path: root/include
2007-05-16Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: libata: track spindown status and skip spindown_compat if possible libata: fix shutdown warning message printing libata-acpi: add ATA_FLAG_ACPI_SATA port flag libata: during revalidation, check n_sectors after device is configured libata: separate out ata_dev_reread_id() pata_scc had been missed by ata_std_prereset() switch
2007-05-16Merge branch 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa: [ALSA] usbaudio - Coping with short replies in usbmixer [ALSA] Include quirks from Ubuntu Dapper/Edgy/Feisty [ALSA] Fix probe of non-PnP ISA devices [ALSA] version 1.0.14rc4 [ALSA] hda-codec - Fix ALC882/861VD codec support on some laptops [ALSA] ASoC AC97 device reg bugfix [ALSA] ASoC AC97 static GPL symbol fix [ALSA] hda-codec - Make the mixer capability check more robust [ALSA] usb-audio: another Logitech QuickCam ID
2007-05-16Merge branch 'for-linus' of git://www.atmel.no/~hskinnemoen/linux/kernel/avr32Linus Torvalds
* 'for-linus' of git://www.atmel.no/~hskinnemoen/linux/kernel/avr32: [AVR32] Implement platform hooks for atmel_lcdfb driver [AVR32] Wire up signalfd, timerfd and eventfd [AVR32] optimize pagefault path [AVR32] Remove bogus comment in arch/avr32/kernel/irq.c
2007-05-16Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Add hypervisor API negotiation and fix console bugs.
2007-05-16SLUB: It is legit to allocate a slab of the maximum permitted sizeChristoph Lameter
Sorry I screwed up the comparison. It is only an error if we attempt to allocate a slab larger than the maximum allowed size. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-16Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] optimize pagefaults a little [IA64] Fix section conflict of ia64_mlogbuf_finish [IA64] s/scalibility/scalability/ [IA64] kdump on INIT needs multi-nodes sync-up (v.2) [IA64] wire up {signal,timer,event}fd syscalls [IA64] spelling fixes: arch/ia64/
2007-05-16[IA64] optimize pagefaults a littleChristoph Hellwig
Get rid of the notifier list and call the kprobes code directly if compiled in. This mirrors the changes that recently went into powerpc, s390 and sparc64. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-16[ALSA] version 1.0.14rc4Jaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-16[ALSA] ASoC AC97 device reg bugfixLiam Girdwood
This patch fixes a bug whereby AC97 bus device data was being clobbered when AC97 codecs using the generic ac97_codec.c driver were being registered. Codecs that didn't use the generic driver were unaffected (e.g. WM9712, WM9713). Changes:- o Add new AC97 codec class for custom (or need bus dev registration) AC97 codecs. o Only register/deregister this custom codec device with the AC97 bus. The generic AC97 driver already does this for generic codec devices. This may be related to bug #3038 :- https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3038 Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-16libata: track spindown status and skip spindown_compat if possibleTejun Heo
Our assumption that most distros issue STANDBYNOW seems wrong. The upstream sysvinit and thus many distros including gentoo and opensuse don't take any action for libata disks on spindown. We can skip compat handling for these distros so that they don't need to update anything to take advantage of kernel-side shutdown. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-16libata-acpi: add ATA_FLAG_ACPI_SATA port flagTejun Heo
Whether a controller needs IDE or SATA ACPI hierarchy is determined by the programming interface of the controller not by whether the controller is SATA or PATA, or it supports slave device or not. This patch adds ATA_FLAG_ACPI_SATA port flags which tells libata-acpi that the port needs SATA ACPI nodes, and sets the flag for ahci and sata_sil24. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-16libata: during revalidation, check n_sectors after device is configuredTejun Heo
