path: root/include
2006-09-28[SUNRPC]: trivial endianness annotationsAlexey Dobriyan
pure s/u32/__be32/ [AV: large part based on Alexey's patches] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[SUNRPC]: svc_{get,put}nl()Alexey Dobriyan
* add svc_getnl(): Take network-endian value from buffer, convert to host-endian and return it. * add svc_putnl(): Take host-endian value, convert to network-endian and put it into a buffer. * annotate svc_getu32()/svc_putu32() as dealing with network-endian. * convert to svc_getnl(), svc_putnl(). [AV: in large part it's a carved-up Alexey's patch] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: ip_build_and_send_pkt() annotationsAl Viro
saddr and daddr are net-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: ip_options_build() annotationsAl Viro
daddr is net-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: multipath_set_nhinfo() annotationsAl Viro
multipath_set_nhinfo() (and underlying callback) take net-endian network and netmask. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate addresses in fib_result and fib_result_nlAl Viro
2006-09-28[IPV4]: inetpeer annotationsAl Viro
This one is interesting - we use net-endian value as search key, but order the tree by *host-endian* comparisons of keys. OK since we only care about lookups. Annotated inet_getpeer() and friends. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: ip_fib_check_default() annotatedAl Viro
2006-09-28[IPV4]: inet_addr_type() annotationsAl Viro
argument and inferred net-endian variables in callers annotated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: icmp_send() annotationAl Viro
The last argument is network-endian (it will go straight into the packet). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate inetdev.h helpersAl Viro
inet_confirm_addr(), inet_ifa_byprefix(), ip_dev_find(), inet_make_mask() and inet_ifa_match() annotated, along with inferred net-endian variables Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate struct in_ifaddrAl Viro
ifa_local, ifa_address, ifa_mask, ifa_broadcast and ifa_anycast are net-endian. Annotated them and variables that are inferred to be net-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: struct fib_config IPv4 address fields annotatedAl Viro
2006-09-28[IPV4]: introduce nla_get_be32()/NLA_PUT_BE32()Al Viro
net-endian counterparts of nla_get_u32()/NLA_PUT_U32() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: FIB_RES_PREFSRC() annotatedAl Viro
2006-09-28[IPV4]: fib_hn ->nh_gw is net-endianAl Viro
2006-09-28[IPV4]: inet_addr_onlink() annotatedAl Viro
2006-09-28[IPV4]: ip_check_mc() annotationsAl Viro
annotated arguments Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: fib_validate_source() annotationsAl Viro
annotated arguments and inferred net-endian variables in callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: inet_select_addr() annotationsAl Viro
argument and return value are net-endian. Annotated function and inferred net-endian variables in callers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotated ipv4 addresses in struct inet_sockAl Viro
2006-09-28[IPV4]: ip_route_connect() ipv4 address arguments annotatedAl Viro
annotated address arguments (port number left alone for now); ditto for inferred net-endian variables in callers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate ipv4 addresses in struct rtable and struct flowiAl Viro
2006-09-28[IPV4]: ip_rt_redirect() annotationsAl Viro
The first 4 arguments of ip_rt_redirect() are net-endian. Annotated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: ip_route_input() annotationsAl Viro
ip_route_input() takes net-endian source and destination address. * Annotated as such. * arguments of its invocations annotated where needed. * local helpers getting the same values passed to by it (ip_route_input_mc(), ip_route_input_slow(), ip_handle_martian_source(), ip_mkroute_input(), ip_mkroute_input_def(), __mkroute_input()) annotated Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: headers endiannessAl Viro
2006-09-28[TR]: endiannness annotationsAl Viro
2006-09-28[ATALK]: endianness annotationsAl Viro
2006-09-28Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/hwmon-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/hwmon-2.6: (39 commits) hwmon: Remove Yuan Mu's address hwmon: Fix unchecked return status, SMSC chips hwmon: Fix unchecked return status, batch 6 w83792d: Fix unchecked return status w83l785ts: Fix unchecked return status w83781d: Fix unchecked return status vt8231: Fix unchecked return status Fix unchecked return status, batch 5 hwmon: Fix unchecked return status, batch 4 hwmon: Fix unchecked return status, batch 3 hwmon: Fix unchecked return status, batch 2 w83627ehf: Fix unchecked return status pc87360: Check for error on sysfs files creation pc87360: Delete sysfs files on device deletion pc87360: Move some code around hwmon: Fix unchecked return status, batch 1 vt1211: Document module parameters vt1211: Add documentation hwmon: New driver for the VIA VT1211 w83791d: Documentation update ...
