path: root/include
2008-03-22[NET]: NPROTO is redundant; it's equal to AF_MAX/PF_MAX.Rusty Russell
DaveM pointed out NPROTO exposed to userspace, so keep it around, just make sure it stays in sync. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[RAW]: Add raw_hashinfo member on struct proto.Pavel Emelyanov
Sorry for the patch sequence confusion :| but I found that the similar thing can be done for raw sockets easily too late. Expand the proto.h union with the raw_hashinfo member and use it in raw_prot and rawv6_prot. This allows to drop the protocol specific versions of hash and unhash callbacks. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[UDP]: Make full use of proto.h.udp_hash innovation.Pavel Emelyanov
After this we have only udp_lib_get_port to get the port and two stubs for ipv4 and ipv6. No difference in udp and udplite except for initialized h.udp_hash member. I tried to find a graceful way to drop the only difference between udp_v4_get_port and udp_v6_get_port (i.e. the rcv_saddr comparison routine), but adding one more callback on the struct proto didn't appear such :( Maybe later. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[SOCK]: Add udp_hash member to struct proto.Pavel Emelyanov
Inspired by the commit ab1e0a13 ([SOCK] proto: Add hashinfo member to struct proto) from Arnaldo, I made similar thing for UDP/-Lite IPv4 and -v6 protocols. The result is not that exciting, but it removes some levels of indirection in udpxxx_get_port and saves some space in code and text. The first step is to union existing hashinfo and new udp_hash on the struct proto and give a name to this union, since future initialization of tcpxxx_prot, dccp_vx_protinfo and udpxxx_protinfo will cause gcc warning about inability to initialize anonymous member this way. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[IPV4]: Remove unused ip_options->is_data.Denis V. Lunev
ip_options->is_data is assigned only and never checked. The structure is not a part of kernel interface to the userspace. So, it is safe to remove this field. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[TCP]: TCP_DEFER_ACCEPT updates - process as establishedPatrick McManus
Change TCP_DEFER_ACCEPT implementation so that it transitions a connection to ESTABLISHED after handshake is complete instead of leaving it in SYN-RECV until some data arrvies. Place connection in accept queue when first data packet arrives from slow path. Benefits: - established connection is now reset if it never makes it to the accept queue - diagnostic state of established matches with the packet traces showing completed handshake - TCP_DEFER_ACCEPT timeouts are expressed in seconds and can now be enforced with reasonable accuracy instead of rounding up to next exponential back-off of syn-ack retry. Signed-off-by: Patrick McManus <mcmanus@ducksong.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21socket: SOCK_DEBUG type checkingStephen Hemminger
Use the inline trick (same as pr_debug) to get checking of debug statements even if no code is generated. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[NETNS][IPV6] tcp6 - make proc per namespaceDaniel Lezcano
Make the proc for tcp6 to be per namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[NETNS][IPV6] udp6 - make proc per namespaceDaniel Lezcano
The proc init/exit functions take a new network namespace parameter in order to register/unregister /proc/net/udp6 for a namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[NETNS][IPV4] tcp - make proc handle the network namespacesDaniel Lezcano
This patch, like udp proc, makes the proc functions to take care of which namespace the socket belongs. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[NETNS][IPV6] udp - make proc handle the network namespaceDaniel Lezcano
This patch makes the common udp proc functions to take care of which socket they should show taking into account the namespace it belongs. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[NET]: Add per-connection option to set max TSO frame sizePeter P Waskiewicz Jr
