path: root/include
2012-05-24Merge branch 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM changes from Avi Kivity: "Changes include additional instruction emulation, page-crossing MMIO, faster dirty logging, preventing the watchdog from killing a stopped guest, module autoload, a new MSI ABI, and some minor optimizations and fixes. Outside x86 we have a small s390 and a very large ppc update. Regarding the new (for kvm) rebaseless workflow, some of the patches that were merged before we switch trees had to be rebased, while others are true pulls. In either case the signoffs should be correct now." Fix up trivial conflicts in Documentation/feature-removal-schedule.txt arch/powerpc/kvm/book3s_segment.S and arch/x86/include/asm/kvm_para.h. I suspect the kvm_para.h resolution ends up doing the "do I have cpuid" check effectively twice (it was done differently in two different commits), but better safe than sorry ;) * 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (125 commits) KVM: make asm-generic/kvm_para.h have an ifdef __KERNEL__ block KVM: s390: onereg for timer related registers KVM: s390: epoch difference and TOD programmable field KVM: s390: KVM_GET/SET_ONEREG for s390 KVM: s390: add capability indicating COW support KVM: Fix mmu_reload() clash with nested vmx event injection KVM: MMU: Don't use RCU for lockless shadow walking KVM: VMX: Optimize %ds, %es reload KVM: VMX: Fix %ds/%es clobber KVM: x86 emulator: convert bsf/bsr instructions to emulate_2op_SrcV_nobyte() KVM: VMX: unlike vmcs on fail path KVM: PPC: Emulator: clean up SPR reads and writes KVM: PPC: Emulator: clean up instruction parsing kvm/powerpc: Add new ioctl to retreive server MMU infos kvm/book3s: Make kernel emulated H_PUT_TCE available for "PR" KVM KVM: PPC: bookehv: Fix r8/r13 storing in level exception handler KVM: PPC: Book3S: Enable IRQs during exit handling KVM: PPC: Fix PR KVM on POWER7 bare metal KVM: PPC: Fix stbux emulation KVM: PPC: bookehv: Use lwz/stw instead of PPC_LL/PPC_STL for 32-bit fields ...
2012-05-24Merge tag 'stable/for-linus-3.5-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen updates from Konrad Rzeszutek Wilk: "Features: * Extend the APIC ops implementation and add IRQ_WORKER vector support so that 'perf' can work properly. * Fix self-ballooning code, and balloon logic when booting as initial domain. * Move array printing code to generic debugfs * Support XenBus domains. * Lazily free grants when a domain is dead/non-existent. * In M2P code use batching calls Bug-fixes: * Fix NULL dereference in allocation failure path (hvc_xen) * Fix unbinding of IRQ_WORKER vector during vCPU hot-unplug * Fix HVM guest resume - we would leak an PIRQ value instead of reusing the existing one." Fix up add-add onflicts in arch/x86/xen/enlighten.c due to addition of apic ipi interface next to the new apic_id functions. * tag 'stable/for-linus-3.5-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: do not map the same GSI twice in PVHVM guests. hvc_xen: NULL dereference on allocation failure xen: Add selfballoning memory reservation tunable. xenbus: Add support for xenbus backend in stub domain xen/smp: unbind irqworkX when unplugging vCPUs. xen: enter/exit lazy_mmu_mode around m2p_override calls xen/acpi/sleep: Enable ACPI sleep via the __acpi_os_prepare_sleep xen: implement IRQ_WORK_VECTOR handler xen: implement apic ipi interface xen/setup: update VA mapping when releasing memory during setup xen/setup: Combine the two hypercall functions - since they are quite similar. xen/setup: Populate freed MFNs from non-RAM E820 entries and gaps to E820 RAM xen/setup: Only print "Freeing XXX-YYY pfn range: Z pages freed" if Z > 0 xen/gnttab: add deferred freeing logic debugfs: Add support to print u32 array in debugfs xen/p2m: An early bootup variant of set_phys_to_machine xen/p2m: Collapse early_alloc_p2m_middle redundant checks. xen/p2m: Allow alloc_p2m_middle to call reserve_brk depending on argument xen/p2m: Move code around to allow for better re-usage.
2012-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc changes from David S. Miller: "This has the generic strncpy_from_user() implementation architectures can now use, which we've been developing on linux-arch over the past few days. For good measure I ran both a 32-bit and a 64-bit glibc testsuite run, and the latter of which pointed out an adjustment I needed to make to sparc's user_addr_max() definition. Linus, you were right, STACK_TOP was not the right thing to use, even on sparc itself :-) From Sam Ravnborg, we have a conversion of sparc32 over to the common alloc_thread_info_node(), since the aspect which originally blocked our doing so (sun4c) has been removed." Fix up trivial arch/sparc/Kconfig and lib/Makefile conflicts. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc: Fix user_addr_max() definition. lib: Sparc's strncpy_from_user is generic enough, move under lib/ kernel: Move REPEAT_BYTE definition into linux/kernel.h sparc: Increase portability of strncpy_from_user() implementation. sparc: Optimize strncpy_from_user() zero byte search. sparc: Add full proper error handling to strncpy_from_user(). sparc32: use the common implementation of alloc_thread_info_node()
2012-05-24Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull GPIO driver changes from Grant Likely: "Lots of gpio changes, both to core code and drivers. Changes do touch architecture code to remove the need for separate arm/gpio.h includes in most architectures. Some new drivers are added, and a number of gpio drivers are converted to use irq_domains for gpio inputs used as interrupts. Device tree support has been amended to allow multiple gpio_chips to use the same device tree node. Remaining changes are primarily bug fixes." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (33 commits) gpio/generic: initialize basic_mmio_gpio shadow variables properly gpiolib: Remove 'const' from data argument of gpiochip_find() gpio/rc5t583: add gpio driver for RICOH PMIC RC5T583 gpiolib: quiet gpiochip_add boot message noise gpio: mpc8xxx: Prevent NULL pointer deref in demux handler gpio/lpc32xx: Add device tree support gpio: Adjust of_xlate API to support multiple GPIO chips gpiolib: Implement devm_gpio_request_one() gpio-mcp23s08: dbg_show: fix pullup configuration display Add support for TCA6424A gpio/omap: (re)fix wakeups on level-triggered GPIOs gpio/omap: fix broken context restore for non-OFF mode transitions gpio/omap: fix missing check in *_runtime_suspend() gpio/omap: remove cpu_is_omapxxxx() checks from *_runtime_resume() gpio/omap: remove suspend/resume callbacks gpio/omap: remove retrigger variable in gpio_irq_handler gpio/omap: remove saved_wakeup field from struct gpio_bank gpio/omap: remove suspend_wakeup field from struct gpio_bank gpio/omap: remove saved_fallingdetect, saved_risingdetect gpio/omap: remove virtual_irq_start variable ... Conflicts: drivers/gpio/gpio-samsung.c
2012-05-24Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull device tree changes from Grant Likely: "Mostly documentation updates, but also includes an empty stub for non-CONFIG_OF builds." * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6: dt/documentation: Fix value format description dt: add vendor prefix for EM Microelectronics ARM: DT: Add binding for GIC virtualization extentions (VGIC) of/irq: add empty irq_of_parse_and_map() for non-dt builds
2012-05-24Merge tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull SPI changes from Grant Likely: "Bug fixes and new features for SPI device drivers. Also move device tree support code out of drivers/of and into drivers/spi/spi.c where it makes more sense." * tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6: spi: By default setup spi_masters with 1 chipselect and dynamics bus number SPI: PRIMA2: use the newest APIs of PINCTRL to fix compiling errors spi/spi-fsl-spi: reference correct pdata in fsl_spi_cs_control spi: refactor spi-coldfire-qspi to use SPI queue framework. spi/omap2-mcspi: convert to the pump message infrastructure spi/rspi: add dmaengine support spi/topcliff: use correct __devexit_p annotation spi: Dont call prepare/unprepare transfer if not populated spi/ep93xx: clean probe/remove routines spi/devicetree: Move devicetree support code into spi directory spi: use module_pci_driver spi/omap2-mcspi: Trivial optimisation spi: omap2-mcspi: add support for pm_runtime autosuspend spi/omap: Remove bus_num usage for instance index OMAP : SPI : use devm_* functions spi: omap2-mcspi: convert to module_platform_driver spi: omap2-mcspi: make it behave as a module
2012-05-24Merge tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull irqdomain changes from Grant Likely: "Minor changes and fixups for irqdomain infrastructure. The most important change adds the ability to remove a registered irqdomain." * tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6: irqdomain: Document size parameter of irq_domain_add_linear() irqdomain: trivial pr_fmt conversion. irqdomain: Kill off duplicate definitions. irqdomain: Make irq_domain_simple_map() static. irqdomain: Export remaining public API symbols. irqdomain: Support removal of IRQ domains.
