm: Make secure API call optional ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers) ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona ARM: bcm: Rename board_bcm mmc: sdhci-bcm-kona: make linker-section warning go away ARM: tegra: defconfig updates ARM: dove: add initial DT file for Globalscale D2Plug ARM: dove: add GPIO IR receiver node to SolidRun CuBox ARM: dove: add common pinmux functions to DT ARM: dove: add cpu device tree node ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument ARM: kirkwood: fix DT building and update defconfig ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code ARM: configs: disable DEBUG_LL in bcm_defconfig ARM: bcm281xx: Board specific reboot code ARM bcm281xx: Turn on socket & network support. ARM: bcm281xx: Turn on L2 cache. ...
2013-09-06Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This branch contains mostly additions and changes to platform enablement and SoC-level drivers. Since there's sometimes a dependency on device-tree changes, there's also a fair amount of those in this branch. Pieces worth mentioning are: - Mbus driver for Marvell platforms, allowing kernel configuration and resource allocation of on-chip peripherals. - Enablement of the mbus infrastructure from Marvell PCI-e drivers. - Preparation of MSI support for Marvell platforms. - Addition of new PCI-e host controller driver for Tegra platforms - Some churn caused by sharing of macro names between i.MX 6Q and 6DL platforms in the device tree sources and header files. - Various suspend/PM updates for Tegra, including LP1 support. - Versatile Express support for MCPM, part of big little support. - Allwinner platform support for A20 and A31 SoCs (dual and quad Cortex-A7) - OMAP2+ support for DRA7, a new Cortex-A15-based SoC. The code that touches other architectures are patches moving MSI arch-specific functions over to weak symbols and removal of ARCH_SUPPORTS_MSI, acked by PCI maintainers" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (266 commits) tegra-cpuidle: provide stub when !CONFIG_CPU_IDLE PCI: tegra: replace devm_request_and_ioremap by devm_ioremap_resource ARM: tegra: Drop ARCH_SUPPORTS_MSI and sort list ARM: dts: vf610-twr: enable i2c0 device ARM: dts: i.MX51: Add one more I2C2 pinmux entry ARM: dts: i.MX51: Move pins configuration under "iomuxc" label ARM: dtsi: imx6qdl-sabresd: Add USB OTG vbus pin to pinctrl_hog ARM: dtsi: imx6qdl-sabresd: Add USB host 1 VBUS regulator ARM: dts: imx27-phytec-phycore-som: Enable AUDMUX ARM: dts: i.MX27: Disable AUDMUX in the template ARM: dts: wandboard: Add support for SDIO bcm4329 ARM: i.MX5 clocks: Remove optional clock setup (CKIH1) from i.MX51 template ARM: dts: imx53-qsb: Make USBH1 functional ARM i.MX6Q: dts: Enable I2C1 with EEPROM and PMIC on Phytec phyFLEX-i.MX6 Ouad module ARM i.MX6Q: dts: Enable SPI NOR flash on Phytec phyFLEX-i.MX6 Ouad module ARM: dts: imx6qdl-sabresd: Add touchscreen support ARM: imx: add ocram clock for imx53 ARM: dts: imx: ocram size is different between imx6q and imx6dl ARM: dts: imx27-phytec-phycore-som: Fix regulator settings ARM: dts: i.MX27: Remove clock name from CPU node ...
2013-09-06Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "Device tree and bindings updates for 3.12. General additions of various on-chip and on-board peripherals on various platforms as support gets added. Some of the bigger changes are: - Addition of (new) PCI-e support on Tegra. - More Tegra4 support, including PMC configuration for Dalmore. - Addition of a new board for Exynos4 (trats2) and more bindings for 4x12 IP. - Addition of Allwinner A20 and A31 SoC and board files. - Move of the ST Ericsson device tree files to now use ste-* prefix. - More move of hardware description of shmobile platforms to DT. - Two new board dts files for Freescale MXs" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (177 commits) dts: Rename DW APB timer compatible strings dts: Deprecate ALTR as a vendor prefix of: add vendor prefix for Altera Corp. ARM: at91/dt: sam9x5ek: add sound configuration ARM: at91/dt: sam9x5ek: enable SSC ARM: at91/dt: sam9x5ek: add WM8731 codec ARM: at91/dt: sam9x5: add SSC DMA parameters ARM: at91/dt: add at91rm9200 PQFP package version ARM: at91: at91rm9200: set default mmc0 pinctrl-names ARM: at91: at91sam9n12: correct pin number of gpio-key ARM: at91: at91sam9n12: add qt1070 support ARM: at91: at91sam9n12: add pinctrl of TWI ARM: at91: Add PMU support for sama5d3 ARM: at91: at91sam9260: add missing pinctrl-names on mmc ARM: tegra: configure power off for Dalmore ARM: DT: binding fixup to align with vendor-prefixes.txt (DT) ARM: dts: add sdio blocks to bcm28155-ap board ARM: dts: align sdio numbers to HW definition ARM: sun7i: Add Olimex A20-Olinuxino-Micro support ARM: sun7i: Add Allwinner A20 DTSI ...
2013-09-06Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This branch contains code cleanups, moves and removals for 3.12. There's a large number of various cleanups, and a nice net removal of 13500 lines of code. Highlights worth mentioning are: - A series of patches from Stephen Boyd removing the ARM local timer API. - Move of Qualcomm MSM IOMMU code to drivers/iommu. - Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM driver and switching over to the drivers/pwm one. - Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM). There's also a move of a header file out of include/linux/i2c/ to platform_data, where it really belongs. It touches mostly ARM platform code for include changes so we took it through our tree" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits) ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK gpio: (gpio-pca953x) move header to linux/platform_data/ arm: zynq: hotplug: Remove unreachable code ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*() tegra: simplify use of devm_ioremap_resource ARM: SAMSUNG: Remove plat/regs-timer.h header ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header ARM: SAMSUNG: Remove pwm-clock infrastructure ARM: SAMSUNG: Remove old PWM timer platform devices pwm: Remove superseded pwm-samsung-legacy driver ARM: SAMSUNG: Modify board files to use new PWM platform device ARM: SAMSUNG: Rework private data handling in dev-backlight pwm: Add new pwm-samsung driver ARM: mach-mvebu: remove redundant DT parsing and validation ARM: msm: Only compile io.c on platforms that use it iommu/msm: Move mach includes to iommu directory ARM: msm: Remove devices-iommu.c ARM: msm: Move mach/board.h contents to common.h ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE ARM: msm: Remove TMR and TMR0 static mappings ...
