I have a Digi Neo 8 PCI card (114f:00b1) Serial controller: Digi
International Digi Neo 8 (rev 05)
that works with the jsm driver after using the following patch.
Signed-off-by: Adam Lackorzynski <adam@os.inf.tu-dresden.de>
Cc: Scott H Kilau <Scott_Kilau@digi.com>
Cc: Wendy Xiong <wendyx@us.ibm.com>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Now, early_pfn_in_nid(PFN, NID) may returns false if PFN is a hole.
and memmap initialization was not done. This was a trouble for
sparc boot.
To fix this, the PFN should be initialized and marked as PG_reserved.
This patch changes early_pfn_in_nid() return true if PFN is a hole.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reported-by: David Miller <davem@davemlloft.net>
Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x, 2.6.27.x, 2.6.28.x]
What's happening is that the assertion in mm/page_alloc.c:move_freepages()
is triggering:
BUG_ON(page_zone(start_page) != page_zone(end_page));
Once I knew this is what was happening, I added some annotations:
if (unlikely(page_zone(start_page) != page_zone(end_page))) {
printk(KERN_ERR "move_freepages: Bogus zones: "
"start_page[%p] end_page[%p] zone[%p]\n",
start_page, end_page, zone);
printk(KERN_ERR "move_freepages: "
"start_zone[%p] end_zone[%p]\n",
page_zone(start_page), page_zone(end_page));
"start_pfn[0x%lx] end_pfn[0x%lx]\n",
page_to_pfn(start_page), page_to_pfn(end_page));
"start_nid[%d] end_nid[%d]\n",
page_to_nid(start_page), page_to_nid(end_page));
And here's what I got:
move_freepages: Bogus zones: start_page[2207d0000] end_page[2207dffc0] zone[fffff8103effcb00]
move_freepages: start_zone[fffff8103effcb00] end_zone[fffff8003fffeb00]
move_freepages: start_pfn[0x81f600] end_pfn[0x81f7ff]
move_freepages: start_nid[1] end_nid[0]
My memory layout on this box is:
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x0081ff5d
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[8] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00020000
[ 0.000000] 1: 0x00800000 -> 0x0081f7ff
[ 0.000000] 1: 0x0081f800 -> 0x0081fe50
[ 0.000000] 1: 0x0081fed1 -> 0x0081fed8
[ 0.000000] 1: 0x0081feda -> 0x0081fedb
[ 0.000000] 1: 0x0081fedd -> 0x0081fee5
[ 0.000000] 1: 0x0081fee7 -> 0x0081ff51
[ 0.000000] 1: 0x0081ff59 -> 0x0081ff5d
So it's a block move in that 0x81f600-->0x81f7ff region which triggers
the problem.
This patch:
Declaration of early_pfn_to_nid() is scattered over per-arch include
files, and it seems it's complicated to know when the declaration is used.
I think it makes fix-for-memmap-init not easy.
This patch moves all declaration to include/linux/mm.h
After this,
if !CONFIG_NODES_POPULATES_NODE_MAP && !CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID
-> Use static definition in include/linux/mm.h
else if !CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID
-> Use generic definition in mm/page_alloc.c
else
-> per-arch back end function will be called.
The conversion of atmel-mci to dma_request_channel missed the
initialization of the channel dma_slave information. The filter_fn passed
to dma_request_channel is responsible for initializing the channel's
private data. This implementation has the additional benefit of enabling
a generic client-channel data passing mechanism.
Reviewed-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
YAMAMOTO-san noticed that task_dirty_inc doesn't seem to be called properly for
cases where set_page_dirty is not used to dirty a page (eg. mark_buffer_dirty).
Additionally, there is some inconsistency about when task_dirty_inc is
called. It is used for dirty balancing, however it even gets called for
__set_page_dirty_no_writeback.
So rather than increment it in a set_page_dirty wrapper, move it down to
exactly where the dirty page accounting stats are incremented.
Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp>
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
As requested by Michael, add a missing check for valid flags in
timerfd_settime(), and make it return EINVAL in case some extra bits are
set.
Michael said:
If this is to be any use to userland apps that want to check flag
support (perhaps it is too late already), then the sooner we get it
into the kernel the better: 2.6.29 would be good; earlier stables as
well would be even better.
