path: root/include
2005-09-05[PATCH] MIPS Technologies PCI ID bitsRalf Baechle
- MIPS Denmark does no longer exist; the PCI vendor ID is now owned by MIPS Technologies. - Add ID for SOC-it, MIPS's system controller. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: add support for Qemu system architectureRalf Baechle
Add support for the virtual MIPS system that is emulated by Qemu. See http://www.linux-mips.org/wiki/Qemu for a detailed current status. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] DEC PMAGB B framebuffer updateRalf Baechle
Revive HX frame buffer support for 2.6. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] DEC PMAG BA frame buffer updateRalf Baechle
Rewrite PMAG BA frame buffer driver for 2.6. Acked-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: remove HP Laserjet remainsRalf Baechle
Remove the one file which managed to survive the removel of HP Laserjet support. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: remove VR4181 supportRalf Baechle
There seem to be no more users or interest in the NEC Osprey evaluation system for the NEC VR4181 SOC which is an old part anyway, so remove the code. More information on the Osprey can be found at http://www.linux-mips.org/wiki/Osprey. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: update IRQ handling for vr41xxYoichi Yuasa
This patch has updated IRQ handling for vr41xx. o added common IRQ dispatch o changed IRQ number in int-handler.S o added resource management to icu.c Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc64: Add VMX save flag to VPAOlof Johansson
We need to indicate to the hypervisor that it needs to save our VMX registers when switching partitions on a shared-processor system, just as it needs to for FP and PMC registers. This could be made to be on-demand when VMX is used, but we don't do that for FP nor PMC right now either so let's not overcomplicate things. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Anton Blanchard <anton@samba.org> Cc: <engebret@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: mv64x60 updates & enhancementsMark A. Greer
Updates and enhancement to the ppc32 mv64x60 code: - move code to get mem size from mem ctlr to bootwrapper - address some errata in the mv64360 pic code - some minor cleanups - export one of the bridge's regs via sysfs so user daemon can watch for extraction events Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: export cacheable_memcpy()Eugene Surovegin
Add declaration and cacheable_memcpy(). I'll be needing this function in new 4xx EMAC driver I'm going to submit to netdev soon. IMHO, the better place for the declaration would be asm-powerpc/string.h, unfortunately, ppc64 doesn't have this function, so asm-ppc/system.h is the next best place. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: add dcr_base field to ocp_func_mal_dataEugene Surovegin
Add dcr_base field to ocp_func_mal_data. This is preparation step for the new EMAC driver. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: move 4xx PHY_MODE_XXX defines to ibm_ocp.hEugene Surovegin
Move 4xx PHY_MODE_XXX defines to asm-ppc/ibm_ocp.h. This is a preparation step for the new EMAC driver. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: add CONFIG_HZKumar Gala
While ppc32 has the CONFIG_HZ Kconfig option, it wasnt actually being used. Connect it up and set all platforms to 250Hz. This pretty much mimics the ppc64 patch from Anton Blanchard. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: ppc_sys system on chip identification additionsKumar Gala
Add the ability to identify an SOC by a name and id. There are cases in which the integer identifier is not sufficient to specify a specific SOC. In these cases we can use a string to further qualify the match. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Don't sleep in flush_dcache_icache_page()Roland Dreier
flush_dcache_icache_page() will be called on an instruction page fault. We can't sleep in the fault handler, so use kmap_atomic() instead of just kmap() for the Book-E case. Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Cleaned up global namespace of Book-E watchdog variablesKumar Gala
Renamed global variables used to convey if the watchdog is enabled and periodicity of the timer and moved the declarations into a header for these variables Signed-off-by: Matt McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: add phy excluded features to ocp_func_emac_dataMatt Porter