2013-09-06net: add documentation for BQL helpersFlorian Fainelli
Provide a kernel-doc comment documentation for the BQL helpers: - netdev_sent_queue - netdev_completed_queue - netdev_reset_queue Similarly to how it is done for the other functions, the documentation only covers the function operating on struct net_device and not struct netdev_queue. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull Tile arch updates from Chris Metcalf: "These changes bring in a bunch of new functionality that has been maintained internally at Tilera over the last year, plus other stray bits of work that I've taken into the tile tree from other folks. The changes include some PCI root complex work, interrupt-driven console support, support for performing fast-path unaligned data fixups by kernel-based JIT code generation, CONFIG_PREEMPT support, vDSO support for gettimeofday(), a serial driver for the tilegx on-chip UART, KGDB support, more optimized string routines, support for ftrace and kprobes, improved ASLR, and many bug fixes. We also remove support for the old TILE64 chip, which is no longer buildable" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (85 commits) tile: refresh tile defconfig files tile: rework <asm/cmpxchg.h> tile PCI RC: make default consistent DMA mask 32-bit tile: add null check for kzalloc in tile/kernel/setup.c tile: make __write_once a synonym for __read_mostly tile: remove support for TILE64 tile: use asm-generic/bitops/builtin-*.h tile: eliminate no-op "noatomichash" boot argument tile: use standard tile_bundle_bits type in traps.c tile: simplify code referencing hypervisor API addresses tile: change <asm/system.h> to <asm/switch_to.h> in comments tile: mark pcibios_init() as __init tile: check for correct compiler earlier in asm-offsets.c tile: use standard 'generic-y' model for <asm/hw_irq.h> tile: use asm-generic version of <asm/local64.h> tile PCI RC: add comment about "PCI hole" problem tile: remove DEBUG_EXTRA_FLAGS kernel config option tile: add virt_to_kpte() API and clean up and document behavior tile: support FRAME_POINTER tile: support reporting Tilera hypervisor statistics ...
2013-09-06Merge tag 'arm64-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull ARM64 update from Catalin Marinas: - User tagged pointers support (top 8-bit of user pointers automatically ignored by the CPU). - Kernel mode NEON (no users for arm64 yet but work in progress). - arm64 kernel Image header extended to accommodate future EFI stub. - Remove BogoMIPS reporting (not relevant, it's just the timer frequency). - Clean-up (EM_AARCH64/EM_ARM to elf-em.h, ELF notes in read-only segment, unused variable). - Bug-fixes (RAM boundaries not 2MB aligned, perf, includes). * tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: Documentation/arm64: clarify requirements for DTB placement arm64: mm: permit use of tagged pointers at EL0 Move the EM_ARM and EM_AARCH64 definitions to uapi/linux/elf-em.h arm64: Remove unused cpu_name ascii in arch/arm64/mm/proc.S arm64: delay: don't bother reporting bogomips in /proc/cpuinfo arm64: Fix mapping of memory banks not ending on a PMD_SIZE boundary arm64: move elf notes into readonly segment arm64: Enable interrupts in the EL0 undef handler arm64: Expand arm64 image header ARM64: include: asm: include "asm/types.h" in "pgtable-2level-types.h" and "pgtable-3level-types.h" arm64: add support for kernel mode NEON arm64: perf: fix ARMv8 EVTYPE_MASK to include NSH bit arm64: perf: fix group validation when using enable_on_exec
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "The usual trivial updates all over the tree -- mostly typo fixes and documentation updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits) doc: Documentation/cputopology.txt fix typo treewide: Convert retrun typos to return Fix comment typo for init_cma_reserved_pageblock Documentation/trace: Correcting and extending tracepoint documentation mm/hotplug: fix a typo in Documentation/memory-hotplug.txt power: Documentation: Update s2ram link doc: fix a typo in Documentation/00-INDEX Documentation/printk-formats.txt: No casts needed for u64/s64 doc: Fix typo "is is" in Documentations treewide: Fix printks with 0x%# zram: doc fixes Documentation/kmemcheck: update kmemcheck documentation doc: documentation/hwspinlock.txt fix typo PM / Hibernate: add section for resume options doc: filesystems : Fix typo in Documentations/filesystems scsi/megaraid fixed several typos in comments ppc: init_32: Fix error typo "CONFIG_START_KERNEL" treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks page_isolation: Fix a comment typo in test_pages_isolated() doc: fix a typo about irq affinity ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: "Highlights: - conversion of HID subsystem to use devm-based resource management, from Benjamin Tissoires - i2c-hid support for DT bindings, from Benjamin Tissoires - much improved support for Win8-multitouch devices, from Benjamin Tissoires - cleanup of core code using common hidinput_input_event(), from David Herrmann - fix for bug in implement() access to the bit stream (causing oops) that has been present in the code for ages, but devices that are able to trigger it have started to appear only now, from Jiri Kosina - fixes for CVE-2013-2899, CVE-2013-2898, CVE-2013-2896, CVE-2013-2892, CVE-2013-2888 (all triggerable only by specially crafted malicious HW devices plugged into the system), from Kees Cook - hidraw oops fix, from Manoj Chourasia - various smaller fixes here and there, support for a bunch of new devices by various contributors" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (53 commits) HID: MAINTAINERS: add roccat drivers HID: hid-sensor-hub: change kmalloc + memcpy by kmemdup HID: hid-sensor-hub: move to devm_kzalloc HID: hid-sensor-hub: fix indentation accross the code HID: move HID_REPORT_TYPES closer to the report-definitions HID: check for NULL field when setting values HID: picolcd_core: validate output report details HID: sensor-hub: validate feature report details HID: ntrig: validate feature report details HID: pantherlord: validate output report details HID: hid-wiimote: print small buffers via %*phC HID: uhid: improve uhid example client HID: Correct the USB IDs for the new Macbook Air 6 HID: wiimote: add support for Guitar-Hero guitars HID: wiimote: add support for Guitar-Hero drums Input: introduce BTN/ABS bits for drums and guitars HID: battery: don't do DMA from stack HID: roccat: add support for KonePureOptical v2 HID: picolcd: Prevent NULL pointer dereference on _remove() HID: usbhid: quirk for N-Trig DuoSense Touch Screen ...
