path: root/include
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SOCK]: Introduce sk_receive_skbArnaldo Carvalho de Melo
Its common enough to to justify that, TCP still can't use it as it has the prequeueing stuff, still to be made generic in the not so distant future :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: Small cleanup to socket initializationAndi Kleen
sock_init can be done as a core_initcall instead of calling it directly in init/main.c Also I removed an out of date #ifdef. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SCTP]: Add support for SCTP_DELAYED_ACK_TIME socket option.Frank Filz
Signed-off-by: Frank Filz <ffilz@us.ibm.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SCTP]: Update SCTP_PEER_ADDR_PARAMS socket option to the latest api draft.Frank Filz
This patch adds support to set/get heartbeat interval, maximum number of retransmissions, pathmtu, sackdelay time for a particular transport/ association/socket as per the latest SCTP sockets api draft11. Signed-off-by: Frank Filz <ffilz@us.ibm.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[FLS64]: x86_64 versionStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[FLS64]: generic versionStephen Hemminger
2006-01-03[PKT_SCHED] netem: packet corruption optionStephen Hemminger
Here is a new feature for netem in 2.6.16. It adds the ability to randomly corrupt packets with netem. A version was done by Hagen Paul Pfeifer, but I redid it to handle the cases of backwards compatibility with netlink interface and presence of hardware checksum offload. It is useful for testing hardware offload in devices. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[AF_UNIX]: Use spinlock for unix_table_lockDavid S. Miller
This lock is actually taken mostly as a writer, so using a rwlock actually just makes performance worse especially on chips like the Intel P4. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IP_SOCKGLUE]: Remove most of the tcp specific callsArnaldo Carvalho de Melo
As DCCP needs to be called in the same spots. Now we have a member in inet_sock (is_icsk), set at sock creation time from struct inet_protosw->flags (if INET_PROTOSW_ICSK is set, like for TCP and DCCP) to see if a struct sock instance is a inet_connection_sock for places like the ones in ip_sockglue.c (v4 and v6) where we previously were looking if sk_type was SOCK_STREAM, that is insufficient because we now use the same code for DCCP, that has sk_type SOCK_DCCP. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TCP]: Move the TCPF_ enum to tcp_states.hArnaldo Carvalho de Melo
Upcoming patches will make, for instance, ip_sockglue.c need just this enum and not all of tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET6]: Generalise tcp_v6_hash_connectArnaldo Carvalho de Melo
Renaming it to inet6_hash_connect, making it possible to ditch dccp_v6_hash_connect and share the same code with TCP instead. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET]: Generalise tcp_v4_hash_connectArnaldo Carvalho de Melo
Renaming it to inet_hash_connect, making it possible to ditch dccp_v4_hash_connect and share the same code with TCP instead. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TWSK]: Introduce struct timewait_sock_opsArnaldo Carvalho de Melo
So that we can share several timewait sockets related functions and make the timewait mini sockets infrastructure closer to the request mini sockets one. Next changesets will take advantage of this, moving more code out of TCP and DCCP v4 and v6 to common infrastructure. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Export ipv6_opt_acceptedArnaldo Carvalho de Melo
It was already non-TCP specific, will be used by DCCPv6. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Introduce inet6_timewait_sockArnaldo Carvalho de Melo
Out of tcp6_timewait_sock, that now is just an aggregation of inet_timewait_sock and inet6_timewait_sock, using tw_ipv6_offset in struct inet_timewait_sock, that is common to the IPv6 transport protocols that use timewait sockets, like DCCP and TCP. tw_ipv6_offset plays the struct inet_sock pinfo6 role, i.e. for the generic code to find the IPv6 area in a timewait sock. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Generalise some functionsArnaldo Carvalho de Melo
Using sk->sk_protocol instead of IPPROTO_TCP. Will be used by DCCPv6 in the next changesets. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: Avoid atomic xchg() for non-error caseBenjamin LaHaise
