path: root/include
2014-10-09Merge tag 'pci-v3.18-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "The interesting things here are: - Turn on Config Request Retry Status Software Visibility. This caused hangs last time, but we included a fix this time. - Rework PCI device configuration to use _HPP/_HPX more aggressively - Allow PCI devices to be put into D3cold during system suspend - Add arm64 PCI support - Add APM X-Gene host bridge driver - Add TI Keystone host bridge driver - Add Xilinx AXI host bridge driver More detailed summary: Enumeration - Check Vendor ID only for Config Request Retry Status (Rajat Jain) - Enable Config Request Retry Status when supported (Rajat Jain) - Add generic domain handling (Catalin Marinas) - Generate uppercase hex for modalias interface class (Ricardo Ribalda Delgado) Resource management - Add missing MEM_64 mask in pci_assign_unassigned_bridge_resources() (Yinghai Lu) - Increase IBM ipr SAS Crocodile BARs to at least system page size (Douglas Lehr) PCI device hotplug - Prevent NULL dereference during pciehp probe (Andreas Noever) - Move _HPP & _HPX handling into core (Bjorn Helgaas) - Apply _HPP to PCIe devices as well as PCI (Bjorn Helgaas) - Apply _HPP/_HPX to display devices (Bjorn Helgaas) - Preserve SERR & PARITY settings when applying _HPP/_HPX (Bjorn Helgaas) - Preserve MPS and MRRS settings when applying _HPP/_HPX (Bjorn Helgaas) - Apply _HPP/_HPX to all devices, not just hot-added ones (Bjorn Helgaas) - Fix wait time in pciehp timeout message (Yinghai Lu) - Add more pciehp Slot Control debug output (Yinghai Lu) - Stop disabling pciehp notifications during init (Yinghai Lu) MSI - Remove arch_msi_check_device() (Alexander Gordeev) - Rename pci_msi_check_device() to pci_msi_supported() (Alexander Gordeev) - Move D0 check into pci_msi_check_device() (Alexander Gordeev) - Remove unused kobject from struct msi_desc (Yijing Wang) - Remove "pos" from the struct msi_desc msi_attrib (Yijing Wang) - Add "msi_bus" sysfs MSI/MSI-X control for endpoints (Yijing Wang) - Use __get_cached_msi_msg() instead of get_cached_msi_msg() (Yijing Wang) - Use __read_msi_msg() instead of read_msi_msg() (Yijing Wang) - Use __write_msi_msg() instead of write_msi_msg() (Yijing Wang) Power management - Drop unused runtime PM support code for PCIe ports (Rafael J. Wysocki) - Allow PCI devices to be put into D3cold during system suspend (Rafael J. Wysocki) AER - Add additional AER error strings (Gong Chen) - Make <linux/aer.h> standalone includable (Thierry Reding) Virtualization - Add ACS quirk for Solarflare SFC9120 & SFC9140 (Alex Williamson) - Add ACS quirk for Intel 10G NICs (Alex Williamson) - Add ACS quirk for AMD A88X southbridge (Marti Raudsepp) - Remove unused pci_find_upstream_pcie_bridge(), pci_get_dma_source() (Alex Williamson) - Add device flag helpers (Ethan Zhao) - Assume all Mellanox devices have broken INTx masking (Gavin Shan) Generic host bridge driver - Fix ioport_map() for !CONFIG_GENERIC_IOMAP (Liviu Dudau) - Add pci_register_io_range() and pci_pio_to_address() (Liviu Dudau) - Define PCI_IOBASE as the base of virtual PCI IO space (Liviu Dudau) - Fix the conversion of IO ranges into IO resources (Liviu Dudau) - Add pci_get_new_domain_nr() and of_get_pci_domain_nr() (Liviu Dudau) - Add support for parsing PCI host bridge resources from DT (Liviu Dudau) - Add pci_remap_iospace() to map bus I/O resources (Liviu Dudau) - Add arm64 architectural support for PCI (Liviu Dudau) APM X-Gene - Add APM X-Gene PCIe driver (Tanmay Inamdar) - Add arm64 DT APM X-Gene PCIe device tree nodes (Tanmay Inamdar) Freescale i.MX6 - Probe in module_init(), not fs_initcall() (Lucas Stach) - Delay enabling reference clock for SS until it stabilizes (Tim Harvey) Marvell MVEBU - Fix uninitialized variable in mvebu_get_tgt_attr() (Thomas Petazzoni) NVIDIA Tegra - Make sure the PCIe PLL is really reset (Eric Yuen) - Add error path tegra_msi_teardown_irq() cleanup (Jisheng Zhang) - Fix extended configuration space mapping (Peter Daifuku) - Implement resource hierarchy (Thierry Reding) - Clear CLKREQ# enable on port disable (Thierry Reding) - Add Tegra124 support (Thierry Reding) ST Microelectronics SPEAr13xx - Pass config resource through reg property (Pratyush Anand) Synopsys DesignWare - Use NULL instead of false (Fabio Estevam) - Parse bus-range property from devicetree (Lucas Stach) - Use pci_create_root_bus() instead of pci_scan_root_bus() (Lucas Stach) - Remove pci_assign_unassigned_resources() (Lucas Stach) - Check private_data validity in single place (Lucas Stach) - Setup and clear exactly one MSI at a time (Lucas Stach) - Remove open-coded bitmap operations (Lucas Stach) - Fix configuration base address when using 'reg' (Minghuan Lian) - Fix IO resource end address calculation (Minghuan Lian) - Rename get_msi_data() to get_msi_addr() (Minghuan Lian) - Add get_msi_data() to pcie_host_ops (Minghuan Lian) - Add support for v3.65 hardware (Murali Karicheri) - Fold struct pcie_port_info into struct pcie_port (Pratyush Anand) TI Keystone - Add TI Keystone PCIe driver (Murali Karicheri) - Limit MRSS for all downstream devices (Murali Karicheri) - Assume controller is already in RC mode (Murali Karicheri) - Set device ID based on SoC to support multiple ports (Murali Karicheri) Xilinx AXI - Add Xilinx AXI PCIe driver (Srikanth Thokala) - Fix xilinx_pcie_assign_msi() return value test (Dan Carpenter) Miscellaneous - Clean up whitespace (Quentin Lambert) - Remove assignments from "if" conditions (Quentin Lambert) - Move PCI_VENDOR_ID_VMWARE to pci_ids.h (Francesco Ruggeri) - x86: Mark DMI tables as initialization data (Mathias Krause) - x86: Move __init annotation to the correct place (Mathias Krause) - x86: Mark constants of pci_mmcfg_nvidia_mcp55() as __initconst (Mathias Krause) - x86: Constify pci_mmcfg_probes[] array (Mathias Krause) - x86: Mark PCI BIOS initialization code as such (Mathias Krause) - Parenthesize PCI_DEVID and PCI_VPD_LRDT_ID parameters (Megan Kamiya) - Remove unnecessary variable in pci_add_dynid() (Tobias Klauser)" * tag 'pci-v3.18-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (109 commits) arm64: dts: Add APM X-Gene PCIe device tree nodes PCI: Add ACS quirk for AMD A88X southbridge devices PCI: xgene: Add APM X-Gene PCIe driver PCI: designware: Remove open-coded bitmap operations PCI/MSI: Remove unnecessary temporary variable PCI/MSI: Use __write_msi_msg() instead of write_msi_msg() MSI/powerpc: Use __read_msi_msg() instead of read_msi_msg() PCI/MSI: Use __get_cached_msi_msg() instead of get_cached_msi_msg() PCI/MSI: Add "msi_bus" sysfs MSI/MSI-X control for endpoints PCI/MSI: Remove "pos" from the struct msi_desc msi_attrib PCI/MSI: Remove unused kobject from struct msi_desc PCI/MSI: Rename pci_msi_check_device() to pci_msi_supported() PCI/MSI: Move D0 check into pci_msi_check_device() PCI/MSI: Remove arch_msi_check_device() irqchip: armada-370-xp: Remove arch_msi_check_device() PCI/MSI/PPC: Remove arch_msi_check_device() arm64: Add architectural support for PCI PCI: Add pci_remap_iospace() to map bus I/O resources of/pci: Add support for parsing PCI host bridge resources from DT of/pci: Add pci_get_new_domain_nr() and of_get_pci_domain_nr() ... Conflicts: arch/arm64/boot/dts/apm-storm.dtsi
