Allow an application to query the memories allowed by its context.
Updated numa_memory_policy.txt to mention that applications can use this to
obtain allowed memories for constructing valid policies.
TODO: update out-of-tree libnuma wrapper[s], or maybe add a new
wrapper--e.g., numa_get_mems_allowed() ?
Also, update numa syscall man pages.
Tested with memtoy V>=0.13.
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Acked-by: Christoph Lameter <clameter@sgi.com>
Cc: Andi Kleen <ak@suse.de>
Move the definitions of struct mm_struct and struct vma_area_struct to
include/mm_types.h. This allows to define more function in asm/pgtable.h
and friends with inline assemblies instead of macros. Compile tested on
i386, powerpc, powerpc64, s390-32, s390-64 and x86_64.
[aurelien@aurel32.net: build fix]
Signed-off-by: Aurelien Jarno <aurelien@aurel32.net>
Rather than sign direct radix-tree pointers with a special bit, sign the
indirect one that hangs off the root. This means that, given a lookup_slot
operation, the invalid result will be differentiated from the valid
(previously, valid results could have the bit either set or clear).
This does not affect slot lookups which occur under lock -- they can never
return an invalid result. Is needed in future for lockless pagecache.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Hugh Dickins <hugh@veritas.com>
The commit b5810039a54e5babf428e9a1e89fc1940fabff11 contains the note
A last caveat: the ZERO_PAGE is now refcounted and managed with rmap
(and thus mapcounted and count towards shared rss). These writes to
the struct page could cause excessive cacheline bouncing on big
systems. There are a number of ways this could be addressed if it is
an issue.
And indeed this cacheline bouncing has shown up on large SGI systems.
There was a situation where an Altix system was essentially livelocked
tearing down ZERO_PAGE pagetables when an HPC app aborted during startup.
This situation can be avoided in userspace, but it does highlight the
potential scalability problem with refcounting ZERO_PAGE, and corner
cases where it can really hurt (we don't want the system to livelock!).
There are several broad ways to fix this problem:
1. add back some special casing to avoid refcounting ZERO_PAGE
2. per-node or per-cpu ZERO_PAGES
3. remove the ZERO_PAGE completely
I will argue for 3. The others should also fix the problem, but they
result in more complex code than does 3, with little or no real benefit
that I can see.
Why? Inserting a ZERO_PAGE for anonymous read faults appears to be a
false optimisation: if an application is performance critical, it would
not be doing many read faults of new memory, or at least it could be
expected to write to that memory soon afterwards. If cache or memory use
is critical, it should not be working with a significant number of
ZERO_PAGEs anyway (a more compact representation of zeroes should be
used).
As a sanity check -- mesuring on my desktop system, there are never many
mappings to the ZERO_PAGE (eg. 2 or 3), thus memory usage here should not
increase much without it.
When running a make -j4 kernel compile on my dual core system, there are
about 1,000 mappings to the ZERO_PAGE created per second, but about 1,000
ZERO_PAGE COW faults per second (less than 1 ZERO_PAGE mapping per second
is torn down without being COWed). So removing ZERO_PAGE will save 1,000
page faults per second when running kbuild, while keeping it only saves
less than 1 page clearing operation per second. 1 page clear is cheaper
than a thousand faults, presumably, so there isn't an obvious loss.
Neither the logical argument nor these basic tests give a guarantee of no
regressions. However, this is a reasonable opportunity to try to remove
the ZERO_PAGE from the pagefault path. If it is found to cause regressions,
we can reintroduce it and just avoid refcounting it.
The /dev/zero ZERO_PAGE usage and TLB tricks also get nuked. I don't see
much use to them except on benchmarks. All other users of ZERO_PAGE are
converted just to use ZERO_PAGE(0) for simplicity. We can look at
replacing them all and maybe ripping out ZERO_PAGE completely when we are
more satisfied with this solution.
