path: root/include
2008-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: Add support for Sony Vaio VGX-TP1E HID: fix lock imbalance in hiddev HID: fix lock imbalance in hidraw HID: fix hidbus/appletouch device binding regression HID: add hid_type to general hid struct HID: quirk for OLED devices present in ASUS G50/G70/G71 HID: Remove "default m" for Thrustmaster and Zeroplus HID: fix hidraw_exit section mismatch HID: add support for another Gyration remote control Revert "HID: Invert HWHEEL mappings for some Logitech mice"
2008-10-25Merge branch 'i7300_idle' into releaseLen Brown
2008-10-24i7300_idle: Disable ioat channel only on platforms where ile driver can loadVenki Pallipadi
Based on input from Andi Kleen: share the platform detection code with ioat_dma and disable the channel in dma engine only for specific platforms. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove unused resource assignment in pci_read_bridge_bases() PCI hotplug: shpchp: message refinement PCI hotplug: shpchp: replace printk with dev_printk PCI: add routines for debugging and handling lost interrupts PCI hotplug: pciehp: message refinement PCI: fix ARI code to be compatible with mixed ARI/non-ARI systems PCI hotplug: cpqphp: fix kernel NULL pointer dereference
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (29 commits) tcp: Restore ordering of TCP options for the sake of inter-operability net: Fix disjunct computation of netdev features sctp: Fix to handle SHUTDOWN in SHUTDOWN_RECEIVED state sctp: Fix to handle SHUTDOWN in SHUTDOWN-PENDING state sctp: Add check for the TSN field of the SHUTDOWN chunk sctp: Drop ICMP packet too big message with MTU larger than current PMTU p54: enable 2.4/5GHz spectrum by eeprom bits. orinoco: reduce stack usage in firmware download path ath5k: fix suspend-related oops on rmmod [netdrvr] fec_mpc52xx: Implement polling, to make netconsole work. qlge: Fix MSI/legacy single interrupt bug. smc911x: Make the driver safer on SMP smc911x: Add IRQ polarity configuration smc911x: Allow Kconfig dependency on ARM sis190: add identifier for Atheros AR8021 PHY 8139x: reduce message severity on driver overlap igb: add IGB_DCA instead of selecting INTEL_IOATDMA igb: fix tx data corruption with transition to L0s on 82575 ehea: Fix memory hotplug support netdev: DM9000: remove BLACKFIN hacking in DM9000 netdev driver ...
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: math-emu: Fix thinko in _FP_DIV math-emu: Fix signalling of underflow and inexact while packing result. sparc: Add checkstack support sparc: correct section of current_pc() sparc: correct section of apc_no_idle sparc64: Fix race in arch/sparc64/kernel/trampoline.S
2008-10-23Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-ledsLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds: leds/acpi: Fix merge fallout from acpi_driver_data change leds: Simplify logic in leds-ams-delta leds: Fix trigger registration race leds: Fix leds-class.c comment leds: Add driver for HP harddisk protection LEDs leds: leds-pca955x - Mark pca955x_led_set() static leds: Remove uneeded leds-cm-x270 driver leds: Remove uneeded strlen calls leds: Add leds-wrap default-trigger leds: Make default trigger fields const leds: Add backlight LED trigger leds: da903x: Add support for LEDs found on DA9030/DA9034
2008-10-23libata: switch to using block layer tagging supportJens Axboe
libata currently has a pretty dumb ATA_MAX_QUEUE loop for finding a free tag to use. Instead of fixing that up, convert libata to using block layer tagging - gets rid of code in libata, and is also much faster. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23PCI: add routines for debugging and handling lost interruptsJames Bottomley
We're getting a lot of storage drivers blamed for interrupt misrouting issues. This patch provides a standard way of reporting the problem ... and, if possible, correcting it. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-23Merge branch 'proc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc * 'proc' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc: (35 commits) proc: remove fs/proc/proc_misc.c proc: move /proc/vmcore creation to fs/proc/vmcore.c proc: move pagecount stuff to fs/proc/page.c proc: move all /proc/kcore stuff to fs/proc/kcore.c proc: move /proc/schedstat boilerplate to kernel/sched_stats.h proc: move /proc/modules boilerplate to kernel/module.c proc: move /proc/diskstats boilerplate to block/genhd.c proc: move /proc/zoneinfo boilerplate to mm/vmstat.c proc: move /proc/vmstat boilerplate to mm/vmstat.c proc: move /proc/pagetypeinfo boilerplate to mm/vmstat.c proc: move /proc/buddyinfo boilerplate to mm/vmstat.c proc: move /proc/vmallocinfo to mm/vmalloc.c proc: move /proc/slabinfo boilerplate to mm/slub.c, mm/slab.c proc: move /proc/slab_allocators boilerplate to mm/slab.c proc: move /proc/interrupts boilerplate code to fs/proc/interrupts.c proc: move /proc/stat to fs/proc/stat.c proc: move rest of /proc/partitions code to block/genhd.c proc: move /proc/cpuinfo code to fs/proc/cpuinfo.c proc: move /proc/devices code to fs/proc/devices.c proc: move rest of /proc/locks to fs/locks.c ...