2006-09-28USB: fix autosuspend when CONFIG_PM isn't setAlan Stern
This patch (as791b) fixes things up to avoid compiler warnings or errors when CONFIG_USB_SUSPEND or CONFIG_PM isn't set. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-28hwmon: New driver k8tempRudolf Marek
Add support for the temperature sensor(s) found in AMD K8 CPUs. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-28Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (130 commits) [ARM] 3856/1: Add clocksource for Intel IXP4xx platforms [ARM] 3855/1: Add generic time support [ARM] 3873/1: S3C24XX: Add irq_chip names [ARM] 3872/1: S3C24XX: Apply consistant tabbing to irq_chips [ARM] 3871/1: S3C24XX: Fix ordering of EINT4..23 [ARM] nommu: confirms the CR_V bit in nommu mode [ARM] nommu: abort handler fixup for !CPU_CP15_MMU cores. [ARM] 3870/1: AT91: Start removing static memory mappings [ARM] 3869/1: AT91: NAND support for DK and KB9202 boards [ARM] 3868/1: AT91 hardware header update [ARM] 3867/1: AT91 GPIO update [ARM] 3866/1: AT91 clock update [ARM] 3865/1: AT91RM9200 header updates [ARM] 3862/2: S3C2410 - add basic power management support for AML M5900 series [ARM] kthread: switch arch/arm/kernel/apm.c [ARM] Off-by-one in arch/arm/common/icst* [ARM] 3864/1: Refactore sharpsl_pm [ARM] 3863/1: Add Locomo SPI Device [ARM] 3847/2: Convert LOMOMO to use struct device for GPIOs [ARM] Use CPU_CACHE_* where possible in asm/cacheflush.h ...
2006-09-28Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-mmc: [MMC] Don't check READY_FOR_DATA when reading [MMC] MMC_CAP_BYTEBLOCK flag for non-log2 block sizes capable hosts [MMC] Add multi block-write capability [MMC] Remove data->blksz_bits member [MMC] Convert mmci to use data->blksz rather than data->blksz_bits
2006-09-28Merge nommu branchRussell King
2006-09-28[ARM] 3856/1: Add clocksource for Intel IXP4xx platformsKevin Hilman
Enables the ixp4xx platforms to use Generic time-of-day. Signed-off-by: Kevin Hilman <khilman@mvista.com> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3855/1: Add generic time supportKevin Hilman
This patch adds Generic time-of-day support for the ARM architecture. The support is currently added using #ifdef's so that it can support sub-arches that do not (yet) have a clocksource added. As sub-arches add clocksource support, they should 'select GENERIC_TIME' Signed-off-by: Deepak Saxena <dsaxena@mvista.com> Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Kevin Hilman <khilman@mvista.com> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3870/1: AT91: Start removing static memory mappingsAndrew Victor
This patch removes the static memory mapping for the currently-unused peripherals [Synchronous Serial, Timer/Counter unit], and for those drivers that already ioremap() their registers [UART]. Also, the Ethernet driver now uses the platform_device resources but doesn't yet use ioremap() so we need to pass it the virtual address instead of the physical address. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[S390] Inline assembly cleanup.Martin Schwidefsky
Major cleanup of all s390 inline assemblies. They now have a common coding style. Quite a few have been shortened, mainly by using register asm variables. Use of the EX_TABLE macro helps as well. The atomic ops, bit ops and locking inlines new use the Q-constraint if a newer gcc is used. That results in slightly better code. Thanks to Christian Borntraeger for proof reading the changes. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-28[S390] __div64_32 for 31 bit.Martin Schwidefsky
The clocksource infrastructure introduced with commit ad596171ed635c51a9eef829187af100cbf8dcf7 broke 31 bit s390. The reason is that the do_div() primitive for 31 bit always had a restriction: it could only divide an unsigned 64 bit integer by an unsigned 31 bit integer. The clocksource code now uses do_div() with a base value that has the most significant bit set. The result is that clock->cycle_interval has a funny value which causes the linux time to jump around like mad. The solution is "obvious": implement a proper __div64_32 function for 31 bit s390. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-28[ARM] 3868/1: AT91 hardware header updateAndrew Victor
This patch adds the hardware register definitions for the TWI (I2C) controller found on the AT91RM9200 and AT91SAM9xx processors. It also defines the AIC Fast-Forcing registers added to the AT91SAM9's. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3867/1: AT91 GPIO updateAndrew Victor
This patch makes the AT91 gpio.c support processor-generic (AT91RM9200 and AT91SAM9xxx). The GPIO controllers supported by a particular AT91 processor are defined in the processor-specific file and are registered with gpio.c at startup. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3865/1: AT91RM9200 header updatesAndrew Victor
This is more preparation for adding support for the new Atmel AT91SAM9 processors. Changes include: - Replace AT91_BASE_* with AT91RM9200_BASE_* - Replace AT91_ID_* with AT91RM9200_ID_* - ROM, SRAM and UHP address definitions moved to at91rm9200.h. - The raw AT91_P[ABCD]_* definitions are now depreciated in favour of the GPIO API. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (48 commits) [PATCH] bonding: update version number [PATCH] git-netdev-all: pc300_tty build fix [PATCH] Make PC300 WAN driver compile again [PATCH] Modularize generic HDLC [PATCH] more s2io __iomem annotations [PATCH] restore __iomem annotations in e1000 [PATCH] 64bit bugs in s2io [PATCH] bonding: Fix primary selection error at enslavement time [PATCH] bonding: Don't mangle LACPDUs [PATCH] bonding: Validate probe replies in ARP monitor [PATCH] bonding: Don't release slaves when master is admin down [PATCH] bonding: Add priv_flag to avoid event mishandling [PATCH] bonding: Handle large hard_header_len [PATCH] bonding: Remove unneeded NULL test [PATCH] bonding: Format fix in seq_printf call [PATCH] bonding: Convert delay value from s16 to int [PATCH] bonding: Allow bonding to enslave a 10 Gig adapter Delete unused drivers/net/gt64240eth.h [PATCH] skge: fiber support [PATCH] fix possible NULL ptr deref in forcedeth ...