Device might be resized during ata_dev_configure() due to HPA or (later) ACPI _GTF. Currently it's worked around by caching n_sectors before turning off HPA. The cached original size is overwritten if the device is reconfigured without being hardreset - which always happens after configuring trasnfer mode. If the device gets hardreset for some reason after that, revalidation fails with -ENODEV. This patch makes size checking more robust by moving n_sectors check from ata_dev_reread_id() to ata_dev_revalidate() after the device is fully configured. No matter what happens during configuration, a device must have the same n_sectors after fully configured to be treated as the same device. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-15[SPARC64]: Add hypervisor API negotiation and fix console bugs.David S. Miller
Hypervisor interfaces need to be negotiated in order to use some API calls reliably. So add a small set of interfaces to request API versions and query current settings. This allows us to fix some bugs in the hypervisor console: 1) If we can negotiate API group CORE of at least major 1 minor 1 we can use con_read and con_write which can improve console performance quite a bit. 2) When we do a console write request, we should hold the spinlock around the whole request, not a byte at a time. What would happen is that it's easy for output from different cpus to get mixed with each other. 3) Use consistent udelay() based polling, udelay(1) each loop with a limit of 1000 polls to handle stuck hypervisor console. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-15m32r: __xchg() should be always_inlineAl Viro
it depends on elimination of unreachable branches in switch (by object size), so we must declare it always_inline Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh64-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh64-2.6: sh64: Add .gitignore entry for syscalltab. sh64: generic quicklist support. sh64: Update cayman defconfig. sh64: Fixup sh-sci build. sh64: ppoll/pselect6() and restartable syscalls. sh64: dma-mapping updates. sh64: Fixups for the irq_regs changes. sh64: Wire up many new syscalls. spelling fixes: arch/sh64/ sh64: ROUND_UP macro cleanup in arch/sh64/kernel/pci_sh5.c
2007-05-15Merge master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6: Use menuconfig objects: IDE sl82c105: Switch to ref counting API ide: remove ide_use_dma() ide: add missing validity checks for identify words 62 and 63 ide: remove ide_dma_enable() sl82c105: add speedproc() method and MWDMA0/1 support cs5530/sc1200: add ->speedproc support cs5530/sc1200: DMA support cleanup ide: use ide_tune_dma() part #2 cs5530/sc1200: add ->udma_filter methods ide: always disable DMA before tuning it pdc202xx_new: use ide_tune_dma() alim15x3: use ide_tune_dma() sis5513: PIO mode setup fixes serverworks: PIO mode setup fixes pdc202xx_old: rewrite mode programming code (v2)
2007-05-16ide: remove ide_use_dma()Bartlomiej Zolnierkiewicz
ide_use_dma() duplicates a lot of ide_max_dma_mode() functionality and as all users of ide_use_dma() were converted to use ide_tune_dma() now it is possible to add missing checks to ide_tune_dma() and remove ide_use_dma() completely, so do it. There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-16ide: remove ide_dma_enable()Bartlomiej Zolnierkiewicz
* check ->speedproc return value in ide_tune_dma() * use ide_tune_dma() in cmd64x/cs5530/sc1200/siimage/sl82c105/scc_pata drivers * remove no longer needed ide_dma_enable() Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-15Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart: [AGPGART] Fix wrong ID in via-agp.c
2007-05-15SLUB: CONFIG_LARGE_ALLOCS must consider MAX_ORDER limitChristoph Lameter
Take MAX_ORDER into consideration when determining KMALLOC_SHIFT_HIGH. Otherwise we may run into a situation where we attempt to create general slabs larger than MAX_ORDER. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15i386: move common parts of smp into their own fileJeremy Fitzhardinge
Several parts of kernel/smp.c and smpboot.c are generally useful for other subarchitectures and paravirt_ops implementations, so make them available for reuse. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15Remove cpu hotplug defines for __INIT & __INITDATAPrarit Bhargava