2014-10-09Merge tag 'gpio-v3.18-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO changes from Linus Walleij: "This is the bulk of GPIO changes for the v3.18 development cycle: - Increase the default ARCH_NR_GPIO from 256 to 512. This was done to avoid having a custom <asm/gpio.h> header for the x86 architecture - GPIO is custom and complicated enough as it is already! We want to move to a radix to store the descriptors going forward, and finally get rid of this fixed array size altogether. - Endgame patching of the gpio_remove() semantics initiated by Abdoulaye Berthe. It is not accepted by the system that the removal of a GPIO chip fails during eg reboot or shutdown, and therefore the return value has now painfully been refactored away. For special cases like GPIO expanders on a hot-pluggable bus like USB, we may later add some gpiochip_try_remove() call, but for the cases we have now, return values are moot. - Some incremental refactoring of the gpiolib core and ACPI GPIO library for more descriptor usage. - Refactor the chained IRQ handler set-up method to handle also threaded, nested interrupts and set up the parent IRQ correctly. Switch STMPE and TC3589x drivers to use this registration method. - Add a .irq_not_threaded flag to the struct gpio_chip, so that also GPIO expanders that block but are still not using threaded IRQ handlers. - New drivers for the ARM64 X-Gene SoC GPIO controller. - The syscon GPIO driver has been improved to handle the "DSP GPIO" found on the TI Keystone 2 SoC:s. - ADNP driver switched to use gpiolib irqchip helpers. - Refactor the DWAPB driver to support being instantiated from and MFD cell (platform device). - Incremental feature improvement in the Zynq, MCP23S08, DWAPB, OMAP, Xilinx and Crystalcove drivers. - Various minor fixes" * tag 'gpio-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (52 commits) gpio: pch: Build context save/restore only for PM pinctrl: abx500: get rid of unused variable gpio: ks8695: fix 'else should follow close brace '}'' gpio: stmpe: add verbose debug code gpio: stmpe: fix up interrupt enable logic gpio: staticize xway_stp_init() gpio: handle also nested irqchips in the chained handler set-up gpio: set parent irq on chained handlers gpiolib: irqchip: use irq_find_mapping while removing irqchip gpio: crystalcove: support virtual GPIO pinctrl: bcm281xx: make Kconfig dependency more strict gpio: kona: enable only on BCM_MOBILE or for compile testing gpio, bcm-kona, LLVMLinux: Remove use of __initconst gpio: Fix ngpio in gpio-xilinx driver gpio: dwapb: fix pointer to integer cast gpio: xgene: Remove unneeded #ifdef CONFIG_OF guard gpio: xgene: Remove unneeded forward declation for struct xgene_gpio gpio: xgene: Fix missing spin_lock_init() gpio: ks8695: fix switch case indentation gpiolib: add irq_not_threaded flag to gpio_chip ...
2014-10-09Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "The irq departement delivers: - a cleanup series to get rid of mindlessly copied code. - another bunch of new pointlessly different interrupt chip drivers. Adding homebrewn irq chips (and timers) to SoCs must provide a value add which is beyond the imagination of mere mortals. - the usual SoC irq controller updates, IOW my second cat herding project" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits) irqchip: gic-v3: Implement CPU PM notifier irqchip: gic-v3: Refactor gic_enable_redist to support both enabling and disabling irqchip: renesas-intc-irqpin: Add minimal runtime PM support irqchip: renesas-intc-irqpin: Add helper variable dev = &pdev->dev irqchip: atmel-aic5: Add sama5d4 support irqchip: atmel-aic5: The sama5d3 has 48 IRQs Documentation: bcm7120-l2: Add Broadcom BCM7120-style L2 binding irqchip: bcm7120-l2: Add Broadcom BCM7120-style Level 2 interrupt controller irqchip: renesas-irqc: Add binding docs for new R-Car Gen2 SoCs irqchip: renesas-irqc: Add DT binding documentation irqchip: renesas-intc-irqpin: Document SoC-specific bindings openrisc: Get rid of handle_IRQ arm64: Get rid of handle_IRQ ARM: omap2: irq: Convert to handle_domain_irq ARM: imx: tzic: Convert to handle_domain_irq ARM: imx: avic: Convert to handle_domain_irq irqchip: or1k-pic: Convert to handle_domain_irq irqchip: atmel-aic5: Convert to handle_domain_irq irqchip: atmel-aic: Convert to handle_domain_irq irqchip: gic-v3: Convert to handle_domain_irq ...
2014-10-09Merge branch 'timers-nohz-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Ingo Molnar: "Main changes: - Fix the deadlock reported by Dave Jones et al - Clean up and fix nohz_full interaction with arch abilities - nohz init code consolidation/cleanup" * 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: nohz: nohz full depends on irq work self IPI support nohz: Consolidate nohz full init code arm64: Tell irq work about self IPI support arm: Tell irq work about self IPI support x86: Tell irq work about self IPI support irq_work: Force raised irq work to run on irq work interrupt irq_work: Introduce arch_irq_work_has_interrupt() nohz: Move nohz full init call to tick init
2014-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Most notable changes in here: 1) By far the biggest accomplishment, thanks to a large range of contributors, is the addition of multi-send for transmit. This is the result of discussions back in Chicago, and the hard work of several individuals. Now, when the ->ndo_start_xmit() method of a driver sees skb->xmit_more as true, it can choose to defer the doorbell telling the driver to start processing the new TX queue entires. skb->xmit_more means that the generic networking is guaranteed to call the driver immediately with another SKB to send. There is logic added to the qdisc layer to dequeue multiple packets at a time, and the handling mis-predicted offloads in software is now done with no locks held. Finally, pktgen is extended to have a "burst" parameter that can be used to test a multi-send implementation. Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4, virtio_net Adding support is almost trivial, so export more drivers to support this optimization soon. I want to thank, in no particular or implied order, Jesper Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann, David Tat, Hannes Frederic Sowa, and Rusty Russell. 2) PTP and timestamping support in bnx2x, from Michal Kalderon. 3) Allow adjusting the rx_copybreak threshold for a driver via ethtool, and add rx_copybreak support to enic driver. From Govindarajulu Varadarajan. 4) Significant enhancements to the generic PHY layer and the bcm7xxx driver in particular (EEE support, auto power down, etc.) from Florian Fainelli. 5) Allow raw buffers to be used for flow dissection, allowing drivers to determine the optimal "linear pull" size for devices that DMA into pools of pages. The objective is to get exactly the necessary amount of headers into the linear SKB area pre-pulled, but no more. The new interface drivers use is eth_get_headlen(). From WANG Cong, with driver conversions (several had their own by-hand duplicated implementations) by Alexander Duyck and Eric Dumazet. 6) Support checksumming more smoothly and efficiently for encapsulations, and add "foo over UDP" facility. From Tom Herbert. 7) Add Broadcom SF2 switch driver to DSA layer, from Florian Fainelli. 8) eBPF now can load programs via a system call and has an extensive testsuite. Alexei Starovoitov and Daniel Borkmann. 9) Major overhaul of the packet scheduler to use RCU in several major areas such as the classifiers and rate estimators. From John Fastabend. 10) Add driver for Intel FM10000 Ethernet Switch, from Alexander Duyck. 11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric Dumazet. 12) Add Datacenter TCP congestion control algorithm support, From Florian Westphal. 13) Reorganize sk_buff so that __copy_skb_header() is significantly faster. From Eric Dumazet" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits) netlabel: directly return netlbl_unlabel_genl_init() net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers net: description of dma_cookie cause make xmldocs warning cxgb4: clean up a type issue cxgb4: potential shift wrapping bug i40e: skb->xmit_more support net: fs_enet: Add NAPI TX net: fs_enet: Remove non NAPI RX r8169:add support for RTL8168EP net_sched: copy exts->type in tcf_exts_change() wimax: convert printk to pr_foo() af_unix: remove 0 assignment on static ipv6: Do not warn for informational ICMP messages, regardless of type. Update Intel Ethernet Driver maintainers list bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING tipc: fix bug in multicast congestion handling net: better IFF_XMIT_DST_RELEASE support net/mlx4_en: remove NETDEV_TX_BUSY 3c59x: fix bad split of cpu_to_le32(pci_map_single()) net: bcmgenet: fix Tx ring priority programming ...
