With the switch to using inode->i_mutex locking during lookups/creation
in the xattr root, the per-super xattr lock is no longer needed.
This patch removes it.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
The current reiserfs xattr implementation will not clean up old xattr
files if files are deleted when REISERFS_FS_XATTR is unset. This
results in inaccessible lost files, wasting space.
This patch compiles in basic xattr knowledge, such as how to delete them
and change ownership for quota tracking. If the file system has never
used xattrs, then the operation is quite fast: it returns immediately
when it sees there is no .reiserfs_priv directory.
There are a number of helper functions for marking a reiserfs inode
private that were leftover from reiserfs did its own thing wrt to
private inodes. S_PRIVATE has been in the kernel for some time, so this
patch removes the helpers and uses IS_PRIVATE instead.
Although reiserfs can currently handle severe errors such as journal failure,
it cannot handle less severe errors like metadata i/o failure. The following
patch adds a reiserfs_error() function akin to the one in ext3.
Subsequent patches will use this new error handler to handle errors more
gracefully in general.
This patch kills off reiserfs_journal_abort as it is never called, and
combines __reiserfs_journal_abort_{soft,hard} into one function called
reiserfs_abort_journal, which performs the same work. It is silent
as opposed to the old version, since the message was always issued
after a regular 'abort' message.
ReiserFS panics can be somewhat inconsistent.
In some cases:
* a unique identifier may be associated with it
* the function name may be included
* the device may be printed separately
This patch aims to make warnings more consistent. reiserfs_warning() prints
the device name, so printing it a second time is not required. The function
name for a warning is always helpful in debugging, so it is now automatically
inserted into the output. Hans has stated that every warning should have
a unique identifier. Some cases lack them, others really shouldn't have them.
reiserfs_warning() now expects an id associated with each message. In the
rare case where one isn't needed, "" will suffice.
uniqueness2type and type2uniquness issue a warning when the value is
unknown. When called from reiserfs_warning, this causes a re-entrancy
problem and deadlocks on the error buffer lock.
ReiserFS warnings can be somewhat inconsistent.
In some cases:
This patch makes leaf_paste_entries more consistent with respect to the
other leaf operations. Using buffer_info instead of buffer_head
directly allows us to get a superblock pointer for use in error
handling.
This patch fixes up the reiserfs code such that transaction ids are
always unsigned ints. In places they can currently be signed ints or
unsigned longs.
The former just causes an annoying clm-2200 warning and may join a
transaction when it should wait.
The latter is just for correctness since the disk format uses a 32-bit
transaction id. There aren't any runtime problems that result from it
not wrapping at the correct location since the value is truncated
correctly even on big endian systems. The 0 value might make it to
disk, but the mount-time checks will bump it to 10 itself.
The following patch adds the fields for tracking mount counts and last
fsck timestamps to the superblock. It also increments the mount count
on every read-write mount.
Reiserfsprogs 3.6.21 added support for these fields.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits)
ucc_geth: Fix oops when using fixed-link support
dm9000: locking bugfix
net: update dnet.c for bus_id removal
dnet: DNET should depend on HAS_IOMEM
dca: add missing copyright/license headers
nl80211: Check that function pointer != NULL before using it
sungem: missing net_device_ops
be2net: fix to restore vlan ids into BE2 during a IF DOWN->UP cycle
be2net: replenish when posting to rx-queue is starved in out of mem conditions
bas_gigaset: correctly allocate USB interrupt transfer buffer
smsc911x: reset last known duplex and carrier on open
sh_eth: Fix mistake of the address of SH7763
sh_eth: Change handling of IRQ
netns: oops in ip[6]_frag_reasm incrementing stats
net: kfree(napi->skb) => kfree_skb
net: fix sctp breakage
ipv6: fix display of local and remote sit endpoints
net: Document /proc/sys/net/core/netdev_budget
tulip: fix crash on iface up with shirq debug
virtio_net: Make virtio_net support carrier detection
In two dca files copyright and license headers are missing.
