The torture tests are designed to run in isolation, but do not enforce
this isolation. This commit therefore checks for concurrent torture
tests, and refuses to start new tests while old tests are running.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Given a CPU running a loop containing cond_resched(), with no
other tasks runnable on that CPU, RCU will eventually report RCU
CPU stall warnings due to lack of quiescent states. Fortunately,
every call to cond_resched() is a perfectly good quiescent state.
Unfortunately, invoking rcu_note_context_switch() is a bit heavyweight
for cond_resched(), especially given the need to disable preemption,
and, for RCU-preempt, interrupts as well.
This commit therefore maintains a per-CPU counter that causes
cond_resched(), cond_resched_lock(), and cond_resched_softirq() to call
rcu_note_context_switch(), but only about once per 256 invocations.
This ratio was chosen in keeping with the relative time constants of
RCU grace periods.
The definition for raw_cpu_add_return() uses the operation prefix
"raw_add_return_", but the definitions in the various percpu.h files
expect "raw_cpu_add_return_". This commit therefore appropriately
adjusts the definition of raw_cpu_add_return().
Acked-by: Christoph Lameter <cl@linux.com>
This commit allows rcutorture to print additional state for the
RCU grace-period kthreads in cases where RCU seems reluctant to
start a new grace period.
The rcutorture output currently does not distinguish between stalls in
the RCU implementation and stalls in the rcu_torture_writer() kthreads.
This commit therefore adds some diagnostics to help distinguish between
these two conditions, at least for the non-SRCU implementations. (SRCU
does not provide evidence of update-side forward progress by design.)
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
Pull slab changes from Pekka Enberg:
"The biggest change is byte-sized freelist indices which reduces slab
freelist memory usage:
https://lkml.org/lkml/2013/12/2/64"
* 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux:
mm: slab/slub: use page->list consistently instead of page->lru
mm/slab.c: cleanup outdated comments and unify variables naming
slab: fix wrongly used macro
slub: fix high order page allocation problem with __GFP_NOFAIL
slab: Make allocations with GFP_ZERO slightly more efficient
slab: make more slab management structure off the slab
slab: introduce byte sized index for the freelist of a slab
slab: restrict the number of objects in a slab
slab: introduce helper functions to get/set free object
slab: factor out calculate nr objects in cache_estimate
Pull yet more networking updates from David Miller:
1) Various fixes to the new Redpine Signals wireless driver, from
Fariya Fatima.
2) L2TP PPP connect code takes PMTU from the wrong socket, fix from
Dmitry Petukhov.
3) UFO and TSO packets differ in whether they include the protocol
header in gso_size, account for that in skb_gso_transport_seglen().
From Florian Westphal.
4) If VLAN untagging fails, we double free the SKB in the bridging
output path. From Toshiaki Makita.
5) Several call sites of sk->sk_data_ready() were referencing an SKB
just added to the socket receive queue in order to calculate the
second argument via skb->len. This is dangerous because the moment
the skb is added to the receive queue it can be consumed in another
context and freed up.
It turns out also that none of the sk->sk_data_ready()
implementations even care about this second argument.
So just kill it off and thus fix all these use-after-free bugs as a
side effect.
6) Fix inverted test in tcp_v6_send_response(), from Lorenzo Colitti.
7) pktgen needs to do locking properly for LLTX devices, from Daniel
Borkmann.
8) xen-netfront driver initializes TX array entries in RX loop :-) From
Vincenzo Maffione.
9) After refactoring, some tunnel drivers allow a tunnel to be
configured on top itself. Fix from Nicolas Dichtel.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (46 commits)
vti: don't allow to add the same tunnel twice
gre: don't allow to add the same tunnel twice
drivers: net: xen-netfront: fix array initialization bug
pktgen: be friendly to LLTX devices
r8152: check RTL8152_UNPLUG
net: sun4i-emac: add promiscuous support
net/apne: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
net: ipv6: Fix oif in TCP SYN+ACK route lookup.
drivers: net: cpsw: enable interrupts after napi enable and clearing previous interrupts
drivers: net: cpsw: discard all packets received when interface is down
net: Fix use after free by removing length arg from sk_data_ready callbacks.
Drivers: net: hyperv: Address UDP checksum issues
Drivers: net: hyperv: Negotiate suitable ndis version for offload support
Drivers: net: hyperv: Allocate memory for all possible per-pecket information
bridge: Fix double free and memory leak around br_allowed_ingress
bonding: Remove debug_fs files when module init fails
i40evf: program RSS LUT correctly
i40evf: remove open-coded skb_cow_head
ixgb: remove open-coded skb_cow_head
igbvf: remove open-coded skb_cow_head
git://git.linuxfoundation.org/llvmlinux/kernel
Pull llvm patches from Behan Webster:
"These are some initial updates to support compiling the kernel with
clang.
These patches have been through the proper reviews to the best of my
ability, and have been soaking in linux-next for a few weeks. These
patches by themselves still do not completely allow clang to be used
with the kernel code, but lay the foundation for other patches which
are still under review.
Several other of the LLVMLinux patches have been already added via
maintainer trees"
* tag 'llvmlinux-for-v3.15' of git://git.linuxfoundation.org/llvmlinux/kernel:
x86: LLVMLinux: Fix "incomplete type const struct x86cpu_device_id"
x86 kbuild: LLVMLinux: More cc-options added for clang
x86, acpi: LLVMLinux: Remove nested functions from Thinkpad ACPI
LLVMLinux: Add support for clang to compiler.h and new compiler-clang.h
LLVMLinux: Remove warning about returning an uninitialized variable
kbuild: LLVMLinux: Fix LINUX_COMPILER definition script for compilation with clang
Documentation: LLVMLinux: Update Documentation/dontdiff
kbuild: LLVMLinux: Adapt warnings for compilation with clang
kbuild: LLVMLinux: Add Kbuild support for building kernel with Clang
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Here are the target pending updates for v3.15-rc1. Apologies in
advance for waiting until the second to last day of the merge window
to send these out.
