This patch adds a cyclic DMA interface to the DW DMA driver. This is
very useful if you want to use the DMA controller in combination with a
sound device which uses cyclic buffers.
Using a DMA channel for cyclic DMA will disable the possibility to use
it as a normal DMA engine until the user calls the cyclic free function
on the DMA channel. Also a cyclic DMA list can not be prepared if the
channel is already active.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
Currently dma_request_channel() set DMA_PRIVATE capability but never
clear it. So if a public channel was once grabbed by
dma_request_channel(), the device stay PRIVATE forever. Add
privatecnt member to dma_device to correctly revert it.
[lg@denx.de: fix bad usage of 'chan' in dma_async_device_register]
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Provide a config option for blocking the allocation of dma channels to
the async_tx api.
To allow an async_tx routine to be compiled away on HAS_DMA=n arch it
needs to be declared __always_inline otherwise the compiler may emit
code and cause a link error.
The dmaengine redux left some unneeded headers in
include/linux/dmaengine.h, clean them up.
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
cpumask: mm_cpumask for accessing the struct mm_struct's cpu_vm_mask.
cpumask: tsk_cpumask for accessing the struct task_struct's cpus_allowed.
This allows us to change the representation (to a dangling bitmap or
cpumask_var_t) without breaking all the callers: they can use
mm_cpumask() now and won't see a difference as the changes roll into
linux-next.
tsk_cpumask() now and won't see a difference as the changes roll into
linux-next.
Comparing the layouts of struct detail_pixel_timing with
x.org's struct detailed_timings and how those are handled,
it appears that the hsync_positive and vsync_positive
fields are backwards.
This patch fixes https://bugs.freedesktop.org/show_bug.cgi?id=20019
for me. It was tested on 2 monitors, LG FLATRON L225WS 22" and
a YAKUMO 17" for which more details are unknown.
Signed-off-by: Pantelis Koukousoulas <pktoss@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] Add p4-clockmod sysfs-ui removal to feature-removal schedule.
Revert "[CPUFREQ] Disable sysfs ui for p4-clockmod."
This reverts commit e088e4c9cdb618675874becb91b2fd581ee707e6.
Removing the sysfs interface for p4-clockmod was flagged as a
regression in bug 12826.
Course of action:
- Find out the remaining causes of overheating, and fix them
if possible. ACPI should be doing the right thing automatically.
If it isn't, we need to fix that.
- mark p4-clockmod ui as deprecated
- try again with the removal in six months.
It's not really feasible to printk about the deprecation, because
it needs to happen at all the sysfs entry points, which means adding
a lot of strcmp("p4-clockmod".. calls to the core, which.. bleuch.
Signed-off-by: Dave Jones <davej@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (29 commits)
p54: fix race condition in memory management
cfg80211: test before subtraction on unsigned
iwlwifi: fix error flow in iwl*_pci_probe
rt2x00 : more devices to rt73usb.c
rt2x00 : more devices to rt2500usb.c
bonding: Fix device passed into ->ndo_neigh_setup().
vlan: Fix vlan-in-vlan crashes.
net: Fix missing dev->neigh_setup in register_netdevice().
tmspci: fix request_irq race
pkt_sched: act_police: Fix a rate estimator test.
