path: root/include
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: (46 commits) fs/9p: Make the writeback_fid owned by root fs/9p: Writeback dirty data before setattr fs/9p: call vmtruncate before setattr 9p opeation fs/9p: Properly update inode attributes on link fs/9p: Prevent multiple inclusion of same header fs/9p: Workaround vfs rename rehash bug fs/9p: Mark directory inode invalid for many directory inode operations fs/9p: Add . and .. dentry revalidation flag fs/9p: mark inode attribute invalid on rename, unlink and setattr fs/9p: Add support for marking inode attribute invalid fs/9p: Initialize root inode number for dotl fs/9p: Update link count correctly on different file system operations fs/9p: Add drop_inode 9p callback fs/9p: Add direct IO support in cached mode fs/9p: Fix inode i_size update in file_write fs/9p: set default readahead pages in cached mode fs/9p: Move writeback fid to v9fs_inode fs/9p: Add v9fs_inode fs/9p: Don't set stat.st_blocks based on nrpages fs/9p: Add inode hashing ...
2011-03-16Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (29 commits) ahci: add another PCI ID for marvell libata: Use 'bool' return value for ata_id_XXX sata_fsl: Update RX_WATER_MARK for TRANSCFG sata_fsl: Fix wrong Device Error Register usage libata: Include WWN ID in inquiry VPD emulation ata/pata_arasan_cf: fill dma chan->private from pdata->dma_priv ata: pata: Convert pr_*(DRV_NAME ...) to pr_fmt/pr_<level> pata_arasan_cf: fix printk format string warning pata_arasan_cf: Adding support for arasan compact flash host controller libata-sff: add ata_sff_queue_work() & ata_sff_queue_delayed_work() ahci: AHCI mode SATA patch for Intel Patsburg SATA RAID controller ahci: recognize Marvell 88se9125 PCIe SATA 6.0 Gb/s controller libata: remove ATA_FLAG_LPM libata: remove ATA_FLAG_NO_LEGACY libata: remove ATA_FLAG_MMIO libata: remove ATA_FLAG_{SRST|SATA_RESET} ipr/sas_ata: use mode mask macros from <linux/ata.h> sata_dwc_460ex: add debugging options sata_dwc_460ex: fix misuse of ata_get_cmd_descript() sata_dwc_460ex: fix return value of dma_dwc_xfer_setup() ...
2011-03-16Merge branch 'for-2.6.39' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu, x86: Add arch-specific this_cpu_cmpxchg_double() support percpu: Generic support for this_cpu_cmpxchg_double() alpha: use L1_CACHE_BYTES for cacheline size in the linker script percpu: align percpu readmostly subsection to cacheline Fix up trivial conflict in arch/x86/kernel/vmlinux.lds.S due to the percpu alignment having changed ("x86: Reduce back the alignment of the per-CPU data section")
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-15Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86: Clean up apic.c and apic.h x86: Remove superflous goal definition of tsc_sync x86: dt: Correct local apic documentation in device tree bindings x86: dt: Cleanup local apic setup x86: dt: Fix OLPC=y/INTEL_CE=n build rtc: cmos: Add OF bindings x86: ce4100: Use OF to setup devices x86: ioapic: Add OF bindings for IO_APIC x86: dtb: Add generic bus probe x86: dtb: Add support for PCI devices backed by dtb nodes x86: dtb: Add device tree support for HPET x86: dtb: Add early parsing of IO_APIC x86: dtb: Add irq domain abstraction x86: dtb: Add a device tree for CE4100 x86: Add device tree support x86: e820: Remove conditional early mapping in parse_e820_ext x86: OLPC: Make OLPC=n build again x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection x86: OLPC: Cleanup config maze completely x86: OLPC: Hide OLPC_OPENFIRMWARE config switch ... Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
2011-03-15Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (93 commits) x86, tlb, UV: Do small micro-optimization for native_flush_tlb_others() x86-64, NUMA: Don't call numa_set_distanc() for all possible node combinations during emulation x86-64, NUMA: Don't assume phys node 0 is always online in numa_emulation() x86-64, NUMA: Clean up initmem_init() x86-64, NUMA: Fix numa_emulation code with node0 without RAM x86-64, NUMA: Revert NUMA affine page table allocation x86: Work around old gas bug x86-64, NUMA: Better explain numa_distance handling x86-64, NUMA: Fix distance table handling mm: Move early_node_map[] reverse scan helpers under HAVE_MEMBLOCK x86-64, NUMA: Fix size of numa_distance array x86: Rename e820_table_* to pgt_buf_* bootmem: Move __alloc_memory_core_early() to nobootmem.c bootmem: Move contig_page_data definition to bootmem.c/nobootmem.c bootmem: Separate out CONFIG_NO_BOOTMEM code into nobootmem.c x86-64, NUMA: Seperate out numa_alloc_distance() from numa_set_distance() x86-64, NUMA: Add proper function comments to global functions x86-64, NUMA: Move NUMA emulation into numa_emulation.c x86-64, NUMA: Prepare numa_emulation() for moving NUMA emulation into a separate file x86-64, NUMA: Do not scan two times for setup_node_bootmem() ... Fix up conflicts in arch/x86/kernel/smpboot.c
