path: root/include
2011-05-25lockdep, mutex: provide mutex_lock_nest_lockPeter Zijlstra
In order to convert i_mmap_lock to a mutex we need a mutex equivalent to spin_lock_nest_lock(), thus provide the mutex_lock_nest_lock() annotation. As with spin_lock_nest_lock(), mutex_lock_nest_lock() allows annotation of the locking pattern where an outer lock serializes the acquisition order of nested locks. That is, if every time you lock multiple locks A, say A1 and A2 you first acquire N, the order of acquiring A1 and A2 is irrelevant. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: extended batches for generic mmu_gatherPeter Zijlstra
Instead of using a single batch (the small on-stack, or an allocated page), try and extend the batch every time it runs out and only flush once either the extend fails or we're done. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Requested-by: Nick Piggin <npiggin@kernel.dk> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm, powerpc: move the RCU page-table freeing into generic codePeter Zijlstra
In case other architectures require RCU freed page-tables to implement gup_fast() and software filled hashes and similar things, provide the means to do so by moving the logic into generic code. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Requested-by: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: mmu_gather reworkPeter Zijlstra
Rework the existing mmu_gather infrastructure. The direct purpose of these patches was to allow preemptible mmu_gather, but even without that I think these patches provide an improvement to the status quo. The first 9 patches rework the mmu_gather infrastructure. For review purpose I've split them into generic and per-arch patches with the last of those a generic cleanup. The next patch provides generic RCU page-table freeing, and the followup is a patch converting s390 to use this. I've also got 4 patches from DaveM lined up (not included in this series) that uses this to implement gup_fast() for sparc64. Then there is one patch that extends the generic mmu_gather batching. After that follow the mm preemptibility patches, these make part of the mm a lot more preemptible. It converts i_mmap_lock and anon_vma->lock to mutexes which together with the mmu_gather rework makes mmu_gather preemptible as well. Making i_mmap_lock a mutex also enables a clean-up of the truncate code. This also allows for preemptible mmu_notifiers, something that XPMEM I think wants. Furthermore, it removes the new and universially detested unmap_mutex. This patch: Remove the first obstacle towards a fully preemptible mmu_gather. The current scheme assumes mmu_gather is always done with preemption disabled and uses per-cpu storage for the page batches. Change this to try and allocate a page for batching and in case of failure, use a small on-stack array to make some progress. Preemptible mmu_gather is desired in general and usable once i_mmap_lock becomes a mutex. Doing it before the mutex conversion saves us from having to rework the code by moving the mmu_gather bits inside the pte_lock. Also avoid flushing the tlb batches from under the pte lock, this is useful even without the i_mmap_lock conversion as it significantly reduces pte lock hold times. [akpm@linux-foundation.org: fix comment tpyo] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: make expand_downwards() symmetrical with expand_upwards()Michal Hocko
Currently we have expand_upwards exported while expand_downwards is accessible only via expand_stack or expand_stack_downwards. check_stack_guard_page is a nice example of the asymmetry. It uses expand_stack for VM_GROWSDOWN while expand_upwards is called for VM_GROWSUP case. Let's clean this up by exporting both functions and make those names consistent. Let's use expand_{upwards,downwards} because expanding doesn't always involve stack manipulation (an example is ia64_do_page_fault which uses expand_upwards for registers backing store expansion). expand_downwards has to be defined for both CONFIG_STACK_GROWS{UP,DOWN} because get_arg_page calls the downwards version in the early process initialization phase for growsup configuration. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Hugh Dickins <hughd@google.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25include/linux/gfp.h: convert BUG_ON() into VM_BUG_ON()Dave Hansen
VM_BUG_ON() if effectively a BUG_ON() undef #ifdef CONFIG_DEBUG_VM. That is exactly what we have here now, and two different folks have suggested doing it this way. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25include/linux/gfp.h: work around apparent sparse confusionDave Hansen
