path: root/include
2008-02-07Memory controller: resource countersPavel Emelianov
With fixes from David Rientjes <rientjes@google.com> Introduce generic structures and routines for resource accounting. Each resource accounting cgroup is supposed to aggregate it, cgroup_subsystem_state and its resource-specific members within. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07tty: Kill TTY_FLIPBUF_SIZEAlan Cox
This legacy define from the old buffer code is now only used in a single power pc driver than doesn't compile anyway. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07tty: fix tty network driver interactions with TCGET/TCSET calls (x86 fix)Dave Miller
And to go with it Dave's type checking x86 termios headers. I've updated these as the original sent by Dave had some wrong types in it. Signed-off-by: Alan Cox <alan@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07VFS: swap do_ioctl and vfs_ioctl namesErez Zadok
Rename old vfs_ioctl to do_ioctl, because the comment above it clearly indicates that it is an internal function not to be exported to modules; therefore it should have a more traditional do_XXX name. The new do_ioctl is exported in fs.h but not to modules. Rename the old do_ioctl to vfs_ioctl because the names vfs_XXX should preferably be reserved to callable VFS functions which modules may call, as many other vfs_XXX functions already do. Export the new vfs_ioctl to GPL modules so others can use it (including Unionfs and eCryptfs). Add DocBook for new vfs_ioctl. [akpm@linux-foundation.org: fix build] Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07DS1WM: decouple host IRQ and INTR active state settingsPhilipp Zabel
The DS1WM driver incorrectly infers the IAS bit (1-wire interrupt active high) from IRQ settings. There are devices that have IAS=0 but still need the IRQ to trigger on a rising edge. With this patch, machines with DS1WM that need IAS=1 have to set .active_high=1 in the ds1wm_platform_data. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Acked-by: Matt Reimer <mreimer@vpop.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-069p: transport API reorganizationEric Van Hensbergen
This merges the mux.c (including the connection interface) with trans_fd in preparation for transport API changes. Ultimately, trans_fd will need to be rewritten to clean it up and simplify the implementation, but this reorganization is viewed as the first step. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: add support for sticky bitAnthony Liguori
GDM gets unhappy if /var/gdm doesn't have the sticky bit set. This patch adds support for the sticky bit in much the same way setuid/setgid is supported. With this patch, I can launch X from a v9fs rootfs (although I quickly run out of fds in the server once gnome starts up). Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: block-based virtio clientEric Van Hensbergen
This replaces the console-based virto client with a block-based client using a single request queue. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: create transport rpc cut-thruEric Van Hensbergen
Add a new transport function which allows a cut-thru directly to the transport instead of processing request through the mux if the cut-thru exists. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86: fix deadlock, make pgd_lock irq-safe virtio: fix trivial build bug x86: fix mttr trimming x86: delay CPA self-test and repeat it x86: fix 64-bit sections generic: add __FINITDATA x86: remove suprious ifdefs from pageattr.c x86: mark the .rodata section also NX x86: fix iret exception recovery on 64-bit cpuidle: dubious one-bit signed bitfield in cpuidle.h x86: fix sparse warnings in powernow-k8.c x86: fix sparse error in traps_32.c x86: trivial sparse/checkpatch in quirks.c x86 ptrace: disallow null cs/ss MAINTAINERS: RDC R-321x SoC maintainer brk randomization: introduce CONFIG_COMPAT_BRK brk: check the lower bound properly x86: remove X2 workaround x86: make spurious fault handler aware of large mappings x86: make traps on entry code be debuggable in user space, 64-bit
2008-02-06x86: fix deadlock, make pgd_lock irq-safeIngo Molnar
