path: root/include
2008-07-26include/video/atmel_lcdc.h must #include <linux/workqueue.h>Adrian Bunk
This patch fixes the following compile error caused by commit d22579b837358cbef12ccca5adaf7e93ae09ab7a ("atmel_lcdfb: FIFO underflow management"): In file included from arch/avr32/boards/atstk1000/atstk1004.c:21: include/video/atmel_lcdc.h:40: error: field 'task' has incomplete type Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26uninline arch_pick_mmap_layout()Andrew Morton
Fix this, on avr32: include/linux/utsname.h:35, from init/main.c:20: include/linux/sched.h: In function 'arch_pick_mmap_layout': include/linux/sched.h:2149: error: implicit declaration of function 'PAGE_ALIGN' Reported-by: Adrian Bunk <bunk@kernel.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: ipsec: ipcomp - Decompress into frags if necessary ipsec: ipcomp - Merge IPComp implementations pkt_sched: Fix locking in shutdown_scheduler_queue()
2008-07-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: Wire up new system calls.
2008-07-25Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Wire up new system calls
2008-07-25sys_paccept definition missing __user annotationHarvey Harrison
Introduced by commit aaca0bdca573f3f51ea03139f9c7289541e7bca3 ("flag parameters: paccept"): net/socket.c:1515:17: error: symbol 'sys_paccept' redeclared with different type (originally declared at include/linux/syscalls.h:413) - incompatible argument 4 (different address spaces) Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25sparc: Wire up new system calls.David S. Miller
This wires up the recently added Wire up signalfd4, eventfd2, epoll_create1, dup3, pipe2, and inotify_init1 system calls. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25Merge git://git.infradead.org/embedded-2.6Linus Torvalds
* git://git.infradead.org/embedded-2.6: Make console charset translation optional
2008-07-25Merge git://git.infradead.org/~dwmw2/random-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/random-2.6: remove dummy asm/kvm.h files firmware: create firmware binaries during 'make modules'.
2008-07-25bootmem: Move node allocation macros back to !HAVE_ARCH_BOOTMEM_NODEJohannes Weiner
These got unintentionally moved, put them back as x86 provides its own versions. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25remove dummy asm/kvm.h filesAdrian Bunk
This patch removes the dummy asm/kvm.h files on architectures not (yet) supporting KVM and uses the same conditional headers installation as already used for a.out.h . Also removed are superfluous install rules in the s390 and x86 Kbuild files (they are already in Kbuild.asm). Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-25Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (34 commits) powerpc: Wireup new syscalls Move update_mmu_cache() declaration from tlbflush.h to pgtable.h powerpc/pseries: Remove kmalloc call in handling writes to lparcfg powerpc/pseries: Update arch vector to indicate support for CMO ibmvfc: Add support for collaborative memory overcommit ibmvscsi: driver enablement for CMO ibmveth: enable driver for CMO ibmveth: Automatically enable larger rx buffer pools for larger mtu powerpc/pseries: Verify CMO memory entitlement updates with virtual I/O powerpc/pseries: vio bus support for CMO powerpc/pseries: iommu enablement for CMO powerpc/pseries: Add CMO paging statistics powerpc/pseries: Add collaborative memory manager powerpc/pseries: Utilities to set firmware page state powerpc/pseries: Enable CMO feature during platform setup powerpc/pseries: Split retrieval of processor entitlement data into a helper routine powerpc/pseries: Add memory entitlement capabilities to /proc/ppc64/lparcfg powerpc/pseries: Split processor entitlement retrieval and gathering to helper routines powerpc/pseries: Remove extraneous error reporting for hcall failures in lparcfg powerpc: Fix compile error with binutils 2.15 ... Fixed up conflict in arch/powerpc/platforms/52xx/Kconfig manually.
2008-07-25Merge branch 'linux-next' of git://git.infradead.org/~dedekind/ubi-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/~dedekind/ubi-2.6: (22 commits) UBI: always start the background thread UBI: fix gcc warning UBI: remove pre-sqnum images support UBI: fix kernel-doc errors and warnings UBI: fix checkpatch.pl errors and warnings UBI: bugfix - do not torture PEB needlessly UBI: rework scrubbing messages UBI: implement multiple volumes rename UBI: fix and re-work debugging stuff UBI: amend commentaries UBI: fix error message UBI: improve mkvol request validation UBI: add ubi_sync() interface UBI: fix 64-bit calculations UBI: fix LEB locking UBI: fix memory leak on error path UBI: do not forget to free internal volumes UBI: fix memory leak UBI: avoid unnecessary division operations UBI: fix buffer padding ...