Running sparse on page_alloc.c today, it errors out: include/linux/gfp.h:254:17: error: bad constant expression include/linux/gfp.h:254:17: error: cannot size expression which is a line in gfp_zone(): BUILD_BUG_ON((GFP_ZONE_BAD >> bit) & 1); That's really unfortunate, because it ends up hiding all of the other legitimate sparse messages like this: mm/page_alloc.c:5315:59: warning: incorrect type in argument 1 (different base types) mm/page_alloc.c:5315:59: expected unsigned long [unsigned] [usertype] size mm/page_alloc.c:5315:59: got restricted gfp_t [usertype] <noident> ... Having sparse be able to catch these very oopsable bugs is a lot more important than keeping a BUILD_BUG_ON(). Kill the BUILD_BUG_ON(). Compiles on x86_64 with and without CONFIG_DEBUG_VM=y. defconfig boots fine for me. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25oom: replace PF_OOM_ORIGIN with toggling oom_score_adjDavid Rientjes
There's a kernel-wide shortage of per-process flags, so it's always helpful to trim one when possible without incurring a significant penalty. It's even more important when you're planning on adding a per- process flag yourself, which I plan to do shortly for transparent hugepages. PF_OOM_ORIGIN is used by ksm and swapoff to prefer current since it has a tendency to allocate large amounts of memory and should be preferred for killing over other tasks. We'd rather immediately kill the task making the errant syscall rather than penalizing an innocent task. This patch removes PF_OOM_ORIGIN since its behavior is equivalent to setting the process's oom_score_adj to OOM_SCORE_ADJ_MAX. The process's old oom_score_adj is stored and then set to OOM_SCORE_ADJ_MAX during the time it used to have PF_OOM_ORIGIN. The old value is then reinstated when the process should no longer be considered a high priority for oom killing. Signed-off-by: David Rientjes <rientjes@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Hugh Dickins <hughd@google.com> Cc: Izik Eidus <ieidus@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm, mem-hotplug: update pcp->stat_threshold when memory hotplug occurKOSAKI Motohiro
Currently, cpu hotplug updates pcp->stat_threshold, but memory hotplug doesn't. There is no reason for this. [akpm@linux-foundation.org: fix CONFIG_SMP=n build] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm, mem-hotplug: recalculate lowmem_reserve when memory hotplug occursKOSAKI Motohiro
Currently, memory hotplug calls setup_per_zone_wmarks() and calculate_zone_inactive_ratio(), but doesn't call setup_per_zone_lowmem_reserve(). It means the number of reserved pages aren't updated even if memory hot plug occur. This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25x86,mm: make pagefault killableKOSAKI Motohiro
When an oom killing occurs, almost all processes are getting stuck at the following two points. 1) __alloc_pages_nodemask 2) __lock_page_or_retry 1) is not very problematic because TIF_MEMDIE leads to an allocation failure and getting out from page allocator. 2) is more problematic. In an OOM situation, zones typically don't have page cache at all and memory starvation might lead to greatly reduced IO performance. When a fork bomb occurs, TIF_MEMDIE tasks don't die quickly, meaning that a fork bomb may create new process quickly rather than the oom-killer killing it. Then, the system may become livelocked. This patch makes the pagefault interruptible by SIGKILL. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: introduce wait_on_page_locked_killable()KOSAKI Motohiro
commit 2687a356 ("Add lock_page_killable") introduced killable lock_page(). Similarly this patch introdues killable wait_on_page_locked(). Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: per-node vmstat: show proper vmstatsKOSAKI Motohiro
commit 2ac390370a ("writeback: add /sys/devices/system/node/<node>/vmstat") added vmstat entry. But strangely it only show nr_written and nr_dirtied. # cat /sys/devices/system/node/node20/vmstat nr_written 0 nr_dirtied 0 Of course, It's not adequate. With this patch, the vmstat show all vm stastics as /proc/vmstat. # cat /sys/devices/system/node/node0/vmstat nr_free_pages 899224 nr_inactive_anon 201 nr_active_anon 17380 nr_inactive_file 31572 nr_active_file 28277 nr_unevictable 0 nr_mlock 0 nr_anon_pages 17321 nr_mapped 8640 nr_file_pages 60107 nr_dirty 33 nr_writeback 0 nr_slab_reclaimable 6850 nr_slab_unreclaimable 7604 nr_page_table_pages 3105 nr_kernel_stack 175 nr_unstable 0 nr_bounce 0 nr_vmscan_write 0 nr_writeback_temp 0 nr_isolated_anon 0 nr_isolated_file 0 nr_shmem 260 nr_dirtied 1050 nr_written 938 numa_hit 962872 numa_miss 0 numa_foreign 0 numa_interleave 8617 numa_local 962872 numa_other 0 nr_anon_transparent_hugepages 0 [akpm@linux-foundation.org: no externs in .c files] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Michael Rubin <mrubin@google.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25arch, mm: filter disallowed nodes from arch specific show_mem functionsDavid Rientjes
