git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm updates from Thierry Reding:
"This set of changes contains a new driver for OMAP (using the
dual-mode timers) as well as an assortment of fixes all across the
board"
* tag 'pwm/for-4.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm:
pwm: Mark all devices as "might sleep"
pwm: omap-dmtimer: Potential NULL dereference on error
pwm: add HAS_IOMEM dependency to PWM_FSL_FTM
pwm: Add PWM driver for OMAP using dual-mode timers
pwm: rcar: Improve accuracy of frequency division setting
pwm: lpc32xx: return ERANGE, if requested period is not supported
pwm: lpc32xx: fix and simplify duty cycle and period calculations
pwm: lpc32xx: make device usable with common clock framework
pwm: lpc32xx: correct number of PWM channels from 2 to 1
dt: lpc32xx: pwm: update documentation of LPC32xx PWM device
dt: lpc32xx: pwm: correct LPC32xx PWM device node example
pwm: fsl-ftm: Fix clock enable/disable when using PM
pwm: lpss: Rework the sequence of programming PWM_SW_UPDATE
pwm: lpss: Select core part automatically
pwm: lpss: Update PWM setting for Broxton
pwm: bcm2835: Fix email address specification
pwm: bcm2835: Prevent division by zero
pwm: bcm2835: Calculate scaler in ->config()
pwm: lpss: Remove ->free() callback
Pull more power management and ACPI updates from Rafael Wysocki:
"This includes fixes on top of the previous batch of PM+ACPI updates
and some new material as well.
From the new material perspective the most significant are the driver
core changes that should allow USB devices to stay suspended over
system suspend/resume cycles if they have been runtime-suspended
already beforehand. Apart from that, ACPICA is updated to upstream
revision 20160108 (cosmetic mostly, but including one fixup on top of
the previous ACPICA update) and there are some devfreq updates the
didn't make it before (due to timing).
A few recent regressions are fixed, most importantly in the cpuidle
menu governor and in the ACPI backlight driver and some x86 platform
drivers depending on it.
Some more bugs are fixed and cleanups are made on top of that.
Specifics:
- Modify the driver core and the USB subsystem to allow USB devices
to stay suspended over system suspend/resume cycles if they have
been runtime-suspended already beforehand and fix some bugs on top
of these changes (Tomeu Vizoso, Rafael Wysocki).
- Update ACPICA to upstream revision 20160108, including updates of
the ACPICA's copyright notices, a code fixup resulting from a
regression fix that was necessary in the upstream code only (the
regression fixed by it has never been present in Linux) and a
compiler warning fix (Bob Moore, Lv Zheng).
- Fix a recent regression in the cpuidle menu governor that broke it
on practically all architectures other than x86 and make a couple
of optimizations on top of that fix (Rafael Wysocki).
- Clean up the selection of cpuidle governors depending on whether or
not the kernel is configured for tickless systems (Jean Delvare).
- Revert a recent commit that introduced a regression in the ACPI
backlight driver, address the problem it attempted to fix in a
different way and revert one more cosmetic change depending on the
problematic commit (Hans de Goede).
- Add two more ACPI backlight quirks (Hans de Goede).
- Fix a few minor problems in the core devfreq code, clean it up a
bit and update the MAINTAINERS information related to it (Chanwoo
Choi, MyungJoo Ham).
- Improve an error message in the ACPI fan driver (Andy Lutomirski).
- Fix a recent build regression in the cpupower tool (Shreyas
Prabhu)"
* tag 'pm+acpi-4.5-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits)
cpuidle: menu: Avoid pointless checks in menu_select()
sched / idle: Drop default_idle_call() fallback from call_cpuidle()
cpupower: Fix build error in cpufreq-info
cpuidle: Don't enable all governors by default
cpuidle: Default to ladder governor on ticking systems
time: nohz: Expose tick_nohz_enabled
ACPICA: Update version to 20160108
ACPICA: Silence a -Wbad-function-cast warning when acpi_uintptr_t is 'uintptr_t'
ACPICA: Additional 2016 copyright changes
ACPICA: Reduce regression fix divergence from upstream ACPICA
ACPI / video: Add disable_backlight_sysfs_if quirk for the Toshiba Satellite R830
ACPI / video: Revert "thinkpad_acpi: Use acpi_video_handles_brightness_key_presses()"
ACPI / video: Document acpi_video_handles_brightness_key_presses() a bit
ACPI / video: Fix using an uninitialized mutex / list_head in acpi_video_handles_brightness_key_presses()
ACPI / video: Revert "ACPI / video: driver must be registered before checking for keypresses"
ACPI / fan: Improve acpi_device_update_power error message
ACPI / video: Add disable_backlight_sysfs_if quirk for the Toshiba Portege R700
cpuidle: menu: Fix menu_select() for CPUIDLE_DRIVER_STATE_START == 0
MAINTAINERS: Add devfreq-event entry
MAINTAINERS: Add missing git repository and directory for devfreq
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas
Pull SH driver updates from Simon Horman:
"Clean up the clock API on legacy SH to make it more similar to the
Common Clock Framework. This will avoid different behaviour in
drivers shared between legacy and CCF-based platforms (e.g. SCIF)"
* tag 'renesas-sh-drivers-for-v4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
drivers: sh: clk: Avoid crashes when passing NULL clocks
drivers: sh: clk: Remove obsolete and unused clk_round_parent()
Pull ARM SoC driver updates from Olof Johansson:
"Driver updates for ARM SoCs. Some for SoC-family code under
drivers/soc, but also some other driver updates that don't belong
anywhere else. We also bring in the drivers/reset code through
arm-soc.
Some of the larger updates:
- Qualcomm support for SMEM, SMSM, SMP2P. All used to communicate
with other parts of the chip/board on these platforms, all
proprietary protocols that don't fit into other subsystems and live
in drivers/soc for now.
- System bus driver for UniPhier
- Driver for the TI Wakeup M3 IPC device
- Power management for Raspberry PI
+ Again a bunch of other smaller updates and patches"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (38 commits)
bus: uniphier: allow only built-in driver
ARM: bcm2835: clarify RASPBERRYPI_FIRMWARE dependency
MAINTAINERS: Drop Kumar Gala from QCOM
bus: uniphier-system-bus: add UniPhier System Bus driver
ARM: bcm2835: add rpi power domain driver
dt-bindings: add rpi power domain driver bindings
ARM: bcm2835: Define two new packets from the latest firmware.
drivers/soc: make mediatek/mtk-scpsys.c explicitly non-modular
soc: mediatek: SCPSYS: Add regulator support
MAINTAINERS: Change QCOM entries
soc: qcom: smd-rpm: Add existing platform support
memory/tegra: Add number of TLB lines for Tegra124
reset: hi6220: fix modular build
soc: qcom: Introduce WCNSS_CTRL SMD client
ARM: qcom: select ARM_CPU_SUSPEND for power management
MAINTAINERS: Add rules for Qualcomm dts files
soc: qcom: enable smsm/smp2p modular build
serial: msm_serial: Make config tristate
soc: qcom: smp2p: Qualcomm Shared Memory Point to Point
soc: qcom: smsm: Add driver for Qualcomm SMSM
Pull ARM DT updates from Olof Johansson:
"As usual, the bulk of this release is again DT file contents.
