If a key has been enabled before jump_label_init() is called, don't
nop it out.
This removes arch_jump_label_text_poke_early() (which can only nop
out a site) and uses arch_jump_label_transform() instead.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Acked-by: Jason Baron <jbaron@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
ATOMIC_INIT() is the proper thing to use.
That flag no longer makes sense, since we don't look up automount points
as eagerly any more. Additionally, it turns out that the NO_AUTOMOUNT
handling was buggy to begin with: it would avoid automounting even for
cases where we really *needed* to do the automount handling, and could
return ENOENT for autofs entries that hadn't been instantiated yet.
With our new non-eager automount semantics, one discussion has been
about adding a AT_AUTOMOUNT flag to vfs_fstatat (and thus the
newfstatat() and fstatat64() system calls), but it's probably not worth
it: you can always force at least directory automounting by simply
adding the final '/' to the filename, which works for *all* of the stat
family system calls, old and new.
So AT_NO_AUTOMOUNT (and thus LOOKUP_NO_AUTOMOUNT) really were just a
result of our bad default behavior.
Acked-by: Ian Kent <raven@themaw.net>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Since we've now turned around and made LOOKUP_FOLLOW *not* force an
automount, we want to add the ability to force an automount event on
lookup even if we don't happen to have one of the other flags that force
it implicitly (LOOKUP_OPEN, LOOKUP_DIRECTORY, LOOKUP_PARENT..)
Most cases will never want to use this, since you'd normally want to
delay automounting as long as possible, which usually implies
LOOKUP_OPEN (when we open a file or directory, we really cannot avoid
the automount any more).
But Trond argued sufficiently forcefully that at a minimum bind mounting
a file and quotactl will want to force the automount lookup. Some other
cases (like nfs_follow_remote_path()) could use it too, although
LOOKUP_DIRECTORY would work there as well.
This commit just adds the flag and logic, no users yet, though. It also
doesn't actually touch the LOOKUP_NO_AUTOMOUNT flag that is related, and
was made irrelevant by the same change that made us not follow on
LOOKUP_FOLLOW.
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Jeff Layton <jlayton@redhat.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Greg KH <gregkh@suse.de>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6:
[S390] kvm: extension capability for new address space layout
[S390] kvm: fix address mode switching
* 'for-linus' of git://git.kernel.dk/linux-block:
floppy: use del_timer_sync() in init cleanup
blk-cgroup: be able to remove the record of unplugged device
block: Don't check QUEUE_FLAG_SAME_COMP in __blk_complete_request
mm: Add comment explaining task state setting in bdi_forker_thread()
mm: Cleanup clearing of BDI_pending bit in bdi_forker_thread()
block: simplify force plug flush code a little bit
block: change force plug flush call order
block: Fix queue_flag update when rq_affinity goes from 2 to 1
block: separate priority boosting from REQ_META
block: remove READ_META and WRITE_META
xen-blkback: fixed indentation and comments
xen-blkback: Don't disconnect backend until state switched to XenbusStateClosed.
598841ca9919d008b520114d8a4378c4ce4e40a1 ([S390] use gmap address
spaces for kvm guest images) changed kvm on s390 to use a separate
address space for kvm guests. We can now put KVM guests anywhere
in the user address mode with a size up to 8PB - as long as the
memory is 1MB-aligned. This change was done without KVM extension
capability bit.
The change was added after 3.0, but we still have a chance to add
a feature bit before 3.1 (keeping the releases in a sane state).
We use number 71 to avoid collisions with other pending kvm patches
as requested by Alexander Graf.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Avi Kivity <avi@redhat.com>
Cc: Alexander Graf <agraf@suse.de>
* git://github.com/davem330/net:
tcp: fix validation of D-SACK
tcp: fix build error if !CONFIG_SYN_COOKIES
commit 946cedccbd7387 (tcp: Change possible SYN flooding messages)
added a build error if CONFIG_SYN_COOKIES=n
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
* 'for-linus' of git://git.infradead.org/users/sameo/mfd-2.6:
mfd: Fix omap-usb-host build failure
mfd: Make omap-usb-host TLL mode work again
mfd: Set MAX8997 irq pointer
mfd: Fix initialisation of tps65910 interrupts
mfd: Check for twl4030-madc NULL pointer
mfd: Copy the device pointer to the twl4030-madc structure
mfd: Rename wm8350 static gpio_set_debounce()
mfd: Fix value of WM8994_CONFIGURE_GPIO
* git://github.com/davem330/net: (62 commits)
ipv6: don't use inetpeer to store metrics for routes.