Update: My mailer ate one of Jarek's feedback mails... Fixed the parameter in netif_set_gso_max_size() to be u32, not u16. Fixed the whitespace issue due to a patch import botch. Changed the types from u32 to unsigned int to be more consistent with other variables in the area. Also brought the patch up to the latest net-2.6.26 tree. Update: Made gso_max_size container 32 bits, not 16. Moved the location of gso_max_size within netdev to be less hotpath. Made more consistent names between the sock and netdev layers, and added a define for the max GSO size. Update: Respun for net-2.6.26 tree. Update: changed max_gso_frame_size and sk_gso_max_size from signed to unsigned - thanks Stephen! This patch adds the ability for device drivers to control the size of the TSO frames being sent to them, per TCP connection. By setting the netdevice's gso_max_size value, the socket layer will set the GSO frame size based on that value. This will propogate into the TCP layer, and send TSO's of that size to the hardware. This can be desirable to help tune the bursty nature of TSO on a per-adapter basis, where one may have 1 GbE and 10 GbE devices coexisting in a system, one running multiqueue and the other not, etc. This can also be desirable for devices that cannot support full 64 KB TSO's, but still want to benefit from some level of segmentation offloading. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
2008-03-20[SCTP]: Fix a race between module load and protosw accessVlad Yasevich
There is a race is SCTP between the loading of the module and the access by the socket layer to the protocol functions. In particular, a list of addresss that SCTP maintains is not initialized prior to the registration with the protosw. Thus it is possible for a user application to gain access to SCTP functions before everything has been initialized. The problem shows up as odd crashes during connection initializtion when we try to access the SCTP address list. The solution is to refactor how we do registration and initialize the lists prior to registering with the protosw. Care must be taken since the address list initialization depends on some other pieces of SCTP initialization. Also the clean-up in case of failure now also needs to be refactored. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/rt2x00dev.c net/8021q/vlan_dev.c
2008-03-17Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-03-17xfrm: ->eth_proto is __be16Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-17[IPV4]: ipv4_is_lbcast() misannotationsAl Viro
2008-03-17[PKT_SCHED]: annotate cls_u32Al Viro
2008-03-17Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: ahci: Add Marvell 6121 SATA support pata_ali: use atapi_cmd_type() to determine cmd type instead of transfer size ahci: implement skip_host_reset parameter ahci: request all PCI BARs devres: implement pcim_iomap_regions_request_all() libata-acpi: improve dock event handling
2008-03-17devres: implement pcim_iomap_regions_request_all()Tejun Heo
Some drivers need to reserve all PCI BARs to prevent other drivers misusing unoccupied BARs. pcim_iomap_regions_request_all() requests all BARs and iomap specified BARs. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-17virtio: fix race in enable_cbChristian Borntraeger
There is a race in virtio_net, dealing with disabling/enabling the callback. I saw the following oops: kernel BUG at /space/kvm/drivers/virtio/virtio_ring.c:218! illegal operation: 0001 [#1] SMP Modules linked in: sunrpc dm_mod CPU: 2 Not tainted 2.6.25-rc1zlive-host-10623-gd358142-dirty #99 Process swapper (pid: 0, task: 000000000f85a610, ksp: 000000000f873c60) Krnl PSW : 0404300180000000 00000000002b81a6 (vring_disable_cb+0x16/0x20) R:0 T:1 IO:0 EX:0 Key:0 M:1 W:0 P:0 AS:0 CC:3 PM:0 EA:3 Krnl GPRS: 0000000000000001 0000000000000001 0000000010005800 0000000000000001 000000000f3a0900 000000000f85a610 0000000000000000 0000000000000000 0000000000000000 000000000f870000 0000000000000000 0000000000001237 000000000f3a0920 000000000010ff74 00000000002846f6 000000000fa0bcd8 Krnl Code: 00000000002b819a: a7110001 tmll %r1,1 00000000002b819e: a7840004 brc 8,2b81a6 00000000002b81a2: a7f40001 brc 15,2b81a4 >00000000002b81a6: a51b0001 oill %r1,1 00000000002b81aa: 40102000 sth %r1,0(%r2) 00000000002b81ae: 07fe bcr 15,%r14 00000000002b81b0: eb7ff0380024 stmg %r7,%r15,56(%r15) 00000000002b81b6: a7f13e00 tmll %r15,15872 Call Trace: ([<000000000fa0bcd0>] 0xfa0bcd0) [<00000000002b8350>] vring_interrupt+0x5c/0x6c [<000000000010ab08>] do_extint+0xb8/0xf0 [<0000000000110716>] ext_no_vtime+0x16/0x1a [<0000000000107e72>] cpu_idle+0x1c2/0x1e0 The problem can be triggered with a high amount of host->guest traffic. I think its the following race: poll says netif_rx_complete poll calls enable_cb enable_cb opens the interrupt mask a new packet comes, an interrupt is triggered----\ enable_cb sees that there is more work | enable_cb disables the interrupt | . V . interrupt is delivered . skb_recv_done does atomic napi test, ok some waiting disable_cb is called->check fails->bang! . poll would do napi check poll would do disable_cb The fix is to let enable_cb not disable the interrupt again, but expect the caller to do the cleanup if it returns false. In that case, the interrupt is only disabled, if the napi test_set_bit was successful. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (cleaned up doco)