2014-10-08Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "These are changes for drivers that are intimately tied to some SoC and for some reason could not get merged through the respective subsystem maintainer tree. Most of the new code is for the Keystone Navigator driver, which is new base support that is going to be needed for their hardware accelerated network driver and other units. Most of the commits are for moving old code around from at91 and omap for things that are done in device drivers nowadays. - at91: move reset, poweroff, memory and clocksource code into drivers directories - socfpga: add edac driver (through arm-soc, as requested by Boris) - omap: move omap-intc code to drivers/irqchip - sunxi: added an RTC driver for sun6i - omap: mailbox driver related changes - keystone: support for the "Navigator" component - versatile: new reboot, led and soc drivers" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (92 commits) bus: arm-ccn: Fix spurious warning message leds: add device tree bindings for register bit LEDs soc: add driver for the ARM RealView power: reset: driver for the Versatile syscon reboot leds: add a driver for syscon-based LEDs drivers/soc: ti: fix build break with modules MAINTAINERS: Add Keystone Multicore Navigator drivers entry soc: ti: add Keystone Navigator DMA support Documentation: dt: soc: add Keystone Navigator DMA bindings soc: ti: add Keystone Navigator QMSS driver Documentation: dt: soc: add Keystone Navigator QMSS bindings rtc: sunxi: Depend on platforms sun4i/sun7i that actually have the rtc rtc: sun6i: Add sun6i RTC driver irqchip: omap-intc: remove unnecessary comments irqchip: omap-intc: correct maximum number or MIR registers irqchip: omap-intc: enable TURBO idle mode irqchip: omap-intc: enable IP protection irqchip: omap-intc: remove unnecesary of_address_to_resource() call irqchip: omap-intc: comment style cleanup irqchip: omap-intc: minor improvement to omap_irq_pending() ...
2014-10-08Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Arnd Bergmann: "As usual, this is the largest branch, though this time a little under half of the total changes with 307 individual non-merge changesets. The largest changes are the addition of new machines, in particular the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support for the old i.MX1 platform. Other changes include - at91: various sam9 and sama5 updates - exynos: much extended Peach Pi/Pit (Chromebook 2) support - keystone: new peripherals - meson: added DT for meson6 SoC - mvebu: new device support for Armada 370/375 - qcom: improved support for IPQ8064 and MSM8x60 - rockchip: much improved support for rk3288 - shmobile: lots of updates all over the place - sunxi: dts license change - sunxi: more a23 device support - vexpress: CLCD DT description" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits) ARM: DTS: meson: update DTSI to add watchdog node ARM: dts: keystone-k2l: fix mdio io start address ARM: dts: keystone-k2e: fix mdio io start address ARM: dts: keystone-k2e: update usb1 node for dma properties ARM: dts: keystone: fix io range for usb_phy0 Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt" Revert "ARM: dts: hix5hd2: add wdg node" ARM: dts: add rk3288 i2s controller ARM: vexpress: Add CLCD Device Tree properties ARM: bcm2835: add I2S pinctrl to device tree ARM: meson: documentation: add bindings documentation ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS ARM: dts: mt6589: Change compatible string for GIC ARM: dts: mediatek: Add compatible property for aquaris5 ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk ARM: dts: mt6589: Fix typo in GIC unit address ARM: dts: Build dtb for Mediatek board ARM: dts: keystone: fix bindings for pcie and usb clock nodes ARM: dts: keystone: k2l: Fix chip selects for SPI devices ARM: dts: keystone: add dsp gpio controllers nodes ...
2014-10-08Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Arnd Bergmann: "New and updated SoC support. Among the things new for this release are: - at91: Added support for the new SAMA5D4 SoC, following the earlier SAMA5D3 - bcm: Added support for BCM63XX family of DSL SoCs - hisi: Added support for HiP04 server-class SoC - meson: Initial support for the Amlogic Meson6 (aka 8726MX) platform - shmobile: added support for new r8a7794 (R-Car E2) automotive SoC Noteworthy changes to existing SoC support are: - imx: convert i.MX1 to device tree - omap: lots of power management work - omap: base support to enable moving to standard UART driver - shmobile: lots of progress for multiplatform support, still ongoing" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (171 commits) ARM: hisi: depend on ARCH_MULTI_V7 CNS3xxx: Fix debug UART. ARM: at91: fix nommu build regression ARM: meson: add basic support for MesonX SoCs ARM: meson: debug: add debug UART for earlyprintk support irq: Export handle_fasteoi_irq ARM: mediatek: Add earlyprintk support for mt6589 ARM: hisi: Fix platmcpm compilation when ARMv6 is selected ARM: debug: fix alphanumerical order on debug uarts ARM: at91: document Atmel SMART compatibles ARM: at91: add sama5d4 support to sama5_defconfig ARM: at91: dt: add device tree file for SAMA5D4ek board ARM: at91: dt: add device tree file for SAMA5D4 SoC ARM: at91: SAMA5D4 SoC detection code and low level routines ARM: at91: introduce basic SAMA5D4 support clk: at91: add a driver for the h32mx clock ARM: pxa3xx: provide specific platform_devices for all ssp ports ARM: pxa: ssp: provide platform_device_id for PXA3xx ARM: OMAP4+: Remove static iotable mappings for SRAM ARM: OMAP4+: Move SRAM data to DT ...
2014-10-08Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "This time around, the cleanup branch contains mostly code removal. A number of board files for at91, imx and msm have become obsolete because of the DT conversion and are now ready to be removed. The OMAP platform has traditionally had its own DMA engine abstraction and as this is being phased out, a lot of the original code is now unused and can be removed as well. S3C24xx can be simplified now that the restart code is a proper device driver. Finally, a number of cleanups in shmobile are done to prepare for the addition of new code in other branches" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits) ARM: at91: Remove the support for the RSI EWS board arm: mach-omap2: Convert pr_warning to pr_warn ARM: OMAP: Remove unused pieces of legacy DMA API ARM: at91: remove board file for Acme Systems Fox G20 ARM: orion5x: Convert pr_warning to pr_warn ARM: S3C24XX: remove separate restart code ARM: EXYNOS: Do not calculate boot address twice ARM: sunxi: Remove sun4i reboot code from mach directory ARM: imx: Remove mach-mxt_td60 board file ARM: shmobile: armadillo800eva legacy: Use rmobile_add_devices_to_domains() ARM: shmobile: r8a7740: Clean up pm domain table ARM: shmobile: r8a7740: Use rmobile_add_devices_to_domains() ARM: shmobile: sh7372: Make domain_devices[] static __initdata ARM: shmobile: mackerel: Make domain_devices[] static __initdata clocksource: tcb_clksrc: sanitize IRQ request ARM: at91/tclib: mask interruptions at shutdown and probe ARM: at91/tclib: move initialization from alloc to probe ARM: at91/tclib: prefer using of devm_* functions ARM: clps711x: Switch CLPS711X subarch to use clk and clocksource driver ARM: shmobile: r8a7791 is now called "R-Car M2-W" ...