2008-07-25edac: i5100 new intel chipset driverArthur Jones
Preliminary support for the Intel 5100 MCH. CE and UE errors are reported along with the current DIMM label information and other memory parameters. Reasons why this is preliminary: 1) This chip has 2 independent memory controllers which, for best perforance, use interleaved accesses to the DDR2 memory. This architecture does not map very well to the current edac data structures which depend on symmetric channel access to the interleaved data. Without core changes, the best I could do for now is to map both memory controllers to different csrows (first all ranks of controller 0, then all ranks of controller 1). Someone much more familiar with the edac core than I will probably need to come up with a more general data structure to handle the interleaving and de-interleaving of the two memory controllers. 2) I have not yet tackled the de-interleaving of the rank/controller address space into the physical address space of the CPU. There is nothing fundamentally missing, it is just ending up to be a lot of code, and I'd rather keep it separate for now, esp since it doesn't work yet... 3) The code depends on a particular i5100 chip select to DIMM mainboard chip select mapping. This mapping seems obvious to me in order to support dual and single ranked memory, but it is not unique and DIMM labels could be wrong on other mainboards. There is no way to query this mapping that I know of. 4) The code requires that the i5100 is in 32GB mode. Only 4 ranks per controller, 2 ranks per DIMM are supported. I do not have hardware (nor do I expect to have hardware anytime soon) for the 48GB (6 ranks per controller) mode. 5) The serial presence detect code should be broken out into a "real" i2c driver so that decode-dimms.pl can work. Signed-off-by: Arthur Jones <ajones@riverbed.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fuse: nfs export special lookupsMiklos Szeredi
Implement the get_parent export operation by sending a LOOKUP request with ".." as the name. Implement looking up an inode by node ID after it has been evicted from the cache. This is done by seding a LOOKUP request with "." as the name (for all file types, not just directories). The filesystem can set the FUSE_EXPORT_SUPPORT flag in the INIT reply, to indicate that it supports these special lookups. Thanks to John Muir for the original implementation of this feature. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Matthew Wilcox <matthew@wil.cx> Cc: David Teigland <teigland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25locks: add special return value for asynchronous locksMiklos Szeredi
Use a special error value FILE_LOCK_DEFERRED to mean that a locking operation returned asynchronously. This is returned by posix_lock_file() for sleeping locks to mean that the lock has been queued on the block list, and will be woken up when it might become available and needs to be retried (either fl_lmops->fl_notify() is called or fl_wait is woken up). f_op->lock() to mean either the above, or that the filesystem will call back with fl_lmops->fl_grant() when the result of the locking operation is known. The filesystem can do this for sleeping as well as non-sleeping locks. This is to make sure, that return values of -EAGAIN and -EINPROGRESS by filesystems are not mistaken to mean an asynchronous locking. This also makes error handling in fs/locks.c and lockd/svclock.c slightly cleaner. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: David Teigland <teigland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25per-task-delay-accounting: update taskstats for memory reclaim delayKeika Kobayashi
Add members for memory reclaim delay to taskstats, and accumulate them in __delayacct_add_tsk() . Signed-off-by: Keika Kobayashi <kobayashi.kk@ncos.nec.co.jp> Cc: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25per-task-delay-accounting: add memory reclaim delayKeika Kobayashi
Sometimes, application responses become bad under heavy memory load. Applications take a bit time to reclaim memory. The statistics, how long memory reclaim takes, will be useful to measure memory usage. This patch adds accounting memory reclaim to per-task-delay-accounting for accounting the time of do_try_to_free_pages(). <i.e> - When System is under low memory load, memory reclaim may not occur. $ free total used free shared buffers cached Mem: 8197800 1577300 6620500 0 4808 1516724 -/+ buffers/cache: 55768 8142032 Swap: 16386292 0 16386292 $ vmstat 1 procs -----------memory---------- ---swap-- -----io---- -system-- ----cpu---- r b swpd free buff cache si so bi bo in cs us sy id wa 0 0 0 5069748 10612 3014060 0 0 0 0 3 26 0 0 100 0 0 0 0 5069748 10612 3014060 0 0 0 0 4 22 0 0 100 0 0 0 0 5069748 10612 3014060 0 0 0 0 3 18 0 0 100 0 Measure the time of tar command. $ ls -s test.dat 1501472 test.dat $ time tar cvf test.tar test.dat real 0m13.388s user 0m0.116s sys 0m5.304s $ ./delayget -d -p <pid> CPU count real total virtual total delay total 428 5528345500 5477116080 62749891 IO count delay total 338 8078977189 SWAP count delay total 0 0 RECLAIM count delay total 0 0 - When system is under heavy memory load memory reclaim may occur. $ vmstat 1 procs -----------memory---------- ---swap-- -----io---- -system-- ----cpu---- r b swpd free buff cache si so bi bo in cs us sy id wa 0 0 7159032 49724 1812 3012 0 0 0 0 3 24 0 0 100 0 0 0 7159032 49724 1812 3012 0 0 0 0 4 24 0 0 100 0 0 0 7159032 49848 1812 3012 0 0 0 0 3 22 0 0 100 0 In this case, one process uses more 8G memory by execution of malloc() and memset(). $ time tar cvf test.tar test.dat real 1m38.563s <- increased by 85 sec user 0m0.140s sys 0m7.060s $ ./delayget -d -p <pid> CPU count real total virtual total delay total 9021 7140446250 7315277975 923201824 IO count delay total 8965 90466349669 SWAP count delay total 3 21036367 RECLAIM count delay total 740 61011951153 In the later case, the value of RECLAIM is increasing. So, taskstats can show how much memory reclaim influences TAT. Signed-off-by: Keika Kobayashi <kobayashi.kk@ncos.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujistu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25task IO accounting: provide distinct tgid/tid I/O statisticsAndrea Righi
Report per-thread I/O statistics in /proc/pid/task/tid/io and aggregate parent I/O statistics in /proc/pid/io. This approach follows the same model used to account per-process and per-thread CPU times. As a practial application, this allows for example to quickly find the top I/O consumer when a process spawns many child threads that perform the actual I/O work, because the aggregated I/O statistics can always be found in /proc/pid/io. [ Oleg Nesterov points out that we should check that the task is still alive before we iterate over the threads, but also says that we can do that fixup on top of this later. - Linus ] Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: Matt Heaton <matt@hostmonster.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Acked-by-with-comments: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25bsdacct: switch from global bsd_acct_struct instance to per-pidns onePavel Emelyanov
Allocate the structure on the first call to sys_acct(). After this each namespace, that ordered the accounting, will live with this structure till its own death. Two notes - routines, that close the accounting on fs umount time use the init_pid_ns's acct by now; - accounting routine accounts to dying task's namespace (also by now). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25pidns: add the struct bsd_acct_struct pointer on pid_namespace structPavel Emelyanov
All the bsdacct-related info will be stored in the area, pointer by this one. It will be NULL automatically for all new namespaces. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25accounting: account for user time when updating memory integralsJonathan Lim
Adapt acct_update_integrals() to include user time when calculating the time difference. The units of acct_rss_mem1 and acct_vm_mem1 are also changed from pages-jiffies to pages-usecs to avoid calling jiffies_to_usecs() in xacct_add_tsk() which might overflow. Signed-off-by: Jonathan Lim <jlim@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25pidns: remove find_task_by_pid, unused for a long timePavel Emelyanov
It seems to me that it was a mistake marking this function as deprecated and scheduling it for removal, rather than resolutely removing it after the last caller's death. Anyway - better late, then never. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25pidns: remove now unused find_pid function.Pavel Emelyanov
This one had the only users so far - the kill_proc, which is removed, so drop this (invalid in namespaced world) call too. And of course - erase all references on it from comments. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25pidns: remove now unused kill_proc functionPavel Emelyanov
This function operated on a pid_t to kill a task, which is no longer valid in a containerized system. It has finally lost all its users and we can safely remove it from the tree. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25shrink struct pid by removing padding on 64 bit buildsRichard Kennedy
When struct pid is built on a 64 bit platform gcc has to insert padding to maintain the correct alignment, by simply reordering its members the memory usage shrinks from 88 bytes to 80. I've successfully run with this patch on my desktop AMD64 machine. There are no significant kernel size changes to a default config.X86_64 on the latest git v2.6.26-rc1 text data bss dec hex filename 5404828 976760 734280 7115868 6c945c vmlinux 5404811 976760 734280 7115851 6c944b vmlinux.pid-patch Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25proper pid{hash,map}_init() prototypesAdrian Bunk