This patch adds a field to struct ocp_func_emac_data that allows platform-specific unsupported PHY features to be passed in to the ibm_emac ethernet driver. This patch also adds some logic for the Bamboo eval board to populate this field based on the dip switches on the board. This is a workaround for the improperly biased RJ-45 sockets on the Rev. 0 Bamboo. Signed-off-by: Wade Farnsworth <wfarnsworth@mvista.com> Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Add ppc_sys descriptions for PowerQUICC II devicesKumar Gala
Added ppc_sys device and system definitions for PowerQUICC II devices. This will allow drivers for PQ2 to be proper platform device drivers. Which can be shared on PQ3 processors with the same peripherals. Signed-off-by: Matt McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: fix asm-ppc/dma-mapping.h sparse warningChristoph Hellwig
GFP flags must be passed as unisgned int __nocast these days, else we'll get tons of sparse warnings in every driver. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Remove board support for SPD823TSKumar Gala
Support for the SPD823TS board is no longer maintained and thus being removed Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Remove board support for REDWOODKumar Gala
Support for the REDWOOD board is no longer maintained and thus being removed Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Remove board support for OAKKumar Gala
Support for the OAK board is no longer maintained and thus being removed Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Remove board support for MCPN765Kumar Gala
Support for the MCPN765 board is no longer maintained and thus being removed Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Remove board support for ASHKumar Gala
Support for the ASH board is no longer maintained and thus being removed Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] VM: add page_state info to per-node meminfoMartin Hicks
Add page_state info to the per-node meminfo file in sysfs. This is mostly just for informational purposes. The lack of this information was brought up recently during a discussion regarding pagecache clearing, and I put this patch together to test out one of the suggestions. It seems like interesting info to have, so I'm submitting the patch. Signed-off-by: Martin Hicks <mort@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86_64: avoid some atomic operations during address space destructionZachary Amsden
Any architecture that has hardware updated A/D bits that require synchronization against other processors during PTE operations can benefit from doing non-atomic PTE updates during address space destruction. Originally done on i386, now ported to x86_64. Doing a read/write pair instead of an xchg() operation saves the implicit lock, which turns out to be a big win on 32-bit (esp w PAE). Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: ptep_clear optimizationZachary Amsden
Add a new accessor for PTEs, which passes the full hint from the mmu_gather struct; this allows architectures with hardware pagetables to optimize away atomic PTE operations when destroying an address space. Removing the locked operation should allow better pipelining of memory access in this loop. I measured an average savings of 30-35 cycles per zap_pte_range on the first 500 destructions on Pentium-M, but I believe the optimization would win more on older processors which still assert the bus lock on xchg for an exclusive cacheline. Update: I made some new measurements, and this saves exactly 26 cycles over ptep_get_and_clear on Pentium M. On P4, with a PAE kernel, this saves 180 cycles per ptep_get_and_clear, for a whopping 92160 cycles savings for a full address space destruction. pte_clear_full is not yet used, but is provided for future optimizations (in particular, when running inside of a hypervisor that queues page table updates, the full hint allows us to avoid queueing unnecessary page table update for an address space in the process of being destroyed. This is not a huge win, but it does help a bit, and sets the stage for further hypervisor optimization of the mm layer on all architectures. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Christoph Lameter <christoph@lameter.com> Cc: <linux-mm@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] sab: consolidate kmem_bufctl_tKyle Moffett
This is used only in slab.c and each architecture gets to define whcih underlying type is to be used. Seems a bit silly - move it to slab.c and use the same type for all architectures: unsigned int. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] remove hugetlb_clean_stale_pgtable() and fix huge_pte_alloc()Chen, Kenneth W