The highlights this round include:
- iser-target support for T10 PI (DIF) offloads (Sagi + Or)
- Fix Task Aborted Status (TAS) handling in target-core (Alex Leung)
- Pass in transport supported PI at session initialization (Sagi + MKP + nab)
- Add WRITE_INSERT + READ_STRIP T10 PI support in target-core (nab + Sagi)
- Fix iscsi-target ERL=2 ASYNC_EVENT connection pointer bug (nab)
- Fix tcm_fc use-after-free of ft_tpg (Andy Grover)
- Use correct ib_sg_dma primitives in ib_isert (Mike Marciniszyn)
Also, note the virtio-scsi + vhost-scsi changes to expose T10 PI
metadata into KVM guest have been left-out for now, as there where a
few comments from MST + Paolo that where not able to be addressed in
time for v3.15. Please expect this feature for v3.16-rc1"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (43 commits)
ib_srpt: Use correct ib_sg_dma primitives
target/tcm_fc: Rename ft_tport_create to ft_tport_get
target/tcm_fc: Rename ft_{add,del}_lport to {add,del}_wwn
target/tcm_fc: Rename structs and list members for clarity
target/tcm_fc: Limit to 1 TPG per wwn
target/tcm_fc: Don't export ft_lport_list
target/tcm_fc: Fix use-after-free of ft_tpg
target: Add check to prevent Abort Task from aborting itself
target: Enable READ_STRIP emulation in target_complete_ok_work
target/sbc: Add sbc_dif_read_strip software emulation
target: Enable WRITE_INSERT emulation in target_execute_cmd
target/sbc: Add sbc_dif_generate software emulation
target/sbc: Only expose PI read_cap16 bits when supported by fabric
target/spc: Only expose PI mode page bits when supported by fabric
target/spc: Only expose PI inquiry bits when supported by fabric
target: Pass in transport supported PI at session initialization
target/iblock: Fix double bioset_integrity_free bug
Target/sbc: Initialize COMPARE_AND_WRITE write_sg scatterlist
target/rd: T10-Dif: RAM disk is allocating more space than required.
iscsi-target: Fix ERL=2 ASYNC_EVENT connection pointer bug
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"A series of bug fix patches for v3.15-rc1. Most are just driver
fixes. There are some changes at remote controller core level, fixing
some definitions on a new API added for Kernel v3.15.
It also adds the missing include at include/uapi/linux/v4l2-common.h,
to allow its compilation on userspace, as pointed by you"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (24 commits)
[media] gpsca: remove the risk of a division by zero
[media] stk1160: warrant a NUL terminated string
[media] v4l: ti-vpe: retain v4l2_buffer flags for captured buffers
[media] v4l: ti-vpe: Set correct field parameter for output and capture buffers
[media] v4l: ti-vpe: zero out reserved fields in try_fmt
[media] v4l: ti-vpe: Fix initial configuration queue data
[media] v4l: ti-vpe: Use correct bus_info name for the device in querycap
[media] v4l: ti-vpe: report correct capabilities in querycap
[media] v4l: ti-vpe: Allow usage of smaller images
[media] v4l: ti-vpe: Use video_device_release_empty
[media] v4l: ti-vpe: Make sure in job_ready that we have the needed number of dst_bufs
[media] lgdt3305: include sleep functionality in lgdt3304_ops
[media] drx-j: use customise option correctly
[media] m88rs2000: fix sparse static warnings
[media] r820t: fix size and init values
[media] rc-core: remove generic scancode filter
[media] rc-core: split dev->s_filter
[media] rc-core: do not change 32bit NEC scancode format for now
[media] rtl28xxu: remove duplicate ID 0458:707f Genius TVGo DVB-T03
[media] xc2028: add missing break to switch
Pull PCIe non-transparent bridge fixes and features from Jon Mason:
"NTB driver bug fixes to address issues in list traversal, skb leak in
ntb_netdev, a typo, and a leak of msix entries in the error path.
Clean ups of the event handling logic, as well as a overall style
cleanup. Finally, the driver was converted to use the new
pci_enable_msix_range logic (and the refactoring to go along with it)"
* tag 'ntb-3.15' of git://github.com/jonmason/ntb:
ntb: Use pci_enable_msix_range() instead of pci_enable_msix()
ntb: Split ntb_setup_msix() into separate BWD/SNB routines
ntb: Use pci_msix_vec_count() to obtain number of MSI-Xs
NTB: Code Style Clean-up
NTB: client event cleanup
ntb: Fix leakage of ntb_device::msix_entries[] array
NTB: Fix typo in setting one translation register
ntb_netdev: Fix skb free issue in open
ntb_netdev: Fix list_for_each_entry exit issue
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull more tracing updates from Steven Rostedt:
"This includes the final patch to clean up and fix the issue with the
design of tracepoints and how a user could register a tracepoint and
have that tracepoint not be activated but no error was shown.
The design was for an out of tree module but broke in tree users. The
clean up was to remove the saving of the hash table of tracepoint
names such that they can be enabled before they exist (enabling a
module tracepoint before that module is loaded). This added more
complexity than needed. The clean up was to remove that code and just
enable tracepoints that exist or fail if they do not.
This removed a lot of code as well as the complexity that it brought.
As a side effect, instead of registering a tracepoint by its name, the
tracepoint needs to be registered with the tracepoint descriptor.
This removes having to duplicate the tracepoint names that are
enabled.
The second patch was added that simplified the way modules were
searched for.
This cleanup required changes that were in the 3.15 queue as well as
some changes that were added late in the 3.14-rc cycle. This final
change waited till the two were merged in upstream and then the change
was added and full tests were run. Unfortunately, the test found some
errors, but after it was already submitted to the for-next branch and
not to be rebased. Sparse errors were detected by Fengguang Wu's bot
tests, and my internal tests discovered that the anonymous union
initialization triggered a bug in older gcc compilers. Luckily, there
was a bugzilla for the gcc bug which gave a work around to the
problem. The third and fourth patch handled the sparse error and the
gcc bug respectively.
A final patch was tagged along to fix a missing documentation for the
README file"
* tag 'trace-3.15-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Add missing function triggers dump and cpudump to README
tracing: Fix anonymous unions in struct ftrace_event_call
tracepoint: Fix sparse warnings in tracepoint.c
tracepoint: Simplify tracepoint module search
tracepoint: Use struct pointer instead of name hash for reg/unreg tracepoints
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
Pull NVMe driver updates from Matthew Wilcox:
"Various updates to the NVMe driver. The most user-visible change is
that drive hotplugging now works and CPU hotplug while an NVMe drive
is installed should also work better"
* git://git.infradead.org/users/willy/linux-nvme:
NVMe: Retry failed commands with non-fatal errors
NVMe: Add getgeo to block ops
NVMe: Start-stop nvme_thread during device add-remove.
