path: root/include
2008-05-14cs5520: disable VDMABartlomiej Zolnierkiewicz
Disable Virtual DMA support for now (it causes system hangs). Thanks to TAKADA Yoshihito for the help with debugging the problem. Reported-by: TAKADA Yoshihito <takada@mbf.nifty.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-14make ide-iops.c:SELECT_MASK() staticAdrian Bunk
SELECT_MASK() can now become static. [bart: remove space between function name and open parenthesis] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: Driver core: struct class remove children list block: do_mounts - accept root=<non-existant partition>
2008-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (22 commits) USB: atmel_usba_udc fixes, mostly disconnect() USB: pxa27x_udc: minor fixes usbtest: comment on why this code "expects" negative and positive errnos USB: remove PICDEM FS USB demo (04d8:000c) device from ldusb USB: option: add new Dell 5520 HSDPA variant USB: unusual_devs: Add support for GI 0401 SD-Card interface USB: serial gadget: descriptor cleanup USB: serial gadget: simplify endpoint handling USB: serial gadget: remove needless data structure USB: serial gadget: cleanup/reorg usb: fix compile warning in isp1760 USB: do not handle device 1410:5010 in 'option' driver USB: Fix unusual_devs.h ordering USB: add Zoom Telephonics Model 3095F V.92 USB Mini External modem to cdc-acm USB: Support for the ET502HS HDSPA modem in option driver USB: Support for the ET502HS HDSPA modem usb: fix integer as NULL pointer warnings found by sparse USB: isp1760: fix printk format USB: add Telstra NextG CDMA id to option driver USB: add association.h ...
2008-05-14Driver core: struct class remove children listDave Young
because of the class_device was removed, now do the children list removing Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14block: do_mounts - accept root=<non-existant partition>Kay Sievers
Some devices, like md, may create partitions only at first access, so allow root= to be set to a valid non-existant partition of an existing disk. This applies only to non-initramfs root mounting. This fixes a regression from 2.6.24 which did allow this to happen and broke some users machines :( Acked-by: Neil Brown <neilb@suse.de> Tested-by: Joao Luis Meloni Assirati <assirati@nonada.if.usp.br> Cc: stable <stable@kernel.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (73 commits) net: Fix typo in net/core/sock.c. ppp: Do not free not yet unregistered net device. netfilter: xt_iprange: module aliases for xt_iprange netfilter: ctnetlink: dump conntrack ID in event messages irda: Fix a misalign access issue. (v2) sctp: Fix use of uninitialized pointer cipso: Relax too much careful cipso hash function. tcp FRTO: work-around inorder receivers tcp FRTO: Fix fallback to conventional recovery New maintainer for Intel ethernet adapters DM9000: Use delayed work to update MII PHY state DM9000: Update and fix driver debugging messages DM9000: Add __devinit and __devexit attributes to probe and remove sky2: fix simple define thinko [netdrvr] sfc: sfc: Add self-test support [netdrvr] sfc: Increment rx_reset when reported as driver event [netdrvr] sfc: Remove unused macro EFX_XAUI_RETRAIN_MAX [netdrvr] sfc: Fix code formatting [netdrvr] sfc: Remove kernel-doc comments for removed members of struct efx_nic [netdrvr] sfc: Remove garbage from comment ...
