Regulators may sometimes take longer to enable than the control operation
used to do so, either because the regulator has ramp rate control used to
limit inrush current or because the control operation is very fast (GPIO
being the most common example of this). In order to ensure that consumers
do not rely on the regulator before it is enabled provide an enable_time()
operation and have the core delay for that time before returning to the
caller.
This is implemented as a function since the ramp rate may be specified in
voltage per unit time and therefore the time depend on the configuration.
In future it would be desirable to allow the bulk operations to run the
delays for multiple enables in parallel but this is not currently supported.
The intended use case is for drivers which disable regulators to save
power but need to do some work to restore the hardware state when
restarting. If the supplies are not actually disabled due to board
limits or sharing with other active devices this notifier allows the
driver to avoid unneeded reinitialisation, particularly when used with
runtime PM.
* 'for-linus' of git://gitorious.org/linux-omap-dss2/linux: (49 commits)
OMAP: DSS2: Taal: Fix TE when resuming
OMAP: DSS2: Taal: Fix ESD check
OMAP: DSS2: OMAPFB: Constify some function parameters
OMAP: DSS2: OMAPFB: install omapfb.h
OMAP: DSS2: DSI: add error prints
OMAP: DSS2: TPO-TD03MTEA1: fix function names
OMAP: DSS2: DSI: add dsi_vc_dcs_read_2() helper
OMAP: DSS2: OMAPFB: Remove FB_OMAP2_FORCE_AUTO_UPDATE
OMAP: DSS2: DSI: remove external TE support
OMAP: DSS2: move timing functions
OMAP: DSS2: move set/get_wss()
OMAP: DSS2: move enable/disable/suspend/resume
OMAP: DSS2: move update() and sync()
OMAP: DSS2: move set/get_update_mode()
OMAP: DSS2: move enable/get_te()
OMAP: DSS2: move get_recommended_bpp()
OMAP: DSS2: move get_resolution()
OMAP: DSS2: move enable/disable_channel to overlay manager
OMAP: DSS2: move wait_vsync()
OMAP: DSS2: move get/set_rotate()
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (214 commits)
omap2: Initialize Menelaus and MMC for N8X0
AM3517 EVM: correct typo - tca6416 mispelt as tca6516
AM3517 EVM: Enable I2C support
AM35x: Enable OMAP_MUX in defconfig
AM35x: Add missing GPIO mux config for EHCI port
Zoom3: Defconfig update
omap: i2c: Fix muxing for command line enabled bus
OMAP4: clock: Remove clock hacks from timer-gp.c
OMAP4: clock: Add dummy clock nodes for interface clocks
OMAP4: clock: Rename leaf clock nodes to end with a _ick or _fck
OMAP2+ clock: revise omap2_clk_{disable,enable}()
OMAP2/3 clock: combine OMAP2 & 3 boot-time MPU rate change code
OMAP clockdomain: if no autodeps exist, don't try to add or remove them
OMAP hwmod: add hwmod class support
OMAP hwmod: convert header files with static allocations into C files
OMAP hwmod: convert hwmod to use hardware clock names rather than clkdev dev+con
OMAP clock: add omap_clk_get_by_name() for use by OMAP hwmod core code
OMAP3: clock: add capability to change rate of dpll4_m5_ck_3630
OMAP4 clock: drop the ALWAYS_ENABLED clock flag
OMAP clock: drop RATE_FIXED clock flag
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1341 commits)
virtio_net: remove forgotten assignment
be2net: fix tx completion polling
sis190: fix cable detect via link status poll
net: fix protocol sk_buff field
bridge: Fix build error when IGMP_SNOOPING is not enabled
bnx2x: Tx barriers and locks
scm: Only support SCM_RIGHTS on unix domain sockets.
vhost-net: restart tx poll on sk_sndbuf full
vhost: fix get_user_pages_fast error handling
vhost: initialize log eventfd context pointer
vhost: logging thinko fix
wireless: convert to use netdev_for_each_mc_addr
ethtool: do not set some flags, if others failed
ipoib: returned back addrlen check for mc addresses
netlink: Adding inode field to /proc/net/netlink
axnet_cs: add new id
bridge: Make IGMP snooping depend upon BRIDGE.
bridge: Add multicast count/interval sysfs entries
bridge: Add hash elasticity/max sysfs entries
bridge: Add multicast_snooping sysfs toggle
Trivial conflicts in Documentation/feature-removal-schedule.txt
Commit e992cd9b72a18 (kmemcheck: make bitfield annotations truly no-ops
when disabled) allows us to revert a workaround we did in the past to
not add holes in sk_buff structure.