I don't think we need to call hugetlb_clean_stale_pgtable() anymore in 2.6.13 because of the rework with free_pgtables(). It now collect all the pte page at the time of munmap. It used to only collect page table pages when entire one pgd can be freed and left with staled pte pages. Not anymore with 2.6.13. This function will never be called and We should turn it into a BUG_ON. I also spotted two problems here, not Adam's fault :-) (1) in huge_pte_alloc(), it looks like a bug to me that pud is not checked before calling pmd_alloc() (2) in hugetlb_clean_stale_pgtable(), it also missed a call to pmd_free_tlb. I think a tlb flush is required to flush the mapping for the page table itself when we clear out the pmd pointing to a pte page. However, since hugetlb_clean_stale_pgtable() is never called, so it won't trigger the bug. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Cc: Adam Litke <agl@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] hugetlb: add pte_huge() macroAdam Litke
This patch adds a macro pte_huge(pte) for i386/x86_64 which is needed by a patch later in the series. Instead of repeating (_PAGE_PRESENT | _PAGE_PSE), I've added __LARGE_PTE to i386 to match x86_64. Signed-off-by: Adam Litke <agl@us.ibm.com> Cc: <linux-mm@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] arm: allow for arch-specific IOREMAP_MAX_ORDERDeepak Saxena
Version 6 of the ARM architecture introduces the concept of 16MB pages (supersections) and 36-bit (40-bit actually, but nobody uses this) physical addresses. 36-bit addressed memory and I/O and ARMv6 can only be mapped using supersections and the requirement on these is that both virtual and physical addresses be 16MB aligned. In trying to add support for ioremap() of 36-bit I/O, we run into the issue that get_vm_area() allows for a maximum of 512K alignment via the IOREMAP_MAX_ORDER constant. To work around this, we can: - Allocate a larger VM area than needed (size + (1ul << IOREMAP_MAX_ORDER)) and then align the pointer ourselves, but this ends up with 512K of wasted VM per ioremap(). - Provide a new __get_vm_area_aligned() API and make __get_vm_area() sit on top of this. I did this and it works but I don't like the idea adding another VM API just for this one case. - My preferred solution which is to allow the architecture to override the IOREMAP_MAX_ORDER constant with it's own version. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mm: correct _PAGE_FILE commentPaolo 'Blaisorblade' Giarrusso
_PAGE_FILE does not indicate whether a file is in page / swap cache, it is set just for non-linear PTE's. Correct the comment for i386, x86_64, UML. Also clearify _PAGE_NONE. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] comment typo fixPaolo 'Blaisorblade' Giarrusso
smp_entry_t -> swap_entry_t Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] VM: add capabilites check to set_zone_reclaimMartin Hicks
Add a capability check to sys_set_zone_reclaim(). This syscall is not something that should be available to a user. Signed-off-by: Martin Hicks <mort@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mm: remove atomicNick Piggin
This bitop does not need to be atomic because it is performed when there will be no references to the page (ie. the page is being freed). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] /proc/<pid>/numa_maps to show on which nodes pages resideChristoph Lameter
This patch was recently discussed on linux-mm: http://marc.theaimsgroup.com/?t=112085728500002&r=1&w=2 I inherited a large code base from Ray for page migration. There was a small patch in there that I find to be very useful since it allows the display of the locality of the pages in use by a process. I reworked that patch and came up with a /proc/<pid>/numa_maps that gives more information about the vma's of a process. numa_maps is indexes by the start address found in /proc/<pid>/maps. F.e. with this patch you can see the page use of the "getty" process: margin:/proc/12008 # cat maps 00000000-00004000 r--p 00000000 00:00 0 2000000000000000-200000000002c000 r-xp 00000000 08:04 516 /lib/ld-2.3.3.so 2000000000038000-2000000000040000 rw-p 00028000 08:04 516 /lib/ld-2.3.3.so 2000000000040000-2000000000044000 rw-p 2000000000040000 00:00 0 2000000000058000-2000000000260000 r-xp 00000000 08:04 54707842 /lib/tls/libc.so.6.1 2000000000260000-2000000000268000 ---p 00208000 08:04 54707842 /lib/tls/libc.so.6.1 2000000000268000-2000000000274000 rw-p 00200000 08:04 54707842 /lib/tls/libc.so.6.1 2000000000274000-2000000000280000 rw-p 2000000000274000 00:00 0 2000000000280000-20000000002b4000 r--p 00000000 08:04 9126923 /usr/lib/locale/en_US.utf8/LC_CTYPE 2000000000300000-2000000000308000 r--s 00000000 08:04 60071467 /usr/lib/gconv/gconv-modules.cache 2000000000318000-2000000000328000 rw-p 2000000000318000 00:00 0 