can: ti_hecc: include linux/io.h
IRDA: Fix global type conflicts in net/irda/irsysctl.c v2
net: Handle different key sizes between address families in flow cache
net: Align AF-specific flowi structs to long
ipv4: Fix fib_info->fib_metrics leak
caif: fix a potential NULL dereference
sctp: deal with multiple COOKIE_ECHO chunks
ibmveth: Fix checksum offload failure handling
ibmveth: Checksum offload is always disabled
ibmveth: Fix issue with DMA mapping failure
ibmveth: Fix DMA unmap error
pch_gbe: support ML7831 IOH
pch_gbe: added the process of FIFO over run error
pch_gbe: fixed the issue which receives an unnecessary packet.
sfc: Use 64-bit writes for TX push where possible
Revert "sfc: Use write-combining to reduce TX latency" and follow-ups
bnx2x: Fix ethtool advertisement
bnx2x: Fix 578xx link LED
bnx2x: Fix XMAC loopback test
With the conversion of struct flowi to a union of AF-specific structs, some
operations on the flow cache need to account for the exact size of the key.
Signed-off-by: David Ward <david.ward@ll.mit.edu>
AF-specific flowi structs are now passed to flow_key_compare, which must
also be aligned to a long.
Attempt to reduce the number of IP packets emitted in response to single
SCTP packet (2e3216cd) introduced a complication - if a packet contains
two COOKIE_ECHO chunks and nothing else then SCTP state machine corks the
socket while processing first COOKIE_ECHO and then loses the association
and forgets to uncork the socket. To deal with the issue add new SCTP
command which can be used to set association explictly. Use this new
command when processing second COOKIE_ECHO chunk to restore the context
for SCTP state machine.
Signed-off-by: Max Matveev <makc@redhat.com>
dev_forward_skb loops an skb back into host networking
stack which might hang on the memory indefinitely.
In particular, this can happen in macvtap in bridged mode.
Copy the userspace fragments to avoid blocking the
sender in that case.
As this patch makes skb_copy_ubufs extern now,
I also added some documentation and made it clear
the SKBTX_DEV_ZEROCOPY flag automatically instead
of doing it in all callers. This can be made into a separate
patch if people feel it's worth it.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
"Possible SYN flooding on port xxxx " messages can fill logs on servers.
Change logic to log the message only once per listener, and add two new
SNMP counters to track :
TCPReqQFullDoCookies : number of times a SYNCOOKIE was replied to client
TCPReqQFullDrop : number of times a SYN request was dropped because
syncookies were not enabled.
Based on a prior patch from Tom Herbert, and suggestions from David.
CC: Tom Herbert <therbert@google.com>
Building a kernel with hotplug disabled results in a link failure:
`bgpio_remove' referenced in section `___ksymtab_gpl+bgpio_remove' of drivers/built-in.o: defined in discarded section `.devexit.text' of drivers/built-in.o
This is because of bgpio_remove() is exported. It is illegal to export
symbols which are discarded either at link time or as part of an
init/exit section.
Fix this by dropping the __devexit attributation from bgpio_remove().
Also drop the __devinit attributation from bgpio_init().
Cc: Grant Likely <grant.likely@secretlab.ca>
Revert the post-3.0 commit 82f9d486e59f5 ("memcg: add
memory.vmscan_stat").
The implementation of per-memcg reclaim statistics violates how memcg
hierarchies usually behave: hierarchically.
The reclaim statistics are accounted to child memcgs and the parent
hitting the limit, but not to hierarchy levels in between. Usually,
hierarchical statistics are perfectly recursive, with each level
representing the sum of itself and all its children.
Since this exports statistics to userspace, this may lead to confusion
and problems with changing things after the release, so revert it now,
we can try again later.
Signed-off-by: Johannes Weiner <jweiner@redhat.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Ying Han <yinghan@google.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Fix kernel-doc warning about internal/private data by marking it
as "private:" so that kernel-doc will ignore it.
Warning(include/linux/regulator/consumer.h:128): No description found for parameter 'ret'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Fix kernel-doc warning in net/cfg80211.h:
Warning(include/net/cfg80211.h:1884): No description found for parameter 'registered'
* 'perf-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
x86, perf: Check that current->mm is alive before getting user callchain
perf_event: Fix broken calc_timer_values()
perf events: Fix slow and broken cgroup context switch code
This needs to be an out of band value for the register and on this device
registers are 16 bit so we must shift left one to the 17th bit.