2011-03-15Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (116 commits) x86: Enable forced interrupt threading support x86: Mark low level interrupts IRQF_NO_THREAD x86: Use generic show_interrupts x86: ioapic: Avoid redundant lookup of irq_cfg x86: ioapic: Use new move_irq functions x86: Use the proper accessors in fixup_irqs() x86: ioapic: Use irq_data->state x86: ioapic: Simplify irq chip and handler setup x86: Cleanup the genirq name space genirq: Add chip flag to force mask on suspend genirq: Add desc->irq_data accessor genirq: Add comments to Kconfig switches genirq: Fixup fasteoi handler for oneshot mode genirq: Provide forced interrupt threading sched: Switch wait_task_inactive to schedule_hrtimeout() genirq: Add IRQF_NO_THREAD genirq: Allow shared oneshot interrupts genirq: Prepare the handling of shared oneshot interrupts genirq: Make warning in handle_percpu_event useful x86: ioapic: Move trigger defines to io_apic.h ... Fix up trivial(?) conflicts in arch/x86/pci/xen.c due to genirq name space changes clashing with the Xen cleanups. The set_irq_msi() had moved to xen_bind_pirq_msi_to_irq().
2011-03-15Merge branch 'timers-rtc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-rtc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: RTC: Fix up rtc.txt documentation to reflect changes to generic rtc layer RTC: sa1100: Update the sa1100 RTC driver. RTC: Fix the cross interrupt issue on rtc-test. RTC: Remove UIE and PIE information from the sa1100 driver proc. RTC: Include information about UIE and PIE in RTC driver proc. RTC: Clean out UIE icotl implementations RTC: Cleanup rtc_class_ops->update_irq_enable() RTC: Cleanup rtc_class_ops->irq_set_freq() RTC: Cleanup rtc_class_ops->irq_set_state RTC: Initialize kernel state from RTC
2011-03-15Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits) posix-clocks: Check write permissions in posix syscalls hrtimer: Remove empty hrtimer_init_hres_timer() hrtimer: Update hrtimer->state documentation hrtimer: Update base[CLOCK_BOOTTIME].offset correctly timers: Export CLOCK_BOOTTIME via the posix timers interface timers: Add CLOCK_BOOTTIME hrtimer base time: Extend get_xtime_and_monotonic_offset() to also return sleep time: Introduce get_monotonic_boottime and ktime_get_boottime hrtimers: extend hrtimer base code to handle more then 2 clockids ntp: Remove redundant and incorrect parameter check mn10300: Switch do_timer() to xtimer_update() posix clocks: Introduce dynamic clocks posix-timers: Cleanup namespace posix-timers: Add support for fd based clocks x86: Add clock_adjtime for x86 posix-timers: Introduce a syscall for clock tuning. time: Splitout compat timex accessors ntp: Add ADJ_SETOFFSET mode bit time: Introduce timekeeping_inject_offset posix-timer: Update comment ... Fix up new system-call-related conflicts in arch/x86/ia32/ia32entry.S arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/syscall_table_32.S (name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some due to movement of get_jiffies_64() in: kernel/time.c
2011-03-15Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits) sched: Resched proper CPU on yield_to() sched: Allow users with sufficient RLIMIT_NICE to change from SCHED_IDLE policy sched: Allow SCHED_BATCH to preempt SCHED_IDLE tasks sched: Clean up the IRQ_TIME_ACCOUNTING code sched: Add #ifdef around irq time accounting functions sched, autogroup: Stop claiming ownership of the root task group sched, autogroup: Stop going ahead if autogroup is disabled sched, autogroup, sysctl: Use proc_dointvec_minmax() instead sched: Fix the group_imb logic sched: Clean up some f_b_g() comments sched: Clean up remnants of sd_idle sched: Wholesale removal of sd_idle logic sched: Add yield_to(task, preempt) functionality sched: Use a buddy to implement yield_task_fair() sched: Limit the scope of clear_buddies sched: Check the right ->nr_running in yield_task_fair() sched: Avoid expensive initial update_cfs_load(), on UP too sched: Fix switch_from_fair() sched: Simplify the idle scheduling class softirqs: Account ksoftirqd time as cpustat softirq ...
