path: root/include
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
2006-01-04Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
2006-01-04[PATCH] USB Storage: add alauda supportMatthew Dharm
This patch adds another usb-storage subdriver, which supports two fairly old dual-XD/SmartMedia reader-writers (USB1.1 devices). This driver was written by Daniel Drake <dsd@gentoo.org> -- he notes that he wrote this driver without specs, however a vendor-supplied GPL driver for the previous generation of products ("sma03") did prove to be quite useful, as did the sddr09 driver which also has to deal with low-level physical block layout on SmartMedia. The original patch has been reformed by me, as it clashed with the libusual patches. We really need to consolidate some of this common SmartMedia code, and get together with the MTD guys to share it with them as well. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: Store port number in usb_deviceAlan Stern
This patch (as610) adds a field to struct usb_device to store the device's port number. This allows us to remove several loops in the hub driver (searching for a particular device among all the entries in the parent's array of children). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: Consider power budget when choosing configurationAlan Stern
This patch (as609) changes the way we keep track of power budgeting for USB hubs and devices, and it updates the choose_configuration routine to take this information into account. (This is something we should have been doing all along.) A new field in struct usb_device holds the amount of bus current available from the upstream port, and the usb_hub structure keeps track of the current available for each downstream port. Two new rules for configuration selection are added: Don't select a self-powered configuration when only bus power is available. Don't select a configuration requiring more bus power than is available. However the first rule is #if-ed out, because I found that the internal hub in my HP USB keyboard claims that its only configuration is self-powered. The rule would prevent the configuration from being chosen, leaving the hub & keyboard unconfigured. Since similar descriptor errors may turn out to be fairly common, it seemed wise not to include a rule that would break automatic configuration unnecessarily for such devices. The second rule may also trigger unnecessarily, although this should be less common. More likely it will annoy people by sometimes failing to accept configurations that should never have been chosen in the first place. The patch also changes usbcore's reaction when no configuration is suitable. Instead of raising an error and rejecting the device, now the core will simply leave the device unconfigured. People can always work around such problems by installing configurations manually through sysfs. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: Remove USB private semaphoreAlan Stern
This patch (as605) removes the private udev->serialize semaphore, relying instead on the locking provided by the embedded struct device's semaphore. The changes are confined to the core, except that the usb_trylock_device routine now uses the return convention of down_trylock rather than down_read_trylock (they return opposite values for no good reason). A couple of other associated changes are included as well: Now that we aren't concerned about HCDs that avoid using the hcd glue layer, usb_disconnect no longer needs to acquire the usb_bus_lock -- that can be done by usb_remove_hcd where it belongs. Devices aren't locked over the same scope of code in usb_new_device and hub_port_connect_change as they used to be. This shouldn't cause any trouble. Along with the preceding driver core patch, this needs a lot of testing. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: make registering a usb driver automatically set the module ownerGreg Kroah-Hartman
This fixes the driver that forgot to set the module owner up. Now we can remove the unneeded pointer from the usb driver structure. The idea for how to do this was from Al Viro, who did this for the PCI drivers. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: allow usb drivers to disable dynamic idsGreg Kroah-Hartman
This lets drivers, like the usb-serial ones, disable the ability to add ids from sysfs. The usb-serial drivers are "odd" in that they are really usb-serial bus drivers, not usb bus drivers, so the dynamic id logic will have to go into the usb-serial bus core for those drivers to get that ability. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: add dynamic id functionality to USB coreGreg Kroah-Hartman