Architectures that implement their own show_mem() function did not pass the filter argument to show_free_areas() to appropriately avoid emitting the state of nodes that are disallowed in the current context. This patch now passes the filter argument to show_free_areas() so those nodes are now avoided. This patch also removes the show_free_areas() wrapper around __show_free_areas() and converts existing callers to pass an empty filter. ia64 emits additional information for each node, so skip_free_areas_zone() must be made global to filter disallowed nodes and it is converted to use a nid argument rather than a zone for this use case. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: James Bottomley <jejb@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge branch 'for-linus/2640/i2c' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/2640/i2c' of git://git.fluff.org/bjdooks/linux: (21 commits) mach-ux500: set proper I2C platform data from MOP500s i2c-nomadik: break out single messsage transmission i2c-nomadik: reset the hw after status check i2c-nomadik: remove the unnecessary delay i2c-nomadik: change the TX and RX threshold i2c-nomadik: add code to retry on timeout failure i2c-nomadik: use pm_runtime API i2c-nomadik: print abort cause only on abort tag i2c-nomadik: correct adapter timeout initialization i2c-nomadik: remove the redundant error message i2c-nomadik: corrrect returned error numbers i2c-nomadik: fix speed enumerator i2c-nomadik: make i2c timeout specific per i2c bus i2c-nomadik: add regulator support i2c: i2c-sh_mobile bus speed platform data V2 i2c: i2c-sh_mobile clock string removal i2c-eg20t: Support new device ML7223 IOH i2c: tegra: Add de-bounce cycles. i2c: tegra: fix repeated start handling i2c: tegra: recover from spurious interrupt storm ...
2011-05-25Merge branches 'for-2639/i2c-eg20t', 'for-2639/i2c-shmobile', ↵Ben Dooks
'for-2639/i2c-tegra' and 'for-2639/i2c-nomadik2' into for-linus/2640/i2c
2011-05-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm: dlm: make plock operation killable dlm: remove shared message stub for recovery dlm: delayed reply message warning dlm: Remove superfluous call to recalc_sigpending()
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (43 commits) TOMOYO: Fix wrong domainname validation. SELINUX: add /sys/fs/selinux mount point to put selinuxfs CRED: Fix load_flat_shared_library() to initialise bprm correctly SELinux: introduce path_has_perm flex_array: allow 0 length elements flex_arrays: allow zero length flex arrays flex_array: flex_array_prealloc takes a number of elements, not an end SELinux: pass last path component in may_create SELinux: put name based create rules in a hashtable SELinux: generic hashtab entry counter SELinux: calculate and print hashtab stats with a generic function SELinux: skip filename trans rules if ttype does not match parent dir SELinux: rename filename_compute_type argument to *type instead of *con SELinux: fix comment to state filename_compute_type takes an objname not a qstr SMACK: smack_file_lock can use the struct path LSM: separate LSM_AUDIT_DATA_DENTRY from LSM_AUDIT_DATA_PATH LSM: split LSM_AUDIT_DATA_FS into _PATH and _INODE SELINUX: Make selinux cache VFS RCU walks safe SECURITY: Move exec_permission RCU checks into security modules SELinux: security_read_policy should take a size_t not ssize_t ...
2011-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: Make struct pcmcia_device_id const, sound drivers edition staging: pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Make declaration and uses of struct pcmcia_device_id const pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
2011-05-24Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (169 commits) drivers/gpu/drm/radeon/atom.c: fix warning drm/radeon/kms: bump kms version number drm/radeon/kms: properly set num banks for fusion asics drm/radeon/kms/atom: move dig phy init out of modesetting drm/radeon/kms/cayman: fix typo in register mask drm/radeon/kms: fix typo in spread spectrum code drm/radeon/kms: fix tile_config value reported to userspace on cayman. drm/radeon/kms: fix incorrect comparison in cayman setup code. drm/radeon/kms: add wait idle ioctl for eg->cayman drm/radeon/cayman: setup hdp to invalidate and flush when asked drm/radeon/evergreen/btc/fusion: setup hdp to invalidate and flush when asked agp/uninorth: Fix lockups with radeon KMS and >1x. drm/radeon/kms: the SS_Id field in the LCD table if for LVDS only drm/radeon/kms: properly set the CLK_REF bit for DCE3 devices drm/radeon/kms: fixup eDP connector handling drm/radeon/kms: bail early for eDP in hotplug callback drm/radeon/kms: simplify hotplug handler logic drm/radeon/kms: rewrite DP handling drm/radeon/kms/atom: add support for setting DP panel mode drm/radeon/kms: atombios.h updates for DP panel mode ...