Signed-off-by: Linus "snif" Torvalds <torvalds@linux-foundation.org>
This gets rid of all kmalloc caches larger than page size. A kmalloc
request larger than PAGE_SIZE > 2 is going to be passed through to the page
allocator. This works both inline where we will call __get_free_pages
instead of kmem_cache_alloc and in __kmalloc.
kfree is modified to check if the object is in a slab page. If not then
the page is freed via the page allocator instead. Roughly similar to what
SLOB does.
Advantages:
- Reduces memory overhead for kmalloc array
- Large kmalloc operations are faster since they do not
need to pass through the slab allocator to get to the
page allocator.
- Performance increase of 10%-20% on alloc and 50% on free for
PAGE_SIZEd allocations.
SLUB must call page allocator for each alloc anyways since
the higher order pages which that allowed avoiding the page alloc calls
are not available in a reliable way anymore. So we are basically removing
useless slab allocator overhead.
- Large kmallocs yields page aligned object which is what
SLAB did. Bad things like using page sized kmalloc allocations to
stand in for page allocate allocs can be transparently handled and are not
distinguishable from page allocator uses.
- Checking for too large objects can be removed since
it is done by the page allocator.
Drawbacks:
- No accounting for large kmalloc slab allocations anymore
- No debugging of large kmalloc slab allocations.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Convert some 'unsigned long' to pgoff_t.
Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn>
Remove VM_MAX_CACHE_HIT, MAX_RA_PAGES and MIN_RA_PAGES.
Introduce radix_tree_next_hole(root, index, max_scan) to scan radix tree for
the first hole. It will be used in interleaved readahead.
The implementation is dumb and obviously correct. It can help debug(and
document) the possible smart one in future.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Combine the file_ra_state members
unsigned long prev_index
unsigned int prev_offset
into
loff_t prev_pos
It is more consistent and better supports huge files.
Thanks to Peter for the nice proposal!
[akpm@linux-foundation.org: fix shift overflow]
Fold file_ra_state.mmap_hit into file_ra_state.mmap_miss and make it an int.
Use 'unsigned int' instead of 'unsigned long' for readahead sizes.
This helps reduce memory consumption on 64bit CPU when a lot of files are
opened.
CC: Andi Kleen <andi@firstfloor.org>
This patch cleans up duplicate includes in
include/linux/memory_hotplug.h
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Enable virtual memmap support for SPARSEMEM on PPC64 systems. Slice a 16th
off the end of the linear mapping space and use that to hold the vmemmap.
Uses the same size mapping as uses in the linear 1:1 kernel mapping.
[pbadari@gmail.com: fix warning]
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Cc: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
[apw@shadowen.org: style fixups]
[apw@shadowen.org: vmemmap sparc64: convert to new config options]
Equip IA64 sparsemem with a virtual memmap. This is similar to the existing
CONFIG_VIRTUAL_MEM_MAP functionality for DISCONTIGMEM. It uses a PAGE_SIZE
mapping.
This is provided as a minimally intrusive solution. We split the 128TB
VMALLOC area into two 64TB areas and use one for the virtual memmap.
This should replace CONFIG_VIRTUAL_MEM_MAP long term.
[apw@shadowen.org: convert to new helper based initialisation]
Cc: "Luck, Tony" <tony.luck@intel.com>
x86_64 uses 2M page table entries to map its 1-1 kernel space. We also
implement the virtual memmap using 2M page table entries. So there is no
additional runtime overhead over FLATMEM, initialisation is slightly more
complex. As FLATMEM still references memory to obtain the mem_map pointer and
SPARSEMEM_VMEMMAP uses a compile time constant, SPARSEMEM_VMEMMAP should be
superior.
With this SPARSEMEM becomes the most efficient way of handling virt_to_page,
pfn_to_page and friends for UP, SMP and NUMA on x86_64.
[apw@shadowen.org: code resplit, style fixups]
[apw@shadowen.org: vmemmap x86_64: ensure end of section memmap is initialised]
Convert the common vmemmap population into initialisation helpers for use by
architecture vmemmap populators. All architecture implementing the
SPARSEMEM_VMEMMAP variant supply an architecture specific vmemmap_populate()
initialiser, which may make use of the helpers.