Echo the usb vendor and product id to the "new_id" file in the driver's sysfs directory, and then that driver will be able to bind to a device with those ids if it is present. Example: echo 0557 2008 > /sys/bus/usb/drivers/foo_driver/new_id adds the hex values 0557 and 2008 to the device id table for the foo_driver. Note, usb-serial drivers do not currently work with this capability yet. usb-storage also might have some oddities. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: drivers/usb/storage/libusualPete Zaitcev
This patch adds a shim driver libusual, which routes devices between usb-storage and ub according to the common table, based on unusual_devs.h. The help and example syntax is in Kconfig. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: pxa27x OHCI - Separate platform code from main driverRichard Purdie
To allow multiple platforms to use the PXA27x OHCI driver, the platform code needs to be moved into the board specific files in arch/arm/mach-pxa. This patch does this for mainstone and adds preliminary hooks to allow other boards to use the driver. This has been compile tested for mainstone and successfully run on Spitz (Sharp Zaurus SL-C3000) with the addition of an appropriate board support file. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-02[PATCH] Avoid namespace pollution in <asm/param.h>Dag-Erling Smørgrav
In commit 3D59121003721a8fad11ee72e646fd9d3076b5679c, the x86 and x86-64 <asm/param.h> was changed to include <linux/config.h> for the configurable timer frequency. However, asm/param.h is sometimes used in userland (it is included indirectly from <sys/param.h>), so your commit pollutes the userland namespace with tons of CONFIG_FOO macros. This greatly confuses software packages (such as BusyBox) which use CONFIG_FOO macros themselves to control the inclusion of optional features. After a short exchange, Christoph approved this patch Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-27[IPV6] mcast: Fix multiple issues in MLDv2 reports.David L Stevens
The below "jumbo" patch fixes the following problems in MLDv2. 1) Add necessary "ntohs" to recent "pskb_may_pull" check [breaks all nonzero source queries on little-endian (!)] 2) Add locking to source filter list [resend of prior patch] 3) fix "mld_marksources()" to a) send nothing when all queried sources are excluded b) send full exclude report when source queried sources are not excluded c) don't schedule a timer when there's nothing to report NOTE: RFC 3810 specifies the source list should be saved and each source reported individually as an IS_IN. This is an obvious DOS path, requiring the host to store and then multicast as many sources as are queried (e.g., millions...). This alternative sends a full, relevant report that's limited to number of sources present on the machine. 4) fix "add_grec()" to send empty-source records when it should The original check doesn't account for a non-empty source list with all sources inactive; the new code keeps that short-circuit case, and also generates the group header with an empty list if needed. 5) fix mca_crcount decrement to be after add_grec(), which needs its original value These issues (other than item #1 ;-) ) were all found by Yan Zheng, much thanks! Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-24[PATCH] n_r3964: fixed usage of HZ; removed bad includeKurt Huwig
Fix n_r3964 timeouts (hardcoded for 100Hz) Also the include of <asm/termios.h> in 'n_r3964.h' is unnecessary and prevents using the header file in any application that has to include <termios.h> due to duplicate definition of 'struct termio'. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-24[PATCH] Fix typo in x86_64 __build_write_lock_const assemblyBen Collins
Based on __build_read_lock_const, this looked like a bug. [ Indeed. Maybe nobody uses this version? Worth fixing up anyway ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-24[PATCH] x86_64/ia64 : Fix compilation error for node_to_first_cpuRavikiran G Thirumalai
Fixes a compiler error in node_to_first_cpu, __ffs expects unsigned long as a parameter; instead cpumask_t was being passed. The macro node_to_first_cpu was not yet used in x86_64 and ia64 arches, and so we never hit this. This patch replaces __ffs with first_cpu macro, similar to other arches. Signed-off-by: Alok N Kataria <alokk@calsoftinc.com> Signed-off-by: Ravikiran G Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-22Pull owner_id into release branchLen Brown
2005-12-22Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2005-12-22[PATCH] fix race with preempt_enable()Nicolas Pitre