2011-03-15Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (184 commits) perf probe: Clean up probe_point_lazy_walker() return value tracing: Fix irqoff selftest expanding max buffer tracing: Align 4 byte ints together in struct tracer tracing: Export trace_set_clr_event() tracing: Explain about unstable clock on resume with ring buffer warning ftrace/graph: Trace function entry before updating index ftrace: Add .ref.text as one of the safe areas to trace tracing: Adjust conditional expression latency formatting. tracing: Fix event alignment: skb:kfree_skb tracing: Fix event alignment: mce:mce_record tracing: Fix event alignment: kvm:kvm_hv_hypercall tracing: Fix event alignment: module:module_request tracing: Fix event alignment: ftrace:context_switch and ftrace:wakeup tracing: Remove lock_depth from event entry perf header: Stop using 'self' perf session: Use evlist/evsel for managing perf.data attributes perf top: Don't let events to eat up whole header line perf top: Fix events overflow in top command ring-buffer: Remove unused #include <linux/trace_irq.h> tracing: Add an 'overwrite' trace_option. ...
2011-03-15Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rtmutex: tester: Remove the remaining BKL leftovers lockdep/timers: Explain in detail the locking problems del_timer_sync() may cause rtmutex: Simplify PI algorithm and make highest prio task get lock rwsem: Remove redundant asmregparm annotation rwsem: Move duplicate function prototypes to linux/rwsem.h rwsem: Unify the duplicate rwsem_is_locked() inlines rwsem: Move duplicate init macros and functions to linux/rwsem.h rwsem: Move duplicate struct rwsem declaration to linux/rwsem.h x86: Cleanup rwsem_count_t typedef rwsem: Cleanup includes locking: Remove deprecated lock initializers cred: Replace deprecated spinlock initialization kthread: Replace deprecated spinlock initialization xtensa: Replace deprecated spinlock initialization um: Replace deprecated spinlock initialization sparc: Replace deprecated spinlock initialization mips: Replace deprecated spinlock initialization cris: Replace deprecated spinlock initialization alpha: Replace deprecated spinlock initialization rtmutex-tester: Remove BKL tests
2011-03-15Merge branch 'core-futexes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: arm: Remove bogus comment in futex_atomic_cmpxchg_inatomic() futex: Deobfuscate handle_futex_death() plist: Add priority list test plist: Shrink struct plist_head futex,plist: Remove debug lock assignment from plist_node futex,plist: Pass the real head of the priority list to plist_del() futex: Sanitize futex ops argument types futex: Sanitize cmpxchg_futex_value_locked API futex: Remove redundant pagefault_disable in futex_atomic_cmpxchg_inatomic() futex: Avoid redudant evaluation of task_pid_vnr() futex: Update futex_wait_setup comments about locking
2011-03-15Merge branch 'core-debugobjects-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-debugobjects-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: debugobjects: Add hint for better object identification
2011-03-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (57 commits) tidy the trailing symlinks traversal up Turn resolution of trailing symlinks iterative everywhere simplify link_path_walk() tail Make trailing symlink resolution in path_lookupat() iterative update nd->inode in __do_follow_link() instead of after do_follow_link() pull handling of one pathname component into a helper fs: allow AT_EMPTY_PATH in linkat(), limit that to CAP_DAC_READ_SEARCH Allow passing O_PATH descriptors via SCM_RIGHTS datagrams readlinkat(), fchownat() and fstatat() with empty relative pathnames Allow O_PATH for symlinks New kind of open files - "location only". ext4: Copy fs UUID to superblock ext3: Copy fs UUID to superblock. vfs: Export file system uuid via /proc/<pid>/mountinfo unistd.h: Add new syscalls numbers to asm-generic x86: Add new syscalls for x86_64 x86: Add new syscalls for x86_32 fs: Remove i_nlink check from file system link callback fs: Don't allow to create hardlink for deleted file vfs: Add open by file handle support ...