lockdep just caught this one: ================================= [ INFO: inconsistent lock state ] 2.6.24 #38 --------------------------------- inconsistent {in-softirq-W} -> {softirq-on-W} usage. swapper/1 [HC0[0]:SC0[0]:HE1:SE1] takes: (pgd_lock){-+..}, at: [<ffffffff8022a9ea>] mm_init+0x1da/0x250 {in-softirq-W} state was registered at: [<ffffffffffffffff>] 0xffffffffffffffff irq event stamp: 394559 hardirqs last enabled at (394559): [<ffffffff80267f0a>] get_page_from_freelist+0x30a/0x4c0 hardirqs last disabled at (394558): [<ffffffff80267d25>] get_page_from_freelist+0x125/0x4c0 softirqs last enabled at (393952): [<ffffffff80232f8e>] __do_softirq+0xce/0xe0 softirqs last disabled at (393945): [<ffffffff8020c57c>] call_softirq+0x1c/0x30 other info that might help us debug this: no locks held by swapper/1. stack backtrace: Pid: 1, comm: swapper Not tainted 2.6.24 #38 Call Trace: [<ffffffff8024e1fb>] print_usage_bug+0x18b/0x190 [<ffffffff8024f55d>] mark_lock+0x53d/0x560 [<ffffffff8024fffa>] __lock_acquire+0x3ca/0xed0 [<ffffffff80250ba8>] lock_acquire+0xa8/0xe0 [<ffffffff8022a9ea>] ? mm_init+0x1da/0x250 [<ffffffff809bcd10>] _spin_lock+0x30/0x70 [<ffffffff8022a9ea>] mm_init+0x1da/0x250 [<ffffffff8022aa99>] mm_alloc+0x39/0x50 [<ffffffff8028b95a>] bprm_mm_init+0x2a/0x1a0 [<ffffffff8028d12b>] do_execve+0x7b/0x220 [<ffffffff80209776>] sys_execve+0x46/0x70 [<ffffffff8020c214>] kernel_execve+0x64/0xd0 [<ffffffff8020901e>] ? _stext+0x1e/0x20 [<ffffffff802090ba>] init_post+0x9a/0xf0 [<ffffffff809bc5f6>] ? trace_hardirqs_on_thunk+0x35/0x3a [<ffffffff8024f75a>] ? trace_hardirqs_on+0xba/0xd0 [<ffffffff8020c1a8>] ? child_rip+0xa/0x12 [<ffffffff8020bcbc>] ? restore_args+0x0/0x44 [<ffffffff8020c19e>] ? child_rip+0x0/0x12 turns out that pgd_lock has been used on 64-bit x86 in an irq-unsafe way for almost two years, since commit 8c914cb704a11460e. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-06generic: add __FINITDATAIngo Molnar
2008-02-06cpuidle: dubious one-bit signed bitfield in cpuidle.hHarvey Harrison
fix these sparse warnings: CHECK arch/x86/kernel/acpi/cstate.c include/linux/cpuidle.h:82:17: error: dubious one-bit signed bitfield CHECK arch/x86/kernel/acpi/processor.c include/linux/cpuidle.h:82:17: error: dubious one-bit signed bitfield CHECK arch/x86/kernel/cpu/cpufreq/powernow-k7.c include/linux/cpuidle.h:82:17: error: dubious one-bit signed bitfield CHECK arch/x86/kernel/cpu/cpufreq/powernow-k8.c include/linux/cpuidle.h:82:17: error: dubious one-bit signed bitfield CHECK arch/x86/kernel/cpu/cpufreq/longhaul.c include/linux/cpuidle.h:82:17: error: dubious one-bit signed bitfield CHECK arch/x86/kernel/cpu/cpufreq/acpi-cpufreq.c include/linux/cpuidle.h:82:17: error: dubious one-bit signed bitfield Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06Merge branch 'async-tx-for-linus' of ↵Linus Torvalds
git://lost.foo-projects.org/~dwillia2/git/iop into fix * 'async-tx-for-linus' of git://lost.foo-projects.org/~dwillia2/git/iop: async_tx: allow architecture specific async_tx_find_channel implementations async_tx: replace 'int_en' with operation preparation flags async_tx: kill tx_set_src and tx_set_dest methods async_tx: kill ASYNC_TX_ASSUME_COHERENT iop-adma: use LIST_HEAD instead of LIST_HEAD_INIT async_tx: use LIST_HEAD instead of LIST_HEAD_INIT async_tx: fix compile breakage, mark do_async_xor __always_inline
2008-02-06Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: ata_piix.c:piix_init_one() must be __devinit sata_via.c: Remove missleading comment. libata-core: unblacklist HITACHI drives sata_nv: fix ATAPI issues with memory over 4GB (v7) ata: drivers/ata/sata_mv.c needs dmapool.h libata: kill now unused n_iter and fix sata_fsl ahci: fix CAP.NP and PI handling sata_mv: Support SoC controllers Rename: linux/pata_platform.h to linux/ata_platform.h