This patch adds them there.
Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
Since creating a device node is normally an operation requiring special
privilege, Igor Zhbanov points out that it is surprising (to say the
least) that a client can, for example, create a device node on a
filesystem exported with root_squash.
So, make sure CAP_MKNOD is among the capabilities dropped when an nfsd
thread handles a request from a non-root user.
Reported-by: Igor Zhbanov <izh1979@gmail.com>
Cc: stable@kernel.org
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
This patch skips the delivery of conntrack events if the packet
was drop due to a race condition in the conntrack insertion.
* master.kernel.org:/home/rmk/linux-2.6-arm: (23 commits)
[ARM] Fix virtual to physical translation macro corner cases
[ARM] update mach-types
[ARM] 5421/1: ftrace: fix crash due to tracing of __naked functions
MX1 fix include
[ARM] 5419/1: ep93xx: fix build warnings about struct i2c_board_info
[ARM] 5418/1: restore lr before leaving mcount
ARM: OMAP: board-omap3beagle: set i2c-3 to 100kHz
ARM: OMAP: Allow I2C bus driver to be compiled as a module
ARM: OMAP: sched_clock() corrected
ARM: OMAP: Fix compile error if pm.h is included
[ARM] orion5x: pass dram mbus data to xor driver
[ARM] S3C64XX: Fix s3c64xx_setrate_clksrc
[ARM] S3C64XX: sparse warnings in arch/arm/plat-s3c64xx/irq.c
[ARM] S3C64XX: sparse warnings in arch/arm/plat-s3c64xx/s3c6400-clock.c
[ARM] S3C64XX: Fix USB host clock mux list
[ARM] S3C64XX: Fix name of USB host clock.
[ARM] S3C64XX: Rename IRQ_UHOST to IRQ_USBH
[ARM] S3C64XX: Do gpiolib configuration earlier
[ARM] S3C64XX: Staticise s3c64xx_init_irq_eint()
[ARM] SMDK6410: Declare iodesc table static
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
Fix Xilinx SystemACE driver to handle empty CF slot
block: fix memory leak in bio_clone()
block: Add gfp_mask parameter to bio_integrity_clone()
Stricter gfp_mask might be required for clone allocation.
For example, request-based dm may clone bio in interrupt context
so it has to use GFP_ATOMIC.
Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Alasdair G Kergon <agk@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (31 commits)
[SCSI] qla2xxx: Update version number to 8.03.00-k4.
[SCSI] qla2xxx: Correct overwrite of pre-assigned init-control-block structure size.
[SCSI] qla2xxx: Correct truncation in return-code status checking.
[SCSI] qla2xxx: Correct vport delete bug.
[SCSI] qla2xxx: Use correct value for max vport in LOOP topology.
[SCSI] qla2xxx: Correct address range checking for option-rom updates.
[SCSI] fcoe: Change fcoe receive thread nice value from 19 (lowest priority) to -20
[SCSI] fcoe: fix handling of pending queue, prevent out of order frames (v3)
[SCSI] fcoe: Out of order tx frames was causing several check condition SCSI status
[SCSI] fcoe: fix kfree(skb)
[SCSI] fcoe: ETH_P_8021Q is already in if_ether and fcoe is not using it anyway
[SCSI] libfc: do not change the fh_rx_id of a recevied frame
[SCSI] fcoe: Correct fcoe_transports initialization vs. registration
[SCSI] fcoe: Use setup_timer() and mod_timer()
[SCSI] libfc, fcoe: Remove unnecessary cast by removing inline wrapper
[SCSI] libfc, fcoe: Cleanup function formatting and minor typos
[SCSI] libfc, fcoe: Fix kerneldoc comments
[SCSI] libfc: Cleanup libfc_function_template comments
[SCSI] libfc: check for err when recv and state is incorrect
[SCSI] libfc: rename rp to rdata in fc_disc_new_target()
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
NFS: Fix the fix to Bugzilla #11061, when IPv6 isn't defined...
