Mark them deprecated so that out-of-tree developers get notified about
this before their modules break when these macros are removed.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Yang Hongyang <yanghy@cn.fujitsu.com>
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
This is a driver for the ARM PrimeCell PL061 GPIO AMBA peripheral. The
driver is implemented using the gpiolib framework.
This driver also includes support for the use of the PL061 as an interrupt
controller (secondary).
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Cc: David Brownell <david-b@pacbell.net>
Acked-by: Russell King <rmk@arm.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
jbd2: clean up jbd2_journal_try_to_free_buffers()
ext4: Don't update ctime for non-extent-mapped inodes
ext4: Fix up whitespace issues in fs/ext4/inode.c
ext4: Fix 64-bit block type problem on 32-bit platforms
ext4: teach the inode allocator to use a goal inode number
ext4: Use a hash of the topdir directory name for the Orlov parent group
ext4: document the "abort" mount option
ext4: move the abort flag from s_mount_opts to s_mount_flags
ext4: update the s_last_mounted field in the superblock
ext4: change s_mount_opt to be an unsigned int
ext4: online defrag -- Add EXT4_IOC_MOVE_EXT ioctl
ext4: avoid unnecessary spinlock in critical POSIX ACL path
ext3: avoid unnecessary spinlock in critical POSIX ACL path
ext4: convert instrumentation from markers to tracepoints
jbd2: convert instrumentation from markers to tracepoints
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (55 commits)
netxen: fix tx ring accounting
netxen: fix detection of cut-thru firmware mode
forcedeth: fix dma api mismatches
atm: sk_wmem_alloc initial value is one
net: correct off-by-one write allocations reports
via-velocity : fix no link detection on boot
Net / e100: Fix suspend of devices that cannot be power managed
TI DaVinci EMAC : Fix rmmod error
net: group address list and its count
ipv4: Fix fib_trie rebalancing, part 2
pkt_sched: Update drops stats in act_police
sky2: version 1.23
sky2: add GRO support
sky2: skb recycling
sky2: reduce default transmit ring
sky2: receive counter update
sky2: fix shutdown synchronization
sky2: PCI irq issues
sky2: more receive shutdown
sky2: turn off pause during shutdown
Manually fix trivial conflict in net/core/skbuff.c due to kmemcheck
The page allocator also needs the masking of gfp flags during boot,
so this moves it out of slab/slub and uses it with the page allocator
as well.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
* 'for-linus' of git://neil.brown.name/md: (39 commits)
md/raid5: correctly update sync_completed when we reach max_resync
md/raid5: add missing call to schedule() after prepare_to_wait()
md/linear: use call_rcu to free obsolete 'conf' structures.
md linear: Protecting mddev with rcu locks to avoid races
md: Move check for bitmap presence to personality code.
md: remove chunksize rounding from common code.
md: raid0/linear: ensure device sizes are rounded to chunk size.
md: move assignment of ->utime so that it never gets skipped.
md: Push down reconstruction log message to personality code.
md: merge reconfig and check_reshape methods.
md: remove unnecessary arguments from ->reconfig method.
md: raid5: check stripe cache is large enough in start_reshape
md: raid0: chunk_sectors cleanups.
md: fix some comments.
md/raid5: Use is_power_of_2() in raid5_reconfig()/raid6_reconfig().
md: convert conf->chunk_size and conf->prev_chunk to sectors.
md: Convert mddev->new_chunk to sectors.
md: Make mddev->chunk_size sector-based.
md: raid0 :Enables chunk size other than powers of 2.
md: prepare for non-power-of-two chunk sizes
This patch adds lib/gcd.c which contains a greatest common divider
implementation taken from sound/core/pcm_timer.c
Several usages of this new library function will be sent to subsystem
maintainers.
[akpm@linux-foundation.org: use swap() (pointed out by Joe)]
[akpm@linux-foundation.org: just add gcd.o to obj-y, remove Kconfig changes]
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Simon Horman <horms@verge.net.au>
Cc: Julius Volz <juliusv@google.com>
Cc: Patrick McHardy <kaber@trash.net>
This patch adds the kernel side of the PPS support currently named
"LinuxPPS".
PPS means "pulse per second" and a PPS source is just a device which
provides a high precision signal each second so that an application can
use it to adjust system clock time.
Common use is the combination of the NTPD as userland program with a GPS
receiver as PPS source to obtain a wallclock-time with sub-millisecond
synchronisation to UTC.