2008-10-23Merge branch 'v28-range-hrtimers-for-linus-v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'v28-range-hrtimers-for-linus-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (37 commits) hrtimers: add missing docbook comments to struct hrtimer hrtimers: simplify hrtimer_peek_ahead_timers() hrtimers: fix docbook comments DECLARE_PER_CPU needs linux/percpu.h hrtimers: fix typo rangetimers: fix the bug reported by Ingo for real rangetimer: fix BUG_ON reported by Ingo rangetimer: fix x86 build failure for the !HRTIMERS case select: fix alpha OSF wrapper select: fix alpha OSF wrapper hrtimer: peek at the timer queue just before going idle hrtimer: make the futex() system call use the per process slack value hrtimer: make the nanosleep() syscall use the per process slack hrtimer: fix signed/unsigned bug in slack estimator hrtimer: show the timer ranges in /proc/timer_list hrtimer: incorporate feedback from Peter Zijlstra hrtimer: add a hrtimer_start_range() function hrtimer: another build fix hrtimer: fix build bug found by Ingo hrtimer: make select() and poll() use the hrtimer range feature ...
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdevLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev: (66 commits) [PATCH] kill the rest of struct file propagation in block ioctls [PATCH] get rid of struct file use in blkdev_ioctl() BLKBSZSET [PATCH] get rid of blkdev_locked_ioctl() [PATCH] get rid of blkdev_driver_ioctl() [PATCH] sanitize blkdev_get() and friends [PATCH] remember mode of reiserfs journal [PATCH] propagate mode through swsusp_close() [PATCH] propagate mode through open_bdev_excl/close_bdev_excl [PATCH] pass fmode_t to blkdev_put() [PATCH] kill the unused bsize on the send side of /dev/loop [PATCH] trim file propagation in block/compat_ioctl.c [PATCH] end of methods switch: remove the old ones [PATCH] switch sr [PATCH] switch sd [PATCH] switch ide-scsi [PATCH] switch tape_block [PATCH] switch dcssblk [PATCH] switch dasd [PATCH] switch mtd_blkdevs [PATCH] switch mmc ...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (46 commits) [PATCH] fs: add a sanity check in d_free [PATCH] i_version: remount support [patch] vfs: make security_inode_setattr() calling consistent [patch 1/3] FS_MBCACHE: don't needlessly make it built-in [PATCH] move executable checking into ->permission() [PATCH] fs/dcache.c: update comment of d_validate() [RFC PATCH] touch_mnt_namespace when the mount flags change [PATCH] reiserfs: add missing llseek method [PATCH] fix ->llseek for more directories [PATCH vfs-2.6 6/6] vfs: add LOOKUP_RENAME_TARGET intent [PATCH vfs-2.6 5/6] vfs: remove LOOKUP_PARENT from non LOOKUP_PARENT lookup [PATCH vfs-2.6 4/6] vfs: remove unnecessary fsnotify_d_instantiate() [PATCH vfs-2.6 3/6] vfs: add __d_instantiate() helper [PATCH vfs-2.6 2/6] vfs: add d_ancestor() [PATCH vfs-2.6 1/6] vfs: replace parent == dentry->d_parent by IS_ROOT() [PATCH] get rid of on-stack dentry in udf [PATCH 2/2] anondev: switch to IDA [PATCH 1/2] anondev: init IDR statically [JFFS2] Use d_splice_alias() not d_add() in jffs2_lookup() [PATCH] Optimise NFS readdir hack slightly. ...