After examining what was checked in and the code base I discovered that most of 86c0baf123e474b6eb404798926ecf62b426bf3a wasn't necessary anymore.... So here's a patch that reverts the last part of that changeset: Revert part of 86c0baf123e474b6eb404798926ecf62b426bf3a. The kernel has moved forward to a state where the original change is not necessary. After porting forward, this final version of the patch was applied and broke non-x86 architectures. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15m68k: implement __clear_user()Geert Uytterhoeven
m68k: implement __clear_user(), which is needed by fs/signalfd.c Since we always let the MMU do all checking, clear_user() and __clear_user() are identical. The old clear_user() is renamed to __clear_user() for consistency. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15alpha: fix hard_smp_processor_id compile errorSimon Horman
"Remove hardcoding of hard_smp_processor_id on UP systems", 2f4dfe206a2fc07099dfad77a8ea2f4b4ae2140f in Linus' tree, moved the definition of hard_smp_processor_id linux/smp.h to asm/smp.h for UP systems. This causes a regression on Alpha. cc1: warnings being treated as errors arch/alpha/kernel/setup.c: In function 'setup_arch': arch/alpha/kernel/setup.c:506: warning: implicit declaration of function 'hard_smp_processor_id' make[1]: *** [arch/alpha/kernel/setup.o] error 1 make: *** [arch/alpha/kernel] error 2 By including asm/smp.h non-conditionally in asm/mmu_context.h the problem appears to be resolved. Cc: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Simon Horman <horms@verge.net.au> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15h8300 atomic.h updateYoshinori Sato
add atomic_sub_and_test define. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15nommu: add ioremap_page_range()Paul Mundt
lib/ioremap.c is presently only built in if CONFIG_MMU is set. While this is reasonable, platforms that support both CONFIG_MMU=y or n need to be able to call in to this regardless. As none of the current nommu platforms do anything special with ioremap(), we assume that it's always successful. This fixes the SH-4 build with CONFIG_MMU=n. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15[AVR32] Implement platform hooks for atmel_lcdfb driverHaavard Skinnemoen
This modifies and extends the existing lcdc platform code to support the new atmel_lcdfb driver. The ATSTK1000 board code is set up to use the on-board Samsung LTV350QV LCD panel. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-05-14[IA64] wire up {signal,timer,event}fd syscallsTony Luck
2007-05-14Revert "ipmi: add new IPMI nmi watchdog handling"Linus Torvalds
This reverts commit f64da958dfc83335de1d2bef9d3868f30feb4e53. Andi Kleen is unhappy with the changes, and they really do not seem worth it. IPMI could use DIE_NMI_IPI instead of the new callback, even though that ends up having its own set of problems too, mainly because the IPMI code cannot really know the NMI was from IPMI or not. Manually fix up conflicts in arch/x86_64/kernel/traps.c and drivers/char/ipmi/ipmi_watchdog.c. Cc: Andi Kleen <ak@suse.de> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Corey Minyard <minyard@acm.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: pxamci: fix PXA27x MMC workaround for bad CRC with 136 bit response mmc: use assigned major for block device sdhci: handle dma boundary interrupts mmc: au1xmmc command types check from data flags
2007-05-14Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Update defconfig. [VIDEO]: XVR-500 and XVR-2500 need FB=y. [SPARC32]: asm/system.h needs asm/smp.h [SPARC32]: Update defconfig. [SPARC32]: Fix sparc32 kdebug changes. [SPARC64]: Accept ebus_bus_type for generic DMA ops. [SPARC64]: Add missing cpus_empty() check in hypervisor xcall handling. [SCSI]: Add help text for SCSI_ESP_CORE. [SPARC] SBUS: display7seg.c needs asm/io.h [SPARC] SBUS: bbc_i2c.c needs asm/io.h [SPARC64]: Be more resiliant with PCI I/O space regs. [SERIAL] SUNHV: Add an ID string.