2011-03-15Merge branch 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvmLinus Torvalds
* 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm: xen: suspend: remove xen_hvm_suspend xen: suspend: pull pre/post suspend hooks out into suspend_info xen: suspend: move arch specific pre/post suspend hooks into generic hooks xen: suspend: refactor non-arch specific pre/post suspend hooks xen: suspend: add "arch" to pre/post suspend hooks xen: suspend: pass extra hypercall argument via suspend_info struct xen: suspend: refactor cancellation flag into a structure xen: suspend: use HYPERVISOR_suspend for PVHVM case instead of open coding xen: switch to new schedop hypercall by default. xen: use new schedop interface for suspend xen: do not respond to unknown xenstore control requests xen: fix compile issue if XEN is enabled but XEN_PVHVM is disabled xen: PV on HVM: support PV spinlocks and IPIs xen: make the ballon driver work for hvm domains xen-blkfront: handle Xen major numbers other than XENVBD xen: do not use xen_info on HVM, set pv_info name to "Xen HVM" xen: no need to delay xen_setup_shutdown_event for hvm guests anymore
2011-03-15Merge branches 'stable/ia64', 'stable/blkfront-cleanup' and 'stable/cleanup' ↵Linus Torvalds
of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/ia64' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: ia64 build broken due to "xen: switch to new schedop hypercall by default." * 'stable/blkfront-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: Union the blkif_request request specific fields * 'stable/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: annotate functions which only call into __init at start of day xen p2m: annotate variable which appears unused xen: events: mark cpu_evtchn_mask_p as __refdata
2011-03-15Merge branch 'stable/irq.cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/irq.cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: events: remove dom0 specific xen_create_msi_irq xen: events: use xen_bind_pirq_msi_to_irq from xen_create_msi_irq xen: events: push set_irq_msi down into xen_create_msi_irq xen: events: update pirq_to_irq in xen_create_msi_irq xen: events: refactor xen_create_msi_irq slightly xen: events: separate MSI PIRQ allocation from PIRQ binding to IRQ xen: events: assume PHYSDEVOP_get_free_pirq exists xen: pci: collapse apic_register_gsi_xen_hvm and xen_hvm_register_pirq xen: events: return irq from xen_allocate_pirq_msi xen: events: drop XEN_ALLOC_IRQ flag to xen_allocate_pirq_msi xen: events: do not leak IRQ from xen_allocate_pirq_msi when no pirq available. xen: pci: only define xen_initdom_setup_msi_irqs if CONFIG_XEN_DOM0
2011-03-15Merge branches 'stable/irq.rework' and 'stable/pcifront-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/irq.rework' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/irq: Cleanup up the pirq_to_irq for DomU PV PCI passthrough guests as well. xen: Use IRQF_FORCE_RESUME xen/timer: Missing IRQF_NO_SUSPEND in timer code broke suspend. xen: Fix compile error introduced by "switch to new irq_chip functions" xen: Switch to new irq_chip functions xen: Remove stale irq_chip.end xen: events: do not free legacy IRQs xen: events: allocate GSIs and dynamic IRQs from separate IRQ ranges. xen: events: add xen_allocate_irq_{dynamic, gsi} and xen_free_irq xen:events: move find_unbound_irq inside CONFIG_PCI_MSI xen: handled remapped IRQs when enabling a pcifront PCI device. genirq: Add IRQF_FORCE_RESUME * 'stable/pcifront-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: pci/xen: When free-ing MSI-X/MSI irq->desc also use generic code. pci/xen: Cleanup: convert int** to int[] pci/xen: Use xen_allocate_pirq_msi instead of xen_allocate_pirq xen-pcifront: Sanity check the MSI/MSI-X values xen-pcifront: don't use flush_scheduled_work()
2011-03-15net/9p: Implement syncfs 9P operationAneesh Kumar K.V
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Small non-IO PDUs for zero-copy supporting transports.Venkateswararao Jujjuri (JV)
If a transport prefers payload to be sent separate from the PDU (P9_TRANS_PREF_PAYLOAD_SEP), there is no need to allocate msize PDU buffers(struct p9_fcall). This patch allocates only upto 4k buffers for this kind of transports and there won't be any change to the legacy transports. Hence, this patch on top of zero copy changes allows user to specify higher msizes through the mount option without hogging the kernel heap. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Add preferences to transport layer.Venkateswararao Jujjuri (JV)