2008-10-23Merge branch 'x86/um-header' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86/um-header' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits) x86: canonicalize remaining header guards x86: drop double underscores from header guards x86: Fix ASM_X86__ header guards x86, um: get rid of uml-config.h x86, um: get rid of arch/um/Kconfig.arch x86, um: get rid of arch/um/os symlink x86, um: get rid of excessive includes of uml-config.h x86, um: get rid of header symlinks x86, um: merge Kconfig.i386 and Kconfig.x86_64 x86, um: get rid of sysdep symlink x86, um: trim the junk from uml ptrace-*.h x86, um: take vm-flags.h to sysdep x86, um: get rid of uml asm/arch x86, um: get rid of uml highmem.h x86, um: get rid of uml unistd.h x86, um: get rid of system.h -> system.h include x86, um: uml atomic.h is not needed anymore x86, um: untangle uml ldt.h x86, um: get rid of more uml asm/arch uses x86, um: remove dead header (uml module-generic.h; never used these days) ...
2008-10-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (123 commits) dock: make dock driver not a module ACPI: fix ia64 build warning ACPI: hack around sysfs warning with link order ACPI suspend: fix build warning when CONFIG_ACPI_SLEEP=n intel_menlo: fix build warning panasonic-laptop: fix build ACPICA: Update version to 20080926 ACPICA: Add support for zero-length buffer-to-string conversions ACPICA: New: Validation for predefined ACPI methods/objects ACPICA: Fix for implicit return compatibility ACPICA: Fixed a couple memory leaks associated with "implicit return" ACPICA: Optimize buffer allocation procedure ACPICA: Fix possible memory leak, error exit path ACPICA: Fix fault after mem allocation failure in AML parser ACPICA: Remove unused ACPI register bit definition ACPICA: Update version to 20080829 ACPICA: Fix possible memory leak in acpi_ns_get_external_pathname ACPICA: Cleanup for internal Reference Object ACPICA: Update comments - no functional changes ACPICA: Update for Reference ACPI_OPERAND_OBJECT ...
2008-10-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (32 commits) PCI hotplug: fix logic in Compaq hotplug controller bus speed setup PCI: don't export linux/io.h from pci.h PCI: PCI_QUIRKS depends on PCI PCI hotplug: pciehp: poll data link layer link active PCI hotplug: pciehp: fix possible memory leak in pcie_init PCI: Workaround invalid P2P bridge bus numbers PCI Hotplug: fakephp: add duplicate slot name debugging PCI: Hotplug core: remove 'name' PCI: shcphp: remove 'name' parameter PCI: SGI Hotplug: stop managing bss_hotplug_slot->name PCI: rpaphp: kmalloc/kfree slot->name directly PCI: pciehp: remove 'name' parameter PCI: ibmphp: stop managing hotplug_slot->name PCI: fakephp: remove 'name' parameter PCI, PCI Hotplug: introduce slot_name helpers PCI: cpqphp: stop managing hotplug_slot->name PCI: cpci_hotplug: stop managing hotplug_slot->name PCI: acpiphp: remove 'name' parameter PCI: prevent duplicate slot names PCI Hotplug: serialize pci_hp_register and pci_hp_deregister ...
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: fix sparse warnings 9p: rdma: RDMA Transport Support for 9P 9p: fix format warning 9p: fix debug build error
2008-10-23Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Add info->archdata field i2c: Inform about deprecated chips directory i2c: Use pci_ioremap_bar() Schedule removal of the legacy i2c device driver binding model i2c: Clean up <linux/i2c.h> i2c: Update and clean up writing-clients document i2c: Drop 2-byte address block transfer defines i2c: Delete legacy model documentation i2c: Constify i2c_get_clientdata's parameter i2c: Delete outdated client porting guide i2c: Make clear what the class field of i2c_adapter is good for i2c-algo-pcf: Fix typo in debugging log message i2c-algo-pcf: Add adapter hooks around xfer begin and end i2c-algo-pcf: Pass adapter data into ->waitforpin() method i2c-i801: Add support for Intel Ibex Peak
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: stop_machine: fix error code handling on multiple cpus stop_machine: use workqueues instead of kernel threads workqueue: introduce create_rt_workqueue Call init_workqueues before pre smp initcalls. Make panic= and panic_on_oops into core_params Make initcall_debug a core_param core_param() for genuinely core kernel parameters param: Fix duplicate module prefixes module: check kernel param length at compile time, not runtime Remove stop_machine during module load v2 module: simplify load_module.