NVMe: Make I/O timeout a module parameter
NVMe: CPU hot plug notification
NVMe: per-cpu io queues
NVMe: Replace DEFINE_PCI_DEVICE_TABLE
NVMe: Fix divide-by-zero in nvme_trans_io_get_num_cmds
NVMe: IOCTL path RCU protect queue access
NVMe: RCU protected access to io queues
NVMe: Initialize device reference count earlier
NVMe: Add CONFIG_PM_SLEEP to suspend/resume functions
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
Pull 9p changes from Eric Van Hensbergen:
"A bunch of updates and cleanup within the transport layer,
particularly with a focus on RDMA"
* tag 'for-linus-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9pnet_rdma: check token type before int conversion
9pnet: trans_fd : allocate struct p9_trans_fd and struct p9_conn together.
9pnet: p9_client->conn field is unused. Remove it.
9P: Get rid of REQ_STATUS_FLSH
9pnet_rdma: add cancelled()
9pnet_rdma: update request status during send
9P: Add cancelled() to the transport functions.
net: Mark function as static in 9p/client.c
9P: Add memory barriers to protect request fields over cb/rpc threads handoff
Pull more ACPI and power management fixes and updates from Rafael Wysocki:
"This is PM and ACPI material that has emerged over the last two weeks
and one fix for a CPU hotplug regression introduced by the recent CPU
hotplug notifiers registration series.
Included are intel_idle and turbostat updates from Len Brown (these
have been in linux-next for quite some time), a new cpufreq driver for
powernv (that might spend some more time in linux-next, but BenH was
asking me so nicely to push it for 3.15 that I couldn't resist), some
cpufreq fixes and cleanups (including fixes for some silly breakage in
a couple of cpufreq drivers introduced during the 3.14 cycle),
assorted ACPI cleanups, wakeup framework documentation fixes, a new
sysfs attribute for cpuidle and a new command line argument for power
domains diagnostics.
Specifics:
- Fix for a recently introduced CPU hotplug regression in ARM KVM
from Ming Lei.
- Fixes for breakage in the at32ap, loongson2_cpufreq, and unicore32
cpufreq drivers introduced during the 3.14 cycle (-stable material)
from Chen Gang and Viresh Kumar.
- New powernv cpufreq driver from Vaidyanathan Srinivasan, with bits
from Gautham R Shenoy and Srivatsa S Bhat.
- Exynos cpufreq driver fix preventing it from being included into
multiplatform builds that aren't supported by it from Sachin Kamat.
- cpufreq cleanups related to the usage of the driver_data field in
struct cpufreq_frequency_table from Viresh Kumar.
- cpufreq ppc driver cleanup from Sachin Kamat.
- Intel BayTrail support for intel_idle and ACPI idle from Len Brown.
- Intel CPU model 54 (Atom N2000 series) support for intel_idle from
Jan Kiszka.
- intel_idle fix for Intel Ivy Town residency targets from Len Brown.
- turbostat updates (Intel Broadwell support and output cleanups)
from Len Brown.
- New cpuidle sysfs attribute for exporting C-states' target
residency information to user space from Daniel Lezcano.
- New kernel command line argument to prevent power domains enabled
by the bootloader from being turned off even if they are not in use
(for diagnostics purposes) from Tushar Behera.
- Fixes for wakeup sysfs attributes documentation from Geert
Uytterhoeven.
- New ACPI video blacklist entry for ThinkPad Helix from Stephen
Chandler Paul.
- Assorted ACPI cleanups and a Kconfig help update from Jonghwan
Choi, Zhihui Zhang, Hanjun Guo"
* tag 'pm+acpi-3.15-rc1-3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (28 commits)
ACPI: Update the ACPI spec information in Kconfig
arm, kvm: fix double lock on cpu_add_remove_lock
cpuidle: sysfs: Export target residency information
cpufreq: ppc: Remove duplicate inclusion of fsl_soc.h
cpufreq: create another field .flags in cpufreq_frequency_table
cpufreq: use kzalloc() to allocate memory for cpufreq_frequency_table
cpufreq: don't print value of .driver_data from core
cpufreq: ia64: don't set .driver_data to index
cpufreq: powernv: Select CPUFreq related Kconfig options for powernv
cpufreq: powernv: Use cpufreq_frequency_table.driver_data to store pstate ids
cpufreq: powernv: cpufreq driver for powernv platform
cpufreq: at32ap: don't declare local variable as static
cpufreq: loongson2_cpufreq: don't declare local variable as static
cpufreq: unicore32: fix typo issue for 'clk'
cpufreq: exynos: Disable on multiplatform build
PM / wakeup: Correct presence vs. emptiness of wakeup_* attributes
PM / domains: Add pd_ignore_unused to keep power domains enabled
ACPI / dock: Drop dock_device_ids[] table
ACPI / video: Favor native backlight interface for ThinkPad Helix
ACPI / thermal: Fix wrong variable usage in debug statement
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
Pullx86 core platform updates from Peter Anvin:
"This is the x86/platform branch with the objectionable IOSF patches
removed.
What is left is proper memory handling for Intel GPUs, and a change to
the Calgary IOMMU code which will be required to make kexec work
sanely on those platforms after some upcoming kexec changes"
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, calgary: Use 8M TCE table size by default
x86/gpu: Print the Intel graphics stolen memory range
x86/gpu: Add Intel graphics stolen memory quirk for gen2 platforms
x86/gpu: Add vfunc for Intel graphics stolen memory base address
'struct page' has two list_head fields: 'lru' and 'list'. Conveniently,
they are unioned together. This means that code can use them
interchangably, which gets horribly confusing like with this nugget from
slab.c:
> list_del(&page->lru);
> if (page->active == cachep->num)
> list_add(&page->list, &n->slabs_full);
This patch makes the slab and slub code use page->lru universally instead
of mixing ->list and ->lru.
So, the new rule is: page->lru is what the you use if you want to keep
your page on a list. Don't like the fact that it's not called ->list?
