Add a generic (unoptimized) implementation of checksum.c in pure C
for use by all architectures that cannot be bother with implementing
their own version.
Based on microblaze code by Michal Simek <monstr@monstr.eu>
Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com>
Based on discussions with Michal Simek and code
from m68knommu and h8300, this version of uaccess.h
should be usable by most architectures, by overriding
some parts of it.
Simple NOMMU architectures can use it out of
the box, but a minimal __access_ok() should be
added there as well.
Memory management in generic is highly architecture specific,
but on NOMMU architectures, it is mostly trivial, so just
add a default implementation in asm-generic that applies
to all NOMMU architectures.
The two files cache.h and cacheflush.h can possibly also
be used by architectures that have an MMU but never require
flushing the cache or have cache lines larger than 32 bytes.
atomic.h and io.h are based on the mn10300 architecture,
which is already pretty generic and can be used by
other architectures that do not have hardware support
for atomic operations or out-of-order I/O access.
The dma.h, hw_irq.h, serial.h and timex.h files originally
described PC-style i8237, i8259A, i8250, i8253 and i8255 chips
as well as the VGA style text mode graphics.
Modern architectures live happily without these specific
interfaces, but a few definitions from these headers keep
getting used in common code.
The new generic headers are what most architectures use
anyway nowadays, just implementing the minimal definitions.
These are all kernel internal interfaces that get copied
around a lot. In most cases, architectures can provide
their own optimized versions, but these generic versions
can work as well.
I have tried to use the most common contents of each
header to allow existing architectures to migrate easily.
Thanks to Remis for suggesting a number of cleanups.
bitops.h apparently suffered from some level of bitrot, it
was missing the smp_mb__{before,after}_clear_bit functions,
and included other headers in an invalid order.
This changes the file so that new architectures can use
it out of the box.
Some generic code is using the horribly misnamed PCI_DMA_BUS_IS_PHYS
from asm/pci.h. This makes sure that an architecture without PCI
support does not have to define this itself but can rely on the
asm-generic version.
Evidently, set_rtc_time is supposed to be overridable
by architectures that define their own version, but
unfortunately, get_rtc_ss would in that case still
use the generic version.
This makes get_rtc_ss call the real set_rtc_time
to let architectures define their own version.
The change should fix the "Extended RTC operation"
on Alpha, which uses the incorrect get_rtc_ss
call. It also allows PowerPC to use the asm-generic/rtc.h
file in the future.
Cc: Richard Henderson <rth@twiddle.net>
Cc: linux-alpha@vger.kernel.org
Cc: Tom Rini <trini@mvista.com>
Cc: rtc-linux@googlegroups.com
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
The current asm-generic/page.h only contains the get_order
function, and asm-generic/uaccess.h only implements
unaligned accesses. This renames the file to getorder.h
and uaccess-unaligned.h to make room for new page.h
and uaccess.h file that will be usable by all simple
(e.g. nommu) architectures.
The existing asm-generic/atomic.h only defines the
atomic_long type. This renames it to atomic-long.h
so we have a place to add a truly generic atomic.h
that can be used on all non-SMP systems.
A new architecture should only define a minimal set of system
calls while still providing the full functionality. This version
of unistd.h has gone through intensive review to make sure that
by default it only enables syscalls that do not already have
a more featureful replacement.
It is modeled after the x86-64 version of unistd.h, which unifies
the syscall number definition and the actual system call table
in a single file, in order to keep them synchronized much more
easily.
This first version still keeps legacy system call definitions
around, guarded by various #ifdefs, and with numbers larger
than 1024. The idea behind this is to make it easier for
new architectures to transition from a full list to the reduced
set. In particular, the new microblaze architecture that should
migrate to using the generic ABI headers can at least use an
existing uClibc source tree without major rewrites during the
conversion.
These header files are typically copied from an existing architecture
into any new one, slightly modified and then remain untouched until
the end of time in the name of ABI stability.
To make it easier for future architectures, provide a sane generic
version here. In cases where multiple architectures already use
identical code, I used the most common version. In cases like
stat.h that are more or less broken everywhere, I provide a
version that is meant to be ideal for new architectures.