4000000000000000-4000000000008000 r-xp 00000000 08:04 29576399 /sbin/mingetty 6000000000004000-6000000000008000 rw-p 00004000 08:04 29576399 /sbin/mingetty 6000000000008000-600000000002c000 rw-p 6000000000008000 00:00 0 [heap] 60000fff7fffc000-60000fff80000000 rw-p 60000fff7fffc000 00:00 0 60000ffffff44000-60000ffffff98000 rw-p 60000ffffff44000 00:00 0 [stack] a000000000000000-a000000000020000 ---p 00000000 00:00 0 [vdso] cat numa_maps 2000000000000000 default MaxRef=43 Pages=11 Mapped=11 N0=4 N1=3 N2=2 N3=2 2000000000038000 default MaxRef=1 Pages=2 Mapped=2 Anon=2 N0=2 2000000000040000 default MaxRef=1 Pages=1 Mapped=1 Anon=1 N0=1 2000000000058000 default MaxRef=43 Pages=61 Mapped=61 N0=14 N1=15 N2=16 N3=16 2000000000268000 default MaxRef=1 Pages=2 Mapped=2 Anon=2 N0=2 2000000000274000 default MaxRef=1 Pages=3 Mapped=3 Anon=3 N0=3 2000000000280000 default MaxRef=8 Pages=3 Mapped=3 N0=3 2000000000300000 default MaxRef=8 Pages=2 Mapped=2 N0=2 2000000000318000 default MaxRef=1 Pages=1 Mapped=1 Anon=1 N2=1 4000000000000000 default MaxRef=6 Pages=2 Mapped=2 N1=2 6000000000004000 default MaxRef=1 Pages=1 Mapped=1 Anon=1 N0=1 6000000000008000 default MaxRef=1 Pages=1 Mapped=1 Anon=1 N0=1 60000fff7fffc000 default MaxRef=1 Pages=1 Mapped=1 Anon=1 N0=1 60000ffffff44000 default MaxRef=1 Pages=1 Mapped=1 Anon=1 N0=1 getty uses ld.so. The first vma is the code segment which is used by 43 other processes and the pages are evenly distributed over the 4 nodes. The second vma is the process specific data portion for ld.so. This is only one page. The display format is: <startaddress> Links to information in /proc/<pid>/map <memory policy> This can be "default" "interleave={}", "prefer=<node>" or "bind={<zones>}" MaxRef= <maximum reference to a page in this vma> Pages= <Nr of pages in use> Mapped= <Nr of pages with mapcount > Anon= <nr of anonymous pages> Nx= <Nr of pages on Node x> The content of the proc-file is self-evident. If this would be tied into the sparsemem system then the contents of this file would not be too useful. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swap: swap_lock replace list+deviceHugh Dickins
The idea of a swap_device_lock per device, and a swap_list_lock over them all, is appealing; but in practice almost every holder of swap_device_lock must already hold swap_list_lock, which defeats the purpose of the split. The only exceptions have been swap_duplicate, valid_swaphandles and an untrodden path in try_to_unuse (plus a few places added in this series). valid_swaphandles doesn't show up high in profiles, but swap_duplicate does demand attention. However, with the hold time in get_swap_pages so much reduced, I've not yet found a load and set of swap device priorities to show even swap_duplicate benefitting from the split. Certainly the split is mere overhead in the common case of a single swap device. So, replace swap_list_lock and swap_device_lock by spinlock_t swap_lock (generally we seem to prefer an _ in the name, and not hide in a macro). If someone can show a regression in swap_duplicate, then probably we should add a hashlock for the swap_map entries alone (shorts being anatomic), so as to help the case of the single swap device too. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swap: scan_swap_map drop swap_device_lockHugh Dickins
get_swap_page has often shown up on latency traces, doing lengthy scans while holding two spinlocks. swap_list_lock is already dropped, now scan_swap_map drop swap_device_lock before scanning the swap_map. While scanning for an empty cluster, don't worry that racing tasks may allocate what was free and free what was allocated; but when allocating an entry, check it's still free after retaking the lock. Avoid dropping the lock in the expected common path. No barriers beyond the locks, just let the cookie crumble; highest_bit limit is volatile, but benign. Guard against swapoff: must check SWP_WRITEOK before allocating, must raise SWP_SCANNING reference count while in scan_swap_map, swapoff wait for that to fall - just use schedule_timeout, we don't want to burden scan_swap_map itself, and it's very unlikely that anyone can really still be in scan_swap_map once swapoff gets this far. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swap: swap unsigned int consistencyHugh Dickins
The swap header's unsigned int last_page determines the range of swap pages, but swap_info has been using int or unsigned long in some cases: use unsigned int throughout (except, in several places a local unsigned long is useful to avoid overflows when adding). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swap: show span of swap extentsHugh Dickins