2007-05-14Declare another couple of compat syscalls.Stephen Rothwell
compat_sys_signalfd and compat_sys_timerfd need declarations before PowerPC can wire them up. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-14mmc: use assigned major for block devicePierre Ossman
The MMC block devices now have an assigned major. Make sure we actually use it. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-14[SPARC32]: asm/system.h needs asm/smp.hDavid S. Miller
To get hard_smp_processor_id() even on UP builds. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-14[SPARC32]: Fix sparc32 kdebug changes.Robert Reif
Fix recent kdebug changes to compile on sparc32. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-14[SPARC64]: Accept ebus_bus_type for generic DMA ops.David S. Miller
Based upon a bug report by Meelis Roos. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-14sh64: generic quicklist support.Paul Mundt
2007-05-14sh64: Fixup sh-sci build.Paul Mundt
sh-sci needs asm/sci.h, borrow this from sh so we can build again. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-14sh64: ppoll/pselect6() and restartable syscalls.Paul Mundt
This patch was hanging around for some time while we were waiting for the compiler situation to improve.. now that all is well again, finally merge it. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-14sh64: dma-mapping updates.Paul Mundt
Follow the noncoherent changes from sh. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-14sh64: Fixups for the irq_regs changes.Paul Mundt
A few interrupt handlers were never updated, fix them up. We were missing the irq_regs conversion also, so do that at the same time. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-14sh64: Wire up many new syscalls.Paul Mundt
This has suffered a bit of bitrot, so we're a bit behind on the syscalls. There were a few that were wrapped incorrectly as well, caught by the syscall checker. Fix them all up. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-13[AGPGART] Fix wrong ID in via-agp.cGabriel Mansi
there is a wrong id in drivers/char/agp/via-agp.c #define PCI_DEVICE_ID_VIA_CX700 0x8324 It must be 0x0324 Notice that PCI_DEVICE_ID_VIA_CX700 is also used in drivers/i2c/busses/i2c-viapro.c and drivers/ide/pci/via82cxxx.c So, I think that constant must be renamed to avoid conflicting. I attached a proposed patch. Signed-off-by: Dave Jones <davej@redhat.com>
2007-05-13[AVR32] Wire up signalfd, timerfd and eventfdHaavard Skinnemoen
2007-05-13[AVR32] optimize pagefault pathChristoph Hellwig
Avoid the costly notifier list in the pagefault path and call the kprobes code directly. The same change went into the 2.6.22 cycle for powerpc, 2s390 and sparc64 already. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-05-12Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (30 commits) [ARM] Use new get_irqnr_preamble [ARM] Ensure machine class menu is sorted alphabetically [ARM] 4333/2: KS8695: Micrel Development board [ARM] 4332/2: KS8695: Serial driver [ARM] 4331/3: Support for Micrel/Kendin KS8695 processor [ARM] 4371/1: AT91: Support for Atmel AT91SAM9RL-EK development board [ARM] 4372/1: Define byte sizes in asm-arm/sizes.h [ARM] 4370/3: AT91: Support for Atmel AT91SAM9RL processors. [ARM] Update mach-types [ARM] export symbol csum_partial_copy_from_user [ARM] iop13xx: msi support [ARM] stacktrace fix [ARM] Spinlock initializer cleanup [ARM] remove useless config option GENERIC_BUST_SPINLOCK [ARM] 4303/3: base kernel support for TI DaVinci [ARM] 4369/1: AT91: Fix circular dependency in header files [ARM] 4368/1: S3C24xx: build fix [ARM] 4364/1: AT91: LEDS on AT91SAM9261-EK [ARM] Fix iop32x/iop33x build [ARM] EBSA110: fix build errors caused by missing "const" ...
2007-05-12include/linux: trivial repair whitespace damageDaniel Walker
Adding tabs where spaces currently are. Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-12SLUB: i386 supportChristoph Lameter
SLUB cannot run on i386 at this point because i386 uses the page->private and page->index field of slab pages for the pgd cache. Make SLUB run on i386 by replacing the pgd slab cache with a quicklist. Limit the changes as much as possible. Leave the improvised linked list in place etc etc. This has been working here for a couple of weeks now. Acked-by: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-12Merge branch 'fixes' into develRussell King
2007-05-12Merge branch 'omap-fixes' into fixesRussell King