This patch partially reverts commit 14d18a81b5171
(net: fix kmemcheck annotations) so that sparse doesnt complain:
include/linux/skbuff.h:357:41: error: invalid bitfield specifier for
type restricted __be16.
Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
arch/arm/plat-omap/Kconfig
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci
* 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (40 commits)
DaVinci DM365: Adding support for SPI EEPROM
DaVinci DM365: Adding DM365 SPI support
DaVinci DM355: Modifications to DM355 SPI support
DaVinci: SPI: Adding header file for SPI support.
davinci: dm646x: CDCE clocks: davinci_clk converted to clk_lookup
davinci: clkdev cleanup: remove clk_lookup wrapper, use clkdev_add_table()
DaVinci: DM365: Voice codec support for the DM365 SoC
davinci: clock: let clk->set_rate function sleep
Add SDA and SCL pin numbers to i2c platform data
davinci: da8xx/omap-l1xx: Add EDMA platform data for da850/omap-l138
davinci: build list of unused EDMA events dynamically
davinci: Fix edma_alloc_channel api for EDMA_CHANNEL_ANY case
davinci: Keep count of channel controllers on a platform
davinci: Correct return value of edma_alloc_channel api
davinci: add CDCE949 support on DM6467 EVM
davinci: add support for CDCE949 clock synthesizer
davinci: da850/omap-l138 EVM: register for suspend support
davinci: da850/omap-l138: add support for SoC suspend
davinci: add power management support
DaVinci: DM365: Changing default queue for DM365.
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (38 commits)
sata_via: Delay on vt6420 when starting ATAPI DMA write
ata: Detect Delkin Devices compact flash
pata_efar: Enable parallel scanning
pata_atiixp: enable parallel scan
[libata] pata_atiixp: add locking for parallel scanning
[libata] pata_efar: add locking for parallel scanning
libata: Pass host flags into the pci helper
[libata] pata_marvell: CONFIG_AHCI is really CONFIG_SATA_AHCI
libata: Allow pata_legacy to be built on non-ISA but PCI systems
pata_pdc202xx_old: fix UDMA mode for PDC2026x chipsets
pata_pdc202xx_old: fix UDMA mode for Promise UDMA33 cards
[libata] pata_at91: fix backslash-continued string
pata_via: store UDMA masks in via_isa_bridges table
pata_via: fix address setup timings underlocking
pata_serverworks: fix error message
pata_serverworks: fix PIO setup for the second channel
pata_efar: fix secondary port support
pata_cypress: fix PIO timings underclocking
pata_cs5535: use correct values for PIO1 and PIO2 data timings
pata_cmd64x: remove unused definitions
I have a Delkin Devices compact flash card that isn't being recognized using the
SATA/PATA drivers.
The card is recognized and works with the deprecated ATA drivers.
The error I am seeing is:
ata1.00: failed to IDENTIFY (device reports invalid type, err_mask=0x0)
I tracked it down to ata_id_is_cfa() in include/linux/ata.h.
The Delkin card has id[0] set to 0x844a and id[83] set to 0.
This isn't what the kernel expects and is probably incorrect.
The simplest work-around is to add a check for 0x844a to ata_id_is_cfa().
Signed-off-by: Ben Gardner <gardner.ben@gmail.com>
This allows parallel scan and the like to be set without having to stop
using the existing full helper functions. This patch merely adds the argument
and fixes up the callers. It doesn't undo the special cases already in the
tree or add any new parallel callers.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Traditional IDE interface sucks in that it doesn't have a reliable IRQ
pending bit, so if the controller raises IRQ while the driver is
expecting it not to, the IRQ won't be cleared and eventually the IRQ
line will be killed by interrupt subsystem. Some controllers have
non-standard mechanism to indicate IRQ pending so that this condition
can be detected and worked around.
This patch adds an optional operation ->sff_irq_check() which will be
called for each port from the ata_sff_interrupt() if an unexpected
interrupt is received. If the operation returns %true,
->sff_check_status() and ->sff_irq_clear() will be cleared for the
port. Note that this doesn't mark the interrupt as handled so it
won't prevent IRQ subsystem from killing the IRQ if this mechanism
fails to clear the spurious IRQ.