Currently a simple void foo(void) { preempt_enable(); } produces the following code on ARM: foo: bic r3, sp, #8128 bic r3, r3, #63 ldr r2, [r3, #4] ldr r1, [r3, #0] sub r2, r2, #1 tst r1, #4 str r2, [r3, #4] blne preempt_schedule mov pc, lr The problem is that the TIF_NEED_RESCHED flag is loaded _before_ the preemption count is stored back, hence any interrupt coming within that 3 instruction window causing TIF_NEED_RESCHED to be set won't be seen and scheduling won't happen as it should. Nothing currently prevents gcc from performing that reordering. There is already a barrier() before the decrement of the preemption count, but another one is needed between this and the TIF_NEED_RESCHED flag test for proper code ordering. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-22Merge git://git.skbuff.net/gitroot/yoshfuji/linux-2.6.14+git+ipv6-fix-20051221aDavid S. Miller
2005-12-21Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
2005-12-21[PATCH] include/linux/irq.h: #include <linux/smp.h>Adrian Bunk
Jan's crosscompile page [1] shows, that one regression in 2.6.15-rc is that the v850 defconfig does no longer compile. The compile error is: <-- snip --> ... CC arch/v850/kernel/setup.o In file included from /usr/src/ctest/rc/kernel/arch/v850/kernel/setup.c:17: /usr/src/ctest/rc/kernel/include/linux/irq.h:13:43: asm/smp.h: No such file or directory make[2]: *** [arch/v850/kernel/setup.o] Error 1 <-- snip --> The #include <asm/smp.h> in irq.h was intruduced in 2.6.15-rc. Since include/linux/irq.h needs code from asm/smp.h only in the CONFIG_SMP=y case and linux/smp.h #include's asm/smp.h only in the CONFIG_SMP=y case, I'm suggesting this patch to #include <linux/smp.h> in irq.h. I've tested the compilation with both CONFIG_SMP=y and CONFIG_SMP=n on i386. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-21[IPV6]: Defer IPv6 device initialization until the link becomes ready.YOSHIFUJI Hideaki
NETDEV_UP might be sent even if the link attached to the interface was not ready. DAD does not make sense in such case, so we won't do so. After interface Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2005-12-21[IPV6]: Flag RTF_ANYCAST for anycast routes.YOSHIFUJI Hideaki
2005-12-21[ACPI] increase owner_id limit to 64 from 32Alex Williamson
This is an interim patch until changes in an updated ACPICA core increase the limit to 255. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-20[PATCH] relayfs: remove warning printk() in relay_switch_subbuf()Tom Zanussi
There's currently a diagnostic printk in relay_switch_subbuf() meant as a warning if you accidentally try to log an event larger than the sub-buffer size. The problem is if this happens while logging from somewhere it's not safe to be doing printks, such as in the scheduler, you can end up with a deadlock. This patch removes the warning from relay_switch_subbuf() and instead prints some diagnostic info when the channel is closed. Thanks to Mathieu Desnoyers for pointing out the problem and suggesting a fix. Signed-off-by: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-19NFS: Fix another O_DIRECT raceTrond Myklebust
Ensure we call unmap_mapping_range() and sync dirty pages to disk before doing an NFS direct write. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-12-19[IPSEC]: Perform SA switchover immediately.David S. Miller
When we insert a new xfrm_state which potentially subsumes an existing one, make sure all cached bundles are flushed so that the new SA is used immediately. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-19[RTNETLINK]: Fix RTNLGRP definitions in rtnetlink.hKristian Slavov
I reported a problem and gave hints to the solution, but nobody seemed to react. So I prepared a patch against 2.6.14.4. Tested on 2.6.14.4 with "ip monitor addr" and with the program attached, while adding and removing IPv6 address. Both programs didn't receive any messages. Tested 2.6.14.4 + this patch, and both programs received add and remove messages. Signed-off-by: Kristian Slavov <kristian.slavov@nomadiclab.com> Acked-by: Jamal Hadi salim <hadi@cyberus.ca> ACKed-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-18[PATCH] mtd onenand driver: reduce stack usageKyungmin Park
2005-12-18[PATCH] mtd onenand driver: check correct manufacturerKyungmin Park
This (and the three subsequent patches) is working well on OMAP H4 with 2.6.15-rc4 kernel and passes the LTP fs test. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-16Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
2005-12-16[PATCH] ppc: ppc4xx_dma DMA_MODE_{READ,WRITE} fixAl Viro