2006-09-27Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (129 commits) [PATCH] USB Storage: fix Rio Karma eject support build error USB: Airprime driver improvements to allow full speed EvDO transfers USB: remove OTG build warning USB: EHCI update VIA workaround USB: force root hub resume after power loss USB: ohci_usb can oops on shutdown USB: Dealias -110 code (more complete) USB: Remove unneeded void * casts in core files USB: u132-hcd: host controller driver for ELAN U132 adapter USB: ftdi-elan: client driver for ELAN Uxxx adapters usb serial: support Alcor Micro Corp. USB 2.0 TO RS-232 through pl2303 driver USB: Moschip 7840 USB-Serial Driver USB: add PlayStation 2 Trance Vibrator driver USB: Add ADU support for Ontrak ADU devices aircable: fix printk format warnings Add AIRcable USB Bluetooth Dongle Driver cypress_m8: implement graceful failure handling cypress_m8: improve control endpoint error handling cypress_m8: use usb_fill_int_urb where appropriate cypress_m8: use appropriate URB polling interval ...
2006-09-27[PATCH] i386: Use early clobbers for semaphores nowAndi Kleen
The new code does clobber the result early, so make sure to tell gcc to not put it into the same register as a input argument Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andrew Morton <akpm@osdl.org> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[ARM] 3864/1: Refactore sharpsl_pmDirk Opfer
This patch adds another hook into sharpsl_pm to notify the machine specific driver immediately after resume. This is needed to support the Sharp SL-6000 (Tosa). Signed-off-by: Dirk Opfer <Dirk@Opfer-Online.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] 3863/1: Add Locomo SPI DeviceDirk Opfer
The Locomo chip has a SPI interface which is used for SD/MMC cards (only collie). This patch adds the definition for the SPI device inside the Locomo chip. Signed-off-by: Dirk Opfer <Dirk@Opfer-Online.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] 3847/2: Convert LOMOMO to use struct device for GPIOsRichard Purdie
Convert LOMOMO to use struct device * for GPIOs instead of struct locomo_dev. This enables access to the GPIOs from code which is not a locomo device itself (such as audio). Access for gpio 31 is removed for error handling (no such hardware exists). Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27usbcore: add autosuspend/autoresume infrastructureAlan Stern
This patch (as739) adds the basic infrastructure for USB autosuspend and autoresume. The main features are: PM usage counters added to struct usb_device and struct usb_interface, indicating whether it's okay to autosuspend them or they are currently in use. Flag added to usb_device indicating whether the current suspend/resume operation originated from outside or as an autosuspend/autoresume. Flag added to usb_driver indicating whether the driver supports autosuspend. If not, no device bound to the driver will be autosuspended. Mutex added to usb_device for protecting PM operations. Unlike the device semaphore, the locking rule for the pm_mutex is that you must acquire the locks going _up_ the device tree. New routines handling autosuspend/autoresume requests for interfaces and devices. Suspend and resume requests are propagated up the device tree (but not outside the USB subsystem). work_struct added to usb_device, for carrying out delayed autosuspend requests. Autoresume added (and autosuspend prevented) during probe and disconnect. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27usbcore: store each usb_device's level in the treeAlan Stern
This patch (as778) adds a field to struct usb_device to store the device's level in the USB tree. In itself this number isn't really important. But the overhead is very low, and in a later patch it will be used for preventing bogus warnings from the lockdep checker. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