2012-05-24Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner. Various trivial conflict fixups in arch Kconfig due to addition of unrelated entries nearby. And one slightly more subtle one for sparc32 (new user of GENERIC_CLOCKEVENTS), fixed up as per Thomas. * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits) timekeeping: Fix a few minor newline issues. time: remove obsolete declaration ntp: Fix a stale comment and a few stray newlines. ntp: Correct TAI offset during leap second timers: Fixup the Kconfig consolidation fallout x86: Use generic time config unicore32: Use generic time config um: Use generic time config tile: Use generic time config sparc: Use: generic time config sh: Use generic time config score: Use generic time config s390: Use generic time config openrisc: Use generic time config powerpc: Use generic time config mn10300: Use generic time config mips: Use generic time config microblaze: Use generic time config m68k: Use generic time config m32r: Use generic time config ...
2012-05-24kernel: Move REPEAT_BYTE definition into linux/kernel.hDavid S. Miller
And make sure that everything using it explicitly includes that header file. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-24Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull IEEE 1394 (FireWire) subsystem updates from Stefan Richter: - Fix mismatch between DMA mapping direction (was wrong) and DMA synchronization direction (was correct) of isochronous reception buffers of userspace drivers if vma-mapped for R/W access. For example, libdc1394 was affected. - more consistent retry stategy in device discovery/ rediscovery, and improved failure diagnostics - various small cleanups, e.g. use SCSI layer's DMA mapping API in firewire-sbp2 * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: sbp2: document the absence of alignment requirements firewire: sbp2: remove superfluous blk_queue_max_segment_size() call firewire: sbp2: use scsi_dma_(un)map firewire: sbp2: give correct DMA device to scsi framework firewire: core: fw_device_refresh(): clean up error handling firewire: core: log config rom reading errors firewire: core: log error in case of failed bus manager lock firewire: move rcode_string() to core firewire: core: improve reread_config_rom() interface firewire: core: wait for inaccessible devices after bus reset firewire: ohci: omit spinlock IRQ flags where possible firewire: ohci: correct signedness of a local variable firewire: core: fix DMA mapping direction firewire: use module_pci_driver
2012-05-24Merge branch 'drm-core-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull main drm updates from Dave Airlie: "This is the main merge window request for the drm. It's big, but jam packed will lots of features and of course 0 regressions. (okay maybe there'll be one). Highlights: - new KMS drivers for server GPU chipsets: ast, mgag200 and cirrus (qemu only). These drivers use the generic modesetting drivers. - initial prime/dma-buf support for i915, nouveau, radeon, udl and exynos - switcheroo audio support: so GPUs with HDMI can turn off the sound driver without crashing stuff. - There are some patches drifting outside drivers/gpu into x86 and EFI for better handling of multiple video adapters in Apple Macs, they've got correct acks except one trivial fixup. - Core: edid parser has better DMT and reduced blanking support, crtc properties, plane properties, - Drivers: exynos: add 2D core accel support, prime support, hdmi features intel: more Haswell support, initial Valleyview support, more hdmi infoframe fixes, update MAINTAINERS for Daniel, lots of cleanups and fixes radeon: more HDMI audio support, improved GPU lockup recovery support, remove nested mutexes, less memory copying on PCIE, fix bus master enable race (kexec), improved fence handling gma500: cleanups, 1080p support, acpi fixes nouveau: better nva3 memory reclocking, kepler accel (needs external firmware rip), async buffer moves on nv84+ hw. I've some more dma-buf patches that rely on the dma-buf merge for vmap stuff, and I've a few fixes building up, but I'd decided I'd better get rid of the main pull sooner rather than later, so the audio guys are also unblocked." Fix up trivial conflict due to some duplicated changes in drivers/gpu/drm/i915/intel_ringbuffer.c * 'drm-core-next' of git://people.freedesktop.org/~airlied/linux: (605 commits) drm/nouveau/nvd9: Fix GPIO initialisation sequence. drm/nouveau: Unregister switcheroo client on exit drm/nouveau: Check dsm on switcheroo unregister drm/nouveau: fix a minor annoyance in an output string drm/nouveau: turn a BUG into a WARN drm/nv50: decode PGRAPH DATA_ERROR = 0x24 drm/nouveau/disp: fix dithering not being enabled on some eDP macbooks drm/nvd9/copy: initialise copy engine, seems to work like nvc0 drm/nvc0/ttm: use copy engines for async buffer moves drm/nva3/ttm: use copy engine for async buffer moves drm/nv98/ttm: add in a (disabled) crypto engine buffer copy method drm/nv84/ttm: use crypto engine for async buffer copies drm/nouveau/ttm: untangle code to support accelerated buffer moves drm/nouveau/fbcon: use fence for sync, rather than notifier drm/nv98/crypt: non-stub implementation of the engine hooks drm/nouveau/fifo: turn all fifo modules into engine modules drm/nv50/graph: remove ability to do interrupt-driven context switching drm/nv50: remove manual context unload on context destruction drm/nv50: remove execution engine context saves on suspend drm/nv50/fifo: use hardware channel kickoff functionality ...
2012-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull more networking updates from David Miller: "Ok, everything from here on out will be bug fixes." 1) One final sync of wireless and bluetooth stuff from John Linville. These changes have all been in his tree for more than a week, and therefore have had the necessary -next exposure. John was just away on a trip and didn't have a change to send the pull request until a day or two ago. 2) Put back some defines in user exposed header file areas that were removed during the tokenring purge. From Stephen Hemminger and Paul Gortmaker. 3) A bug fix for UDP hash table allocation got lost in the pile due to one of those "you got it.. no I've got it.." situations. :-) From Tim Bird. 4) SKB coalescing in TCP needs to have stricter checks, otherwise we'll try to coalesce overlapping frags and crash. Fix from Eric Dumazet. 5) RCU routing table lookups can race with free_fib_info(), causing crashes when we deref the device pointers in the route. Fix by releasing the net device in the RCU callback. From Yanmin Zhang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (293 commits) tcp: take care of overlaps in tcp_try_coalesce() ipv4: fix the rcu race between free_fib_info and ip_route_output_slow mm: add a low limit to alloc_large_system_hash ipx: restore token ring define to include/linux/ipx.h if: restore token ring ARP type to header xen: do not disable netfront in dom0 phy/micrel: Fix ID of KSZ9021 mISDN: Add X-Tensions USB ISDN TA XC-525 gianfar:don't add FCB length to hard_header_len Bluetooth: Report proper error number in disconnection Bluetooth: Create flags for bt_sk() Bluetooth: report the right security level in getsockopt Bluetooth: Lock the L2CAP channel when sending Bluetooth: Restore locking semantics when looking up L2CAP channels Bluetooth: Fix a redundant and problematic incoming MTU check Bluetooth: Add support for Foxconn/Hon Hai AR5BBU22 0489:E03C Bluetooth: Fix EIR data generation for mgmt_device_found Bluetooth: Fix Inquiry with RSSI event mask Bluetooth: improve readability of l2cap_seq_list code Bluetooth: Fix skb length calculation ...