Too bad.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Pekka Enberg <penberg@kernel.org>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
On systems with CONFIG_COMPAT we introduced the new requirement that
audit_classify_compat_syscall() exists. This wasn't true for everything
(apparently not for "tilegx", which I know less that nothing about.)
Instead of wrapping the preprocessor optomization with CONFIG_COMPAT we
should have used the new CONFIG_AUDIT_COMPAT_GENERIC. This patch uses
that config option to make sure only arches which intend to implement
this have the requirement.
This works fine for tilegx according to Chris Metcalf
Signed-off-by: Eric Paris <eparis@redhat.com>
For commands returned with failed status, queue these for resubmission
and continue retrying them until success or for a limited amount of
time. The final timeout was arbitrarily chosen so requests can't be
retried indefinitely.
Since these are requeued on the nvmeq that submitted the command, the
callbacks have to take an nvmeq instead of an nvme_dev as a parameter
so that we can use the locked queue to append the iod to retry later.
The nvme_iod conviently can be used to track how long we've been trying
to successfully complete an iod request. The nvme_iod also provides the
nvme prp dma mappings, so I had to move a few things around so we can
keep those mappings.
Signed-off-by: Keith Busch <keith.busch@intel.com>
[fixed checkpatch issue with long line]
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Increase the default timeout to 30 seconds to match SCSI.
[use byte instead of ushort]
Registers with hot cpu notification to rebalance, and potentially allocate
additional, io queues.
The device's IO queues are associated with CPUs, so we can use a per-cpu
variable to map the a qid to a cpu. This provides a convienient way
to optimally assign queues to multiple cpus when the device supports
fewer queues than the host has cpus. The previous implementation may
have assigned these poorly in these situations. This patch addresses
this by sharing queues among cpus that are "close" together and should
have a lower lock contention penalty.
Pull block layer fixes from Jens Axboe:
"A small collection of fixes that should go in before -rc1. The pull
request contains:
- A two patch fix for a regression with block enabled tagging caused
by a commit in the initial pull request. One patch is from Martin
and ensures that SCSI doesn't truncate 64-bit block flags, the
other one is from me and prevents us from double using struct
request queuelist for both completion and busy tags. This caused
anything from a boot crash for some, to crashes under load.
- A blk-mq fix for a potential soft stall when hot unplugging CPUs
with busy IO.
- percpu_counter fix is listed in here, that caused a suspend issue
with virtio-blk due to percpu counters having an inconsistent state
during CPU removal. Andrew sent this in separately a few days ago,
but it's here. JFYI.
- A few fixes for block integrity from Martin.
- A ratelimit fix for loop from Mike Galbraith, to avoid spewing too
much in error cases"
* 'for-linus' of git://git.kernel.dk/linux-block:
block: fix regression with block enabled tagging
scsi: Make sure cmd_flags are 64-bit
block: Ensure we only enable integrity metadata for reads and writes
block: Fix integrity verification
block: Fix for_each_bvec()
drivers/block/loop.c: ratelimit error messages
blk-mq: fix potential stall during CPU unplug with IO pending
percpu_counter: fix bad counter state during suspend
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Here is a bunch of small fixes that have been collected since the
previous pull request. In addition to various misc fixes, the
following are included:
- HD-audio quirks for Dell, HP, Chromebook, and ALC28x codecs
- HD-audio AMD HDMI regression fix
- Continued PM support/fixes for ice1712 driver
- Multiplatform fixes for ASoC samsung drivers
- Addition of device id tables to a few ASoC drivers
- Bit clock polarity config and error flag fixes in ASoC fsl_sai"
* tag 'sound-fix-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (32 commits)
ALSA: usb-audio: Suppress repetitive debug messages from retire_playback_urb()
ALSA: hda - Make full_reset boolean
ALSA: hda - add headset mic detect quirk for a Dell laptop
sound: dmasound: use module_platform_driver_probe()
ALSA: au1x00: use module_platform_driver()
ALSA: hda - Use runtime helper to check active state.
ALSA: ice1712: Fix boundary checks in PCM pointer ops
ASoC: davinci-mcasp: Fix bit clock polarity settings
ASoC: samsung: Fix build on multiplatform
ASoC: fsl_sai: Fix Bit Clock Polarity configurations
ALSA: hda - Do not assign streams in reverse order
ALSA: hda/realtek - Add eapd shutup to ALC283
ALSA: hda/realtek - Change model name alias for ChromeOS
ASoC: da732x: Print correct major id
ALSA: hda/realtek - Improve HP depop when system change power state on Chromebook
ASoC: cs42l52: Fix mask for REVID
sound/oss: Remove uncompilable DBG macro use
ALSA: ice1712: Save/restore routing and rate registers
ALSA: ice1712: restore AK4xxx volumes on resume
ASoC: alc56(23|32): fix undefined return value of probing code
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds
Pull LED updates from Bryan Wu:
"This cycle we got:
- new driver for leds-mc13783
- bug fixes
- code cleanup"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds:
leds: make sure we unregister a trigger only once
leds: leds-pwm: properly clean up after probe failure
leds: clevo-mail: Make probe function __init
leds-ot200: Fix dependencies
leds-gpio: of: introduce MODULE_DEVICE_TABLE for module autoloading
leds: clevo-mail: remove __initdata marker
leds: leds-ss4200: remove __initdata marker
leds: blinkm: remove unnecessary spaces
leds: lp5562: remove unnecessary parentheses
leds: leds-ss4200: remove DEFINE_PCI_DEVICE_TABLE macro
leds: leds-s3c24xx: Trivial cleanup in header file
drivers/leds: delete non-required instances of include <linux/init.h>
leds: leds-gpio: add retain-state-suspended property
leds: leds-mc13783: Add devicetree support
leds: leds-mc13783: Remove unnecessary cleaning of registers on exit
leds: leds-mc13783: Use proper "max_brightness" value fo LEDs
leds: leds-mc13783: Use LED core PM functions
leds: leds-mc13783: Add MC34708 LED support
leds: Turn off led if blinking is disabled
ledtrig-cpu: Handle CPU hot(un)plugging
Pull slave-dmaengine updates from Vinod Koul:
- New driver for Qcom bam dma
- New driver for RCAR peri-peri
- New driver for FSL eDMA
- Various odd fixes and updates thru the subsystem
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (29 commits)
dmaengine: add Qualcomm BAM dma driver
shdma: add R-Car Audio DMAC peri peri driver
dmaengine: sirf: enable generic dt binding for dma channels
dma: omap-dma: Implement device_slave_caps callback
dmaengine: qcom_bam_dma: Add device tree binding
dma: dw: Add suspend and resume handling for PCI mode DW_DMAC.
