path: root/include
2008-06-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: update my email address parisc: fix miscompilation of ip_fast_csum with gcc >= 4.3 parisc: fix off by one in setup_sigcontext32 parisc: export empty_zero_page parisc: export copy_user_page_asm parisc: move head.S to head.text section Revert "parisc: fix trivial section name warnings"
2008-06-13parisc: fix miscompilation of ip_fast_csum with gcc >= 4.3Kyle McMartin
ip_fast_csum needs an asm "memory" clobber, otherwise the aggressive optimizations in gcc-4.3 cause it to be miscompiled. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: tcp: Revert 'process defer accept as established' changes. ipv6: Fix duplicate initialization of rawv6_prot.destroy bnx2x: Updating the Maintainer net: Eliminate flush_scheduled_work() calls while RTNL is held. drivers/net/r6040.c: correct bad use of round_jiffies() fec_mpc52xx: MPC52xx_MESSAGES_DEFAULT: 2nd NETIF_MSG_IFDOWN => IFUP ipg: fix receivemode IPG_RM_RECEIVEMULTICAST{,HASH} in ipg_nic_set_multicast_list() netfilter: nf_conntrack: fix ctnetlink related crash in nf_nat_setup_info() netfilter: Make nflog quiet when no one listen in userspace. ipv6: Fail with appropriate error code when setting not-applicable sockopt. ipv6: Check IPV6_MULTICAST_LOOP option value. ipv6: Check the hop limit setting in ancillary data. ipv6 route: Fix route lifetime in netlink message. ipv6 mcast: Check address family of gf_group in getsockopt(MS_FILTER). dccp: Bug in initial acknowledgment number assignment dccp ccid-3: X truncated due to type conversion dccp ccid-3: TFRC reverse-lookup Bug-Fix dccp ccid-2: Bug-Fix - Ack Vectors need to be ignored on request sockets dccp: Fix sparse warnings dccp ccid-3: Bug-Fix - Zero RTT is possible
2008-06-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 5091/1: Add missing bitfield include to regs-lcd.h [ARM] 5090/1: Correct pxafb palette typo error [ARM] 5077/1: spi: fix list scan success verification in PXA ssp driver
2008-06-12pagemap: pass mm into pagewalkersDave Hansen
We need this at least for huge page detection for now, because powerpc needs the vm_area_struct to be able to determine whether a virtual address is referring to a huge page (its pmd_huge() doesn't work). It might also come in handy for some of the other users. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12cciss: add new hardware supportMike Miller
Add support for the next generation of HP Smart Array SAS/SATA controllers. Shipping date is late Fall 2008. Bump the driver version to 3.6.20 to reflect the new hardware support from patch 1 of this set. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12proc_fs.h: move struct mm_struct forward-declarationBen Nizette
Move the forward-declaration of struct mm_struct a little way up proc_fs.h. This fixes a bunch of "'struct mm_struct' declared inside parameter list" warnings with CONFIG_PROC_FS=n Signed-off-by: Ben Nizette <bn@niasdigital.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12m68k: Add ext2_find_{first,next}_bit() for ext4Aneesh Kumar K.V
Add ext2_find_{first,next}_bit(), which are needed for ext4. They're derived out of the ext2_find_next_zero_bit found in the same file. Compile tested with crosstools [Reworked to preserve all symmetry with ext2_find_{first,next}_zero_bit()] This fixes http://bugzilla.kernel.org/show_bug.cgi?id=10393 [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12tcp: Revert 'process defer accept as established' changes.David S. Miller
This reverts two changesets, ec3c0982a2dd1e671bad8e9d26c28dcba0039d87 ("[TCP]: TCP_DEFER_ACCEPT updates - process as established") and the follow-on bug fix 9ae27e0adbf471c7a6b80102e38e1d5a346b3b38 ("tcp: Fix slab corruption with ipv6 and tcp6fuzz"). This change causes several problems, first reported by Ingo Molnar as a distcc-over-loopback regression where connections were getting stuck. Ilpo Järvinen first spotted the locking problems. The new function added by this code, tcp_defer_accept_check(), only has the child socket locked, yet it is modifying state of the parent listening socket. Fixing that is non-trivial at best, because we can't simply just grab the parent listening socket lock at this point, because it would create an ABBA deadlock. The normal ordering is parent listening socket --> child socket, but this code path would require the reverse lock ordering. Next is a problem noticed by Vitaliy Gusev, he noted: ---------------------------------------- >--- a/net/ipv4/tcp_timer.c >+++ b/net/ipv4/tcp_timer.c >@@ -481,6 +481,11 @@ static void tcp_keepalive_timer (unsigned long data) > goto death; > } > >+ if (tp->defer_tcp_accept.request && sk->sk_state == TCP_ESTABLISHED) { >+ tcp_send_active_reset(sk, GFP_ATOMIC); >+ goto death; Here socket sk is not attached to listening socket's request queue. tcp_done() will not call inet_csk_destroy_sock() (and tcp_v4_destroy_sock() which should release this sk) as socket is not DEAD. Therefore socket sk will be lost for freeing. ---------------------------------------- Finally, Alexey Kuznetsov argues that there might not even be any real value or advantage to these new semantics even if we fix all of the bugs: ---------------------------------------- Hiding from accept() sockets with only out-of-order data only is the only thing which is impossible with old approach. Is this really so valuable? My opinion: no, this is nothing but a new loophole to consume memory without control. ---------------------------------------- So revert this thing for now. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-12Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: 64-bit: fix arithmetics overflow sched: fair group: fix overflow(was: fix divide by zero) sched: fix TASK_WAKEKILL vs SIGKILL race
2008-06-12[ARM] 5091/1: Add missing bitfield include to regs-lcd.hStefan Schmidt
Macros like Fld() or FShft used in regs-lcd.h are defined in bitfield.h, but the latter is not included. Also fix one whitespace issue while being there. Signed-off-by: Antonio Ospite <ao2@openezx.org> Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-12Merge branch 'core/iter-div' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/iter-div' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: always_inline timespec_add_ns add an inlined version of iter_div_u64_rem common implementation of iterative div/mod
2008-06-12always_inline timespec_add_nstip-core-iter-div-2008-06-16_09.11_MonJeremy Fitzhardinge
timespec_add_ns is used from the x86-64 vdso, which cannot call out to other kernel code. Make sure that timespec_add_ns is always inlined (and only uses always_inlined functions) to make sure there are no unexpected calls. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12add an inlined version of iter_div_u64_remJeremy Fitzhardinge
iter_div_u64_rem is used in the x86-64 vdso, which cannot call other kernel code. For this case, provide the always_inlined version, __iter_div_u64_rem. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12common implementation of iterative div/modJeremy Fitzhardinge
We have a few instances of the open-coded iterative div/mod loop, used when we don't expcet the dividend to be much bigger than the divisor. Unfortunately modern gcc's have the tendency to strength "reduce" this into a full mod operation, which isn't necessarily any faster, and even if it were, doesn't exist if gcc implements it in libgcc. The workaround is to put a dummy asm statement in the loop to prevent gcc from performing the transformation. This patch creates a single implementation of this loop, and uses it to replace the open-coded versions I know about. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Segher Boessenkool <segher@kernel.crashing.org> Cc: Christian Kujau <lists@nerdbynature.de> Cc: Robert Hancock <hancockr@shaw.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-11Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (23 commits) ACPICA: fix stray va_end() caused by mis-merge ACPI: Reject below-freezing temperatures as invalid critical temperatures ACPICA: Fix for access to deleted object <regression> ACPICA: Fix to make _SST method optional ACPICA: Fix for Load operator, load table at the namespace root ACPICA: Ignore ACPI table signature for Load() operator ACPICA: Fix to allow zero-length ASL field declarations ACPI: use memory_read_from_buffer() bay: exit if notify handler cannot be installed dock.c remove trailing printk whitespace proper prototype for acpi_processor_tstate_has_changed() ACPI: handle invalid ACPI SLIT table PNPACPI: use _CRS IRQ descriptor length for _SRS pnpacpi: fix shareable IRQ encode/decode pnpacpi: fix IRQ flag decoding MAINTAINERS: update ACPI homepage ACPI 2.6.26-rc2: Add missing newline to DSDT/SSDT warning message ACPI: EC: Use msleep instead of udelay while waiting for event. thinkpad-acpi: fix LED handling on older ThinkPads thinkpad-acpi: fix initialization error paths ...