2008-02-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (35 commits) virtio net: fix oops on interface-up Fix PHY Lib support for gianfar and ucc_geth forcedeth: preserve registers forcedeth: phy status fix forcedeth: restart tx/rx ipvs: Make wrr "no available servers" error message rate-limited [PPPOL2TP]: Label unused warning when CONFIG_PROC_FS is not set. [NET_SCHED]: cls_flow: support classification based on VLAN tag [VLAN]: Constify skb argument to vlan_get_tag() [NET_SCHED]: cls_flow: fix key mask validity check [NET_SCHED]: em_meta: fix compile warning b43: Fix DMA for 30/32-bit DMA engines b43: fix build with CONFIG_SSB_PCIHOST=n mac80211: Is not EXPERIMENTAL anymore iwl3945-base.c: fix off-by-one errors b43legacy: fix DMA slot resource leakage b43legacy: drop packets we are not able to encrypt b43legacy: fix suspend/resume b43legacy: fix PIO crash Generic HDLC - use random_ether_addr() ...
2008-02-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Temporarily remove IOMMU merging code. [SPARC64]: Update defconfig. [SPARC]: Add new timerfd syscall entries.
2008-02-06jbd.h: hide kernel only codeOlaf Hering
Move a few kernel-only things into __KERNEL__. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06make jbd/journal.c:__journal_abort_hard() staticAdrian Bunk
__journal_abort_hard() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06isapnp driver semaphore to mutexDaniel Walker
Changed the isapnp semaphore to a mutex. [akpm@linux-foundation.org: no externs-in-c] [akpm@linux-foundation.org: build fix] Signed-off-by: Daniel Walker <dwalker@mvista.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: change ITERATE_RDEV_GENERIC to rdev_for_each_list, and remove ↵NeilBrown
ITERATE_RDEV_PENDING. Finish ITERATE_ to for_each conversion. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: change ITERATE_RDEV to rdev_for_eachNeilBrown
As this is more in line with common practice in the kernel. Also swap the args around to be more like list_for_each. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: allow devices to be shared between md arraysNeilBrown
Currently, a given device is "claimed" by a particular array so that it cannot be used by other arrays. This is not ideal for DDF and other metadata schemes which have their own partitioning concept. So for externally managed metadata, just claim the device for md in general, require that "offset" and "size" are set properly for each device, and make sure that if a device is included in different arrays then the active sections do not overlap. This involves adding another flag to the rdev which makes it awkward to set "->flags = 0" to clear certain flags. So now clear flags explicitly by name when we want to clear things. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: allow a maximum extent to be set for resyncingNeilBrown
This allows userspace to control resync/reshape progress and synchronise it with other activities, such as shared access in a SAN, or backing up critical sections during a tricky reshape. Writing a number of sectors (which must be a multiple of the chunk size if such is meaningful) causes a resync to pause when it gets to that point. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: support 'external' metadata for md arraysNeilBrown
- Add a state flag 'external' to indicate that the metadata is managed externally (by user-space) so important changes need to be left of user-space to handle. Alternates are non-persistant ('none') where there is no stable metadata - after the array is stopped there is no record of it's status - and internal which can be version 0.90 or version 1.x These are selected by writing to the 'metadata' attribute. - move the updating of superblocks (sync_sbs) to after we have checked if there are any superblocks or not. - New array state 'write_pending'. This means that the metadata records the array as 'clean', but a write has been requested, so the metadata has to be updated to record a 'dirty' array before the write can continue. This change is reported to md by writing 'active' to the array_state attribute. - tidy up marking of sb_dirty: - don't set sb_dirty when resync finishes as md_check_recovery calls md_update_sb when the sync thread finishes anyway. - Don't set sb_dirty in multipath_run as the array might not be dirty. - don't mark superblock dirty when switching to 'clean' if there is no internal superblock (if external, userspace can choose to update the superblock whenever it chooses to). Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: Update md bitmap during resync.NeilBrown