2008-10-23Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (36 commits) V4L/DVB (9336): cx88: always de-alloc frontends on fault condition V4L/DVB (9335): videobuf: split unregister bus creating self-contained frontend de-allocator V4L/DVB (9334): cx88: dvb_remove debug output V4L/DVB (9333): cx88: Not all boards that requires cx88-mpeg has frontends V4L/DVB (9332): cx88: initial fix for analogue only compilation V4L/DVB (9331): Remove unused inode parameter from video_ioctl2 V4L/DVB (9330): Get rid of inode parameter at v4l_compat_translate_ioctl() V4L/DVB (9328): ivtvfb: FB_BLANK_POWERDOWN turns off video output V4L/DVB (9327): v4l: use video_device.num instead of minor in video%d V4L/DVB (9326): ivtv: avoid green flashing when loading ivtv V4L/DVB (9325): ivtv: switch to unlocked_ioctl. V4L/DVB (9324): v4l2: add video_ioctl2_unlocked for unlocked_ioctl support. V4L/DVB (9323): v4l2-int-if: Add enum_framesizes and enum_frameintervals ioctls. V4L/DVB (9322): v4l2-int-if: Export more interfaces to modules V4L/DVB (9321): v4l2-int-if: Define new power state changes V4L/DVB (9320): v4l2: Add 10-bit RAW Bayer formats V4L/DVB (9319): v4l2-int-if: Add cropcap, g_crop and s_crop commands. V4L/DVB (9318): v4l2-int-if: Add command to get slave private data. V4L/DVB (9316): s5h1411: Power down s5h1411 when not in use V4L/DVB (9315): s5h1411: Skip reconfiguring demod modulation if already at the desired modulation ...
2008-10-23Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: Admit to maintaining VT-d, for my sins. dmar: fix uninitialised 'ret' variable in dmar_parse_dev() intel-iommu: use coherent_dma_mask in alloc_coherent amd_iommu: fix nasty bug that caused ILLEGAL_DEVICE_TABLE_ENTRY errors intel-iommu: IA64 support dmar: remove the quirk which disables dma-remapping when intr-remapping enabled dmar: Use queued invalidation interface for IOTLB and context invalidation dmar: context cache and IOTLB invalidation using queued invalidation dmar: use spin_lock_irqsave() in qi_submit_sync()
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dmLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: dm: tidy local_init dm: remove unused flush_all dm raid1: separate region_hash interface part1 dm: mark split bio as cloned dm crypt: remove waitqueue dm crypt: fix async split dm crypt: tidy sector dm: remove dm header from targets dm: publish array_too_big dm exception store: fix misordered writes dm exception store: refactor zero_area dm snapshot: drop unused last_percent dm snapshot: fix primary_pe race dm kcopyd: avoid queue shuffle
2008-10-23Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: disable the hrtick for now sched: revert back to per-rq vruntime sched: fair scheduler should not resched rt tasks sched: optimize group load balancer sched: minor fast-path overhead reduction sched: fix the wrong mask_len, cleanup sched: kill unused scheduler decl. sched: fix the wrong mask_len sched: only update rq->clock while holding rq->lock
2008-10-23Merge branch 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: NULL struct irq_desc's member 'name' in dynamic_irq_cleanup() genirq: fix off by one and coding style genirq: fix set_irq_type() when recording trigger type
2008-10-238250: Oxford Semiconductor DevicesLee Howard
Add support for the OxSemi 'Tornado' devices. Reformatted and reworked a bit by Alan Cox Signed-off-by: Lee Howard <lee.howard@mainpine.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23mutex: speed up generic mutex implementationsNick Piggin
- atomic operations which both modify the variable and return something imply full smp memory barriers before and after the memory operations involved (failing atomic_cmpxchg, atomic_add_unless, etc don't imply a barrier because they don't modify the target). See Documentation/atomic_ops.txt. So remove extra barriers and branches. - All architectures support atomic_cmpxchg. This has no relation to __HAVE_ARCH_CMPXCHG. We can just take the atomic_cmpxchg path unconditionally This reduces a simple single threaded fastpath lock+unlock test from 590 cycles to 203 cycles on a ppc970 system. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/czankel/xtensa-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/czankel/xtensa-2.6: xtensa: Add config files for Diamond 232L - Rev B processor variant xtensa: Fix io regions xtensa: Add support for the Sonic Ethernet device for the XT2000 board. xtensa: replace remaining __FUNCTION__ occurrences xtensa: use newer __SPIN_LOCK_UNLOCKED macro XTENSA: warn about including <asm/rwsem.h> directly.
