path: root/include
2015-11-10Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "I Was Almost Tempted To Capitalise Every Word, but then I decided I couldn't read it myself! I've also got one pull request for the sti driver outstanding. It relied on a commit in Greg's tree and I didn't find out in time, that commit is in your tree now so I might send that along once this is merged. I also had the accidental misfortune to have access to a Skylake on my desk for a few days, and I've had to encourage Intel to try harder, which seems to be happening now. Here is the main drm-next pull request for 4.4. Highlights: New driver: vc4 driver for the Rasberry Pi VPU. (From Eric Anholt at Broadcom.) Core: Atomic fbdev support Atomic helpers for runtime pm dp/aux i2c STATUS_UPDATE handling struct_mutex usage cleanups. Generic of probing support. Documentation: Kerneldoc for VGA switcheroo code. Rename to gpu instead of drm to reflect scope. i915: Skylake GuC firmware fixes HPD A support VBT backlight fallbacks Fastboot by default for some systems FBC work BXT/SKL workarounds Skylake deeper sleep state fixes amdgpu: Enable GPU scheduler by default New atombios opcodes GPUVM debugging options Stoney support. Fencing cleanups. radeon: More efficient CS checking nouveau: gk20a instance memory handling improvements. Improved PGOB detection and GK107 support Kepler GDDR5 PLL statbility improvement G8x/GT2xx reclock improvements new userspace API compatiblity fixes. virtio-gpu: Add 3D support - qemu 2.5 has it merged for it's gtk backend. msm: Initial msm88896 (snapdragon 8200) exynos: HDMI cleanups Enable mixer driver byt default Add DECON-TV support vmwgfx: Move to using memremap + fixes. rcar-du: Add support for R8A7793/4 DU armada: Remove support for non-component mode Improved plane handling Power savings while in DPMS off. tda998x: Remove unused slave encoder support Use more HDMI helpers Fix EDID read handling dwhdmi: Interlace video mode support for ipu-v3/dw_hdmi Hotplug state fixes Audio driver integration imx: More color formats support. tegra: Minor fixes/improvements" [ Merge fixup: remove unused variable 'dev' that had all uses removed in commit 4e270f088011: "drm/gem: Drop struct_mutex requirement from drm_gem_mmap_obj" ] * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (764 commits) drm/vmwgfx: Relax irq locking somewhat drm/vmwgfx: Properly flush cursor updates and page-flips drm/i915/skl: disable display side power well support for now drm/i915: Extend DSL readout fix to BDW and SKL. drm/i915: Do graphics device reset under forcewake drm/i915: Skip fence installation for objects with rotated views (v4) vga_switcheroo: Drop client power state VGA_SWITCHEROO_INIT drm/amdgpu: group together common fence implementation drm/amdgpu: remove AMDGPU_FENCE_OWNER_MOVE drm/amdgpu: remove now unused fence functions drm/amdgpu: fix fence fallback check drm/amdgpu: fix stoping the scheduler timeout drm/amdgpu: cleanup on error in amdgpu_cs_ioctl() drm/i915: Fix locking around GuC firmware load drm/amdgpu: update Fiji's Golden setting drm/amdgpu: update Fiji's rev id drm/amdgpu: extract common code in vi_common_early_init drm/amd/scheduler: don't oops on failure to load drm/amdgpu: don't oops on failure to load (v2) drm/amdgpu: don't VT switch on suspend ...
2015-11-09Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patch-bomb from Andrew Morton: "We're pretty much done over here - I'm still waiting for a nouveau merge so I can cleanly finish up Christoph's dma-mapping rework. - bunch of small misc stuff - fold abs64() into abs(), remove abs64() - new_valid_dev() cleanups - binfmt_elf_fdpic feature work" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (24 commits) fs/binfmt_elf_fdpic.c: provide NOMMU loader for regular ELF binaries fs/stat.c: remove unnecessary new_valid_dev() check fs/reiserfs/namei.c: remove unnecessary new_valid_dev() check fs/nilfs2/namei.c: remove unnecessary new_valid_dev() check fs/ncpfs/dir.c: remove unnecessary new_valid_dev() check fs/jfs: remove unnecessary new_valid_dev() checks fs/hpfs/namei.c: remove unnecessary new_valid_dev() check fs/f2fs/namei.c: remove unnecessary new_valid_dev() check fs/ext2/namei.c: remove unnecessary new_valid_dev() check fs/exofs/namei.c: remove unnecessary new_valid_dev() check fs/btrfs/inode.c: remove unnecessary new_valid_dev() check fs/9p: remove unnecessary new_valid_dev() checks include/linux/kdev_t.h: old/new_valid_dev() can return bool include/linux/kdev_t.h: remove unused huge_valid_dev() kmap_atomic_to_page() has no users, remove it drivers/scsi/cxgbi: fix build with EXTRA_CFLAGS dma: remove external references to dma_supported Documentation/sysctl/vm.txt: fix misleading code reference of overcommit_memory remove abs64() kernel.h: make abs() work with 64-bit types ...
2015-11-09Merge tag 'nfs-for-4.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Highlights include: New features: - RDMA client backchannel from Chuck - Support for NFSv4.2 file CLONE using the btrfs ioctl Bugfixes + cleanups: - Move socket data receive out of the bottom halves and into a workqueue - Refactor NFSv4 error handling so synchronous and asynchronous RPC handles errors identically. - Fix a panic when blocks or object layouts reads return a bad data length - Fix nfsroot so it can handle a 1024 byte long path. - Fix bad usage of page offset in bl_read_pagelist - Various NFSv4 callback cleanups+fixes - Fix GETATTR bitmap verification - Support hexadecimal number for sunrpc debug sysctl files" * tag 'nfs-for-4.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (53 commits) Sunrpc: Supports hexadecimal number for sysctl files of sunrpc debug nfs: Fix GETATTR bitmap verification nfs: Remove unused xdr page offsets in getacl/setacl arguments fs/nfs: remove unnecessary new_valid_dev check SUNRPC: fix variable type NFS: Enable client side NFSv4.1 backchannel to use other transports pNFS/flexfiles: Add support for FF_FLAGS_NO_IO_THRU_MDS pNFS/flexfiles: When mirrored, retry failed reads by switching mirrors SUNRPC: Remove the TCP-only restriction in bc_svc_process() svcrdma: Add backward direction service for RPC/RDMA transport xprtrdma: Handle incoming backward direction RPC calls xprtrdma: Add support for sending backward direction RPC replies xprtrdma: Pre-allocate Work Requests for backchannel xprtrdma: Pre-allocate backward rpc_rqst and send/receive buffers SUNRPC: Abstract backchannel operations xprtrdma: Saving IRQs no longer needed for rb_lock xprtrdma: Remove reply tasklet xprtrdma: Use workqueue to process RPC/RDMA replies xprtrdma: Replace send and receive arrays xprtrdma: Refactor reply handler error handling ...