This patch adds preferences field to the p9_trans_module. Through this, now transport layer can express its preference about the payload. i.e if payload neds to be part of the PDU or it prefers it to be sent sepearetly so that the transport layer can handle it in a better way. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Preparation and helper functions for zero copyVenkateswararao Jujjuri (JV)
This patch prepares p9_fcall structure for zero copy. Added fields send the payload buffer information to the transport layer. In addition it adds a 'private' field for the transport layer to store mapped/pinned page information so that it can be freed/unpinned during req_done. This patch also creates trans_common.[ch] to house helper functions. It adds the following helper functions. p9_release_req_pages - Release pages after the transaction. p9_nr_pages - Return number of pages needed to accomodate the payload. payload_gup - Translates user buffer into kernel pages. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15Merge commit 'v2.6.38' into x86/mmIngo Molnar
Conflicts: arch/x86/mm/numa_64.c Merge reason: Resolve the conflict, update the branch to .38. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-15libata: Use 'bool' return value for ata_id_XXXHannes Reinecke
Most ata_id_XXX inlines are simple tests, so we should set the return value to 'bool' here. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-15New kind of open files - "location only".Al Viro
New flag for open(2) - O_PATH. Semantics: * pathname is resolved, but the file itself is _NOT_ opened as far as filesystem is concerned. * almost all operations on the resulting descriptors shall fail with -EBADF. Exceptions are: 1) operations on descriptors themselves (i.e. close(), dup(), dup2(), dup3(), fcntl(fd, F_DUPFD), fcntl(fd, F_DUPFD_CLOEXEC, ...), fcntl(fd, F_GETFD), fcntl(fd, F_SETFD, ...)) 2) fcntl(fd, F_GETFL), for a common non-destructive way to check if descriptor is open 3) "dfd" arguments of ...at(2) syscalls, i.e. the starting points of pathname resolution * closing such descriptor does *NOT* affect dnotify or posix locks. * permissions are checked as usual along the way to file; no permission checks are applied to the file itself. Of course, giving such thing to syscall will result in permission checks (at the moment it means checking that starting point of ....at() is a directory and caller has exec permissions on it). fget() and fget_light() return NULL on such descriptors; use of fget_raw() and fget_raw_light() is needed to get them. That protects existing code from dealing with those things. There are two things still missing (they come in the next commits): one is handling of symlinks (right now we refuse to open them that way; see the next commit for semantics related to those) and another is descriptor passing via SCM_RIGHTS datagrams. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-15vfs: Export file system uuid via /proc/<pid>/mountinfoAneesh Kumar K.V
We add a per superblock uuid field. File systems should update the uuid in the fill_super callback Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-15unistd.h: Add new syscalls numbers to asm-genericAneesh Kumar K.V
2011-03-15vfs: Add open by file handle supportAneesh Kumar K.V
[AV: duplicate of open() guts removed; file_open_root() used instead] Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-15vfs: Add name to file handle conversion supportAneesh Kumar K.V
The syscall also return mount id which can be used to lookup file system specific information such as uuid in /proc/<pid>/mountinfo Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14New AT_... flag: AT_EMPTY_PATHAl Viro