tg3: Fix 5906 link problems
SCTP: change sctp_ctl_sock_init() to try IPv4 if IPv6 fails
IPv6: add "disable" module parameter support to ipv6.ko
sungem: another error printed one too early
aoe: error printed 1 too early
net pcmcia: worklimit reaches -1
net: more timeouts that reach -1
net: fix tokenring license
dm9601: new vendor/product IDs
netlink: invert error code in netlink_set_err()
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
dmatest: fix use after free in dmatest_exit
ipu_idmac: fix spinlock type
iop-adma, mv_xor: fix mem leak on self-test setup failure
fsldma: fix off by one in dma_halt
I/OAT: fail self-test if callback test reaches timeout
I/OAT: update driver version and copyright dates
I/OAT: list usage cleanup
I/OAT: set tcp_dma_copybreak to 256k for I/OAT ver.3
I/OAT: cancel watchdog before dma remove
I/OAT: fail initialization on zero channels detection
I/OAT: do not set DCACTRL_CMPL_WRITE_ENABLE for I/OAT ver.3
I/OAT: add verification for proper APICID_TAG_MAP setting by BIOS
dmaengine: update kerneldoc
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
ata: add CFA specific identify data words
remove stale comment from <linux/hdreg.h>
AT91: initialize Compact Flash on AT91SAM9263 cpu
ide: add at91_ide driver
ide: allow to wrap interrupt handler
ide-iops: fix odd-length ATAPI PIO transfers
ide: NULL noise: drivers/ide/ide-*.c
ide: expiry() returns int, negative expiry() return values won't be noticed
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: Don't trust current capacity values in identify words 57-58
libata: make sure port is thawed when skipping resets
sata_nv: fix module parameter description
ahci: Add the Device IDs for MCP89 and remove IDs of MCP7B to/from ahci.c
libata: don't use on-stack sense buffer
libata: align ap->sector_buf
libata: fix dma_unmap_sg misuse
libata: change drive ready wait after hard reset to 5s
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: serio - fix protocol number for TouchIT213
Protocol 0x37 has been reserved for iNexio devices and Sahara
was supposed to get 0x38.
Reported-by: Claudio Nieder <private@claudio.ch>
Declare CFA specific identify data words 162 and 163 for future use.
[bart: update patch summary/description]
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
HDIO_GET_IDENTITY returns 256 words currently.
Noticed by Norman Diamond.
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
Cc: Andrew Victor <linux@maxim.org.za>
[bart: minor checkpatch.pl / CodingStyle fixups]
ap->sector_buf is used as DMA target and should at least be aligned on
cacheline. This caused problems on some embedded machines.
libata passes the returned value of dma_map_sg() to
dma_unmap_sg(),which is the misuse of dma_unmap_sg().
DMA-mapping.txt says:
To unmap a scatterlist, just call:
pci_unmap_sg(pdev, sglist, nents, direction);
Again, make sure DMA activity has already finished.
PLEASE NOTE: The 'nents' argument to the pci_unmap_sg call must be
the _same_ one you passed into the pci_map_sg call,
it should _NOT_ be the 'count' value _returned_ from the
pci_map_sg call.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
This fixes problems during resume with drives that take longer than 1s to
be ready. The ATA-6 spec appears to allow 5 seconds for a drive to be
ready.
On one affected system, this patch changes "PM: resume devices took..."
message from 17 seconds to 4 seconds, and gets rid of a lot of ugly
timeout/error messages.
Without this patch, the libata code moves on after 1s, tries to send a
soft reset (which the drive doesn't see because it isn't ready) which also
times out, then an IDENTIFY command is sent to the drive which times out,
and finally the error handler will try to send another hard reset which
will finally get things working.
Signed-off-by: Stuart Hayes <stuart_hayes@dell.com>
As analyzed by Patrick McHardy, vlan needs to reset it's
netdev_ops pointer in it's ->init() function but this
leaves the compat method pointers stale.
Add a netdev_resync_ops() and call it from the vlan code.
Any other driver which changes ->netdev_ops after register_netdevice()
will need to call this new function after doing so too.
With help from Patrick McHardy.
Tested-by: Patrick McHardy <kaber@trash.net>
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: don't allow setuid to succeed if the user does not have rt bandwidth
sched_rt: don't start timer when rt bandwidth disabled
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: Teach RCU that idle task is not quiscent state at boot
It turns out that net_alive is unnecessary, and the original problem
that led to it being added was simply that the icmp code thought
it was a network device and wound up being unable to handle packets
while there were still packets in the network namespace.