2008-03-16Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: [PARISC] make ptr_to_pide() static [PARISC] head.S: section mismatch fixes [PARISC] add back Crestone Peak cpu [PARISC] futex: special case cmpxchg NULL in kernel space [PARISC] clean up show_stack [PARISC] add pa8900 CPUs to hardware inventory [PARISC] clean up include/asm-parisc/elf.h [PARISC] move defconfig to arch/parisc/configs/ [PARISC] add back AD1889 MAINTAINERS entry [PARISC] pdc_console: fix bizarre panic on boot [PARISC] dump_stack in show_regs [PARISC] pdc_stable: fix compile errors [PARISC] remove unused pdc_iodc_printf function [PARISC] bump __NR_syscalls [PARISC] unbreak pgalloc.h [PARISC] move VMALLOC_* definitions to fixmap.h [PARISC] wire up timerfd syscalls [PARISC] remove old timerfd syscall
2008-03-15[PARISC] futex: special case cmpxchg NULL in kernel spaceKyle McMartin
Commit a0c1e9073ef7428a14309cba010633a6cd6719ea added code to futex.c to detect whether futex_atomic_cmpxchg_inatomic was implemented at run time: + curval = cmpxchg_futex_value_locked(NULL, 0, 0); + if (curval == -EFAULT) + futex_cmpxchg_enabled = 1; This is bogus on parisc, since page zero in kernel virtual space is the gateway page for syscall entry, and should not be read from the kernel. (That, and we really don't like the kernel faulting on its own address space...) Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-03-15[PARISC] clean up include/asm-parisc/elf.hRandolph Chung
Cleanup some cruft. No functionality changes. Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-03-15[PARISC] pdc_console: fix bizarre panic on bootKyle McMartin
Commit 721fdf34167580ff98263c74cead8871d76936e6 introduced a subtle bug by accidently removing the "static" from iodc_dbuf. This resulted in, what appeared to be, a trap without *current set to a task. Probably the result of a trap in real mode while calling firmware. Also do other misc clean ups. Since the only input from firmware is non blocking, share iodc_dbuf between input and output, and spinlock the only callers. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2008-03-15[PARISC] remove unused pdc_iodc_printf functionKyle McMartin
2008-03-15[PARISC] bump __NR_syscallsKyle McMartin
oops, forgot this in the previous commit. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2008-03-15[PARISC] unbreak pgalloc.hKyle McMartin
Commit 2f569afd9ced9ebec9a6eb3dbf6f83429be0a7b4 broke the compile rather spectacularly. Fix code errors. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2008-03-15[PARISC] move VMALLOC_* definitions to fixmap.hKyle McMartin
They make way more sense here, really... Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2008-03-15[PARISC] wire up timerfd syscallsKyle McMartin
2008-03-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: [NET]: Fix tbench regression in 2.6.25-rc1
2008-03-14struct export_operations: adjust comments to match current membersMarc Dionne
The comments in the definition of struct export_operations don't match the current members. Add a comment for the 2 new functions and remove 2 comments for unused ones. Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-13ssb: Add SPROM/invariants support for PCMCIA devicesMichael Buesch
This adds support for reading/writing the SPROM invariants for PCMCIA based devices. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13include/net/ieee80211.h - remove duplicate includeJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6: PCI: fix issue with busses registering multiple times in sysfs
2008-03-13h8300: fix recent uaccess breakageYoshinori Sato
Al Viro wrote: > > After that commit in asm-h8300/uaccess.h we have > > #define get_user(x, ptr) \ > ({ \ > int __gu_err = 0; \ > uint32_t __gu_val = 0; \ > ^^^^^^^^^^^^^^^^^ > switch (sizeof(*(ptr))) { \ > case 1: \ > case 2: \ > case 4: \ > __gu_val = *(ptr); \ > break; \ > case 8: \ > memcpy(&__gu_val, ptr, sizeof (*(ptr))); \ > ^^^^^^^^^^^^^^^^ > > which, of course, is FUBAR whenever we actually hit that case - memcpy of > 8 bytes into uint32_t is obviously wrong. Why don't we simply do Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-13the scheduled ieee80211 softmac removalAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13PCI: fix issue with busses registering multiple times in sysfsGreg Kroah-Hartman