2014-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-10-08net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpersEric Dumazet
Add two helpers so that drivers do not have to care of BQL being available or not. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Jim Davis <jim.epost@gmail.com> Fixes: 29d40c903247 ("net/mlx4_en: Use prefetch in tx path") Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-08net: description of dma_cookie cause make xmldocs warningMasanari Iida
In commit 7bced397510ab569d31de4c70b39e13355046387, dma_cookie was removed from struct skbuff. But the description of dma_cookie still exist. So the "make xmldocs" output following warning. Warning(.//include/linux/skbuff.h:609): Excess struct/union /enum/typedef member 'dma_cookie' description in 'sk_buff' Remove description of dma_cookie fix the symptom. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-08net: fs_enet: Remove non NAPI RXLEROY Christophe
In the probe function, use_napi is inconditionnaly set to 1. This patch removes all the code which is conditional to !use_napi, and removes use_napi which has then become useless. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-08Merge tag 'f2fs-for-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs updates from Jaegeuk Kim: "This patch-set introduces a couple of new features such as large sector size, FITRIM, and atomic/volatile writes. Several patches enhance power-off recovery and checkpoint routines. The fsck.f2fs starts to support fixing corrupted partitions with recovery hints provided by this patch-set. Summary: - retain some recovery information for fsck.f2fs - enhance checkpoint speed - enhance flush command management - bug fix for lseek - tune in-place-update policies - enhance roll-forward speed - revisit all the roll-forward and fsync rules - support larget sector size - support FITRIM - support atomic and volatile writes And several clean-ups and bug fixes are included" * tag 'f2fs-for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (42 commits) f2fs: support volatile operations for transient data f2fs: support atomic writes f2fs: remove unused return value f2fs: clean up f2fs_ioctl functions f2fs: potential shift wrapping buf in f2fs_trim_fs() f2fs: call f2fs_unlock_op after error was handled f2fs: check the use of macros on block counts and addresses f2fs: refactor flush_nat_entries to remove costly reorganizing ops f2fs: introduce FITRIM in f2fs_ioctl f2fs: introduce cp_control structure f2fs: use more free segments until SSR is activated f2fs: change the ipu_policy option to enable combinations f2fs: fix to search whole dirty segmap when get_victim f2fs: fix to clean previous mount option when remount_fs f2fs: skip punching hole in special condition f2fs: support large sector size f2fs: fix to truncate blocks past EOF in ->setattr f2fs: update i_size when __allocate_data_block f2fs: use MAX_BIO_BLOCKS(sbi) f2fs: remove redundant operation during roll-forward recovery ...
2014-10-08Merge branch 'for-3.18' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "Highlights: - support the NFSv4.2 SEEK operation (allowing clients to support SEEK_HOLE/SEEK_DATA), thanks to Anna. - end the grace period early in a number of cases, mitigating a long-standing annoyance, thanks to Jeff - improve SMP scalability, thanks to Trond" * 'for-3.18' of git://linux-nfs.org/~bfields/linux: (55 commits) nfsd: eliminate "to_delegation" define NFSD: Implement SEEK NFSD: Add generic v4.2 infrastructure svcrdma: advertise the correct max payload nfsd: introduce nfsd4_callback_ops nfsd: split nfsd4_callback initialization and use nfsd: introduce a generic nfsd4_cb nfsd: remove nfsd4_callback.cb_op nfsd: do not clear rpc_resp in nfsd4_cb_done_sequence nfsd: fix nfsd4_cb_recall_done error handling nfsd4: clarify how grace period ends nfsd4: stop grace_time update at end of grace period nfsd: skip subsequent UMH "create" operations after the first one for v4.0 clients nfsd: set and test NFSD4_CLIENT_STABLE bit to reduce nfsdcltrack upcalls nfsd: serialize nfsdcltrack upcalls for a particular client nfsd: pass extra info in env vars to upcalls to allow for early grace period end nfsd: add a v4_end_grace file to /proc/fs/nfsd lockd: add a /proc/fs/lockd/nlm_end_grace file nfsd: reject reclaim request when client has already sent RECLAIM_COMPLETE nfsd: remove redundant boot_time parm from grace_done client tracking op ...
2014-10-08Merge tag 'nfs-for-3.18-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Highlights include: Stable fixes: - fix an NFSv4.1 state renewal regression - fix open/lock state recovery error handling - fix lock recovery when CREATE_SESSION/SETCLIENTID_CONFIRM fails - fix statd when reconnection fails - don't wake tasks during connection abort - don't start reboot recovery if lease check fails - fix duplicate proc entries Features: - pNFS block driver fixes and clean ups from Christoph - More code cleanups from Anna - Improve mmap() writeback performance - Replace use of PF_TRANS with a more generic mechanism for avoiding deadlocks in nfs_release_page" * tag 'nfs-for-3.18-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (66 commits) NFSv4.1: Fix an NFSv4.1 state renewal regression NFSv4: fix open/lock state recovery error handling NFSv4: Fix lock recovery when CREATE_SESSION/SETCLIENTID_CONFIRM fails NFS: Fabricate fscache server index key correctly SUNRPC: Add missing support for RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT NFSv3: Fix missing includes of nfs3_fs.h NFS/SUNRPC: Remove other deadlock-avoidance mechanisms in nfs_release_page() NFS: avoid waiting at all in nfs_release_page when congested. NFS: avoid deadlocks with loop-back mounted NFS filesystems. MM: export page_wakeup functions SCHED: add some "wait..on_bit...timeout()" interfaces. NFS: don't use STABLE writes during writeback. NFSv4: use exponential retry on NFS4ERR_DELAY for async requests. rpc: Add -EPERM processing for xs_udp_send_request() rpc: return sent and err from xs_sendpages() lockd: Try to reconnect if statd has moved SUNRPC: Don't wake tasks during connection abort Fixing lease renewal nfs: fix duplicate proc entries pnfs/blocklayout: Fix a 64-bit division/remainder issue in bl_map_stripe ...
2014-10-08Merge tag 'char-misc-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big set of driver patches for char/misc drivers. Nothing major in here, the shortlog goes into the details. All have been in the linux-next tree for a while with no issues" * tag 'char-misc-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (80 commits) mei: mei_txe_fw_sts can be static mei: fix kernel-doc warnings mei: fix KDoc documentation formatting mei: drop me_client_presentation_num mei: trivial: fix errors in prints in comments mei: remove include to pci header from mei module files mei: push pci cfg structure me hw mei: remove the reference to pdev from mei_device mei: move fw_status back to hw ops handlers mei: get rid of most of the pci dependencies in mei mei: push all standard settings into mei_device_init mei: move mei_hbm_hdr function from hbm.h the hbm.c mei: kill error message for allocation failure mei: nfc: fix style warning mei: fix style warning: Missing a blank line after declarations mei: pg: fix cat and paste error in comments mei: debugfs: add single buffer indicator mei: debugfs: adjust print buffer mei: add hbm and pg state in devstate debugfs print Drivers: hv: vmbus: Enable interrupt driven flow control ...