To obtain this goal the userland programs shoud use the PPS API
specification (RFC 2783 - Pulse-Per-Second API for UNIX-like Operating
Systems, Version 1.0) which in part is implemented by this patch. It
provides a set of chars devices, one per PPS source, which can be used to
get the time signal. The RFC's functions can be implemented by accessing
to these char devices.
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Cc: Greg KH <greg@kroah.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
On embedded devices, sleep mode conditions can be tricky to handle,
Especially when processors tend to pull-down the w1 bus during sleep. Bus
slaves (such as the ds2760) may interpret this as a reason for power-down
conditions and entirely switch off the device.
This patch adds a callback function pointer to let users switch on and off
the external pull-up resistor. This lets the outside world know whether
the processor is currently actively driving the bus or not.
When this callback is not provided, the code behaviour won't change.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Acked-by: Ville Syrjala <syrjala@sci.fi>
Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
We unified x86 and IA64's handling of multiple dma mapping operations
(struct dma_map_ops in linux/dma-mapping.h) so we can remove duplication
in their arch/include/asm/dma-mapping.h.
This patchset adds include/asm-generic/dma-mapping-common.h that provides
some generic dma mapping function definitions for the users of struct
dma_map_ops. This enables us to remove about 100 lines. This also
enables us to easily add CONFIG_DMA_API_DEBUG support, which only x86
supports for now. The 4th patch adds CONFIG_DMA_API_DEBUG support to IA64
by adding only 8 lines.
This patch:
This header file provides some mapping function definitions that the users
of struct dma_map_ops can use.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Joerg Roedel <joerg.roedel@amd.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Enable the use of GCC's coverage testing tool gcov [1] with the Linux
kernel. gcov may be useful for:
* debugging (has this code been reached at all?)
* test improvement (how do I change my test to cover these lines?)
* minimizing kernel configurations (do I need this option if the
associated code is never run?)
The profiling patch incorporates the following changes:
* change kbuild to include profiling flags
* provide functions needed by profiling code
* present profiling data as files in debugfs
Note that on some architectures, enabling gcc's profiling option
"-fprofile-arcs" for the entire kernel may trigger compile/link/
run-time problems, some of which are caused by toolchain bugs and
others which require adjustment of architecture code.
For this reason profiling the entire kernel is initially restricted
to those architectures for which it is known to work without changes.
This restriction can be lifted once an architecture has been tested
and found compatible with gcc's profiling. Profiling of single files
or directories is still available on all platforms (see config help
text).
[1] http://gcc.gnu.org/onlinedocs/gcc/Gcov.html
Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Li Wei <W.Li@Sun.COM>
Cc: Michael Ellerman <michaele@au1.ibm.com>
Cc: Heiko Carstens <heicars2@linux.vnet.ibm.com>
Cc: Martin Schwidefsky <mschwid2@linux.vnet.ibm.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Jeff Dike <jdike@addtoit.com>
seq_write() can be used to construct seq_files containing arbitrary data.
Required by the gcov-profiling interface to synthesize binary profiling
data files.
Call constructors (gcc-generated initcall-like functions) during kernel
start and module load. Constructors are e.g. used for gcov data
initialization.
Disable constructor support for usermode Linux to prevent conflicts with
host glibc.
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Function is really private to ipc/ and avoid struct kern_ipc_perm
forward declaration.
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
find_task_by_pid_type_ns is only used to implement find_task_by_vpid and
find_task_by_pid_ns, but both of them pass PIDTYPE_PID as first argument.
So just fold find_task_by_pid_type_ns into find_task_by_pid_ns and use
find_task_by_pid_ns to implement find_task_by_vpid.
While we're at it also remove the exports for find_task_by_pid_ns and
find_task_by_vpid - we don't have any modular callers left as the only
modular caller of he old pre pid namespace find_task_by_pid (gfs2) was
switched to pid_task which operates on a struct pid pointer instead of a
pid_t. Given the confusion about pid_t values vs namespace that's
generally the better option anyway and I think we're better of restricting
modules to do it that way.
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
- Use rcu_read_lock() instead of tasklist_lock to find/get the task
in ptrace_get_task_struct().
- Make it static, it has no callers outside of ptrace.c.
- The comment doesn't match the reality, this helper does not do
any checks. Beacuse it is really trivial and static I removed the
whole comment.
Acked-by: Roland McGrath <roland@redhat.com>
tracehook_unsafe_exec() doesn't need task_lock(), remove the old comment.
We don't have an interface to reset mem.limit or memsw.limit now.
This patch allows to reset mem.limit or memsw.limit when they are being
set to -1.