[akpm@linux-foundation.org: remove unused TFD_FLAGS_SET]
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Cc: <stable@kernel.org> [2.6.27.x, 2.6.28.x]
Currently seq_read assumes that the offset passed to it is always the
offset it passed to user space. In the case pread this assumption is
broken and we do the wrong thing when presented with pread.
To solve this I introduce an offset cache inside of struct seq_file so we
know where our logical file position is. Then in seq_read if we try to
read from another offset we reset our data structures and attempt to go to
the offset user space wanted.
[akpm@linux-foundation.org: restore FMODE_PWRITE]
[pjt@google.com: seq_open needs its fmode opened up to take advantage of this]
Signed-off-by: Eric Biederman <ebiederm@xmission.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Paul Turner <pjt@google.com>
Separate FMODE_PREAD and FMODE_PWRITE into separate flags to reflect the
reality that the read and write paths may have independent restrictions.
A git grep verifies that these flags are always cleared together so this
new behavior will only apply to interfaces that change to clear flags
individually.
This is required for "seq_file: properly cope with pread", a post-2.6.25
regression fix.
[akpm@linux-foundation.org: add comment]
Signed-off-by: Paul Turner <pjt@google.com>
Cc: Eric Biederman <ebiederm@xmission.com>
We have get_vm_area_caller() and __get_vm_area() but not
__get_vm_area_caller()
On powerpc, I use __get_vm_area() to separate the ranges of addresses
given to vmalloc vs. ioremap (various good reasons for that) so in order
to be able to implement the new caller tracking in /proc/vmallocinfo, I
need a "_caller" variant of it.
(akpm: needed for ongoing powerpc development, so merge it early)
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Signed-off-by: Zlatko Calusic <zlatko.calusic@iskon.hr>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, vm86: fix preemption bug
x86, olpc: fix model detection without OFW
x86, hpet: fix for LS21 + HPET = boot hang
x86: CPA avoid repeated lazy mmu flush
x86: warn if arch_flush_lazy_mmu_cpu is called in preemptible context
x86/paravirt: make arch_flush_lazy_mmu/cpu disable preemption
x86, pat: fix warn_on_once() while mapping 0-1MB range with /dev/mem
x86/cpa: make sure cpa is safe to call in lazy mmu mode
x86, ptrace, mm: fix double-free on race
The macro doesn't expand correctly when its parameter isn't 'pte'.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: Fix NULL dereference in ext4_ext_migrate()'s error handling
ext4: Implement range_cyclic in ext4_da_writepages instead of write_cache_pages
ext4: Initialize preallocation list_head's properly
ext4: Fix lockdep warning
ext4: Fix to read empty directory blocks correctly in 64k
jbd2: Avoid possible NULL dereference in jbd2_journal_begin_ordered_truncate()
Revert "ext4: wait on all pending commits in ext4_sync_fs()"
jbd2: Fix return value of jbd2_journal_start_commit()
kvm_arch_sync_events is introduced to quiet down all other events may happen
contemporary with VM destroy process, like IRQ handler and work struct for
assigned device.
For kvm_arch_sync_events is called at the very beginning of kvm_destroy_vm(), so
the state of KVM here is legal and can provide a environment to quiet down other
events.
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Kconfig symbols are not available in userspace, and are not stripped by
headers-install. Avoid their use by adding #defines in <asm/kvm.h> to
suit each architecture.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ASoC: Only register AC97 bus if it's not done already
ALSA: hda - Add snd_hda_multi_out_dig_cleanup()
ALSA: hda - Add missing terminator in slave dig-out array
ALSA: hda - Change HP dv7 (103c:30f4) quirk from hp-m4 to hp-dv5 model
ALSA: hda - Register (new) devices at reconfig
ALSA: mtpav - Fix initial value for input hwport
ALSA: hda - add id for Intel IbexPeak integrated HDMI codec
ALSA: hda - compute checksum in HDMI audio infoframe
ALSA: hda - enable HDMI audio pin out at module loading time
ALSA: hda - allow multi-channel HDMI audio playback when ELD is not present
ASoC: Update SDP3430 machine driver for snd_soc_card
ALSA: hda - Add quirk for Asus z37e (1043:8284)
sound: Remove OSSlib stuff from linux/soundcard.h
ASoC: WM8990: Fix kcontrol's private value use in put callback
ASoC: TLV320AIC3X: Fix kcontrol's private value use in put callback
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits)
wimax: fix oops in wimax_dev_get_by_genl_info() when looking up non-wimax iface
net: 4 bytes kernel memory disclosure in SO_BSDCOMPAT gsopt try #2
netxen: fix compile waring "label ‘set_32_bit_mask’ defined but not used" on IA64 platform
bnx2: Update version to 1.9.2 and copyright.