2014-10-08Merge tag 'driver-core-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the driver core patches for 3.18-rc1. Just a few small things, and the addition of a new interface to dump firmware "core dumps" to userspace through sysfs that the wireless and graphic drivers want to use. All of these have been in linux-next for a while" * tag 'driver-core-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: dynamic_debug: change __dynamic_<foo>_dbg return types to void driver/base/node: remove unnecessary kfree of node struct from unregister_one_node devres: Improve devm_kasprintf()/kvasprintf() support Documentation: devres: Add missing devm_kstrdup() managed interface Documentation: devres: Add missing IRQ functions firmware_class: make sure fw requests contain a name driver core: Remove kerneldoc from local function attribute_container: fix coding style issues attribute_container: fix whitespace errors drivers/base: Fix length checks in create_syslog_header()/dev_vprintk_emit() device coredump: add new device coredump class Documentation/sysfs-rules.txt: Add device attribute error code documentation
2014-10-08Merge tag 'tty-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver updates from Greg KH: "Here's the big tty/serial driver patchset for 3.18-rc1. Lots of little things in here, some good work from Peter Hurley on the tty core, and in lots of drivers. There are also lots of other driver updates in here as well, full details in the changelogs. All have been in the linux-next tree for a while" * tag 'tty-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (99 commits) Revert "serial/core: Initialize the console pm state" tty: serial: 8250: use 32bit variable for rpm_tx_active tty: serial: msm: Add earlycon support serial/core: Initialize the console pm state serial: asc: Conditionally use readl_relaxed (COMPILE_TEST) serial: of-serial: add PM suspend/resume support m68k: AMIGA_BUILTIN_SERIAL should depend on TTY asm/uapi: Add definition of TIOC[SG]RS485 tty/metag_da: Add console_poll module parameter serial: 8250_pci: remove rts_n override from Baytrail quirk serial: cadence: Add generic earlycon support serial: imx: change the wait even to interruptiable serial: imx: terminate the RX DMA when the UART is suspending serial: imx: fix throttle/unthrottle callbacks for hardware assisted flow control serial: 8250: Add Quark X1000 to 8250_pci.c tty: omap-serial: pull out calculation from baud_is_mode16 tty: omap-serial: fix division by zero xen_hvc: no reason to write the type key on xenstore tty: serial: 8250_core: remove UART_IER_RDI in serial8250_stop_rx() tty: serial: 8250_core: use the ->line argument as a hint in serial8250_find_match_or_unused() ...
2014-10-08Merge tag 'staging-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging updates from Greg KH: "Here is the big staging patch set for 3.18-rc1. Once again, we are deleting more code than we added, with something like 150000 lines deleted overall. Some of this is due to drivers being added to the networking tree, so the old versions are removed here, but even then, the overall difference is quite good. Other than driver deletions, lots and lots and lots of minor cleanups all over the place. Full details are in the changelog" * tag 'staging-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1481 commits) staging: et131x: Remove et131x driver from drivers/staging staging: emxx_udc: Use min_t instead of min staging: emxx_udc: Fix replace printk(KERN_DEBUG ..) with dev_dbg staging: media: Fixed else after return or break warning staging: media: omap4iss: Fixed else after return or break warning staging: rtl8712: Fixed else not required after return staging: rtl8712: Fix missing blank line warning staging: rtl8192e: rtl8192e: Remove spaces before the semicolons staging: rtl8192e: rtl8192e: Remove unnecessary return statements staging: rtl8192e: Remove unneeded void return staging: rtl8192e: Fix void function return statements style staging: rtl8712: Fix unnecessary parentheses style warning staging: rtl8192e: Fix unnecessary space before function pointer arguments staging: rtl8192e: Array was made static const char * const staging: ft1000: ft1000-usb: Removed unnecessary else statement. staging: ft1000: ft1000-usb: Removed unnecessary else statement. staging: ft1000: ft1000-usb: Removed unnecessary parentheses. staging: ft1000: ft1000-usb: Added new line after declarations. staging: vt6655: Fixed C99 // comment errors in wpactl.c staging: speakup: Fixed warning <linux/serial.h> instead of <asm/serial.h> ...
2014-10-08Merge tag 'usb-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB updates from Greg KH: "Here's the big USB patchset for 3.18-rc1. Also in here is the PHY tree, as it seems to fit well with the USB tree for various reasons... Anyway, lots of little changes in here, all over the place, full details in the changelog All have been in the linux-next tree for a while with no issues" * tag 'usb-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (244 commits) USB: host: st: fix typo 'CONFIG_USB_EHCI_HCD_ST' uas: Reduce number of function arguments for uas_alloc_foo functions xhci: Allow xHCI drivers to be built as separate modules xhci: Export symbols used by host-controller drivers xhci: Check for XHCI_COMP_MODE_QUIRK when disabling D3cold xhci: Introduce xhci_init_driver() usb: hcd: add generic PHY support usb: rename phy to usb_phy in HCD usb: gadget: uvc: fix up uvcg_v4l2_get_unmapped_area typo USB: host: st: fix ehci/ohci driver selection usb: host: ehci-exynos: Remove unnecessary usb-phy support usb: core: return -ENOTSUPP for all targeted hosts USB: Remove .owner field for driver usb: core: log higher level message on malformed LANGID descriptor usb: Add LED triggers for USB activity usb: Rename usb-common.c usb: gadget: Refactor request completion usb: gadget: Introduce usb_gadget_giveback_request() usb: dwc2/gadget: move phy bus legth initialization phy: remove .owner field for drivers using module_platform_driver ...
2014-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - add multibuffer infrastructure (single_task_running scheduler helper, OKed by Peter on lkml. - add SHA1 multibuffer implementation for AVX2. - reenable "by8" AVX CTR optimisation after fixing counter overflow. - add APM X-Gene SoC RNG support. - SHA256/SHA512 now handles unaligned input correctly. - set lz4 decompressed length correctly. - fix algif socket buffer allocation failure for 64K page machines. - misc fixes * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (47 commits) crypto: sha - Handle unaligned input data in generic sha256 and sha512. Revert "crypto: aesni - disable "by8" AVX CTR optimization" crypto: aesni - remove unused defines in "by8" variant crypto: aesni - fix counter overflow handling in "by8" variant hwrng: printk replacement crypto: qat - Removed unneeded partial state crypto: qat - Fix typo in name of tasklet_struct crypto: caam - Dynamic allocation of addresses for various memory blocks in CAAM. crypto: mcryptd - Fix typos in CRYPTO_MCRYPTD description crypto: algif - avoid excessive use of socket buffer in skcipher arm64: dts: add random number generator dts node to APM X-Gene platform. Documentation: rng: Add X-Gene SoC RNG driver documentation hwrng: xgene - add support for APM X-Gene SoC RNG support crypto: mv_cesa - Add missing #define crypto: testmgr - add test for lz4 and lz4hc crypto: lz4,lz4hc - fix decompression crypto: qat - Use pci_enable_msix_exact() instead of pci_enable_msix() crypto: drbg - fix maximum value checks on 32 bit systems crypto: drbg - fix sparse warning for cpu_to_be[32|64] crypto: sha-mb - sha1_mb_alg_state can be static ...