This allows us to clean up and remove the initialisation Kconfig entries.
With this patch there is a single SPARSEMEM_VMEMMAP_ENABLE Kconfig option to
indicate use of that variant.
SPARSEMEM is a pretty nice framework that unifies quite a bit of code over all
the arches. It would be great if it could be the default so that we can get
rid of various forms of DISCONTIG and other variations on memory maps. So far
what has hindered this are the additional lookups that SPARSEMEM introduces
for virt_to_page and page_address. This goes so far that the code to do this
has to be kept in a separate function and cannot be used inline.
This patch introduces a virtual memmap mode for SPARSEMEM, in which the memmap
is mapped into a virtually contigious area, only the active sections are
physically backed. This allows virt_to_page page_address and cohorts become
simple shift/add operations. No page flag fields, no table lookups, nothing
involving memory is required.
The two key operations pfn_to_page and page_to_page become:
#define __pfn_to_page(pfn) (vmemmap + (pfn))
#define __page_to_pfn(page) ((page) - vmemmap)
By having a virtual mapping for the memmap we allow simple access without
wasting physical memory. As kernel memory is typically already mapped 1:1
this introduces no additional overhead. The virtual mapping must be big
enough to allow a struct page to be allocated and mapped for all valid
physical pages. This vill make a virtual memmap difficult to use on 32 bit
platforms that support 36 address bits.
However, if there is enough virtual space available and the arch already maps
its 1-1 kernel space using TLBs (f.e. true of IA64 and x86_64) then this
technique makes SPARSEMEM lookups even more efficient than CONFIG_FLATMEM.
FLATMEM needs to read the contents of the mem_map variable to get the start of
the memmap and then add the offset to the required entry. vmemmap is a
constant to which we can simply add the offset.
This patch has the potential to allow us to make SPARSMEM the default (and
even the only) option for most systems. It should be optimal on UP, SMP and
NUMA on most platforms. Then we may even be able to remove the other memory
models: FLATMEM, DISCONTIG etc.
[apw@shadowen.org: config cleanups, resplit code etc]
[kamezawa.hiroyu@jp.fujitsu.com: Fix sparsemem_vmemmap init]
[apw@shadowen.org: vmemmap: remove excess debugging]
[apw@shadowen.org: simplify initialisation code and reduce duplication]
[apw@shadowen.org: pull out the vmemmap code into its own file]
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
We have flags to indicate whether a section actually has a valid mem_map
associated with it. This is never set and we rely solely on the present bit
to indicate a section is valid. By definition a section is not valid if it
has no mem_map and there is a window during init where the present bit is set
but there is no mem_map, during which pfn_valid() will return true
incorrectly.
Use the existing SECTION_HAS_MEM_MAP flag to indicate the presence of a valid
mem_map. Switch valid_section{,_nr} and pfn_valid() to this bit. Add a new
present_section{,_nr} and pfn_present() interfaces for those users who care to
know that a section is going to be valid.
[akpm@linux-foundation.org: coding-syle fixes]
x86(-64) are the last architectures still using the page fault notifier
cruft for the kprobes page fault hook. This patch converts them to the
proper direct calls, and removes the now unused pagefault notifier bits
aswell as the cruft in kprobes.c that was related to this mess.
I know Andi didn't really like this, but all other architecture maintainers
agreed the direct calls are much better and besides the obvious cruft
removal a common way of dealing with kprobes across architectures is
important aswell.
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: fix sparc64]
Cc: <linux-arch@vger.kernel.org>
Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Convert cpu_sibling_map from a static array sized by NR_CPUS to a per_cpu
variable. This saves sizeof(cpumask_t) * NR unused cpus. Access is mostly
from startup and CPU HOTPLUG functions.
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com>
This is from an earlier message from 'Christoph Lameter':
cpu_core_map is currently an array defined using NR_CPUS. This means that
we overallocate since we will rarely really use maximum configured cpu.
If we put the cpu_core_map into the per cpu area then it will be allocated
for each processor as it comes online.