2012-05-24Merge branch 'perf-uprobes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull user-space probe instrumentation from Ingo Molnar: "The uprobes code originates from SystemTap and has been used for years in Fedora and RHEL kernels. This version is much rewritten, reviews from PeterZ, Oleg and myself shaped the end result. This tree includes uprobes support in 'perf probe' - but SystemTap (and other tools) can take advantage of user probe points as well. Sample usage of uprobes via perf, for example to profile malloc() calls without modifying user-space binaries. First boot a new kernel with CONFIG_UPROBE_EVENT=y enabled. If you don't know which function you want to probe you can pick one from 'perf top' or can get a list all functions that can be probed within libc (binaries can be specified as well): $ perf probe -F -x /lib/libc.so.6 To probe libc's malloc(): $ perf probe -x /lib64/libc.so.6 malloc Added new event: probe_libc:malloc (on 0x7eac0) You can now use it in all perf tools, such as: perf record -e probe_libc:malloc -aR sleep 1 Make use of it to create a call graph (as the flat profile is going to look very boring): $ perf record -e probe_libc:malloc -gR make [ perf record: Woken up 173 times to write data ] [ perf record: Captured and wrote 44.190 MB perf.data (~1930712 $ perf report | less 32.03% git libc-2.15.so [.] malloc | --- malloc 29.49% cc1 libc-2.15.so [.] malloc | --- malloc | |--0.95%-- 0x208eb1000000000 | |--0.63%-- htab_traverse_noresize 11.04% as libc-2.15.so [.] malloc | --- malloc | 7.15% ld libc-2.15.so [.] malloc | --- malloc | 5.07% sh libc-2.15.so [.] malloc | --- malloc | 4.99% python-config libc-2.15.so [.] malloc | --- malloc | 4.54% make libc-2.15.so [.] malloc | --- malloc | |--7.34%-- glob | | | |--93.18%-- 0x41588f | | | --6.82%-- glob | 0x41588f ... Or: $ perf report -g flat | less # Overhead Command Shared Object Symbol # ........ ............. ............. .......... # 32.03% git libc-2.15.so [.] malloc 27.19% malloc 29.49% cc1 libc-2.15.so [.] malloc 24.77% malloc 11.04% as libc-2.15.so [.] malloc 11.02% malloc 7.15% ld libc-2.15.so [.] malloc 6.57% malloc ... The core uprobes design is fairly straightforward: uprobes probe points register themselves at (inode:offset) addresses of libraries/binaries, after which all existing (or new) vmas that map that address will have a software breakpoint injected at that address. vmas are COW-ed to preserve original content. The probe points are kept in an rbtree. If user-space executes the probed inode:offset instruction address then an event is generated which can be recovered from the regular perf event channels and mmap-ed ring-buffer. Multiple probes at the same address are supported, they create a dynamic callback list of event consumers. The basic model is further complicated by the XOL speedup: the original instruction that is probed is copied (in an architecture specific fashion) and executed out of line when the probe triggers. The XOL area is a single vma per process, with a fixed number of entries (which limits probe execution parallelism). The API: uprobes are installed/removed via /sys/kernel/debug/tracing/uprobe_events, the API is integrated to align with the kprobes interface as much as possible, but is separate to it. Injecting a probe point is privileged operation, which can be relaxed by setting perf_paranoid to -1. You can use multiple probes as well and mix them with kprobes and regular PMU events or tracepoints, when instrumenting a task." Fix up trivial conflicts in mm/memory.c due to previous cleanup of unmap_single_vma(). * 'perf-uprobes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) perf probe: Detect probe target when m/x options are absent perf probe: Provide perf interface for uprobes tracing: Fix kconfig warning due to a typo tracing: Provide trace events interface for uprobes tracing: Extract out common code for kprobes/uprobes trace events tracing: Modify is_delete, is_return from int to bool uprobes/core: Decrement uprobe count before the pages are unmapped uprobes/core: Make background page replacement logic account for rss_stat counters uprobes/core: Optimize probe hits with the help of a counter uprobes/core: Allocate XOL slots for uprobes use uprobes/core: Handle breakpoint and singlestep exceptions uprobes/core: Rename bkpt to swbp uprobes/core: Make order of function parameters consistent across functions uprobes/core: Make macro names consistent uprobes: Update copyright notices uprobes/core: Move insn to arch specific structure uprobes/core: Remove uprobe_opcode_sz uprobes/core: Make instruction tables volatile uprobes: Move to kernel/events/ uprobes/core: Clean up, refactor and improve the code ...
2012-05-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input layer updates from Dmitry Torokhov: - a bunch of new drivers (DA9052/53 touchscreenn controller, Synaptics Navpoint, LM8333 keypads, Wacom I2C touhscreen); - updates to existing touchpad drivers (ALPS, Sntelic); - Wacom driver now supports Intuos5; - device-tree bindings in numerous drivers; - other cleanups and fixes. Fix annoying conflict in drivers/input/tablet/wacom_wac.c that I think implies that the input layer device naming is broken, but let's see. I brough it up with Dmitry. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (57 commits) Input: matrix-keymap - fix building keymaps Input: spear-keyboard - document DT bindings Input: spear-keyboard - add device tree bindings Input: matrix-keymap - wire up device tree support Input: matrix-keymap - uninline and prepare for device tree support Input: adp5588 - add support for gpio names Input: omap-keypad - dynamically handle register offsets Input: synaptics - fix compile warning MAINTAINERS: adjust input-related patterns Input: ALPS - switch to using input_mt_report_finger_count Input: ALPS - add semi-MT support for v4 protocol Input: Add Synaptics NavPoint (PXA27x SSP/SPI) driver Input: atmel_mxt_ts - dump each message on just 1 line Input: atmel_mxt_ts - do not read extra (checksum) byte Input: atmel_mxt_ts - verify object size in mxt_write_object Input: atmel_mxt_ts - only allow root to update firmware Input: atmel_mxt_ts - use CONFIG_PM_SLEEP Input: sentelic - report device's production serial number Input: tl6040-vibra - Device Tree support Input: evdev - properly handle read/write with count 0 ...
2012-05-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - some V4L2 API updates needed by embedded devices - DVB API extensions for ATSC-MH delivery system, used in US for mobile TV - new tuners for fc0011/0012/0013 and tua9001 - a new dvb driver for af9033/9035 - a new ATSC-MH frontend (lg2160) - new remote controller keymaps - Removal of a few legacy webcam driver that got replaced by gspca on several kernel versions ago - a new driver for Exynos 4/5 webcams(s5pp fimc-lite) - a new webcam sensor driver (smiapp) - a new video input driver for embedded (sta2x1xx) - several improvements, fixes, cleanups, etc inside the drivers. Manually fix up conflicts due to err() -> dev_err() conversion in drivers/staging/media/easycap/easycap_main.c * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (484 commits) [media] saa7134-cards: Remove a PCI entry added by mistake [media] radio-sf16fmi: add support for SF16-FMD [media] rc-loopback: remove duplicate line [media] patch for Asus My Cinema PS3-100 (1043:48cd) [media] au0828: Move the Kconfig knob under V4L_USB_DRIVERS [media] em28xx: simple comment fix [media] [resend] radio-sf16fmr2: add PnP support for SF16-FMD2 [media] smiapp: Use v4l2_ctrl_new_int_menu() instead of v4l2_ctrl_new_custom() [media] smiapp: Add support for 8-bit uncompressed formats [media] smiapp: Allow generic quirk registers [media] smiapp: Use non-binning limits if the binning limit is zero [media] smiapp: Initialise rval in smiapp_read_nvm() [media] smiapp: Round minimum pre_pll up rather than down in ip_clk_freq check [media] smiapp: Use 8-bit reads only before identifying the sensor [media] smiapp: Quirk for sensors that only do 8-bit reads [media] smiapp: Pass struct sensor to register writing commands instead of i2c_client [media] smiapp: Allow using external clock from the clock framework [media] zl10353: change .read_snr() to report SNR as a 0.1 dB [media] media: add support to gspca/pac7302.c for 093a:2627 (Genius FaceCam 300) [media] m88rs2000 - only flip bit 2 on reg 0x70 on 16th try ...
2012-05-24mm: add a low limit to alloc_large_system_hashTim Bird
UDP stack needs a minimum hash size value for proper operation and also uses alloc_large_system_hash() for proper NUMA distribution of its hash tables and automatic sizing depending on available system memory. On some low memory situations, udp_table_init() must ignore the alloc_large_system_hash() result and reallocs a bigger memory area. As we cannot easily free old hash table, we leak it and kmemleak can issue a warning. This patch adds a low limit parameter to alloc_large_system_hash() to solve this problem. We then specify UDP_HTABLE_SIZE_MIN for UDP/UDPLite hash table allocation. Reported-by: Mark Asselstine <mark.asselstine@windriver.com> Reported-by: Tim Bird <tim.bird@am.sony.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull first series of signal handling cleanups from Al Viro: "This is just the first part of the queue (about a half of it); assorted fixes all over the place in signal handling. This one ends with all sigsuspend() implementations switched to generic one (->saved_sigmask-based). With this, a bunch of assorted old buglets are fixed and most of the missing bits of NOTIFY_RESUME hookup are in place. Two more fixes sit in arm and um trees respectively, and there's a couple of broken ones that need obvious fixes - parisc and avr32 check TIF_NOTIFY_RESUME only on one of two codepaths; fixes for that will happen in the next series" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (55 commits) unicore32: if there's no handler we need to restore sigmask, syscall or no syscall xtensa: add handling of TIF_NOTIFY_RESUME microblaze: drop 'oldset' argument of do_notify_resume() microblaze: handle TIF_NOTIFY_RESUME score: add handling of NOTIFY_RESUME to do_notify_resume() m68k: add TIF_NOTIFY_RESUME and handle it. sparc: kill ancient comment in sparc_sigaction() h8300: missing checks of __get_user()/__put_user() return values frv: missing checks of __get_user()/__put_user() return values cris: missing checks of __get_user()/__put_user() return values powerpc: missing checks of __get_user()/__put_user() return values sh: missing checks of __get_user()/__put_user() return values sparc: missing checks of __get_user()/__put_user() return values avr32: struct old_sigaction is never used m32r: struct old_sigaction is never used xtensa: xtensa_sigaction doesn't exist alpha: tidy signal delivery up score: don't open-code force_sigsegv() cris: don't open-code force_sigsegv() blackfin: don't open-code force_sigsegv() ...