2015-11-09include/linux/kdev_t.h: old/new_valid_dev() can return boolYaowei Bai
Make old/new_valid_dev return bool due to these two particular functions only using either one or zero as their return value. No functional change. Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-09include/linux/kdev_t.h: remove unused huge_valid_dev()Yaowei Bai
There's no user of huge_valid_dev() any more, so remove it. No functional change. Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-09kmap_atomic_to_page() has no users, remove itNicolas Pitre
Removal started in commit 5bbeed12bdc3 ("sparc32: drop unused kmap_atomic_to_page"). Let's do it across the whole tree. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-09remove abs64()Andrew Morton
Switch everything to the new and more capable implementation of abs(). Mainly to give the new abs() a bit of a workout. Cc: Michal Nazarewicz <mina86@mina86.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-09kernel.h: make abs() work with 64-bit typesMichal Nazarewicz
For 64-bit arguments, the abs macro casts it to an int which leads to lost precision and may cause incorrect results. To deal with 64-bit types abs64 macro has been introduced but still there are places where abs macro is used incorrectly. To deal with the problem, expand abs macro such that it operates on s64 type when dealing with 64-bit types while still returning long when dealing with smaller types. This fixes one known bug (per John): The internal clocksteering done for fine-grained error correction uses a : logarithmic approximation, so any time adjtimex() adjusts the clock : steering, timekeeping_freqadjust() quickly approximates the correct clock : frequency over a series of ticks. : : Unfortunately, the logic in timekeeping_freqadjust(), introduced in commit : dc491596f639438 (Rework frequency adjustments to work better w/ nohz), : used the abs() function with a s64 error value to calculate the size of : the approximated adjustment to be made. : : Per include/linux/kernel.h: "abs() should not be used for 64-bit types : (s64, u64, long long) - use abs64()". : : Thus on 32-bit platforms, this resulted in the clocksteering to take a : quite dampended random walk trying to converge on the proper frequency, : which caused the adjustments to be made much slower then intended (most : easily observed when large adjustments are made). Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Reported-by: John Stultz <john.stultz@linaro.org> Tested-by: John Stultz <john.stultz@linaro.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-07Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - most of the rest of MM - procfs - lib/ updates - printk updates - bitops infrastructure tweaks - checkpatch updates - nilfs2 update - signals - various other misc bits: coredump, seqfile, kexec, pidns, zlib, ipc, dma-debug, dma-mapping, ... * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (102 commits) ipc,msg: drop dst nil validation in copy_msg include/linux/zutil.h: fix usage example of zlib_adler32() panic: release stale console lock to always get the logbuf printed out dma-debug: check nents in dma_sync_sg* dma-mapping: tidy up dma_parms default handling pidns: fix set/getpriority and ioprio_set/get in PRIO_USER mode kexec: use file name as the output message prefix fs, seqfile: always allow oom killer seq_file: reuse string_escape_str() fs/seq_file: use seq_* helpers in seq_hex_dump() coredump: change zap_threads() and zap_process() to use for_each_thread() coredump: ensure all coredumping tasks have SIGNAL_GROUP_COREDUMP signal: remove jffs2_garbage_collect_thread()->allow_signal(SIGCONT) signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread() signal: turn dequeue_signal_lock() into kernel_dequeue_signal() signals: kill block_all_signals() and unblock_all_signals() nilfs2: fix gcc uninitialized-variable warnings in powerpc build nilfs2: fix gcc unused-but-set-variable warnings MAINTAINERS: nilfs2: add header file for tracing nilfs2: add tracepoints for analyzing reading and writing metadata files ...
2015-11-07Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma updates from Doug Ledford: "This is my initial round of 4.4 merge window patches. There are a few other things I wish to get in for 4.4 that aren't in this pull, as this represents what has gone through merge/build/run testing and not what is the last few items for which testing is not yet complete. - "Checksum offload support in user space" enablement - Misc cxgb4 fixes, add T6 support - Misc usnic fixes - 32 bit build warning fixes - Misc ocrdma fixes - Multicast loopback prevention extension - Extend the GID cache to store and return attributes of GIDs - Misc iSER updates - iSER clustering update - Network NameSpace support for rdma CM - Work Request cleanup series - New Memory Registration API" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (76 commits) IB/core, cma: Make __attribute_const__ declarations sparse-friendly IB/core: Remove old fast registration API IB/ipath: Remove fast registration from the code IB/hfi1: Remove fast registration from the code RDMA/nes: Remove old FRWR API IB/qib: Remove old FRWR API iw_cxgb4: Remove old FRWR API RDMA/cxgb3: Remove old FRWR API RDMA/ocrdma: Remove old FRWR API IB/mlx4: Remove old FRWR API support IB/mlx5: Remove old FRWR API support IB/srp: Dont allocate a page vector when using fast_reg IB/srp: Remove srp_finish_mapping IB/srp: Convert to new registration API IB/srp: Split srp_map_sg RDS/IW: Convert to new memory registration API svcrdma: Port to new memory registration API xprtrdma: Port to new memory registration API iser-target: Port to new memory registration API IB/iser: Port to new fast registration API ...