This means that the core map cannot be accessed until the per cpu area
has been allocated. Xen does a weird thing here looping over all processors
and zeroing the masks that are not yet allocated and that will be zeroed
when they are allocated. I commented the code out.
Enable wakeup from serial ports, make it run-time configurable over sysfs,
e.g.,
echo enabled > /sys/devices/platform/serial8250.0/tty/ttyS0/power/wakeup
Requires
# CONFIG_SYSFS_DEPRECATED is not set
Following suggestions from Alan and Russell moved the may_wake_up checks
to serial_core.c. This time actually tested - it does even work. Could
someone, please, verify, that put_device after device_find_child is
correct?
Also would be nice to test with a Natsemi UART, that can wake up the system,
if such systems exist.
For this you just have to apply the patch below, issue the above "echo"
command to one of your Natsemi port, suspend and resume your system, and
verify that your Natsemi port still works. If you are actually capable of
waking up the system from that port, would be nice to test that as well.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Greg KH <greg@kroah.com>
Provide {enable,disable}_irq_wakeup dummies for undefined
cross-compilers for platforms without CONFIG_GENERIC_IRQ.
Needed by wake-up-from-a-serial-port.patch
Add support for a whole range of boards. Some are partly autodetected but
not fully correctly others (PCI Express notably) not at all. Stick all
the right entries in.
Thanks to Mainpine for information and testing.
Signed-off-by: Alan Cox <alan@redhat.com>
Most non cardbus devices can't do dma, so flag them as such in the device
creation routine.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Cc: Tejun Heo <htejun@gmail.com>
Cc: Natalie Protasevich <protasnb@gmail.com>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Some devices are incapable of DMA and need to be recognised as such.
Introduce a NONE dma mask to facilitate this plus an inline function:
is_device_dma_capable() to check this.
Only a few definitions is in xxs1500.h .
They can be move to au1000_xxs1500.c .
[m.kozlowski@tuxland.pl: fix unbalanced parenthesis]
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
I need __INIT_REFOK to fix a MODPOST warning for a few MIPS configs which
have to call init code from .text very early in the game due to bootloader
issues. __INITDATA_REFOK is just for consistency.
Optionally add a boot delay after each kernel printk() call, crudely
measured in milliseconds, with a maximum delay of 10 seconds per printk.
Enable CONFIG_BOOT_PRINTK_DELAY=y and then add (e.g.):
"lpj=loops_per_jiffy boot_delay=100"
to the kernel command line.
It has been useful in cases like "during boot, my machine just reboots or the
screen goes black" by slowing down printk, (and adding initcall_debug), we can
usually see the last thing that happened before the lights went out which is
usually a valuable clue.
[akpm@linux-foundation.org: not all architectures implement CONFIG_HZ]
[akpm@linux-foundation.org: fix lots of stuff]
[bunk@stusta.de: kernel/printk.c: make 2 variables static]
[heiko.carstens@de.ibm.com: fix slow down printk on boot compile error]
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Dave Jones <davej@redhat.com>
Fix filesystems docbook warnings.
Warning(linux-2.6.23-git8//fs/debugfs/file.c:241): No description found for parameter 'name'
Warning(linux-2.6.23-git8//fs/debugfs/file.c:241): No description found for parameter 'mode'
Warning(linux-2.6.23-git8//fs/debugfs/file.c:241): No description found for parameter 'parent'
Warning(linux-2.6.23-git8//fs/debugfs/file.c:241): No description found for parameter 'value'
Warning(linux-2.6.23-git8//include/linux/jbd.h:404): No description found for parameter 'h_lockdep_map'
Fix USB docbook warnings.