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace enhancements from Eric Biederman: "This is a course correction for the user namespace, so that we can reach an inexpensive, maintainable, and reasonably complete implementation. Highlights: - Config guards make it impossible to enable the user namespace and code that has not been converted to be user namespace safe. - Use of the new kuid_t type ensures the if you somehow get past the config guards the kernel will encounter type errors if you enable user namespaces and attempt to compile in code whose permission checks have not been updated to be user namespace safe. - All uids from child user namespaces are mapped into the initial user namespace before they are processed. Removing the need to add an additional check to see if the user namespace of the compared uids remains the same. - With the user namespaces compiled out the performance is as good or better than it is today. - For most operations absolutely nothing changes performance or operationally with the user namespace enabled. - The worst case performance I could come up with was timing 1 billion cache cold stat operations with the user namespace code enabled. This went from 156s to 164s on my laptop (or 156ns to 164ns per stat operation). - (uid_t)-1 and (gid_t)-1 are reserved as an internal error value. Most uid/gid setting system calls treat these value specially anyway so attempting to use -1 as a uid would likely cause entertaining failures in userspace. - If setuid is called with a uid that can not be mapped setuid fails. I have looked at sendmail, login, ssh and every other program I could think of that would call setuid and they all check for and handle the case where setuid fails. - If stat or a similar system call is called from a context in which we can not map a uid we lie and return overflowuid. The LFS experience suggests not lying and returning an error code might be better, but the historical precedent with uids is different and I can not think of anything that would break by lying about a uid we can't map. - Capabilities are localized to the current user namespace making it safe to give the initial user in a user namespace all capabilities. My git tree covers all of the modifications needed to convert the core kernel and enough changes to make a system bootable to runlevel 1." Fix up trivial conflicts due to nearby independent changes in fs/stat.c * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits) userns: Silence silly gcc warning. cred: use correct cred accessor with regards to rcu read lock userns: Convert the move_pages, and migrate_pages permission checks to use uid_eq userns: Convert cgroup permission checks to use uid_eq userns: Convert tmpfs to use kuid and kgid where appropriate userns: Convert sysfs to use kgid/kuid where appropriate userns: Convert sysctl permission checks to use kuid and kgids. userns: Convert proc to use kuid/kgid where appropriate userns: Convert ext4 to user kuid/kgid where appropriate userns: Convert ext3 to use kuid/kgid where appropriate userns: Convert ext2 to use kuid/kgid where appropriate. userns: Convert devpts to use kuid/kgid where appropriate userns: Convert binary formats to use kuid/kgid where appropriate userns: Add negative depends on entries to avoid building code that is userns unsafe userns: signal remove unnecessary map_cred_ns userns: Teach inode_capable to understand inodes whose uids map to other namespaces. userns: Fail exec for suid and sgid binaries with ids outside our user namespace. userns: Convert stat to return values mapped from kuids and kgids userns: Convert user specfied uids and gids in chown into kuids and kgid userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfs ...
2012-05-23Merge branch 'delete-mca' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull the MCA deletion branch from Paul Gortmaker: "It was good that we could support MCA machines back in the day, but realistically, nobody is using them anymore. They were mostly limited to 386-sx 16MHz CPU and some 486 class machines and never more than 64MB of RAM. Even the enthusiast hobbyist community seems to have dried up close to ten years ago, based on what you can find searching various websites dedicated to the relatively short lived hardware. So lets remove the support relating to CONFIG_MCA. There is no point carrying this forward, wasting cycles doing routine maintenance on it; wasting allyesconfig build time on validating it, wasting I/O on git grep'ping over it, and so on." Let's see if anybody screams. It generally has compiled, and James Bottomley pointed out that there was a MCA extension from NCR that allowed for up to 4GB of memory and PPro-class machines. So in *theory* there may be users out there. But even James (technically listed as a maintainer) doesn't actually have a system, and while Alan Cox claims to have a machine in his cellar that he offered to anybody who wants to take it off his hands, he didn't argue for keeping MCA support either. So we could bring it back. But somebody had better speak up and talk about how they have actually been using said MCA hardware with modern kernels for us to do that. And David already took the patch to delete all the networking driver code (commit a5e371f61ad3: "drivers/net: delete all code/drivers depending on CONFIG_MCA"). * 'delete-mca' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: MCA: delete all remaining traces of microchannel bus support. scsi: delete the MCA specific drivers and driver code serial: delete the MCA specific 8250 support. arm: remove ability to select CONFIG_MCA
2012-05-23Merge tag 'md-3.5' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from NeilBrown: "It's been a busy cycle for md - lots of fun stuff here.. if you like this kind of thing :-) Main features: - RAID10 arrays can be reshaped - adding and removing devices and changing chunks (not 'far' array though) - allow RAID5 arrays to be reshaped with a backup file (not tested yet, but the priciple works fine for RAID10). - arrays can be reshaped while a bitmap is present - you no longer need to remove it first - SSSE3 support for RAID6 syndrome calculations and of course a number of minor fixes etc." * tag 'md-3.5' of git://neil.brown.name/md: (56 commits) md/bitmap: record the space available for the bitmap in the superblock. md/raid10: Remove extras after reshape to smaller number of devices. md/raid5: improve removal of extra devices after reshape. md: check the return of mddev_find() MD RAID1: Further conditionalize 'fullsync' DM RAID: Use md_error() in place of simply setting Faulty bit DM RAID: Record and handle missing devices DM RAID: Set recovery flags on resume md/raid5: Allow reshape while a bitmap is present. md/raid10: resize bitmap when required during reshape. md: allow array to be resized while bitmap is present. md/bitmap: make sure reshape request are reflected in superblock. md/bitmap: add bitmap_resize function to allow bitmap resizing. md/bitmap: use DIV_ROUND_UP instead of open-code md/bitmap: create a 'struct bitmap_counts' substructure of 'struct bitmap' md/bitmap: make bitmap bitops atomic. md/bitmap: make _page_attr bitops atomic. md/bitmap: merge bitmap_file_unmap and bitmap_file_put. md/bitmap: remove async freeing of bitmap file. md/bitmap: convert some spin_lock_irqsave to spin_lock_irq ...