2015-11-06include/linux/zutil.h: fix usage example of zlib_adler32()Anish Bhatt
alder32 was renamed to zlib_adler32 since before 2.6.11. Signed-off-by: Anish Bhatt <anish@chelsio.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06dma-mapping: tidy up dma_parms default handlingRobin Murphy
Many DMA controllers and other devices set max_segment_size to indicate their scatter-gather capability, but have no interest in segment_boundary_mask. However, the existence of a dma_parms structure precludes the use of any default value, leaving them as zeros (assuming a properly kzalloc'ed structure). If a well-behaved IOMMU (or SWIOTLB) then tries to respect this by ensuring a mapped segment does not cross a zero-byte boundary, hilarity ensues. Since zero is a nonsensical value for either parameter, treat it as an indicator for "default", as might be expected. In the process, clean up a bit by replacing the bare constants with slightly more meaningful macros and removing the superfluous "else" statements. [akpm@linux-foundation.org: dma-mapping.h needs sizes.h for SZ_64K] Signed-off-by: Robin Murphy <robin.murphy@arm.com> Reviewed-by: Sumit Semwal <sumit.semwal@linaro.org> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Sakari Ailus <sakari.ailus@iki.fi> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread()Oleg Nesterov
jffs2_garbage_collect_thread() can race with SIGCONT and sleep in TASK_STOPPED state after it was already sent. Add the new helper, kernel_signal_stop(), which does this correctly. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Felipe Balbi <balbi@ti.com> Cc: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06signal: turn dequeue_signal_lock() into kernel_dequeue_signal()Oleg Nesterov
1. Rename dequeue_signal_lock() to kernel_dequeue_signal(). This matches another "for kthreads only" kernel_sigaction() helper. 2. Remove the "tsk" and "mask" arguments, they are always current and current->blocked. And it is simply wrong if tsk != current. 3. We could also remove the 3rd "siginfo_t *info" arg but it looks potentially useful. However we can simplify the callers if we change kernel_dequeue_signal() to accept info => NULL. 4. Remove _irqsave, it is never called from atomic context. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Felipe Balbi <balbi@ti.com> Cc: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06signals: kill block_all_signals() and unblock_all_signals()Oleg Nesterov
It is hardly possible to enumerate all problems with block_all_signals() and unblock_all_signals(). Just for example, 1. block_all_signals(SIGSTOP/etc) simply can't help if the caller is multithreaded. Another thread can dequeue the signal and force the group stop. 2. Even is the caller is single-threaded, it will "stop" anyway. It will not sleep, but it will spin in kernel space until SIGCONT or SIGKILL. And a lot more. In short, this interface doesn't work at all, at least the last 10+ years. Daniel said: Yeah the only times I played around with the DRM_LOCK stuff was when old drivers accidentally deadlocked - my impression is that the entire DRM_LOCK thing was never really tested properly ;-) Hence I'm all for purging where this leaks out of the drm subsystem. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Dave Airlie <airlied@redhat.com> Cc: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06nilfs2: add tracepoints for analyzing reading and writing metadata filesHitoshi Mitake
This patch adds tracepoints for analyzing requests of reading and writing metadata files. The tracepoints cover every in-place mdt files (cpfile, sufile, and datfile). Example of tracing mdt_insert_new_block(): cp-14635 [000] ...1 30598.199309: nilfs2_mdt_insert_new_block: inode = ffff88022a8d0178 ino = 3 block = 155 cp-14635 [000] ...1 30598.199520: nilfs2_mdt_insert_new_block: inode = ffff88022a8d0178 ino = 3 block = 5 cp-14635 [000] ...1 30598.200828: nilfs2_mdt_insert_new_block: inode = ffff88022a8d0178 ino = 3 block = 253 Signed-off-by: Hitoshi Mitake <mitake.hitoshi@lab.ntt.co.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: TK Kato <TK.Kato@wdc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06nilfs2: add tracepoints for analyzing sufile manipulationHitoshi Mitake
This patch adds tracepoints which would be useful for analyzing segment usage from a perspective of high level sufile manipulation (check, alloc, free). sufile is an important in-place updated metadata file, so analyzing the behavior would be useful for performance turning. example of usage (a case of allocation): $ sudo bin/tpoint nilfs2:nilfs2_segment_usage_allocated Tracing nilfs2:nilfs2_segment_usage_allocated. Ctrl-C to end. segctord-17800 [002] ...1 10671.867294: nilfs2_segment_usage_allocated: sufile = ffff880054f908a8 segnum = 2 segctord-17800 [002] ...1 10675.073477: nilfs2_segment_usage_allocated: sufile = ffff880054f908a8 segnum = 3 Signed-off-by: Hitoshi Mitake <mitake.hitoshi@lab.ntt.co.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benixon Dhas <benixon.dhas@wdc.com> Cc: TK Kato <TK.Kato@wdc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06nilfs2: add a tracepoint for transaction eventsHitoshi Mitake
This patch adds a tracepoint for transaction events of nilfs. With the tracepoint, these events can be tracked: begin, abort, commit, trylock, lock, and unlock. Basically, these events have corresponding functions e.g. begin event corresponds nilfs_transaction_begin(). The unlock event is an exception. It corresponds to the iteration in nilfs_transaction_lock(). Only one tracepoint is introcued: nilfs2_transaction_transition. The above events are distinguished with newly introduced enum. With this tracepoint, we can analyse a critical section of segment constructoin. Sample output by tpoint of perf-tools: cp-4457 [000] ...1 63.266220: nilfs2_transaction_transition: sb = ffff8802112b8800 ti = ffff8800bf5ccc58 count = 1 flags = 9 state = BEGIN cp-4457 [000] ...1 63.266221: nilfs2_transaction_transition: sb = ffff8802112b8800 ti = ffff8800bf5ccc58 count = 0 flags = 9 state = COMMIT cp-4457 [000] ...1 63.266221: nilfs2_transaction_transition: sb = ffff8802112b8800 ti = ffff8800bf5ccc58 count = 0 flags = 9 state = COMMIT segctord-4371 [001] ...1 68.261196: nilfs2_transaction_transition: sb = ffff8802112b8800 ti = ffff8800b889bdf8 count = 0 flags = 10 state = TRYLOCK segctord-4371 [001] ...1 68.261280: nilfs2_transaction_transition: sb = ffff8802112b8800 ti = ffff8800b889bdf8 count = 0 flags = 10 state = LOCK segctord-4371 [001] ...1 68.261877: nilfs2_transaction_transition: sb = ffff8802112b8800 ti = ffff8800b889bdf8 count = 1 flags = 10 state = BEGIN segctord-4371 [001] ...1 68.262116: nilfs2_transaction_transition: sb = ffff8802112b8800 ti = ffff8800b889bdf8 count = 0 flags = 18 state = COMMIT segctord-4371 [001] ...1 68.265032: nilfs2_transaction_transition: sb = ffff8802112b8800 ti = ffff8800b889bdf8 count = 0 flags = 18 state = UNLOCK segctord-4371 [001] ...1 132.376847: nilfs2_transaction_transition: sb = ffff8802112b8800 ti = ffff8800b889bdf8 count = 0 flags = 10 state = TRYLOCK This patch also does trivial cleaning of comma usage in collection stage transition event for consistent coding style. Signed-off-by: Hitoshi Mitake <mitake.hitoshi@lab.ntt.co.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06nilfs2: add a tracepoint for tracking stage transition of segment constructionHitoshi Mitake