For name_to_handle_at(2) we'll want both ...at()-style syscall that would be usable for non-directory descriptors (with empty relative pathname). Introduce new flag (AT_EMPTY_PATH) to deal with that and corresponding LOOKUP_EMPTY; teach user_path_at() and path_init() to deal with the latter. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: NFSROOT should default to "proto=udp" nfs4: remove duplicated #include NFSv4: nfs4_state_mark_reclaim_nograce() should be static NFSv4: Fix the setlk error handler NFSv4.1: Fix the handling of the SEQUENCE status bits NFSv4/4.1: Fix nfs4_schedule_state_recovery abuses NFSv4.1 reclaim complete must wait for completion NFSv4: remove duplicate clientid in struct nfs_client NFSv4.1: Retry CREATE_SESSION on NFS4ERR_DELAY sunrpc: Propagate errors from xs_bind() through xs_create_sock() (try3-resend) Fix nfs_compat_user_ino64 so it doesn't cause problems if bit 31 or 63 are set in fileid nfs: fix compilation warning nfs: add kmalloc return value check in decode_and_add_ds SUNRPC: Remove resource leak in svc_rdma_send_error() nfs: close NFSv4 COMMIT vs. CLOSE race SUNRPC: Close a race in __rpc_wait_for_completion_task()
2011-03-14exportfs: Return the minimum required handle sizeAneesh Kumar K.V
The exportfs encode handle function should return the minimum required handle size. This helps user to find out the handle size by passing 0 handle size in the first step and then redoing to the call again with the returned handle size value. Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14clean statfs-like syscalls upAl Viro
New helpers: user_statfs() and fd_statfs(), taking userland pathname and descriptor resp. and filling struct kstatfs. Syscalls of statfs family (native, compat and foreign - osf and hpux on alpha and parisc resp.) switched to those. Removes some boilerplate code, simplifies cleanup on errors... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14open-style analog of vfs_path_lookup()Al Viro
new function: file_open_root(dentry, mnt, name, flags) opens the file vfs_path_lookup would arrive to. Note that name can be empty; in that case the usual requirement that dentry should be a directory is lifted. open-coded equivalents switched to it, may_open() got down exactly one caller and became static. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14reduce vfs_path_lookup() to do_path_lookup()Al Viro
New lookup flag: LOOKUP_ROOT. nd->root is set (and held) by caller, path_init() starts walking from that place and all pathname resolution machinery never drops nd->root if that flag is set. That turns vfs_path_lookup() into a special case of do_path_lookup() *and* gets us down to 3 callers of link_path_walk(), making it finally feasible to rip the handling of trailing symlink out of link_path_walk(). That will not only simply the living hell out of it, but make life much simpler for unionfs merge. Trailing symlink handling will become iterative, which is a good thing for stack footprint in a lot of situations as well. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14get rid of nd->fileAl Viro
Don't stash the struct file * used as starting point of walk in nameidata; pass file ** to path_init() instead. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14switch do_filp_open() to struct open_flagsAl Viro
take calculation of open_flags by open(2) arguments into new helper in fs/open.c, move filp_open() over there, have it and do_sys_open() use that helper, switch exec.c callers of do_filp_open() to explicit (and constant) struct open_flags. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14untangle the "need_reval_dot" messAl Viro
instead of ad-hackery around need_reval_dot(), do the following: set a flag (LOOKUP_JUMPED) in the beginning of path, on absolute symlink traversal, on ".." and on procfs-style symlinks. Clear on normal components, leave unchanged on ".". Non-nested callers of link_path_walk() call handle_reval_path(), which checks that flag is set and that fs does want the final revalidate thing, then does ->d_revalidate(). In link_path_walk() all the return_reval stuff is gone. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14kill path_lookup()Al Viro
all remaining callers pass LOOKUP_PARENT to it, so flags argument can die; renamed to kern_path_parent() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14libata: Include WWN ID in inquiry VPD emulationHannes Reinecke
As per SAT-3 the WWN ID should be included in the VPD page 0x83 (device identification) emulation. Signed-off-by: Hannes Reinecke <hare@suse.de> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-14ata/pata_arasan_cf: fill dma chan->private from pdata->dma_privViresh Kumar