Now that icmp and tcp have been fixed to properly register themselves
this problem is no longer present and we have a stronger guarantee
that packets will not arrive in a network namespace then that provided
by net_alive in netif_receive_skb. So remove net_alive allowing
packet reception run a little faster.
Additionally document the strong reason why network namespace cleanup
is safe so that if something happens again someone else will have
a chance of figuring it out.
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
fix warning in io_mapping_map_wc()
x86: i915 needs pgprot_writecombine() and is_io_mapping_possible()
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
The DCB netlink interface is required for building the userspace tools
available at e1000.sourceforge.net
Signed-off-by: Chris Leech <christopher.leech@intel.com>
1) add an include for <linux/types.h>
2) change dcbmsg.dcb_family from unsigned char to __u8 to be more
consistent with use of kernel types
Acked-by: Sam Ravnborg <sam@ravnborg.org>
x86: enable DMAR by default
xen: disable interrupts early, as start_kernel expects
gpu/drm, x86, PAT: io_mapping_create_wc and resource_size_t
gpu/drm, x86, PAT: Handle io_mapping_create_wc() errors in a clean way
x86, Voyager: fix compile by lifting the degeneracy of phys_cpu_present_map
x86, doc: fix references to Documentation/x86/i386/boot.txt
free_uid() and free_user_ns() are corecursive when CONFIG_USER_SCHED=n,
but free_user_ns() is called from free_uid() by way of uid_hash_remove(),
which requires uidhash_lock to be held. free_user_ns() then calls
free_uid() to complete the destruction.
Fix this by deferring the destruction of the user_namespace.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Impact: fix hung task with certain (non-default) rt-limit settings
Corey Hickey reported that on using setuid to change the uid of a
rt process, the process would be unkillable and not be running.
This is because there was no rt runtime for that user group. Add
in a check to see if a user can attach an rt task to its task group.
On failure, return EINVAL, which is also returned in
CONFIG_CGROUP_SCHED.
Reported-by: Corey Hickey <bugfood-ml@fatooh.org>
Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
blk_recalc_rq_segments() requires a request structure passed in, which
we don't have from blk_recount_segments(). So the latter allocates one on
the stack, using > 400 bytes of stack for that. This can cause us to spill
over one page of stack from ext4 at least:
0) 4560 400 blk_recount_segments+0x43/0x62
1) 4160 32 bio_phys_segments+0x1c/0x24
2) 4128 32 blk_rq_bio_prep+0x2a/0xf9
3) 4096 32 init_request_from_bio+0xf9/0xfe
4) 4064 112 __make_request+0x33c/0x3f6
5) 3952 144 generic_make_request+0x2d1/0x321
6) 3808 64 submit_bio+0xb9/0xc3
7) 3744 48 submit_bh+0xea/0x10e
8) 3696 368 ext4_mb_init_cache+0x257/0xa6a [ext4]
9) 3328 288 ext4_mb_regular_allocator+0x421/0xcd9 [ext4]
10) 3040 160 ext4_mb_new_blocks+0x211/0x4b4 [ext4]
11) 2880 336 ext4_ext_get_blocks+0xb61/0xd45 [ext4]
12) 2544 96 ext4_get_blocks_wrap+0xf2/0x200 [ext4]
13) 2448 80 ext4_da_get_block_write+0x6e/0x16b [ext4]
14) 2368 352 mpage_da_map_blocks+0x7e/0x4b3 [ext4]
15) 2016 352 ext4_da_writepages+0x2ce/0x43c [ext4]
16) 1664 32 do_writepages+0x2d/0x3c
17) 1632 144 __writeback_single_inode+0x162/0x2cd
18) 1488 96 generic_sync_sb_inodes+0x1e3/0x32b
19) 1392 16 sync_sb_inodes+0xe/0x10
20) 1376 48 writeback_inodes+0x69/0xb3
21) 1328 208 balance_dirty_pages_ratelimited_nr+0x187/0x2f9
22) 1120 224 generic_file_buffered_write+0x1d4/0x2c4
23) 896 176 __generic_file_aio_write_nolock+0x35f/0x393
24) 720 80 generic_file_aio_write+0x6c/0xc8
25) 640 80 ext4_file_write+0xa9/0x137 [ext4]
26) 560 320 do_sync_write+0xf0/0x137
27) 240 48 vfs_write+0xb3/0x13c
28) 192 64 sys_write+0x4c/0x74
29) 128 128 system_call_fastpath+0x16/0x1b
Split the segment counting out into a __blk_recalc_rq_segments() helper
to avoid allocating an onstack request just for checking the physical
segment count.