2011-05-24Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (29 commits) [S390] cpu hotplug: fix external interrupt subclass mask handling [S390] oprofile: dont access lowcore [S390] oprofile: add missing irq stats counter [S390] Ignore sendmmsg system call note wired up warning [S390] s390,oprofile: fix compile error for !CONFIG_SMP [S390] s390,oprofile: fix alert counter increment [S390] Remove unused includes in process.c [S390] get CPC image name [S390] sclp: event buffer dissection [S390] chsc: process channel-path-availability information [S390] refactor page table functions for better pgste support [S390] merge page_test_dirty and page_clear_dirty [S390] qdio: prevent compile warning [S390] sclp: remove unnecessary sendmask check [S390] convert old cpumask API into new one [S390] pfault: cleanup code [S390] pfault: cpu hotplug vs missing completion interrupts [S390] smp: add __noreturn attribute to cpu_die() [S390] percpu: implement arch specific irqsafe_cpu_ops [S390] vdso: disable gcov profiling ...
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) Input: ADP5589 - new driver for I2C Keypad Decoder and I/O Expander Input: tsc2007 - add X, Y and Z fuzz factors to platform data Input: tsc2007 - add poll_period parameter to platform data Input: tsc2007 - add poll_delay parameter to platform data Input: tsc2007 - add max_rt parameter to platform data Input: tsc2007 - debounce pressure measurement Input: ad714x - fix captouch wheel option algorithm Input: ad714x - allow platform code to specify irqflags Input: ad714x - fix threshold and completion interrupt masks Input: ad714x - fix up input configuration Input: elantech - remove support for proprietary X driver Input: elantech - report multitouch with proper ABS_MT messages Input: elantech - export pressure and width when supported Input: elantech - describe further the protocol Input: atmel_tsadcc - correct call to input_free_device Input: add driver FSL MPR121 capacitive touch sensor Input: remove useless synchronize_rcu() calls Input: ads7846 - fix gpio_pendown configuration Input: ads7846 - add possibility to use external vref on ads7846 Input: rotary-encoder - add support for half-period encoders ...
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
2011-05-24Merge branch 'linux-next' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubi-2.6: UBI: switch to dynamic printks UBI: turn some macros into static inline UBI: improve checking in debugging prints UBI: fix typo in a message UBI: fix minor stylistic issues UBI: use __packed instead of __attribute__((packed)) UBI: cleanup comments around volume properties UBI: re-name set volume properties ioctl UBI: make the control character device non-seekable
2011-05-24Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into ↵James Morris
for-linus Conflicts: lib/flex_array.c security/selinux/avc.c security/selinux/hooks.c security/selinux/ss/policydb.c security/smack/smack_lsm.c Manually resolve conflicts. Signed-off-by: James Morris <jmorris@namei.org>
2011-05-24Merge branch 'next' into for-linusJames Morris
2011-05-24x86: Get rid of asmregparmRichard Weinberger
As UML does no longer need asmregparm we can remove it. Signed-off-by: Richard Weinberger <richard@nod.at> Cc: namhyung@gmail.com Cc: davem@davemloft.net Cc: fweisbec@gmail.com Cc: dhowells@redhat.com Link: http://lkml.kernel.org/r/%3C1306189085-29896-1-git-send-email-richard%40nod.at%3E Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-24Merge branch 'fixes-2.6.39' into for-2.6.40Tejun Heo
2011-05-24Merge branch 'next' into for-linusDmitry Torokhov
2011-05-23Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (247 commits) [media] gspca - sunplus: Fix some warnings and simplify code [media] gspca: Fix some warnings tied to 'no debug' [media] gspca: Unset debug by default [media] gspca - cpia1: Remove a bad conditional compilation instruction [media] gspca - main: Remove USB traces [media] gspca - main: Version change to 2.13 [media] gspca - stk014 / t613: Accept the index 0 in querymenu [media] gspca - kinect: Remove __devinitdata [media] gspca - cpia1: Fix some warnings [media] video/Kconfig: Fix mis-classified devices [media] support for medion dvb stick 1660:1921 [media] tm6000: fix uninitialized field, change prink to dprintk [media] cx231xx: Add support for Iconbit U100 [media] saa7134 add new TV cards [media] Use a more consistent value for RC repeat period [media] cx18: Move spinlock and vb_type initialisation into stream_init [media] tm6000: remove tm6010 sif audio start and stop [media] tm6000: remove unused exports [media] tm6000: add pts logging [media] tm6000: change from ioctl to unlocked_ioctl ...