There's a huge number of changes here, and it's challenging to give a
crisp overview of just what is in here. To start with:
New boards:
- TI-based DM3730 from LogicPD (Torpedo)
- Cosmic+ M4 (nommu) initial support (Freescale Vybrid)
- Raspberry Pi 2 DT files
- Watchdog on Meson8b
- Veyron-mickey (ASUS Chromebit) DTS
- Rockchip rk3228 SoC and eval board
- Sigma Designs Tango4
Improvements:
- Improved support for Qualcomm APQ8084, including Sony Xperia Z DT files
- Misc new devices for Rockchip rk3036 and rk3288
- Allwinner updates for misc SoCs and systems
... and a _large_ number of other changes across the field. Devices
added to SoC DTSI and board DTS files for a number of SoC vendors, new
product boards on already-supported SoCs, cleanups and refactorings of
existing DTS/DTSI files and a bunch of other changes"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (469 commits)
ARM: dts: compulab: add new board description
ARM: versatile: add the syscon LEDs to the DT
dts: vt8500: Fix errors in SDHC node for WM8505
ARM: dts: imx6q: clean up unused ipu2grp
ARM: dts: silk: Add compatible property to "partitions" node
ARM: dts: gose: Add compatible property to "partitions" node
ARM: dts: porter: Add compatible property to "partitions" node
ARM: dts: koelsch: Add compatible property to "partitions" node
ARM: dts: lager: Add compatible property to "partitions" node
ARM: dts: bockw: Add compatible property to "partitions" node
ARM: dts: meson8b: Add watchdog node
Documentation: watchdog: Add new bindings for meson8b
ARM: meson: Add status LED for Odroid-C1
ARM: dts: uniphier: fix a typo in comment block
ARM: bcm2835: Add the auxiliary clocks to the device tree.
ARM: bcm2835: Add devicetree for bcm2836 and Raspberry Pi 2 B
ARM: bcm2835: Move the CPU/peripheral include out of common RPi DT.
ARM: bcm2835: Split the DT for peripherals from the DT for the CPU
ARM: realview: set up cache correctly on the PB11MPCore
ARM: dts: Unify G2D device node with other devices on exynos4
Pull ARM SoC platform updates from Olof Johansson:
"Updates for new platform support:
- New platform: Tango4 from Sigma Designs.
- Broadcom BCM2836 (Raspberry Pi 2 SoC)
- Enable cpufreq on Freescale i.MX7D
- Rockchip: SMP support for rk3036, general support for rk3228
- SMP support on Broadcom Kona and NSP
- Cleanups for OMAP removing legacy IOMMU data
+ a bunch of misc fixes and tweaks for various platforms"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (46 commits)
ARM: tango: Fix UP build issues
ARM: tango: pass ARM arch level for smc.S
ARM: bcm2835: Add Kconfig support for bcm2836
ARM: OMAP2+: Add support for dm814x and dra62x usb
ARM: OMAP2+: Add mmc hwmod entries for dm814x
ARM: OMAP2+: Update 81xx clock and power domains for default, active and sgx
ARM: OMAP2+: Fix SoC detection for dra62x j5-eco
ARM: tango4: Initial platform support
ARM: bcm2835: Add a compat string for bcm2836 machine probe
dt-bindings: Add root properties for Raspberry Pi 2
ARM: imx: select SRC for i.MX7
ARM: uniphier: select PINCTRL
ARM: OMAP2+: Remove device creation for omap-pcm-audio
ARM: OMAP1: Remove device creation for omap-pcm-audio
ARM: rockchip: enable support for RK3228 SoCs
ARM: rockchip: use const and __initconst for rk3036 smp_operations
ARM: zynq: Select ARCH_HAS_RESET_CONTROLLER
ARM: BCM: Add SMP support for Broadcom 4708
ARM: BCM: Add SMP support for Broadcom NSP
ARM: BCM: Clean up SMP support for Broadcom Kona
Pull ARM SoC multiplatform code updates from Arnd Bergmann:
"This branch is the culmination of 5 years of effort to bring the ARMv6
and ARMv7 platforms together such that they can all be enabled and
boot the same kernel. It has been a tremendous amount of cleanup and
refactoring by a huge number of people, and creation of several new
(and major) subsystems to better abstract out all the platform details
in an appropriate manner.
The bulk of this branch is a large patchset from Arnd that brings
several of the more minor and older platforms we have closer to
multiplatform support. Among these are MMP, S3C64xx, Orion5x, mv78xx0
and realview Much of this is moving around header files from old mach
directories, but there are also some cleanup patches of debug_ll
(lowlevel debug per-platform options) and other parts.
Linus Walleij also has some patchs to clean up the older ARM Realview
platforms by finally introducing DT support, and Rob Herring has some
for ARM Versatile which is now DT-only. Both of these platforms are
now multiplatform.
Finally, a couple of patches from Russell for Dove PMU, and a fix from
Valentin Rothberg for Exynos ADC, which were rebased on top of the
series to avoid conflicts"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits)
ARM: realview: don't select SMP_ON_UP for UP builds
ARM: s3c: simplify s3c_irqwake_{e,}intallow definition
ARM: s3c64xx: fix pm-debug compilation
iio: exynos-adc: fix irqf_oneshot.cocci warnings
ARM: realview: build realview-dt SMP support only when used
ARM: realview: select apropriate targets
ARM: realview: clean up header files
ARM: realview: make all header files local
ARM: no longer make CPU targets visible separately
ARM: integrator: use explicit core module options
ARM: realview: enable multiplatform
ARM: make default platform work for NOMMU
ARM: debug-ll: move DEBUG_LL_UART_EFM32 to correct Kconfig location
ARM: defconfig: use correct debug_ll settings
ARM: versatile: convert to multi-platform
ARM: versatile: merge mach code into a single file
ARM: versatile: switch to DT only booting and remove legacy code
ARM: versatile: add DT based PCI detection
ARM: pxa: mark ezx structures as __maybe_unused
ARM: pxa: mark raumfeld init functions as __maybe_unused
Pull ARM SoC cleanups from Olof Johansson:
"A smallish number of general cleanup commits this release cycle. Some
of these are minor tweaks:
- shmobile change of binding for their GIC (using arm,pl390 now)
- ARCH_RENESAS introduction
- Misc other renesas updates
There's also a couple of treewide commits from Masahiro Yamada
cleaning up const/__initconst for SMP operation structs and a switch
to using "depends on" instead of if-constructs on most of the Kconfig
platform targets"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
staging: board: armadillo800eva: Use "arm,pl390"
staging: board: kzm9d: Use "arm,pl390"
ARM: shmobile: r8a7778 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: emev2 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: r8a7740 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: r7s72100 dtsi: Use "arm,pl390" for GIC
ARM: use "depends on" for SoC configs instead of "if" after prompt
ARM/clocksource: use automatic DT probing for ux500 PRCMU
ARM: use const and __initconst for smp_operations
ARM: hisi: do not export smp_operations structures
ARM: mvebu: remove unused mach/gpio.h
ARM: shmobile: Remove legacy mach/irqs.h
ARM: shmobile: Introduce ARCH_RENESAS
MAINTAINERS: Remove link to oss.renesas.com which is closed
Pull non-urgent ARM SoC fixes from Olof Johansson:
"As usual, we queue up a few fixes that don't seem urgent enough to go
in through -rc.
- MAINTAINERS updates to add a list for brcmstb and fix a typo
- A handful of fixes for OMAP 81xx, a recently resurrected platform
so these can't be considered real regressions and thus got queued.
- A couple of other small fixes for scoop, sa1100 and davinci"
* tag 'armsoc-fixes-nc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: OMAP2+: Fix randconfig build warning for dm814_pllss_data
ARM: sa1100/simpad: Be sure to clamp return value
ARM: scoop: Be sure to clamp return value
ARM: davinci: fix a problematic usage of WARN()
ARM: davinci: only select WT cache if cache is enabled
ARM: OMAP2+: Remove useless check for legacy booting for dm814x
ARM: OMAP2+: Enable GPIO for dm814x
ARM: dts: Fix dm814x pinctrl address and mask
ARM: dts: Fix dm8148 control modules ranges
ARM: OMAP2+: Fix timer entries for dm814x
ARM: dts: Fix some mux and divider clocks to get dm814x-evm booting
ARM: OMAP2+: Add DPPLS clock manager for dm814x
clk: ti: Add few dm814x clock aliases
ARM: dts: Fix dm814x entries for pllss and prcm
MAINTAINERS: gpio-brcmstb: Remove stray '>'
MAINTAINERS: brcmstb: Include Broadcom internal mailing-list
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic updates from Arnd Bergmann:
"The asm-generic tree this time contains one series from Nicolas Pitre
that makes the optimized do_div() implementation from the ARM
architecture available to all architectures.