The ipc64 data structures were originally meant to
be architecture specific so that each architecture
could add their own optimizations for padding.
In the end, most of them just copied the x86 version,
and most got that wrong. UClibc expects the x86 anyway,
so we might just declare that the default and get
rid of the extra copies.
This provides a reliable way for asm-generic/types.h and other
files to find out if it is running on a 32 or 64 bit platform.
We cannot use CONFIG_64BIT for this in headers that are included
from user space because CONFIG symbols are not available there.
We also cannot do it inside of asm/types.h because some headers
need the word size but cannot include types.h.
The solution is to introduce a new header <asm/bitsperlong.h>
that defines both __BITS_PER_LONG for user space and
BITS_PER_LONG for usage in the kernel. The asm-generic
version falls back to 32 bit unless the architecture overrides
it, which I did for all 64 bit platforms.
The existing asm-generic versions are incomplete and included
by some architectures. New architectures should be able
to use a generic version, so rename the existing files and
change all users, which lets us add the new files.
So can get cpumask_var with cpumask_clear
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 5543/1: arm: serial amba: add missing declaration in serial.h
[ARM] pxa: fix pxa27x_udc default pullup GPIO
[ARM] pxa/imote2: fix UCAM sensor board ADC model number
mx[23]: don't put clock lookups in __initdata
fix oops when using console=ttymxcN with N > 0
[ARM] ARMv7 errata: only apply fixes when running on applicable CPU
[ARM] 5534/1: kmalloc must return a cache line aligned buffer
This header is sometimes included in the uncompress stage to get
register values, but no <linux/amba/bus.h> can be included there.
So declare "struct amba_device" here before using it in a prototype.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
The "trace || CLONE_PTRACE" check in tracehook_report_clone() is not right,
- If the untraced task does clone(CLONE_PTRACE) the new child is not traced,
we must not queue SIGSTOP.
- If we forked the traced task, but the tracer exits and untraces both the
forking task and the new child (after copy_process() drops tasklist_lock),
we should not queue SIGSTOP too.
Change the code to check task_ptrace() != 0 instead. This is still racy, but
the race is harmless.
We can race with another tracer attaching to this child, or the tracer can
exit and detach in parallel. But giwen that we didn't do wake_up_new_task()
yet, the child must have the pending SIGSTOP anyway.
Acked-by: Roland McGrath <roland@redhat.com>
drm_helper_connector_dpms.
Making the drm_crtc.c code recognize the DPMS property and invoke the
connector->dpms function doesn't remove any capability from the driver while
reducing code duplication.
That just highlighted the problem with the existing DPMS functions which
could turn off the connector, but failed to turn off any relevant crtcs. The
new drm_helper_connector_dpms function manages all of that, using the
drm_helper-specific crtc and encoder dpms functions, automatically computing
the appropriate DPMS level for each object in the system.
This fixes the current troubles in the i915 driver which left PLLs, pipes
and planes running while in DPMS_OFF mode or even while they were unused.
Signed-off-by: Keith Packard <keithp@keithp.com>
Ideally we should have a directory of drivers and a link to the 'active'
driver. For now just show the first device which is effectively the existing
semantics without a warning.
This is an update on the original buggy patch that I then forgot to
resubmit. Confusingly it was proposed by Red Hat, written by Etched Pixels
fixed and submitted by Intel ...