It also looks like there were 2 places where the test on sk_err was missing from the event wait logic (in sk_stream_wait_connect and sk_stream_wait_memory), while the rest of the sock_error() users look to be doing the right thing. This version of the patch fixes those, and cleans up a few places that were testing ->sk_err directly. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IP]: Simplify and consolidate MSG_PEEK error handlingHerbert Xu
When a packet is obtained from skb_recv_datagram with MSG_PEEK enabled it is left on the socket receive queue. This means that when we detect a checksum error we have to be careful when trying to free the packet as someone could have dequeued it in the time being. Currently this delicate logic is duplicated three times between UDPv4, UDPv6 and RAWv6. This patch moves them into a one place and simplifies the code somewhat. This is based on a suggestion by Eric Dumazet. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[ICSK]: Move v4_addr2sockaddr from TCP to icskArnaldo Carvalho de Melo
Renaming it to inet_csk_addr2sockaddr. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[ICSK]: Rename struct tcp_func to struct inet_connection_sock_af_opsArnaldo Carvalho de Melo
And move it to struct inet_connection_sock. DCCP will use it in the upcoming changesets. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Introduce inet6_rsk()Arnaldo Carvalho de Melo
And inet6_rsk_offset in inet_request_sock, for the same reasons as inet_sock's pinfo6 member. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Generalise tcp_v6_search_req & tcp_v6_synq_addArnaldo Carvalho de Melo
More work is needed tho to introduce inet6_request_sock from tcp6_request_sock, in the same layout considerations as ipv6_pinfo in inet_sock, next changeset will do that. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[ICSK]: make inet_csk_reqsk_queue_hash_add timeout arg unsigned longArnaldo Carvalho de Melo
2006-01-03[IPV6]: Generalise __tcp_v6_hash, renaming it to __inet6_hashArnaldo Carvalho de Melo
2006-01-03[IPV6]: Reuse inet_csk_get_port in tcp_v6_get_portArnaldo Carvalho de Melo
2006-01-03[IPV4]: Safer reassemblyHerbert Xu
Another spin of Herbert Xu's "safer ip reassembly" patch for 2.6.16. (The original patch is here: http://marc.theaimsgroup.com/?l=linux-netdev&m=112281936522415&w=2 and my only contribution is to have tested it.) This patch (optionally) does additional checks before accepting IP fragments, which can greatly reduce the possibility of reassembling fragments which originated from different IP datagrams. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arthur Kepner <akepner@sgi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[LSM-IPSec]: Security association restriction.Trent Jaeger
This patch series implements per packet access control via the extension of the Linux Security Modules (LSM) interface by hooks in the XFRM and pfkey subsystems that leverage IPSec security associations to label packets. Extensions to the SELinux LSM are included that leverage the patch for this purpose. This patch implements the changes necessary to the XFRM subsystem, pfkey interface, ipv4/ipv6, and xfrm_user interface to restrict a socket to use only authorized security associations (or no security association) to send/receive network packets. Patch purpose: The patch is designed to enable access control per packets based on the strongly authenticated IPSec security association. Such access controls augment the existing ones based on network interface and IP address. The former are very coarse-grained, and the latter can be spoofed. By using IPSec, the system can control access to remote hosts based on cryptographic keys generated using the IPSec mechanism. This enables access control on a per-machine basis or per-application if the remote machine is running the same mechanism and trusted to enforce the access control policy. Patch design approach: The overall approach is that policy (xfrm_policy) entries set by user-level programs (e.g., setkey for ipsec-tools) are extended with a security context that is used at policy selection time in the XFRM subsystem to restrict the sockets that can send/receive packets via security associations (xfrm_states) that are built from those policies. A presentation available at www.selinux-symposium.org/2005/presentations/session2/2-3-jaeger.pdf from the SELinux symposium describes the overall approach. Patch implementation details: On output, the policy retrieved (via xfrm_policy_lookup or xfrm_sk_policy_lookup) must be authorized for the security context of the socket and the same security context is required for resultant security association (retrieved