SUNRPC: xprt_connect() don't abort the task if the transport isn't bound
SUNRPC: Fix an Oops due to socket not set up yet...
Bug 11061, NFS mounts dropped
NFS: Handle -ESTALE error in access()
NLM: Fix GRANT callback address comparison when IPv6 is enabled
NLM: Shrink the IPv4-only version of nlm_cmp_addr()
NFSv3: Fix posix ACL code
NFS: Fix misparsing of nfsv4 fs_locations attribute (take 2)
SUNRPC: Tighten up the task locking rules in __rpc_execute()
dma_map_sg could return a value different to 'nents' argument of
dma_map_sg so the ide stack needs to save it for the later usage
(e.g. for_each_sg).
The ide stack also needs to save the original sg_nents value for
pci_unmap_sg.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
[bart: backport to Linus' tree]
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
cpumask: mm_cpumask for accessing the struct mm_struct's cpu_vm_mask.
cpumask: tsk_cpumask for accessing the struct task_struct's cpus_allowed.
This is a fix for the following crash observed in 2.6.29-rc3:
http://lkml.org/lkml/2009/1/29/150
On ARM it doesn't make sense to trace a naked function because then
mcount is called without stack and frame pointer being set up and there
is no chance to restore the lr register to the value before mcount was
called.
Reported-by: Matthias Kaehlcke <matthias@kaehlcke.net>
Tested-by: Matthias Kaehlcke <matthias@kaehlcke.net>
Cc: Abhishek Sagar <sagar.abhishek@gmail.com>
Cc: Steven Rostedt <rostedt@home.goodmis.org>
This allows us to change the representation (to a dangling bitmap or
cpumask_var_t) without breaking all the callers: they can use
mm_cpumask() now and won't see a difference as the changes roll into
linux-next.
tsk_cpumask() now and won't see a difference as the changes roll into
linux-next.
Comparing the layouts of struct detail_pixel_timing with
x.org's struct detailed_timings and how those are handled,
it appears that the hsync_positive and vsync_positive
fields are backwards.
This patch fixes https://bugs.freedesktop.org/show_bug.cgi?id=20019
for me. It was tested on 2 monitors, LG FLATRON L225WS 22" and
a YAKUMO 17" for which more details are unknown.
Signed-off-by: Pantelis Koukousoulas <pktoss@gmail.com>
Clean up/micro-optimatization: Make the AF_INET-only version of
nlm_cmp_addr() smaller. This matches the style of
nlm_privileged_requester(), and makes the AF_INET-only version of
nlm_cmp_addr() nearly the same size as it was before IPv6 support.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Fix a memory leak due to allocation in the XDR layer. In cases where the
RPC call needs to be retransmitted, we end up allocating new pages without
clearing the old ones. Fix this by moving the allocation into
nfs3_proc_setacls().
Also fix an issue discovered by Kevin Rudd, whereby the amount of memory
reserved for the acls in the xdr_buf->head was miscalculated, and causing
corruption.
status
frames followed by these errors in log.
[sdp] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
[sdp] Sense Key : Aborted Command [current]
[sdp] Add. Sense: Data phase error
This was causing some test apps to exit due to write failure under heavy
load.
This was due to a race around adding and removing tx frame skb in
fcoe_pending_queue, Chris Leech helped me to find that brief unlocking
period when pulling skb from fcoe_pending_queue in various contexts
(fcoe_watchdog and fcoe_xmit) and then adding skb back into fcoe_pending_queue
up on a failed fcoe_start_io could change skb/tx frame order in
fcoe_pending_queue. Thanks Chris.
This patch allows only single context to pull skb from fcoe_pending_queue
at any time to prevent above described ordering issue/race by use of
fcoe_pending_queue_active flag.