This also adds stricter type checking for callers of do_div, which has
uncovered a number of bugs in existing code, and fixes up the ones we
have found"
* tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
ARM: asm/div64.h: adjust to generic codde
__div64_32(): make it overridable at compile time
__div64_const32(): abstract out the actual 128-bit cross product code
do_div(): generic optimization for constant divisor on 32-bit machines
div64.h: optimize do_div() for power-of-two constant divisors
mtd/sm_ftl.c: fix wrong do_div() usage
drm/mgag200/mgag200_mode.c: fix wrong do_div() usage
hid-sensor-hub.c: fix wrong do_div() usage
ti/fapll: fix wrong do_div() usage
ti/clkt_dpll: fix wrong do_div() usage
tegra/clk-divider: fix wrong do_div() usage
imx/clk-pllv2: fix wrong do_div() usage
imx/clk-pllv1: fix wrong do_div() usage
nouveau/nvkm/subdev/clk/gk20a.c: fix wrong do_div() usage
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"The highlights this round include:
- Introduce configfs support for unlocked configfs_depend_item()
(krzysztof + andrezej)
- Conversion of usb-gadget target driver to new function registration
interface (andrzej + sebastian)
- Enable qla2xxx FC target mode support for Extended Logins (himansu +
giridhar)
- Enable qla2xxx FC target mode support for Exchange Offload (himansu +
giridhar)
- Add qla2xxx FC target mode irq affinity notification + selective
command queuing. (quinn + himanshu)
- Fix iscsi-target deadlock in se_node_acl configfs deletion (sagi +
nab)
- Convert se_node_acl configfs deletion + se_node_acl->queue_depth to
proper se_session->sess_kref + target_get_session() usage. (hch +
sagi + nab)
- Fix long-standing race between se_node_acl->acl_kref get and
get_initiator_node_acl() lookup. (hch + nab)
- Fix target/user block-size handling, and make sure netlink reaches
all network namespaces (sheng + andy)
Note there is an outstanding bug-fix series for remote I_T nexus port
TMR LUN_RESET has been posted and still being tested, and will likely
become post -rc1 material at this point"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (56 commits)
scsi: qla2xxxx: avoid type mismatch in comparison
target/user: Make sure netlink would reach all network namespaces
target: Obtain se_node_acl->acl_kref during get_initiator_node_acl
target: Convert ACL change queue_depth se_session reference usage
iscsi-target: Fix potential dead-lock during node acl delete
ib_srpt: Convert acl lookup to modern get_initiator_node_acl usage
tcm_fc: Convert acl lookup to modern get_initiator_node_acl usage
tcm_fc: Wait for command completion before freeing a session
target: Fix a memory leak in target_dev_lba_map_store()
target: Support aborting tasks with a 64-bit tag
usb/gadget: Remove set-but-not-used variables
target: Remove an unused variable
target: Fix indentation in target_core_configfs.c
target/user: Allow user to set block size before enabling device
iser-target: Fix non negative ERR_PTR isert_device_get usage
target/fcoe: Add tag support to tcm_fc
qla2xxx: Check for online flag instead of active reset when transmitting responses
qla2xxx: Set all queues to 4k
qla2xxx: Disable ZIO at start time.
qla2xxx: Move atioq to a different lock to reduce lock contention
* pm-cpuidle:
* pm-devfreq:
PM / devfreq: Do not show statistics if it's not ready.
PM / devfreq: Modify the indentation of trans_stat sysfs for readability
PM / devfreq: Set the freq_table of devfreq device
PM / devfreq: Add show_one macro to delete the duplicate code
PM / devfreq: event: Fix the error and warning from script/checkpatch.pl
PM / devfreq: event: Remove the error log of devfreq_event_get_edev_by_phandle()
* pm-core:
driver core: Avoid NULL pointer dereferences in device_is_bound()
platform: Do not detach from PM domains on shutdown
USB / PM: Allow USB devices to remain runtime-suspended when sleeping
PM / sleep: Go direct_complete if driver has no callbacks
PM / Domains: add setter for dev.pm_domain
device core: add device_is_bound()
* acpica:
* acpi-video:
* acpi-fan:
This patch addresses a long standing race where obtaining
se_node_acl->acl_kref in __transport_register_session()
happens a bit too late, and leaves open the potential
for core_tpg_del_initiator_node_acl() to hit a NULL
pointer dereference.
Instead, take ->acl_kref in core_tpg_get_initiator_node_acl()
while se_portal_group->acl_node_mutex is held, and move the
final target_put_nacl() from transport_deregister_session()
into transport_free_session() so that fabric driver login
failure handling using the modern method to still work
as expected.
Also, update core_tpg_get_initiator_node_acl() to take
an extra reference for dynamically generated acls for
demo-mode, before returning to fabric caller. Also
update iscsi-target sendtargets special case handling
to use target_tpg_has_node_acl() when checking if
demo_mode_discovery == true during discovery lookup.
Note the existing wait_for_completion(&acl->acl_free_comp)
in core_tpg_del_initiator_node_acl() does not change.
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Andy Grover <agrover@redhat.com>
Cc: Mike Christie <michaelc@cs.wisc.edu>
This patch converts core_tpg_set_initiator_node_queue_depth()
to use struct se_node_acl->acl_sess_list when performing
explicit se_tpg_tfo->shutdown_session() for active sessions,
in order for new se_node_acl->queue_depth to take effect.
This follows how core_tpg_del_initiator_node_acl() currently
works when invoking se_tpg_tfo->shutdown-session(), and ahead
of the next patch to take se_node_acl->acl_kref during lookup,
the extra get_initiator_node_acl() can go away. In order to
achieve this, go ahead and change target_get_session() to use
kref_get_unless_zero() and propigate up the return value
to know when a session is already being released.
This is because se_node_acl->acl_group is already protecting
se_node_acl->acl_group reference via configfs, and shutdown
within core_tpg_del_initiator_node_acl() won't occur until
sys_write() to core_tpg_set_initiator_node_queue_depth()
attribute returns back to user-space.
Also, drop the left-over iscsi-target hack, and obtain
se_portal_group->session_lock in lio_tpg_shutdown_session()
internally. Remove iscsi-target wrapper and unused se_tpg +
force parameters and associated code.
Reported-by: Christoph Hellwig <hch@lst.de>
Pull core block updates from Jens Axboe:
"We don't have a lot of core changes this time around, it's mostly in
drivers, which will come in a subsequent pull.
The cores changes include:
- blk-mq
- Prep patch from Christoph, changing blk_mq_alloc_request() to
take flags instead of just using gfp_t for sleep/nosleep.
- Doc patch from me, clarifying the difference between legacy
and blk-mq for timer usage.
- Fixes from Raghavendra for memory-less numa nodes, and a reuse
of CPU masks.
- Cleanup from Geliang Tang, using offset_in_page() instead of open
coding it.
- From Ilya, rename request_queue slab to it reflects what it holds,
and a fix for proper use of bdgrab/put.
- A real fix for the split across stripe boundaries from Keith. We
yanked a broken version of this from 4.4-rc final, this one works.
- From Mike Krinkin, emit a trace message when we split.
- From Wei Tang, two small cleanups, not explicitly clearing memory
that is already cleared"
* 'for-4.5/core' of git://git.kernel.dk/linux-block:
block: use bd{grab,put}() instead of open-coding
block: split bios to max possible length
block: add call to split trace point
blk-mq: Avoid memoryless numa node encoded in hctx numa_node
blk-mq: Reuse hardware context cpumask for tags
blk-mq: add a flags parameter to blk_mq_alloc_request
Revert "blk-flush: Queue through IO scheduler when flush not required"
block: clarify blk_add_timer() use case for blk-mq
bio: use offset_in_page macro
block: do not initialise statics to 0 or NULL
block: do not initialise globals to 0 or NULL
block: rename request_queue slab cache
Pull virtio barrier rework+fixes from Michael Tsirkin:
"This adds a new kind of barrier, and reworks virtio and xen to use it.