Resolves-Bug: http://bugzilla.kernel.org/show_bug.cgi?id=9749
Signed-off-by: Alan Cox <alan@linux.intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
3c509: Add missing EISA IDs
MAINTAINERS: take maintainership of the cpmac Ethernet driver
net/firmare: Ignore .cis files
ath1e: add new device id for asus hardware
mlx4_en: Fix a kernel panic when waking tx queue
rtl8187: add USB ID for Linksys WUSB54GC-EU v2 USB wifi dongle
at76c50x-usb: avoid mutex deadlock in at76_dwork_hw_scan
mac8390: fix build with NET_POLL_CONTROLLER
cxgb3: link fault fixes
cxgb3: fix dma mapping regression
netfilter: nfnetlink_log: fix wrong skbuff size calculation
netfilter: xt_hashlimit does a wrong SEQ_SKIP
bfin_mac: fix build error due to net_device_ops convert
atlx: move modinfo data from atlx.h to atl1.c
gianfar: fix babbling rx error event bug
cls_cgroup: read classid atomically in classifier
netfilter: nf_ct_dccp: add missing DCCP protocol changes in event cache
netfilter: nf_ct_tcp: fix accepting invalid RST segments
* git://git.kernel.org/pub/scm/linux/kernel/git/jaswinder/headers-check-2.6:
headers_check fix: linux/net_dropmon.h
headers_check fix: linux/auto_fs.h
fix the following 'make headers_check' warnings:
usr/include/linux/net_dropmon.h:7: found __[us]{8,16,32,64} type without #include <linux/types.h>
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
usr/include/linux/auto_fs.h:17: include of <linux/types.h> is preferred over <asm/types.h>
'redhat-bugzilla-500311', 'pci-bind-oops', 'misc-2.6.30' and 'i7300_idle' into release
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: libps2 - better handle bad scheduler decisions
Input: usb1400_ts - fix access to "device data" in resume function
Input: multitouch - augment event semantics documentation
Input: multitouch - add tracking ID to the protocol
mapping->tree_lock can be acquired from interrupt context. Then,
following dead lock can occur.
Assume "A" as a page.
CPU0:
lock_page_cgroup(A)
interrupted
-> take mapping->tree_lock.
CPU1:
-> lock_page_cgroup(A)
This patch tries to fix above deadlock by moving memcg's hook to out of
mapping->tree_lock. charge/uncharge of pagecache/swapcache is protected
by page lock, not tree_lock.
After this patch, lock_page_cgroup() is not called under mapping->tree_lock.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
linux/cred.h can't be included as first header (alphabetical order)
because it uses __init which is enough to break compilation on some archs.
Acked-by: James Morris <jmorris@namei.org>
Testing the i7300_idle driver on i5000-series hardware required
an edit to i7300_idle.h to "#define SUPPORT_I5000 1" and a re-build
of both i7300_idle and ioat_dma.
Replace that build-time scheme with a load-time module parameter:
"7300_idle.forceload=1" to make it easier to test the driver
on hardware that while not officially validated, works fine
and is much more commonly available.
By default (no modparam) the driver will continue to load
only on the i7300.
Note that ioat_dma runs a copy of i7300_idle's probe routine
to know to reserve an IOAT channel for i7300_idle.
This change makes ioat_dma do that always on the i5000,
just like it does on the i7300.
Signed-off-by: Len Brown <len.brown@intel.com>
Acked-by: Andrew Henroid <andrew.d.henroid@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel:
drm/i915: Add support for VGA load detection (pre-945).
drm/i915: Use an I2C algo to do the flip to SDVO DDC bus.
drm/i915: Determine type before initialising connector
drm/i915: Return SDVO LVDS VBT mode if no EDID modes are detected.
drm/i915: Fetch SDVO LVDS mode lines from VBT, then reserve them
i915: support 8xx desktop cursors
drm/i915: allocate large pointer arrays with vmalloc
Robert L Mathews discovered that some clients send evil TCP RST segments,
which are accepted by netfilter conntrack but discarded by the
destination. Thus the conntrack entry is destroyed but the destination
retransmits data until timeout.
The same technique, i.e. sending properly crafted RST segments, can easily
be used to bypass connlimit/connbytes based restrictions (the sample
script written by Robert can be found in the netfilter mailing list
archives).
The patch below adds a new flag and new field to struct ip_ct_tcp_state so
that checking RST segments can be made more strict and thus TCP conntrack
can catch the invalid ones: the RST segment is accepted only if its
sequence number higher than or equal to the highest ack we seen from the
other direction. (The last_ack field cannot be reused because it is used
to catch resent packets.)
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] mpt2sas: fix driver version inconsistency
[SCSI] 3w-xxxx: scsi_dma_unmap fix
[SCSI] 3w-9xxx: scsi_dma_unmap fix
[SCSI] ses: fix problems caused by empty SES provided name
[SCSI] fc-transport: Close state transition-window during rport deletion.