Currently an md array with a write-intent bitmap does not updated that bitmap to reflect successful partial resync. Rather the entire bitmap is updated when the resync completes. This is because there is no guarentee that resync requests will complete in order, and tracking each request individually is unnecessarily burdensome. However there is value in regularly updating the bitmap, so add code to periodically pause while all pending sync requests complete, then update the bitmap. Doing this only every few seconds (the same as the bitmap update time) does not notciably affect resync performance. [snitzer@gmail.com: export bitmap_cond_end_sync] Signed-off-by: Neil Brown <neilb@suse.de> Cc: "Mike Snitzer" <snitzer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06FB/S3C2412: add S3C2412 support to S3C2410 fb driverBen Dooks
Add support for the S3C2412 to the S3C2410 frame buffer driver by ensuring that any moved registers can be dealt with. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Vincent Sanders <vince@simtec.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ps3: use symbolic names for video modesGeert Uytterhoeven
Use symbolic names for video modes Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ps3av: ps3av_get_scanmode() and ps3av_get_refresh_rate() are unusedGeert Uytterhoeven
ps3av_get_scanmode() and ps3av_get_refresh_rate() are unused, so remove them Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06atmel_lcdfb: backlight controlDavid Brownell
On the sam9 EK boards, the LCD backlight is hooked up to a PWM output from the LCD controller. It's controlled by "contrast" registers though. This patch lets boards declare that they have that kind of backlight control. The driver can then export this control, letting screenblank and other operations actually take effect ... reducing the typically substantial power drain from the backlight. Note that it's not fully cooked - doesn't force backlight off during system suspend - the "power" and "blank" events may not be done right This should be easily added in the future. [nicolas.ferre@atmel.com: remove unneeded inline and rename functions] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06sm501fb: control panel pin usage with platform data flagsMagnus Damm
This patch makes it possible to control panel pins usage with flags passed from the platform data. Without this patch the sm501fb driver always controls the VBIASEN and FPEN pins. The polarity and use of these pins are very platform specific, so this patch introduces the flags SM501FB_FLAG_PANEL_USE_VBIASEN and SM501FB_FLAG_PANEL_USE_FPEN which enable the use of these pins. This patch is needed to support the a Sharp LQ104V1DG21 lcd panel on SuperH platforms such as R2D-1 and R2D-PLUS boards. Letting the sm501fb driver control the FPEN and VBIASEN pins like today just results in lcd panel flicker. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06atmel_lcdfb: validate display timingsHaavard Skinnemoen
Setting a display timing parameter too high or too low may cause it to wrap around and thus become completely wrong. Validate the timings in atmel_lcdfb_check_var() and saturate to the highest or lowest possible value if necessary. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06gpio: rename pca953x symbolsGuennadi Liakhovetski
This second part of an extension to support more pca953x chips renames the C and Kconfig symbols. All affected files were updated by sed, except for a couple of obvious exceptions. It also updates the Kconfig helptext. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06gpio: rename pca9539 driverGuennadi Liakhovetski
First part of an extension to let the pca9539 driver support more chips, starting with pca9534, pca9535, pca9536, pca9537, and pca9538. This renames the files and modifies the Makefile. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06w1-gpio: add GPIO w1 bus master driverVille Syrjala
Add a GPIO 1-wire bus master driver. The driver used the GPIO API to control the wire and the GPIO pin can be specified using platform data similar to i2c-gpio. The driver was tested with AT91SAM9260 + DS2401. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06kprobes: kretprobe user entry-handlerAbhishek Sagar