2012-05-23Merge branch 'sbp-target-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull sbp-2 (firewire) target mode support from Nicholas Bellinger: "The FireWire SBP-2 Target is a driver for using an IEEE-1394 connection as a SCSI transport. This module uses the SCSI Target framework to expose LUNs to other machines attached to a FireWire bus, in effect acting as a FireWire hard disk similar to FireWire Target Disk mode on many Apple computers. Also included are the two drivers/firewire/ patches required by sbp-target to access fw_request fabric speed needed for mgt_agent TCODE_WRITE_BLOCK_REQUEST ops, and exporting fw_card kref logic used when creating/destroying active session references to individual endpoints. A credit goes to Chris in being able to get this code up and running so quickly w/o any target core changes, and special thanks goes out to Stefan Richter + Clemens Ladisch + Andy Grover for their help in getting this driver ready for mainline. Also, one of Chris's goals was to be able to connect sbp-target to a PowerPC based MacOS-X based client, that he accomplished along the way in this obligatory screenshot: http://linux-iscsi.org/wiki/File:Linux-fireware-target-bootc-macosx.png Great work Chris + linux-1394 team !!" Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> * 'sbp-target-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: sbp-target: Initial merge of firewire/ieee-1394 target mode support firewire: Move fw_card kref functions into linux/firewire.h firewire: Add function to get speed from opaque struct fw_request
2012-05-23Merge tag 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev Pull libata update from Jeff Garzik: "Changes, all of them boring and minor: 1) Ugly MSFT Hyper-V workaround in ata_piix 2) Fix a longstanding error recovery delay caused by excessive re-re-retries, when media errors occur. 3) Minor hw-specific workarounds and quirks 4) New PATA driver for ep93xx" * tag 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: PATA host controller driver for ep93xx [libata] Add " 2GB ATA Flash Disk"/"ADMA428M" to DMA blacklist ata_generic: Skip is_intel_ider() check when ata_generic=1 is set libata-eh don't waste time retrying media errors (v3) ata_piix: defer disks to the Hyper-V drivers by default libata: add a host flag to ignore detected ATA devices
2012-05-23Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon updates from Guenter Roeck: "New driver for INA219 and INA226, added support for IT8782F and IT8783E/F to it87 driver, plus cleanups in a couple of drivers." * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (it87) Make temp3 attribute conditional for IT8782F hwmon: (it87) Convert to use devm_kzalloc and devm_request_region hwmon: INA219 and INA226 support hwmon: (it87) Create voltage attributes only if voltage is enabled hwmon: (ntc_thermistor) Fix checkpatch warning hwmon: (ntc_thermistor) Optimize and fix build warning hwmon: (ntc_thermistor) Return error code from hwmon_device_register hwmon: (ntc_thermistor) Convert to devm_kzalloc hwmon: (ad7314) Remove unused defines, and rename OFFSET to SHIFT acpi_power_meter: clean up code around setup_attrs acpi_power_meter: drop meter_rw_attrs, use common meter_attrs acpi_power_meter: remove duplicate code between register_{ro,rw}_attrs acpi_power_meter: use a {RW,RO}_SENSOR_TEMPLATE macro to clean things up acpi_power_meter: use the same struct {rw,ro}_sensor_template for both hwmon: use module_pci_driver hwmon: (it87) Add support for IT8782F and IT8783E/F
2012-05-23Merge tag 'pm-for-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates from Rafael Wysocki: - Implementation of opportunistic suspend (autosleep) and user space interface for manipulating wakeup sources. - Hibernate updates from Bojan Smojver and Minho Ban. - Updates of the runtime PM core and generic PM domains framework related to PM QoS. - Assorted fixes. * tag 'pm-for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (25 commits) epoll: Fix user space breakage related to EPOLLWAKEUP PM / Domains: Make it possible to add devices to inactive domains PM / Hibernate: Use get_gendisk to verify partition if resume_file is integer format PM / Domains: Fix computation of maximum domain off time PM / Domains: Fix link checking when add subdomain PM / Sleep: User space wakeup sources garbage collector Kconfig option PM / Sleep: Make the limit of user space wakeup sources configurable PM / Documentation: suspend-and-cpuhotplug.txt: Fix typo PM / Domains: Cache device stop and domain power off governor results, v3 PM / Domains: Make device removal more straightforward PM / Sleep: Fix a mistake in a conditional in autosleep_store() epoll: Add a flag, EPOLLWAKEUP, to prevent suspend while epoll events are ready PM / QoS: Create device constraints objects on notifier registration PM / Runtime: Remove device fields related to suspend time, v2 PM / Domains: Rework default domain power off governor function, v2 PM / Domains: Rework default device stop governor function, v2 PM / Sleep: Add user space interface for manipulating wakeup sources, v3 PM / Sleep: Add "prevent autosleep time" statistics to wakeup sources PM / Sleep: Implement opportunistic sleep, v2 PM / Sleep: Add wakeup_source_activate and wakeup_source_deactivate tracepoints ...
2012-05-23Merge tag 'sound-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This is the first big chunk for 3.5 merges of sound stuff. There are a few big changes in different areas. First off, the streaming logic of USB-audio endpoints has been largely rewritten for the better support of "implicit feedback". If anything about USB got broken, this change has to be checked. For HD-audio, the resume procedure was changed; instead of delaying the resume of the hardware until the first use, now waking up immediately at resume. This is for buggy BIOS. For ASoC, dynamic PCM support and the improved support for digital links between off-SoC devices are major framework changes. Some highlights are below: * HD-audio - Avoid accesses of invalid pin-control bits that may stall the codec - V-ref setup cleanups - Fix the races in power-saving code - Fix the races in codec cache hashes and connection lists - Split some common codes for BIOS auto-parser to hda_auto_parser.c - Changed the PM resume code to wake up immediately for buggy BIOS - Creative SoundCore3D support - Add Conexant CX20751/2/3/4 codec support * ASoC - Dynamic PCM support, allowing support for SoCs with internal routing through components with tight sequencing and formatting constraints within their internal paths or where there are multiple components connected with CPU managed DMA controllers inside the SoC. - Greatly improved support for direct digital links between off-SoC devices, providing a much simpler way of connecting things like digital basebands to CODECs. - Much more fine grained and robust locking, cleaning up some of the confusion that crept in with multi-component. - CPU support for nVidia Tegra 30 I2S and audio hub controllers and ST-Ericsson MSP I2S controolers - New CODEC drivers for Cirrus CS42L52, LAPIS Semiconductor ML26124, Texas Instruments LM49453. - Some regmap changes needed by the Tegra I2S driver. - mc13783 audio support. * Misc - Rewrite with module_pci_driver() - Xonar DGX support for snd-oxygen - Improvement of packet handling in snd-firewire driver - New USB-endpoint streaming logic - Enhanced M-audio FTU quirks and relevant cleanups - Increment the support of OSS devices to 256 - snd-aloop accuracy improvement There are a few more pending changes for 3.5, but they will be sent slightly later as partly depending on the changes of DRM." Fix up conflicts in regmap (due to duplicate patches, with some further updates then having already come in from the regmap tree). Also some fairly trivial context conflicts in the imx and mcx soc drivers. * tag 'sound-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (280 commits) ALSA: snd-usb: fix stream info output in /proc ALSA: pcm - Add proper state checks to snd_pcm_drain() ALSA: sh: Fix up namespace collision in sh_dac_audio. ALSA: hda/realtek - Fix unused variable compile warning ASoC: sh: fsi: enable chip specific data transfer mode ASoC: sh: fsi: call fsi_hw_startup/shutdown from fsi_dai_trigger() ASoC: sh: fsi: use same format for IN/OUT ASoC: sh: fsi: add fsi_version() and removed meaningless version check ASoC: sh: fsi: use register field macro name on IN/OUT_DMAC ASoC: tegra: Add machine driver for WM8753 codec ALSA: hda - Fix possible races of accesses to connection list array ASoC: OMAP: HDMI: Introduce codec ARM: mx31_3ds: Add sound support ASoC: imx-mc13783 cleanup mx31moboard: Add sound support ASoC: mc13783 codec cleanups ASoC: add imx-mc13783 sound support ASoC: Add mc13783 codec mfd: mc13xxx: add codec platform data ASoC: don't flip master of DT-instantiated DAI links ...