2014-10-08Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "Included in these updates are: - Performance optimisation to avoid writing the control register at every exception. - Use static inline instead of extern inline in ftrace code. - Crypto ARM assembly updates for big endian - Alignment of initrd/.init memory to page sizes when freeing to ensure that we fully free the regions - Add gcov support - A couple of preparatory patches for VDSO support: use _install_special_mapping, and randomize the sigpage placement above stack. - Add L2 ePAPR DT cache properties so that DT can specify the cache geometry. - Preparatory patch for FIQ (NMI) kernel C code for things like spinlock lockup debug. Following on from this are a couple of my patches cleaning up show_regs() and removing an unused (probably since 1.x days) do_unexp_fiq() function. - Use pr_warn() rather than pr_warning(). - A number of cleanups (smp, footbridge, return_address)" * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (21 commits) ARM: 8167/1: extend the reserved memory for initrd to be page aligned ARM: 8168/1: extend __init_end to a page align address ARM: 8169/1: l2c: parse cache properties from ePAPR definitions ARM: 8160/1: drop warning about return_address not using unwind tables ARM: 8161/1: footbridge: select machine dir based on ARCH_FOOTBRIDGE ARM: 8158/1: LLVMLinux: use static inline in ARM ftrace.h ARM: 8155/1: place sigpage at a random offset above stack ARM: 8154/1: use _install_special_mapping for sigpage ARM: 8153/1: Enable gcov support on the ARM architecture ARM: Avoid writing to control register on every exception ARM: 8152/1: Convert pr_warning to pr_warn ARM: remove unused do_unexp_fiq() function ARM: remove extraneous newline in show_regs() ARM: 8150/3: fiq: Replace default FIQ handler ARM: 8140/1: ep93xx: Enable DEBUG_LL_UART_PL01X ARM: 8139/1: versatile: Enable DEBUG_LL_UART_PL01X ARM: 8138/1: drop ISAR0 workaround for B15 ARM: 8136/1: sa1100: add Micro ASIC platform device ARM: 8131/1: arm/smp: Absorb boot_secondary() ARM: 8126/1: crypto: enable NEON SHA-384/SHA-512 for big endian ...
2014-10-08Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Paolo Bonzini: "Fixes and features for 3.18. Apart from the usual cleanups, here is the summary of new features: - s390 moves closer towards host large page support - PowerPC has improved support for debugging (both inside the guest and via gdbstub) and support for e6500 processors - ARM/ARM64 support read-only memory (which is necessary to put firmware in emulated NOR flash) - x86 has the usual emulator fixes and nested virtualization improvements (including improved Windows support on Intel and Jailhouse hypervisor support on AMD), adaptive PLE which helps overcommitting of huge guests. Also included are some patches that make KVM more friendly to memory hot-unplug, and fixes for rare caching bugs. Two patches have trivial mm/ parts that were acked by Rik and Andrew. Note: I will soon switch to a subkey for signing purposes" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (157 commits) kvm: do not handle APIC access page if in-kernel irqchip is not in use KVM: s390: count vcpu wakeups in stat.halt_wakeup KVM: s390/facilities: allow TOD-CLOCK steering facility bit KVM: PPC: BOOK3S: HV: CMA: Reserve cma region only in hypervisor mode arm/arm64: KVM: Report correct FSC for unsupported fault types arm/arm64: KVM: Fix VTTBR_BADDR_MASK and pgd alloc kvm: Fix kvm_get_page_retry_io __gup retval check arm/arm64: KVM: Fix set_clear_sgi_pend_reg offset kvm: x86: Unpin and remove kvm_arch->apic_access_page kvm: vmx: Implement set_apic_access_page_addr kvm: x86: Add request bit to reload APIC access page address kvm: Add arch specific mmu notifier for page invalidation kvm: Rename make_all_cpus_request() to kvm_make_all_cpus_request() and make it non-static kvm: Fix page ageing bugs kvm/x86/mmu: Pass gfn and level to rmapp callback. x86: kvm: use alternatives for VMCALL vs. VMMCALL if kernel text is read-only kvm: x86: use macros to compute bank MSRs KVM: x86: Remove debug assertion of non-PAE reserved bits kvm: don't take vcpu mutex for obviously invalid vcpu ioctls kvm: Faults which trigger IO release the mmap_sem ...
2014-10-07Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI updates from James Bottomley: "This patch set consists of the usual driver updates (megaraid_sas, arcmsr, be2iscsi, lpfc, mpt2sas, mpt3sas, qla2xxx, ufs) plus several assorted fixes and miscellaneous updates (including the pci_msix_enable_range() changes that have been pending for a while)" * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (202 commits) scsi: add a CONFIG_SCSI_MQ_DEFAULT option ufs: definitions for phy interface ufs: tune bkops while power managment events ufs: Add support for clock scaling using devfreq framework ufs: Add freq-table-hz property for UFS device ufs: Add support for clock gating ufs: refactor configuring power mode ufs: add UFS power management support ufs: introduce well known logical unit in ufs ufs: manually add well known logical units ufs: Active Power Mode - configuring bActiveICCLevel ufs: improve init sequence ufs: refactor query descriptor API support ufs: add voting support for host controller power ufs: Add clock initialization support ufs: Add regulator enable support ufs: Allow vendor specific initialization scsi: don't add scsi_device if its already visible scsi: fix the type for well known LUs scsi: fix comment in struct Scsi_Host definition ...
2014-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "A few new haptic/button drivers, a rudimentary support for laptops using FocalTech touchpads; xpad driver will bind to more devices, and a few other driver fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: soc_button_array - convert to platform bus Input: palmas-pwrbutton - fix typo in the license string Input: palmas-pwrbutton - use IRQF_ONESHOT Input: psmouse - add support for detecting FocalTech PS/2 touchpads Input: psmouse - add psmouse_matches_pnp_id helper function Input: joystick - use ktime for measuring timing Input: add haptic driver on max77693 Input: introduce palmas-pwrbutton Input: add support for the DRV2667 haptic driver Input: xpad - sync device IDs with xboxdrv Input: xpad - add VID/PID for Razer Sabertooth Input: cros_ec_keyb - optimize ghosting algorithm Input: drv260x - fix binding document Input: drv260x - add check for ERM mode and LRA Libraries Input: drv260x - remove unused defines Input: drv260x - add TI drv260x haptics driver
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: - quirk for devices that need to be pulled in much more aggresive way than mandated, by Johan Hovold - robustification of sanity checking of incoming reports in RMI driver, by Benjamin Tissoires - fixes, updates, and new HW support to SONY driver, by Frank Praznik - port of uHID to the new transport layer layout, by David Herrmann - robustification of Clear-Halt/reset in USB HID, by Alan Stern - native support for hopefully any future HID compliant wacom tablet. Those found on the various laptops (ISDv4/5) already are HID compliant and they should work in the future without any modification of the kernel. Written by Benjamin Tissoires. - a lot more simple fixes and device ID additions all over the place * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (45 commits) HID: uHID: fix excepted report type HID: usbhid: add another mouse that needs QUIRK_ALWAYS_POLL HID: wacom: implement the finger part of the HID generic handling HID: wacom: implement generic HID handling for pen generic devices HID: wacom: move allocation of inputs earlier HID: wacom: split out input allocation and registration HID: wacom: rename failN with some meaningful information HID: sony: Update the DualShock 4 touchpad resolution HID: wacom: fix timeout on probe for some wacoms HID: sony: Set touchpad bits in the input_configured callback HID: sony: Update file header and correct comments HID: sony: Corrections for the DualShock 4 HID descriptor HID: rmi: check sanity of the incoming report HID: wacom: make the WL connection friendly for the desktop HID: wacom - enable LED support for Wireless Intuos5/Pro HID: wacom - remove report_id from wacom_get_report interface HID: wacom - Clean up of sysfs HID: wacom - Add default permission defines for sysfs attributes HID: usbhid: fix PIXART optical mouse HID: Add Holtek USB ID 04d9:a0c2 ETEKCITY Scroll ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull "trivial tree" updates from Jiri Kosina: "Usual pile from trivial tree everyone is so eagerly waiting for" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Remove MN10300_PROC_MN2WS0038 mei: fix comments treewide: Fix typos in Kconfig kprobes: update jprobe_example.c for do_fork() change Documentation: change "&" to "and" in Documentation/applying-patches.txt Documentation: remove obsolete pcmcia-cs from Changes Documentation: update links in Changes Documentation: Docbook: Fix generated DocBook/kernel-api.xml score: Remove GENERIC_HAS_IOMAP gpio: fix 'CONFIG_GPIO_IRQCHIP' comments tty: doc: Fix grammar in serial/tty dma-debug: modify check_for_stack output treewide: fix errors in printk genirq: fix reference in devm_request_threaded_irq comment treewide: fix synchronize_rcu() in comments checkstack.pl: port to AArch64 doc: queue-sysfs: minor fixes init/do_mounts: better syntax description MIPS: fix comment spelling powerpc/simpleboot: fix comment ...