This patch adds proper prototypes for pid{hash,map}_init() in include/linux/pid_namespace.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25proc: always do ->releaseAlexey Dobriyan
Current two-stage scheme of removing PDE emphasizes one bug in proc: open rmmod remove_proc_entry close ->release won't be called because ->proc_fops were cleared. In simple cases it's small memory leak. For every ->open, ->release has to be done. List of openers is introduced which is traversed at remove_proc_entry() if neeeded. Discussions with Al long ago (sigh). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25move proc_kmsg_operations to fs/proc/internal.hAdrian Bunk
This patch moves the extern of struct proc_kmsg_operations to fs/proc/internal.h and adds an #include "internal.h" to fs/proc/kmsg.c so that the latter sees the former. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fs/partition/check.c: fix return value warningAbdel Benamrouche
fs/partitions/check.c:381: warning: ignoring return value of ___device_add___, declared with attribute warn_unused_result [akpm@linux-foundation.org: multiple-return-statements-per-function are evil] Signed-off-by: Abdel Benamrouche <draconux@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25elf: use ELF_CORE_EFLAGS for kcore ELF header flagsEdgar E. Iglesias
ELF_CORE_EFLAGS is already used by the binfmt_elf coredumper to set correct arch specific ELF header flags on coredumps. Use it for kcore dumps as well. At the moment, this affects the CRIS and the H8300 arch. Signed-off-by: Edgar E. Iglesias <edgar@axis.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: do not use a negative value to re-enable msgmni automatic recomputingNadia Derbey
This patch proposes an alternative to the "magical positive-versus-negative number trick" Andrew complained about last week in http://lkml.org/lkml/2008/6/24/418. This had been introduced with the patches that scale msgmni to the amount of lowmem. With these patches, msgmni has a registered notification routine that recomputes msgmni value upon memory add/remove or ipc namespace creation/ removal. When msgmni is changed from user space (i.e. value written to the proc file), that notification routine is unregistered, and the way to make it registered back is to write a negative value into the proc file. This is the "magical positive-versus-negative number trick". To fix this, a new proc file is introduced: /proc/sys/kernel/auto_msgmni. This file acts as ON/OFF for msgmni automatic recomputing. With this patch, the process is the following: 1) kernel boots in "automatic recomputing mode" /proc/sys/kernel/msgmni contains the value that has been computed (depends on lowmem) /proc/sys/kernel/automatic_msgmni contains "1" 2) echo <val> > /proc/sys/kernel/msgmni . sets msg_ctlmni to <val> . de-activates automatic recomputing (i.e. if, say, some memory is added msgmni won't be recomputed anymore) . /proc/sys/kernel/automatic_msgmni now contains "0" 3) echo "0" > /proc/sys/kernel/automatic_msgmni . de-activates msgmni automatic recomputing this has the same effect as 2) except that msg_ctlmni's value stays blocked at its current value) 3) echo "1" > /proc/sys/kernel/automatic_msgmni . recomputes msgmni's value based on the current available memory size and number of ipc namespaces . re-activates automatic recomputing for msgmni. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Solofo Ramangalahy <Solofo.Ramangalahy@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: rewrite undo list lockingManfred Spraul
The attached patch: - reverses the locking order of ulp->lock and sem_lock: Previously, it was first ulp->lock, then inside sem_lock. Now it's the other way around. - converts the undo structure to rcu. Benefits: - With the old locking order, IPC_RMID could not kfree the undo structures. The stale entries remained in the linked lists and were released later. - The patch fixes a a race in semtimedop(): if both IPC_RMID and a semget() that recreates exactly the same id happen between find_alloc_undo() and sem_lock, then semtimedop() would access already kfree'd memory. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: convert sem_array.sem_pending to struct list_headManfred Spraul
sem_array.sem_pending is a double linked list, the attached patch converts it to struct list_head. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: remove unused entries from struct sem_queueManfred Spraul
sem_queue.sma and sem_queue.id were never used, the attached patch removes them. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: convert undo structures to struct list_headManfred Spraul
The undo structures contain two linked lists, the attached patch replaces them with generic struct list_head lists. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25idr: make idr_find rcu-safeNadia Derbey