dma: dw: allocate memory in two stages in probe
Add new line to test result strings produced in verbose mode
dmaengine: pch_dma: use tasklet_kill in teardown
dmaengine: at_hdmac: use tasklet_kill in teardown
dma: cppi41: start tear down only if channel is busy
usb: musb: musb_cppi41: Dont reprogram DMA if tear down is initiated
dmaengine: s3c24xx-dma: make phy->irq signed for error handling
dma: imx-dma: Add missing module owner field
dma: imx-dma: Replace printk with dev_*
dma: fsl-edma: fix static checker warning of NULL dereference
dma: Remove comment about embedding dma_slave_config into custom structs
dma: mmp_tdma: move to generic device tree binding
dma: mmp_pdma: add IRQF_SHARED when request irq
dma: edma: Fix memory leak in edma_prep_dma_cyclic()
Martin reported that his test system would not boot with
current git, it oopsed with this:
BUG: unable to handle kernel paging request at ffff88046c6c9e80
IP: [<ffffffff812971e0>] blk_queue_start_tag+0x90/0x150
PGD 1ddf067 PUD 1de2067 PMD 47fc7d067 PTE 800000046c6c9060
Oops: 0002 [#1] SMP DEBUG_PAGEALLOC
Modules linked in: sd_mod lpfc(+) scsi_transport_fc scsi_tgt oracleasm
rpcsec_gss_krb5 ipv6 igb dca i2c_algo_bit i2c_core hwmon
CPU: 3 PID: 87 Comm: kworker/u17:1 Not tainted 3.14.0+ #246
Hardware name: Supermicro X9DRX+-F/X9DRX+-F, BIOS 3.00 07/09/2013
Workqueue: events_unbound async_run_entry_fn
task: ffff8802743c2150 ti: ffff880273d02000 task.ti: ffff880273d02000
RIP: 0010:[<ffffffff812971e0>] [<ffffffff812971e0>]
RSP: 0018:ffff880273d03a58 EFLAGS: 00010092
RAX: ffff88046c6c9e78 RBX: ffff880077208e78 RCX: 00000000fffc8da6
RDX: 00000000fffc186d RSI: 0000000000000009 RDI: 00000000fffc8d9d
RBP: ffff880273d03a88 R08: 0000000000000001 R09: ffff8800021c2410
R10: 0000000000000005 R11: 0000000000015b30 R12: ffff88046c5bb8a0
R13: ffff88046c5c0890 R14: 000000000000001e R15: 000000000000001e
FS: 0000000000000000(0000) GS:ffff880277b00000(0000)
knlGS:0000000000000000
CR2: ffff88046c6c9e80 CR3: 00000000018f6000 CR4: 00000000000407e0
Stack:
ffff880273d03a98 ffff880474b18800 0000000000000000 ffff880474157000
ffff88046c5c0890 ffff880077208e78 ffff880273d03ae8 ffffffff813b9e62
ffff880200000010 ffff880474b18968 ffff880474b18848 ffff88046c5c0cd8
Call Trace:
[<ffffffff813b9e62>] scsi_request_fn+0xf2/0x510
[<ffffffff81293167>] __blk_run_queue+0x37/0x50
[<ffffffff8129ac43>] blk_execute_rq_nowait+0xb3/0x130
[<ffffffff8129ad24>] blk_execute_rq+0x64/0xf0
[<ffffffff8108d2b0>] ? bit_waitqueue+0xd0/0xd0
[<ffffffff813bba35>] scsi_execute+0xe5/0x180
[<ffffffff813bbe4a>] scsi_execute_req_flags+0x9a/0x110
[<ffffffffa01b1304>] sd_spinup_disk+0x94/0x460 [sd_mod]
[<ffffffff81160000>] ? __unmap_hugepage_range+0x200/0x2f0
[<ffffffffa01b2b9a>] sd_revalidate_disk+0xaa/0x3f0 [sd_mod]
[<ffffffffa01b2fb8>] sd_probe_async+0xd8/0x200 [sd_mod]
[<ffffffff8107703f>] async_run_entry_fn+0x3f/0x140
[<ffffffff8106a1c5>] process_one_work+0x175/0x410
[<ffffffff8106b373>] worker_thread+0x123/0x400
[<ffffffff8106b250>] ? manage_workers+0x160/0x160
[<ffffffff8107104e>] kthread+0xce/0xf0
[<ffffffff81070f80>] ? kthread_freezable_should_stop+0x70/0x70
[<ffffffff815f0bac>] ret_from_fork+0x7c/0xb0
Code: 48 0f ab 11 72 db 48 81 4b 40 00 00 10 00 89 83 08 01 00 00 48 89
df 49 8b 04 24 48 89 1c d0 e8 f7 a8 ff ff 49 8b 85 28 05 00 00 <48> 89
58 08 48 89 03 49 8d 85 28 05 00 00 48 89 43 08 49 89 9d
RIP [<ffffffff812971e0>] blk_queue_start_tag+0x90/0x150
RSP <ffff880273d03a58>
Martin bisected and found this to be the problem patch;
commit 6d113398dcf4dfcd9787a4ead738b186f7b7ff0f
Author: Jan Kara <jack@suse.cz>
Date: Mon Feb 24 16:39:54 2014 +0100
block: Stop abusing rq->csd.list in blk-softirq
and the problem was immediately apparent. The patch states that
it is safe to reuse queuelist at completion time, since it is
no longer used. However, that is not true if a device is using
block enabled tagging. If that is the case, then the queuelist
is reused to keep track of busy tags. If a device also ended
up using softirq completions, we'd reuse ->queuelist for the
IPI handling while block tagging was still using it. Boom.
Fix this by adding a new ipi_list list head, and share the
memory used with the request hash table. The hash table is
never used after the request is moved to the dispatch list,
which happens long before any potential completion of the
request. Add a new request bit for this, so we don't have
cases that check rq->hash while it could potentially have
been reused for the IPI completion.