Plus some fixes here and there"
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: (44 commits)
checkpatch: add virt barriers
checkpatch: check for __smp outside barrier.h
checkpatch.pl: add missing memory barriers
virtio: make find_vqs() checkpatch.pl-friendly
virtio_balloon: fix race between migration and ballooning
virtio_balloon: fix race by fill and leak
s390: more efficient smp barriers
s390: use generic memory barriers
xen/events: use virt_xxx barriers
xen/io: use virt_xxx barriers
xenbus: use virt_xxx barriers
virtio_ring: use virt_store_mb
sh: move xchg_cmpxchg to a header by itself
sh: support 1 and 2 byte xchg
virtio_ring: update weak barriers to use virt_xxx
Revert "virtio_ring: Update weak barriers to use dma_wmb/rmb"
asm-generic: implement virt_xxx memory barriers
x86: define __smp_xxx
xtensa: define __smp_xxx
tile: define __smp_xxx
Pull arch/tile updates from Chris Metcalf:
"This is a grab bag of changes that includes some NOHZ and
context-tracking related changes, some debugging improvements,
JUMP_LABEL support, and some fixes for tilepro allmodconfig support.
We also remove the now-unused node_has_online_mem() definitions both
for tile's asm/topology.h as well as in linux/topology.h itself"
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
numa: remove stale node_has_online_mem() define
arch/tile: move user_exit() to early kernel entry sequence
tile: fix bug in setting PT_FLAGS_DISABLE_IRQ on kernel entry
tile: fix tilepro casts for readl, writel, etc
tile: fix a -Wframe-larger-than warning
tile: include the syscall number in the backtrace
MAINTAINERS: add git URL for tile
arch/tile: adopt prepare_exit_to_usermode() model from x86
tile/jump_label: add jump label support for TILE-Gx
tile: define a macro ktext_writable_addr to get writable kernel text address
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32
Pull AVR32 updates from Hans-Christian Noren Egtvedt.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32:
mmc: atmel: get rid of struct mci_dma_data
mmc: atmel-mci: restore dma on AVR32
avr32: wire up missing syscalls
avr32: wire up accept4 syscall
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs updates from Chris Mason:
"This has our usual assortment of fixes and cleanups, but the biggest
change included is Omar Sandoval's free space tree. It's not the
default yet, mounting -o space_cache=v2 enables it and sets a readonly
compat bit. The tree can actually be deleted and regenerated if there
are any problems, but it has held up really well in testing so far.
For very large filesystems (30T+) our existing free space caching code
can end up taking a huge amount of time during commits. The new tree
based code is faster and less work overall to update as the commit
progresses.
Omar worked on this during the summer and we'll hammer on it in
production here at FB over the next few months"
* 'for-linus-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (73 commits)
Btrfs: fix fitrim discarding device area reserved for boot loader's use
Btrfs: Check metadata redundancy on balance
btrfs: statfs: report zero available if metadata are exhausted
btrfs: preallocate path for snapshot creation at ioctl time
btrfs: allocate root item at snapshot ioctl time
btrfs: do an allocation earlier during snapshot creation
btrfs: use smaller type for btrfs_path locks
btrfs: use smaller type for btrfs_path lowest_level
btrfs: use smaller type for btrfs_path reada
btrfs: cleanup, use enum values for btrfs_path reada
btrfs: constify static arrays
btrfs: constify remaining structs with function pointers
btrfs tests: replace whole ops structure for free space tests
btrfs: use list_for_each_entry* in backref.c
btrfs: use list_for_each_entry_safe in free-space-cache.c
btrfs: use list_for_each_entry* in check-integrity.c
Btrfs: use linux/sizes.h to represent constants
btrfs: cleanup, remove stray return statements
btrfs: zero out delayed node upon allocation
btrfs: pass proper enum type to start_transaction()
Pull more networking fixes from David Miller:
1) Fix brcmfmac build with older gcc, from Arend van Spriel.
2) IRQ values unintentionally truncated to u8 in mlx5 driver, from
Doron Tsur.
3) Fix build warnings wrt tcp cgroup changes, from Geert Uytterhoeven.
4) Limit deep recursion in ovs stack, from Hannes Frederic Sowa.
5) at803x phy driver bug fixes from, Martin Blumenstingl.
6) Fix TSO handling in hns driver, from Daode Huang
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (22 commits)
ovs: limit ovs recursions in ovs_execute_actions to not corrupt stack
team: Replace rcu_read_lock with a mutex in team_vlan_rx_kill_vid
net: hns: bug fix about hisilicon TSO BD mode
brcmfmac: fix BRCMF_FW_NVRAM_DEF macro for older gcc compilers
net: phy: at803x: Add the interrupt register bit definitions
net: phy: at803x: Clean up duplicate register definitions
net: phy: at803x: Allow specifying the RGMII RX clock delay via phy mode
net: phy: at803x: Don't set gbit features for the AR8030 phy
arm64: bpf: add extra pass to handle faulty codegen
arm64: insn: remove BUG_ON from codegen
sctp: the temp asoc's transports should not be hashed/unhashed
net/mlx5_core: Fix trimming down IRQ number
tcp_memcontrol: Forward declare cgroup_subsys and mem_cgroup stucts
batman-adv: Drop immediate orig_node free function
batman-adv: Drop immediate batadv_hard_iface free function
batman-adv: Drop immediate neigh_ifinfo free function
batman-adv: Drop immediate batadv_hardif_neigh_node free function
batman-adv: Drop immediate batadv_neigh_node free function
batman-adv: Drop immediate batadv_orig_ifinfo free function
batman-adv: Avoid recursive call_rcu for batadv_nc_node
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux
Pull RTC updates from Alexandre Belloni:
"Core:
- fix module reference count in rtc-proc
- Replace simple_strtoul by kstrtoul
New driver:
- Epson RX8010SJ
Subsystem wide cleanups:
- use %ph for short hex dumps
- constify *_chip_ops structures
Drivers:
- abx80x: Microcrystal rv1805 support, alarm support
- cmos: prevent kernel warning on IRQ flags mismatch
- s5m: various cleanups
- rv8803: rx8900 compatibility, small error path fix
- sunxi: various cleanups
- lpc32xx: remove irq > NR_IRQS check from probe()
- imxdi: fix spelling mistake in warning message
- ds1685: don't try to micromanage sysfs output size
- da9063: avoid writing undefined data to rtc
- gemini: Remove unnecessary platform_set_drvdata()
- efi: add efi_procfs in efi_rtc_ops
- pcf8523: refuse to write dates later than 2099"
* tag 'rtc-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (24 commits)
rtc: cmos: prevent kernel warning on IRQ flags mismatch
rtc: rtc-ds2404: constify ds2404_chip_ops structures
rtc: s5m: Make register configuration per S2MPS device to remove exceptions
rtc: s5m: Add separate field for storing auto-cleared mask in register config
rtc: s5m: Cleanup by removing useless 'rtc' prefix from fields
rtc: Replace simple_strtoul by kstrtoul
rtc: abx80x: add alarm support
rtc: abx80x: Add Microcrystal rv1805 support
rtc: v3020: constify v3020_chip_ops structures
rtc: rv8803: Extend compatibility with the rx8900
rtc: rv8803: fix handling return value of i2c_smbus_read_byte_data
rtc: Add Epson RX8010SJ RTC driver
rtc: lpc32xx: remove irq > NR_IRQS check from probe()
rtc: imxdi: fix spelling mistake in warning message
rtc: ds1685: don't try to micromanage sysfs output size
rtc: use %ph for short hex dumps
rtc: da9063: avoid writing undefined data to rtc
rtc: sunxi: use of_device_get_match_data
rtc: sunxi: constify the data_year_param structure
rtc: sunxi: fix signedness issues
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev updates from Tomi Valkeinen:
"Summary:
- pxafb: device-tree support
- An unsafe kernel parameter 'lockless_register_fb' for debugging
problems happening while inside the console lock
- Small miscellaneous fixes & cleanups
- omapdss: add writeback support functions
- Separation of omapfb and omapdrm (see below)
About the separation of omapfb and omapdrm, see
http://permalink.gmane.org/gmane.comp.video.dri.devel/143151
for longer story. The short version:
omapfb and omapdrm have shared low level drivers (omapdss and panel
drivers), making further development of omapdrm difficult. After
these patches omapfb and omapdrm have their own versions of the
drivers, which are more or less direct copies for now but will diverge
soon.