2014-10-07Merge tag 'spi-v3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi updates from Mark Brown: "A quiet release for SPI, mainly driver updates and not too many of them: - Support for dummy transfers (for delays on startup) in drivers using transfer_one(). - Lots of enhancements to the Designware driver to support new Intel SoCs. - Support for newer Renesas chips. - DMA support for the i.MX driver. - One new driver for Broadcom BCM53xx chips" * tag 'spi-v3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (64 commits) spi: spi-mxs: fix a tiny typo in a comment spi: dw-mid: follow new DMAengine workflow spi: dw-mid: convert to use DMAengine wrappers spi: dw-mid: change magic numbers to the constants spi: orion: support armada extended baud rates spi: fsl: Sort include headers alphabetically spi: bcm53xx: Add missing module information spi: bcm53xx: Fix module dependency spi/rockchip: fix bug that cause the failure to read data in DMA mode spi: fsl-dspi: Remove probe info message spi: pl022: Add support for chip select extension spi: Fix possible ZERO_SIZE_PTR pointer dereferencing error. spi: dw: fix style of code in few places spi: dw: introduce support of loopback mode spi: dw-mid: terminate ongoing transfers at exit spi: dw-mid: respect 8 bit mode spi: clps711x: Migrate to the new clk subsystem spi: pl022: Add missing error check for devm_kzalloc spi: spi-imx: add DMA support spi: davinci: add support for adding delay between word's transmissions ...
2014-10-07Merge tag 'regulator-v3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates from Mark Brown: "This time around most of the changes are a lot of new drivers along with the standard set of fixes and cleanups (thanks again largely to Axel Lin). We do have one nice new feature in the core which factors out the disappointingly tricky code around DT parsing, only a couple of drivers have been converted so far: - Factor out the code for parsing the standard bindings for a set of regulators out of DT, making the probe part of a lot of drivers simplier. - New drivers for Dialog DA9213, HiSilicon HI6420, Intersil ISL9305/H, Ricoh RN5T618, Rockchip RK808, Skyworks SKY81452, Silergy SYR82x, and Qualcomm RPM" * tag 'regulator-v3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (71 commits) regulator: da9211: Fix a bug in update of mask bit regulator: pwm-regulator: add devicetree bindings for pwm regulator regulator: pwm-regulator: get voltage and duty table from dts regulator: qcom_rpm: Fix FORCE_MODE_IS_2_BITS macro regulator: qcom_rpm: Don't explicitly initialise the first field of config regulator: ltc3589: fix broken voltage transitions regulator: qcom-rpm: Regulator driver for the Qualcomm RPM regulator: axp20x: Use parent device as regulator configuration device regulator: fan53555: Fix null pointer dereference regulator: fan53555: Fixup report wrong vendor message regulator: fan53555: fix wrong cast in probe regulator: fan53555: add support for Silergy SYR82x regulators regulator: fan53555: add devicetree support regulator: add devicetree bindings for Fairchild FAN53555 regulators regulator: rk808: Add function for ramp delay for buck1/buck2 regulator: fan53555: use set_ramp_delay to set the ramp up slew rate regulator: fan53555: enable vin supply regulator: rk808: Fix missing of_node_put regulator: rk808: Remove unused variables regulator: of: Add stub OF match function for !OF case ...
2014-10-07Merge tag 'pinctrl-v3.18-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control changes from Linus Walleij: "This is the bulk of pin control changes for the v3.18 development series: - New drivers for the Freescale i.MX21, Qualcomm APQ8084 pin controllers. - Incremental new features on the Rockchip, atlas 6, OMAP, AM437x, APQ8064, prima2, AT91, Tegra, i.MX, Berlin and Nomadik. - Push Freescale drivers down into their own subdirectory. - Assorted sprays of syntax and semantic fixes" * tag 'pinctrl-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (48 commits) pinctrl: specify bindings for pins and groups pinctrl: nomadik: improve GPIO debug prints pinctrl: abx500: refactor DT parser to take two paths pinctrl: abx500: use helpers for map allocation/free pinctrl: alter device tree bindings for functions pinctrl: nomadik: refactor DT parser to take two paths pinctrl: nomadik: use utils map free function pinctrl: nomadik: use util function to reserve maps pinctrl: qcom: use restart_notifier mechanism for ps_hold pinctrl: sh-pfc: sh73a0: Remove unnecessary SoC data allocation pinctrl: berlin: fix the dt_free_map function pinctrl: at91: disable PD or PU before enabling PU or PD pinctrl: st: remove gpiochip in failure cases pinctrl: at91: Fix error handling while doing gpiochio_irqchip_add pinctrl: at91: Fix failure path in at91_gpio_probe path pinctrl: lantiq: Release gpiochip resources in fail case pinctrl: imx: detect uninitialized pins pinctrl: tegra: Add MIPI pad control pinctrl: at91: Switch to using managed clk_get pinctrl: adi2: Remove duplicate gpiochip_remove_pin_ranges ...