Reported-by: Martin K. Petersen <martin.petersen@oracle.com>
Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
cmd_flags in struct request is now 64 bits wide but the scsi_execute
functions truncated arguments passed to int leading to errors. Make sure
the flags parameters are u64.
Cc: Jens Axboe <axboe@fb.com>
CC: Jan Kara <jack@suse.cz>
gcc <= 4.5.x has significant limitations with respect to initialization
of anonymous unions within structures. They need to be surrounded by
brackets, _and_ they need to be initialized in the same order in which
they appear in the structure declaration.
Link: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=10676
Link: http://lkml.kernel.org/r/1397077568-3156-1-git-send-email-mathieu.desnoyers@efficios.com
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Similar to the fix in 40413dcb7b273bda681dca38e6ff0bbb3728ef11
MODULE_DEVICE_TABLE(x86cpu, ...) expects the struct to be called struct
x86cpu_device_id, and not struct x86_cpu_id which is what is used in the rest
of the kernel code. Although gcc seems to ignore this error, clang fails
without this define to fix the name.
Code from drivers/thermal/x86_pkg_temp_thermal.c
static const struct x86_cpu_id __initconst pkg_temp_thermal_ids[] = { ... };
MODULE_DEVICE_TABLE(x86cpu, pkg_temp_thermal_ids);
Error from clang:
drivers/thermal/x86_pkg_temp_thermal.c:577:1: error: variable has
incomplete type 'const struct x86cpu_device_id'
include/linux/module.h:145:3: note: expanded from macro
'MODULE_DEVICE_TABLE'
MODULE_GENERIC_TABLE(type##_device, name)
include/linux/module.h:87:32: note: expanded from macro
'MODULE_GENERIC_TABLE'
extern const struct gtype##_id __mod_##gtype##_table \
<scratch space>:143:1: note: expanded from here
__mod_x86cpu_device_table
drivers/thermal/x86_pkg_temp_thermal.c:577:1: note: forward declaration of
'struct x86cpu_device_id'
include/linux/module.h:87:21: note: expanded from macro
<scratch space>:141:1: note: expanded from here
x86cpu_device_id
1 error generated.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Add a compiler-clang.h file to add specific macros needed for compiling the
kernel with clang.
Initially the only override required is the macro for silencing the
compiler for a purposefully uninintialized variable.
Author: Mark Charlebois <charlebm@gmail.com>
Signed-off-by: Mark Charlebois <charlebm@gmail.com>
Fix uninitialized return code in default case in cmpxchg-local.h
This patch fixes the code to prevent an uninitialized return value that is detected
when compiling with clang. The bug produces numerous warnings when compiling the
Linux kernel with clang.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fixes for v3.15
A smattering of device specific fixes, nothing stands out here except
for the multiplatform fixes for Samsung and the device IDs being added
by Stephen Warren - there's no real code changes from those and they
give better robustness to the enumeration with DT.
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Here is the pull request from the i2c subsystem. It got a little
delayed because I needed to wait for a dependency to be included
(commit b424080a9e08: "reset: Add optional resets and stubs"). Plus,
I had some email problems. All done now, the highlights are:
- drivers can now deprecate their use of i2c classes. That shouldn't
be used on embedded platforms anyhow and was often blindly
copy&pasted. This mechanism gives users time to switch away and
ultimately boot faster once the use of classes for those drivers is
gone for good.
- new drivers for QUP, Cadence, efm32
- tracepoint support for I2C and SMBus
- bigger cleanups for the mv64xxx, nomadik, and designware drivers
And the usual bugfixes, cleanups, feature additions. Most stuff has
been in linux-next for a while. Just some hot fixes and new drivers
were added a bit more recently."
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (63 commits)
i2c: cadence: fix Kconfig dependency
i2c: Add driver for Cadence I2C controller
i2c: cadence: Document device tree bindings
Documentation: i2c: improve section about flags mangling the protocol
i2c: qup: use proper type fro clk_freq
i2c: qup: off by ones in qup_i2c_probe()
i2c: efm32: fix binding doc
MAINTAINERS: update I2C web resources
i2c: qup: New bus driver for the Qualcomm QUP I2C controller
i2c: qup: Add device tree bindings information
i2c: i2c-xiic: deprecate class based instantiation
i2c: i2c-sirf: deprecate class based instantiation
i2c: i2c-mv64xxx: deprecate class based instantiation
i2c: i2c-designware-platdrv: deprecate class based instantiation
i2c: i2c-davinci: deprecate class based instantiation
i2c: i2c-bcm2835: deprecate class based instantiation
i2c: mv64xxx: Fix reset controller handling
i2c: omap: fix usage of IS_ERR_VALUE with pm_runtime_get_sync
i2c: efm32: new bus driver
i2c: exynos5: remove unnecessary cast of void pointer
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC updates from Chris Ball:
"MMC highlights for 3.15:
Core:
- CONFIG_MMC_UNSAFE_RESUME=y is now default behavior
- DT bindings for SDHCI UHS, eMMC HS200, high-speed DDR, at 1.8/1.2V
- Add GPIO descriptor based slot-gpio card detect API
Drivers:
- dw_mmc: Refactor SOCFPGA support as a variant inside dw_mmc-pltfm.c
- mmci: Support HW busy detection on ux500
- omap: Support MMC_ERASE
- omap_hsmmc: Support MMC_PM_KEEP_POWER, MMC_PM_WAKE_SDIO_IRQ, (a)cmd23
- rtsx: Support pre-req/post-req async
- sdhci: Add support for Realtek RTS5250 controllers
- sdhci-acpi: Add support for 80860F16, fix 80860F14/SDIO card detect
- sdhci-msm: Add new driver for Qualcomm SDHCI chipset support
- sdhci-pxav3: Add support for Marvell Armada 380 and 385 SoCs"
* tag 'mmc-updates-for-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (102 commits)
mmc: sdhci-acpi: Intel SDIO has broken card detect
mmc: sdhci-pxav3: add support for the Armada 38x SDHCI controller
mmc: sdhci-msm: Add platform_execute_tuning implementation
mmc: sdhci-msm: Initial support for Qualcomm chipsets
mmc: sdhci-msm: Qualcomm SDHCI binding documentation
sdhci: only reprogram retuning timer when flag is set
mmc: rename ARCH_BCM to ARCH_BCM_MOBILE
mmc: sdhci: Allow for irq being shared
mmc: sdhci-acpi: Add device id 80860F16
mmc: sdhci-acpi: Fix broken card detect for ACPI HID 80860F14
mmc: slot-gpio: Add GPIO descriptor based CD GPIO API
mmc: slot-gpio: Split out CD IRQ request into a separate function
mmc: slot-gpio: Record GPIO descriptors instead of GPIO numbers
Revert "dts: socfpga: Add support for SD/MMC on the SOCFPGA platform"
mmc: sdhci-spear: use generic card detection gpio support
mmc: sdhci-spear: remove support for power gpio
mmc: sdhci-spear: simplify resource handling
mmc: sdhci-spear: fix platform_data usage
mmc: sdhci-spear: fix error handling paths for DT
mmc: sdhci-bcm-kona: fix build errors when built-in
Fix the following sparse warnings:
CHECK kernel/tracepoint.c
kernel/tracepoint.c:184:18: warning: incorrect type in assignment (different address spaces)
kernel/tracepoint.c:184:18: expected struct tracepoint_func *tp_funcs
kernel/tracepoint.c:184:18: got struct tracepoint_func [noderef] <asn:4>*funcs
kernel/tracepoint.c:216:18: warning: incorrect type in assignment (different address spaces)
kernel/tracepoint.c:216:18: expected struct tracepoint_func *tp_funcs
kernel/tracepoint.c:216:18: got struct tracepoint_func [noderef] <asn:4>*funcs
kernel/tracepoint.c:392:24: error: return expression in void function
CC kernel/tracepoint.o
kernel/tracepoint.c: In function tracepoint_module_going:
kernel/tracepoint.c:491:6: warning: symbol 'syscall_regfunc' was not declared. Should it be static?