Warning(linux-2.6.23-git8//include/linux/usb/gadget.h:487): No description found for parameter 'g'
Warning(linux-2.6.23-git8//include/linux/usb/gadget.h:506): No description found for parameter 'g'
Warning(linux-2.6.23-git8//drivers/usb/core/hub.c:1416): No description found for parameter 'usb_dev'
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (95 commits)
[ARM] 4578/1: CM-x270: PCMCIA support
[ARM] 4577/1: ITE 8152 PCI bridge support
[ARM] 4576/1: CM-X270 machine support
[ARM] pxa: Avoid pxa_gpio_mode() in gpio_direction_{in,out}put()
[ARM] pxa: move pxa_set_mode() from pxa2xx_mainstone.c to mainstone.c
[ARM] pxa: move pxa_set_mode() from pxa2xx_lubbock.c to lubbock.c
[ARM] pxa: Make cpu_is_pxaXXX dependent on configuration symbols
[ARM] pxa: PXA3xx base support
[NET] smc91x: fix PXA DMA support code
[SERIAL] Fix console initialisation ordering
[ARM] pxa: tidy up arch/arm/mach-pxa/Makefile
[ARM] Update arch/arm/Kconfig for drivers/Kconfig changes
[ARM] 4600/1: fix kernel build failure with build-id-supporting binutils
[ARM] 4599/1: Preserve ATAG list for use with kexec (2.6.23)
[ARM] Rename consistent_sync() as dma_cache_maint()
[ARM] 4572/1: ep93xx: add cirrus logic edb9307 support
[ARM] 4596/1: S3C2412: Correct IRQs for SDI+CF and add decoding support
[ARM] 4595/1: ns9xxx: define registers as void __iomem * instead of volatile u32
[ARM] 4594/1: ns9xxx: use the new gpio functions
[ARM] 4593/1: ns9xxx: implement generic clockevents
* 'locks' of git://linux-nfs.org/~bfields/linux:
nfsd: remove IS_ISMNDLCK macro
Rework /proc/locks via seq_files and seq_list helpers
fs/locks.c: use list_for_each_entry() instead of list_for_each()
NFS: clean up explicit check for mandatory locks
AFS: clean up explicit check for mandatory locks
9PFS: clean up explicit check for mandatory locks
GFS2: clean up explicit check for mandatory locks
Cleanup macros for distinguishing mandatory locks
Documentation: move locks.txt in filesystems/
locks: add warning about mandatory locking races
Documentation: move mandatory locking documentation to filesystems/
locks: Fix potential OOPS in generic_setlease()
Use list_first_entry in locks_wake_up_blocks
locks: fix flock_lock_file() comment
Memory shortage can result in inconsistent flocks state
locks: kill redundant local variable
locks: reverse order of posix_locks_conflict() arguments
ssh://master.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of ssh://master.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] build fix for scatterlist
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits)
[IPV6]: Consolidate the ip6_pol_route_(input|output) pair
[TCP]: Make snd_cwnd_cnt 32-bit
[TCP]: Update the /proc/net/tcp documentation
[NETNS]: Don't panic on creating the namespace's loopback
[NEIGH]: Ensure that pneigh_lookup is protected with RTNL
[INET]: kmalloc+memset -> kzalloc in frag_alloc_queue
[ISDN]: Fix compile with CONFIG_ISDN_X25 disabled.
[IPV6]: Replace sk_buff ** with sk_buff * in input handlers
[SELINUX]: Update for netfilter ->hook() arg changes.
[INET]: Consolidate the xxx_put
[INET]: Small cleanup for xxx_put after evictor consolidation
[INET]: Consolidate the xxx_evictor
[INET]: Consolidate the xxx_frag_destroy
[INET]: Consolidate xxx_the secret_rebuild
[INET]: Consolidate the xxx_frag_kill
[INET]: Collect common frag sysctl variables together
[INET]: Collect frag queues management objects together
[INET]: Move common fields from frag_queues in one place.
[TG3]: Fix performance regression on 5705.
[ISDN]: Remove local copy of device name to make sure renames work.
include/scsi/scsi_eh.h:79: error: field `sense_sgl' has incomplete type
x86 resolves this by including scatterlist.h from dma-mapping.h which
seems as good a place as any.