This also means that omapfb (everything under drivers/video/fbdev/omap2/)
is now in maintenance mode, and all new development will be done for
omapdrm (drivers/gpu/drm/omapdrm/)"
* tag 'fbdev-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (49 commits)
video: fbdev: pxafb: fix out of memory error path
drm/omap: make omapdrm select OMAP2_DSS
drm/omap: move omapdss & displays under omapdrm
omapfb: move vrfb into omapfb
omapfb: take omapfb's private omapdss into use
omapfb/displays: change CONFIG_DISPLAY_* to CONFIG_FB_OMAP2_*
omapfb/dss: change CONFIG_OMAP* to CONFIG_FB_OMAP*
omapdss: remove CONFIG_OMAP2_DSS_VENC from omapdss.h
omapfb: copy omapdss & displays for omapfb
omapfb: allow compilation only if DRM_OMAP is disabled
fbdev: omap2: panel-dpi: simplify gpio setting
fbdev: omap2: panel-dpi: in .disable first disable backlight then display
OMAPDSS: DSS: fix a warning message
video: omapdss: delete unneeded of_node_put
OMAPDSS: DISPC: Remove boolean comparisons
OMAPDSS: DSI: cleanup DSI_IRQ_ERROR_MASK define
OMAPDSS: remove extra out == NULL checks
OMAPDSS: change internal dispc functions to static
OMAPDSS: make a two dss feat funcs internal to omapdss
OMAPDSS: remove extra EXPORT_SYMBOLs
This isn't used anywhere, so delete it.
Looks like the last usage (in x86-specific code) was removed by Tejun
in 2011 in commit bd6709a91a59 ("x86, NUMA: Make 32bit use common NUMA
init path").
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
- EVM gains support for loading an x509 cert from the kernel
(EVM_LOAD_X509), into the EVM trusted kernel keyring.
- Smack implements 'file receive' process-based permission checking for
sockets, rather than just depending on inode checks.
- Misc enhancments for TPM & TPM2.
- Cleanups and bugfixes for SELinux, Keys, and IMA.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (41 commits)
selinux: Inode label revalidation performance fix
KEYS: refcount bug fix
ima: ima_write_policy() limit locking
IMA: policy can be updated zero times
selinux: rate-limit netlink message warnings in selinux_nlmsg_perm()
selinux: export validatetrans decisions
gfs2: Invalid security labels of inodes when they go invalid
selinux: Revalidate invalid inode security labels
security: Add hook to invalidate inode security labels
selinux: Add accessor functions for inode->i_security
security: Make inode argument of inode_getsecid non-const
security: Make inode argument of inode_getsecurity non-const
selinux: Remove unused variable in selinux_inode_init_security
keys, trusted: seal with a TPM2 authorization policy
keys, trusted: select hash algorithm for TPM2 chips
keys, trusted: fix: *do not* allow duplicate key options
tpm_ibmvtpm: properly handle interrupted packet receptions
tpm_tis: Tighten IRQ auto-probing
tpm_tis: Refactor the interrupt setup
tpm_tis: Get rid of the duplicate IRQ probing code
Pull audit updates from Paul Moore:
"Seven audit patches for 4.5, all very minor despite the diffstat.
The diffstat churn for linux/audit.h can be attributed to needing to
reshuffle the linux/audit.h header to fix the seccomp auditing issue
(see the commit description for details).
Besides the seccomp/audit fix, most of the fixes are around trying to
improve the connection with the audit daemon and a Kconfig
simplification. Nothing crazy, and everything passes our little
audit-testsuite"
* 'upstream' of git://git.infradead.org/users/pcmoore/audit:
audit: always enable syscall auditing when supported and audit is enabled
audit: force seccomp event logging to honor the audit_enabled flag
audit: Delete unnecessary checks before two function calls
audit: wake up threads if queue switched from limited to unlimited
audit: include auditd's threads in audit_log_start() wait exception
audit: remove audit_backlog_wait_overflow
audit: don't needlessly reset valid wait time
Pull drm updates from Dave Airlie:
"This is the main drm pull request for 4.5. I don't think I've missed
anything too major, I'm mostly back at work now but I'll probably get
some sleep in 5 years time.
Summary:
New drivers:
- etnaviv:
GPU driver for the 3D core on the Vivante core used in numerous
ARM boards.
Highlights:
Core:
- Atomic suspend/resume helpers
- Move the headers to using userspace friendlier types.
- Documentation updates
- Lots of struct_mutex removal.
- Bunch of DP MST fixes from AMD.
Panel:
- More DSI helpers
- Support for some new basic panels
i915:
- Basic Kabylake support
- DP link training and detect code refactoring
- fbc/psr fixes
- FIFO underrun fixes
- SDE interrupt handling fixes
- dma-buf/fence support in pageflip path.
- GPU side for MST audio support
radeon/amdgpu:
- Drop UMS support
- GPUVM/Scheduler optimisations
- Initial Powerplay support for Tonga/Fiji/CZ/ST
- ACP audio prerequisites
nouveau:
- GK20a instmem improvements
- PCIE link speed change support
msm:
- DSI support for msm8960/apq8064
tegra:
- Host1X support for Tegra210 SoC
vc4:
- 3D acceleration support
armada:
- Get rid of struct mutex
tda998x:
- Atomic modesetting support
- TMDS clock limitations
omapdrm:
- improved TILER performance
rockchip:
- RK3036 VOP support
- Synopsys DW MIPI DSI support
exynos:
- Runtime PM support
- of_graph binding for DP panels
- Cleanup of IPP code
- Configurable plane support
- Kernel panic fixes at release time"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (711 commits)
drm/fb_cma_helper: Remove implicit call to disable_unused_functions
drm/amdgpu: add missing irq.h include
drm/vmwgfx: Fix a width / pitch mismatch on framebuffer updates
drm/vmwgfx: Fix an incorrect lock check
drm: nouveau: fix nouveau_debugfs_init prototype
drm/nouveau/pci: fix check in nvkm_pcie_set_link
drm/amdgpu: validate duplicates first
drm/amdgpu: move VM page tables to the LRU end on CS v2
drm/ttm: add ttm_bo_move_to_lru_tail function v2
drm/ttm: fix adding foreign BOs to the swap LRU
drm/ttm: fix adding foreign BOs to the LRU during init v2
drm/radeon: use kobj_to_dev()
drm/amdgpu: use kobj_to_dev()
drm/amdgpu/cz: force vce clocks when sclks are forced
drm/amdgpu/cz: force uvd clocks when sclks are forced
drm/amdgpu/cz: add code to enable forcing VCE clocks
drm/amdgpu/cz: add code to enable forcing UVD clocks
drm/amdgpu: fix lost sync_to if scheduler is enabled.
drm/amd/powerplay: fix static checker warning for return meaningless value.
drm/sysfs: use kobj_to_dev()
git://anongit.freedesktop.org/drm-intel into drm-next
Since your main drm-next pull isn't out of the door yet I figured I might
as well flush out drm-misc instead of delaying for 4.6. It's really just
random stuff all over, biggest thing probably connector_mask tracking from
Maarten.