2008-05-14fix SMP data race in pagetable setup vs walkingNick Piggin
There is a possible data race in the page table walking code. After the split ptlock patches, it actually seems to have been introduced to the core code, but even before that I think it would have impacted some architectures (powerpc and sparc64, at least, walk the page tables without taking locks eg. see find_linux_pte()). The race is as follows: The pte page is allocated, zeroed, and its struct page gets its spinlock initialized. The mm-wide ptl is then taken, and then the pte page is inserted into the pagetables. At this point, the spinlock is not guaranteed to have ordered the previous stores to initialize the pte page with the subsequent store to put it in the page tables. So another Linux page table walker might be walking down (without any locks, because we have split-leaf-ptls), and find that new pte we've inserted. It might try to take the spinlock before the store from the other CPU initializes it. And subsequently it might read a pte_t out before stores from the other CPU have cleared the memory. There are also similar races in higher levels of the page tables. They obviously don't involve the spinlock, but could see uninitialized memory. Arch code and hardware pagetable walkers that walk the pagetables without locks could see similar uninitialized memory problems, regardless of whether split ptes are enabled or not. I prefer to put the barriers in core code, because that's where the higher level logic happens, but the page table accessors are per-arch, and open-coding them everywhere I don't think is an option. I'll put the read-side barriers in alpha arch code for now (other architectures perform data-dependent loads in order). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14read_barrier_depends arch fixletsNick Piggin
read_barrie_depends has always been a noop (not a compiler barrier) on all architectures except SMP alpha. This brings UP alpha and frv into line with all other architectures, and fixes incorrect documentation. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14USB: add association.hGreg Kroah-Hartman
This will be used by the wireless usb code, as well as potentially other USB code. Originally based on some .c code written by Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-13irda: Fix a misalign access issue. (v2)Graf Yang
Replace u16ho with put/get_unaligned functions Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: [ALSA] ASoC: Fix wrong enum count for jack_function in N810 machine driver [ALSA] ASoC: build fix for snd_soc_info_bool_ext [ALSA] ASoC: Fix TLV320AIC3X mono line output interconnect [ALSA] soc - fsl_ssi.c fix "BUG: scheduling while atomic" [ALSA] emux midi synthesizer doesn't honor SOFT_PEDAL-release event
2008-05-13fuse: add flag to turn on big writesMiklos Szeredi
Prior to 2.6.26 fuse only supported single page write requests. In theory all fuse filesystem should be able support bigger than 4k writes, as there's nothing in the API to prevent it. Unfortunately there's a known case in NTFS-3G where big writes cause filesystem corruption. There could also be other filesystems, where the lack of testing with big write requests would result in bugs. To prevent such problems on a kernel upgrade, disable big writes by default, but let filesystems set a flag to turn it on. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Szabolcs Szakacsits <szaka@ntfs-3g.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13memcg: fix possible panic when CONFIG_MM_OWNER=yKOSAKI Motohiro
When mm destruction happens, we should pass mm_update_next_owner() the old mm. But unfortunately new mm is passed in exec_mmap(). Thus, kernel panic is possible when a multi-threaded process uses exec(). Also, the owner member comment description is wrong. mm->owner does not necessarily point to the thread group leader. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: "Paul Menage" <menage@google.com> Cc: "KAMEZAWA Hiroyuki" <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13cpumask: remove bitmap_scnprintf_len and cpumask_scnprintf_lenPaul Jackson
They aren't used. They were briefly used as part of some other patches to provide an alternative format for displaying some /proc and /sys cpumasks. They probably should have been removed when those other patches were dropped, in favor of a different solution. Signed-off-by: Paul Jackson <pj@sgi.com> Cc: "Mike Travis" <travis@sgi.com> Cc: "Bert Wesarg" <bert.wesarg@googlemail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: random driver fixesJeff Dike