2013-09-06Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext3, reiserfs, udf & isofs fixes from Jan Kara: "The contains a bunch of ext3 cleanups and minor improvements, major reiserfs locking changes which should hopefully fix deadlocks introduced by BKL removal, and udf/isofs changes to refuse mounting fs rw instead of mounting it ro automatically which makes eject button work as expected for all media (see the changelog for why userspace should be ok with this change)" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: jbd: use a single printk for jbd_debug() reiserfs: locking, release lock around quota operations reiserfs: locking, handle nested locks properly reiserfs: locking, push write lock out of xattr code jbd: relocate assert after state lock in journal_commit_transaction() udf: Refuse RW mount of the filesystem instead of making it RO udf: Standardize return values in mount sequence isofs: Refuse RW mount of the filesystem instead of making it RO ext3: allow specifying external journal by pathname mount option jbd: remove unneeded semicolon
2013-09-06Merge tag 'for-f2fs-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs updates from Jaegeuk Kim: "This patch-set includes the following major enhancement patches: - support inline xattrs - add sysfs support to control GCs explicitly - add proc entry to show the current segment usage information - improve the GC/SSR performance The other bug fixes are as follows: - avoid the overflow on status calculation - fix some error handling routines - fix inconsistent xattr states after power-off-recovery - fix incorrect xattr node offset definition - fix deadlock condition in fsync - fix the fdatasync routine for power-off-recovery" * tag 'for-f2fs-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (40 commits) f2fs: optimize gc for better performance f2fs: merge more bios of node block writes f2fs: avoid an overflow during utilization calculation f2fs: trigger GC when there are prefree segments f2fs: use strncasecmp() simplify the string comparison f2fs: fix omitting to update inode page f2fs: support the inline xattrs f2fs: add the truncate_xattr_node function f2fs: introduce __find_xattr for readability f2fs: reserve the xattr space dynamically f2fs: add flags for inline xattrs f2fs: fix error return code in init_f2fs_fs() f2fs: fix wrong BUG_ON condition f2fs: fix memory leak when init f2fs filesystem fail f2fs: fix a compound statement label error f2fs: avoid writing inode redundantly when creating a file f2fs: alloc_page() doesn't return an ERR_PTR f2fs: should cover i_xattr_nid with its xattr node page lock f2fs: check the free space first in new_node_page f2fs: clean up the needless end 'return' of void function ...
2013-09-06Merge branches 'for-3.12/devm', 'for-3.12/i2c-hid', 'for-3.12/i2c-hid-dt', ↵Jiri Kosina
'for-3.12/logitech', 'for-3.12/multitouch-win8', 'for-3.12/trasnport-driver-cleanup', 'for-3.12/uhid', 'for-3.12/upstream' and 'for-3.12/wiimote' into for-linus
2013-09-05Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "This set includes adding support for Neon acceleration of RAID6 XOR code from Ard Biesheuvel, cache flushing and barrier updates from Will Deacon, and a cleanup to the ARM debug code which reduces the amount of code by about 500 lines. A few other cleanups, such as constifying the machine descriptors which already shouldn't be written to, cleaning up the printing of the L2 cache size" * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (55 commits) ARM: 7826/1: debug: support debug ll on hisilicon soc ARM: 7830/1: delay: don't bother reporting bogomips in /proc/cpuinfo ARM: 7829/1: Add ".text.unlikely" and ".text.hot" to arm unwind tables ARM: 7828/1: ARMv7-M: implement restart routine common to all v7-M machines ARM: 7827/1: highbank: fix debug uart virtual address for LPAE ARM: 7823/1: errata: workaround Cortex-A15 erratum 773022 ARM: 7806/1: allow DEBUG_UNCOMPRESS for Tegra ARM: 7793/1: debug: use generic option for ep93xx PL10x debug port ARM: debug: move SPEAr debug to generic PL01x code ARM: debug: move davinci debug to generic 8250 code ARM: debug: move keystone debug to generic 8250 code ARM: debug: remove DEBUG_ROCKCHIP_UART ARM: debug: provide generic option choices for 8250 and PL01x ports ARM: debug: move PL01X debug include into arch/arm/include/debug/ ARM: debug: provide PL01x debug uart phys/virt address configuration options ARM: debug: add support for word accesses to debug/8250.S ARM: debug: move 8250 debug include into arch/arm/include/debug/ ARM: debug: provide 8250 debug uart phys/virt address configuration options ARM: debug: provide 8250 debug uart register shift configuration option ARM: debug: provide 8250 debug uart flow control configuration option ...
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: "Noteworthy changes this time around: 1) Multicast rejoin support for team driver, from Jiri Pirko. 2) Centralize and simplify TCP RTT measurement handling in order to reduce the impact of bad RTO seeding from SYN/ACKs. Also, when both timestamps and local RTT measurements are available prefer the later because there are broken middleware devices which scramble the timestamp. From Yuchung Cheng. 3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel memory consumed to queue up unsend user data. From Eric Dumazet. 4) Add a "physical port ID" abstraction for network devices, from Jiri Pirko. 5) Add a "suppress" operation to influence fib_rules lookups, from Stefan Tomanek. 6) Add a networking development FAQ, from Paul Gortmaker. 7) Extend the information provided by tcp_probe and add ipv6 support, from Daniel Borkmann. 8) Use RCU locking more extensively in openvswitch data paths, from Pravin B Shelar. 9) Add SCTP support to openvswitch, from Joe Stringer. 10) Add EF10 chip support to SFC driver, from Ben Hutchings. 11) Add new SYNPROXY netfilter target, from Patrick McHardy. 12) Compute a rate approximation for sending in TCP sockets, and use this to more intelligently coalesce TSO frames. Furthermore, add a new packet scheduler which takes advantage of this estimate when available. From Eric Dumazet. 13) Allow AF_PACKET fanouts with random selection, from Daniel Borkmann. 14) Add ipv6 support to vxlan driver, from Cong Wang" Resolved conflicts as per discussion. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits) openvswitch: Fix alignment of struct sw_flow_key. netfilter: Fix build errors with xt_socket.c tcp: Add missing braces to do_tcp_setsockopt caif: Add missing braces to multiline if in cfctrl_linkup_request bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize vxlan: Fix kernel panic on device delete. net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls net: mvneta: properly disable HW PHY polling and ensure adjust_link() works icplus: Use netif_running to determine device state ethernet/arc/arc_emac: Fix huge delays in large file copies tuntap: orphan frags before trying to set tx timestamp tuntap: purge socket error queue on detach qlcnic: use standard NAPI weights ipv6:introduce function to find route for redirect bnx2x: VF RSS support - VF side bnx2x: VF RSS support - PF side vxlan: Notify drivers for listening UDP port changes net: usbnet: update addr_assign_type if appropriate driver/net: enic: update enic maintainers and driver driver/net: enic: Exposing symbols for Cisco's low latency driver ...