kernel/tracepoint.c:508:6: warning: symbol 'syscall_unregfunc' was not declared. Should it be static?
Link: http://lkml.kernel.org/r/1397049883-28692-1-git-send-email-mathieu.desnoyers@efficios.com
Commit 4550dd6c6b062 introduced for_each_bvec() which iterates over each
bvec attached to a bio or bip. However, the macro fails to check bi_size
before dereferencing which can lead to crashes while counting/mapping
integrity scatterlist segments.
Cc: Kent Overstreet <kmo@daterainc.com>
Cc: Nicholas Bellinger <nab@linux-iscsi.org>
Cc: <stable@vger.kernel.org> # v3.14+
Pull nfsd updates from Bruce Fields:
"Highlights:
- server-side nfs/rdma fixes from Jeff Layton and Tom Tucker
- xdr fixes (a larger xdr rewrite has been posted but I decided it
would be better to queue it up for 3.16).
- miscellaneous fixes and cleanup from all over (thanks especially to
Kinglong Mee)"
* 'for-3.15' of git://linux-nfs.org/~bfields/linux: (36 commits)
nfsd4: don't create unnecessary mask acl
nfsd: revert v2 half of "nfsd: don't return high mode bits"
nfsd4: fix memory leak in nfsd4_encode_fattr()
nfsd: check passed socket's net matches NFSd superblock's one
SUNRPC: Clear xpt_bc_xprt if xs_setup_bc_tcp failed
NFSD/SUNRPC: Check rpc_xprt out of xs_setup_bc_tcp
SUNRPC: New helper for creating client with rpc_xprt
NFSD: Free backchannel xprt in bc_destroy
NFSD: Clear wcc data between compound ops
nfsd: Don't return NFS4ERR_STALE_STATEID for NFSv4.1+
nfsd4: fix nfs4err_resource in 4.1 case
nfsd4: fix setclientid encode size
nfsd4: remove redundant check from nfsd4_check_resp_size
nfsd4: use more generous NFS4_ACL_MAX
nfsd4: minor nfsd4_replay_cache_entry cleanup
nfsd4: nfsd4_replay_cache_entry should be static
nfsd4: update comments with obsolete function name
rpc: Allow xdr_buf_subsegment to operate in-place
NFSD: Using free_conn free connection
SUNRPC: fix memory leak of peer addresses in XPRT
Instead of copying the num_tracepoints and tracepoints_ptrs from
the module structure to the tp_mod structure, which only uses it to
find the module associated to tracepoints of modules that are coming
and going, simply copy the pointer to the module struct to the tracepoint
tp_module structure.
Also removed un-needed brackets around an if statement.
Link: http://lkml.kernel.org/r/20140408201705.4dad2c4a@gandalf.local.home
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Register/unregister tracepoint probes with struct tracepoint pointer
rather than tracepoint name.
This change, which vastly simplifies tracepoint.c, has been proposed by
Steven Rostedt. It also removes 8.8kB (mostly of text) to the vmlinux
size.
From this point on, the tracers need to pass a struct tracepoint pointer
to probe register/unregister. A probe can now only be connected to a
tracepoint that exists. Moreover, tracers are responsible for
unregistering the probe before the module containing its associated
tracepoint is unloaded.
10443444 4282528 10391552 25117524 17f4354 vmlinux.orig
10434930 4282848 10391552 25109330 17f2352 vmlinux
Link: http://lkml.kernel.org/r/1396992381-23785-2-git-send-email-mathieu.desnoyers@efficios.com
CC: Ingo Molnar <mingo@kernel.org>
CC: Frederic Weisbecker <fweisbec@gmail.com>
CC: Andrew Morton <akpm@linux-foundation.org>
CC: Frank Ch. Eigler <fche@redhat.com>
CC: Johannes Berg <johannes.berg@intel.com>
[ SDR - fixed return val in void func in tracepoint_module_going() ]
ASoC: Final updates for v3.15 merge window
A few more updates from last week - use of the tdm_slot mapping from
Xiubo plus a few smaller fixes and cleanups.
# gpg: Signature made Mon 31 Mar 2014 10:49:42 BST using RSA key ID 7EA229BD
# gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>"
# gpg: aka "Mark Brown <broonie@debian.org>"
# gpg: aka "Mark Brown <broonie@kernel.org>"
# gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>"
# gpg: aka "Mark Brown <broonie@linaro.org>"
# gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
ASoC: Updates for v3.15
A few more updates for the merge window:
- Fixes for the simple-card DAI format DT mess.
- A new driver for Cirrus cs42xx8 devices.
- DT support for a couple more devices.