2012-05-23Merge branches 'perf-urgent-for-linus' and 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: - Leftover AMD PMU driver fix fix from the end of the v3.4 stabilization cycle. - Late tools/perf/ changes that missed the first round: * endianness fixes * event parsing improvements * libtraceevent fixes factored out from trace-cmd * perl scripting engine fixes related to libtraceevent, * testcase improvements * perf inject / pipe mode fixes * plus a kernel side fix * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86: Update event scheduling constraints for AMD family 15h models * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: Revert "sched, perf: Use a single callback into the scheduler" perf evlist: Show event attribute details perf tools: Bump default sample freq to 4 kHz perf buildid-list: Work better with pipe mode perf tools: Fix piped mode read code perf inject: Fix broken perf inject -b perf tools: rename HEADER_TRACE_INFO to HEADER_TRACING_DATA perf tools: Add union u64_swap type for swapping u64 data perf tools: Carry perf_event_attr bitfield throught different endians perf record: Fix documentation for branch stack sampling perf target: Add cpu flag to sample_type if target has cpu perf tools: Always try to build libtraceevent perf tools: Rename libparsevent to libtraceevent in Makefile perf script: Rename struct event to struct event_format in perl engine perf script: Explicitly handle known default print arg type perf tools: Add hardcoded name term for pmu events perf tools: Separate 'mem:' event scanner bits perf tools: Use allocated list for each parsed event perf tools: Add support for displaying event parser debug info perf test: Move parse event automated tests to separated object
2012-05-23Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 platform changes from Ingo Molnar: "This tree includes assorted platform driver updates and a preparatory series for a platform with custom DMA remapping semantics (sta2x11 I/O hub)." * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/vsmp: Fix number of CPUs when vsmp is disabled keyboard: Use BIOS Keyboard variable to set Numlock x86/olpc/xo1/sci: Report RTC wakeup events x86/olpc/xo1/sci: Produce wakeup events for buttons and switches x86, platform: Initial support for sta2x11 I/O hub x86: Introduce CONFIG_X86_DMA_REMAP x86-32: Introduce CONFIG_X86_DEV_DMA_OPS
2012-05-23ipx: restore token ring define to include/linux/ipx.hPaul Gortmaker
Commit 211ed865108e24697b44bee5daac502ee6bdd4a4 "net: delete all instances of special processing for token ring" removed the define for IPX_FRAME_TR_8022. While it is unlikely, we can't be 100% sure that there aren't random userspace consumers of this value, so restore it. The only instance I could find was in ncpfs-2.2.6, and it was safe as-is, since it used #ifdef IPX_FRAME_TR_8022 around the two use cases it had, but there may be other userspace packages without similar ifdefs. Cc: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-23Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/umlLinus Torvalds
Pull UML updates from Richard Weinberger: "Most changes are bug fixes and cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml: um: missing checks of __put_user()/__get_user() return values um: stub_rt_sigsuspend isn't needed these days anymore um/x86: merge (and trim) 32- and 64-bit variants of ptrace.h irq: Remove irq_chip->release() um: Remove CONFIG_IRQ_RELEASE_METHOD um: Remove usage of irq_chip->release() um: Implement um_free_irq() um: Fix __swp_type() um: Implement a custom pte_same() function um: Add BUG() to do_ops()'s error path um: Remove unused variables um: bury unused _TIF_RESTORE_SIGMASK um: wrong sigmask saved in case of multiple sigframes um: add TIF_NOTIFY_RESUME um: ->restart_block.fn needs to be reset on sigreturn
2012-05-23Merge tag 'sh-for-linus' of git://github.com/pmundt/linux-shLinus Torvalds
Pull SuperH updates from Paul Mundt: - New CPUs: SH7734 (SH-4A), SH7264 and SH7269 (SH-2A) - New boards: RSK2+SH7264, RSK2+SH7269 - Unbreaking kgdb for SMP - Consolidation of _32/_64 page fault handling. - watchdog and legacy DMA chainsawing, part 1 - Conversion to evt2irq() hwirq lookup, to support relocation of vectored IRQs for irqdomains. * tag 'sh-for-linus' of git://github.com/pmundt/linux-sh: (98 commits) sh: intc: Kill off special reservation interface. sh: Enable PIO API for hp6xx and se770x. sh: Kill off machvec IRQ hinting. sh: dma: More legacy cpu dma chainsawing. sh: Kill off MAX_DMA_ADDRESS leftovers. sh: Tidy up some of the cpu legacy dma header mess. sh: Move sh4a dma header from cpu-sh4 to cpu-sh4a. sh64: Fix up vmalloc fault range check. Revert "sh: Ensure fixmap and store queue space can co-exist." serial: sh-sci: Fix for port types without BRI interrupts. sh: legacy PCI evt2irq migration. sh: cpu dma evt2irq migration. sh: sh7763rdp evt2irq migration. sh: sdk7780 evt2irq migration. sh: migor evt2irq migration. sh: landisk evt2irq migration. sh: kfr2r09 evt2irq migration. sh: ecovec24 evt2irq migration. sh: ap325rxa evt2irq migration. sh: urquell evt2irq migration. ...
2012-05-23Revert "sched, perf: Use a single callback into the scheduler"Jiri Olsa
This reverts commit cb04ff9ac424 ("sched, perf: Use a single callback into the scheduler"). Before this change was introduced, the process switch worked like this (wrt. to perf event schedule): schedule (prev, next) - schedule out all perf events for prev - switch to next - schedule in all perf events for current (next) After the commit, the process switch looks like: schedule (prev, next) - schedule out all perf events for prev - schedule in all perf events for (next) - switch to next The problem is, that after we schedule perf events in, the pmu is enabled and we can receive events even before we make the switch to next - so "current" still being prev process (event SAMPLE data are filled based on the value of the "current" process). Thats exactly what we see for test__PERF_RECORD test. We receive SAMPLES with PID of the process that our tracee is scheduled from. Discussed with Peter Zijlstra: > Bah!, yeah I guess reverting is the right thing for now. Sad > though. > > So by having the two hooks we have a black-spot between them > where we receive no events at all, this black-spot covers the > hand-over of current and we thus don't receive the 'wrong' > events. > > I rather liked we could do away with both that black-spot and > clean up the code a little, but apparently people rely on it. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: acme@redhat.com Cc: paulus@samba.org Cc: cjashfor@linux.vnet.ibm.com Cc: fweisbec@gmail.com Cc: eranian@google.com Link: http://lkml.kernel.org/r/20120523111302.GC1638@m.brq.redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-05-23ttm: add prime sharing support to TTM (v2)Dave Airlie
This adds the ability for ttm common code to take an SG table and use it as the backing for a slave TTM object. The drivers can then populate their GTT tables using the SG object. v2: make sure to setup VM for sg bos as well. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-23drm/prime: introduce sg->pages/addr arrays helperDave Airlie
the ttm drivers need this currently, in order to get fault handling working and efficient. It also allows addrs to be NULL for devices like udl. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-22Merge tag 'dlm-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm Pull dlm updates from David Teigland: "This set includes some minor fixes and improvements. The one large patch addresses the special "nodir" mode, which has been a long neglected proof of concept, but with these fixes seems to be quite usable. It allows the resource master to be assigned statically instead of dynamically, which can improve performance if there is little locality and most resources are shared." * tag 'dlm-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm: dlm: NULL dereference on failure in kmem_cache_create() gfs2: fix recovery during unmount dlm: fixes for nodir mode dlm: improve error and debug messages dlm: avoid unnecessary search in search_rsb dlm: limit rcom debug messages dlm: fix waiter recovery dlm: prevent connections during shutdown
2012-05-22Merge tag 'upstream-3.5-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull UBI and UBIFS updates from Artem Bityutskiy: UBIFS: * Always support xattrs (remove the Kconfig option) * Always support debugging (remove the Kconfig option) * A fix for a memory leak on error path * A number of clean-ups UBI: * Always support debugging (remove the Kconfig option) * Remove "data type" hint support * Huge amount of renames to prepare for the fastmap wor * A lot of clean-ups * tag 'upstream-3.5-rc1' of git://git.infradead.org/linux-ubifs: (54 commits) UBI: modify ubi_wl_flush function to clear work queue for a lnum UBI: introduce UBI_ALL constant UBI: add lnum and vol_id to struct ubi_work UBI: add volume id struct ubi_ainf_peb UBI: add in hex the value for UBI_INTERNAL_VOL_START to comment UBI: rename scan.c to attach.c UBI: remove scan.h UBI: rename UBI_SCAN_UNKNOWN_EC UBI: move and rename attach_by_scanning UBI: rename _init_scan functions UBI: amend comments after all the renamings UBI: rename ubi_scan_leb_slab UBI: rename ubi_scan_move_to_list UBI: rename ubi_scan_destroy_ai UBI: rename ubi_scan_get_free_peb UBI: rename ubi_scan_rm_volume UBI: rename ubi_scan_find_av UBI: rename ubi_scan_add_used UBI: remove unused function UBI: make ubi_scan_erase_peb static and rename ...
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID subsystem updates from Jiri Kosina: "Apart from various driver updates and added support for a number of new devices (mostly multitouch ones, but not limited to), there is one change that is worth pointing out explicitly: creation of HID device groups and proper autoloading of hid-multitouch, implemented by Henrik Rydberg." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (50 commits) HID: wacom: fix build breakage without CONFIG_LEDS_CLASS HID: waltop: Extend barrel button fix HID: hyperv: Set the hid drvdata correctly HID: wacom: Unify speed setting HID: wacom: Add speed setting for Intuos4 WL HID: wacom: Move Graphire raport header check. HID: uclogic: Add support for UC-Logic TWHL850 HID: explain the signed/unsigned handling in hid_add_field() HID: handle logical min/max signedness properly in parser HID: logitech: read all 32 bits of report type bitfield HID: wacom: Add LED selector control for Wacom Intuos4 WL HID: hid-multitouch: fix wrong protocol detection HID: wiimote: Fix IR data parser HID: wacom: Add tilt reporting for Intuos4 WL HID: multitouch: MT interface matching for Baanto HID: hid-multitouch: Only match MT interfaces HID: Create a common generic driver HID: hid-multitouch: Switch to device groups HID: Create a generic device group HID: Allow bus wildcard matching ...