bnx2: Fix jumbo frames error handling.
bnx2: Update 5709 firmware.
bnx2: Update 5706/5708 firmware.
3c505: do not set pcb->data.raw beyond its size
Documentation/connector/cn_test.c: don't use gfp_any()
net: don't use in_atomic() in gfp_any()
IRDA: cnt is off by 1
netxen: remove pcie workaround
sun3: print when lance_open() fails
qlge: bugfix: Add missing rx buf clean index on early exit.
qlge: bugfix: Fix RX scaling values.
qlge: bugfix: Fix TSO breakage.
qlge: bugfix: Add missing dev_kfree_skb_any() call.
qlge: bugfix: Add missing put_page() call.
qlge: bugfix: Fix fatal error recovery hang.
qlge: bugfix: Use netif_receive_skb() and vlan_hwaccel_receive_skb().
The problem is that in_atomic() will return false inside spinlocks if
CONFIG_PREEMPT=n. This will lead to deadlockable GFP_KERNEL allocations
from spinlocked regions.
Secondly, if CONFIG_PREEMPT=y, this bug solves itself because networking
will instead use GFP_ATOMIC from this callsite. Hence we won't get the
might_sleep() debugging warnings which would have informed us of the buggy
callsites.
Solve both these problems by switching to in_interrupt(). Now, if someone
runs a gfp_any() allocation from inside spinlock we will get the warning
if CONFIG_PREEMPT=y.
I reviewed all callsites and most of them were too complex for my little
brain and none of them documented their interface requirements. I have no
idea what this patch will do.
With the new system call defines we get this on uml:
arch/um/sys-i386/built-in.o: In function `sys_call_table':
(.rodata+0x308): undefined reference to `sys_sigprocmask'
Reason for this is that uml passes the preprocessor option
-Dsigprocmask=kernel_sigprocmask to gcc when compiling the kernel.
This causes SYSCALL_DEFINE3(sigprocmask, ...) to be expanded to
SYSCALL_DEFINEx(3, kernel_sigprocmask, ...) and finally to a system
call named sys_kernel_sigprocmask. However sys_sigprocmask is missing
because of this.
To avoid macro expansion for the system call name just concatenate the
name at first define instead of carrying it through severel levels.
This was pointed out by Al Viro.
Reviewed-by: WANG Cong <wangcong@zeuux.org>
I enabled all cgroup subsystems when compiling kernel, and then:
# mount -t cgroup -o net_cls xxx /mnt
# mkdir /mnt/0
This showed up immediately:
BUG: MAX_LOCKDEP_SUBCLASSES too low!
turning off the locking correctness validator.
It's caused by the cgroup hierarchy lock:
for (i = 0; i < CGROUP_SUBSYS_COUNT; i++) {
struct cgroup_subsys *ss = subsys[i];
if (ss->root == root)
mutex_lock_nested(&ss->hierarchy_mutex, i);
Now we have 9 cgroup subsystems, and the above 'i' for net_cls is 8, but
MAX_LOCKDEP_SUBCLASSES is 8.
This patch uses different lockdep keys for different subsystems.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Paul Menage <menage@google.com>
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
timers: fix TIMER_ABSTIME for process wide cpu timers
timers: split process wide cpu clocks/timers, fix
x86: clean up hpet timer reinit
timers: split process wide cpu clocks/timers, remove spurious warning
signal: re-add dead task accumulation stats.
x86: fix hpet timer reinit for x86_64
sched: fix nohz load balancer on cpu offline
Ptrace_detach() races with __ptrace_unlink() if the traced task is
reaped while detaching. This might cause a double-free of the BTS
buffer.