Signed-off-by: Tony Luck <tony.luck@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits)
Input: use full RCU API
Input: remove tsdev interface
Input: add support for Blackfin BF54x Keypad controller
Input: appletouch - another fix for idle reset logic
HWMON: hdaps - switch to using input-polldev
Input: add support for SEGA Dreamcast keyboard
Input: omap-keyboard - don't pretend we support changing keymap
Input: lifebook - fix X and Y axis range
Input: usbtouchscreen - add support for GeneralTouch devices
Input: fix open count handling in input interfaces
Input: keyboard - add CapsShift lock
Input: adbhid - produce all CapsLock key events
Input: ALPS - add signature for ThinkPad R61
Input: jornada720_kbd - send MSC_SCAN events
Input: add support for the HP Jornada 7xx (710/720/728) touchscreen
Input: add support for HP Jornada 7xx onboard keyboard
Input: add support for HP Jornada onboard keyboard (HP6XX)
Input: ucb1400_ts - use schedule_timeout_uninterruptible
Input: xpad - fix dependancy on LEDS class
Input: auto-select INPUT for MAC_EMUMOUSEBTN option
Resolved conflicts manually in drivers/hwmon/applesmc.c: converting from
a class device to a device and converting to use input-polldev created a
few apparently trivial clashes..
Very little point of having 32-bit snd_cnwd if this is not
32-bit as well, as a number of snd_cwnd incrementation formulas
assume that snd_cwnd_cnt can be at least as large as snd_cwnd.
Whether 32-bit is useful was discussed when e0ef57cc56c3c96
was made:
http://marc.info/?l=linux-netdev&m=117218144409825&w=2
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
With all the users of the double pointers removed from the IPv6 input path,
this patch converts all occurances of sk_buff ** to sk_buff * in IPv6 input
handlers.
These ones use the generic data types too, so move
them in one place.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
The evictors collect some statistics for ipv4 and ipv6,
so make it return the number of evicted queues and account
them all at once in the caller.
The XXX_ADD_STATS_BH() macros are just for this case,
but maybe there are places in code, that can make use of
them as well.
To make in possible we need to know the exact frag queue
size for inet_frags->mem management and two callbacks:
* to destoy the skb (optional, used in conntracks only)
* to free the queue itself (mandatory, but later I plan to
move the allocation and the destruction of frag_queues
into the common place, so this callback will most likely
be optional too).
This code works with the generic data types as well, so
move this into inet_fragment.c
This move makes it possible to hide the secret_timer
management and the secret_rebuild routine completely in
the inet_fragment.c
Introduce the ->hashfn() callback in inet_frags() to get
the hashfun for a given inet_frag_queue() object.
Since now all the xxx_frag_kill functions now work
with the generic inet_frag_queue data type, this can
be moved into a common place.
The xxx_unlink() code is moved as well.
Some sysctl variables are used to tune the frag queues
management and it will be useful to work with them in
a common way in the future, so move them into one
structure, moreover they are the same for all the frag
management codes.
I don't place them in the existing inet_frags object,
introduced in the previous patch for two reasons:
1. to keep them in the __read_mostly section;
2. not to export the whole inet_frags objects outside.
There are some objects that are common in all the places
which are used to keep track of frag queues, they are:
* hash table
* LRU list
* rw lock
* rnd number for hash function
* the number of queues
* the amount of memory occupied by queues
* secret timer
Move all this stuff into one structure (struct inet_frags)
to make it possible use them uniformly in the future. Like
with the previous patch this mostly consists of hunks like
- write_lock(&ipfrag_lock);
+ write_lock(&ip4_frags.lock);
To address the issue with exporting the number of queues and
the amount of memory occupied by queues outside the .c file
they are declared in, I introduce a couple of helpers.
Introduce the struct inet_frag_queue in include/net/inet_frag.h
file and place there all the common fields from three structs:
* struct ipq in ipv4/ip_fragment.c
* struct nf_ct_frag6_queue in nf_conntrack_reasm.c
* struct frag_queue in ipv6/reassembly.c
After this, replace these fields on appropriate structures with
this structure instance and fix the users to use correct names
i.e. hunks like
- atomic_dec(&fq->refcnt);
+ atomic_dec(&fq->q.refcnt);
(these occupy most of the patch)
Signed-off-by: Karsten Keil <kkeil@suse.de>
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