DMA_MODE_{READ,WRITE} are declared in asm-powerpc/dma.h and their declarations there match the definitions. Old declarations in ppc4xx_dma.h are not right anymore (wrong type, to start with). Killed them, added include of asm/dma.h where needed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-16[IA64] Add __read_mostly support for IA64Christoph Lameter
sparc64, i386 and x86_64 have support for a special data section dedicated to rarely updated data that is frequently read. The section was created to avoid false sharing of those rarely read data with frequently written kernel data. This patch creates such a data section for ia64 and will group rarely written data into this section. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-12-16Make sure we copy pages inserted with "vm_insert_page()" on forkLinus Torvalds
The logic that decides that a fork() might be able to avoid copying a VM area when it can be re-created by page faults didn't know about the new vm_insert_page() case. Also make some things a bit more anal wrt VM_PFNMAP. Pointed out by Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-16[IA64] disable preemption in udelay()John Hawkes
The udelay() inline for ia64 uses the ITC. If CONFIG_PREEMPT is enabled and the platform has unsynchronized ITCs and the calling task migrates to another CPU while doing the udelay loop, then the effective delay may be too short or very, very long. This patch disables preemption around 100 usec chunks of the overall desired udelay time. This minimizes preemption-holdoffs. udelay() is now too big to be inline, move it out of line and export it. Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-12-15[SCSI] fix for fc transport recursion problem.James.Smart@Emulex.Com
In the scenario that a link was broken, the devloss timer for each rport was expire at roughly the same time, causing lots of "delete" workqueue items being queued. Depth is dependent upon the number of rports that were on the link. The rport target remove calls were calling flush_scheduled_work(), which would interrupt the stream, and start the next workqueue item, which did the same thing, and so on until recursion depth was large. This fix stops the recursion in the initial delete path, and pushes it off to a host-level work item that reaps the dead rports. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15[PATCH] sun4c_memerr_reg __iomem annotationsAl Viro
2005-12-15[PATCH] fix iomem annotations in sparc32 pcic codeAl Viro
2005-12-14Merge master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
2005-12-14Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
2005-12-15[PATCH] ide: cleanup ide_driver_tBartlomiej Zolnierkiewicz
Remove unused fields: ioctl, ata[pi]_prebuilder. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-12-15[PATCH] ide: cleanup ide.hBartlomiej Zolnierkiewicz
Remove: * stale comment * unused HOST() macro * unused ata_{error,control}_t types * unused atapi_select_t type * ide_init_subdrivers() prototype Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-12-15[PATCH] ide: AU1200 IDE updateJordan Crouse
Changes here include removing all of CONFIG_PM while it is being repeatedly smacked with a lead pipe, moving the BURSTMODE param to a #define (it should be defined almost always anyway), fixing the rqsize stuff, pulling ide_ioreg_t, and general cleanups and whatnot. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-12-15[PATCH] ide: core modifications for AU1200Jordan Crouse
bart: slightly modified by me Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-12-15[PATCH] via82cxxx IDE: Add VT8251 ISA bridgeDaniel Drake
Some motherboards (such as the Asus P5V800-MX) ship a PCI_DEVICE_ID_VIA_82C586_1 IDE controller alongside a VT8251 southbridge. This southbridge is currently unrecognised in the via82cxxx IDE driver, preventing those users from getting DMA access to disks. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-12-14Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-12-14[ARM] 3205/1: Handle new EABI relocations when loading kernel modules.Daniel Jacobowitz
Patch from Daniel Jacobowitz Handle new EABI relocations when loading kernel modules. This is necessary for CONFIG_AEABI kernels, and also for some broken (since fixed) old ABI toolchains. Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-13[SCSI] Consolidate REQ_BLOCK_PC handling path (fix ipod panic)James Bottomley
This follows on from Jens' patch and consolidates all of the ULD separate handlers for REQ_BLOCK_PC into a single call which has his fix for our direction bug. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