Change the ptrace_detach() path to only do the memory accounting in
ptrace_bts_detach() and leave the buffer free to ptrace_bts_untrace()
which will be called from __ptrace_unlink().
The fix follows a proposal from Oleg Nesterov.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Signed-off-by: Markus Metzger <markus.t.metzger@intel.com>
The POSIX timer interface allows for absolute time expiry values through the
TIMER_ABSTIME flag, therefore we have to synchronize the timer to the clock
every time we start it.
To decrease the chance of a missed enable, always enable the timer when we
sample it, we'll always disable it when we find that there are no active timers
in the jiffy tick.
This fixes a flood of warnings reported by Mike Galbraith.
Reported-by: Mike Galbraith <efault@gmx.de>
Using u32 in this header breaks the build of iptables.
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
Fix regression due to 5a6fe125950676015f5108fb71b2a67441755003,
"Do not account for the address space used by hugetlbfs using VM_ACCOUNT"
which added an argument to the function hugetlb_file_setup() but not to
the macro hugetlb_file_setup().
Reported-by: Chris Clayton <chris2553@googlemail.com>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Acked-by: Mel Gorman <mel@csn.ul.ie>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (23 commits)
bridge: Fix LRO crash with tun
IPv6: fix to set device name when new IPv6 over IPv6 tunnel device is created.
gianfar: Fix boot hangs while bringing up gianfar ethernet
netfilter: xt_sctp: sctp chunk mapping doesn't work
netfilter: ctnetlink: fix echo if not subscribed to any multicast group
netfilter: ctnetlink: allow changing NAT sequence adjustment in creation
netfilter: nf_conntrack_ipv6: don't track ICMPv6 negotiation message
netfilter: fix tuple inversion for Node information request
netxen: fix msi-x interrupt handling
de2104x: force correct order when writing to rx ring
tun: Fix unicast filter overflow
drivers/isdn: introduce missing kfree
drivers/atm: introduce missing kfree
sunhme: Don't match PCI devices in SBUS probe.
9p: fix endian issues [attempt 3]
net_dma: call dmaengine_get only if NET_DMA enabled
3c509: Fix resume from hibernation for PnP mode.
sungem: Soft lockup in sungem on Netra AC200 when switching interface up
RxRPC: Fix a potential NULL dereference
r8169: Don't update statistics counters when interface is down
When overcommit is disabled, the core VM accounts for pages used by anonymous
shared, private mappings and special mappings. It keeps track of VMAs that
should be accounted for with VM_ACCOUNT and VMAs that never had a reserve
with VM_NORESERVE.
Overcommit for hugetlbfs is much riskier than overcommit for base pages
due to contiguity requirements. It avoids overcommiting on both shared and
private mappings using reservation counters that are checked and updated
during mmap(). This ensures (within limits) that hugepages exist in the
future when faults occurs or it is too easy to applications to be SIGKILLed.
As hugetlbfs makes its own reservations of a different unit to the base page
size, VM_ACCOUNT should never be set. Even if the units were correct, we would
double account for the usage in the core VM and hugetlbfs. VM_NORESERVE may
be set because an application can request no reserves be made for hugetlbfs
at the risk of getting killed later.
With commit fc8744adc870a8d4366908221508bb113d8b72ee, VM_NORESERVE and
VM_ACCOUNT are getting unconditionally set for hugetlbfs-backed mappings. This
breaks the accounting for both the core VM and hugetlbfs, can trigger an
OOM storm when hugepage pools are too small lockups and corrupted counters
otherwise are used. This patch brings hugetlbfs more in line with how the
core VM treats VM_NORESERVE but prevents VM_ACCOUNT being set.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
If we race with commit code setting i_transaction to NULL, we could
possibly dereference it. Proper locking requires the journal pointer
(to access journal->j_list_lock), which we don't have. So we have to
change the prototype of the function so that filesystem passes us the
journal pointer. Also add a more detailed comment about why the
function jbd2_journal_begin_ordered_truncate() does what it does and
how it should be used.
Thanks to Dan Carpenter <error27@gmail.com> for pointing to the
suspitious code.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Acked-by: Joel Becker <joel.becker@oracle.com>
CC: linux-ext4@vger.kernel.org
CC: ocfs2-devel@oss.oracle.com
CC: mfasheh@suse.de
CC: Dan Carpenter <error27@gmail.com>
Removed OSSlib stuff from linux/soundcard.h to fix the warnings for
'make headers_check'.