This patch adds a tracepoint for tracking stage transition of block collection in segment construction. With the tracepoint, we can analysis the behavior of segment construction in depth. It would be useful for bottleneck detection and debugging, etc. The tracepoint is created with the standard trace API of linux (like ext3, ext4, f2fs and btrfs). So we can analysis with existing tools easily. Of course, more detailed analysis will be possible if we can create nilfs specific analysis tools. Below is an example of event dump with Brendan Gregg's perf-tools (https://github.com/brendangregg/perf-tools). Time consumption between each stage can be obtained. $ sudo bin/tpoint nilfs2:nilfs2_collection_stage_transition Tracing nilfs2:nilfs2_collection_stage_transition. Ctrl-C to end. segctord-14875 [003] ...1 28311.067794: nilfs2_collection_stage_transition: sci = ffff8800ce6de000 stage = ST_INIT segctord-14875 [003] ...1 28311.068139: nilfs2_collection_stage_transition: sci = ffff8800ce6de000 stage = ST_GC segctord-14875 [003] ...1 28311.068139: nilfs2_collection_stage_transition: sci = ffff8800ce6de000 stage = ST_FILE segctord-14875 [003] ...1 28311.068486: nilfs2_collection_stage_transition: sci = ffff8800ce6de000 stage = ST_IFILE segctord-14875 [003] ...1 28311.068540: nilfs2_collection_stage_transition: sci = ffff8800ce6de000 stage = ST_CPFILE segctord-14875 [003] ...1 28311.068561: nilfs2_collection_stage_transition: sci = ffff8800ce6de000 stage = ST_SUFILE segctord-14875 [003] ...1 28311.068565: nilfs2_collection_stage_transition: sci = ffff8800ce6de000 stage = ST_DAT segctord-14875 [003] ...1 28311.068573: nilfs2_collection_stage_transition: sci = ffff8800ce6de000 stage = ST_SR segctord-14875 [003] ...1 28311.068574: nilfs2_collection_stage_transition: sci = ffff8800ce6de000 stage = ST_DONE For capturing transition correctly, this patch adds wrappers for the member scnt of nilfs_cstage. With this change, every transition of the stage can produce trace event in a correct manner. Signed-off-by: Hitoshi Mitake <mitake.hitoshi@lab.ntt.co.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06rbtree: clarify documentation of rbtree_postorder_for_each_entry_safe()Cody P Schafer
I noticed that commit a20135ffbc44 ("writeback: don't drain bdi_writeback_congested on bdi destruction") added a usage of rbtree_postorder_for_each_entry_safe() in mm/backing-dev.c which appears to try to rb_erase() elements from an rbtree while iterating over it using rbtree_postorder_for_each_entry_safe(). Doing this will cause random nodes to be missed by the iteration because rb_erase() may rebalance the tree, changing the ordering that we're trying to iterate over. The previous documentation for rbtree_postorder_for_each_entry_safe() wasn't clear that this wasn't allowed, it was taken from the docs for list_for_each_entry_safe(), where erasing isn't a problem due to list_del() not reordering. Explicitly warn developers about this potential pit-fall. Note that I haven't fixed the actual issue that (it appears) the commit referenced above introduced (not familiar enough with that code). In general (and in this case), the patterns to follow are: - switch to rb_first() + rb_erase(), don't use rbtree_postorder_for_each_entry_safe(). - keep the postorder iteration and don't rb_erase() at all. Instead just clear the fields of rb_node & cgwb_congested_tree as required by other users of those structures. [akpm@linux-foundation.org: tweak comments] Signed-off-by: Cody P Schafer <dev@codyps.com> Cc: John de la Garza <john@jjdev.com> Cc: Michel Lespinasse <walken@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06lib/kasprintf.c: introduce kvasprintf_constRasmus Villemoes
This adds kvasprintf_const which tries to use kstrdup_const if possible: If the format string contains no % characters, or if the format string is exactly "%s", we delegate to kstrdup_const. Otherwise, we fall back to kvasprintf. Just as for kstrdup_const, the main motivation is to save memory by reusing .rodata when possible. The return value should be freed by kfree_const, just like for kstrdup_const. There is deliberately no kasprintf_const: In the vast majority of cases, the format string argument is a literal, so one can determine statically whether one could instead use kstrdup_const directly (which would also require one to change all corresponding kfree calls to kfree_const). Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06bitops.h: add sign_extend64()Martin Kepplinger
Months back, this was discussed, see https://lkml.org/lkml/2015/1/18/289 The result was the 64-bit version being "likely fine", "valuable" and "correct". The discussion fell asleep but since there are possible users, let's add it. Signed-off-by: Martin Kepplinger <martin.kepplinger@theobroma-systems.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: George Spelvin <linux@horizon.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Maxime Coquelin <maxime.coquelin@st.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Yury Norov <yury.norov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06bitops.h: improve sign_extend32()'s documentationMartin Kepplinger
It is often overlooked that sign_extend32(), despite its name, is safe to use for 16 and 8 bit types as well. This should help prevent sign extension being done manually some other way. Signed-off-by: Martin Kepplinger <martin.kepplinger@theobroma-systems.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: George Spelvin <linux@horizon.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Maxime Coquelin <maxime.coquelin@st.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Yury Norov <yury.norov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06include/linux/compiler-gcc.h: improve __visible documentationAndrew Morton
Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: use 'unsigned int' for compound_dtor/compound_order on 64BITKirill A. Shutemov
On 64 bit system we have enough space in struct page to encode compound_dtor and compound_order with unsigned int. On x86-64 it leads to slightly smaller code size due usesage of plain MOV instead of MOVZX (zero-extended move) or similar effect. allyesconfig: text data bss dec hex filename 159520446 48146736 72196096 279863278 10ae5fee vmlinux.pre 159520382 48146736 72196096 279863214 10ae5fae vmlinux.post On other architectures without native support of 16-bit data types the Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: use 'unsigned int' for page orderKirill A. Shutemov
Let's try to be consistent about data type of page order. [sfr@canb.auug.org.au: fix build (type of pageblock_order)] [hughd@google.com: some configs end up with MAX_ORDER and pageblock_order having different types] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: make compound_head() robustKirill A. Shutemov
Hugh has pointed that compound_head() call can be unsafe in some context. There's one example: CPU0 CPU1 isolate_migratepages_block() page_count() compound_head() !!PageTail() == true put_page() tail->first_page = NULL head = tail->first_page alloc_pages(__GFP_COMP) prep_compound_page() tail->first_page = head __SetPageTail(p); !!PageTail() == true <head == NULL dereferencing> The race is pure theoretical. I don't it's possible to trigger it in practice. But who knows. We can fix the race by changing how encode PageTail() and compound_head() within struct page to be able to update them in one shot. The patch introduces page->compound_head into third double word block in front of compound_dtor and compound_order. Bit 0 encodes PageTail() and the rest bits are pointer to head page if bit zero is set. The patch moves page->pmd_huge_pte out of word, just in case if an architecture defines pgtable_t into something what can have the bit 0 set. hugetlb_cgroup uses page->lru.next in the second tail page to store pointer struct hugetlb_cgroup. The patch switch it to use page->private in the second tail page instead. The space is free since ->first_page is removed from the union. The patch also opens possibility to remove HUGETLB_CGROUP_MIN_ORDER limitation, since there's now space in first tail page to store struct hugetlb_cgroup pointer. But that's out of scope of the patch. That means page->compound_head shares storage space with: - page->lru.next; - page->next; - page->rcu_head.next; That's too long list to be absolutely sure, but looks like nobody uses bit 0 of the word. page->rcu_head.next guaranteed[1] to have bit 0 clean as long as we use call_rcu(), call_rcu_bh(), call_rcu_sched(), or call_srcu(). But future call_rcu_lazy() is not allowed as it makes use of the bit and we can get false positive PageTail(). [1] http://lkml.kernel.org/g/20150827163634.GD4029@linux.vnet.ibm.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: pack compound_dtor and compound_order into one word in struct pageKirill A. Shutemov