This patch fixes a bug located by Vegard Nossum with the aid of
kmemcheck, updated based on review comments from Nick Piggin,
Ingo Molnar, and Andrew Morton. And cleans up the variable-name
and function-name language. ;-)
The boot CPU runs in the context of its idle thread during boot-up.
During this time, idle_cpu(0) will always return nonzero, which will
fool Classic and Hierarchical RCU into deciding that a large chunk of
the boot-up sequence is a big long quiescent state. This in turn causes
RCU to prematurely end grace periods during this time.
This patch changes the rcutree.c and rcuclassic.c rcu_check_callbacks()
function to ignore the idle task as a quiescent state until the
system has started up the scheduler in rest_init(), introducing a
new non-API function rcu_idle_now_means_idle() to inform RCU of this
transition. RCU maintains an internal rcu_idle_cpu_truthful variable
to track this state, which is then used by rcu_check_callback() to
determine if it should believe idle_cpu().
Because this patch has the effect of disallowing RCU grace periods
during long stretches of the boot-up sequence, this patch also introduces
Josh Triplett's UP-only optimization that makes synchronize_rcu() be a
no-op if num_online_cpus() returns 1. This allows boot-time code that
calls synchronize_rcu() to proceed normally. Note, however, that RCU
callbacks registered by call_rcu() will likely queue up until later in
the boot sequence. Although rcuclassic and rcutree can also use this
same optimization after boot completes, rcupreempt must restrict its
use of this optimization to the portion of the boot sequence before the
scheduler starts up, given that an rcupreempt RCU read-side critical
section may be preeempted.
In addition, this patch takes Nick Piggin's suggestion to make the
system_state global variable be __read_mostly.
Changes since v4:
o Changes the name of the introduced function and variable to
be less emotional. ;-)
Changes since v3:
o WARN_ON(nr_context_switches() > 0) to verify that RCU
switches out of boot-time mode before the first context
switch, as suggested by Nick Piggin.
Changes since v2:
o Created rcu_blocking_is_gp() internal-to-RCU API that
determines whether a call to synchronize_rcu() is itself
a grace period.
o The definition of rcu_blocking_is_gp() for rcuclassic and
rcutree checks to see if but a single CPU is online.
o The definition of rcu_blocking_is_gp() for rcupreempt
checks to see both if but a single CPU is online and if
the system is still in early boot.
This allows rcupreempt to again work correctly if running
on a single CPU after booting is complete.
o Added check to rcupreempt's synchronize_sched() for there
being but one online CPU.
Tested all three variants both SMP and !SMP, booted fine, passed a short
rcutorture test on both x86 and Power.
Located-by: Vegard Nossum <vegard.nossum@gmail.com>
Tested-by: Vegard Nossum <vegard.nossum@gmail.com>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
During host driver module removal del_gendisk() results in a final
put on drive->gendev and freeing the drive by drive_release_dev().
Convert device drivers from using struct kref to use struct device
so device driver's object holds reference on ->gendev and prevents
drive from prematurely going away.
Also fix ->remove methods to not erroneously drop reference on a
host driver by using only put_device() instead of ide*_put().