2014-10-07Merge tag 'dmaengine-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine updates from Dan Williams: "Even though this has fixes marked for -stable, given the size and the needed conflict resolutions this is 3.18-rc1/merge-window material. These patches have been languishing in my tree for a long while. The fact that I do not have the time to do proper/prompt maintenance of this tree is a primary factor in the decision to step down as dmaengine maintainer. That and the fact that the bulk of drivers/dma/ activity is going through Vinod these days. The net_dma removal has not been in -next. It has developed simple conflicts against mainline and net-next (for-3.18). Continuing thanks to Vinod for staying on top of drivers/dma/. Summary: 1/ Step down as dmaengine maintainer see commit 08223d80df38 "dmaengine maintainer update" 2/ Removal of net_dma, as it has been marked 'broken' since 3.13 (commit 77873803363c "net_dma: mark broken"), without reports of performance regression. 3/ Miscellaneous fixes" * tag 'dmaengine-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine: net: make tcp_cleanup_rbuf private net_dma: revert 'copied_early' net_dma: simple removal dmaengine maintainer update dmatest: prevent memory leakage on error path in thread ioat: Use time_before_jiffies() dmaengine: fix xor sources continuation dma: mv_xor: Rename __mv_xor_slot_cleanup() to mv_xor_slot_cleanup() dma: mv_xor: Remove all callers of mv_xor_slot_cleanup() dma: mv_xor: Remove unneeded mv_xor_clean_completed_slots() call ioat: Use pci_enable_msix_exact() instead of pci_enable_msix() drivers: dma: Include appropriate header file in dca.c drivers: dma: Mark functions as static in dma_v3.c dma: mv_xor: Add DMA API error checks ioat/dca: Use dev_is_pci() to check whether it is pci device
2014-10-07Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing major: support for compressing modules, and auto-tainting params. PS. My virtio-next tree is empty: DaveM took the patches I had. There might be a virtio-rng starvation fix, but so far it's a bit voodoo so I will get to that in the next two days or it will wait" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: moduleparam: Resolve missing-field-initializer warning kbuild: handle module compression while running 'make modules_install'. modinst: wrap long lines in order to enhance cmd_modules_install modsign: lookup lines ending in .ko in .mod files modpost: simplify file name generation of *.mod.c files modpost: reduce visibility of symbols and constify r/o arrays param: check for tainting before calling set op. drm/i915: taint the kernel if unsafe module parameters are set module: add module_param_unsafe and module_param_named_unsafe module: make it possible to have unsafe, tainting module params module: rename KERNEL_PARAM_FL_NOARG to avoid confusion
2014-10-07Merge remote-tracking branch 'scsi-queue/drivers-for-3.18' into for-linusJames Bottomley
2014-10-07net: better IFF_XMIT_DST_RELEASE supportEric Dumazet
Testing xmit_more support with netperf and connected UDP sockets, I found strange dst refcount false sharing. Current handling of IFF_XMIT_DST_RELEASE is not optimal. Dropping dst in validate_xmit_skb() is certainly too late in case packet was queued by cpu X but dequeued by cpu Y The logical point to take care of drop/force is in __dev_queue_xmit() before even taking qdisc lock. As Julian Anastasov pointed out, need for skb_dst() might come from some packet schedulers or classifiers. This patch adds new helper to cleanly express needs of various drivers or qdiscs/classifiers. Drivers that need skb_dst() in their ndo_start_xmit() should call following helper in their setup instead of the prior : dev->priv_flags &= ~IFF_XMIT_DST_RELEASE; -> netif_keep_dst(dev); Instead of using a single bit, we use two bits, one being eventually rebuilt in bonding/team drivers. The other one, is permanent and blocks IFF_XMIT_DST_RELEASE being rebuilt in bonding/team. Eventually, we could add something smarter later. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-07net: phy: adjust fixed_phy_register() return valuePetri Gynther
Adjust fixed_phy_register() to return struct phy_device *, so that it becomes easy to use fixed PHYs without device tree support: phydev = fixed_phy_register(PHY_POLL, &fixed_phy_status, NULL); fixed_phy_set_link_update(phydev, fixed_phy_link_update); phy_connect_direct(netdev, phydev, handler_fn, phy_interface); This change is a prerequisite for modifying bcmgenet driver to work without a device tree on Broadcom's MIPS-based 7xxx platforms. Signed-off-by: Petri Gynther <pgynther@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-07openvswitch: fix a compilation error when CONFIG_INET is not setW!Andy Zhou
Fix a openvswitch compilation error when CONFIG_INET is not set: ===================================================== In file included from include/net/geneve.h:4:0, from net/openvswitch/flow_netlink.c:45: include/net/udp_tunnel.h: In function 'udp_tunnel_handle_offloads': >> include/net/udp_tunnel.h:100:2: error: implicit declaration of function 'iptunnel_handle_offloads' [-Werror=implicit-function-declaration] >> return iptunnel_handle_offloads(skb, udp_csum, type); >> ^ >> >> include/net/udp_tunnel.h:100:2: warning: return makes pointer from integer without a cast >> >> cc1: some warnings being treated as errors ===================================================== Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Andy Zhou <azhou@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-07ipv6: make fib6 serial number per namespaceHannes Frederic Sowa
Try to reduce number of possible fn_sernum mutation by constraining them to their namespace. Also remove rt_genid which I forgot to remove in 705f1c869d577c ("ipv6: remove rt6i_genid"). Cc: YOSHIFUJI Hideaki <hideaki@yoshifuji.org> Cc: Martin Lau <kafai@fb.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-07ipv6: make rt_sernum atomic and serial number fields ordinary intsHannes Frederic Sowa
2014-10-07ipv6: minor fib6 cleanups like type safety, bool conversion, inline removalHannes Frederic Sowa
Also renamed struct fib6_walker_t to fib6_walker and enum fib_walk_state_t to fib6_walk_state as recommended by Cong Wang. Cc: Cong Wang <cwang@twopensource.com> Cc: YOSHIFUJI Hideaki <hideaki@yoshifuji.org> Cc: Martin Lau <kafai@fb.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-06net: sched: remove tcf_proto from ematch callsJohn Fastabend
This removes the tcf_proto argument from the ematch code paths that only need it to reference the net namespace. This allows simplifying qdisc code paths especially when we need to tear down the ematch from an RCU callback. In this case we can not guarentee that the tcf_proto structure is still valid. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-06net: introduce netdevice gso_min_segs attributeEric Dumazet
Some TSO engines might have a too heavy setup cost, that impacts performance on hosts sending small bursts (2 MSS per packet). This patch adds a device gso_min_segs, allowing drivers to set a minimum segment size for TSO packets, according to the NIC performance. Tested on a mlx4 NIC, this allows to get a ~110% increase of throughput when sending 2 MSS per packet. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-06Merge branches 'for-3.18/always-poll-quirk', 'for-3.18/logitech', ↵Jiri Kosina
'for-3.18/picolcd', 'for-3.18/rmi', 'for-3.18/sony', 'for-3.18/uhid', 'for-3.18/upstream' and 'for-3.18/wacom' into for-linus
2014-10-06ethtool: Ethtool parameter to dynamically change tx_copybreakEric Dumazet
Use new ethtool [sg]et_tunable() to set tx_copybread (inline threshold) Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Amir Vadai <amirv@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-06net/mlx4_en: Code cleanups in tx pathEric Dumazet
- Remove unused variable ring->poll_cnt - No need to set some fields if using blueflame - Add missing const's - Use unlikely - Remove unneeded new line - Make some comments more precise - struct mlx4_bf @offset field reduced to unsigned int to save space Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Amir Vadai <amirv@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-06net: sched: avoid costly atomic operation in fq_dequeue()Eric Dumazet
Standard qdisc API to setup a timer implies an atomic operation on every packet dequeue : qdisc_unthrottled() It turns out this is not really needed for FQ, as FQ has no concept of global qdisc throttling, being a qdisc handling many different flows, some of them can be throttled, while others are not. Fix is straightforward : add a 'bool throttle' to qdisc_watchdog_schedule_ns(), and remove calls to qdisc_unthrottled() in sch_fq. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-06openvswitch: Add support for Geneve tunneling.Jesse Gross
The Openvswitch implementation is completely agnostic to the options that are in use and can handle newly defined options without further work. It does this by simply matching on a byte array of options and allowing userspace to setup flows on this array. Signed-off-by: Jesse Gross <jesse@nicira.com> Singed-off-by: Ansis Atteka <aatteka@nicira.com> Signed-off-by: Andy Zhou <azhou@nicira.com> Acked-by: Thomas Graf <tgraf@noironetworks.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-06openvswitch: Wrap struct ovs_key_ipv4_tunnel in a new structure.Jesse Gross
Currently, the flow information that is matched for tunnels and the tunnel data passed around with packets is the same. However, as additional information is added this is not necessarily desirable, as in the case of pointers. This adds a new structure for tunnel metadata which currently contains only the existing struct. This change is purely internal to the kernel since the current OVS_KEY_ATTR_IPV4_TUNNEL is simply a compressed version of OVS_KEY_ATTR_TUNNEL that is translated at flow setup. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: Andy Zhou <azhou@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-06openvswitch: Add support for matching on OAM packets.Jesse Gross
Some tunnel formats have mechanisms for indicating that packets are OAM frames that should be handled specially (either as high priority or not forwarded beyond an endpoint). This provides support for allowing those types of packets to be matched. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: Andy Zhou <azhou@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-06net: Add Geneve tunneling protocol driverAndy Zhou
This adds a device level support for Geneve -- Generic Network Virtualization Encapsulation. The protocol is documented at http://tools.ietf.org/html/draft-gross-geneve-01 Only protocol layer Geneve support is provided by this driver. Openvswitch can be used for configuring, set up and tear down functional Geneve tunnels. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: Andy Zhou <azhou@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