2008-06-11proper prototype for acpi_processor_tstate_has_changed()Adrian Bunk
This patch adds a proper prototype for acpi_processor_tstate_has_changed() in include/acpi/processor.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-06-11pnpacpi: fix IRQ flag decodingBjorn Helgaas
When decoding IRQ trigger mode and polarity, it is not enough to mask by IORESOURCE_BITS because there are now additional bits defined. For example, if IORESOURCE_IRQ_SHAREABLE was set, we failed to set *triggering and *polarity at all. I can't point to a failure that this patch fixes, but bugs in this area have caused problems when resuming after suspend, for example: http://bugzilla.kernel.org/show_bug.cgi?id=6316 http://bugzilla.kernel.org/show_bug.cgi?id=9487 https://bugs.launchpad.net/ubuntu/+source/linux-source-2.6.22/+bug/152187 This is based on a patch by Tom Jaeger: http://bugzilla.kernel.org/show_bug.cgi?id=9487#c32 [rene.herman@keyaccess.nl: fix comment] Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-06-11cpuidle acpi driver: fix oops on AC<->DCVenkatesh Pallipadi
cpuidle and acpi driver interaction bug with the way cpuidle_register_driver() is called. Due to this bug, there will be oops on AC<->DC on some systems, where they support C-states in one DC and not in AC. The current code does ON BOOT: Look at CST and other C-state info to see whether more than C1 is supported. If it is, then acpi processor_idle does a cpuidle_register_driver() call, which internally enables the device. ON CST change notification (AC<->DC) and on suspend-resume: acpi driver temporarily disables device, updates the device with any new C-states, and reenables the device. The problem is is on boot, there are no C2, C3 states supported and we skip the register. Later on AC<->DC, we may get a CST notification and we try to reevaluate CST and enabled the device, without actually registering it. This causes breakage as we try to create /sys fs sub directory, without the parent directory which is created at register time. Thanks to Sanjeev for reporting the problem here. http://bugzilla.kernel.org/show_bug.cgi?id=10394 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-06-11Merge branch 'kvm-updates-2.6.26' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'kvm-updates-2.6.26' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: KVM: MMU: Fix is_empty_shadow_page() check KVM: MMU: Fix printk() format string KVM: IOAPIC: only set remote_irr if interrupt was injected KVM: MMU: reschedule during shadow teardown KVM: VMX: Clear CR4.VMXE in hardware_disable KVM: migrate PIT timer KVM: ppc: Report bad GFNs KVM: ppc: Use a read lock around MMU operations, and release it on error KVM: ppc: Remove unmatched kunmap() call KVM: ppc: add lwzx/stwz emulation KVM: ppc: Remove duplicate function KVM: s390: Fix race condition in kvm_s390_handle_wait KVM: s390: Send program check on access error KVM: s390: fix interrupt delivery KVM: s390: handle machine checks when guest is running KVM: s390: fix locking order problem in enable_sie KVM: s390: use yield instead of schedule to implement diag 0x44 KVM: x86 emulator: fix hypercall return value on AMD KVM: ia64: fix zero extending for mmio ld1/2/4 emulation in KVM
2008-06-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) net: Fix routing tables with id > 255 for legacy software sky2: Hold RTNL while calling dev_close() s2io iomem annotations atl1: fix suspend regression qeth: start dev queue after tx drop error qeth: Prepare-function to call s390dbf was wrong qeth: reduce number of kernel messages qeth: Use ccw_device_get_id(). qeth: layer 3 Oops in ip event handler virtio: use callback on empty in virtio_net virtio: virtio_net free transmit skbs in a timer virtio: Fix typo in virtio_net_hdr comments virtio_net: Fix skb->csum_start computation ehea: set mac address fix sfc: Recover from RX queue flush failure add missing lance_* exports ixgbe: fix typo forcedeth: msi interrupts ipsec: pfkey should ignore events when no listeners pppoe: Unshare skb before anything else ...
2008-06-10Merge branch 'davem-fixes' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2008-06-10net: Fix routing tables with id > 255 for legacy softwareKrzysztof Piotr Oledzki
Most legacy software do not like tables > 255 as rtm_table is u8 so tb_id is sent &0xff and it is possible to mismatch for example table 510 with table 254 (main). This patch introduces RT_TABLE_COMPAT=252 so the code uses it if tb_id > 255. It makes such old applications happy, new ones are still able to use RTA_TABLE to get a proper table id. Signed-off-by: Krzysztof Piotr Oledzki <ole@ans.pl> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10virtio: Fix typo in virtio_net_hdr commentsMark McLoughlin
Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-10inet{6}_request_sock: Init ->opt and ->pktopts in the constructorArnaldo Carvalho de Melo
Wei Yongjun noticed that we may call reqsk_free on request sock objects where the opt fields may not be initialized, fix it by introducing inet_reqsk_alloc where we initialize ->opt to NULL and set ->pktopts to NULL in inet6_reqsk_alloc. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10ipv4: Remove unused declaration from include/net/tcp.h.Rami Rosen
- The tcp_unhash() method in /include/net/tcp.h is no more needed, as the unhash method in tcp_prot structure is now inet_unhash (instead of tcp_unhash in the past); see tcp_prot structure in net/ipv4/tcp_ipv4.c. - So, this patch removes tcp_unhash() declaration from include/net/tcp.h Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: fix BLK_DEV_HD_ONLY on ARM dependencies ide: export ide_doubler palm_bk3710: add warm-plug support delkin_cb: add missing __init/__exit tags delkin_cb: add warm-plug support delkin_cb: use struct ide_port_info delkin_cb: set proper hwif->gendev.parent value ide: fix host drivers missing hwif->chipset initialization ide-generic: add missing hwif->chipset setup sis5513: add missing pci_enable_device() call MAINTAINERS: remove SIS 5513 IDE entry ide: remove the ide_etrax100 chipset type