The random driver would essentially hang if the host's /dev/random returned -EAGAIN. There was a test of need_resched followed by a schedule inside the loop, but that didn't help and it's the wrong way to work anyway. The right way is to ask for an interrupt when there is input available from the host and handle it then rather than polling. Now, when the host's /dev/random returns -EAGAIN, the driver asks for a wakeup when there's randomness available again and sleeps. The interrupt routine just wakes up whatever processes are sleeping on host_read_wait. There is an atomic_t, host_sleep_count, which counts the number of processes waiting for randomness. When this reaches zero, the interrupt is disabled. An added complication is that async I/O notification was only recently added to /dev/random (by me), so essentially all hosts will lack it. So, we use the sigio workaround here, which is to have a separate thread poll on the descriptor and send an interrupt when there is input on it. This mechanism is activated when a process gets -EAGAIN (activating this multiple times is harmless, if a bit wasteful) and deactivated by the last process still waiting. The module name was changed from "random" to "hw_random" in order for udev to recognize it. The sigio workaround needed some changes. sigio_broken was added for cases when we know that async notification doesn't work. This is now called from maybe_sigio_broken, which deals with pts devices. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: use PAGE_SIZE in linker scriptsCyrill Gorcunov
This patch includes page.h header into linker scripts that allow us to use PAGE_SIZE macro instead of numeric constant. To be able to include page.h into linker scripts page.h is needed for some modification - i.e. we need to use __ASSEMBLY__ and _AC macro [jdike@linux.intel.com - fixed conflict with as-layout.h] Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: remove unused headerJeff Dike
From: Adrian Bunk <bunk@kernel.org> This patch removes the unused and broken (the normal asm/keyboard.h files no longer exists) include/asm-um/keyboard.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13[ALSA] ASoC: build fix for snd_soc_info_bool_extPhilipp Zabel
I suspect that snd_ctl_boolean_mono should have been snd_ctl_boolean_mono_info instead. This fixes the build for magician. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-12net: Allow netdevices to specify needed head/tailroomJohannes Berg
This patch adds needed_headroom/needed_tailroom members to struct net_device and updates many places that allocate sbks to use them. Not all of them can be converted though, and I'm sure I missed some (I mostly grepped for LL_RESERVED_SPACE) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12net: Set LL_MAX_HEADER properly for wireless.David S. Miller
Wireless networking, particularly with MESH enabled, has quite strong requirements for link-layer header space. Based upon some numbers and descriptions from Johannes Berg we use 96 (same as AX25) for plain wireless, and with mesh enabled we use 128. In the process, simplify the cpp conditional logic here by ordering the cases by those needing the most space down to those needing the least case. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12Make 'cond_resched()' nullification depend on PREEMPT_BKLLinus Torvalds
Because it's not correct with a non-preemptable BKL and just causes PREEMPT kernels to have longer latencies than non-PREEMPT ones (which is obviously not the point of it at all). Of course, that config option actually got removed as an option earlier, so for now this basically disables it entirely, but if BKL preemption is ever resurrected it will be a meaningful optimization. And in the meantime, it at least documents the intent of the code, while not doing the wrong thing. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-12Fix up 'need_resched()' definitionLinus Torvalds
We should not go through the task pointer to get at the thread info, since it's usually cheaper to just access the thread info directly. So don't make the code look up 'current', when we can just use the thread info accessor functions directly. This generally avoids one level of indirection and tends to work better together with code that also looks at other thread flags (eg preempt_count). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/hpa/linux-2.6-inttypesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hpa/linux-2.6-inttypes: types: s390: fix #ifdef reversal in <asm-s390/types.h>
2008-05-12Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (28 commits) [MIPS] Pb1000: bury the remnants of the PCI code [MIPS] Fix build failure in mips oprofile code [MIPS] fix warning message on SMP kernels [MIPS] markeins: build fix [MIPS] ELF handling - use SELFMAG instead of numeric constant [MIPS] Get rid of __ilog2 [MIPS] Fix __fls for non-MIPS32/MIPS64 cpus [MIPS] XXS1500 code style cleanup [MIPS] MTX-1 code style cleanup [MIPS] Pb1200/DBAu1200 code style cleanup [MIPS] Pb1550 code style cleanup [MIPS] Pb1500 code style cleanup [MIPS] Pb1100 code style cleanup [MIPS] Pb1000 code style cleanup [MIPS] DBAu1xx0 code style cleanup [MIPS] Alchemy PCI code style cleanup [MIPS] Alchemy common code style cleanup [MIPS] Alchemy common headers style cleanup [MIPS] Add empty argument parenthesis to GCC_IMM_ASM [MIPS] msp_hwbutton.c: minor irq handler cleanups ...