2011-05-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) PCI: Don't use dmi_name_in_vendors in quirk PCI: remove unused AER functions PCI/sysfs: move bus cpuaffinity to class dev_attrs PCI: add rescan to /sys/.../pci_bus/.../ PCI: update bridge resources to get more big ranges when allocating space (again) KVM: Use pci_store/load_saved_state() around VM device usage PCI: Add interfaces to store and load the device saved state PCI: Track the size of each saved capability data area PCI/e1000e: Add and use pci_disable_link_state_locked() x86/PCI: derive pcibios_last_bus from ACPI MCFG PCI: add latency tolerance reporting enable/disable support PCI: add OBFF enable/disable support PCI: add ID-based ordering enable/disable support PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot. PCI: Set PCIE maxpayload for card during hotplug insertion PCI/ACPI: Report _OSC control mask returned on failure to get control x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs PCI: handle positive error codes PCI: check pci_vpd_pci22_wait() return PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio ... Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461 moved the intel SMBUS ID definitons to the i2c-i801.c driver.
2011-05-23Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (137 commits) ARM: bcmring: convert to use sp804 clockevents ARM: bcmring: convert to sp804 clocksource ARM: 6912/1: bcmring: Add clkdev table in init_early clockevents: ARM sp804: obtain sp804 timer rate via clks clockevents: ARM sp804: allow clockevent name to be specified clocksource: ARM sp804: obtain sp804 timer rate via clks clocksource: ARM sp804: allow clocksource name to be specified clocksource: convert OMAP1 to 32-bit down counting clocksource clocksource: convert MXS timrotv2 to 32-bit down counting clocksource clocksource: convert SPEAr platforms 16-bit up counting clocksource clocksource: convert Integrator/AP 16-bit down counting clocksource clocksource: convert W90x900 24-bit down counting clocksource clocksource: convert ARM 32-bit down counting clocksources clocksource: convert ARM 32-bit up counting clocksources clocksource: add common mmio clocksource ARM: update sa1100 to reflect PXA updates ARM: omap1: convert to using readl/writel instead of volatile struct ARM: omap1: delete useless interrupt handler ARM: s5p: consolidate selection of timer register ARM: 6939/1: fix missing 'cpu_relax()' declaration ...
2011-05-23Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Increase SCHED_LOAD_SCALE resolution sched: Introduce SCHED_POWER_SCALE to scale cpu_power calculations sched: Cleanup set_load_weight()
2011-05-23Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits) USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h USB: UHCI: Support big endian GRUSBHC HC sparc: add {read,write}*_be routines USB: UHCI: Add support for big endian descriptors USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier USB: UHCI: Add support for big endian mmio usb-storage: Correct adjust_quirks to include latest flags usb/isp1760: Fix possible unlink problems usb/isp1760: Move function isp1760_endpoint_disable() within file. USB: remove remaining usages of hcd->state from usbcore and fix regression usb: musb: ux500: add configuration and build options for ux500 dma usb: musb: ux500: add dma glue layer for ux500 usb: musb: ux500: add dma name for ux500 usb: musb: ux500: add ux500 specific code for gadget side usb: musb: fix compile error usb-storage: fix up the unusual_realtek device list USB: gadget: f_audio: Fix invalid dereference of initdata EHCI: don't rescan interrupt QHs needlessly OHCI: fix regression caused by nVidia shutdown workaround USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage ...