The "Adding %dk swap" message shows the number of swap extents, as a guide to how fragmented the swapfile may be. But a useful further guide is what total extent they span across (sometimes scarily large). And there's no need to keep nr_extents in swap_info: it's unused after the initial message, so save a little space by keeping it on stack. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swap: swap extent list is orderedHugh Dickins
There are several comments that swap's extent_list.prev points to the lowest extent: that's not so, it's extent_list.next which points to it, as you'd expect. And a couple of loops in add_swap_extent which go all the way through the list, when they should just add to the other end. Fix those up, and let map_swap_page search the list forwards: profiles shows it to be twice as quick that way - because prefetch works better on how the structs are typically kmalloc'ed? or because usually more is written to than read from swap, and swap is allocated ascendingly? Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mm: consolidate get_orderStephen Rothwell
Someone mentioned that almost all the architectures used basically the same implementation of get_order. This patch consolidates them into asm-generic/page.h and includes that in the appropriate places. The exceptions are ia64 and ppc which have their own (presumably optimised) versions. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] sparsemem extreme: hotplug preparationDave Hansen
This splits up sparse_index_alloc() into two pieces. This is needed because we'll allocate the memory for the second level in a different place from where we actually consume it to keep the allocation from happening underneath a lock Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Bob Picco <bob.picco@hp.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] sparsemem extreme implementationBob Picco
With cleanups from Dave Hansen <haveblue@us.ibm.com> SPARSEMEM_EXTREME makes mem_section a one dimensional array of pointers to mem_sections. This two level layout scheme is able to achieve smaller memory requirements for SPARSEMEM with the tradeoff of an additional shift and load when fetching the memory section. The current SPARSEMEM implementation is a one dimensional array of mem_sections which is the default SPARSEMEM configuration. The patch attempts isolates the implementation details of the physical layout of the sparsemem section array. SPARSEMEM_EXTREME requires bootmem to be functioning at the time of memory_present() calls. This is not always feasible, so architectures which do not need it may allocate everything statically by using SPARSEMEM_STATIC. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] SPARSEMEM EXTREMEBob Picco
A new option for SPARSEMEM is ARCH_SPARSEMEM_EXTREME. Architecture platforms with a very sparse physical address space would likely want to select this option. For those architecture platforms that don't select the option, the code generated is equivalent to SPARSEMEM currently in -mm. I'll be posting a patch on ia64 ml which uses this new SPARSEMEM feature. ARCH_SPARSEMEM_EXTREME makes mem_section a one dimensional array of pointers to mem_sections. This two level layout scheme is able to achieve smaller memory requirements for SPARSEMEM with the tradeoff of an additional shift and load when fetching the memory section. The current SPARSEMEM -mm implementation is a one dimensional array of mem_sections which is the default SPARSEMEM configuration. The patch attempts isolates the implementation details of the physical layout of the sparsemem section array. ARCH_SPARSEMEM_EXTREME depends on 64BIT and is by default boolean false. I've boot tested under aim load ia64 configured for ARCH_SPARSEMEM_EXTREME. I've also boot tested a 4 way Opteron machine with !ARCH_SPARSEMEM_EXTREME and tested with aim. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-02[PATCH] remove driverfs references from include/linux/cpu.h and ↵Rolf Eike Beer
net/sunrpc/rpc_pipe.c This patch is against 2.6.10, but still applies cleanly. It's just s/driverfs/sysfs/ in these two files. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-02[PATCH] m68knommu: need pfn_valid macroGreg Ungerer
Need pfn_valid macro, even on MMUless platforms. Enclose the macro args of __pa and __va in parentheses. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-02Merge HEAD from master.kernel.org:/home/rmk/linux-2.6-serial Linus Torvalds
2005-09-02Merge HEAD from master.kernel.org:/home/rmk/linux-2.6-arm Linus Torvalds
2005-09-02Merge refs/heads/ieee80211-wifi from ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