2008-05-12types: s390: fix #ifdef reversal in <asm-s390/types.h>H. Peter Anvin
The #ifdef for the integer types was reversed; the standard pattern in these files are: #ifndef __s390x__ /* 32-bit code */ #else /* 64-bit code */ #endif Stick with the original pattern, but make sure the 32-bit code actually comes first! Reported by Al Viro. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk>
2008-05-12[MIPS] Get rid of __ilog2Ralf Baechle
56a6b1eb7bfb5ace0b5cb9c149f502fbd101b8ab was a bit too conservative and left __ilog2 around which is only used as an internal function for other bitops. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Fix __fls for non-MIPS32/MIPS64 cpusThomas Bogendoerfer
Only MIPS32 and MIPS64 CPUs implement clz/dclz. Therefore don't export __ilog2() for non MIPS32/MIPS64 cpus and use generic __fls bitop code for these cpus. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1200/DBAu1200 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - initialization of a 'static' variable to 0; - space after opening and before closing parentheses; - missing space between 'for' and opening parenthesis; - macros with complex values not enclosed in parentheses; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used; - line over 80 characters. In addition to these changes, also do the following: - mention DBAu1200 board in the Makefile; - replace the group of #include/#ifdef directives by a single #include <au1xxx.h> since this header contains the needed stuff; - properly indent the blocks; - insert spaces between operator and its operands, remove excess spaces there; - remove needless parentheses and add some for clarity; - replace numeric literals/expressions with the matching macros; - remove space after the type cast's closing parenthesis; - reduce pb1200_setup_cascade() to the single 'return' statement; - reduce the number of printed empty lines in the so-called CPLD workaround; - remove #undef AU1X00_EXTERNAL_INT since that macro is not defined anywhere; - replace spaces after the macro name with tabs in the #define directives; - remove excess tabs after the macro name in the #define directives; - fix typo in the BCSR_RESETS_PWMR1mUX macro's name; - group all Pb1200 PCMCIA definitions together; - put the function's result type and name/parameters on the same line; - insert missing and remove excess new lines; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line and/or adding space/asterisk on their left side; - fix typos/errors, capitalize acronyms, etc. in the comments; - combine some comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1550 code style cleanupSergei Shtylyov
Fix a few errors and warnings given by checkpatch.pl: - macros with complex values not enclosed in parentheses; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - replace numeric literals with the matching macros; - properly indent the code and the array initializers; - insert spaces between operator and its operands, also remove excess spaces there; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array initializers; - replace spaces after the macro name with tabs in the #define directives, also sometimes insert space there for better looks; - remove excess tabs after the macro name in the #define directives; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1500 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - replace numeric literals/expressions with the matching macros; - insert spaces between operator and its operands; - properly indent the code and the array initializers; - remove useless #if dirctive from board_setup(); - remove needless parentheses; - remove unneeded type casts; - remove excess new lines; - make hexadecimal literals all lower case; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array initializers; - replace spaces after the macro name with tabs in the #define directives, also sometimes insert space there for better looks; - fix typos/errors, capitalize acronyms, etc. in the comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1100 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - space between asterisk and variable name; - use of C99 // comments; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - properly indent the code; - remove space after the type cast's closing parenthesis; - replace numeric literals/expressions with the matching macros; - replace spaces after the macro name with tabs in the #define directives, and sometimes insert spaces there; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1000 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - brace not on the same line with condition in the 'switch' statement; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - properly indent the 'switch' statement; - remove needless parentheses; - insert spaces between operator and its operands; - replace numeric literals/expressions with the matching macros; - remove useless #if dirctive from board_setup(); - remove unneeded numeric literal type casts; - remove space after the type cast's closing parenthesis; - replace spaces after the macro name with tabs in the #define