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-23Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimers: Reorder clock bases hrtimers: Avoid touching inactive timer bases hrtimers: Make struct hrtimer_cpu_base layout less stupid timerfd: Manage cancelable timers in timerfd clockevents: Move C3 stop test outside lock alarmtimer: Drop device refcount after rtc_open() alarmtimer: Check return value of class_find_device() timerfd: Allow timers to be cancelled when clock was set hrtimers: Prepare for cancel on clock was set timers
2011-05-23Merge branches 'consolidate', 'ep93xx', 'fixes', 'misc', 'mmci', 'remove' ↵Russell King
and 'spear' into for-linus
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slub: Deal with hyperthetical case of PAGE_SIZE > 2M slub: Remove node check in slab_free slub: avoid label inside conditional slub: Make CONFIG_DEBUG_PAGE_ALLOC work with new fastpath slub: Avoid warning for !CONFIG_SLUB_DEBUG slub: Remove CONFIG_CMPXCHG_LOCAL ifdeffery slub: Move debug handlign in __slab_free slub: Move node determination out of hotpath slub: Eliminate repeated use of c->page through a new page variable slub: get_map() function to establish map of free objects in a slab slub: Use NUMA_NO_NODE in get_partial slub: Fix a typo in config name
2011-05-23Merge branches 'consolidate-clksrc', 'consolidate-flash', ↵Russell King
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
2011-05-23clocksource: add common mmio clocksourceRussell King
Add a generic mmio clocksource, covering both 32-bit and 16-bit register access sizes, for up or down counters. This can be used to easily create clocksources for simple counter-based implementations. Cc: Alessandro Rubini <rubini@unipv.it> Cc: Colin Cross <ccross@android.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Erik Gilling <konkers@android.com> Acked-by: "Hans J. Koch" <hjk@hansjkoch.de> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: linux-omap@vger.kernel.org Acked-by: Nicolas Pitre <nico@fluxnic.net> Cc: Olof Johansson <olof@lixom.net> Tested-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Viresh Kumar <viresh.kumar@st.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23Merge branch 'slab/next' into for-linusPekka Enberg
Conflicts: mm/slub.c
2011-05-23Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: hwmon: (coretemp) Fix checkpatch errors hwmon: Remove pkgtemp driver hwmon: (coretemp) Merge pkgtemp with coretemp hwmon: (pmbus) Add support for Analog Devices ADM1275 hwmon: (pmbus) Support for TI UCD90xxx series Sequencer and System Health Controllers hwmon: (pmbus) Add support for TI UCD9200 series of PWM System Controllers hwmon: (pmbus) Use device specific function to read fan configuration hwmon: (pmbus) Expand scope of device specific get_status function hwmon: (pmbus) Introduce infrastructure to detect sensors and limit registers hwmon: Driver for MAX16065 System Manager and compatibles hwmon: (sht15) add support for CRC validation hwmon: (sht15) add support for the status register hwmon: (sht15) clean-up the probe function hwmon: (sht15) general code clean-up hwmon: Add support for MAX6642
2011-05-23Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf tools: Fix sample size bit operations perf tools: Fix ommitted mmap data update on remap watchdog: Change the default timeout and configure nmi watchdog period based on watchdog_thresh watchdog: Disable watchdog when thresh is zero watchdog: Only disable/enable watchdog if neccessary watchdog: Fix rounding bug in get_sample_period() perf tools: Propagate event parse error handling perf tools: Robustify dynamic sample content fetch perf tools: Pre-check sample size before parsing perf tools: Move evlist sample helpers to evlist area perf tools: Remove junk code in mmap size handling perf tools: Check we are able to read the event size on mmap
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (346 commits) ASoC: core: Don't set "(null)" as a driver name ALSA: hda - Use LPIB for ATI/AMD chipsets as default Revert "ALSA: hda - Use position_fix=3 as default for AMD chipsets" ASoC: Tegra: Fix compile when debugfs not enabled ASoC: spdif-dit: Add missing MODULE_* SOUND: OSS: Remove Au1550 driver. ALSA: hda - add Intel Panther Point HDMI codec id ALSA: emu10k1 - Add dB range to Bass and Treble for SB Live! ALSA: hda - Remove PCM mixer elements from Virtual Master of realtek ALSA: hda - Fix input-src parse in patch_analog.c ASoC: davinci-mcasp: enable ping-pong SRAM buffers ASoC: add iPAQ hx4700 machine driver ASoC: Asahi Kasei AK4641 codec driver ALSA: hda - Enable Realtek ALC269 codec input layer beep ALSA: intel8x0m: enable AMD8111 modem ALSA: HDA: Add jack detection for HDMI ALSA: sound, core, pcm_lib: fix xrun_log ASoC: Max98095: Move existing NULL check before pointer dereference. ALSA: sound, core, pcm_lib: xrun_log: log also in_interrupt ALSA: usb-audio - Add support for USB X-Fi S51 Pro ...