[SCSI] initialize max_target_blocked in scsi_alloc_target
[SCSI] fnic: Add new Cisco PCI-Express FCoE HBA
There are a few multi-touch devices that support finger tracking
well in hardware, Stantum being the prime example. By exposing the
tracking ID in the MT protocol, evdev bandwidth and cpu usage in
user space can be reduced.
This patch adds the ABS_MT_TRACKING_ID to the MT protocol.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Tested-by: Stéphane Chatty <chatty@enac.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
via82cxxx: Add VIA VX855 PCI Device ID
ide: report timeouts in ide_busy_sleep()
ide: improve failed opcode reporting
ide: fix printk() levels in ide_dump_ata[pi]_error()
ide: fix OOPS during ide-cd error recovery
ide: fix 40-wire cable detection for TSST SH-S202* ATAPI devices (v2)
This patch adds the PCI Device ID 0xc409 to the PCI ID table of via82cxxx.c,
as well as the 0x8409 south bridge ID.
This is required to make the IDE driver work on the VX855/VX875 integrated
chipset.
Signed-off-by: Harald Welte <HaraldWelte@viatech.com>
Cc: Joseph Chan <JosephChan@via.com.tw>
Cc: Bruce Chang <BruceChang@via.com.tw>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
* change 'hwif' argument to 'drive'
* report an error on timeout
* master.kernel.org:/home/rmk/linux-2.6-arm: (25 commits)
[ARM] 5519/1: amba probe: pass "struct amba_id *" instead of void *
[ARM] 5517/1: integrator: don't put clock lookups in __initdata
[ARM] 5518/1: versatile: don't put clock lookups in __initdata
[ARM] mach-l7200: fix spelling of SYS_CLOCK_OFF
[ARM] Double check memmap is actually valid with a memmap has unexpected holes V2
[ARM] realview: fix broadcast tick support
[ARM] realview: remove useless smp_cross_call_done()
[ARM] smp: fix cpumask usage in ARM SMP code
[ARM] 5513/1: Eurotech VIPER SBC: fix compilation error
[ARM] 5509/1: ep93xx: clkdev enable UARTS
ARM: OMAP2/3: Change omapfb to use clkdev for dispc and rfbi, v2
ARM: OMAP3: Fix HW SAVEANDRESTORE shift define
ARM: OMAP3: Fix number of GPIO lines for 34xx
[ARM] S3C: Do not set clk->owner field if unset
[ARM] S3C2410: mach-bast.c registering i2c data too early
[ARM] S3C24XX: Fix unused code warning in arch/arm/plat-s3c24xx/dma.c
[ARM] S3C64XX: fix GPIO debug
[ARM] S3C64XX: GPIO include cleanup
[ARM] nwfpe: fix 'floatx80_is_nan' sparse warning
[ARM] nwfpe: Add decleration for ExtendedCPDO
The second argument of the probe method points to the amba_id
structure, so it's better passed with the correct type. None of the
current in-tree drivers uses the pointer, so they have only been
checked for a clean compile.
Change suggested by Russell King.
For awhile now, many of the GEM code paths have allocated page or
object arrays with the slab allocator. This is nice and fast, but
won't work well if memory is fragmented, since the slab allocator works
with physically contiguous memory (i.e. order > 2 allocations are
likely to fail fairly early after booting and doing some work).
This patch works around the issue by falling back to vmalloc for
>PAGE_SIZE allocations. This is ugly, but much less work than chaining
a bunch of pages together by hand (suprisingly there's not a bunch of
generic kernel helpers for this yet afaik). vmalloc space is somewhat
precious on 32 bit kernels, but our allocations shouldn't be big enough
to cause problems, though they're routinely more than a page.
Note that this patch doesn't address the unchecked
alloc-based-on-ioctl-args in GEM; that needs to be fixed in a separate
patch.
Also, I've deliberately ignored the DRM's "area" junk. I don't think
anyone actually uses it anymore and I'm hoping it gets ripped out soon.
[Updated: removed size arg to new free function. We could unify the
free functions as well once the DRM mem tracking is ripped out.]
fd.o bug #20152 (part 1/3)
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Eric Anholt <eric@anholt.net>
`local_add_unless(x, y, z)' will be expanded to `(&(x)->y, (y), (x))', but
`&(x)->y' should be `&(x)->a'
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
holes V2
pfn_valid() is meant to be able to tell if a given PFN has valid memmap
associated with it or not. In FLATMEM, it is expected that holes always
have valid memmap as long as there is valid PFNs either side of the hole.