Cc: stable@kernel.org
Signed-off-by: Jim Garlick <garlick@llnl.gov>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Some of the flags are OS/arch dependent we add a 9p
protocol value which maps to asm-generic/fcntl.h values in Linux
Based on the original patch from Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com>
Allow transparent sockets to be less restrictive about
the source ip of ipv6 udp packets being sent.
Google-Bug-Id: 5018138
Signed-off-by: Maciej Żenczykowski <maze@google.com>
CC: "Erik Kline" <ek@google.com>
CC: "Lorenzo Colitti" <lorenzo@google.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (42 commits)
netpoll: fix incorrect access to skb data in __netpoll_rx
cassini: init before use in cas_interruptN.
can: ti_hecc: Fix uninitialized spinlock in probe
can: ti_hecc: Fix unintialized variable
net: sh_eth: fix the compile error
net/phy: fix DP83865 phy interrupt handler
sendmmsg/sendmsg: fix unsafe user pointer access
ibmveth: Fix leak when recycling skb and hypervisor returns error
arp: fix rcu lockdep splat in arp_process()
bridge: fix a possible use after free
bridge: Pseudo-header required for the checksum of ICMPv6
mcast: Fix source address selection for multicast listener report
MAINTAINERS: Update GIT trees for network development
ath9k: Fix PS wrappers in ath9k_set_coverage_class
carl9170: Fix mismatch in carl9170_op_set_key mutex lock-unlock
wl12xx: add max_sched_scan_ssids value to the hw description
wl12xx: Fix validation of pm_runtime_get_sync return value
wl12xx: Remove obsolete testmode NVS push command
bcma: add uevent to the bus, to autoload drivers
ath9k_hw: Fix STA (AR9485) bringup issue due to incorrect MAC address
The current cgroup context switch code was incorrect leading
to bogus counts. Furthermore, as soon as there was an active
cgroup event on a CPU, the context switch cost on that CPU
would increase by a significant amount as demonstrated by a
simple ping/pong example:
$ ./pong
Both processes pinned to CPU1, running for 10s
10684.51 ctxsw/s
Now start a cgroup perf stat:
$ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 100
$ ./pong
6674.61 ctxsw/s
That's a 37% penalty.
Note that pong is not even in the monitored cgroup.
The results shown by perf stat are bogus:
Performance counter stats for 'sleep 100':
CPU1 <not counted> cycles test
CPU1 16,984,189,138 cycles # 0.000 GHz
The second 'cycles' event should report a count @ CPU clock
(here 2.4GHz) as it is counting across all cgroups.
The patch below fixes the bogus accounting and bypasses any
cgroup switches in case the outgoing and incoming tasks are
in the same cgroup.
With this patch the same test now yields:
$ ./pong
10775.30 ctxsw/s
Start perf stat with cgroup:
Run pong outside the cgroup:
$ /pong
10687.80 ctxsw/s
The penalty is now less than 2%.
And the results for perf stat are correct:
Performance counter stats for 'sleep 10':
CPU1 <not counted> cycles test # 0.000 GHz
CPU1 23,933,981,448 cycles # 0.000 GHz
Now perf stat reports the correct counts for
for the non cgroup event.
If we run pong inside the cgroup, then we also get the
correct counts:
CPU1 22,297,726,205 cycles test # 0.000 GHz
10.001457237 seconds time elapsed
Signed-off-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20110825135803.GA4697@quad
The nfsservctl system call is now gone, so we should remove all
linkage for it.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
omap-serial: Allow IXON and IXOFF to be disabled.
TTY: serial, document ignoring of uart->ops->startup error
TTY: pty, fix pty counting
8250: Fix race condition in serial8250_backup_timeout().