2012-05-22Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "The biggest change is the cleanup/simplification of the load-balancer: instead of the current practice of architectures twiddling scheduler internal data structures and providing the scheduler domains in colorfully inconsistent ways, we now have generic scheduler code in kernel/sched/core.c:sched_init_numa() that looks at the architecture's node_distance() parameters and (while not fully trusting it) deducts a NUMA topology from it. This inevitably changes balancing behavior - hopefully for the better. There are various smaller optimizations, cleanups and fixlets as well" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Taint kernel with TAINT_WARN after sleep-in-atomic bug sched: Remove stale power aware scheduling remnants and dysfunctional knobs sched/debug: Fix printing large integers on 32-bit platforms sched/fair: Improve the ->group_imb logic sched/nohz: Fix rq->cpu_load[] calculations sched/numa: Don't scale the imbalance sched/fair: Revert sched-domain iteration breakage sched/x86: Rewrite set_cpu_sibling_map() sched/numa: Fix the new NUMA topology bits sched/numa: Rewrite the CONFIG_NUMA sched domain support sched/fair: Propagate 'struct lb_env' usage into find_busiest_group sched/fair: Add some serialization to the sched_domain load-balance walk sched/fair: Let minimally loaded cpu balance the group sched: Change rq->nr_running to unsigned int x86/numa: Check for nonsensical topologies on real hw as well x86/numa: Hard partition cpu topology masks on node boundaries x86/numa: Allow specifying node_distance() for numa=fake x86/sched: Make mwait_usable() heed to "idle=" kernel parameters properly sched: Update documentation and comments sched_rt: Avoid unnecessary dequeue and enqueue of pushable tasks in set_cpus_allowed_rt()
2012-05-22Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "Lots of changes: - (much) improved assembly annotation support in perf report, with jump visualization, searching, navigation, visual output improvements and more. - kernel support for AMD IBS PMU hardware features. Notably 'perf record -e cycles:p' and 'perf top -e cycles:p' should work without skid now, like PEBS does on the Intel side, because it takes advantage of IBS transparently. - the libtracevents library: it is the first step towards unifying tracing tooling and perf, and it also gives a tracing library for external tools like powertop to rely on. - infrastructure: various improvements and refactoring of the UI modules and related code - infrastructure: cleanup and simplification of the profiling targets code (--uid, --pid, --tid, --cpu, --all-cpus, etc.) - tons of robustness fixes all around - various ftrace updates: speedups, cleanups, robustness improvements. - typing 'make' in tools/ will now give you a menu of projects to build and a short help text to explain what each does. - ... and lots of other changes I forgot to list. The perf record make bzImage + perf report regression you reported should be fixed." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (166 commits) tracing: Remove kernel_lock annotations tracing: Fix initial buffer_size_kb state ring-buffer: Merge separate resize loops perf evsel: Create events initially disabled -- again perf tools: Split term type into value type and term type perf hists: Fix callchain ip printf format perf target: Add uses_mmap field ftrace: Remove selecting FRAME_POINTER with FUNCTION_TRACER ftrace/x86: Have x86 ftrace use the ftrace_modify_all_code() ftrace: Make ftrace_modify_all_code() global for archs to use ftrace: Return record ip addr for ftrace_location() ftrace: Consolidate ftrace_location() and ftrace_text_reserved() ftrace: Speed up search by skipping pages by address ftrace: Remove extra helper functions ftrace: Sort all function addresses, not just per page tracing: change CPU ring buffer state from tracing_cpumask tracing: Check return value of tracing_dentry_percpu() ring-buffer: Reset head page before running self test ring-buffer: Add integrity check at end of iter read ring-buffer: Make addition of pages in ring buffer atomic ...
2012-05-22Merge branch 'for-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "cgroup file type addition / removal is updated so that file types are added and removed instead of individual files so that dynamic file type addition / removal can be implemented by cgroup and used by controllers. blkio controller changes which will come through block tree are dependent on this. Other changes include res_counter cleanup and disallowing kthread / PF_THREAD_BOUND threads to be attached to non-root cgroups. There's a reported bug with the file type addition / removal handling which can lead to oops on cgroup umount. The issue is being looked into. It shouldn't cause problems for most setups and isn't a security concern." Fix up trivial conflict in Documentation/feature-removal-schedule.txt * 'for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (21 commits) res_counter: Account max_usage when calling res_counter_charge_nofail() res_counter: Merge res_counter_charge and res_counter_charge_nofail cgroups: disallow attaching kthreadd or PF_THREAD_BOUND threads cgroup: remove cgroup_subsys->populate() cgroup: get rid of populate for memcg cgroup: pass struct mem_cgroup instead of struct cgroup to socket memcg cgroup: make css->refcnt clearing on cgroup removal optional cgroup: use negative bias on css->refcnt to block css_tryget() cgroup: implement cgroup_rm_cftypes() cgroup: introduce struct cfent cgroup: relocate __d_cgrp() and __d_cft() cgroup: remove cgroup_add_file[s]() cgroup: convert memcg controller to the new cftype interface memcg: always create memsw files if CONFIG_CGROUP_MEM_RES_CTLR_SWAP cgroup: convert all non-memcg controllers to the new cftype interface cgroup: relocate cftype and cgroup_subsys definitions in controllers cgroup: merge cft_release_agent cftype array into the base files array cgroup: implement cgroup_add_cftypes() and friends cgroup: build list of all cgroups under a given cgroupfs_root cgroup: move cgroup_clear_directory() call out of cgroup_populate_dir() ...
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu updates from Tejun Heo: "Contains Alex Shi's three patches to remove percpu_xxx() which overlap with this_cpu_xxx(). There shouldn't be any functional change." * 'for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: remove percpu_xxx() functions x86: replace percpu_xxx funcs with this_cpu_xxx net: replace percpu_xxx funcs with this_cpu_xxx or __this_cpu_xxx
2012-05-22Merge branch 'for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "Nothing exciting. Most are updates to debug stuff and related fixes. Two not-too-critical bugs are fixed - WARN_ON() triggering spurious during cpu offlining and unlikely lockdep related oops." * 'for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: lockdep: fix oops in processing workqueue workqueue: skip nr_running sanity check in worker_enter_idle() if trustee is active workqueue: Catch more locking problems with flush_work() workqueue: change BUG_ON() to WARN_ON() trace: Remove unused workqueue tracer
2012-05-22Merge tag 'staging-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging tree changes from Greg Kroah-Hartman: "Here is the big staging tree pull request for the 3.5-rc1 merge window. Loads of changes here, and we just narrowly added more lines than we added: 622 files changed, 28356 insertions(+), 26059 deletions(-) But, good news is that there is a number of subsystems that moved out of the staging tree, to their respective "real" portions of the kernel. Code that moved out was: - iio core code - mei driver - vme core and bridge drivers There was one broken network driver that moved into staging as a step before it is removed from the tree (pc300), and there was a few new drivers added to the tree: - new iio drivers - gdm72xx wimax USB driver - ipack subsystem and 2 drivers All of the movements around have acks from the various subsystem maintainers, and all of this has been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up various trivial conflicts, along with a non-trivial one found in -next and pointed out by Olof Johanssen: a clean - but incorrect - merge of the arch/arm/boot/dts/at91sam9g20.dtsi file. Fix up manually as per Stephen Rothwell. * tag 'staging-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (536 commits) Staging: bcm: Remove two unused variables from Adapter.h Staging: bcm: Removes the volatile type definition from Adapter.h Staging: bcm: Rename all "INT" to "int" in Adapter.h Staging: bcm: Fix warning: __packed vs. __attribute__((packed)) in Adapter.h Staging: bcm: Correctly format all comments in Adapter.h Staging: bcm: Fix all whitespace issues in Adapter.h Staging: bcm: Properly format braces in Adapter.h Staging: ipack/bridges/tpci200: remove unneeded casts Staging: ipack/bridges/tpci200: remove TPCI200_SHORTNAME constant Staging: ipack: remove board_name and bus_name fields from struct ipack_device Staging: ipack: improve the register of a bus and a device in the bus. staging: comedi: cleanup all the comedi_driver 'detach' functions staging: comedi: remove all 'default N' in Kconfig staging: line6/config.h: Delete unused header staging: gdm72xx depends on NET staging: gdm72xx: Set up parent link in sysfs for gdm72xx devices staging: drm/omap: initial dmabuf/prime import support staging: drm/omap: dmabuf/prime mmap support pstore/ram: Add ECC support pstore/ram: Switch to persistent_ram routines ...