Provide support to add an optional user defined callback to be run at function entry of a kretprobe'd function. Also modify the kprobe smoke tests to include an entry-handler during the kretprobe sanity test. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Acked-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06spi: s3c drivers shouldn't care about spi_board_infoDavid Brownell
The two S3C SPI master drivers got merged without much review, so I just noticed that they're doing something that the SPI core code is responsible for, rather than any adapter driver: they try to register SPI devices. This removes that support from those drivers so they act normally. Interestingly, none of the current boards are affected. So it's a net code shrink with no loss of functionality. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06system timer: fix crash in <100Hz system timerDavid Fries
The kernel has a divide by zero crash when trying to run the system timer less than 100Hz. The problem is x/(HZ/USER_HZ) and related. Now x*(USER_HZ/HZ) will be used if HZ<USER_HZ. I'm running the Linux kernel under qemu and went to run a slower system timer to take less CPU (and battery) on the host. I found that the kernel paniced under emulation because of a divide by zero in three places. Here is the patch. The base git was updated today 01-05-2008. I went for a 20Hz system time by adding config HZ_20 etc to kernel/Kconfig.hz. With this patch I verified the system timer by looking at /proc/interrupts. [akpm@linux-foundation.org: partially clean up the macro maze] Signed-off-by: David Fries <david@fries.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06kernel/sys.c: get rid of expensive divides in groups_sort()Eric Dumazet
groups_sort() can be quite long if user loads a large gid table. This is because GROUP_AT(group_info, some_integer) uses an integer divide. So having to do XXX thousand divides during one syscall can lead to very high latencies. (NGROUPS_MAX=65536) In the past (25 Mar 2006), an analog problem was found in groups_search() (commit d74beb9f33a5f16d2965f11b275e401f225c949d ) and at that time I changed some variables to unsigned int. I believe that a more generic fix is to make sure NGROUPS_PER_BLOCK is unsigned. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06parport: add support for the Quatech SPPXP-100 Parallel port PCI ExpressCardLuís P Mendes
Added pci device id for the Quatech SPPXP-100 ExpressCard - 0x278 - to include/linux/pci_id.h Modified drivers/parport/parport_pc.c to support the Quatech SPPXP-100 Parallel port PCI ExpressCard [akpm@linux-foundation.org: build fix] Signed-off-by: Luís P Mendes <luis.p.mendes@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Add arch_ptrace_stopRoland McGrath
This adds support to allow asm/ptrace.h to define two new macros, arch_ptrace_stop_needed and arch_ptrace_stop. These control special machine-specific actions to be done before a ptrace stop. The new code compiles away to nothing when the new macros are not defined. This is the case on all machines to begin with. On ia64, these macros will be defined to solve the long-standing issue of ptrace vs register backing store. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06drivers/isdn/i4l/isdn_tty.c: remove write_semDaniel Walker
I couldn't find any users, so removing it.. Signed-off-by: Daniel Walker <dwalker@mvista.com> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06drivers/char/tty_io.c: remove pty_semDaniel Walker
I couldn't find any users, so removing it.. Signed-off-by: Daniel Walker <dwalker@mvista.com> Acked-by: Alan Cox <alan@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Remove rcu_assign_pointer() penalty for NULL pointersPaul E. McKenney