Some DMA controllers (eg: drivers/dma/dw_dmac*) allow platform specific configuration for dma transfers. User drivers need to set chan->private field of channel with pointer to configuration data. This patch takes dma_priv data from platform data and passes it to chan->private_data, in order to pass platform specific configuration to DMAC controller. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-14pata_arasan_cf: Adding support for arasan compact flash host controllerViresh Kumar
The Arasan CompactFlash Device Controller has three basic modes of operation: PC card ATA using I/O mode, PC card ATA using memory mode, PC card ATA using true IDE modes. Currently driver supports only True IDE mode. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-14libata-sff: add ata_sff_queue_work() & ata_sff_queue_delayed_work()Viresh Kumar
This patch adds ata_sff_queue_work() & ata_sff_queue_delayed_work() routine in libata-sff.c file. This routine can be used by ata drivers to use ata_sff_wq. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] target: Fix t_transport_aborted handling in LUN_RESET + active I/O shutdown
2011-03-12Merge branch 'irq/core' into x86/irqThomas Gleixner
Reason: Enabling irq threads and update to latest genirq functionality requires the core code Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-12Merge branch 'tip/futex/devel' of ↵Thomas Gleixner
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-rt into core/futexes futex,plist: Pass the real head of the priority list to plist_del() futex,plist: Remove debug lock assignment from plist_node plist: Shrink struct plist_head plist: Add priority list test
2011-03-12genirq: Add chip flag to force mask on suspendThomas Gleixner
On suspend we disable all interrupts in the core code, but this does not mask the interrupt line in the default implementation as we use a lazy disable approach. That means we mark the interrupt disabled, but leave the hardware unmasked. That's an optimization because we avoid the hardware access for the common case where no interrupt happens after we marked it disabled. If an interrupt happens, then the interrupt flow handler masks the line at the hardware level and marks it pending. Suspend makes use of this delayed disable as it "disables" all interrupts when preparing the suspend transition. Right before the system goes into hardware suspend state it checks whether one of the interrupts which is marked as a wakeup interrupt came in after disabling it. Most interrupt chips have a separate register which selects the interrupts which can wake up the system from suspend, so we don't have to mask any on the non wakeup interrupts. But now we have to deal with brilliant designed hardware which lacks such a wakeup configuration facility. For such hardware it's necessary to mask all non wakeup interrupts before going into suspend in order to avoid the wakeup from random interrupts. Rather than working around this in the affected interrupt chip implementations we can solve this elegant in the core code itself. Add a flag IRQCHIP_MASK_ON_SUSPEND which can be set by the irq chip implementation to indicate, that the interrupts which are not selected as wakeup sources must be masked in the suspend path. Mask them in the loop which checks the wakeup interrupts pending flag. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> LKML-Reference: <alpine.LFD.2.00.1103112112310.2787@localhost6.localdomain6>
2011-03-11NFSv4/4.1: Fix nfs4_schedule_state_recovery abusesTrond Myklebust
nfs4_schedule_state_recovery() should only be used when we need to force the state manager to check the lease. If we just want to start the state manager in order to handle a state recovery situation, we should be using nfs4_schedule_state_manager(). This patch fixes the abuses of nfs4_schedule_state_recovery() by replacing its use with a set of helper functions that do the right thing. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11plist: Shrink struct plist_headLai Jiangshan
struct plist_head is used in struct task_struct as well as struct rtmutex. If we can make it smaller, it will also make these structures smaller as well. The field prio_list in struct plist_head is seldom used and we can get its information from the plist_nodes. Removing this field will decrease the size of plist_head by half. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4D107982.9090700@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