In SPARSEMEM, it is assumed that a valid section has a memmap for the
entire section.
However, ARM and maybe other embedded architectures in the future free
memmap backing holes to save memory on the assumption the memmap is never
used. The page_zone linkages are then broken even though pfn_valid()
returns true. A walker of the full memmap must then do this additional
check to ensure the memmap they are looking at is sane by making sure the
zone and PFN linkages are still valid. This is expensive, but walkers of
the full memmap are extremely rare.
This was caught before for FLATMEM and hacked around but it hits again for
SPARSEMEM because the page_zone linkages can look ok where the PFN linkages
are totally screwed. This looks like a hatchet job but the reality is that
any clean solution would end up consumning all the memory saved by punching
these unexpected holes in the memmap. For example, we tried marking the
memmap within the section invalid but the section size exceeds the size of
the hole in most cases so pfn_valid() starts returning false where valid
memmap exists. Shrinking the size of the section would increase memory
consumption offsetting the gains.
This patch identifies when an architecture is punching unexpected holes
in the memmap that the memory model cannot automatically detect and sets
ARCH_HAS_HOLES_MEMORYMODEL. At the moment, this is restricted to EP93xx
which is the model sub-architecture this has been reported on but may expand
later. When set, walkers of the full memmap must call memmap_valid_within()
for each PFN and passing in what it expects the page and zone to be for
that PFN. If it finds the linkages to be broken, it assumes the memmap is
invalid for that PFN.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
This adds CONFIG_REISERFS_FS_XATTR protection from reiserfs_permission.
This is needed to avoid warnings during file deletions and chowns with
xattrs disabled.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
* 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel:
drm/i915: Add new GET_PIPE_FROM_CRTC_ID ioctl.
drm/i915: Set HDMI hot plug interrupt enable for only the output in question.
drm/i915: Include 965GME pci ID in IS_I965GM(dev) to match UMS.
drm/i915: Use the GM45 VGA hotplug workaround on G45 as well.
drm/i915: ignore LVDS on intel graphics systems that lie about having it
drm/i915: sanity check IER at wait_request time
drm/i915: workaround IGD i2c bus issue in kernel side (v2)
drm/i915: Don't allow binding objects into the last page of the aperture.
drm/i915: save/restore fence registers across suspend/resume
drm/i915: x86 always has writeq. Add I915_READ64 for symmetry.
This patch provides new heuristics for parsing both the form factor and
media rotation rate ATA IDENFITY words.
The reported ATA version must be 7 or greater and the device must return
values defined as valid in the standard. Only then are the
characteristics reported to SCSI via the VPD B1 page.
This seems like a reasonable compromise to me considering that we have
been shipping several kernel releases that key off the rotation rate bit
without any version checking whatsoever. With no complaints so far.
> After an rport's state has transitioned to FC_PORTSTATE_BLOCKED,
> but, prior to making the upcall to 'block' the scsi-target
> associated with an rport, queued commands can recycle and
> ultimately run out of retries causing failures to propagate to
> upper-level drivers. Close this transition-window by returning
> the non-'retries' modifying DID_IMM_RETRY status for submitted
> I/Os.
The same can happen for iscsi when transitioning from logged in
to failed and blocking the sdevs.
This patch converts iscsi and fc's transitions back to use DID_IMM_RETRY
instead of DID_TRANSPORT_DISRUPTED which has a limited number of retries
that we do not want to use for handling this race.
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
[Addition of iscsi and fc port online devloss case conversion by Mike Christie]
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
Revert "mm: add /proc controls for pdflush threads"
viocd: needs to depend on BLOCK
block: fix the bio_vec array index out-of-bounds test
This reverts commit fafd688e4c0c34da0f3de909881117d374e4c7af.
Work is progressing to switch away from pdflush as the process backing
for flushing out dirty data. So it seems pointless to add more knobs
to control pdflush threads. The original author of the patch did not
have any specific use cases for adding the knobs, so we can easily
revert this before 2.6.30 to avoid having to maintain this API
forever.