- A revert of a previous buggy fix for soc-pcm, plus a few more fixes
and cleanups.
# gpg: Signature made Sun 23 Mar 2014 16:56:11 GMT using RSA key ID 7EA229BD
This is mostly a few additional fixes from Lars-Peter, a new driver and
cleaning up a git failure with merging the Intel branch (combined with
an xargs failure to pay attention to error codes). The history lists a
bunch of additional commits for the branch but the content of those
commits is actually present already but not recorded in history due to
git failing. Unfortunately xargs is used in the merge script and it
doesn't do a good job of noticing errors from the commands it invokes.
# gpg: Signature made Thu 13 Mar 2014 14:25:44 GMT using RSA key ID 7EA229BD
Quite a busy release for ASoC this time, more on janitorial work than
exciting new features but welcome nontheless:
- Lots of cleanups from Takashi for enumerations; the original API for
these was error prone so he's refactored lots of code to use more
modern APIs which avoid issues.
- Elimination of the ASoC level wrappers for I2C and SPI moving us
closer to converting to regmap completely and avoiding some
randconfig hassle.
- Provide both manually and transparently locked DAPM APIs rather than
a mix of the two fixing some concurrency issues.
- Start converting CODEC drivers to use separate bus interface drivers
rather than having them all in one file helping avoid dependency
issues.
- DPCM support for Intel Haswell and Bay Trail platforms.
- Lots of work on improvements for simple-card, DaVinci and the Renesas
rcar drivers.
- New drivers for Analog Devices ADAU1977, TI PCM512x and parts of the
CSR SiRF SoC.
# gpg: Signature made Wed 12 Mar 2014 23:05:45 GMT using RSA key ID 7EA229BD
Pull more networking updates from David Miller:
1) If a VXLAN interface is created with no groups, we can crash on
reception of packets. Fix from Mike Rapoport.
2) Missing includes in CPTS driver, from Alexei Starovoitov.
3) Fix string validations in isdnloop driver, from YOSHIFUJI Hideaki
and Dan Carpenter.
4) Missing irq.h include in bnxw2x, enic, and qlcnic drivers. From
Josh Boyer.
5) AF_PACKET transmit doesn't statistically count TX drops, from Daniel
Borkmann.
6) Byte-Queue-Limit enabled drivers aren't handled properly in
AF_PACKET transmit path, also from Daniel Borkmann.
Same problem exists in pktgen, and Daniel fixed it there too.
7) Fix resource leaks in driver probe error paths of new sxgbe driver,
from Francois Romieu.
8) Truesize of SKBs can gradually get more and more corrupted in NAPI
packet recycling path, fix from Eric Dumazet.
9) Fix uniprocessor netfilter build, from Florian Westphal. In the
longer term we should perhaps try to find a way for ARRAY_SIZE() to
work even with zero sized array elements.
10) Fix crash in netfilter conntrack extensions due to mis-estimation of
required extension space. From Andrey Vagin.
11) Since we commit table rule updates before trying to copy the
counters back to userspace (it's the last action we perform), we
really can't signal the user copy with an error as we are beyond the
point from which we can unwind everything. This causes all kinds of
use after free crashes and other mysterious behavior.
From Thomas Graf.
12) Restore previous behvaior of div/mod by zero in BPF filter
processing. From Daniel Borkmann.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (38 commits)
net: sctp: wake up all assocs if sndbuf policy is per socket
isdnloop: several buffer overflows
netdev: remove potentially harmful checks
pktgen: fix xmit test for BQL enabled devices
net/at91_ether: avoid NULL pointer dereference
tipc: Let tipc_release() return 0
at86rf230: fix MAX_CSMA_RETRIES parameter
mac802154: fix duplicate #include headers
sxgbe: fix duplicate #include headers
net: filter: be more defensive on div/mod by X==0
netfilter: Can't fail and free after table replacement
xen-netback: Trivial format string fix
net: bcmgenet: Remove unnecessary version.h inclusion
net: smc911x: Remove unused local variable
bonding: Inactive slaves should keep inactive flag's value
netfilter: nf_tables: fix wrong format in request_module()
netfilter: nf_tables: set names cannot be larger than 15 bytes
netfilter: nf_conntrack: reserve two bytes for nf_ct_ext->len
netfilter: Add {ipt,ip6t}_osf aliases for xt_osf
netfilter: x_tables: allow to use cgroup match for LOCAL_IN nf hooks
Pull drm updates from Dave Airlie:
"Highlights:
- drm:
Generic display port aux features, primary plane support, drm
master management fixes, logging cleanups, enforced locking checks
(instead of docs), documentation improvements, minor number
handling cleanup, pseudofs for shared inodes.
- ttm:
add ability to allocate from both ends
- i915:
broadwell features, power domain and runtime pm, per-process
address space infrastructure (not enabled)
- msm:
power management, hdmi audio support
- nouveau:
ongoing GPU fault recovery, initial maxwell support, random fixes
- exynos:
refactored driver to clean up a lot of abstraction, DP support
moved into drm, LVDS bridge support added, parallel panel support
- gma500:
SGX MMU support, SGX irq handling, asle irq work fixes
- radeon:
video engine bringup, ring handling fixes, use dp aux helpers
- vmwgfx:
add rendernode support"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (849 commits)
DRM: armada: fix corruption while loading cursors
drm/dp_helper: don't return EPROTO for defers (v2)
drm/bridge: export ptn3460_init function
drm/exynos: remove MODULE_DEVICE_TABLE definitions
ARM: dts: exynos4412-trats2: enable exynos/fimd node
ARM: dts: exynos4210-trats: enable exynos/fimd node
ARM: dts: exynos4412-trats2: add panel node
ARM: dts: exynos4210-trats: add panel node
ARM: dts: exynos4: add MIPI DSI Master node
drm/panel: add S6E8AA0 driver
ARM: dts: exynos4210-universal_c210: add proper panel node
drm/panel: add ld9040 driver
panel/ld9040: add DT bindings
panel/s6e8aa0: add DT bindings
drm/exynos: add DSIM driver
exynos/dsim: add DT bindings
drm/exynos: disallow fbdev initialization if no device is connected
drm/mipi_dsi: create dsi devices only for nodes with reg property
drm/mipi_dsi: add flags to DSI messages
Skip intel_crt_init for Dell XPS 8700