* tag 'topic/drm-misc-2016-01-17' of git://anongit.freedesktop.org/drm-intel: (24 commits)
drm/i915: Init power domains early in driver load
drm: Do not set connector->encoder in drivers
apple-gmux: Add initial documentation
drm: move MODULE_PARM_DESC to other file
drm/edid: index CEA/HDMI mode tables using the VIC
drm/atomic: Remove drm_atomic_connectors_for_crtc.
drm/i915: Update connector_mask during readout, v2.
drm: Remove opencoded drm_gem_object_release_handle()
drm: Do not set outparam on error during GEM handle allocation
drm/docs: more leftovers from the big vtable documentation pile
drm/atomic-helper: Reject legacy flips on a disabled pipe
drm/atomic: add connector mask to drm_crtc_state.
drm/tegra: Use __drm_atomic_helper_reset_connector for subclassing connector state, v2.
drm/atomic: Add __drm_atomic_helper_connector_reset, v2.
drm/i915: Set connector_state->connector using the helper.
drm: Use a normal idr allocation for the obj->name
drm: Only bump object-reference count when adding first handle
drm: Balance error path for GEM handle allocation
Merge second patch-bomb from Andrew Morton:
- more MM stuff:
- Kirill's page-flags rework
- Kirill's now-allegedly-fixed THP rework
- MADV_FREE implementation
- DAX feature work (msync/fsync). This isn't quite complete but DAX
is new and it's good enough and the guys have a handle on what
needs to be done - I expect this to be wrapped in the next week or
two.
- some vsprintf maintenance work
- various other misc bits
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (145 commits)
printk: change recursion_bug type to bool
lib/vsprintf: factor out %pN[F] handler as netdev_bits()
lib/vsprintf: refactor duplicate code to special_hex_number()
printk-formats.txt: remove unimplemented %pT
printk: help pr_debug and pr_devel to optimize out arguments
lib/test_printf.c: test dentry printing
lib/test_printf.c: add test for large bitmaps
lib/test_printf.c: account for kvasprintf tests
lib/test_printf.c: add a few number() tests
lib/test_printf.c: test precision quirks
lib/test_printf.c: check for out-of-bound writes
lib/test_printf.c: don't BUG
lib/kasprintf.c: add sanity check to kvasprintf
lib/vsprintf.c: warn about too large precisions and field widths
lib/vsprintf.c: help gcc make number() smaller
lib/vsprintf.c: expand field_width to 24 bits
lib/vsprintf.c: eliminate potential race in string()
lib/vsprintf.c: move string() below widen_string()
lib/vsprintf.c: pull out padding code from dentry_name()
printk: do cond_resched() between lines while outputting to consoles
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"Here is the bulk of GPIO changes for v4.5.
Notably there are big refactorings mostly by myself, aimed at getting
the gpio_chip into a shape that makes me believe I can proceed to
preserve state for a proper userspace ABI (character device) that has
already been proposed once, but resulted in the feedback that I need
to go back and restructure stuff. So I've been restructuring stuff.
On the way I ran into brokenness (return code from the get_value()
callback) and had to fix it. Also, refactored generic GPIO to be
simpler.
Some of that is still waiting to trickle down from the subsystems all
over the kernel that provide random gpio_chips, I've touched every
single GPIO driver in the kernel now, oh man I didn't know I was
responsible for so much...
Apart from that we're churning along as usual.
I took some effort to test and retest so it should merge nicely and we
shook out a couple of bugs in -next.
Infrastructural changes:
- In struct gpio_chip, rename the .dev node to .parent to better
reflect the fact that this is not the GPIO struct device
abstraction. We will add that soon so this would be totallt
confusing.
- It was noted that the driver .get_value() callbacks was sometimes
reporting negative -ERR values to the gpiolib core, expecting them
to be propagated to consumer gpiod_get_value() and gpio_get_value()
calls. This was not happening, so as there was a mess of drivers
returning negative errors and some returning "anything else than
zero" to indicate that a line was active. As some would have bit
31 set to indicate "line active" it clashed with negative error
codes. This is fixed by the largeish series clamping values in all
drivers with !!value to [0,1] and then augmenting the code to
propagate error codes to consumers. (Includes some ACKed patches
in other subsystems.)
- Add a void *data pointer to struct gpio_chip. The container_of()
design pattern is indeed very nice, but we want to reform the
struct gpio_chip to be a non-volative, stateless business, and keep
states internal to the gpiolib to be able to hold on to the state
when adding a proper userspace ABI (character device) further down
the road. To achieve this, drivers need a handle at the internal
state that is not dependent on their struct gpio_chip() so we add
gpiochip_add_data() and gpiochip_get_data() following the pattern
of many other subsystems. All the "use gpiochip data pointer"
patches transforms drivers to this scheme.
- The Generic GPIO chip header has been merged into the general
<linux/gpio/driver.h> header, and the custom header for that
removed. Instead of having a separate mm_gpio_chip struct for
these generic drivers, merge that into struct gpio_chip,
simplifying the code and removing the need for separate and
confusing includes.
Misc improvements:
- Stabilize the way GPIOs are looked up from the ACPI legacy
specification.
- Incremental driver features for PXA, PCA953X, Lantiq (patches from
the OpenWRT community), RCAR, Zynq, PL061, 104-idi-48
New drivers:
- Add a GPIO chip to the ALSA SoC AC97 driver.
- Add a new Broadcom NSP SoC driver (this lands in the pinctrl dir,
but the branch is merged here too to account for infrastructural
changes).
- The sx150x driver now supports the sx1502"
* tag 'gpio-v4.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (220 commits)
gpio: generic: make bgpio_pdata always visible
gpiolib: fix chip order in gpio list
gpio: mpc8xxx: Do not use gpiochip_get_data() in mpc8xxx_gpio_save_regs()
gpio: mm-lantiq: Do not use gpiochip_get_data() in ltq_mm_save_regs()
gpio: brcmstb: Allow building driver for BMIPS_GENERIC
gpio: brcmstb: Set endian flags for big-endian MIPS
gpio: moxart: fix build regression
gpio: xilinx: Do not use gpiochip_get_data() in xgpio_save_regs()
leds: pca9532: use gpiochip data pointer
leds: tca6507: use gpiochip data pointer
hid: cp2112: use gpiochip data pointer
bcma: gpio: use gpiochip data pointer
avr32: gpio: use gpiochip data pointer
video: fbdev: via: use gpiochip data pointer
gpio: pch: Optimize pch_gpio_get()
Revert "pinctrl: lantiq: Implement gpio_chip.to_irq"
pinctrl: nsp-gpio: use gpiochip data pointer
pinctrl: vt8500-wmt: use gpiochip data pointer
pinctrl: exynos5440: use gpiochip data pointer
pinctrl: at91-pio4: use gpiochip data pointer
Pull watchdog updates from Wim Van Sebroeck:
"This adds following items:
- watchdog restart handler support
- watchdog reboot notifier support
- watchdog sysfs attributes
- support for the following new devices: AMD Mullins platform, AMD
Carrizo platform, meson8b SoC, CSRatlas7, TS-4800, Alphascale
asm9260-wdt, Zodiac, Sigma Designs SMP86xx/SMP87xx
- Changes in refcounting for the watchdog core
- watchdog core improvements
- and small fixes"
* git://www.linux-watchdog.org/linux-watchdog: (60 commits)
watchdog: asm9260: remove __init and __exit annotations
watchdog: Drop pointer to watchdog device from struct watchdog_device
watchdog: ziirave: Use watchdog infrastructure to create sysfs attributes
watchdog: Add support for creating driver specific sysfs attributes
watchdog: kill unref/ref ops
watchdog: stmp3xxx: Remove unused variables
watchdog: add MT7621 watchdog support
hwmon: (sch56xx) Drop watchdog driver data reference count callbacks
watchdog: da9055_wdt: Drop reference counting
watchdog: da9052_wdt: Drop reference counting
watchdog: Separate and maintain variables based on variable lifetime
watchdog: diag288: Stop re-using watchdog core internal flags
watchdog: Create watchdog device in watchdog_dev.c
watchdog: qcom-wdt: Do not set 'dev' in struct watchdog_device
watchdog: mena21: Do not use device pointer from struct watchdog_device
watchdog: gpio: Do not use device pointer from struct watchdog_device
watchdog: tangox: Print info message using pointer to platform device
watchdog: bcm2835_wdt: Drop log message if watchdog is stopped
devicetree: watchdog: add binding for Sigma Designs SMP8642 watchdog
watchdog: add support for Sigma Designs SMP86xx/SMP87xx
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"We've had quite busy weeks in this cycle. Looking at ALSA core, the
significant changes are a few fixes wrt timer and sequencer ioctls
that have been revealed by fuzzer recently. Other than that, ASoC
core got a few updates about DAI link handling, but these are rather
straightforward refactoring.