2012-05-22Merge tag 'tty-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull TTY updates from Greg Kroah-Hartman: "Here's the big TTY/serial driver pull request for the 3.5-rc1 merge window. Nothing major in here, just lots of incremental changes from Alan and Jiri reworking some tty core things to behave better and to get a more solid grasp on some of the nasty tty locking issues. There are a few tty and serial driver updates in here as well. All of this has been in the linux-next releases for a while with no problems. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'tty-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (115 commits) serial: bfin_uart: Make MMR access compatible with 32 bits bf609 style controller. serial: bfin_uart: RTS and CTS MMRs can be either 16-bit width or 32-bit width. serial: bfin_uart: narrow the reboot condition in DMA tx interrupt serial: bfin_uart: Adapt bf5xx serial driver to bf60x serial4 controller. Revert "serial_core: Update buffer overrun statistics." tty: hvc_xen: NULL dereference on allocation failure tty: Fix LED error return tty: Allow uart_register/unregister/register tty: move global ldisc idle waitqueue to the individual ldisc serial8250-em: Add DT support serial8250-em: clk_get() IS_ERR() error handling fix serial_core: Update buffer overrun statistics. tty: drop the pty lock during hangup cris: fix missing tty arg in wait_event_interruptible_tty call tty/amiserial: Add missing argument for tty_unlock() tty_lock: Localise the lock pty: Lock the devpts bits privately tty_lock: undo the old tty_lock use on the ctty serial8250-em: Emma Mobile UART driver V2 Add missing call to uart_update_timeout() ...
2012-05-22Merge tag 'driver-core-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the driver core, and other driver subsystems, pull request for the 3.5-rc1 merge window. Outside of a few minor driver core changes, we ended up with the following different subsystem and core changes as well, due to interdependancies on the driver core: - hyperv driver updates - drivers/memory being created and some drivers moved into it - extcon driver subsystem created out of the old Android staging switch driver code - dynamic debug updates - printk rework, and /dev/kmsg changes All of this has been tested in the linux-next releases for a few weeks with no reported problems. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up conflicts in drivers/extcon/extcon-max8997.c where git noticed that a patch to the deleted drivers/misc/max8997-muic.c driver needs to be applied to this one. * tag 'driver-core-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (90 commits) uio_pdrv_genirq: get irq through platform resource if not set otherwise memory: tegra{20,30}-mc: Remove empty *_remove() printk() - isolate KERN_CONT users from ordinary complete lines sysfs: get rid of some lockdep false positives Drivers: hv: util: Properly handle version negotiations. Drivers: hv: Get rid of an unnecessary check in vmbus_prep_negotiate_resp() memory: tegra{20,30}-mc: Use dev_err_ratelimited() driver core: Add dev_*_ratelimited() family Driver Core: don't oops with unregistered driver in driver_find_device() printk() - restore prefix/timestamp printing for multi-newline strings printk: add stub for prepend_timestamp() ARM: tegra30: Make MC optional in Kconfig ARM: tegra20: Make MC optional in Kconfig ARM: tegra30: MC: Remove unnecessary BUG*() ARM: tegra20: MC: Remove unnecessary BUG*() printk: correctly align __log_buf ARM: tegra30: Add Tegra Memory Controller(MC) driver ARM: tegra20: Add Tegra Memory Controller(MC) driver printk() - restore timestamp printing at console output printk() - do not merge continuation lines of different threads ...
2012-05-22Merge tag 'char-misc-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull Char/Misc patches from Greg Kroah-Hartman: "Here are a few various char/misc tree patches for the 3.5-rc1 merge window. Nothing major here at all, just different driver updates and some parport dead code removal. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'char-misc-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: parport: remove unused dead code from lowlevel drivers xilinx_hwicap: reset XHI_MAX_RETRIES xilinx_hwicap: add support for virtex6 FPGAs Support M95040 SPI EEPROM misc: add support for bmp18x chips to the bmp085 driver misc: bmp085: add device tree properties misc: clean up bmp085 driver misc: do not mark exported functions __devexit misc: add missing __devexit_p() annotations pch_phub: delete duplicate definitions misc: Fix irq leak in max8997_muic_probe error path
2012-05-22Merge tag 'usb-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB 3.5-rc1 changes from Greg Kroah-Hartman: "Here is the big USB 3.5-rc1 pull request for the 3.5-rc1 merge window. It's touches a lot of different parts of the kernel, all USB drivers, due to some API cleanups (getting rid of the ancient err() macro) and some changes that are needed for USB 3.0 power management updates. There are also lots of new drivers, pimarily gadget, but others as well. We deleted a staging driver, which was nice, and finally dropped the obsolete usbfs code, which will make Al happy to never have to touch that again. There were some build errors in the tree that linux-next found a few days ago, but those were fixed by the most recent changes (all were due to us not building with CONFIG_PM disabled.) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'usb-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (477 commits) xhci: Fix DIV_ROUND_UP compile error. xhci: Fix compile with CONFIG_USB_SUSPEND=n USB: Fix core compile with CONFIG_USB_SUSPEND=n brcm80211: Fix compile error for .disable_hub_initiated_lpm. Revert "USB: EHCI: work around bug in the Philips ISP1562 controller" MAINTAINERS: Add myself as maintainer to the USB PHY Layer USB: EHCI: fix command register configuration lost problem USB: Remove races in devio.c USB: ehci-platform: remove update_device USB: Disable hub-initiated LPM for comms devices. xhci: Add Intel U1/U2 timeout policy. xhci: Add infrastructure for host-specific LPM policies. USB: Add macros for interrupt endpoint types. xhci: Reserve one command for USB3 LPM disable. xhci: Some Evaluate Context commands must succeed. USB: Disable USB 3.0 LPM in critical sections. USB: Add support to enable/disable USB3 link states. USB: Allow drivers to disable hub-initiated LPM. USB: Calculate USB 3.0 exit latencies for LPM. USB: Refactor code to set LPM support flag. ... Conflicts: arch/arm/mach-exynos/mach-nuri.c arch/arm/mach-exynos/mach-universal_c210.c drivers/net/wireless/ath/ath6kl/usb.c
2012-05-22if: restore token ring ARP type to headerstephen hemminger
Recent removal of Token Ring breaks the build of iproute2. Even though Token Ring support is gone from the kernel, it is worth keeping the the definition of the TR ARP type to avoid breaking userspace programs that use this file. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-22Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc board specific changes from Olof Johansson: "While we generally attempt to get rid of board specific files and replace them with device tree based descriptions, a lot of platforms have not come that far: In shmobile, we add two new board files because their recently started effort to add DT support has not proceeded enough to use it for all of the important hardware. In Kirkwood, we are adding support for new boards with a combination of DT and board file contents in multiple cases. pxa/mmp and imx are extending support for existing board files but not adding new ones." Fix up trivial conflicts in arch/arm/mach-{mmp/ttc_dkb.c,shmobile/{Kconfig,Makefile}} * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: shmobile: fix smp build ARM: kirkwood: Add support for RaidSonic IB-NAS6210/6220 using devicetree kirkwood: Add iconnect support orion/kirkwood: create a generic function for gpio led blinking kirkwood/orion: fix orion_gpio_set_blink ARM: kirkwood: Define DNS-320/DNS-325 NAND in fdt kirkwood: Allow nand to be configured via. devicetree mtd: Add orion_nand devicetree bindings ARM: kirkwood: Basic support for DNS-320 and DNS-325 ARM: mach-shmobile: Use DT_MACHINE for armadillo 800 eva ARM: mach-shmobile: Use DT_MACHINE for KZM9G ARM: pxa: hx4700: Add Synaptics NavPoint touchpad ARM: pxa: Use REGULATOR_SUPPLY macro ARM: mach-shmobile: kzm9g: enable SMP boot ARM: mach-shmobile: kzm9g: defconfig update ARM: mach-shmobile: kzm9g: add PCF8757 gpio-key ARM: mach-shmobile: kzm9g: add SDHI support ARM: mach-shmobile: kzm9g: add MMCIF support ARM: mach-shmobile: kzm9g: correct screen direction ARM: mach-shmobile: sh73a0.h: add GPIO_NR ...
2012-05-22Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John says: -------------------- I apologize for not having sent this sooner. FWIW, I was in a car somewhere between Illinois and North Carolina for most of the day Sunday and Monday... :-) This is (obviously) the last non-fix pull request for wireless bits intended for 3.5. It includes AP support for mwifiex, a variety of HCI and other updates for NFC, some brcmfmac and brcmsmac refactoring, a large batch of ssb and bcma updates, a batch of ath6kl updates, some cfg80211 and mac80211 updates/refactoring from Johannes Berg, a rather large collection of Bluetooth updates by way of Gustavo, and a variety of other bits here and there. -------------------- Signed-off-by: David S. Miller <davem@davemloft.net>