2008-10-23memcg: fix page_cgroup allocationKAMEZAWA Hiroyuki
page_cgroup_init() is called from mem_cgroup_init(). But at this point, we cannot call alloc_bootmem(). (and this caused panic at boot.) This patch moves page_cgroup_init() to init/main.c. Time table is following: == parse_args(). # we can trust mem_cgroup_subsys.disabled bit after this. .... cgroup_init_early() # "early" init of cgroup. .... setup_arch() # memmap is allocated. ... page_cgroup_init(); mem_init(); # we cannot call alloc_bootmem after this. .... cgroup_init() # mem_cgroup is initialized. == Before page_cgroup_init(), mem_map must be initialized. So, I added page_cgroup_init() to init/main.c directly. (*) maybe this is not very clean but - cgroup_init_early() is too early - in cgroup_init(), we have to use vmalloc instead of alloc_bootmem(). use of vmalloc area in x86-32 is important and we should avoid very large vmalloc() in x86-32. So, we want to use alloc_bootmem() and added page_cgroup_init() directly to init/main.c [akpm@linux-foundation.org: remove unneeded/bad mem_cgroup_subsys declaration] [akpm@linux-foundation.org: fix build] Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Tested-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23jbd: fix error handling for checkpoint ioHidehiro Kawai
When a checkpointing IO fails, current JBD code doesn't check the error and continue journaling. This means latest metadata can be lost from both the journal and filesystem. This patch leaves the failed metadata blocks in the journal space and aborts journaling in the case of log_do_checkpoint(). To achieve this, we need to do: 1. don't remove the failed buffer from the checkpoint list where in the case of __try_to_free_cp_buf() because it may be released or overwritten by a later transaction 2. log_do_checkpoint() is the last chance, remove the failed buffer from the checkpoint list and abort the journal 3. when checkpointing fails, don't update the journal super block to prevent the journaled contents from being cleaned. For safety, don't update j_tail and j_tail_sequence either 4. when checkpointing fails, notify this error to the ext3 layer so that ext3 don't clear the needs_recovery flag, otherwise the journaled contents are ignored and cleaned in the recovery phase 5. if the recovery fails, keep the needs_recovery flag 6. prevent cleanup_journal_tail() from being called between __journal_drop_transaction() and journal_abort() (a race issue between journal_flush() and __log_wait_for_space() Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23profiling: fix up CONFIG_PROC_FS=n buildPaul Mundt
In the case where procfs is disabled, create_proc_profile() does not exist. Stub it in with the others. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (53 commits) powerpc: Support for relocatable kdump kernel powerpc: Don't use a 16G page if beyond mem= limits powerpc: Add del_node() for early boot code to prune inapplicable devices. powerpc: Further compile fixup for STRICT_MM_TYPECHECKS powerpc: Remove empty #else from signal_64.c powerpc: Move memory size print into common show_cpuinfo for 32-bit hvc_console: Remove __devexit annotation of hvc_remove() hvc_console: Add support for tty window resizing hvc_console: Fix loop if put_char() returns 0 hvc_console: Add tty driver flag TTY_DRIVER_RESET_TERMIOS hvc_console: Add a hangup notifier for backends powerpc/83xx: Add DS1339 RTC support for MPC8349E-mITX boards .dts powerpc/83xx: Add support for MCU microcontroller in .dts files powerpc/85xx: Move mpc8572ds.dts to address-cells/size-cells = <2> of/spi: Support specifying chip select as active high via device tree powerpc: Remove device_type = "board_control" properties in .dts files i2c-cpm: Suppress autoprobing for devices powerpc/85xx: Fix mpc8536ds dma interrupt numbers powerpc/85xx: Enable enhanced functions for 8536 TSEC powerpc: Delete unused prom_strtoul and prom_memparse ...