directives, and sometimes insert spaces there; - remove excess new lines; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first/last line; - combine some comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] DBAu1xx0 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - macros with complex values not enclosed in parentheses; - leading spaces instead of tabs; - printk() without KERN_* facility level; - using simple_strtol() where strict_strtol() could be used; - line over 80 characters. In addition to these changes, also do the following: - initialize variable instead of assigning value later where it makes sense; - insert spaces between operator and its operands, also remove excess spaces there; - remove unneeded numeric literal type casts; - remove needless parentheses; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array initializers; - replace spaces after the macro name with tabs in the #define directives; - remove excess tabs after the macro name in the #define directives; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first/last line; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Alchemy common headers style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - space after opening and before closing parentheses; - opening brace following 'struct' not on the same line; - leading spaces instead of tabs; - use of C99 // comments; - macros with complex values not enclosed in parentheses; - missing space between the type and asterisk in a variable declaration; - space between asterisk and function name; - including <asm/io.h> instead of <linux/io.h> and <asm/irq.h> instead of <linux/irq.h>; - use of '__inline__' instead of 'inline'; - space between function name and opening parenthesis; - line over 80 characters. In addition to these changes, also do the following: - remove needless parentheses; - insert spaces between operator and its operands; - replace spaces after the macro name with tabs in the #define directives and after the type in the structure field declarations; - remove excess tabs after the macro name in the #define directives and in the 'extern' variable declarations; - remove excess spaces between # and define for the SSI_*_MASK macros to align with other such macros; - put '||' operator on the same line with its first operand; - properly indent multi-line function prototypes; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line and/or adding space/asterisk on their left side; - make two-line comments that only have one line of text one-line; - convert the large multi-line comment in au1xxx_ide.h into several one-liners, replace spaces with tabs there; - fix typos/errors, capitalize acronyms, etc. in the comments; - insert missing and remove excess new lines; - update MontaVista copyright; - remove Pete Popov's and Steve Longerbeam's old email addresses... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Add empty argument parenthesis to GCC_IMM_ASMRalf Baechle
This is to clarify that GCC_IMM_ASM does not take an argument as the context of the macro's invocation seems to imply. As suggested by Maciej W. Rozycki (macro@linux-mips.org). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] MT: Functional fixes and a little reformatting of APRP supportKevin D. Kissell
Signed-off-by: Kevin D. Kissell <kevink@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] ppc: More compile fixes [POWERPC] ppc: Don't run prom_init_check for arch/ppc builds [POWERPC] ppc: Include <asm/cacheflush.h> in kernel/ppc_ksyms.c [POWERPC] ppc: Use ebony_defconfig for defconfig [POWERPC] Fix default cputable entries for e200 and e500 families
2008-05-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Work around memory probing bug in openfirmware. sparc32: fix rtrap.S typo sparc32: Fix build.
2008-05-12[POWERPC] ppc: More compile fixesPaul Mackerras
This fixes a few more miscellaneous compile problems with ARCH=ppc. 1. Don't compile devres.c on ARCH=ppc, it doesn't have ioremap_flags. 2. Include <asm/irq.h> in setup.c for the __DO_IRQ_CANON definition. 3. Include <linux/proc_fs.h> in residual.c for the definition of create_proc_read_entry. 4. Fix xchg_ptr to be a static inline to eliminate a compiler warning. Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-12syncppp: Fix crashes.David S. Miller
The syncppp layer wants a mid-level netdev private pointer. It was using netdev->priv but that only worked by accident, and thus this scheme was broken when the device private allocation strategy changed. Add a proper mid-layer private pointer for uses like this, update syncppp and all users, and remove the HDLC_PPP broken tag from drivers/net/wan/Kconfig Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-11Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Convert some more new-style drivers to use module aliasing i2c: Match dummy devices by type i2c-sibyte: Mark i2c_sibyte_add_bus() as static i2c-sibyte: Correct a comment about frequency i2c: Improve the functionality documentation i2c: Improve smbus-protocol documentation i2c-piix4: Blacklist two mainboards i2c-piix4: Increase the intitial delay for the ServerWorks CSB5 i2c-mpc: Compare to NO_IRQ instead of zero