In drivers scene, ASoC received quite lots of new drivers in addition
to bunch of updates for still ongoing Intel Skylake support and
topology API. HD-audio gained a new HDMI/DP hotplug notification via
component. FireWire got a pile of code refactoring/updates with
SCS.1x driver integration.
More highlights are shown below.
[ NOTE: this contains also many commits for DRM. This is due to the
pull of drm stable branch into sound tree, as the base of i915 audio
component work for HD-audio. The highlights below don't contain
these DRM changes, as these are supposed to be pulled via drm tree
in anyway sooner or later. ]
Core:
- Handful fixes to harden ALSA timer and sequencer ioctls against
races reported by syzkaller fuzzer
- Irq description string can be unique to each card; only for
HD-audio for now
ASoC:
- Conversion of the array of DAI links to a list for supporting
dynamically adding and removing DAI links
- Topology API enhancements to make everything more component based
and being able to specify PCM links via topology
- Some more fixes for the topology code, though it is still not final
and ready for enabling in production; we really need to get to the
point where that can be done
- A pile of changes for Intel SkyLake drivers which hopefully deliver
some useful initial functionality for systems with this chipset,
though there is more work still to come
- Lots of new features and cleanups for the Renesas drivers
- ANC support for WM5110
- New drivers: Imagination Technologies IPs, Atmel class D speaker,
Cirrus CS47L24 and WM1831, Dialog DA7128, Realtek RT5659 and
RT56156, Rockchip RK3036, TI PC3168A, and AMD ACP
- Rename PCM1792a driver to be generic pcm179x
HD-Audio:
- Use audio component for i915 HDMI/DP hotplug handling
- On-demand binding with i915 driver
- bdl_pos_adj parameter adjustment for Baytrail controllers
- Enable power_save_node for CX20722; this shouldn't lead to
regression, hopefully
- Kabylake HDMI/DP codec support
- Quirks for Lenovo E50-80, Dell Latitude E-series, and other Dell
machines
- A few code refactoring
FireWire:
- Lots of code cleanup and refactoring
- Integrate the support of SCS.1x devices into snd-oxfw driver;
snd-scs1x driver is obsoleted
USB-audio:
- Fix possible NULL dereference at disconnection
- A regression fix for Native Instruments devices
Misc:
- A few code cleanups of fm801 driver"
* tag 'sound-4.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (722 commits)
ALSA: timer: Code cleanup
ALSA: timer: Harden slave timer list handling
ALSA: hda - Add fixup for Dell Latitidue E6540
ALSA: timer: Fix race among timer ioctls
ALSA: hda - add codec support for Kabylake display audio codec
ALSA: timer: Fix double unlink of active_list
ALSA: usb-audio: Fix mixer ctl regression of Native Instrument devices
ALSA: hda - fix the headset mic detection problem for a Dell laptop
ALSA: hda - Fix white noise on Dell Latitude E5550
ALSA: hda_intel: add card number to irq description
ALSA: seq: Fix race at timer setup and close
ALSA: seq: Fix missing NULL check at remove_events ioctl
ALSA: usb-audio: Avoid calling usb_autopm_put_interface() at disconnect
ASoC: hdac_hdmi: remove unused hdac_hdmi_query_pin_connlist
ASoC: AMD: Add missing include file
ALSA: hda - Fixup inverted internal mic for Lenovo E50-80
ALSA: usb: Add native DSD support for Oppo HA-1
ASoC: Make aux_dev more like a generic component
ASoC: bcm2835: cleanup includes by ordering them alphabetically
ASoC: AMD: Manage ACP 2.x SRAM banks power
With several ConnectX-4 cards installed on a server, one may receive
irqn > 255 from the kernel API, which we mistakenly trim to 8bit.
This causes EQ creation failure with the following stack trace:
[<ffffffff812a11f4>] dump_stack+0x48/0x64
[<ffffffff810ace21>] __setup_irq+0x3a1/0x4f0
[<ffffffff810ad7e0>] request_threaded_irq+0x120/0x180
[<ffffffffa0923660>] ? mlx5_eq_int+0x450/0x450 [mlx5_core]
[<ffffffffa0922f64>] mlx5_create_map_eq+0x1e4/0x2b0 [mlx5_core]
[<ffffffffa091de01>] alloc_comp_eqs+0xb1/0x180 [mlx5_core]
[<ffffffffa091ea99>] mlx5_dev_init+0x5e9/0x6e0 [mlx5_core]
[<ffffffffa091ec29>] init_one+0x99/0x1c0 [mlx5_core]
[<ffffffff812e2afc>] local_pci_probe+0x4c/0xa0
Fixing it by changing of the irqn type from u8 to unsigned int to
support values > 255
Fixes: 61d0e73e0a5a ('net/mlx5_core: Use the the real irqn in eq->irqn')
Reported-by: Jiri Pirko <jiri@mellanox.com>
Signed-off-by: Doron Tsur <doront@mellanox.com>
Signed-off-by: Matan Barak <matanb@mellanox.com>
In file included from net/ipv4/tcp_ipv4.c:77 (and many more):
include/net/tcp_memcontrol.h:5: warning: ‘struct cgroup_subsys’ declared inside parameter list
include/net/tcp_memcontrol.h:5: warning: its scope is only this definition or declaration, which is probably not what you want
Add forward declarations for all used structures to fix this.
Currently, pr_debug and pr_devel will not elide function call arguments
appearing in calls to the no_printk for these macros. This is because
all side effects must be honored before proceeding to the 0-value
assignment in no_printk.
The behavior is contrary to documentation found in the CodingStyle and
the header file where these functions are declared.
This patch corrects that behavior by shunting out the call to no_printk
completely. The format string is still checked by gcc for correctness,
but no code seems to be emitted in common cases.
[akpm@linux-foundation.org: remove braces, per Joe]
Fixes: 5264f2f75d86 ("include/linux/printk.h: use and neaten no_printk")
Signed-off-by: Aaron Conole <aconole@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Jason Baron <jbaron@akamai.com>
@console_may_schedule tracks whether console_sem was acquired through
lock or trylock. If the former, we're inside a sleepable context and
console_conditional_schedule() performs cond_resched(). This allows
console drivers which use console_lock for synchronization to yield
while performing time-consuming operations such as scrolling.
However, the actual console outputting is performed while holding
irq-safe logbuf_lock, so console_unlock() clears @console_may_schedule
before starting outputting lines. Also, only a few drivers call
console_conditional_schedule() to begin with. This means that when a
lot of lines need to be output by console_unlock(), for example on a
console registration, the task doing console_unlock() may not yield for
a long time on a non-preemptible kernel.
If this happens with a slow console devices, for example a serial
console, the outputting task may occupy the cpu for a very long time.