serial/8250_pci: delete duplicate data definition
8250_pci: add support for Rosewill RC-305 4x serial port card
tty: Add "spi:" prefix for spi modalias
atmel_serial: fix atmel_default_console_device
serial: 8250_pnp: add Intermec CV60 touchscreen device
drivers/serial/ucc_uart.c: Fix compiler warning
pch_uart: Set PCIe bus number using probe parameter
serial: samsung: Fix build error
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6:
drivers:misc: ti-st: fix unexpected UART close
drivers:misc: ti-st: free skb on firmware download
drivers:misc: ti-st: wait for completion at fail
drivers:misc: ti-st: reinit completion before send
drivers:misc: ti-st: fail-safe on wrong pkt type
drivers:misc: ti-st: reinit completion on ver read
drivers:misc:ti-st: platform hooks for chip states
drivers:misc: ti-st: avoid a misleading dbg msg
base/devres.c: quiet sparse noise about context imbalance
pti: add missing CONFIG_PCI dependency
drivers/base/devtmpfs.c: correct annotation of `setup_done'
driver core: fix kernel-doc warning in platform.c
firmware: fix google/gsmi.c build warning
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
We need a callback to do some things after pwm_enable, pwm_disable
and pwm_config.
Signed-off-by: Dilan Lee <dilee@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Arun Murthy <arun.murthy@stericsson.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Replace/remove use of RIO v.1.2 registers/bits that are not
forward-compatible with newer versions of RapidIO specification.
RapidIO specification v.1.3 removed Write Port CSR, Doorbell CSR,
Mailbox CSR and Mailbox and Doorbell bits of the PEF CAR.
Use of removed (since RIO v.1.3) register bits affects users of
currently available 1.3 and 2.x compliant devices who may use not so
recent kernel versions.
Removing checks for unsupported bits makes corresponding routines
compatible with all versions of RapidIO specification. Therefore,
backporting makes stable kernel versions compliant with RIO v.1.3 and
later as well.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Cc: Thomas Moll <thomas.moll@sysgo.com>
Cc: Chul Kim <chul.kim@idt.com>
Cc: <stable@kernel.org>
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net>
Purely in-memory filesystems do not use the inode hash as the dcache
tells us if an entry already exists. As a result, they do not call
unlock_new_inode, and thus directory inodes do not get put into a
different lockdep class for i_sem.
We need the different lockdep classes, because the locking order for
i_mutex is different for directory inodes and regular inodes. Directory
inodes can do "readdir()", which takes i_mutex *before* possibly taking
mm->mmap_sem (due to a page fault while copying the directory entry to
user space).
In contrast, regular inodes can be mmap'ed, which takes mm->mmap_sem
before accessing i_mutex.
The two cases can never happen for the same inode, so no real deadlock
can occur, but without the different lockdep classes, lockdep cannot
understand that. As a result, if CONFIG_DEBUG_LOCK_ALLOC is set, this
can lead to false positives from lockdep like below:
find/645 is trying to acquire lock:
(&mm->mmap_sem){++++++}, at: [<ffffffff81109514>] might_fault+0x5c/0xac
but task is already holding lock:
(&sb->s_type->i_mutex_key#15){+.+.+.}, at: [<ffffffff81149f34>]
vfs_readdir+0x5b/0xb4
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&sb->s_type->i_mutex_key#15){+.+.+.}:
[<ffffffff8108ac26>] lock_acquire+0xbf/0x103
[<ffffffff814db822>] __mutex_lock_common+0x4c/0x361
[<ffffffff814dbc46>] mutex_lock_nested+0x40/0x45
[<ffffffff811daa87>] hugetlbfs_file_mmap+0x82/0x110
[<ffffffff81111557>] mmap_region+0x258/0x432
[<ffffffff811119dd>] do_mmap_pgoff+0x2ac/0x306
[<ffffffff81111b4f>] sys_mmap_pgoff+0x118/0x16a
[<ffffffff8100c858>] sys_mmap+0x22/0x24
[<ffffffff814e3ec2>] system_call_fastpath+0x16/0x1b
-> #0 (&mm->mmap_sem){++++++}:
[<ffffffff8108a4bc>] __lock_acquire+0xa1a/0xcf7
[<ffffffff81109541>] might_fault+0x89/0xac
[<ffffffff81149cff>] filldir+0x6f/0xc7
[<ffffffff811586ea>] dcache_readdir+0x67/0x205
[<ffffffff81149f54>] vfs_readdir+0x7b/0xb4
[<ffffffff8114a073>] sys_getdents+0x7e/0xd1
This patch moves the directory vs file lockdep annotation into a helper
function that can be called by in-memory filesystems and has hugetlbfs
call it.