PCI busses can be registered multiple times, so we need to detect if we have registered our bus structure in sysfs already. If so, don't do it again. Thanks to Guennadi Liakhovetski <g.liakhovetski@gmx.de> for reporting the problem, and to Linus for poking me to get me to believe that it was a real problem. Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-12[NET]: Fix tbench regression in 2.6.25-rc1Zhang Yanmin
Comparing with kernel 2.6.24, tbench result has regression with 2.6.25-rc1. 1) On 2 quad-core processor stoakley: 4%. 2) On 4 quad-core processor tigerton: more than 30%. bisect located below patch. b4ce92775c2e7ff9cf79cca4e0a19c8c5fd6287b is first bad commit commit b4ce92775c2e7ff9cf79cca4e0a19c8c5fd6287b Author: Herbert Xu <herbert@gondor.apana.org.au> Date: Tue Nov 13 21:33:32 2007 -0800 [IPV6]: Move nfheader_len into rt6_info The dst member nfheader_len is only used by IPv6. It's also currently creating a rather ugly alignment hole in struct dst. Therefore this patch moves it from there into struct rt6_info. Above patch changes the cache line alignment, especially member __refcnt. I did a testing by adding 2 unsigned long pading before lastuse, so the 3 members, lastuse/__refcnt/__use, are moved to next cache line. The performance is recovered. I created a patch to rearrange the members in struct dst_entry. With Eric and Valdis Kletnieks's suggestion, I made finer arrangement. 1) Move tclassid under ops in case CONFIG_NET_CLS_ROUTE=y. So sizeof(dst_entry)=200 no matter if CONFIG_NET_CLS_ROUTE=y/n. I tested many patches on my 16-core tigerton by moving tclassid to different place. It looks like tclassid could also have impact on performance. If moving tclassid before metrics, or just don't move tclassid, the performance isn't good. So I move it behind metrics. 2) Add comments before __refcnt. On 16-core tigerton: If CONFIG_NET_CLS_ROUTE=y, the result with below patch is about 18% better than the one without the patch; If CONFIG_NET_CLS_ROUTE=n, the result with below patch is about 30% better than the one without the patch. With 32bit 2.6.25-rc1 on 8-core stoakley, the new patch doesn't introduce regression. Thank Eric, Valdis, and David! Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Acked-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (26 commits) [ARM] 4856/1: Orion: initialise the sixth PCIe MBUS mapping window as well [ARM] 4855/1: Orion: use correct ethernet unit address range [ARM] 4853/1: include uImage target in make help [ARM] 4851/1: ns9xxx: fix size of gpiores [ARM] AT91: correct at91sam9263ek LCD power gpio pin [ARM] replace remaining __FUNCTION__ occurrences [ARM] 4850/1: include generic pgtable.h for !CONFIG_MMU case [ARM] 4849/1: move ATAGS asm definitions [ARM] 4848/1: at91: remove false lockdep warnings [ARM] 4847/1: kprobes: fix compilation with CONFIG_DEBUG_FS=y [ARM] include/asm-arm - use angle brackets for includes [ARM] 4845/1: Orion: Ignore memory tags with invalid data ARM: OMAP2: Register the L4 io bus to boot OMAP2 ARM: OMAP1: Compile in other 16xx boards to OSK defconfig ARM: OMAP1: Refresh H2 defconfig ARM: OMAP1: Refresh OSK defconfig ARM: OMAP: gpio lockdep updates ARM: OMAP1: omap1/pm.c build fix ARM: OMAP1: omap h2 regression fix ARM: OMAP1: Fix compile for boards depending on old gpio expander ...
2008-03-12Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (22 commits) [POWERPC] Fix large hash table allocation on Cell blades [POWERPC] Export empty_zero_page [POWERPC] Fix viodasd driver with scatterlist debug [POWERPC] Fix arch/powerpc/platforms/powermac/pic.c when !CONFIG_ADB_PMU [POWERPC] Fix drivers/macintosh/mediabay.c when !CONFIG_ADB_PMU [POWERPC] Fix undefined pmu_sys_suspended compilation error [POWERPC] Fix build of modular drivers/macintosh/apm_emu.c [POWERPC] Fix sleep on some powerbooks [POWERPC] Fix bogus test for unassigned PCI resources [POWERPC] Fix zImage-dtb.initrd build error [POWERPC] Add __ucmpdi2 for 64-bit comparisons in 32-bit kernels [POWERPC] spufs: fix rescheduling of non-runnable contexts [POWERPC] spufs: don't (ab)use SCHED_IDLE [POWERPC] QE: Make qe_get_firmware_info reentrant [POWERPC] 83xx: Make 83xx perfmon support selectable [PPC] 8xx: swap bug-fix [POWERPC] 85xx: sbc8548 - Fix incorrect PCI-X and PCI interrupt map [POWERPC] QE: Fix QE firmware uploading limit [POWERPC] 8xx: Fix wrapper platform for adder875, and combine defconfigs. [POWERPC] 8xx: fix swap ...