The patch halves space occupied by compound_dtor and compound_order in struct page. For compound_order, it's trivial long -> short conversion. For get_compound_page_dtor(), we now use hardcoded table for destructor lookup and store its index in the struct page instead of direct pointer to destructor. It shouldn't be a big trouble to maintain the table: we have only two destructor and NULL currently. This patch free up one word in tail pages for reuse. This is preparation for the next patch. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: drop page->slab_pageKirill A. Shutemov
Since 8456a648cf44 ("slab: use struct page for slab management") nobody uses slab_page field in struct page. Let's drop it. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Christoph Lameter <cl@linux.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: zsmalloc: constify struct zs_pool nameSergey SENOZHATSKY
Constify `struct zs_pool' ->name. [akpm@inux-foundation.org: constify zpool_create_pool()'s `type' arg also] Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Dan Streetman <ddstreet@ieee.org> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06zpool: remove redundant zpool->type string, const-ify zpool_get_typeDan Streetman
Make the return type of zpool_get_type const; the string belongs to the zpool driver and should not be modified. Remove the redundant type field in the struct zpool; it is private to zpool.c and isn't needed since ->driver->type can be used directly. Add comments indicating strings must be null-terminated. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Seth Jennings <sjennings@variantweb.net> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06module: export param_free_charp()Dan Streetman
Change the param_free_charp() function from static to exported. It is used by zswap in the next patch ("zswap: use charp for zswap param strings"). Signed-off-by: Dan Streetman <ddstreet@ieee.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Seth Jennings <sjennings@variantweb.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm, fs: introduce mapping_gfp_constraint()Michal Hocko
There are many places which use mapping_gfp_mask to restrict a more generic gfp mask which would be used for allocations which are not directly related to the page cache but they are performed in the same context. Let's introduce a helper function which makes the restriction explicit and easier to track. This patch doesn't introduce any functional changes. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Michal Hocko <mhocko@suse.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06include/linux/mmzone.h: reflow commentAndrew Morton
Someone has an 86 column display. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: page_alloc: hide some GFP internals and document the bits and flag ↵Mel Gorman
combinations Andrew stated the following We have quite a history of remote parts of the kernel using weird/wrong/inexplicable combinations of __GFP_ flags. I tend to think that this is because we didn't adequately explain the interface. And I don't think that gfp.h really improved much in this area as a result of this patchset. Could you go through it some time and decide if we've adequately documented all this stuff? This patches first moves some GFP flag combinations that are part of the MM internals to mm/internal.h. The rest of the patch documents the __GFP_FOO bits under various headings and then documents the flag combinations. It will not help callers that are brain damaged but the clarity might motivate some fixes and avoid future mistakes. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm, page_alloc: reserve pageblocks for high-order atomic allocations on demandMel Gorman
High-order watermark checking exists for two reasons -- kswapd high-order awareness and protection for high-order atomic requests. Historically the kernel depended on MIGRATE_RESERVE to preserve min_free_kbytes as high-order free pages for as long as possible. This patch introduces MIGRATE_HIGHATOMIC that reserves pageblocks for high-order atomic allocations on demand and avoids using those blocks for order-0 allocations. This is more flexible and reliable than MIGRATE_RESERVE was. A MIGRATE_HIGHORDER pageblock is created when an atomic high-order allocation request steals a pageblock but limits the total number to 1% of the zone. Callers that speculatively abuse atomic allocations for long-lived high-order allocations to access the reserve will quickly fail. Note that SLUB is currently not such an abuser as it reclaims at least once. It is possible that the pageblock stolen has few suitable high-order pages and will need to steal again in the near future but there would need to be strong justification to search all pageblocks for an ideal candidate. The pageblocks are unreserved if an allocation fails after a direct reclaim attempt. The watermark checks account for the reserved pageblocks when the allocation request is not a high-order atomic allocation. The reserved pageblocks can not be used for order-0 allocations. This may allow temporary wastage until a failed reclaim reassigns the pageblock. This is deliberate as the intent of the reservation is to satisfy a limited number of atomic high-order short-lived requests if the system requires them. The stutter benchmark was used to evaluate this but while it was running there was a systemtap script that randomly allocated between 1 high-order page and 12.5% of memory's worth of order-3 pages using GFP_ATOMIC. This is much larger than the potential reserve and it does not attempt to be realistic. It is intended to stress random high-order allocations from an unknown source, show that there is a reduction in failures without introducing an anomaly where atomic allocations are more reliable than regular allocations. The amount of memory reserved varied throughout the workload as reserves were created and reclaimed under memory pressure. The allocation failures once the workload warmed up were as follows; 4.2-rc5-vanilla 70% 4.2-rc5-atomic-reserve 56% The failure rate was also measured while building multiple kernels. The failure rate was 14% but is 6% with this patch applied. Overall, this is a small reduction but the reserves are small relative to the number of allocation requests. In early versions of the patch, the failure rate reduced by a much larger amount but that required much larger reserves and perversely made atomic allocations seem more reliable than regular allocations. [yalin.wang2010@gmail.com: fix redundant check and a memory leak] Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: yalin wang <yalin.wang2010@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm, page_alloc: remove MIGRATE_RESERVEMel Gorman
MIGRATE_RESERVE preserves an old property of the buddy allocator that existed prior to fragmentation avoidance -- min_free_kbytes worth of pages tended to remain contiguous until the only alternative was to fail the allocation. At the time it was discovered that high-order atomic allocations relied on this property so MIGRATE_RESERVE was introduced. A later patch will introduce an alternative MIGRATE_HIGHATOMIC so this patch deletes MIGRATE_RESERVE and supporting code so it'll be easier to review. Note that this patch in isolation may look like a false regression if someone was bisecting high-order atomic allocation failures. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm, page_alloc: delete the zonelist_cacheMel Gorman