This patch also implements ->sff_irq_check() for ata_piix. Note that
this adds slight overhead to shared IRQ operation as IRQs which are
destined for other controllers will trigger extra register accesses to
check whether IDE interrupt is pending but this solves rare screaming
IRQ cases and for some curious reason also helps weird BIOS related
glitch on Samsung n130 as reported in bko#14314.
http://bugzilla.kernel.org/show_bug.cgi?id=14314
* piix_base_ops dropped as suggested by Sergei.
* Spurious IRQ detection doesn't kick in anymore if polling qc is in
progress. This provides less protection but some controllers have
possible data corruption issues if the wrong register is accessed
while a command is in progress.
Reported-by: Johannes Stezenbach <js@sig21.net>
Reported-by: Hans Werner <hwerner4@gmx.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (62 commits)
Input: atkbd - release previously reserved keycodes 248 - 254
Input: add KEY_WPS_BUTTON definition
Input: ads7846 - add regulator support
Input: winbond-cir - fix suspend/resume
Input: gamecon - use pr_err() and friends
Input: gamecon - constify some of the setup structures
Input: gamecon - simplify pad type handling
Input: gamecon - simplify coordinate calculation for PSX
Input: gamecon - fix some formatting issues
Input: gamecon - add rumble support for N64 pads
Input: wacom - add device type to device name string
Input: s3c24xx_ts - report touch only when stylus is down
Input: s3c24xx_ts - re-enable IRQ on resume
Input: wacom - constify product features data
Input: wacom - use per-device instance of wacom_features
Input: sh_keysc - enable building on SH-Mobile ARM
Input: wacom - get features from driver info
Input: rotary-encoder - set gpio direction for each requested gpio
Input: sh_keysc - update the driver with mode 6
Input: sh_keysc - switch to using bitmaps
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI: replace acpi_integer by u64
ACPICA: Update version to 20100121.
ACPICA: Remove unused uint32_struct type
ACPICA: Disassembler: Remove obsolete "Integer64" field in parse object
ACPICA: Remove obsolete ACPI_INTEGER (acpi_integer) type
ACPICA: Predefined name repair: fix NULL package elements
ACPICA: AcpiGetDevices: Eliminate unnecessary _STA calls
ACPICA: Update all ACPICA copyrights and signons to 2010
ACPICA: Update for new gcc-4 warning options
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits)
ARM: Eliminate decompressor -Dstatic= PIC hack
ARM: 5958/1: ARM: U300: fix inverted clk round rate
ARM: 5956/1: misplaced parentheses
ARM: 5955/1: ep93xx: move timer defines into core.c and document
ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c
ARM: 5953/1: ep93xx: fix broken build of clock.c
ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig
ARM: 5949/1: NUC900 add gpio virtual memory map
ARM: 5948/1: Enable timer0 to time4 clock support for nuc910
ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk
ARM: make_coherent(): fix problems with highpte, part 2
MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself
ARM: 5945/1: ep93xx: include correct irq.h in core.c
ARM: 5933/1: amba-pl011: support hardware flow control
ARM: 5930/1: Add PKMAP area description to memory.txt.
ARM: 5929/1: Add checks to detect overlap of memory regions.
ARM: 5928/1: Change type of VMALLOC_END to unsigned long.
ARM: 5927/1: Make delimiters of DMA area globally visibly.
ARM: 5926/1: Add "Virtual kernel memory..." printout.