2013-09-05constify dcache.c inlined helpers where possibleAl Viro
2013-09-05vfs: check submounts and drop atomicallyMiklos Szeredi
We check submounts before doing d_drop() on a non-empty directory dentry in NFS (have_submounts()), but we do not exclude a racing mount. Process A: have_submounts() -> returns false Process B: mount() -> success Process A: d_drop() This patch prepares the ground for the fix by doing the following operations all under the same rename lock: have_submounts() shrink_dcache_parent() d_drop() This is actually an optimization since have_submounts() and shrink_dcache_parent() both traverse the same dentry tree separately. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: David Howells <dhowells@redhat.com> CC: Steven Whitehouse <swhiteho@redhat.com> CC: Trond Myklebust <Trond.Myklebust@netapp.com> CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c net/bridge/br_multicast.c net/ipv6/sit.c The conflicts were minor: 1) sit.c changes overlap with change to ip_tunnel_xmit() signature. 2) br_multicast.c had an overlap between computing max_delay using msecs_to_jiffies and turning MLDV2_MRC() into an inline function with a name using lowercase instead of uppercase letters. 3) stmmac had two overlapping changes, one which conditionally allocated and hooked up a dma_cfg based upon the presence of the pbl OF property, and another one handling store-and-forward DMA made. The latter of which should not go into the new of_find_property() basic block. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "This series contains: - Exynos s5p-mfc driver got support for VP8 encoder - Some SoC drivers gained support for asynchronous registration (needed for DT) - The RC subsystem gained support for RC activity LED; - New drivers added: a video decoder(adv7842), a video encoder (adv7511), a new GSPCA driver (stk1135) and support for Renesas R-Car (vsp1) - the first SDR kernel driver: mirics msi3101. Due to some troubles with the driver, and because the API is still under discussion, it will be merged at staging for 3.12. Need to rework on it - usual new boards additions, fixes, cleanups and driver improvements" * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (242 commits) [media] cx88: Fix regression: CX88_AUDIO_WM8775 can't be 0 [media] exynos4-is: Fix entity unregistration on error path [media] exynos-gsc: Register v4l2 device [media] exynos4-is: Fix fimc-lite bayer formats [media] em28xx: fix assignment of the eeprom data [media] hdpvr: fix iteration over uninitialized lists in hdpvr_probe() [media] usbtv: Throw corrupted frames away [media] usbtv: Fix deinterlacing [media] v4l2: added missing mutex.h include to v4l2-ctrls.h [media] DocBook: upgrade media_api DocBook version to 4.2 [media] ml86v7667: fix compile warning: 'ret' set but not used [media] s5p-g2d: Fix registration failure [media] media: coda: Fix DT driver data pointer for i.MX27 [media] s5p-mfc: Fix input/output format reporting [media] v4l: vsp1: Fix mutex double lock at streamon time [media] v4l: vsp1: Add support for RT clock [media] v4l: vsp1: Initialize media device bus_info field [media] davinci: vpif_capture: fix error return code in vpif_probe() [media] davinci: vpif_display: fix error return code in vpif_probe() [media] MAINTAINERS: add entries for adv7511 and adv7842 ...
2013-09-05Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm tree changes from Dave Airlie: "This is the main drm pull request, I have some overlap with sound and arm-soc, the sound patch is acked and may conflict based on -next reports but should be a trivial fixup, which I'll leave to you! Highlights: - new drivers: MSM driver from Rob Clark - non-drm: switcheroo and hdmi audio driver support for secondary GPU poweroff, so drivers can use runtime PM to poweroff the GPUs. This can save 5 or 6W on some optimus laptops. - drm core: combined GEM and TTM VMA manager per-filp mmap permission tracking initial rendernode support (via a runtime enable for now, until we get api stable), remove old proc support, lots of cleanups of legacy code hdmi vendor infoframes and 4k modes lots of gem/prime locking and races fixes async pageflip scaffolding drm bridge objects - i915: Haswell PC8+ support and eLLC support, HDMI 4K support, initial per-process VMA pieces, watermark reworks, convert to generic hdmi infoframes, encoder reworking, fastboot support, - radeon: CIK PM support, remove 3d blit code in favour of DMA engines, Berlin GPU support, HDMI audio fixes - nouveau: secondary GPU power down support for optimus laptops, lots of fixes, use MSI, VP3 engine support - exynos: runtime pm support for g2d, DT support, remove non-DT, - tda998x i2c driver: lots of fixes for sync issues - gma500: lots of cleanups - rcar: add LVDS support, fbdev emulation, - tegra: just minor fixes" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (684 commits) drm/exynos: Fix build error with exynos_drm_connector.c drm/exynos: Remove non-DT support in exynos_drm_fimd drm/exynos: Remove non-DT support in exynos_hdmi drm/exynos: Remove non-DT support in exynos_drm_g2d drm/exynos: Remove non-DT support in exynos_hdmiphy drm/exynos: Remove non-DT support in exynos_ddc drm/exynos: Make Exynos DRM drivers depend on OF drm/exynos: Consider fallback option to allocation fail drm/exynos: fimd: move platform data parsing to separate function drm/exynos: fimd: get signal polarities from device tree drm/exynos: fimd: replace struct fb_videomode with videomode drm/exynos: check a pixel format to a particular window layer drm/exynos: fix fimd pixel format setting drm/exynos: Add NULL pointer check drm/exynos: Remove redundant error messages drm/exynos: Add missing of.h header include drm/exynos: Remove redundant NULL check in exynos_drm_buf drm/exynos: add device tree support for rotator drm/exynos: Add missing includes drm/exynos: add runtime pm interfaces to g2d driver ...