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp>
This patch fixes mis-accounting of swap usage in memcg.
In the current implementation, memcg's swap account is uncharged only when
swap is completely freed. But there are several cases where swap cannot
be freed cleanly. For handling that, this patch changes that memcg
uncharges swap account when swap has no references other than cache.
By this, memcg's swap entry accounting can be fully synchronous with the
application's behavior.
This patch also changes memcg's hooks for swap-out.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: Balbir Singh <balbir@in.ibm.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
This forward declaration seems pointless.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
mem_cgroup_cache_charge_swapin() isn't used any more, so remove no-op
definition of it in header file.
Add file RSS tracking per memory cgroup
We currently don't track file RSS, the RSS we report is actually anon RSS.
All the file mapped pages, come in through the page cache and get
accounted there. This patch adds support for accounting file RSS pages.
It should
1. Help improve the metrics reported by the memory resource controller
2. Will form the basis for a future shared memory accounting heuristic
that has been proposed by Kamezawa.
Unfortunately, we cannot rename the existing "rss" keyword used in
memory.stat to "anon_rss". We however, add "mapped_file" data and hope to
educate the end user through documentation.
[hugh.dickins@tiscali.co.uk: fix mem_cgroup_update_mapped_file_stat oops]
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Li Zefan <lizf@cn.fujitsu.cn>
Cc: Paul Menage <menage@google.com>
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Several code paths in reiserfs have a construct like:
if (is_direntry_le_ih(ih = B_N_PITEM_HEAD(src, item_num))) ...
which, in addition to being ugly, end up causing compiler warnings with
gcc 4.4.0. Previous compilers didn't issue a warning.
fs/reiserfs/do_balan.c:1273: warning: operation on `aux_ih' may be undefined
fs/reiserfs/lbalance.c:393: warning: operation on `ih' may be undefined
fs/reiserfs/lbalance.c:421: warning: operation on `ih' may be undefined
fs/reiserfs/lbalance.c:777: warning: operation on `ih' may be undefined
I believe this is due to the ih being passed to macros which evaluate the
argument more than once. This is old code and we haven't seen any
problems with it, but this patch eliminates the warnings.
It converts the multiple evaluation macros to static inlines and does a
preassignment for the cases that were causing the warnings because that
code is just ugly.
Reported-by: Chris Mason <mason@oracle.com>
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Add support to the PCA953x driver to use the GPIOLIB naming facility for
GPIOs.
Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk>
Cc: Ben Gardner <bgardner@wabtec.com>
Cc: Jean Delvare <khali@linux-fr.org>
mpc52xx_psc_spi driver is the last user of the legacy activate_cs and
deactivate_cs callbacks, so convert the driver to the cs_control hook and
remove the legacy callbacks from fsl_spi_platform_data struct.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Move some common spi_setup() error checks into the SPI framework from the
spi_master controller drivers:
- Add a new "mode_bits" field to spi_master
- Use that in spi_setup to validate the spi->mode value being
requested. Setting this new field is now mandatory for any
controller supporting more than vanilla SPI_MODE_0.
- Update all spi_master drivers to:
* Initialize that field
* Remove current spi_setup() checks using that value.
This is a net minor code shrink.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Start moving some spi_setup() functionality into the SPI core from the
various spi_master controller drivers:
- Make that function stop being an inline;
- Move two common idioms from drivers into that new function:
* Default bits_per_word to 8 if that field isn't set
* Issue a standardized dev_dbg() message
This is a net minor source code shrink, and supports enhancments found in
some follow-up patches.
Statistics for softirq doesn't exist.
It will be helpful like statistics for interrupts.
This patch introduces counting the number of softirq,
which will be exported in /proc/softirqs.
When softirq handler consumes much CPU time,
/proc/stat is like the following.
$ while :; do cat /proc/stat | head -n1 ; sleep 10 ; done
cpu 88 0 408 739665 583 28 2 0 0
cpu 450 0 1090 740970 594 28 1294 0 0
softirq
In such a situation,
/proc/softirqs shows us which softirq handler is invoked.
We can see the increase rate of softirqs.