ARM: 5920/1: OMAP4: Enable L2 Cache
Fix up trivial conflict in arch/arm/mach-mx25/clock.c
* 'for-2.6.34' of git://git.kernel.dk/linux-2.6-block: (38 commits)
block: don't access jiffies when initialising io_context
cfq: remove 8 bytes of padding from cfq_rb_root on 64 bit builds
block: fix for "Consolidate phys_segment and hw_segment limits"
cfq-iosched: quantum check tweak
blktrace: perform cleanup after setup error
blkdev: fix merge_bvec_fn return value checks
cfq-iosched: requests "in flight" vs "in driver" clarification
cciss: Fix problem with scatter gather elements in the scsi half of the driver
cciss: eliminate unnecessary pointer use in cciss scsi code
cciss: do not use void pointer for scsi hba data
cciss: factor out scatter gather chain block mapping code
cciss: fix scatter gather chain block dma direction kludge
cciss: simplify scatter gather code
cciss: factor out scatter gather chain block allocation and freeing
cciss: detect bad alignment of scsi commands at build time
cciss: clarify command list padding calculation
cfq-iosched: rethink seeky detection for SSDs
cfq-iosched: rework seeky detection
block: remove padding from io_context on 64bit builds
block: Consolidate phys_segment and hw_segment limits
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (252 commits)
ASoC: Check progress when reporting periods from i.MX FIQ handler
ASoC: Remove a unused variables from i.MX FIQ runtime data
ALSA: hda - Add/fix ALC269 FSC and Quanta models
ALSA: hda - Add ALC670 codec support
OMAP4: PMIC: Add support for twl6030 codec
ALSA: hda - remove unnecessary msleep on power state transitions
usb/gadget/{f_audio,gmidi}.c: follow recent changes in audio.h
ASoC: fsi: Modify over/under run error settlement
ASoC: OMAP4: Add McPDM platform driver
ASoC: OMAP4: Add support for McPDM
ASoC: OMAP: data_type and sync_mode configurable in audio dma
ALSA: hda - Add missing description in HD-Audio-Models.txt
ALSA: add support for Macbook Air 2,1 internal speaker
ALSA: usbaudio: consolidate header files
ALSA: usbmixer: bail out early when parsing audio class v2 descriptors
ALSA: usbaudio: implement basic set of class v2.0 parser
ALSA: usbaudio: introduce new types for audio class v2
ALSA: usbaudio: parse USB descriptors with structs
ALSA: hda - enable snoop for Intel Cougar Point
ALSA: hda - Remove identical definitions for macmini3 model
'bkl-drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Protect pid lookup in compat code with RCU
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: Fix documentation of default chip disable()
* 'bkl-drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
nvram: Drop the BKL from nvram_open()
* 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
posix-timers.c: Don't export local functions
clocksource: start CMT at clocksource resume
clocksource: add suspend callback
clocksource: add argument to resume callback
ntp: Cleanup xtime references in ntp.c
ntp: Make time_esterror and time_maxerror static
omapfb has several custom ioctls so user space needs
the header in order to utilize them.
Signed-off-by: Ville Syrjälä <ville.syrjala@nokia.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
drivers/firmware/iscsi_ibft.c
* 'x86-ptrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, ptrace: Remove set_stopped_child_used_math() in [x]fpregs_set
x86, ptrace: Simplify xstateregs_get()
ptrace: Fix ptrace_regset() comments and diagnose errors specifically
parisc: Disable CONFIG_HAVE_ARCH_TRACEHOOK
ptrace: Add support for generic PTRACE_GETREGSET/PTRACE_SETREGSET
x86, ptrace: regset extensions to support xstate
* 'x86-pci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Enable NMI on all cpus on UV
vgaarb: Add user selectability of the number of GPUS in a system
vgaarb: Fix VGA arbiter to accept PCI domains other than 0
x86, uv: Update UV arch to target Legacy VGA I/O correctly.
pci: Update pci_set_vga_state() to call arch functions
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, mm: Unify kernel_physical_mapping_init() API
x86, mm: Allow highmem user page tables to be disabled at boot time
x86: Do not reserve brk for DMI if it's not going to be used
x86: Convert tlbstate_lock to raw_spinlock
x86: Use the generic page_is_ram()
x86: Remove BIOS data range from e820
Move page_is_ram() declaration to mm.h
Generic page_is_ram: use __weak
resources: introduce generic page_is_ram()
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits)
sched: Fix SCHED_MC regression caused by change in sched cpu_power
sched: Don't use possibly stale sched_class
kthread, sched: Remove reference to kthread_create_on_cpu
sched: cpuacct: Use bigger percpu counter batch values for stats counters
percpu_counter: Make __percpu_counter_add an inline function on UP
sched: Remove member rt_se from struct rt_rq
sched: Change usage of rt_rq->rt_se to rt_rq->tg->rt_se[cpu]
sched: Remove unused update_shares_locked()
sched: Use for_each_bit
sched: Queue a deboosted task to the head of the RT prio queue
sched: Implement head queueing for sched_rt
sched: Extend enqueue_task to allow head queueing
sched: Remove USER_SCHED
sched: Fix the place where group powers are updated
sched: Assume *balance is valid
sched: Remove load_balance_newidle()
sched: Unify load_balance{,_newidle}()