Long enough to trigger softlockup and/or RCU stall warnings, which in
turn pile more messages, sometimes enough to trigger the next cycle of
warnings incapacitating the system.
Fix it by making console_unlock() insert cond_resched() between lines if
@console_may_schedule.
Reported-by: Calvin Owens <calvinowens@fb.com>
Acked-by: Jan Kara <jack@suse.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Kyle McMartin <kyle@kernel.org>
Cc: <stable@vger.kernel.org>
Add a helper to check if an object (given an address and a size) is part
of a section (given beginning and end addresses). For convenience, also
provide a helper that performs this check for __init data using the
__init_begin and __init_end limits.
Signed-off-by: Thierry Reding <treding@nvidia.com>
IS_ERR_VALUE() already contains it and so we need to add this only to
the !ptr check. That will allow users of IS_ERR_OR_NULL(), to not add
this compiler flag.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
As all new_valid_dev() checks have been removed it's time to drop
new_valid_dev() itself.
No functional change.
Signed-off-by: Yaowei Bai <baiyaowei@cmss.chinamobile.com>
Rewrite abs() so that its return type does not depend on the
architecture and no unexpected type conversion happen inside of it. The
only conversion is from unsigned to signed type. char is left as a
return type but treated as a signed type regradless of it's actual
signedness.
With the old version, int arguments were promoted to long and depending
on architecture a long argument might result in s64 or long return type
(which may or may not be the same).
This came after some back and forth with Nicolas. The current macro has
different return type (for the same input type) depending on
architecture which might be midly iritating.
An alternative version would promote to int like so:
#define abs(x) __abs_choose_expr(x, long long, \
__abs_choose_expr(x, long, \
__builtin_choose_expr( \
sizeof(x) <= sizeof(int), \
({ int __x = (x); __x<0?-__x:__x; }), \
((void)0))))
I have no preference but imagine Linus might. :] Nicolas argument against
is that promoting to int causes iconsistent behaviour:
int main(void) {
unsigned short a = 0, b = 1, c = a - b;
unsigned short d = abs(a - b);
unsigned short e = abs(c);
printf("%u %u\n", d, e); // prints: 1 65535
Then again, no sane person expects consistent behaviour from C integer
arithmetic. ;)
Note:
__builtin_types_compatible_p(unsigned char, char) is always false, and
__builtin_types_compatible_p(signed char, char) is also always false.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Cc: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Cc: Wey-Yi Guy <wey-yi.w.guy@intel.com>
TIMER_ENTRY_STATIC and TAIL_MAPPING are defined as poison pointers which
should point to nowhere. Redefine them using POISON_POINTER_DELTA
arithmetics to make sure they really point to non-mappable area declared
by the target architecture.
Signed-off-by: Vasily Kulikov <segoon@openwall.com>
Cc: Solar Designer <solar@openwall.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk framework updates from Michael Turquette:
"The clk framework and driver changes for 4.5 look pretty typical. The
bulk of the changes are to clk controller drivers, though some
improvements to the core and some re-usable blocks/templates also
received some love.
In this past cycle the clk maintainers developed a good workflow for
handling the common case of patch submissions containing a new
drivers, new shared Device Tree header and a new Device Tree binding
description. This requires coordination with the Device Tree
maintainers and with the architecture maintainers (typically the
arm-soc tree in our case).
This explains the increase in changes to include/dt-bindings/... and
to Documentation/devicetree/bindings/clock/... coming from the clk
tree. The same commits can be expected to come through those trees on
occasion, through the use of shared, immutable branches"
* tag 'clk-for-linus-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (125 commits)
clk: remove duplicated COMMON_CLK_NXP record from clk/Kconfig
clk: fix clk-gpio.c with optional clock= DT property
clk: rockchip: fix section mismatches with new child-clocks
clk: gpio: handle error codes for of_clk_get_parent_count()
clk: gpio: fix memory leak
clk: shmobile: r8a7795: Add SATA0 clock
clk: bcm2835: Add PWM clock support
clk: bcm2835: Support for clock parent selection
clk: bcm2835: add a round up ability to the clock divisor
clk: lpc32xx: add common clock framework driver
clk: lpc18xx: add NXP specific COMMON_CLK_NXP configuration symbol
dt-bindings: clock: add NXP LPC32xx clock list for consumers
dt-bindings: clock: add description of LPC32xx USB clock controller
dt-bindings: clock: add description of LPC32xx clock controller
clk: rockchip: rk3036: include downstream muxes into fractional dividers
clk: add flag for clocks that need to be enabled on rate changes
clk: rockchip: Allow the RK3288 SPDIF clocks to change their parent
clk: rockchip: include downstream muxes into fractional dividers
clk: rockchip: handle mux dependency of fractional dividers
clk: bcm2835: Add a driver for the auxiliary peripheral clock gates.
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull dmi updates from Jean Delvare.
* 'dmi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
firmware: dmi_scan: Save SMBIOS Type 9 System Slots
firmware: dmi_scan: Fix dmi_find_device description
firmware: dmi_scan: Clarify dmi_save_extended_devices
firmware: dmi_scan: Optimize dmi_save_extended_devices
Since can_do_mlock only return 1 or 0, so make it boolean.
[akpm@linux-foundation.org: update declaration in mm.h]
Signed-off-by: Wang Xiaoqiang <wangxq10@lzu.edu.cn>
allmodconfig produces following warning for me:
WARNING: vmlinux.o(.text.unlikely+0x10314): Section mismatch in reference from the function movable_node_is_enabled() to the variable .meminit.data:movable_node_enabled
The function movable_node_is_enabled() references
the variable __meminitdata movable_node_enabled.
This is often because movable_node_is_enabled lacks a __meminitdata
annotation or the annotation of movable_node_enabled is wrong.
Let's mark the function with __meminit. It fixes the warning.
During Jason's work with postcopy migration support for s390 a problem
regarding gmap faults was discovered.
The gmap code will call fixup_user_fault which will end up always in
handle_mm_fault. Till now we never cared about retries, but as the
userfaultfd code kind of relies on it. this needs some fix.
This patchset does not take care of the futex code. I will now look
closer at this.
This patch (of 2):
With the introduction of userfaultfd, kvm on s390 needs fixup_user_fault
to pass in FAULT_FLAG_ALLOW_RETRY and give feedback if during the
faulting we ever unlocked mmap_sem.
This patch brings in the logic to handle retries as well as it cleans up
the current documentation. fixup_user_fault was not having the same
semantics as filemap_fault. It never indicated if a retry happened and
so a caller wasn't able to handle that case. So we now changed the
behaviour to always retry a locked mmap_sem.
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: "Jason J. Herne" <jjherne@linux.vnet.ibm.com>
Cc: Eric B Munson <emunson@akamai.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Dominik Dingel <dingel@linux.vnet.ibm.com>
A dax mapping establishes a pte with _PAGE_DEVMAP set when the driver
has established a devm_memremap_pages() mapping, i.e. when the pfn_t
return from ->direct_access() has PFN_DEV and PFN_MAP set. Later, when
encountering _PAGE_DEVMAP during a page table walk we lookup and pin a
struct dev_pagemap instance to keep the result of pfn_to_page() valid
until put_page().
Tested-by: Logan Gunthorpe <logang@deltatee.com>
Cc: Dave Hansen <dave@sr71.net>
A dax-huge-page mapping while it uses some thp helpers is ultimately not
a transparent huge page. The distinction is especially important in the
get_user_pages() path. pmd_devmap() is used to distinguish dax-pmds
from pmd_huge() and pmd_trans_huge() which have slightly different
semantics.
Explicitly mark the pmd_trans_huge() helpers that dax needs by adding
pmd_devmap() checks.
[kirill.shutemov@linux.intel.com: fix regression in handling mlocked pages in __split_huge_pmd()]
Cc: Matthew Wilcox <willy@linux.intel.com>