<before>
$ cat /proc/softirqs
CPU0 CPU1 CPU2 CPU3
HI 0 0 0 0
TIMER 462850 462805 462782 462718
NET_TX 0 0 0 365
NET_RX 2472 2 2 40
BLOCK 0 0 381 1164
TASKLET 0 0 0 224
SCHED 462654 462689 462698 462427
RCU 3046 2423 3367 3173
<after>
CPU0 CPU1 CPU2 CPU3
HI 0 0 0 0
TIMER 463361 465077 465056 464991
NET_TX 53 0 1 365
NET_RX 3757 2 2 40
BLOCK 0 0 398 1170
TASKLET 0 0 0 224
SCHED 463074 464318 464612 463330
RCU 3505 2948 3947 3673
When CPU TIME of softirq is high,
the rates of increase is the following.
TIMER : 220/sec : CPU1-3
NET_TX : 5/sec : CPU0
NET_RX : 120/sec : CPU0
SCHED : 40-200/sec : all CPU
RCU : 45-58/sec : all CPU
The rates of increase in an idle mode is the following.
TIMER : 250/sec
SCHED : 250/sec
RCU : 2/sec
It seems many softirqs for receiving packets and rcu are invoked. This
gives us help for checking system.
Signed-off-by: Keika Kobayashi <kobayashi.kk@ncos.nec.co.jp>
Reviewed-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Eric Dumazet <dada1@cosmosbay.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
This patch is inspired by patch recently posted by Johannes Berg. Basically what
my patch does is to group list and a count of addresses into newly introduced
structure netdev_hw_addr_list. This brings us two benefits:
1) struct net_device becames a bit nicer.
2) in the future there will be a possibility to operate with lists independently
on netdevices (with exporting right functions).
I wanted to introduce this patch before I'll post a multicast lists conversion.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
drivers/net/bnx2.c | 4 +-
drivers/net/e1000/e1000_main.c | 4 +-
drivers/net/ixgbe/ixgbe_main.c | 6 +-
drivers/net/mv643xx_eth.c | 2 +-
drivers/net/niu.c | 4 +-
drivers/net/virtio_net.c | 10 ++--
drivers/s390/net/qeth_l2_main.c | 2 +-
include/linux/netdevice.h | 17 +++--
net/core/dev.c | 130 ++++++++++++++++++--------------------
9 files changed, 89 insertions(+), 90 deletions(-)
1/ Raid5 has learned to take over also raid4 and raid6 arrays.
2/ new_chunk in mdp_superblock_1 is in sectors, not bytes.
Signed-off-by: NeilBrown <neilb@suse.de>
This function was only used by pci_claim_resource(), and the last commit
deleted that use.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Convert ia64 to use int-ll64.h
[IA64] Fix build error in paravirt_patchlist.c
[IA64] ia64 does not need umount2() syscall
[IA64] hook up new rt_tgsigqueueinfo syscall
[IA64] msi_ia64.c dmar_msi_type should be static
[IA64] remove obsolete hw_interrupt_type
[IA64] remove obsolete irq_desc_t typedef
[IA64] remove obsolete no_irq_type
[IA64] unexport fpswa.h
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6:
mfd: early init for MFD running regulators
mfd: fix tmio related warnings
mfd: asic3: enable SD/SDIO cell
mfd: asic3: enable DS1WM cell
mfd: asic3: remove SD/SDIO controller register definitions
mfd: asic3: use resource_size macro instead of local variable
mfd: add ASIC3 IRQ numbers
mfd: asic3: add clock handling for MFD cells
mfd: asic3: add asic3_set_register common operation
mfd: Fix Kconfig help text for WM8350
mfd: add PCAP driver
mfd: add U300 AB3100 core support
drivers/mfd: remove obsolete irq_desc_t typedef
mfd/pcf50633-gpio.c: add MODULE_LICENSE
mfd: Mark WM8350 mask revision as readable to match silicon
mfd: Mark clocks_init as non-init in twl4030-core.c
mfd: Correct readability of WM8350 register 227
We can not have .driver_data as const since platform_set_drvdata() doesnt take
a const.
The hclk mmc_data field can be const though.
Only the base addresses remain, as they are needed to set up
the IOMEM resources.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
IRQ number definitions for PWM, LED, SPI and OWM (ds1wm).
Used to configure single bits of the SDHWCTRL_SDCONF and EXTCF_RESET/SELECT
registers needed for DS1WM, MMC/SDIO and PCMCIA functionality.
The PCAP Asic as present on EZX phones is a multi function device with
voltage regulators, ADC, touch screen controller, RTC, USB transceiver,
leds controller, and audio codec.
It has two SPI ports, typically one is connected to the application
processor and another to the baseband, this driver provides read/write
functions to its registers, irq demultiplexer and ADC
queueing/abstraction.