sched: Add a lock break for PREEMPT=y
sched: Remove from fwd decls
sched: Remove rq_iterator from move_one_task
Fix up trivial conflicts in kernel/sched.c
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Fix race between ttwu() and task_rq_lock()
sched: Fix SMT scheduler regression in find_busiest_queue()
sched: Fix sched_mv_power_savings for !SMT
kernel/sched.c: Suppress unused var warning
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (172 commits)
perf_event, amd: Fix spinlock initialization
perf_event: Fix preempt warning in perf_clock()
perf tools: Flush maps on COMM events
perf_events, x86: Split PMU definitions into separate files
perf annotate: Handle samples not at objdump output addr boundaries
perf_events, x86: Remove superflous MSR writes
perf_events: Simplify code by removing cpu argument to hw_perf_group_sched_in()
perf_events, x86: AMD event scheduling
perf_events: Add new start/stop PMU callbacks
perf_events: Report the MMAP pgoff value in bytes
perf annotate: Defer allocating sym_priv->hist array
perf symbols: Improve debugging information about symtab origins
perf top: Use a macro instead of a constant variable
perf symbols: Check the right return variable
perf/scripts: Tag syscall_name helper as not yet available
perf/scripts: Add perf-trace-python Documentation
perf/scripts: Remove unnecessary PyTuple resizes
perf/scripts: Add syscall tracing scripts
perf/scripts: Add Python scripting engine
perf/scripts: Remove check-perf-trace from listed scripts
Fix trivial conflict in tools/perf/util/probe-event.c
* 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits)
ftrace: Add function names to dangling } in function graph tracer
tracing: Simplify memory recycle of trace_define_field
tracing: Remove unnecessary variable in print_graph_return
tracing: Fix typo of info text in trace_kprobe.c
tracing: Fix typo in prof_sysexit_enable()
tracing: Remove CONFIG_TRACE_POWER from kernel config
tracing: Fix ftrace_event_call alignment for use with gcc 4.5
ftrace: Remove memory barriers from NMI code when not needed
tracing/kprobes: Add short documentation for HAVE_REGS_AND_STACK_ACCESS_API
s390: Add pt_regs register and stack access API
tracing/kprobes: Make Kconfig dependencies generic
tracing: Unify arch_syscall_addr() implementations
tracing: Add notrace to TRACE_EVENT implementation functions
ftrace: Allow to remove a single function from function graph filter
tracing: Add correct/incorrect to sort keys for branch annotation output
tracing: Simplify test for function_graph tracing start point
tracing: Drop the tr check from the graph tracing path
tracing: Add stack dump to trace_printk if stacktrace option is set
tracing: Use appropriate perl constructs in recordmcount.pl
tracing: optimize recordmcount.pl for offsets-handling
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (44 commits)
rcu: Fix accelerated GPs for last non-dynticked CPU
rcu: Make non-RCU_PROVE_LOCKING rcu_read_lock_sched_held() understand boot
rcu: Fix accelerated grace periods for last non-dynticked CPU
rcu: Export rcu_scheduler_active
rcu: Make rcu_read_lock_sched_held() take boot time into account
rcu: Make lockdep_rcu_dereference() message less alarmist
sched, cgroups: Fix module export
rcu: Add RCU_CPU_STALL_VERBOSE to dump detailed per-task information
rcu: Fix rcutorture mod_timer argument to delay one jiffy
rcu: Fix deadlock in TREE_PREEMPT_RCU CPU stall detection
rcu: Convert to raw_spinlocks
rcu: Stop overflowing signed integers
rcu: Use canonical URL for Mathieu's dissertation
rcu: Accelerate grace period if last non-dynticked CPU
rcu: Fix citation of Mathieu's dissertation
rcu: Documentation update for CONFIG_PROVE_RCU
security: Apply lockdep-based checking to rcu_dereference() uses
idr: Apply lockdep-based diagnostics to rcu_dereference() uses
radix-tree: Disable RCU lockdep checking in radix tree
vfs: Abstract rcu_dereference_check for files-fdtable use
'tracing-fixes-for-linus', 'x86-debug-for-linus', 'x86-doc-for-linus', 'x86-gpu-for-linus' and 'x86-rlimit-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'core-ipi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
generic-ipi: Optimize accesses by using DEFINE_PER_CPU_SHARED_ALIGNED for IPI data
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
plist: Fix grammar mistake, and c-style mistake
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
kprobes: Add mcount to the kprobes blacklist
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86_64: Print modules like i386 does
* 'x86-doc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Put 'nopat' in kernel-parameters
* 'x86-gpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86-64: Allow fbdev primary video code
* 'x86-rlimit-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Use helpers for rlimits
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-next-2.6
This patch adds the pci_vpd_find_info_keyword() helper function to
find information field keywords within read-only and read-write large
resource data type sections.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
This patch adds a preprocessor constant to describe the PCI VPD
information field header size and an inline function to extract the
size of the information field itself.