This patch breaks building against OSSlib with the kernel headers
instead of its own headers. It should still work with any
version of the library from the 2003 onwards which provide
their own headers for the latest interface.
Cc: Jaswinder Singh Rajput <jaswinder@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/i915: select framebuffer support automatically
drm/i915: add get_vblank_counter function for GM45
drm/i915: capture last_vblank count at IRQ uninstall time too
drm/i915: Unlock mutex on i915_gem_fault() error path
drm/i915: Quiet the message on get/setparam ioctl with an unknown value.
drm/i915: skip LVDS initialization on Apple Mac Mini
drm/i915: sync SDVO code with stable userland modesetting driver
drm/i915: Unref the object after failing to set tiling mode.
drm/i915: add fence register management to execbuf
drm/i915: Return error from i915_gem_object_get_fence_reg() when failing.
drm/i915: Set up an MTRR covering the GTT at driver load.
drm/i915: Skip SDVO/HDMI init when the chipset tells us it's not present.
drm/i915: Suppress GEM teardown on X Server exit in KMS mode.
drm/radeon: fix ioremap conflict with AGP mappings
i915: fix unneeded locking in i915 LVDS get modes code.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: scatterwalk - Avoid flush_dcache_page on slab pages
crypto: shash - Fix tfm destruction
crypto: api - Fix zeroing on free
crypto: shash - Fix module refcount
crypto: api - Fix algorithm test race that broke aead initialisation
Architectures other than mips and x86 are not using ticket spinlocks.
Therefore, the contention on the lock is meaningless, since there is
nobody known to be waiting on it (arguably /fairly/ unfair locks).
Dummy it out to return 0 on other architectures.
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Rename the async_*_special() functions to async_*_domain(), which
describes the purpose of these functions much better.
[Broke up long lines to silence checkpatch]
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Adds code to set up fence registers at execbuf time on pre-965 chips as
necessary. Also fixes up a few bugs in the pre-965 tile register support
(get_order != ffs). The number of fences available to the kernel defaults
to the hw limit minus 3 (for legacy X front/back/depth), but a new parameter
allows userspace to override that as needed.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Dave Airlie <airlied@linux.ie>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI PM: make the PM core more careful with drivers using the new PM framework
PCI PM: Read power state from device after trying to change it on resume
PCI PM: Do not disable and enable bridges during suspend-resume
PCI: PCIe portdrv: Simplify suspend and resume
PCI PM: Fix saving of device state in pci_legacy_suspend
PCI PM: Check if the state has been saved before trying to restore it
PCI PM: Fix handling of devices without drivers
PCI: return error on failure to read PCI ROMs
PCI: properly clean up ASPM link state on device remove
Impact: fix spurious BUG_ON() triggered under load
module_refcount() isn't reliable outside stop_machine(), as demonstrated
by Karsten Keil <kkeil@suse.de>, networking can trigger it under load
(an inc on one cpu and dec on another while module_refcount() is tallying
can give false results, for example).
Almost noone should be using __module_get, but that's another issue.
Cc: Karsten Keil <kkeil@suse.de>
'ec', 'misc', 'printk' and 'processor' into release
Based upon a patch from Atsushi Nemoto <anemo@mba.ocn.ne.jp>
The commit 649274d993212e7c23c0cb734572c2311c200872 ("net_dma:
acquire/release dma channels on ifup/ifdown") added unconditional call
of dmaengine_get() to net_dma. The API should be called only if
NET_DMA was enabled.
Acked-by: Dan Williams <dan.j.williams@intel.com>
Bit 11 in intel PDC definitions is meant for OS capability to handle
hardware coordination of P-states. In Linux we have always supported
hwardware coordination of P-states. Just let the BIOSes know that we
support it, by setting this bit.
Some BIOSes use this bit to choose between hardware or software coordination
and without this change below, BIOSes switch to software coordination, which
is not very optimal in terms of power consumption and extra wakeups from idle.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Mike Galbraith reported that the new warning in thread_group_cputimer()
triggers en masse with Amarok running.