Reported-by: Stanislaw Gruszka <stf_xl@wp.pl>
Tested-by: Stanislaw Gruszka <stf_xl@wp.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/i915: convert DRM_ERROR to DRM_DEBUG in phys object pwrite path
drm/i915: make hw page ioremap use ioremap_wc
drm: edid revision 0 is valid
drm: Correct unbalanced drm_vblank_put() during mode setting.
drm: disable encoders before re-routing them
drm: Fix ordering of bit fields in EDID structure leading huge vsync values.
drm: Fix shifts of EDID vsync offset/width fields.
drm/i915: handle bogus VBT panel timing
drm/i915: remove PLL debugging messages
* git://git.infradead.org/iommu-2.6:
intel-iommu: fix endless "Unknown DMAR structure type" loop
VT-d: handle Invalidation Queue Error to avoid system hang
intel-iommu: fix build error with INTR_REMAP=y and DMAR=n
io_mapping_create_wc should take a resource_size_t parameter in place of
unsigned long. With unsigned long, there will be no way to map greater than 4GB
address in i386/32 bit.
On x86, greater than 4GB addresses cannot be mapped on i386 without PAE. Return
error for such a case.
Patch also adds a structure for io_mapping, that saves the base, size and
type on HAVE_ATOMIC_IOMAP archs, that can be used to verify the offset on
io_mapping_map calls.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Eric Anholt <eric@anholt.net>
Cc: Keith Packard <keithp@keithp.com>
In some cases we may receive a mode config that has a different
CRTC<->encoder map that the current configuration. In that case, we
need to disable any re-routed encoders before setting the mode,
otherwise they may not pick up the new CRTC (if the output types are
incompatible for example).
Tested-by: Kristian Høgsberg <krh@bitplanet.net>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Dave Airlie <airlied@linux.ie>
Reviewed-by: Eric Anholt <eric@anholt.net>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
The unit in which user-space can set the bus timeout value is jiffies
for historical reasons (back when HZ was always 100.) This is however
not good because user-space doesn't know how long a jiffy lasts. The
timeout value should instead be set in a fixed time unit. Given the
original value of HZ, this unit should be 10 ms, for compatibility.
netns: fix double free at netns creation
veth : add the set_mac_address capability
sunlance: Beyond ARRAY_SIZE of ib->btx_ring
ISDN: fix sc/shmem printk format warning
SMSC: timeout reaches -1
smsc9420: handle magic field of ethtool_eeprom
sundance: missing parentheses?
smsc9420: fix another postfixed timeout
wimax/i2400m: driver loads firmware v1.4 instead of v1.3
vlan: Update skb->mac_header in __vlan_put_tag().
cxgb3: Add support for PCI ID 0x35.
tcp: remove obsoleted comment about different passes
TG3: &&/|| confusion
ATM: misplaced parentheses?
net/mv643xx: don't disable the mib timer too early and lock properly
net/mv643xx: use GFP_ATOMIC while atomic
atl1c: Atheros L1C Gigabit Ethernet driver
net: Kill skb_truesize_check(), it only catches false-positives.
net: forcedeth: Fix wake-on-lan regression
Move the sysdev_suspend/resume from the callee to the callers, with
no real change in semantics, so that we can rework the disabling of
interrupts during suspend/hibernation.
This is based on an earlier patch from Linus.
* hibernate:
PM: Fix suspend_console and resume_console to use only one semaphore
PM: Wait for console in resume
PM: Fix pm_notifiers during user mode hibernation
swsusp: clean up shrink_all_zones()
swsusp: dont fiddle with swappiness
PM: fix build for CONFIG_PM unset
PM/hibernate: fix "swap breaks after hibernation failures"
PM/resume: wait for device probing to finish
Consolidate driver_probe_done() loops into one place
there's a few places that currently loop over driver_probe_done(), and
I'm about to add another one. This patch abstracts it into a helper
to reduce duplication.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Len Brown <lenb@kernel.org>
Acked-by: Greg KH <gregkh@suse.de>