This patch adds the pci_vpd_find_tag() helper function to find VPD
resource data types in a buffer.
This patch introduces more VPD preprocessor definitions to identify some
small and large resource data type item names. The patch then continues
to correct how the tg3 and bnx2 drivers search for the "read-only data"
large resource data type.
This patch adds a preprocessor constant to describe the PCI VPD large
resource data type tag size and an inline function to extract the large
resource section size from the large resource data type tag.
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (35 commits)
[S390] time: remove unused code
[S390] zcore: Add prefix registers to dump header
[S390] correct vdso version string
[S390] add support for compressed kernels
[S390] Define new s390 ELF note sections in elf.h
[S390] codepage conversion of kernel parameter line
[S390] seq_file: convert drivers/s390/
[S390] add z9-ec/z10 instruction to kernel disassembler
[S390] dasd: correct offline processing
[S390] dasd: fix refcounting.
[S390] dasd: fix online/offline race
[S390] use kprobes_built_in() in mm/fault code
[S390] bug: use relative pointers in bug table entries
[S390] Cleanup struct _lowcore usage and defines.
[S390] free_initmem: reduce code duplication
[S390] Replace ENOTSUPP usage with EOPNOTSUPP
[S390] spinlock: check virtual cpu running status
[S390] sysinfo: fix SYSIB 3,2,2 structure
[S390] add MACHINE_IS_LPAR flag
[S390] qdio: optimize cache line usage of struct qdio_irq
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (49 commits)
pcmcia: validate late-added resources
pcmcia: allow for extension of resource interval
pcmcia: remove useless msleep in ds.c
pcmcia: use read_cis_mem return value
pcmcia: handle error in serial_cs config calls
pcmcia: add locking to pcmcia_{read,write}_cis_mem
pcmcia: avoid prod_id memleak
pcmcia: avoid sysfs-related lockup for cardbus
pcmcia: use state machine for extended requery
pcmcia: delay re-scanning and re-querying of PCMCIA bus
pcmcia: use pccardd to handle eject, insert, suspend and resume requests
pcmcia: use ops_mutex for rsrc_{mgr,nonstatic} locking
pcmcia: use mutex for dynid lock
pcmcia: assert locking to struct pcmcia_device
pcmcia: add locking documentation
pcmcia: simplify locking
pcmcia: add locking to struct pcmcia_socket->pcmcia_state()
pcmcia: protect s->device_count
pcmcia: properly lock skt->irq, skt->irq_mask
pcmcia: lock ops->set_socket
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (88 commits)
powerpc: Fix lwsync feature fixup vs. modules on 64-bit
powerpc: Convert pmc_owner_lock to raw_spinlock
powerpc: Convert die.lock to raw_spinlock
powerpc: Convert tlbivax_lock to raw_spinlock
powerpc: Convert mpic locks to raw_spinlock
powerpc: Convert pmac_pic_lock to raw_spinlock
powerpc: Convert big_irq_lock to raw_spinlock
powerpc: Convert feature_lock to raw_spinlock
powerpc: Convert i8259_lock to raw_spinlock
powerpc: Convert beat_htab_lock to raw_spinlock
powerpc: Convert confirm_error_lock to raw_spinlock
powerpc: Convert ipic_lock to raw_spinlock
powerpc: Convert native_tlbie_lock to raw_spinlock
powerpc: Convert beatic_irq_mask_lock to raw_spinlock
powerpc: Convert nv_lock to raw_spinlock
powerpc: Convert context_lock to raw_spinlock
powerpc/85xx: Add NOR, LEDs and PIB support for MPC8568E-MDS boards
powerpc/86xx: Enable VME driver on the GE SBC610
powerpc/86xx: Enable VME driver on the GE PPC9A
powerpc/86xx: Add MSI section to GE PPC9A DTS
With the Bluetooth 3.0 specification and the introduction of alternate
MAC/PHY (AMP) support, it is required to differentiate between primary
BR/EDR controllers and 802.11 AMP controllers. So introduce a special
type inside HCI device for differentiation.