The zonelist cache (zlc) was introduced to skip over zones that were recently known to be full. This avoided expensive operations such as the cpuset checks, watermark calculations and zone_reclaim. The situation today is different and the complexity of zlc is harder to justify. 1) The cpuset checks are no-ops unless a cpuset is active and in general are a lot cheaper. 2) zone_reclaim is now disabled by default and I suspect that was a large source of the cost that zlc wanted to avoid. When it is enabled, it's known to be a major source of stalling when nodes fill up and it's unwise to hit every other user with the overhead. 3) Watermark checks are expensive to calculate for high-order allocation requests. Later patches in this series will reduce the cost of the watermark checking. 4) The most important issue is that in the current implementation it is possible for a failed THP allocation to mark a zone full for order-0 allocations and cause a fallback to remote nodes. The last issue could be addressed with additional complexity but as the benefit of zlc is questionable, it is better to remove it. If stalls due to zone_reclaim are ever reported then an alternative would be to introduce deferring logic based on a timeout inside zone_reclaim itself and leave the page allocator fast paths alone. The impact on page-allocator microbenchmarks is negligible as they don't hit the paths where the zlc comes into play. Most page-reclaim related workloads showed no noticeable difference as a result of the removal. The impact was noticeable in a workload called "stutter". One part uses a lot of anonymous memory, a second measures mmap latency and a third copies a large file. In an ideal world the latency application would not notice the mmap latency. On a 2-node machine the results of this patch are stutter 4.3.0-rc1 4.3.0-rc1 baseline nozlc-v4 Min mmap 20.9243 ( 0.00%) 20.7716 ( 0.73%) 1st-qrtle mmap 22.0612 ( 0.00%) 22.0680 ( -0.03%) 2nd-qrtle mmap 22.3291 ( 0.00%) 22.3809 ( -0.23%) 3rd-qrtle mmap 25.2244 ( 0.00%) 25.2396 ( -0.06%) Max-90% mmap 48.0995 ( 0.00%) 28.3713 ( 41.02%) Max-93% mmap 52.5557 ( 0.00%) 36.0170 ( 31.47%) Max-95% mmap 55.8173 ( 0.00%) 47.3163 ( 15.23%) Max-99% mmap 67.3781 ( 0.00%) 70.1140 ( -4.06%) Max mmap 24447.6375 ( 0.00%) 12915.1356 ( 47.17%) Mean mmap 33.7883 ( 0.00%) 27.7944 ( 17.74%) Best99%Mean mmap 27.7825 ( 0.00%) 25.2767 ( 9.02%) Best95%Mean mmap 26.3912 ( 0.00%) 23.7994 ( 9.82%) Best90%Mean mmap 24.9886 ( 0.00%) 23.2251 ( 7.06%) Best50%Mean mmap 22.0157 ( 0.00%) 22.0261 ( -0.05%) Best10%Mean mmap 21.6705 ( 0.00%) 21.6083 ( 0.29%) Best5%Mean mmap 21.5581 ( 0.00%) 21.4611 ( 0.45%) Best1%Mean mmap 21.3079 ( 0.00%) 21.1631 ( 0.68%) Note that the maximum stall latency went from 24 seconds to 12 which is still bad but an improvement. The milage varies considerably 2-node machine on an earlier test went from 494 seconds to 47 seconds and a 4-node machine that tested an earlier version of this patch went from a worst case stall time of 6 seconds to 67ms. The nature of the benchmark is inherently unpredictable as it is hammering the system and the milage will vary between machines. There is a secondary impact with potentially more direct reclaim because zones are now being considered instead of being skipped by zlc. In this particular test run it did not occur so will not be described. However, in at least one test the following was observed 1. Direct reclaim rates were higher. This was likely due to direct reclaim being entered instead of the zlc disabling a zone and busy looping. Busy looping may have the effect of allowing kswapd to make more progress and in some cases may be better overall. If this is found then the correct action is to put direct reclaimers to sleep on a waitqueue and allow kswapd make forward progress. Busy looping on the zlc is even worse than when the allocator used to blindly call congestion_wait(). 2. There was higher swap activity as direct reclaim was active. 3. Direct reclaim efficiency was lower. This is related to 1 as more scanning activity also encountered more pages that could not be immediately reclaimed In that case, the direct page scan and reclaim rates are noticeable but it is not considered a problem for a few reasons 1. The test is primarily concerned with latency. The mmap attempts are also faulted which means there are THP allocation requests. The ZLC could cause zones to be disabled causing the process to busy loop instead of reclaiming. This looks like elevated direct reclaim activity but it's the correct action to take based on what processes requested. 2. The test hammers reclaim and compaction heavily. The number of successful THP faults is highly variable but affects the reclaim stats. It's not a realistic or reasonable measure of page reclaim activity. 3. No other page-reclaim intensive workload that was tested showed a problem. 4. If a workload is identified that benefitted from the busy looping then it should be fixed by having direct reclaimers sleep on a wait queue until woken by kswapd instead of busy looping. We had this class of problem before when congestion_waits() with a fixed timeout was a brain damaged decision but happened to benefit some workloads. If a workload is identified that relied on the zlc to busy loop then it should be fixed correctly and have a direct reclaimer sleep on a waitqueue until woken by kswapd. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Christoph Lameter <cl@linux.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm, page_alloc: rename __GFP_WAIT to __GFP_RECLAIMMel Gorman
__GFP_WAIT was used to signal that the caller was in atomic context and could not sleep. Now it is possible to distinguish between true atomic context and callers that are not willing to sleep. The latter should clear __GFP_DIRECT_RECLAIM so kswapd will still wake. As clearing __GFP_WAIT behaves differently, there is a risk that people will clear the wrong flags. This patch renames __GFP_WAIT to __GFP_RECLAIM to clearly indicate what it does -- setting it allows all reclaim activity, clearing them prevents it. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Lameter <cl@linux.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: page_alloc: remove GFP_IOFSMel Gorman
GFP_IOFS was intended to be shorthand for clearing two flags, not a set of allocation flags. There is only one user of this flag combination now and there appears to be no reason why Lustre had to be protected from reclaim stalls. As none of the sites appear to be atomic, this patch simply deletes GFP_IOFS and converts Lustre to using GFP_KERNEL, GFP_NOFS or GFP_NOIO as appropriate. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Cc: Oleg Drokin <oleg.drokin@intel.com> Cc: Andreas Dilger <andreas.dilger@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm, page_alloc: distinguish between being unable to sleep, unwilling to ↵Mel Gorman