Oleg Nesterov observed:
Can't fastpath_timer_check()->thread_group_cputimer() have the
false warning too? Suppose we had the timer, then posix_cpu_timer_del()
removes this timer, but task_cputime_zero(&sig->cputime_expires) still
not true.
Remove the spurious debug warning.
Explained-by: Oleg Nesterov <oleg@redhat.com>
Fix namespace violations by changing non-kconfig CONFIG_ names to CNFG_*.
Fixes breakage in staging/, which adds a real CONFIG_PANEL.
With exclusive waiters, every process woken up through the wait queue must
ensure that the next waiter down the line is woken when it has finished.
Interruptible waiters don't do that when aborting due to a signal. And if
an aborting waiter is concurrently woken up through the waitqueue, noone
will ever wake up the next waiter.
This has been observed with __wait_on_bit_lock() used by
lock_page_killable(): the first contender on the queue was aborting when
the actual lock holder woke it up concurrently. The aborted contender
didn't acquire the lock and therefor never did an unlock followed by
waking up the next waiter.
Add abort_exclusive_wait() which removes the process' wait descriptor from
the waitqueue, iff still queued, or wakes up the next waiter otherwise.
It does so under the waitqueue lock. Racing with a wake up means the
aborting process is either already woken (removed from the queue) and will
wake up the next waiter, or it will remove itself from the queue and the
concurrent wake up will apply to the next waiter after it.
Use abort_exclusive_wait() in __wait_event_interruptible_exclusive() and
__wait_on_bit_lock() when they were interrupted by other means than a wake
up through the queue.
Reported-by: Chris Mason <chris.mason@oracle.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Mentored-by: Oleg Nesterov <oleg@redhat.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Chuck Lever <cel@citi.umich.edu>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: <stable@kernel.org> ["after some testing"]
Avoid calling copy_from/to_user() with fb_info->lock mutex held in fbmem
ioctl().
fb_mmap() is called under mm->mmap_sem (A) held, that also acquires
fb_info->lock (B); fb_ioctl() takes fb_info->lock (B) and does
copy_from/to_user() that might acquire mm->mmap_sem (A), causing a
deadlock.
NOTE: it doesn't push down the fb_info->lock in each own driver's
fb_ioctl(), so there are still potential deadlocks elsewhere.
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
Cc: Dave Jones <davej@redhat.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Johannes Weiner <hannes@saeurebad.de>
Cc: Krzysztof Helt <krzysztof.h1@wp.pl>
Cc: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
The swap() macro is accidentally retuning the value of its first argument.
Change it into a doesn't-return-anything macro before someone goes and
relies upon this behaviour.
Cc: Wu Fengguang <wfg@linux.intel.com>
Change the process wide cpu timers/clocks so that we:
1) don't mess up the kernel with too many threads,
2) don't have a per-cpu allocation for each process,
3) have no impact when not used.
In order to accomplish this we're going to split it into two parts:
- clocks; which can take all the time they want since they run
from user context -- ie. sys_clock_gettime(CLOCK_PROCESS_CPUTIME_ID)
- timers; which need constant time sampling but since they're
explicity used, the user can pay the overhead.
The clock readout will go back to a full sum of the thread group, while the
timers will run of a global 'clock' that only runs when needed, so only
programs that make use of the facility pay the price.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
We're going to split the process wide cpu accounting into two parts:
from user context.
- timers; which need constant time tracing but can affort the overhead
because they're default off -- and rare.
The clock readout will go back to a full sum of the thread group, for this
we need to re-add the exit stats that were removed in the initial itimer
rework (f06febc9: timers: fix itimer/many thread hang).
Furthermore, since that full sum can be rather slow for large thread groups
and we have the complete dead task stats, revert the do_notify_parent time
computation.
We were freeing an offset into the slab object instead of the
start. This patch fixes it by calling crypto_destroy_tfm which
allows the correct address to be given.
Geert Uytterhoeven pointed out that we're not zeroing all the
memory when freeing a transform. This patch fixes it by calling
ksize to ensure that we zero everything in sight.
Reported-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
This patch makes the ROM reading code return an error to user space if
the size of the ROM read is equal to 0.
The patch also emits a warnings if the contents of the ROM are invalid,
and documents the effects of the "enable" file on ROM reading.
Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au>
Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com>