or negotiated via racoon in ipsec-tools). This is enforced in xfrm_state_find. On input, the policy retrieved must also be authorized for the socket (at __xfrm_policy_check), and the security context of the policy must also match the security association being used. The patch has virtually no impact on packets that do not use IPSec. The existing Netfilter (outgoing) and LSM rcv_skb hooks are used as before. Also, if IPSec is used without security contexts, the impact is minimal. The LSM must allow such policies to be selected for the combination of socket and remote machine, but subsequent IPSec processing proceeds as in the original case. Testing: The pfkey interface is tested using the ipsec-tools. ipsec-tools have been modified (a separate ipsec-tools patch is available for version 0.5) that supports assignment of xfrm_policy entries and security associations with security contexts via setkey and the negotiation using the security contexts via racoon. The xfrm_user interface is tested via ad hoc programs that set security contexts. These programs are also available from me, and contain programs for setting, getting, and deleting policy for testing this interface. Testing of sa functions was done by tracing kernel behavior. Signed-off-by: Trent Jaeger <tjaeger@cse.psu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-02[PATCH] Avoid namespace pollution in <asm/param.h>Dag-Erling Smørgrav
In commit 3D59121003721a8fad11ee72e646fd9d3076b5679c, the x86 and x86-64 <asm/param.h> was changed to include <linux/config.h> for the configurable timer frequency. However, asm/param.h is sometimes used in userland (it is included indirectly from <sys/param.h>), so your commit pollutes the userland namespace with tons of CONFIG_FOO macros. This greatly confuses software packages (such as BusyBox) which use CONFIG_FOO macros themselves to control the inclusion of optional features. After a short exchange, Christoph approved this patch Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-27[IPV6] mcast: Fix multiple issues in MLDv2 reports.David L Stevens
The below "jumbo" patch fixes the following problems in MLDv2. 1) Add necessary "ntohs" to recent "pskb_may_pull" check [breaks all nonzero source queries on little-endian (!)] 2) Add locking to source filter list [resend of prior patch] 3) fix "mld_marksources()" to a) send nothing when all queried sources are excluded b) send full exclude report when source queried sources are not excluded c) don't schedule a timer when there's nothing to report NOTE: RFC 3810 specifies the source list should be saved and each source reported individually as an IS_IN. This is an obvious DOS path, requiring the host to store and then multicast as many sources as are queried (e.g., millions...). This alternative sends a full, relevant report that's limited to number of sources present on the machine. 4) fix "add_grec()" to send empty-source records when it should The original check doesn't account for a non-empty source list with all sources inactive; the new code keeps that short-circuit case, and also generates the group header with an empty list if needed. 5) fix mca_crcount decrement to be after add_grec(), which needs its original value These issues (other than item #1 ;-) ) were all found by Yan Zheng, much thanks! Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-24[PATCH] n_r3964: fixed usage of HZ; removed bad includeKurt Huwig
Fix n_r3964 timeouts (hardcoded for 100Hz) Also the include of <asm/termios.h> in 'n_r3964.h' is unnecessary and prevents using the header file in any application that has to include <termios.h> due to duplicate definition of 'struct termio'. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-24[PATCH] Fix typo in x86_64 __build_write_lock_const assemblyBen Collins
Based on __build_read_lock_const, this looked like a bug. [ Indeed. Maybe nobody uses this version? Worth fixing up anyway ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-24[PATCH] x86_64/ia64 : Fix compilation error for node_to_first_cpuRavikiran G Thirumalai
Fixes a compiler error in node_to_first_cpu, __ffs expects unsigned long as a parameter; instead cpumask_t was being passed. The macro node_to_first_cpu was not yet used in x86_64 and ia64 arches, and so we never hit this. This patch replaces __ffs with first_cpu macro, similar to other arches. Signed-off-by: Alok N Kataria <alokk@calsoftinc.com> Signed-off-by: Ravikiran G Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-22Pull owner_id into release branchLen Brown