The rcu_assign_pointer() primitive currently unconditionally executes a memory barrier, even when a NULL pointer is being assigned. This has lead some to avoid using rcu_assign_pointer() for NULL pointers, which loses the self-documenting advantages of rcu_assign_pointer() This patch uses __builtin_const_p() to omit needless memory barriers for NULL-pointer assignments at compile time with no runtime penalty, as discussed in the following thread: http://www.mail-archive.com/netdev@vger.kernel.org/msg54852.html Tested on x86_64 and ppc64, also compiled the four cases (NULL/non-NULL and const/non-const) with gcc version 4.1.2, and hand-checked the assembly output. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Fix __const_udelay declaration and definition mismatchesJeff Dike
The declaration and implementation of __const_udelay use different names for the parameter on a number of architectures: include/asm-avr32/delay.h:15:extern void __const_udelay(unsigned long usecs); arch/avr32/lib/delay.c:39:inline void __const_udelay(unsigned long xloops) include/asm-sh/delay.h:15:extern void __const_udelay(unsigned long usecs); arch/sh/lib/delay.c:22:inline void __const_udelay(unsigned long xloops) include/asm-m32r/delay.h:15:extern void __const_udelay(unsigned long usecs); arch/m32r/lib/delay.c:58:void __const_udelay(unsigned long xloops) include/asm-x86/delay.h:16:extern void __const_udelay(unsigned long usecs); arch/x86/lib/delay_32.c:82:inline void __const_udelay(unsigned long xloops) arch/x86/lib/delay_64.c:46:inline void __const_udelay(unsigned long xloops) The units of the parameter isn't usecs, so that name is definitely wrong. It's also not exactly loops, so I suppose xloops is an OK name. This patch changes these names from usecs to xloops. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06get rid of NR_OPEN and introduce a sysctl_nr_openEric Dumazet
NR_OPEN (historically set to 1024*1024) actually forbids processes to open more than 1024*1024 handles. Unfortunatly some production servers hit the not so 'ridiculously high value' of 1024*1024 file descriptors per process. Changing NR_OPEN is not considered safe because of vmalloc space potential exhaust. This patch introduces a new sysctl (/proc/sys/fs/nr_open) wich defaults to 1024*1024, so that admins can decide to change this limit if their workload needs it. [akpm@linux-foundation.org: export it for sparc64] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06inotify: send IN_ATTRIB events when link count changesJan Kara
Currently, no notification event has been sent when inode's link count changed. This is inconvenient for the application in some cases: Suppose you have the following directory structure foo/test bar/ and you watch test. If someone does "mv foo/test bar/", you get event IN_MOVE_SELF and you know something has happened with the file "test". However if someone does "ln foo/test bar/test" and "rm foo/test" you get no inotify event for the file "test" (only directories "foo" and "bar" receive events). Furthermore it could be argued that link count belongs to file's metadata and thus IN_ATTRIB should be sent when it changes. The following patch implements sending of IN_ATTRIB inotify events when link count of the inode changes, i.e., when a hardlink to the inode is created or when it is removed. This event is sent in addition to all the events sent so far. In particular, when a last link to a file is removed, IN_ATTRIB event is sent in addition to IN_DELETE_SELF event. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Morten Welinder <mwelinder@gmail.com> Cc: Robert Love <rlove@google.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Steven French <sfrench@us.ibm.com> Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fs: use list_for_each_entry_reverse and kill sb_entryAkinobu Mita
Use list_for_each_entry_reverse for super_blocks list and remove unused sb_entry macro. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Avoid divide in IS_ALIGNHerbert Xu
I was happy to discover the brand new IS_ALIGN macro and quickly used it in my code. To my dismay I found that the generated code used division to perform the test. This patch fixes it by changing the % test to an &. This avoids the division. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06PERCPU : __percpu_alloc_mask() can dynamically size percpu_data storageEric Dumazet
Instead of allocating a fix sized array of NR_CPUS pointers for percpu_data, we can use nr_cpu_ids, which is generally < NR_CPUS. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