This patch simplified fcoe_watchdog with modified fcoe_check_wait_queue by
use of FCOE_LOW_QUEUE_DEPTH instead previously used several conditionals
to clear and set lp->qfull.
I think FCOE_MAX_QUEUE_DEPTH with FCOE_LOW_QUEUE_DEPTH will work better
in re/setting lp->qfull and these could be fine tuned for performance.
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
Signed-off-by: Robert Love <robert.w.love@intel.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Signed-off-by: Yi Zou <yi.zou@intel.com>
Comment from "Andrew Morton <akpm@linux-foundation.org>"
> + return (struct fcoe_softc *)lport_priv(lp);
unneeded/undesirable cast of void*. There are probably zillions of
instances of this - there always are.
This whole inline function was unnecessary. The FCoE layer knows
that it's data structure is stored in the lport private data, it
can just access it from lport_priv().
1) Added '()' for function names in kerneldoc comments
2) Changed comment bookends from '**/' to '*/'. The comment on the the
mailing list was that '**/' "is consistently unconventional. Not
wrong, just odd." The Documentation/kernel-doc-nano-HOWTO.txt
states that kerneldoc comment blocks should end with '**/' but most
(if not all) instance I found under drivers/scsi/ were only using
the '*/' so I converted to that style.
3) Removed incorrect linebreaks in kerneldoc comments where found
4) Removed a few unnecessary blank comment lines in kerneldoc comment
blocks
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] Add p4-clockmod sysfs-ui removal to feature-removal schedule.
Revert "[CPUFREQ] Disable sysfs ui for p4-clockmod."
This reverts commit e088e4c9cdb618675874becb91b2fd581ee707e6.
Removing the sysfs interface for p4-clockmod was flagged as a
regression in bug 12826.
Course of action:
- Find out the remaining causes of overheating, and fix them
if possible. ACPI should be doing the right thing automatically.
If it isn't, we need to fix that.
- mark p4-clockmod ui as deprecated
- try again with the removal in six months.
It's not really feasible to printk about the deprecation, because
it needs to happen at all the sysfs entry points, which means adding
a lot of strcmp("p4-clockmod".. calls to the core, which.. bleuch.
Signed-off-by: Dave Jones <davej@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (29 commits)
p54: fix race condition in memory management
cfg80211: test before subtraction on unsigned
iwlwifi: fix error flow in iwl*_pci_probe
rt2x00 : more devices to rt73usb.c
rt2x00 : more devices to rt2500usb.c
bonding: Fix device passed into ->ndo_neigh_setup().
vlan: Fix vlan-in-vlan crashes.
net: Fix missing dev->neigh_setup in register_netdevice().
tmspci: fix request_irq race
pkt_sched: act_police: Fix a rate estimator test.
tg3: Fix 5906 link problems
SCTP: change sctp_ctl_sock_init() to try IPv4 if IPv6 fails
IPv6: add "disable" module parameter support to ipv6.ko
sungem: another error printed one too early
aoe: error printed 1 too early
net pcmcia: worklimit reaches -1
net: more timeouts that reach -1
net: fix tokenring license
dm9601: new vendor/product IDs
netlink: invert error code in netlink_set_err()
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
dmatest: fix use after free in dmatest_exit
ipu_idmac: fix spinlock type
iop-adma, mv_xor: fix mem leak on self-test setup failure
fsldma: fix off by one in dma_halt
I/OAT: fail self-test if callback test reaches timeout
I/OAT: update driver version and copyright dates
I/OAT: list usage cleanup
I/OAT: set tcp_dma_copybreak to 256k for I/OAT ver.3
I/OAT: cancel watchdog before dma remove
I/OAT: fail initialization on zero channels detection
I/OAT: do not set DCACTRL_CMPL_WRITE_ENABLE for I/OAT ver.3
I/OAT: add verification for proper APICID_TAG_MAP setting by BIOS
dmaengine: update kerneldoc
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
ata: add CFA specific identify data words
remove stale comment from <linux/hdreg.h>
AT91: initialize Compact Flash on AT91SAM9263 cpu
ide: add at91_ide driver
ide: allow to wrap interrupt handler
ide-iops: fix odd-length ATAPI PIO transfers
ide: NULL noise: drivers/ide/ide-*.c
ide: expiry() returns int, negative expiry() return values won't be noticed
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: Don't trust current capacity values in identify words 57-58
libata: make sure port is thawed when skipping resets
sata_nv: fix module parameter description
ahci: Add the Device IDs for MCP89 and remove IDs of MCP7B to/from ahci.c
libata: don't use on-stack sense buffer
libata: align ap->sector_buf
libata: fix dma_unmap_sg misuse
libata: change drive ready wait after hard reset to 5s
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: serio - fix protocol number for TouchIT213
Protocol 0x37 has been reserved for iNexio devices and Sahara
was supposed to get 0x38.