2008-03-13[POWERPC] Fix drivers/macintosh/mediabay.c when !CONFIG_ADB_PMUTony Breeds
When building drivers/macintosh/mediabay.c if CONFIG_ADB_PMU isn't defined we get: drivers/built-in.o: In function `media_bay_step': mediabay.c:(.text+0x92b84): undefined reference to `pmu_suspend' mediabay.c:(.text+0x92c08): undefined reference to `pmu_resume' Create empty place holders in that scenario. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-13[POWERPC] Fix undefined pmu_sys_suspended compilation errorTony Breeds
pmu_sys_suspended is declared extern when: defined(CONFIG_PM_SLEEP) && defined(CONFIG_PPC32) but only defined when: defined(CONFIG_SUSPEND) && defined(CONFIG_PPC32) which is wrong. Let's fix that. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) [SCTP]: Fix local_addr deletions during list traversals. net: fix build with CONFIG_NET=n [TCP]: Prevent sending past receiver window with TSO (at last skb) rt2x00: Add new D-Link USB ID rt2x00: never disable multicast because it disables broadcast too libertas: fix the 'compare command with itself' properly drivers/net/Kconfig: fix whitespace for GELIC_WIRELESS entry [NETFILTER]: nf_queue: don't return error when unregistering a non-existant handler [NETFILTER]: nfnetlink_queue: fix EPERM when binding/unbinding and instance 0 exists [NETFILTER]: nfnetlink_log: fix EPERM when binding/unbinding and instance 0 exists [NETFILTER]: nf_conntrack: replace horrible hack with ksize() [NETFILTER]: nf_conntrack: add \n to "expectation table full" message [NETFILTER]: xt_time: fix failure to match on Sundays [NETFILTER]: nfnetlink_log: fix computation of netlink skb size [NETFILTER]: nfnetlink_queue: fix computation of allocated size for netlink skb. [NETFILTER]: nfnetlink: fix ifdef in nfnetlink_compat.h [NET]: include <linux/types.h> into linux/ethtool.h for __u* typedef [NET]: Make /proc/net a symlink on /proc/self/net (v3) RxRPC: fix rxrpc_recvmsg()'s returning of msg_name net/enc28j60: oops fix ...
2008-03-12Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Clocksource: Only install r4k counter as clocksource if present. [MIPS] Lasat: fix LASAT_CASCADE_IRQ [MIPS] Delete leftovers of old pcspeaker support. [MIPS] BCM1480: Init pci controller io_map_base [MIPS] Yosemite: Fix a few more section reference bugs. [MIPS] Fix yosemite build error [MIPS] Fix loads of section missmatches [MIPS] IP27: Tighten up CPU description to fix warnings. [MIPS] Fix plat_ioremap for JMR3927 [MIPS] Export __ucmpdi2 to modules. [MIPS] Fix typo in comment [MIPS] Use KBUILD_DEFCONFIG [MIPS] Allow 48Hz to be selected if CONFIG_SYS_SUPPORTS_ARBIT_HZ is set. [MIPS] Added missing cases for rdhwr emulation [MIPS] Alchemy: Fix ids in Alchemy db dma device table
2008-03-12Remove <linux/genhd.h> from user-visible headers.David Woodhouse
It was all wrapped in '#ifdef CONFIG_BLOCK' anyway, so userspace was getting nothing useful out of it. And the special #ifndef __KERNEL__ version of 'struct partition' makes me inclined to promote an attitude of violence... Stick some comments on some of the #endifs too, while we're at it. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-12nommu: Provide is_vmalloc_addr() stub.Paul Mundt
Introduced in commit-id 9e2779fa281cfda13ac060753d674bbcaa23367e and ifdef'ed out for nommu in 8ca3ed87db062201e1fa15b64a9214e193fc3a8a, both approaches end up breaking the nommu build in different ways. An impressive feat for a 2-liner. Current is_vmalloc_addr() users fall in to two camps: - Determining whether to use vfree()/kfree() - Whether to do vmlist traversal (only /proc/kcore). Since we don't support /proc/kcore on nommu, that leaves the vfree()/kfree() determination use cases. nommu vfree() happens to be a wrapper to kfree() anyways, so is_vmalloc_addr() can always return 0 and end up with the right behaviour. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-12[MIPS] Clocksource: Only install r4k counter as clocksource if present.Ralf Baechle
2008-03-12[MIPS] Lasat: fix LASAT_CASCADE_IRQYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