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback
* 'urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback:
squeeze max-pause area and drop pass-good area
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
* '3.1-rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (21 commits)
target: Convert acl_node_lock to be IRQ-disabling
target: Make locking in transport_deregister_session() IRQ safe
tcm_fc: init/exit functions should not be protected by "#ifdef MODULE"
target: Print subpage too for unhandled MODE SENSE pages
iscsi-target: Fix iscsit_allocate_se_cmd_for_tmr failure path bugs
iscsi-target: Implement iSCSI target IPv6 address printing.
target: Fix task SGL chaining breakage with transport_allocate_data_tasks
target: Fix task count > 1 handling breakage and use max_sector page alignment
target: Add missing DATA_SG_IO transport_cmd_get_valid_sectors check
target: Fix SYNCHRONIZE_CACHE zero LBA + range breakage
target: Remove duplicate task completions in transport_emulate_control_cdb
target: Fix WRITE_SAME usage with transport_get_size
target: Add WRITE_SAME (10) parsing and refactor passthrough checks
target: Fix write payload exception handling with ->new_cmd_map
iscsi-target: forever loop bug in iscsit_attach_ooo_cmdsn()
iscsi-target: remove duplicate return
target: Convert target_core_rd.c to use use BUG_ON
iscsi-target: Fix leak on failure in iscsi_copy_param_list()
target: Use ERR_CAST inlined function
target: Make standard INQUIRY return 'not connected' for tpg_virt_lun0
I ran into a couple of programs which broke with the new Linux 3.0
version. Some of those were binary only. I tried to use LD_PRELOAD to
work around it, but it was quite difficult and in one case impossible
because of a mix of 32bit and 64bit executables.
For example, all kind of management software from HP doesnt work, unless
we pretend to run a 2.6 kernel.
$ uname -a
Linux svivoipvnx001 3.0.0-08107-g97cd98f #1062 SMP Fri Aug 12 18:11:45 CEST 2011 i686 i686 i386 GNU/Linux
$ hpacucli ctrl all show
Error: No controllers detected.
$ rpm -qf /usr/sbin/hpacucli
hpacucli-8.75-12.0
Another notable case is that Python now reports "linux3" from
sys.platform(); which in turn can break things that were checking
sys.platform() == "linux2":
https://bugzilla.mozilla.org/show_bug.cgi?id=664564
It seems pretty clear to me though it's a bug in the apps that are using
'==' instead of .startswith(), but this allows us to unbreak broken
programs.
This patch adds a UNAME26 personality that makes the kernel report a
2.6.40+x version number instead. The x is the x in 3.x.
I know this is somewhat ugly, but I didn't find a better workaround, and
compatibility to existing programs is important.
Some programs also read /proc/sys/kernel/osrelease. This can be worked
around in user space with mount --bind (and a mount namespace)
To use:
wget ftp://ftp.kernel.org/pub/linux/kernel/people/ak/uname26/uname26.c
gcc -o uname26 uname26.c
./uname26 program
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: check size of FUSE_NOTIFY_INVAL_ENTRY message
fuse: mark pages accessed when written to
fuse: delete dead .write_begin and .write_end aops
fuse: fix flock
fuse: fix non-ANSI void function notation
Cleaning up the code a little bit. attempt_plug_merge() traverses the plug
list anyway, we can do the request counting there, so stack size is reduced
a little bit.
The motivation here is I suspect if we should count the requests for each
queue (task could handle multiple disks in the meantime), but my test doesn't
show it's worthy doing. If somebody proves we should do it, below change
will make that more easier.
Signed-off-by: Shaohua Li <shli@kernel.org>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
tty_operations->remove is normally called like:
queue_release_one_tty
->tty_shutdown
->tty_driver_remove_tty
->tty_operations->remove
However tty_shutdown() is called from queue_release_one_tty() only if
tty_operations->shutdown is NULL. But for pty, it is not.
pty_unix98_shutdown() is used there as ->shutdown.
So tty_operations->remove of pty (i.e. pty_unix98_remove()) is never
called. This results in invalid pty_count. I.e. what can be seen in
/proc/sys/kernel/pty/nr.
I see this was already reported at:
https://lkml.org/lkml/2009/11/5/370
But it was not fixed since then.
This patch is kind of a hackish way. The problem lies in ->install. We
allocate there another tty (so-called tty->link). So ->install is
called once, but ->remove twice, for both tty and tty->link. The fix
here is to count both tty and tty->link and divide the count by 2 for
user.
And to have ->remove called, let's make tty_driver_remove_tty() global
and call that from pty_unix98_shutdown() (tty_operations->shutdown).