2008-05-11Add new 'cond_resched_bkl()' helper functionLinus Torvalds
It acts exactly like a regular 'cond_resched()', but will not get optimized away when CONFIG_PREEMPT is set. Normal kernel code is already preemptable in the presense of CONFIG_PREEMPT, so cond_resched() is optimized away (see commit 02b67cc3ba36bdba351d6c3a00593f4ec550d9d3 "sched: do not do cond_resched() when CONFIG_PREEMPT"). But when wanting to conditionally reschedule while holding a lock, you need to use "cond_sched_lock(lock)", and the new function is the BKL equivalent of that. Also make fs/locks.c use it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-11sparc32: Fix build.Robert Reif
Fix sparc32 build error due to undefined bool type. CC [M] fs/ocfs2/dlm/userdlm.o In file included from include/asm/sigcontext.h:6, from include/asm/signal.h:5, from include/linux/signal.h:4, from fs/ocfs2/dlm/userdlm.c:30: include/asm/ptrace.h:42: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘pt_regs_is_syscall’ include/asm/ptrace.h:47: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘pt_regs_clear_syscall’ make[3]: *** [fs/ocfs2/dlm/userdlm.o] Error 1 make[2]: *** [fs/ocfs2/dlm] Error 2 make[1]: *** [fs/ocfs2] Error 2 make: *** [fs] Error 2 Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-11i2c: Convert some more new-style drivers to use module aliasingJean Delvare
Update 3 more new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. These video drivers aren't used yet so converting them is trivial. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-11i2c: Match dummy devices by typeJean Delvare
As the old driver_name/type matching scheme is going away soon, change the dummy device mechanism to use the new matching scheme. This has the downside that dummy i2c clients can no longer choose their name, they'll all appear as "dummy" in sysfs and in log messages. I don't think it is a problem in practice though, as there is little reason to use these i2c clients to log messages. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: Fix debugger syscall restart interactions. sparc: Fix ptrace() detach. sparc32: Don't twiddle PT_DTRACE in exec. sparc video: remove open boot prom code
2008-05-11Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] revert new check-ready Status register logic
2008-05-11sparc: Fix debugger syscall restart interactions.David S. Miller
So, forever, we've had this ptrace_signal_deliver implementation which tries to handle all of the nasties that can occur when the debugger looks at a process about to take a signal. It's meant to address all of these issues inside of the kernel so that the debugger need not be mindful of such things. Problem is, this doesn't work. The idea was that we should do the syscall restart business first, so that the debugger captures that state. Otherwise, if the debugger for example saves the child's state, makes the child execute something else, then restores the saved state, we won't handle the syscall restart properly because we lose the "we're in a syscall" state. The code here worked for most cases, but if the debugger actually passes the signal through to the child unaltered, it's possible that we would do a syscall restart when we shouldn't have. In particular this breaks the case of debugging a process under a gdb which is being debugged by yet another gdb. gdb uses sigsuspend to wait for SIGCHLD of the inferior, but if gdb itself is being debugged by a top-level gdb we get a ptrace_stop(). The top-level gdb does a PTRACE_CONT with SIGCHLD to let the inferior gdb see the signal. But ptrace_signal_deliver() assumed the debugger would cancel out the signal and therefore did a syscall restart, because the return error was ERESTARTNOHAND. Fix this by simply making ptrace_signal_deliver() a nop, and providing a way for the debugger to control system call restarting properly: 1) Report a "in syscall" software bit in regs->{tstate,psr}. It is set early on in trap entry to a system call and is fully visible to the debugger via ptrace() and regsets. 2) Test this bit right before doing a syscall restart. We have to do a final recheck right after get_signal_to_deliver() in case the debugger cleared the bit during ptrace_stop(). 3) Clear the bit in trap return so we don't accidently try to set that bit in the real register. As a result we also get a ptrace_{is,clear}_syscall() for sparc32 just like sparc64 has. M68K has this same exact bug, and is now the only other user of the ptrace_signal_deliver hook. It needs to be fixed in the same exact way as sparc. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-11sparc: Fix ptrace() detach.David S. Miller
Forever we had a PTRACE_SUNOS_DETACH which was unconditionally recognized, regardless of the personality of the process. Unfortunately, this value is what ended up in the GLIBC sys/ptrace.h header file on sparc as PTRACE_DETACH and PT_DETACH. So continue to recognize this old value. Luckily, it doesn't conflict with anything we actually care about. Signed-off-by: David S. Miller <davem@davemloft.net>