2008-06-10ide: remove the ide_etrax100 chipset typeAdrian Bunk
I forgot to remove the ide_etrax100 chipset type when removing the ETRAX_IDE driver. Reported-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-10sched: fix TASK_WAKEKILL vs SIGKILL raceOleg Nesterov
schedule() has the special "TASK_INTERRUPTIBLE && signal_pending()" case, this allows us to do current->state = TASK_INTERRUPTIBLE; schedule(); without fear to sleep with pending signal. However, the code like current->state = TASK_KILLABLE; schedule(); is not right, schedule() doesn't take TASK_WAKEKILL into account. This means that mutex_lock_killable(), wait_for_completion_killable(), down_killable(), schedule_timeout_killable() can miss SIGKILL (and btw the second SIGKILL has no effect). Introduce the new helper, signal_pending_state(), and change schedule() to use it. Hopefully it will have more users, that is why the task's state is passed separately. Note this "__TASK_STOPPED | __TASK_TRACED" check in signal_pending_state(). This is needed to preserve the current behaviour (ptrace_notify). I hope this check will be removed soon, but this (afaics good) change needs the separate discussion. The fast path is "(state & (INTERRUPTIBLE | WAKEKILL)) + signal_pending(p)", basically the same that schedule() does now. However, this patch of course bloats schedule(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-10[S390] Fix __ctl_load/__ctl_store inline assembly constraintsMartin Schwidefsky
__ctl_load/__ctl_store are called with either an array of unsigned long or a single unsigned long value. Add an address operator to the "m"/"=m" contraints to make them work for unsigned long arguments as well. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-06-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/core: Remove IB_DEVICE_SEND_W_INV capability flag IB/umem: Avoid sign problems when demoting npages to integer
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: Blackfin serial driver: fix up tty core set_ldisc API change breakage bug Blackfin arch: protect only the SPI bus controller with CONFIG_SPI_BFIN Blackfin arch: fixup warnings with the new cplb saved values Blackfin Serial Driver: Clean up BF54x macro in blackfin UART driver.
2008-06-09include/linux/ssb/ssb_driver_gige.h typo fixAdrian Bunk
This patch fixes a typo in the name of a config variable. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Reviewed-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-09Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] ehea: Remove dependency on MEMORY_HOTPLUG [POWERPC] Make walk_memory_resource available with MEMORY_HOTPLUG=n [POWERPC] Use dev_set_name in pci_64.c [POWERPC] Fix incorrect enabling of VMX when building signal or user context [POWERPC] boot/Makefile CONFIG_ variable fixes
2008-06-09mm: Minor clean-up of page flags in mm/page_alloc.cRuss Anderson
Minor source code cleanup of page flags in mm/page_alloc.c. Move the definition of the groups of bits to page-flags.h. The purpose of this clean up is that the next patch will conditionally add a page flag to the groups. Doing that in a header file is cleaner than adding #ifdefs to the C code. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-09IB/core: Remove IB_DEVICE_SEND_W_INV capability flagRoland Dreier
In 2.6.26, we added some support for send with invalidate work requests, including a device capability flag to indicate whether a device supports such requests. However, the support was incomplete: the completion structure was not extended with a field for the key contained in incoming send with invalidate requests. Full support for memory management extensions (send with invalidate, local invalidate, fast register through a send queue, etc) is planned for 2.6.27. Since send with invalidate is not very useful by itself, just remove the IB_DEVICE_SEND_W_INV bit before the 2.6.26 final release; we will add an IB_DEVICE_MEM_MGT_EXTENSIONS bit in 2.6.27, which makes things simpler for applications, since they will not have quite as confusing an array of fine-grained bits to check. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-06-09[POWERPC] Make walk_memory_resource available with MEMORY_HOTPLUG=nNathan Lynch
The ehea driver was recently changed[1] to use walk_memory_resource() to detect the system's memory layout. However, walk_memory_resource() is available only when memory hotplug is enabled. So CONFIG_EHEA was made to depend on MEMORY_HOTPLUG [2], but it is inappropriate for a network driver to have such a dependency. Make the declaration of walk_memory_resource() and its powerpc implementation (ehea is powerpc-specific) unconditionally available. [1] 48cfb14f8b89d4d5b3df6c16f08b258686fb12ad "ehea: Add DLPAR memory remove support" [2] fb7b6ca2b6b7c23b52be143bdd5f55a23b9780c8 "ehea: Add dependency to Kconfig" Signed-off-by: Nathan Lynch <ntl@pobox.com> Acked-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-08fat_valid_media() isn't for userspaceAdrian Bunk
Commit 73f20e58b1d586e9f6d3ddc3aad872829aca7743 ("FAT_VALID_MEDIA(): remove pointless test") wrongly added the new fat_valid_media() function to the userspace-visible part of include/linux/msdos_fs.h Move it to the part of include/linux/msdos_fs.h that is not exported to userspace. Reported-by: Onur Küçük <onur@pardus.org.tr> Reported-by: S.Çağlar Onur <caglar@pardus.org.tr> Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: enable barriers by default jbd2: Fix barrier fallback code to re-lock the buffer head ext4: Display the journal_async_commit mount option in /proc/mounts jbd2: If a journal checksum error is detected, propagate the error to ext4 jbd2: Fix memory leak when verifying checksums in the journal ext4: fix online resize bug ext4: Fix uninit block group initialization with FLEX_BG ext4: Fix use of uninitialized data with debug enabled.