2005-12-22Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2005-12-22[PATCH] fix race with preempt_enable()Nicolas Pitre
Currently a simple void foo(void) { preempt_enable(); } produces the following code on ARM: foo: bic r3, sp, #8128 bic r3, r3, #63 ldr r2, [r3, #4] ldr r1, [r3, #0] sub r2, r2, #1 tst r1, #4 str r2, [r3, #4] blne preempt_schedule mov pc, lr The problem is that the TIF_NEED_RESCHED flag is loaded _before_ the preemption count is stored back, hence any interrupt coming within that 3 instruction window causing TIF_NEED_RESCHED to be set won't be seen and scheduling won't happen as it should. Nothing currently prevents gcc from performing that reordering. There is already a barrier() before the decrement of the preemption count, but another one is needed between this and the TIF_NEED_RESCHED flag test for proper code ordering. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-22Merge git://git.skbuff.net/gitroot/yoshfuji/linux-2.6.14+git+ipv6-fix-20051221aDavid S. Miller
2005-12-21Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
2005-12-21[PATCH] include/linux/irq.h: #include <linux/smp.h>Adrian Bunk
Jan's crosscompile page [1] shows, that one regression in 2.6.15-rc is that the v850 defconfig does no longer compile. The compile error is: <-- snip --> ... CC arch/v850/kernel/setup.o In file included from /usr/src/ctest/rc/kernel/arch/v850/kernel/setup.c:17: /usr/src/ctest/rc/kernel/include/linux/irq.h:13:43: asm/smp.h: No such file or directory make[2]: *** [arch/v850/kernel/setup.o] Error 1 <-- snip --> The #include <asm/smp.h> in irq.h was intruduced in 2.6.15-rc. Since include/linux/irq.h needs code from asm/smp.h only in the CONFIG_SMP=y case and linux/smp.h #include's asm/smp.h only in the CONFIG_SMP=y case, I'm suggesting this patch to #include <linux/smp.h> in irq.h. I've tested the compilation with both CONFIG_SMP=y and CONFIG_SMP=n on i386. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-21[IPV6]: Defer IPv6 device initialization until the link becomes ready.YOSHIFUJI Hideaki
NETDEV_UP might be sent even if the link attached to the interface was not ready. DAD does not make sense in such case, so we won't do so. After interface Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2005-12-21[IPV6]: Flag RTF_ANYCAST for anycast routes.YOSHIFUJI Hideaki
2005-12-21[ACPI] increase owner_id limit to 64 from 32Alex Williamson
This is an interim patch until changes in an updated ACPICA core increase the limit to 255. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-20[PATCH] relayfs: remove warning printk() in relay_switch_subbuf()Tom Zanussi
There's currently a diagnostic printk in relay_switch_subbuf() meant as a warning if you accidentally try to log an event larger than the sub-buffer size. The problem is if this happens while logging from somewhere it's not safe to be doing printks, such as in the scheduler, you can end up with a deadlock. This patch removes the warning from relay_switch_subbuf() and instead prints some diagnostic info when the channel is closed. Thanks to Mathieu Desnoyers for pointing out the problem and suggesting a fix. Signed-off-by: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-19NFS: Fix another O_DIRECT raceTrond Myklebust
Ensure we call unmap_mapping_range() and sync dirty pages to disk before doing an NFS direct write. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-12-19[IPSEC]: Perform SA switchover immediately.David S. Miller
When we insert a new xfrm_state which potentially subsumes an existing one, make sure all cached bundles are flushed so that the new SA is used immediately. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-19[RTNETLINK]: Fix RTNLGRP definitions in rtnetlink.hKristian Slavov
I reported a problem and gave hints to the solution, but nobody seemed to react. So I prepared a patch against 2.6.14.4. Tested on 2.6.14.4 with "ip monitor addr" and with the program attached, while adding and removing IPv6 address. Both programs didn't receive any messages. Tested 2.6.14.4 + this patch, and both programs received add and remove messages. Signed-off-by: Kristian Slavov <kristian.slavov@nomadiclab.com> Acked-by: Jamal Hadi salim <hadi@cyberus.ca> ACKed-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-18[PATCH] mtd onenand driver: reduce stack usageKyungmin Park
2005-12-18[PATCH] mtd onenand driver: check correct manufacturerKyungmin Park
This (and the three subsequent patches) is working well on OMAP H4 with 2.6.15-rc4 kernel and passes the LTP fs test. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-16Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