Make idr_find rcu-safe: it can now be called inside an rcu_read critical section. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Reviewed-by: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Jim Houston <jim.houston@comcast.net> Cc: Pierre Peiffer <peifferp@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25idr: error checking factorizationNadia Derbey
Do some code factorization in the return code analysis. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Jim Houston <jim.houston@comcast.net> Cc: Pierre Peiffer <peifferp@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25idr: change the idr structureNadia Derbey
After scalability problems have been detected when using the sysV ipcs, I have proposed to use an RCU based implementation of the IDR api instead (see threads http://lkml.org/lkml/2008/4/11/212 and http://lkml.org/lkml/2008/4/29/295). This resulted in many people asking to convert the idr API and make it rcu safe (because most of the code was duplicated and thus unmaintanable and unreviewable). So here is a first attempt. The important change wrt to the idr API itself is during idr removes: idr layers are freed after a grace period, instead of being moved to the free list. The important change wrt to ipcs, is that idr_find() can now be called locklessly inside a rcu read critical section. Here are the results I've got for the pmsg test sent by Manfred: 2.6.25-rc3-mm1 2.6.25-rc3-mm1+ 2.6.25-mm1 Patched 2.6.25-mm1 1 1168441 1064021 876000 947488 2 1094264 921059 1549592 1730685 3 2082520 1738165 1694370 2324880 4 2079929 1695521 404553 2400408 5 2898758 406566 391283 3246580 6 2921417 261275 263249 3752148 7 3308761 126056 191742 4243142 8 3329456 100129 141722 4275780 1st column: stock 2.6.25-rc3-mm1 2nd column: 2.6.25-rc3-mm1 + ipc patches (store ipcs into idrs) 3nd column: stock 2.6.25-mm1 4th column: 2.6.25-mm1 + this pacth series. This patch: Add an rcu_head to the idr_layer structure in order to free it after a grace period. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Reviewed-by: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Jim Houston <jim.houston@comcast.net> Cc: Pierre Peiffer <peifferp@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25calgary iommu: use the first kernels TCE tables in kdumpChandru
kdump kernel fails to boot with calgary iommu and aacraid driver on a x366 box. The ongoing dma's of aacraid from the first kernel continue to exist until the driver is loaded in the kdump kernel. Calgary is initialized prior to aacraid and creation of new tce tables causes wrong dma's to occur. Here we try to get the tce tables of the first kernel in kdump kernel and use them. While in the kdump kernel we do not allocate new tce tables but instead read the base address register contents of calgary iommu and use the tables that the registers point to. With these changes the kdump kernel and hence aacraid now boots normally. Signed-off-by: Chandru Siddalingappa <chandru@in.ibm.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25workqueues: make get_online_cpus() useable for work->func()Oleg Nesterov
workqueue_cpu_callback(CPU_DEAD) flushes cwq->thread under cpu_maps_update_begin(). This means that the multithreaded workqueues can't use get_online_cpus() due to the possible deadlock, very bad and very old problem. Introduce the new state, CPU_POST_DEAD, which is called after cpu_hotplug_done() but before cpu_maps_update_done(). Change workqueue_cpu_callback() to use CPU_POST_DEAD instead of CPU_DEAD. This means that create/destroy functions can't rely on get_online_cpus() any longer and should take cpu_add_remove_lock instead. [akpm@linux-foundation.org: fix CONFIG_SMP=n] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Gautham R Shenoy <ego@in.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Max Krasnyansky <maxk@qualcomm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25workqueues: implement flush_work()Oleg Nesterov
Most of users of flush_workqueue() can be changed to use cancel_work_sync(), but sometimes we really need to wait for the completion and cancelling is not an option. schedule_on_each_cpu() is good example. Add the new helper, flush_work(work), which waits for the completion of the specific work_struct. More precisely, it "flushes" the result of of the last queue_work() which is visible to the caller. For example, this code queue_work(wq, work); /* WINDOW */ queue_work(wq, work); flush_work(work); doesn't necessary work "as expected". What can happen in the WINDOW above is - wq starts the execution of work->func() - the caller migrates to another CPU now, after the 2nd queue_work() this work is active on the previous CPU, and at the same time it is queued on another. In this case flush_work(work) may return before the first work->func() completes. It is trivial to add another helper int flush_work_sync(struct work_struct *work) { return flush_work(work) || wait_on_work(work); } which works "more correctly", but it has to iterate over all CPUs and thus it much slower than flush_work(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Max Krasnyansky <maxk@qualcomm.com> Acked-by: Jarek Poplawski <jarkao2@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coredump: kill mm->core_doneOleg Nesterov