2013-09-05Merge tag 'fbdev-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev changes from Tomi Valkeinen: - Improvements to da8xx-fb to make it support v2 of the LCDC IP, used eg in BeagleBone - Himax HX8369 controller support - Various small fixes and cleanups * tag 'fbdev-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (42 commits) video: da8xx-fb: fix the polarities of the hsync/vsync pulse video: da8xx-fb: support lcdc v2 timing register expansion video: da8xx-fb: fixing timing off by one errors video: da8xx-fb fixing incorrect porch mappings video: xilinxfb: replace devm_request_and_ioremap by devm_ioremap_resource fbmem: move EXPORT_SYMBOL annotation next to symbol declarations drivers: video: fbcmap: remove the redundency and incorrect checkings video: mxsfb: simplify use of devm_ioremap_resource Release efifb's colormap in efifb_destroy() at91/avr32/atmel_lcdfb: prepare clk before calling enable video: exynos: Ensure definitions match prototypes OMAPDSS: fix WARN_ON in 'alpha_blending_enabled' sysfs file OMAPDSS: HDMI: Fix possible NULL reference video: da8xx-fb: adding am33xx as dependency video: da8xx-fb: let compiler decide what to inline video: da8xx-fb: make clock naming consistent video: da8xx-fb: set upstream clock rate (if reqd) video: da8xx-fb: reorganize panel detection video: da8xx-fb: ensure non-null cfg in pdata video: da8xx-fb: use devres ...
2013-09-05vxlan: Notify drivers for listening UDP port changesJoseph Gasparakis
This patch adds two more ndo ops: ndo_add_rx_vxlan_port() and ndo_del_rx_vxlan_port(). Drivers can get notifications through the above functions about changes of the UDP listening port of VXLAN. Also, when physical ports come up, now they can call vxlan_get_rx_port() in order to obtain the port number(s) of the existing VXLAN interface in case they already up before them. This information about the listening UDP port would be used for VXLAN related offloads. A big thank you to John Fastabend (john.r.fastabend@intel.com) for his input and his suggestions on this patch set. CC: John Fastabend <john.r.fastabend@intel.com> CC: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Joseph Gasparakis <joseph.gasparakis@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05Merge tag 'fbdev-3.12-omap-legacy-removal' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull OMAP specific fbdev changes from Tomi Valkeinen: "I've got this pull request separate from the main fbdev pull request, as this contains a bunch of OMAP board file changes and thus could possibly be rejected in case of bad conflicts. The removal of the old display drivers depend on the board file changes, so Tony Lindgren suggested taking them together via fbdev tree. These are in linux-next, and also Tony didn't see any conflicts with any of the branches he had, so they should go in clean. - Change the OMAP board files to use the new OMAP display drivers - Remove all the old drivers, and the related auxiliary code" * tag 'fbdev-3.12-omap-legacy-removal' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (35 commits) OMAPDSS: rename omap_dss_device's 'device' field to 'dst' OMAPDSS: rename omap_dss_device's 'output' to 'src' OMAPDSS: DSS: remove legacy dss bus support OMAPDSS: RFBI: remove code related to old panel model OMAPDSS: VENC: remove code related to old panel model OMAPDSS: SDI: remove code related to old panel model OMAPDSS: DSI: remove code related to old panel model OMAPDSS: HDMI: remove code related to old panel model OMAPDSS: DPI: remove code related to old panel model OMAPDSS: remove all old panel drivers OMAPDSS: DPI: change regulator handling OMAPDSS: SDI: change regulator handling OMAPDSS: fix DPI and SDI device ids OMAPDSS: remove omap_dss_device->channel field OMAPDSS: RFBI: Mark RFBI as broken ARM: OMAP2+: Remove old display drivers from omap2plus_defconfig ARM: OMAP: AM3517EVM: use new display drivers ARM: OMAP: Zoom: use new display drivers ARM: OMAP: Pandora: use new display drivers ARM: OMAP: OMAP3EVM: use new display drivers ...
2013-09-05Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull main batch of InfiniBand/RDMA changes from Roland Dreier: - Large ocrdma HW driver update: add "fast register" work requests, fixes, cleanups - Add receive flow steering support for raw QPs - Fix IPoIB neighbour race that leads to crash - iSER updates including support for using "fast register" memory registration - IPv6 support for iWARP - XRC transport fixes * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (54 commits) RDMA/ocrdma: Fix compiler warning about int/pointer size mismatch IB/iser: Fix redundant pointer check in dealloc flow IB/iser: Fix possible memory leak in iser_create_frwr_pool() IB/qib: Move COUNTER_MASK definition within qib_mad.h header guards RDMA/ocrdma: Fix passing wrong opcode to modify_srq RDMA/ocrdma: Fill PVID in UMC case RDMA/ocrdma: Add ABI versioning support RDMA/ocrdma: Consider multiple SGES in case of DPP RDMA/ocrdma: Fix for displaying proper link speed RDMA/ocrdma: Increase STAG array size RDMA/ocrdma: Dont use PD 0 for userpace CQ DB RDMA/ocrdma: FRMA code cleanup RDMA/ocrdma: For ERX2 irrespective of Qid, num_posted offset is 24 RDMA/ocrdma: Fix to work with even a single MSI-X vector RDMA/ocrdma: Remove the MTU check based on Ethernet MTU RDMA/ocrdma: Add support for fast register work requests (FRWR) RDMA/ocrdma: Create IRD queue fix IB/core: Better checking of userspace values for receive flow steering IB/mlx4: Add receive flow steering support IB/core: Export ib_create/destroy_flow through uverbs ...
2013-09-05Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "Highlights: - OF and ACPI helpers are now included in the core, and not in external files anymore. This removes dependency problems for modules and is cleaner, in general. - mv64xxx-driver gains fifo usage to support mv78230 - imx-driver overhaul to support VF610 - various cleanups, most notably related to devm_* and CONFIG_PM usage - driver bugfixes and smaller feature additions" * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (51 commits) i2c: rcar: add rcar-H2 support i2c: sirf: retry 3 times as sometimes we get random noack and timeout i2c: sirf: support reverse direction of address i2c: sirf: fix the typo for setting bitrate to less than 100k i2c: sirf: we need to wait I2C_RESET status in resume i2c: sirf: reset i2c controller early after we get a noack i2c: designware: get SDA hold time, HCNT and LCNT configuration from ACPI i2c: designware: make HCNT/LCNT values configurable i2c: mpc: cleanup clock API use i2c: pnx: fix error return code in i2c_pnx_probe() i2c: ismt: add error return code in probe() i2c: mv64xxx: fix typo in binding documentation i2c: imx: use exact SoC revision to document binding i2c: move ACPI helpers into the core i2c: move OF helpers into the core i2c: mv64xxx: Fix timing issue on Armada XP (errata FE-8471889) i2c: mv64xxx: Add I2C Transaction Generator support i2c: powermac: fix return path on error Documentation: i2c: Fix example in instantiating-devices i2c: tiny-usb: do not use stack as URB transfer_buffer ...