sleep and avoiding waking kswapd __GFP_WAIT has been used to identify atomic context in callers that hold spinlocks or are in interrupts. They are expected to be high priority and have access one of two watermarks lower than "min" which can be referred to as the "atomic reserve". __GFP_HIGH users get access to the first lower watermark and can be called the "high priority reserve". Over time, callers had a requirement to not block when fallback options were available. Some have abused __GFP_WAIT leading to a situation where an optimisitic allocation with a fallback option can access atomic reserves. This patch uses __GFP_ATOMIC to identify callers that are truely atomic, cannot sleep and have no alternative. High priority users continue to use __GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify callers that want to wake kswapd for background reclaim. __GFP_WAIT is redefined as a caller that is willing to enter direct reclaim and wake kswapd for background reclaim. This patch then converts a number of sites o __GFP_ATOMIC is used by callers that are high priority and have memory pools for those requests. GFP_ATOMIC uses this flag. o Callers that have a limited mempool to guarantee forward progress clear __GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall into this category where kswapd will still be woken but atomic reserves are not used as there is a one-entry mempool to guarantee progress. o Callers that are checking if they are non-blocking should use the helper gfpflags_allow_blocking() where possible. This is because checking for __GFP_WAIT as was done historically now can trigger false positives. Some exceptions like dm-crypt.c exist where the code intent is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to flag manipulations. o Callers that built their own GFP flags instead of starting with GFP_KERNEL and friends now also need to specify __GFP_KSWAPD_RECLAIM. The first key hazard to watch out for is callers that removed __GFP_WAIT and was depending on access to atomic reserves for inconspicuous reasons. In some cases it may be appropriate for them to use __GFP_HIGH. The second key hazard is callers that assembled their own combination of GFP flags instead of starting with something like GFP_KERNEL. They may now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless if it's missed in most cases as other activity will wake kswapd. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm, page_alloc: use masks and shifts when converting GFP flags to migrate typesMel Gorman
This patch redefines which GFP bits are used for specifying mobility and the order of the migrate types. Once redefined it's possible to convert GFP flags to a migrate type with a simple mask and shift. The only downside is that readers of OOM kill messages and allocation failures may have been used to the existing values but scripts/gfp-translate will help. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm, page_alloc: remove unnecessary taking of a seqlock when cpusets are disabledMel Gorman
There is a seqcounter that protects against spurious allocation failures when a task is changing the allowed nodes in a cpuset. There is no need to check the seqcounter until a cpuset exists. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Christoph Lameter <cl@linux.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm, page_alloc: remove unnecessary parameter from zone_watermark_ok_safeMel Gorman
Overall, the intent of this series is to remove the zonelist cache which was introduced to avoid high overhead in the page allocator. Once this is done, it is necessary to reduce the cost of watermark checks. The series starts with minor micro-optimisations. Next it notes that GFP flags that affect watermark checks are abused. __GFP_WAIT historically identified callers that could not sleep and could access reserves. This was later abused to identify callers that simply prefer to avoid sleeping and have other options. A patch distinguishes between atomic callers, high-priority callers and those that simply wish to avoid sleep. The zonelist cache has been around for a long time but it is of dubious merit with a lot of complexity and some issues that are explained. The most important issue is that a failed THP allocation can cause a zone to be treated as "full". This potentially causes unnecessary stalls, reclaim activity or remote fallbacks. The issues could be fixed but it's not worth it. The series places a small number of other micro-optimisations on top before examining GFP flags watermarks. High-order watermarks enforcement can cause high-order allocations to fail even though pages are free. The watermark checks both protect high-order atomic allocations and make kswapd aware of high-order pages but there is a much better way that can be handled using migrate types. This series uses page grouping by mobility to reserve pageblocks for high-order allocations with the size of the reservation depending on demand. kswapd awareness is maintained by examining the free lists. By patch 12 in this series, there are no high-order watermark checks while preserving the properties that motivated the introduction of the watermark checks. This patch (of 10): No user of zone_watermark_ok_safe() specifies alloc_flags. This patch removes the unnecessary parameter. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Christoph Lameter <cl@linux.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06Merge branch 'for-linus-4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs updates from Chris Mason: "We have a lot of subvolume quota improvements in here, along with big piles of cleanups from Dave Sterba and Anand Jain and others. Josef pitched in a batch of allocator fixes based on production use here at FB. We found that mount -o ssd_spread greatly improved our performance on hardware raid5/6, but it exposed some CPU bottlenecks in the allocator. These patches make a huge difference" * 'for-linus-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (100 commits) Btrfs: fix hole punching when using the no-holes feature Btrfs: find_free_extent: Do not erroneously skip LOOP_CACHING_WAIT state btrfs: Fix a data space underflow warning btrfs: qgroup: Fix a rebase bug which will cause qgroup double free btrfs: qgroup: Fix a race in delayed_ref which leads to abort trans btrfs: clear PF_NOFREEZE in cleaner_kthread() btrfs: qgroup: Don't copy extent buffer to do qgroup rescan btrfs: add balance filters limits, stripes and usage to supported mask btrfs: extend balance filter usage to take minimum and maximum btrfs: add balance filter for stripes btrfs: extend balance filter limit to take minimum and maximum btrfs: fix use after free iterating extrefs btrfs: check unsupported filters in balance arguments Btrfs: fix regression running delayed references when using qgroups Btrfs: fix regression when running delayed references Btrfs: don't do extra bitmap search in one bit case Btrfs: keep track of largest extent in bitmaps Btrfs: don't keep trying to build clusters if we are fragmented Btrfs: cut down on loops through the allocator Btrfs: don't continue setting up space cache when enospc ...
2015-11-06Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "Add support for the CSUM_SEED feature which will allow future userspace utilities to change the file system's UUID without rewriting all of the file system metadata. A number of miscellaneous fixes, the most significant of which are in the ext4 encryption support. Anyone wishing to use the encryption feature should backport all of the ext4 crypto patches up to 4.4 to get fixes to a memory leak and file system corruption bug. There are also cleanups in ext4's feature test macros and in ext4's sysfs support code" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (26 commits) fs/ext4: remove unnecessary new_valid_dev check ext4: fix abs() usage in ext4_mb_check_group_pa ext4: do not allow journal_opts for fs w/o journal ext4: explicit mount options parsing cleanup ext4, jbd2: ensure entering into panic after recording an error in superblock [PATCH] fix calculation of meta_bg descriptor backups ext4: fix potential use after free in __ext4_journal_stop jbd2: fix checkpoint list cleanup ext4: fix xfstest generic/269 double revoked buffer bug with bigalloc ext4: make the bitmap read routines return real error codes jbd2: clean up feature test macros with predicate functions ext4: clean up feature test macros with predicate functions ext4: call out CRC and corruption errors with specific error codes ext4: store checksum seed in superblock ext4: reserve code points for the project quota feature ext4: promote ext4 over ext2 in the default probe order jbd2: gate checksum calculations on crc driver presence, not sb flags ext4: use private version of page_zero_new_buffers() for data=journal mode ext4 crypto: fix bugs in ext4_encrypted_zeroout() ext4 crypto: replace some BUG_ON()'s with error checks ...