Now that we have core_state->dumper list we can use it to wake up the sub-threads waiting for the coredump completion. This uglifies the code and .text grows by 47 bytes, but otoh mm_struct lessens by sizeof(struct completion). Also, with this change we can decouple exit_mm() from the coredumping code. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coredump: construct the list of coredumping threads at startup timeOleg Nesterov
binfmt->core_dump() has to iterate over the all threads in system in order to find the coredumping threads and construct the list using the GFP_ATOMIC allocations. With this patch each thread allocates the list node on exit_mm()'s stack and adds itself to the list. This allows us to do further changes: - simplify ->core_dump() - change exit_mm() to clear ->mm first, then wait for ->core_done. this makes the coredumping process visible to oom_kill - kill mm->core_done Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coredump: turn core_state->nr_threads into atomic_tOleg Nesterov
Turn core_state->nr_threads into atomic_t and kill now unneeded down_write(&mm->mmap_sem) in exit_mm(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coredump: move mm->core_waiters into struct core_stateOleg Nesterov
Move mm->core_waiters into "struct core_state" allocated on stack. This shrinks mm_struct a little bit and allows further changes. This patch mostly does s/core_waiters/core_state. The only essential change is that coredump_wait() must clear mm->core_state before return. The coredump_wait()'s path is uglified and .text grows by 30 bytes, this is fixed by the next patch. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coredump: turn mm->core_startup_done into the pointer to struct core_stateOleg Nesterov
mm->core_startup_done points to "struct completion startup_done" allocated on the coredump_wait()'s stack. Introduce the new structure, core_state, which holds this "struct completion". This way we can add more info visible to the threads participating in coredump without enlarging mm_struct. No changes in affected .o files. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25kill PF_BORROWED_MM in favour of PF_KTHREADOleg Nesterov
Kill PF_BORROWED_MM. Change use_mm/unuse_mm to not play with ->flags, and do s/PF_BORROWED_MM/PF_KTHREAD/ for a couple of other users. No functional changes yet. But this allows us to do further fixes/cleanups. oom_kill/ptrace/etc often check "p->mm != NULL" to filter out the kthreads, this is wrong because of use_mm(). The problem with PF_BORROWED_MM is that we need task_lock() to avoid races. With this patch we can check PF_KTHREAD directly, or use a simple lockless helper: /* The result must not be dereferenced !!! */ struct mm_struct *__get_task_mm(struct task_struct *tsk) { if (tsk->flags & PF_KTHREAD) return NULL; return tsk->mm; } Note also ecard_task(). It runs with ->mm != NULL, but it's the kernel thread without PF_BORROWED_MM. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25introduce PF_KTHREAD flagOleg Nesterov
Introduce the new PF_KTHREAD flag to mark the kernel threads. It is set by INIT_TASK() and copied to the forked childs (we could set it in kthreadd() along with PF_NOFREEZE instead). daemonize() was changed as well. In that case testing of PF_KTHREAD is racy, but daemonize() is hopeless anyway. This flag is cleared in do_execve(), before search_binary_handler(). Probably not the best place, we can do this in exec_mmap() or in start_thread(), or clear it along with PF_FORKNOEXEC. But I think this doesn't matter in practice, and if do_execve() fails kthread should die soon. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ptrace: give more respect to SIGKILLOleg Nesterov
ptrace_stop() has some complicated checks to prevent the scheduling in the TASK_TRACED state with the pending SIGKILL, but these checks are racy, and they depend on arch_ptrace_stop_needed(). This patch assumes that the traced task should die asap if it was killed by SIGKILL, in that case schedule()->signal_pending_state() has no reason to ignore the TASK_WAKEKILL part of TASK_TRACED, and we can kill this nasty special case. Note: do_exit()->ptrace_notify() is special, the killed task can already dequeue SIGKILL at this point. Another indication that fatal_signal_pending() is not exactly right. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