This chip is used on a lot of Motorola phones, it was manufactured by TI
as a custom product with the name PTWL93017, later this design evolved
into the ATLAS PMIC from Freescale (MC13783).
Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com>
This adds a core driver for the AB3100 mixed-signal circuit
found in the ST-Ericsson U300 series platforms. This driver
is a singleton proxy for all accesses to the AB3100
sub-drivers which will be merged on top of this one, RTC,
regulators, battery and system power control, vibrator,
LEDs, and an ALSA codec.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Reviewed-by: Mike Rapoport <mike@compulab.co.il>
Reviewed-by: Ben Dooks <ben-linux@fluff.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6:
[SCSI] aic79xx: make driver respect nvram for IU and QAS settings
[SCSI] don't attach ULD to Dell Universal Xport
[SCSI] lpfc 8.3.3 : Update driver version to 8.3.3
[SCSI] lpfc 8.3.3 : Add support for Target Reset handler entrypoint
[SCSI] lpfc 8.3.3 : Fix a couple of spin_lock and memory issues and a crash
[SCSI] lpfc 8.3.3 : FC/FCOE discovery fixes
[SCSI] lpfc 8.3.3 : Fix various SLI-3 vs SLI-4 differences
[SCSI] qla2xxx: Resolve a performance issue in interrupt
[SCSI] cnic, bnx2i: Fix build failure when CONFIG_PCI is not set.
[SCSI] nsp_cs: time_out reaches -1
[SCSI] qla2xxx: fix printk format warnings
[SCSI] ncr53c8xx: div reaches -1
[SCSI] compat: don't perform unneeded copy in sg_io code
[SCSI] zfcp: Update FC pass-through support
[SCSI] zfcp: Add FC pass-through support
[SCSI] FC Pass Thru support
* 'linux-next' of git://git.infradead.org/ubi-2.6: (21 commits)
UBI: add reboot notifier
UBI: handle more error codes
UBI: fix multiple spelling typos
UBI: fix kmem_cache_free on error patch
UBI: print amount of reserved PEBs
UBI: improve messages in the WL worker
UBI: make gluebi a separate module
UBI: remove built-in gluebi
UBI: add notification API
UBI: do not switch to R/O mode on read errors
UBI: fix and clean-up error paths in WL worker
UBI: introduce new constants
UBI: fix race condition
UBI: minor serialization fix
UBI: do not panic if volume check fails
UBI: add dump_stack in checking code
UBI: fix races in I/O debugging checks
UBI: small debugging code optimization
UBI: improve debugging messages
UBI: re-name volumes_mutex to device_mutex
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
SLUB: Fix early boot GFP_DMA allocations
SLUB: Don't print out OOM warning for __GFP_NOFAIL
SLUB: fix build when !SLUB_DEBUG
SLUB: Out-of-memory diagnostics
slab: document kzfree() zeroing behavior
slab: fix generic PAGE_POISONING conflict with SLAB_RED_ZONE
slob: use PG_slab for identifying SLOB pages
It is generally agreed that it would be beneficial for u64 to be an
unsigned long long on all architectures. ia64 (in common with several
other 64-bit architectures) currently uses unsigned long. Migrating
piecemeal is too painful; this giant patch fixes all compilation warnings
and errors that come as a result of switching to use int-ll64.h.
Note that userspace will still see __u64 defined as unsigned long. This
is important as it affects C++ name mangling.
[Updated by Tony Luck to change efi.h:efi_freemem_callback_t to use
u64 for start/end rather than unsigned long]
Signed-off-by: Tony Luck <tony.luck@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
get rid of BKL in fs/sysv
get rid of BKL in fs/minix
get rid of BKL in fs/efs
befs ->pust_super() doesn't need BKL
Cleanup of adfs headers
9P doesn't need BKL in ->umount_begin()
fuse doesn't need BKL in ->umount_begin()
No instance of ->bmap() needs BKL
remove unlock_kernel() left accidentally
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
(net: No more expensive sock_hold()/sock_put() on each tx)
changed initial sk_wmem_alloc value.
Some protocols check sk_wmem_alloc value to determine if a timer
must delay socket deallocation. We must take care of the sk_wmem_alloc
value being one instead of zero when no write allocations are pending.
Reported by Ingo Molnar, and full diagnostic from David Miller.
This patch introduces three helpers to get read/write allocations
and a followup patch will use these helpers to report correct
write allocations to user.
Reported-by: Ingo Molnar <mingo@elte.hu>
Fix kernel-doc warnings (missing + extra entries) in skbuff.h.
'slub/fixes' into for-linus