While at it, let's document that when ->shutdown is defined,
tty_shutdown() is not called.
Cc: Alan Cox <alan@linux.intel.com>
Cc: stable <stable@kernel.org>
Add a new REQ_PRIO to let requests preempt others in the cfq I/O schedule,
and lave REQ_META purely for marking requests as metadata in blktrace.
All existing callers of REQ_META except for XFS are updated to also
set REQ_PRIO for now.
Reviewed-by: Namhyung Kim <namhyung@gmail.com>
Replace all occurnanced of the undocumented READ_META with READ | REQ_META
and remove the unused WRITE_META define.
Certain platform specific or Host-WiLink Interface specific actions would be
required to be taken when the chip is being enabled and after the chip is
disabled such as configuration of the mux modes for the GPIO of host connected
to the nshutdown of the chip or relinquishing UART after the chip is disabled.
Similar actions can also be taken when the chip is in deep sleep or when the
chip is awake. Performance enhancements such as configuring the host to run
faster when chip is awake and slower when chip is asleep can also be made
here.
Signed-off-by: Pavan Savoy <pavan_savoy@ti.com>
This patch changes target_emulate_inquiry_std() to set the 'not connected'
(0x35) bit in standard INQUIRY response data when we are processing a
request to a virtual LUN=0 mapping from struct se_device *g_lun0_dev that
have been setup for us in transport_lookup_cmd_lun().
This addresses an issue where qla2xxx FC clients need to be able
to create demo-mode I_T FC Nexuses by default, but should not be
exposing the default set of TPG LUNs to all FC clients. This includes
adding an new optional target_core_fabric_ops->tpg_check_demo_mode_login_only()
caller to allow demo_mode nexuses to skip the old default of bulding
a demo-mode MappedLUNs list via core_tpg_add_node_to_devs().
(roland: Add missing tpg_check_demo_mode_login_only check in core_dev_add_lun)
Reported-by: Roland Dreier <roland@purestorage.com>
Cc: Andrew Vasquez <andrew.vasquez@qlogic.com>
Signed-off-by: Nicholas Bellinger <nab@risingtidesystems.com>
Do not call ->suspend, ->resume methods after we unregister wiphy. Also
delete sta_clanup timer after we finish wiphy unregister to avoid this:
WARNING: at lib/debugobjects.c:262 debug_print_object+0x85/0xa0()
Hardware name: 6369CTO
ODEBUG: free active (active state 0) object type: timer_list hint: sta_info_cleanup+0x0/0x180 [mac80211]
Modules linked in: aes_i586 aes_generic fuse bridge stp llc autofs4 sunrpc cpufreq_ondemand acpi_cpufreq mperf ext2 dm_mod uinput thinkpad_acpi hwmon sg arc4 rt2800usb rt2800lib crc_ccitt rt2x00usb rt2x00lib mac80211 cfg80211 i2c_i801 iTCO_wdt iTCO_vendor_support e1000e ext4 mbcache jbd2 sd_mod crc_t10dif sr_mod cdrom yenta_socket ahci libahci pata_acpi ata_generic ata_piix i915 drm_kms_helper drm i2c_algo_bit video [last unloaded: microcode]
Pid: 5663, comm: pm-hibernate Not tainted 3.1.0-rc1-wl+ #19
Call Trace:
[<c0454cfd>] warn_slowpath_common+0x6d/0xa0
[<c05e05e5>] ? debug_print_object+0x85/0xa0
[<c0454dae>] warn_slowpath_fmt+0x2e/0x30
[<c05e05e5>] debug_print_object+0x85/0xa0
[<f8a808e0>] ? sta_info_alloc+0x1a0/0x1a0 [mac80211]
[<c05e0bd2>] debug_check_no_obj_freed+0xe2/0x180
[<c051175b>] kfree+0x8b/0x150
[<f8a126ae>] cfg80211_dev_free+0x7e/0x90 [cfg80211]
[<f8a13afd>] wiphy_dev_release+0xd/0x10 [cfg80211]
[<c068d959>] device_release+0x19/0x80
[<c05d06ba>] kobject_release+0x7a/0x1c0
[<c07646a8>] ? rtnl_unlock+0x8/0x10
[<f8a13adb>] ? wiphy_resume+0x6b/0x80 [cfg80211]
[<c05d0640>] ? kobject_del+0x30/0x30
[<c05d1a6d>] kref_put+0x2d/0x60
[<c05d056d>] kobject_put+0x1d/0x50
[<c08015f4>] ? mutex_lock+0x14/0x40
[<c068d60f>] put_device+0xf/0x20
[<c069716a>] dpm_resume+0xca/0x160
[<c04912bd>] hibernation_snapshot+0xcd/0x260
[<c04903df>] ? freeze_processes+0x3f/0x90
[<c049151b>] hibernate+0xcb/0x1e0
[<c048fdc0>] ? pm_async_store+0x40/0x40
[<c048fe60>] state_store+0xa0/0xb0
[<c05d0200>] kobj_attr_store+0x20/0x30
[<c0575ea4>] sysfs_write_file+0x94/0xf0
[<c051e26a>] vfs_write+0x9a/0x160
[<c0575e10>] ? sysfs_open_file+0x200/0x200
[<c051e3fd>] sys_write+0x3d/0x70
[<c080959f>] sysenter_do_call+0x12/0x28
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
* 'for-linus' of git://git.kernel.dk/linux-block: (23 commits)
Revert "cfq: Remove special treatment for metadata rqs."