2011-05-23dlm: make plock operation killableDavid Teigland
Allow processes blocked on plock requests to be interrupted when they are killed. This leaves the problem of cleaning up the lock state in userspace. This has three parts: 1. Add a flag to unlock operations sent to userspace indicating the file is being closed. Userspace will then look for and clear any waiting plock operations that were abandoned by an interrupted process. 2. Queue an unlock-close operation (like in 1) to clean up userspace from an interrupted plock request. This is needed because the vfs will not send a cleanup-unlock if it sees no locks on the file, which it won't if the interrupted operation was the only one. 3. Do not use replies from userspace for unlock-close operations because they are unnecessary (they are just cleaning up for the process which did not make an unlock call). This also simplifies the new unlock-close generated from point 2. Signed-off-by: David Teigland <teigland@redhat.com>
2011-05-23Merge branch 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (131 commits) KVM: MMU: Use ptep_user for cmpxchg_gpte() KVM: Fix kvm mmu_notifier initialization order KVM: Add documentation for KVM_CAP_NR_VCPUS KVM: make guest mode entry to be rcu quiescent state KVM: x86 emulator: Make jmp far emulation into a separate function KVM: x86 emulator: Rename emulate_grpX() to em_grpX() KVM: x86 emulator: Remove unused arg from emulate_pop() KVM: x86 emulator: Remove unused arg from writeback() KVM: x86 emulator: Remove unused arg from read_descriptor() KVM: x86 emulator: Remove unused arg from seg_override() KVM: Validate userspace_addr of memslot when registered KVM: MMU: Clean up gpte reading with copy_from_user() KVM: PPC: booke: add sregs support KVM: PPC: booke: save/restore VRSAVE (a.k.a. USPRG0) KVM: PPC: use ticks, not usecs, for exit timing KVM: PPC: fix exit accounting for SPRs, tlbwe, tlbsx KVM: PPC: e500: emulate SVR KVM: VMX: Cache vmcs segment fields KVM: x86 emulator: consolidate segment accessors KVM: VMX: Avoid reading %rip unnecessarily when handling exceptions ...
2011-05-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) bnx2x: allow device properly initialize after hotplug bnx2x: fix DMAE timeout according to hw specifications bnx2x: properly handle CFC DEL in cnic flow bnx2x: call dev_kfree_skb_any instead of dev_kfree_skb net: filter: move forward declarations to avoid compile warnings pktgen: refactor pg_init() code pktgen: use vzalloc_node() instead of vmalloc_node() + memset() net: skb_trim explicitely check the linearity instead of data_len ipv4: Give backtrace in ip_rt_bug(). net: avoid synchronize_rcu() in dev_deactivate_many net: remove synchronize_net() from netdev_set_master() rtnetlink: ignore NETDEV_RELEASE and NETDEV_JOIN event net: rename NETDEV_BONDING_DESLAVE to NETDEV_RELEASE bridge: call NETDEV_JOIN notifiers when add a slave netpoll: disable netpoll when enslave a device macvlan: Forward unicast frames in bridge mode to lowerdev net: Remove linux/prefetch.h include from linux/skbuff.h ipv4: Include linux/prefetch.h in fib_trie.c netlabel: Remove prefetches from list handlers. drivers/net: add prefetch header for prefetch users ... Fixed up prefetch parts: removed a few duplicate prefetch.h includes, fixed the location of the igb prefetch.h, took my version of the skbuff.h code without the extra parentheses etc.
2011-05-23Merge branch 'exec_rm_compat' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc * 'exec_rm_compat' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: exec: document acct_arg_size() exec: unify do_execve/compat_do_execve code exec: introduce struct user_arg_ptr exec: introduce get_user_arg_ptr() helper
2011-05-23hrtimers: Reorder clock basesThomas Gleixner
The ordering of the clock bases is historical due to the CLOCK_REALTIME and CLOCK_MONOTONIC constants. Now the hrtimer bases have their own enumeration due to the gap between CLOCK_MONOTONIC and CLOCK_BOOTTIME. So we can be more clever as most timers end up on the CLOCK_MONOTONIC base due to the virtue of POSIX declaring that relative CLOCK_REALTIME timers are not affected by time changes. In desktop environments this is slowly changing as applications switch to absolute timers, but I've observed empty CLOCK_REALTIME bases often enough. There is no performance penalty or overhead when CLOCK_REALTIME timers are active, but in case they are not we don't skip over a full cache line. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Peter Zijlstra <peterz@infradead.org>