2013-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "Unfortunately, this merge window it'll have a be a lot of small piles - my fault, actually, for not keeping #for-next in anything that would resemble a sane shape ;-/ This pile: assorted fixes (the first 3 are -stable fodder, IMO) and cleanups + %pd/%pD formats (dentry/file pathname, up to 4 last components) + several long-standing patches from various folks. There definitely will be a lot more (starting with Miklos' check_submount_and_drop() series)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits) direct-io: Handle O_(D)SYNC AIO direct-io: Implement generic deferred AIO completions add formats for dentry/file pathnames kvm eventfd: switch to fdget powerpc kvm: use fdget switch fchmod() to fdget switch epoll_ctl() to fdget switch copy_module_from_fd() to fdget git simplify nilfs check for busy subtree ibmasmfs: don't bother passing superblock when not needed don't pass superblock to hypfs_{mkdir,create*} don't pass superblock to hypfs_diag_create_files don't pass superblock to hypfs_vm_create_files() oprofile: get rid of pointless forward declarations of struct super_block oprofilefs_create_...() do not need superblock argument oprofilefs_mkdir() doesn't need superblock argument don't bother with passing superblock to oprofile_create_stats_files() oprofile: don't bother with passing superblock to ->create_files() don't bother passing sb to oprofile_create_files() coh901318: don't open-code simple_read_from_buffer() ...
2013-09-05Merge branches 'debug-choice', 'devel-stable' and 'misc' into for-linusRussell King
2013-09-05drm/exynos: fimd: replace struct fb_videomode with videomodeAndrzej Hajda
The patch replaces all occurrences of struct fb_videomode by more accurate struct videomode. The change allows to remove mode conversion function and simplifies clock divider calculation. Clock configuration is moved to separate function. Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com>
2013-09-04Merge branch 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Gleb Natapov: "The highlights of the release are nested EPT and pv-ticketlocks support (hypervisor part, guest part, which is most of the code, goes through tip tree). Apart of that there are many fixes for all arches" Fix up semantic conflicts as discussed in the pull request thread.. * 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (88 commits) ARM: KVM: Add newlines to panic strings ARM: KVM: Work around older compiler bug ARM: KVM: Simplify tracepoint text ARM: KVM: Fix kvm_set_pte assignment ARM: KVM: vgic: Bump VGIC_NR_IRQS to 256 ARM: KVM: Bugfix: vgic_bytemap_get_reg per cpu regs ARM: KVM: vgic: fix GICD_ICFGRn access ARM: KVM: vgic: simplify vgic_get_target_reg KVM: MMU: remove unused parameter KVM: PPC: Book3S PR: Rework kvmppc_mmu_book3s_64_xlate() KVM: PPC: Book3S PR: Make instruction fetch fallback work for system calls KVM: PPC: Book3S PR: Don't corrupt guest state when kernel uses VMX KVM: x86: update masterclock when kvmclock_offset is calculated (v2) KVM: PPC: Book3S: Fix compile error in XICS emulation KVM: PPC: Book3S PR: return appropriate error when allocation fails arch: powerpc: kvm: add signed type cast for comparation KVM: x86: add comments where MMIO does not return to the emulator KVM: vmx: count exits to userspace during invalid guest emulation KVM: rename __kvm_io_bus_sort_cmp to kvm_io_bus_cmp kvm: optimize away THP checks in kvm_is_mmio_pfn() ...
2013-09-04Merge tag 'stable/for-linus-3.12-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen updates from Konrad Rzeszutek Wilk: "A couple of features and a ton of bug-fixes. There is also some maintership changes. Jeremy is enjoying the full-time work at the startup and as much as he would love to help - he can't find the time. I have a bunch of other things that I promised to work on - paravirt diet, get SWIOTLB working everywhere, etc, but haven't been able to find the time. As such both David Vrabel and Boris Ostrovsky have graciously volunteered to help with the maintership role. They will keep the lid on regressions, bug-fixes, etc. I will be in the background to help - but eventually there will be less of me doing the Xen GIT pulls and more of them. Stefano is still doing the ARM/ARM64 and will continue on doing so. Features: - Xen Trusted Platform Module (TPM) frontend driver - with the backend in MiniOS. - Scalability improvements in event channel. - Two extra Xen co-maintainers (David, Boris) and one going away (Jeremy) Bug-fixes: - Make the 1:1 mapping work during early bootup on selective regions. - Add scratch page to balloon driver to deal with unexpected code still holding on stale pages. - Allow NMIs on PV guests (64-bit only) - Remove unnecessary TLB flush in M2P code. - Fixes duplicate callbacks in Xen granttable code. - Fixes in PRIVCMD_MMAPBATCH ioctls to allow retries - Fix for events being lost due to rescheduling on different VCPUs. - More documentation" * tag 'stable/for-linus-3.12-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (23 commits) hvc_xen: Remove unnecessary __GFP_ZERO from kzalloc drivers/xen-tpmfront: Fix compile issue with missing option. xen/balloon: don't set P2M entry for auto translated guest xen/evtchn: double free on error Xen: Fix retry calls into PRIVCMD_MMAPBATCH*. xen/pvhvm: Initialize xen panic handler for PVHVM guests xen/m2p: use GNTTABOP_unmap_and_replace to reinstate the original mapping xen: fix ARM build after 6efa20e4 MAINTAINERS: Remove Jeremy from the Xen subsystem. xen/events: document behaviour when scanning the start word for events x86/xen: during early setup, only 1:1 map the ISA region x86/xen: disable premption when enabling local irqs swiotlb-xen: replace dma_length with sg_dma_len() macro swiotlb: replace dma_length with sg_dma_len() macro xen/balloon: set a mapping for ballooned out pages xen/evtchn: improve scalability by using per-user locks xen/p2m: avoid unneccesary TLB flush in m2p_remove_override() MAINTAINERS: Add in two extra co-maintainers of the Xen tree. MAINTAINERS: Update the Xen subsystem's with proper mailing list. xen: replace strict_strtoul() with kstrtoul() ...