Reported-by: Claudio Nieder <private@claudio.ch>
Made the comments more like the comments for struct scsi_host_template.
This allows any rport ELS to retry on LS_RJT.
The rport error handling would only retry on resource allocation failures
and exchange timeouts. I have a target that will occasionally reject PLOGI
when we do a quick LOGO/PLOGI. When a critical ELS was rejected, libfc would
fail silently leaving the rport in a dead state.
The retry count and delay are managed by fc_rport_error_retry. If the retry
count is exceeded fc_rport_error will be called. When retrying is not the
correct course of action, fc_rport_error can be called directly.
Signed-off-by: Chris Leech <christopher.leech@intel.com>
lport->link_status
The fcoe_xmit could call fc_pause in case the pending skb queue len is larger
than FCOE_MAX_QUEUE_DEPTH, the fc_pause was trying to grab lport->lp_muex to
change lport->link_status and that had these issues :-
1. The fcoe_xmit was getting called with bh disabled, thus causing
"BUG: scheduling while atomic" when grabbing lport->lp_muex with bh disabled.
2. fc_linkup and fc_linkdown function calls lport_enter function with
lport->lp_mutex held and these enter function in turn calls fcoe_xmit to send
lport related FC frame, e.g. fc_linkup => fc_lport_enter_flogi to send flogi
req. In this case grabbing the same lport->lp_mutex again in fc_puase from
fcoe_xmit would cause deadlock.
The lport->lp_mutex was used for setting FC_PAUSE in fcoe_xmit path but
FC_PAUSE bit was not used anywhere beside just setting and clear this
bit in lport->link_status, instead used a separate field qfull in fc_lport
to eliminate need for lport->lp_mutex to track pending queue full condition
and in turn avoid above described two locking issues.
Also added check for lp->qfull in fc_fcp_lport_queue_ready to trigger
SCSI_MLQUEUE_HOST_BUSY when lp->qfull is set to prevent more scsi-ml cmds
while lp->qfull is set.
This patch eliminated FC_LINK_UP and FC_PAUSE and instead used dedicated
fields in fc_lport for this, this simplified all related conditional
code.
Also removed fc_pause and fc_unpause functions and instead used newly added
lport->qfull directly in fcoe.
fc_exch_mgr structure is private to fc_exch.c. To export exch_mgr_reset to
transport, transport needs access to the exch manager. Change
exch_mgr_reset to use lport param which is the shared structure between
libFC and transport.
Alternatively, fc_exch_mgr definition can be moved to libfc.h so that lport
can be accessed from mp*.
Signed-off-by: Abhijeet Joglekar <abjoglek@cisco.com>
Declare CFA specific identify data words 162 and 163 for future use.
[bart: update patch summary/description]
HDIO_GET_IDENTITY returns 256 words currently.
Noticed by Norman Diamond.
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
Cc: Andrew Victor <linux@maxim.org.za>
[bart: minor checkpatch.pl / CodingStyle fixups]
ap->sector_buf is used as DMA target and should at least be aligned on
cacheline. This caused problems on some embedded machines.