2015-11-06Merge tag 'asm-generic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic cleanups from Arnd Bergmann: "The asm-generic changes for 4.4 are mostly a series from Christoph Hellwig to clean up various abuses of headers in there. The patch to rename the io-64-nonatomic-*.h headers caused some conflicts with new users, so I added a workaround that we can remove in the next merge window. The only other patch is a warning fix from Marek Vasut" * tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: asm-generic: temporarily add back asm-generic/io-64-nonatomic*.h asm-generic: cmpxchg: avoid warnings from macro-ized cmpxchg() implementations gpio-mxc: stop including <asm-generic/bug> n_tracesink: stop including <asm-generic/bug> n_tracerouter: stop including <asm-generic/bug> mlx5: stop including <asm-generic/kmap_types.h> hifn_795x: stop including <asm-generic/kmap_types.h> drbd: stop including <asm-generic/kmap_types.h> move count_zeroes.h out of asm-generic move io-64-nonatomic*.h out of asm-generic
2015-11-06Merge tag 'trace-v4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracking updates from Steven Rostedt: "Most of the changes are clean ups and small fixes. Some of them have stable tags to them. I searched through my INBOX just as the merge window opened and found lots of patches to pull. I ran them through all my tests and they were in linux-next for a few days. Features added this release: ---------------------------- - Module globbing. You can now filter function tracing to several modules. # echo '*:mod:*snd*' > set_ftrace_filter (Dmitry Safonov) - Tracer specific options are now visible even when the tracer is not active. It was rather annoying that you can only see and modify tracer options after enabling the tracer. Now they are in the options/ directory even when the tracer is not active. Although they are still only visible when the tracer is active in the trace_options file. - Trace options are now per instance (although some of the tracer specific options are global) - New tracefs file: set_event_pid. If any pid is added to this file, then all events in the instance will filter out events that are not part of this pid. sched_switch and sched_wakeup events handle next and the wakee pids" * tag 'trace-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (68 commits) tracefs: Fix refcount imbalance in start_creating() tracing: Put back comma for empty fields in boot string parsing tracing: Apply tracer specific options from kernel command line. tracing: Add some documentation about set_event_pid ring_buffer: Remove unneeded smp_wmb() before wakeup of reader benchmark tracing: Allow dumping traces without tracking trace started cpus ring_buffer: Fix more races when terminating the producer in the benchmark ring_buffer: Do no not complete benchmark reader too early tracing: Remove redundant TP_ARGS redefining tracing: Rename max_stack_lock to stack_trace_max_lock tracing: Allow arch-specific stack tracer recordmcount: arm64: Replace the ignored mcount call into nop recordmcount: Fix endianness handling bug for nop_mcount tracepoints: Fix documentation of RCU lockdep checks tracing: ftrace_event_is_function() can return boolean tracing: is_legal_op() can return boolean ring-buffer: rb_event_is_commit() can return boolean ring-buffer: rb_per_cpu_empty() can return boolean ring_buffer: ring_buffer_empty{cpu}() can return boolean ring-buffer: rb_is_reader_page() can return boolean ...
2015-11-06Merge tag 'devicetree-for-4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree updates from Rob Herring: "A fairly large (by DT standards) pull request this time with the majority being some overdue moving DT binding docs around to consolidate similar bindings. - DT binding doc consolidation moving similar bindings to common locations. The majority of these are display related which were scattered in video/, fb/, drm/, gpu/, and panel/ directories. - Add new config option, CONFIG_OF_ALL_DTBS, to enable building all dtbs in the tree for most arches with dts files (except powerpc for now). - OF_IRQ=n fixes for user enabled CONFIG_OF. - of_node_put ref counting fixes from Julia Lawall. - Common DT binding for wakeup-source and deprecation of all similar bindings. - DT binding for PXA LCD controller. - Allow ignoring failed PCI resource translations in order to ignore 64-bit addresses on non-LPAE 32-bit kernels. - Support setting the NUMA node from DT instead of only from parent device. - Couple of earlycon DT parsing fixes for address and options" * tag 'devicetree-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (45 commits) MAINTAINERS: update DT binding doc locations devicetree: add Sigma Designs vendor prefix of: simplify arch_find_n_match_cpu_physical_id() function Documentation: arm: Fixed typo in socfpga fpga mgr example Documentation: devicetree: fix reference to legacy wakeup properties Documentation: devicetree: standardize/consolidate on "wakeup-source" property drivers: of: removing assignment of 0 to static variable xtensa: enable building of all dtbs mips: enable building of all dtbs metag: enable building of all dtbs metag: use common make variables for dtb builds h8300: enable building of all dtbs arm64: enable building of all dtbs arm: enable building of all dtbs arc: enable building of all dtbs arc: use common make variables for dtb builds of: add config option to enable building of all dtbs of/fdt: fix error checking for earlycon address of/overlay: add missing of_node_put of/platform: add missing of_node_put ...
2015-11-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "Items of note: - evdev users can now limit or mask the kind of events they will receive. This will allow applications such as power manager or network manager to only be woken when user presses special keys such as KEY_POWER or KEY_WIFI and not be bothered with ordinary key presses coming from keyboard - support for FocalTech FT6236 touchscreen controller - support for ROHM BU21023/24 touchscreen controller - edt-ft5x06 touchscreen driver got a face lift and can now be used with FT5506 - support for Google Fiber TV Box remote controls - improvements in xpad driver (with more to come) - several parport-based drivers have been switched to the new device model - other miscellaneous driver improvements" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (70 commits) HID: hid-gfrm: avoid warning for input_configured API change HID: hid-input: allow input_configured callback return errors Input: evdev - fix bug in checking duplicate clock change request Input: add userio module Input: evdev - add event-mask API Input: snvs_pwrkey - remove duplicated semicolon HID: hid-gfrm: Google Fiber TV Box remote controls Input: e3x0-button - update Kconfig description Input: tegra-kbc - drop use of IRQF_NO_SUSPEND flag Input: tegra-kbc - enable support for the standard "wakeup-source" property Input: xen - check return value of xenbus_printf Input: hp_sdc_rtc - fix y2038 problem in proc_show Input: nomadik-ske-keypad - fix a trivial typo Input: xpad - fix clash of presence handling with LED setting Input: edt-ft5x06 - work around FT5506 firmware bug Input: edt-ft5x06 - add support for FT5506 Input: edt-ft5x06 - add support for different max support points Input: edt-ft5x06 - use max support points to determine how much to read Input: rotary-encoder - add support for quarter-period mode Input: rotary-encoder - use of_property_read_bool ...