For now all AMP controllers will be treated as raw devices until an
AMP manager has been implemented.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
The output of the inquiry cache is only useful for debugging purposes
and so move it into debugfs.
The hdev->type is misnamed and should be actually hdev->bus instead. So
convert it now.
The alignment requirement for 64-bit load/store instructions on ARM is
implementation defined. Some CPUs (such as Marvell Feroceon) do not
generate an exception, if such an instruction is executed with an
address that is not 64 bit aligned. In such a case, the Feroceon
corrupts adjacent memory, which showed up in my tests as a crash in the
rx path of ath9k that only occured with CONFIG_XFRM set.
This crash happened, because the first field of the mac80211 rx status
info in the cb is an u64, and changing it corrupted the skb->sp field.
This patch also closes some potential pre-existing holes in the sk_buff
struct surrounding the cb[] area.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Cc: stable@kernel.org
commit e8469ed959c373c2ff9e6f488aa5a14971aebe1f
Author: Patrick McHardy <kaber@trash.net>
Date: Tue Feb 23 20:41:30 2010 +0100
Support specifying the initial device flags when creating a device though
rtnl_link. Devices allocated by rtnl_create_link() are marked as INITIALIZING
in order to surpress netlink registration notifications. To complete setup,
rtnl_configure_link() must be called, which performs the device flag changes
and invokes the deferred notifiers if everything went well.
Two examples:
# add macvlan to eth0
$ ip link add link eth0 up allmulticast on type macvlan
[LINK]11: macvlan0@eth0: <BROADCAST,MULTICAST,ALLMULTI,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN
link/ether 26:f8:84:02:f9:2a brd ff:ff:ff:ff:ff:ff
[ROUTE]ff00::/8 dev macvlan0 table local metric 256 mtu 1500 advmss 1440 hoplimit 0
[ROUTE]fe80::/64 dev macvlan0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
[ADDR]11: macvlan0 inet6 fe80::24f8:84ff:fe02:f92a/64 scope link
valid_lft forever preferred_lft forever
[ROUTE]local fe80::24f8:84ff:fe02:f92a via :: dev lo table local proto none metric 0 mtu 16436 advmss 16376 hoplimit 0
[ROUTE]default via fe80::215:e9ff:fef0:10f8 dev macvlan0 proto kernel metric 1024 mtu 1500 advmss 1440 hoplimit 0
[NEIGH]fe80::215:e9ff:fef0:10f8 dev macvlan0 lladdr 00:15:e9:f0:10:f8 router STALE
[ROUTE]2001:6f8:974::/64 dev macvlan0 proto kernel metric 256 expires 0sec mtu 1500 advmss 1440 hoplimit 0
[PREFIX]prefix 2001:6f8:974::/64 dev macvlan0 onlink autoconf valid 14400 preferred 131084
[ADDR]11: macvlan0 inet6 2001:6f8:974:0:24f8:84ff:fe02:f92a/64 scope global dynamic
valid_lft 86399sec preferred_lft 14399sec
# add VLAN to eth1, eth1 is down
$ ip link add link eth1 up type vlan id 1000
RTNETLINK answers: Network is down
<no events>
Split dev_change_flags() into two functions: __dev_change_flags() to
perform the actual changes and __dev_notify_flags() to invoke netdevice
notifiers. This will be used by rtnl_link to defer netlink notifications
until the device has been fully configured.
This changes ordering of some operations, in particular:
- netlink notifications are sent after all changes have been performed.
As a side effect this surpresses one unnecessary netlink message when
the IFF_UP and other flags are changed simultaneously.
- The NETDEV_UP/NETDEV_DOWN and NETDEV_CHANGE notifiers are invoked
after all changes have been performed. Their relative is unchanged.
- net_dmaengine_put() is invoked before the NETDEV_DOWN notifier instead
of afterwards. This should not make any difference since both RX and TX
are already shut down at this point.
In order to support specifying device flags during device creation,
we must be able to roll back device registration in case setting the
flags fails without sending any notifications related to the device
to userspace.
This patch changes rollback_registered_many() and register_netdevice()
to manually send netlink notifications for devices not handled by
rtnl_link and allows to defer notifications for devices handled by
rtnl_link until setup is complete.