2013-09-04Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Minor fixes mainly, including a potential use-after-free on remove found by CONFIG_DEBUG_KOBJECT_RELEASE which may be theoretical" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: Fix mod->mkobj.kobj potentially freed too early kernel/params.c: use scnprintf() instead of sprintf() kernel/module.c: use scnprintf() instead of sprintf() module/lsm: Have apparmor module parameters work with no args module: Add NOARG flag for ops with param_set_bool_enable_only() set function module: Add flag to allow mod params to have no arguments modules: add support for soft module dependencies scripts/mod/modpost.c: permit '.cranges' secton for sh64 architecture. module: fix sprintf format specifier in param_get_byte()
2013-09-04Merge tag 'PTR_RET-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull PTR_RET() removal patches from Rusty Russell: "PTR_RET() is a weird name, and led to some confusing usage. We ended up with PTR_ERR_OR_ZERO(), and replacing or fixing all the usages. This has been sitting in linux-next for a whole cycle" [ There are still some PTR_RET users scattered about, with some of them possibly being new, but most of them existing in Rusty's tree too. We have that #define PTR_RET(p) PTR_ERR_OR_ZERO(p) thing in <linux/err.h>, so they continue to work for now - Linus ] * tag 'PTR_RET-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: GFS2: Replace PTR_RET with PTR_ERR_OR_ZERO Btrfs: volume: Replace PTR_RET with PTR_ERR_OR_ZERO drm/cma: Replace PTR_RET with PTR_ERR_OR_ZERO sh_veu: Replace PTR_RET with PTR_ERR_OR_ZERO dma-buf: Replace PTR_RET with PTR_ERR_OR_ZERO drivers/rtc: Replace PTR_RET with PTR_ERR_OR_ZERO mm/oom_kill: remove weird use of ERR_PTR()/PTR_ERR(). staging/zcache: don't use PTR_RET(). remoteproc: don't use PTR_RET(). pinctrl: don't use PTR_RET(). acpi: Replace weird use of PTR_RET. s390: Replace weird use of PTR_RET. PTR_RET is now PTR_ERR_OR_ZERO(): Replace most. PTR_RET is now PTR_ERR_OR_ZERO
2013-09-04Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "New features for 3.12: - Added aggressive extent caching using the extent status tree. This can actually decrease memory usage in read-mostly workloads since the information is much more compactly stored in the extent status tree than if we had to keep the extent tree metadata blocks in the buffer cache. This also improves Asynchronous I/O since it is it makes much less likely that we need to do metadata I/O to lookup the extent tree information. - Improve the recovery after corrupted allocation bitmaps are found when running in errors=ignore mode. Also fixed some writeback vs truncate races when using a blocksize less than the page size" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (25 commits) ext4: allow specifying external journal by pathname mount option ext4: mark group corrupt on group descriptor checksum ext4: mark block group as corrupt on inode bitmap error ext4: mark block group as corrupt on block bitmap error ext4: fix type declaration of ext4_validate_block_bitmap ext4: error out if verifying the block bitmap fails jbd2: Fix endian mixing problems in the checksumming code ext4: isolate ext4_extents.h file ext4: Fix misspellings using 'codespell' tool ext4: convert write_begin methods to stable_page_writes semantics ext4: fix use of potentially uninitialized variables in debugging code ext4: fix lost truncate due to race with writeback ext4: simplify truncation code in ext4_setattr() ext4: fix ext4_writepages() in presence of truncate ext4: move test whether extent to map can be extended to one place ext4: fix warning in ext4_da_update_reserve_space() quota: provide interface for readding allocated space into reserved space ext4: avoid reusing recently deleted inodes in no journal mode ext4: allocate delayed allocation blocks before rename ext4: start handle at least possible moment when renaming files ...
2013-09-04Merge tag 'sound-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "Changes are seen in a wide range of codes, mainly due to ASoC DAPM requirements; HD-audio shows a high peak in diffstat, it's just a removal of bunch of old static quirks. Some highlights: - HDPM: Updates for AIO/RayDAT support, TCO/sync support - RME96: Add PCM sync support - HD-audio: * A few HDMI/DP audio updates (CA assignment fix, stream switching fix, Intel DP device list support) * Device specific fixes (ASUS/CXT HP mic support, Thinkpad mic improvements, Chromebook fixes, STAC9228 Dell fixes) * Replace the all static quirks for AD codecs with the generic parser * WAKEEN support for handling irqs in the power saving mode - USB-audio: Clean up implicit fb handling and related codes - DAPM is now mandatory for ASoC CODEC drivers; all existing drivers have had some level of DAPM support added. In addition, a lot of cleanups and improvements in DAPM. - Support for ASoC cross-platform compile test - New drivers and support for Analog Devices ADAU1702 and ADAU1401(a), Asahi Kasei Microdevices AK4554, Atmel AT91ASM9x5 and WM8904 based machines, Freescale S/PDIF and SSI AC'97, Renesas R-Car SoCs, Samsung Exynos5420 SoCs, Texas Instruments PCM1681 and PCM1792A and Wolfson Microelectronics WM8997 - DT bindings for kirkwood and i.MX S/PDIF - Clean up and bug fixes: ssm2602, rt5640 and sgtl5000. - Core helpers for bitbanged AC'97 reset" * tag 'sound-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (375 commits) ALSA: hda - Re-setup HDMI pin and audio infoframe on stream switches ALSA: hda - hdmi: Fallback to ALSA allocation when selecting CA ASoC: mxs-sgtl5000: Configure the dai_links as unidirectional ASoC: soc-pcm: Allow to specify unidirectional dai_link ASoC: fsl_spdif: Staticse non-exported symbols ASoC: ssm2602: Fix cache sync ASoC: Remove unused sysfs_registered field from snd_soc_codec struct ASoC: Remove unused debugfs_dapm field from snd_soc_{platform,codec} struct ASoC: Remove unused control_type field from snd_soc_codec struct ASoC: fsl: Add one blank space after ':=' in Makefile ASoC: fsl: Add wrapping for dev_dbg() in fsl_spdif.c ASoC: rt5640: change widget sequence for depop ASoC: dapm: Fix auto-disable for inverted controls ASoC: fsl: Drop SND_SOC_FSL_UTILS from SND_SOC_IMX_SPDIF ASoC: Samsung: Do not queue cyclic buffers multiple times ASoC: ep93xx-i2s: Remove unnecessary dev_set_drvdata() ASoC: designware_i2s: Remove unnecessary dev_set_drvdata() ASoC: fsl_spdif: remove redundant dev_err call in fsl_spdif_probe() ASoC: fsl: Add S/PDIF machine driver ASoc: kirkwood: Use the Kirkwood audio driver in Dove boards ...