block: fix flush machinery for stacking drivers with differring flush flags
block: improve rq_affinity placement
blktrace: add FLUSH/FUA support
Move some REQ flags to the common bio/request area
allow blk_flush_policy to return REQ_FSEQ_DATA independent of *FLUSH
xen/blkback: Make description more obvious.
cfq-iosched: Add documentation about idling
block: Make rq_affinity = 1 work as expected
block: swim3: fix unterminated of_device_id table
block/genhd.c: remove useless cast in diskstats_show()
drivers/cdrom/cdrom.c: relax check on dvd manufacturer value
drivers/block/drbd/drbd_nl.c: use bitmap_parse instead of __bitmap_parse
bsg-lib: add module.h include
cfq-iosched: Reduce linked group count upon group destruction
blk-throttle: correctly determine sync bio
loop: fix deadlock when sysfs and LOOP_CLR_FD race against each other
loop: add BLK_DEV_LOOP_MIN_COUNT=%i to allow distros 0 pre-allocated loop devices
loop: add management interface for on-demand device allocation
loop: replace linked list of allocated devices with an idr index
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: OF: Don't crash when bridge parent is NULL.
PCI: export pcie_bus_configure_settings symbol
PCI: code and comments cleanup
PCI: make cardbus-bridge resources optional
PCI: make SRIOV resources optional
PCI : ability to relocate assigned pci-resources
PCI: honor child buses add_size in hot plug configuration
PCI: Set PCI-E Max Payload Size on fabric
Revert the pass-good area introduced in ffd1f609ab10 ("writeback:
introduce max-pause and pass-good dirty limits") and make the max-pause
area smaller and safe.
This fixes ~30% performance regression in the ext3 data=writeback
fio_mmap_randwrite_64k/fio_mmap_randrw_64k test cases, where there are
12 JBOD disks, on each disk runs 8 concurrent tasks doing reads+writes.
Using deadline scheduler also has a regression, but not that big as CFQ,
so this suggests we have some write starvation.
The test logs show that
- the disks are sometimes under utilized
- global dirty pages sometimes rush high to the pass-good area for
several hundred seconds, while in the mean time some bdi dirty pages
drop to very low value (bdi_dirty << bdi_thresh). Then suddenly the
global dirty pages dropped under global dirty threshold and bdi_dirty
rush very high (for example, 2 times higher than bdi_thresh). During
which time balance_dirty_pages() is not called at all.
So the problems are
1) The random writes progress so slow that they break the assumption of
the max-pause logic that "8 pages per 200ms is typically more than
enough to curb heavy dirtiers".
2) The max-pause logic ignored task_bdi_thresh and thus opens the possibility
for some bdi's to over dirty pages, leading to (bdi_dirty >> bdi_thresh)
and then (bdi_thresh >> bdi_dirty) for others.
3) The higher max-pause/pass-good thresholds somehow leads to the bad
swing of dirty pages.
The fix is to allow the task to slightly dirty over task_bdi_thresh, but
no way to exceed bdi_dirty and/or global dirty_thresh.
Tests show that it fixed the JBOD regression completely (both behavior
and performance), while still being able to cut down large pause times
in balance_dirty_pages() for single-disk cases.
Reported-by: Li Shaohua <shaohua.li@intel.com>
Tested-by: Li Shaohua <shaohua.li@intel.com>
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