2008-10-23Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: (47 commits) uwb: wrong sizeof argument in mac address compare uwb: don't use printk_ratelimit() so often uwb: use kcalloc where appropriate uwb: use time_after() when purging stale beacons uwb: add credits for the original developers of the UWB/WUSB/WLP subsystems uwb: add entries in the MAINTAINERS file uwb: depend on EXPERIMENTAL wusb: wusb-cbaf (CBA driver) sysfs ABI simplification uwb: document UWB and WUSB sysfs files uwb: add symlinks in sysfs between radio controllers and PALs uwb: dont tranmit identification IEs uwb: i1480/GUWA100U: fix firmware download issues uwb: i1480: remove MAC/PHY information checking function uwb: add Intel i1480 HWA to the UWB RC quirk table uwb: disable command/event filtering for D-Link DUB-1210 uwb: initialize the debug sub-system uwb: Fix handling IEs with empty IE data in uwb_est_get_size() wusb: fix bmRequestType for Abort RPipe request wusb: fix error path for wusb_set_dev_addr() wusb: add HWA host controller driver ...
2008-10-23Merge branch 'for-next' of git://git.o-hand.com/linux-mfdLinus Torvalds
* 'for-next' of git://git.o-hand.com/linux-mfd: mfd: check for platform_get_irq() return value in sm501 mfd: use pci_ioremap_bar() in sm501 mfd: Don't store volatile bits in WM8350 register cache mfd: don't export wm3850 static functions mfd: twl4030-gpio driver mfd: rtc-twl4030 driver mfd: twl4030 IRQ handling update
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/ehca: Reject dynamic memory add/remove when ehca adapter is present IB/ehca: Fix reported max number of QPs and CQs in systems with >1 adapter IPoIB: Set netdev offload features properly for child (VLAN) interfaces IPoIB: Clean up ethtool support mlx4_core: Add Ethernet PCI device IDs mlx4_en: Add driver for Mellanox ConnectX 10GbE NIC mlx4_core: Multiple port type support mlx4_core: Ethernet MAC/VLAN management mlx4_core: Get ethernet MTU and default address from firmware mlx4_core: Support multiple pre-reserved QP regions Update NetEffect maintainer emails to Intel emails RDMA/cxgb3: Remove cmid reference on tid allocation failures IB/mad: Use krealloc() to resize snoop table IPoIB: Always initialize poll_timer to avoid crash on unload IB/ehca: Don't allow creating UC QP with SRQ mlx4_core: Add QP range reservation support RDMA/ucma: Test ucma_alloc_multicast() return against NULL, not with IS_ERR()
2008-10-23proc: remove fs/proc/proc_misc.cAlexey Dobriyan
Now that everything was moved to their more or less expected places, apply rm(1). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-23proc: move /proc/vmcore creation to fs/proc/vmcore.cAlexey Dobriyan
2008-10-23proc: move all /proc/kcore stuff to fs/proc/kcore.cAlexey Dobriyan
2008-10-23proc: move /proc/schedstat boilerplate to kernel/sched_stats.hAlexey Dobriyan
2008-10-23proc: move /proc/diskstats boilerplate to block/genhd.cAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-23proc: move /proc/zoneinfo boilerplate to mm/vmstat.cAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Christoph Lameter <cl@linux-foundation.org>
2008-10-23proc: move /proc/vmstat boilerplate to mm/vmstat.cAlexey Dobriyan
2008-10-23proc: move /proc/pagetypeinfo boilerplate to mm/vmstat.cAlexey Dobriyan
2008-10-23proc: move /proc/buddyinfo boilerplate to mm/vmstat.cAlexey Dobriyan
2008-10-23proc: move /proc/vmallocinfo to mm/vmalloc.cAlexey Dobriyan
2008-10-23proc: move /proc/slabinfo boilerplate to mm/slub.c, mm/slab.cAlexey Dobriyan
Lose dummy ->write hook in case of SLUB, it's possible now. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-10-23proc: move rest of /proc/partitions code to block/genhd.cAlexey Dobriyan
2008-10-23proc: move rest of /proc/locks to fs/locks.cAlexey Dobriyan
2008-10-23proc: move /proc/hardware to m68k-specific codeAlexey Dobriyan
2008-10-23proc: switch /proc/meminfo to seq_fileAlexey Dobriyan
and move it to fs/proc/meminfo.c while I'm at it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-23[PATCH] i_version: remount supportMimi Zohar
Add support for remounting a filesystem with the i_version option. Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