2013-09-04Merge tag 'pinctrl-v3.12-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control changes from Linus Walleij: "Here is the bulk of pin control changes for the v3.12 series. Most of the relevant information is in the tag. I merged in v3.11-rc7 last week to get rid of a largeish conflict within the sunxi (AllWinner) driver in linux-next and fix up the non-trivial merge the right way. That driver had a rather large fix adding locking late in the release cycle. Overall the bulk changes this time is cleanups and refactorings and not much new features, which is nice. - Refactorings for generic pin config handling in the core. - Factor out a set of device tree utilities for use in all drivers, to parse and allocate maps from the device tree. - Some fixes to the core such as more nitpicky locking. - Pushed down config array iteration into the drivers. This patch is necessary for drivers that want to iterate over configs and pile up a stack of alterations to the same register(s), or if the driver wants to take a local spinlock when committing the configuration. - A new driver for the Texas Instruments Palmas PMIC by Laxman Dewangan. This is used on the Tegra systems. - A major cleanup and modernization of the PFC (Super Hitachi and ARM SHmobile) pin controller and subdrivers. - Support for the A20 and A31 sunxi (AllWinner) SoCs. - A huge pile of fixes and cleanups: Axel Lin, Jingoo Han Dan Carpenter, Julia Lawall and Sachin Kamat did an excellent job here" * tag 'pinctrl-v3.12-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (124 commits) pinctrl: sunxi: Fix off-by-one for valid offset range checking pinctrl: sunxi: drop lock on error path pinctrl: pinconf-generic: Remove ti prefix in dev_err messages pinctrl: rockchip: Implement .request() and .free() callbacks pinctrl: at91: fix get_pullup/down function return pinctrl: sh-pfc: remove unnecessary platform_set_drvdata() pinctrl: Add s5pv210 support to pinctrl-exynos pinctrl: utils: include export.h to avoid warnings pinctrl: s3c24xx: off by one in s3c24xx_eint_init() pinctrl: mvebu: testing the wrong variable pinctrl: abx500: fix bitwise AND test pinctrl: mvebu: Convert to use devm_ioremap_resource pinctrl: Pass all configs to driver on pin_config_set() pinctrl: tz1090-pdc: Convert to devm_ioremap_resource pinctrl: tz1090: Convert to devm_ioremap_resource pinctrl: tegra: Convert to devm_ioremap_resource pinctrl: rockchip: Simplify pin_to_bank equation pinctrl: spear: Convert to devm_ioremap_resource pinctrl: rockchip: Remove of_match_ptr macro for DT only driver pinctrl: palmas: PINCTRL_PALMAS needs to select PINMUX ...
2013-09-04Merge branch 'x86-spinlocks-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 spinlock changes from Ingo Molnar: "The biggest change here are paravirtualized ticket spinlocks (PV spinlocks), which bring a nice speedup on various benchmarks. The KVM host side will come to you via the KVM tree" * 'x86-spinlocks-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/kvm/guest: Fix sparse warning: "symbol 'klock_waiting' was not declared as static" kvm: Paravirtual ticketlocks support for linux guests running on KVM hypervisor kvm guest: Add configuration support to enable debug information for KVM Guests kvm uapi: Add KICK_CPU and PV_UNHALT definition to uapi xen, pvticketlock: Allow interrupts to be enabled while blocking x86, ticketlock: Add slowpath logic jump_label: Split jumplabel ratelimit x86, pvticketlock: When paravirtualizing ticket locks, increment by 2 x86, pvticketlock: Use callee-save for lock_spinning xen, pvticketlocks: Add xen_nopvspin parameter to disable xen pv ticketlocks xen, pvticketlock: Xen implementation for PV ticket locks xen: Defer spinlock setup until boot CPU setup x86, ticketlock: Collapse a layer of functions x86, ticketlock: Don't inline _spin_unlock when using paravirt spinlocks x86, spinlock: Replace pv spinlocks with pv ticketlocks
2013-09-04net: ipv6: mld: get rid of MLDV2_MRC and simplify calculationDaniel Borkmann
Get rid of MLDV2_MRC and use our new macros for mantisse and exponent to calculate Maximum Response Delay out of the Maximum Response Code. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-04net: ipv6: mld: fix v1/v2 switchback timeout to rfc3810, 9.12.Daniel Borkmann
i) RFC3810, 9.2. Query Interval [QI] says: The Query Interval variable denotes the interval between General Queries sent by the Querier. Default value: 125 seconds. [...] ii) RFC3810, 9.3. Query Response Interval [QRI] says: The Maximum Response Delay used to calculate the Maximum Response Code inserted into the periodic General Queries. Default value: 10000 (10 seconds) [...] The number of seconds represented by the [Query Response Interval] must be less than the [Query Interval]. iii) RFC3810, 9.12. Older Version Querier Present Timeout [OVQPT] says: The Older Version Querier Present Timeout is the time-out for transitioning a host back to MLDv2 Host Compatibility Mode. When an MLDv1 query is received, MLDv2 hosts set their Older Version Querier Present Timer to [Older Version Querier Present Timeout]. This value MUST be ([Robustness Variable] times (the [Query Interval] in the last Query received)) plus ([Query Response Interval]). Hence, on *default* the timeout results in: [RV] = 2, [QI] = 125sec, [QRI] = 10sec [OVQPT] = [RV] * [QI] + [QRI] = 260sec Having that said, we currently calculate [OVQPT] (here given as 'switchback' variable) as ... switchback = (idev->mc_qrv + 1) * max_delay RFC3810, 9.12. says "the [Query Interval] in the last Query received". In section "9.14. Configuring timers", it is said: This section is meant to provide advice to network administrators on how to tune these settings to their network. Ambitious router implementations might tune these settings dynamically based upon changing characteristics of the network. [...] iv) RFC38010, 9.14.2. Query Interval: The overall level of periodic MLD traffic is inversely proportional to the Query Interval. A longer Query Interval results in a lower overall level of MLD traffic. The value of the Query Interval MUST be equal to or greater than the Maximum Response Delay used to calculate the Maximum Response Code inserted in General Query messages. I assume that was why switchback is calculated as is (3 * max_delay), although this setting seems to be meant for routers only to configure their [QI] interval for non-default intervals. So usage here like this is clearly wrong. Concluding, the current behaviour in IPv6's multicast code is not conform to the RFC as switch back is calculated wrongly. That is, it has a too small value, so MLDv2 hosts switch back again to MLDv2 way too early, i.e. ~30secs instead of ~260secs on default. Hence, introduce necessary helper functions and fix this up properly as it should be. Introduced in 06da92283 ("[IPV6]: Add MLDv2 support."). Credits to Hannes Frederic Sowa who also had a hand in this as well. Also thanks to Hangbin Liu who did initial testing. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: David Stevens <dlstevens@us.ibm.com> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