2008-06-06uml: activate_mm: remove the dead PF_BORROWED_MM checktip-core-topology-2008-06-16_09.13_Montip-core-misc-2008-06-16_09.11_MonOleg Nesterov
use_mm() was changed to use switch_mm() instead of activate_mm(), since then nobody calls (and nobody should call) activate_mm() with PF_BORROWED_MM bit set. As Jeff Dike pointed out, we can also remove the "old != new" check, it is always true. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6: capabilities: remain source compatible with 32-bit raw legacy capability support. LSM: remove stale web site from MAINTAINERS
2008-06-06vm: add kzalloc_node() inlineJeff Layton
To get zeroed out memory from a particular NUMA node. To be used by sunrpc. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06asm-m32r/uaccess.h must #include <asm/setup.h>Adrian Bunk
This patch fixes the following compile error caused by commit 4016a1390d07f15b267eecb20e76a48fd5c524ef (mm/nommu.c: return 0 from kobjsize with invalid objects): /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c: In function 'kobjsize': /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: 'memory_end' undeclared (first use in this function) /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: (Each undeclared identifier is reported only once /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: for each function it appears in.) The patch also removes now no longer required memory_{start,end} declarations inside access_ok(). Reported-by: Adrian Bunk <adrian.bunk@movial.fi> Signed-off-by: Adrian Bunk <adrian.bunk@movial.fi> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Michael Hennerich <Michael.Hennerich@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06v850: fix typo in header guardVegard Nossum
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06h8300: fix typo in header guardVegard Nossum
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06ipc: restore MSGPOOL original valueNadia Derbey
When posting: [PATCH 1/8] Scaling msgmni to the amount of lowmem (see http://article.gmane.org/gmane.linux.kernel/637849/) I changed the MSGPOOL value to make it fit what is said in the man pages (i.e. a size in bytes). But Michael Kerrisk rightly complained that this change could affect the ABI. So I'm posting this patch to make MSGPOOL expressed back in Kbytes. Michael, on his side, has fixed the man page. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Acked-by: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06introduce memory_read_from_buffer()Akinobu Mita
This patch introduces memory_read_from_buffer(). The only difference between memory_read_from_buffer() and simple_read_from_buffer() is which address space the function copies to. simple_read_from_buffer copies to user space memory. memory_read_from_buffer copies to normal memory. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Doug Warzecha <Douglas_Warzecha@dell.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: Abhay Salunke <Abhay_Salunke@dell.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Markus Rechberger <markus.rechberger@amd.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Bob Moore <robert.moore@intel.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Len Brown <lenb@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Cc: Michael Holzheu <holzheu@de.ibm.com> Cc: Brian King <brking@us.ibm.com> Cc: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Cc: Andrew Vasquez <linux-driver@qlogic.com> Cc: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06lib: export bitrev16Harvey Harrison
Bluetooth will be able to use this. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06Fix various old email addresses for dwmw2David Woodhouse
Although if people have questions about ARCnet, perhaps it's _better_ for them to be mailing dwmw2@cam.ac.uk about it... Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06KVM: migrate PIT timerMarcelo Tosatti
Migrate the PIT timer to the physical CPU which vcpu0 is scheduled on, similarly to what is done for the LAPIC timers, otherwise PIT interrupts will be delayed until an unrelated event causes an exit. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
