IDA_BITMAP_LONGS value is calculated take into account struct ida_bitmap
not to waste memory space. Comment it.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Fix various typos of valid.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
Fix a spelling mistake.
The below updates a broken web address to one(hopefully) thats
the new correct address.
Fix kernel-doc warnings in linux/i2c.h:
Warning(include/linux/i2c.h:176): No description found for parameter 'alert'
Warning(include/linux/i2c.h:259): No description found for parameter 'of_node'
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits)
block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n
xen-blkfront: fix missing out label
blkdev: fix blkdev_issue_zeroout return value
block: update request stacking methods to support discards
block: fix missing export of blk_types.h
writeback: fix bad _bh spinlock nesting
drbd: revert "delay probes", feature is being re-implemented differently
drbd: Initialize all members of sync_conf to their defaults [Bugz 315]
drbd: Disable delay probes for the upcomming release
writeback: cleanup bdi_register
writeback: add new tracepoints
writeback: remove unnecessary init_timer call
writeback: optimize periodic bdi thread wakeups
writeback: prevent unnecessary bdi threads wakeups
writeback: move bdi threads exiting logic to the forker thread
writeback: restructure bdi forker loop a little
writeback: move last_active to bdi
writeback: do not remove bdi from bdi_list
writeback: simplify bdi code a little
writeback: do not lose wake-ups in bdi threads
Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and
drivers/scsi/scsi_error.c as per Jens.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (94 commits)
V4L/DVB: tvp7002: fix write to H-PLL Feedback Divider LSB register
V4L/DVB: dvb: siano: free spinlock before schedule()
V4L/DVB: media: video: pvrusb2: remove custom hex_to_bin()
V4L/DVB: drivers: usbvideo: remove custom implementation of hex_to_bin()
V4L/DVB: Report supported QAM modes on bt8xx
V4L/DVB: media: ir-keytable: null dereference in debug code
V4L/DVB: ivtv: convert to the new control framework
V4L/DVB: ivtv: convert gpio subdev to new control framework
V4L/DVB: wm8739: convert to the new control framework
V4L/DVB: cs53l32a: convert to new control framework
V4L/DVB: wm8775: convert to the new control framework
V4L/DVB: cx2341x: convert to the control framework
V4L/DVB: cx25840: convert to the new control framework
V4L/DVB: cx25840/ivtv: replace ugly priv control with s_config
V4L/DVB: saa717x: convert to the new control framework
V4L/DVB: msp3400: convert to the new control framework
V4L/DVB: saa7115: convert to the new control framework
V4L/DVB: v4l2: hook up the new control framework into the core framework
V4L/DVB: Documentation: add v4l2-controls.txt documenting the new controls API
V4L/DVB: v4l2-ctrls: Whitespace cleanups
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
watchdog: hpwdt: formatting of pointers in printk()
watchdog: Adding support for ARM Primecell SP805 Watchdog
watchdog: f71808e_wdt: new watchdog driver for Fintek F71808E and F71882FG
watchdog: sch311x_wdt.c: set parent before registeriing the misc device in probe() function
watchdog: wdt_pci.c: move ids to pci_ids.h
watchdog: s3c2410_wdt - Fix removing of platform device
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: xpad - add USB-ID for PL-3601 Xbox 360 pad
Input: cy8ctmg100_ts - signedness bug
Input: elantech - report position also with 3 fingers
Input: elantech - discard the first 2 positions on some firmwares
Input: adxl34x - do not mark device as disabled on startup
Input: gpio_keys - add hooks to enable/disable device
Input: evdev - rearrange ioctl handling
Input: dynamically allocate ABS information
Input: switch to input_abs_*() access functions
Input: add static inline accessors for ABS properties
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (148 commits)
USB: serial: fix stalled writes
USB: remove fake "address-of" expressions
USB: fix thread-unsafe anchor utiliy routines
USB: usbtest: support test device with only one iso-in or iso-out endpoint
USB: usbtest: avoid to free coherent buffer in atomic context
USB: xhci: Set DMA mask for host.
USB: xhci: Don't flush doorbell writes.
USB: xhci: Reduce reads and writes of interrupter registers.
USB: xhci: Make xhci_set_hc_event_deq() static.
USB: xhci: Minimize HW event ring dequeue pointer writes.
USB: xhci: Make xhci_handle_event() static.
USB: xhci: Remove unnecessary reads of IRQ_PENDING register.
USB: xhci: Performance - move xhci_work() into xhci_irq()
USB: xhci: Performance - move interrupt handlers into xhci-ring.c
USB: xhci: Performance - move functions that find ep ring.
USB:: fix linux/usb.h kernel-doc warnings
USB: add USB serial ssu100 driver
USB: usb-storage: implement autosuspend
USB: ehci: fix remove of ehci debugfs dir
USB: Add USB 2.0 to ssb ohci driver
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (68 commits)
U6715 16550A serial driver support
Char: nozomi, set tty->driver_data appropriately
Char: nozomi, fix tty->count counting
serial: max3107: Fix gpiolib support
hsu: call PCI pm hooks in suspend/resume function
hsu: some code cleanup
hsu: add a periodic timer to check dma rx channel
hsu: driver for Medfield High Speed UART device
mxser: remove unnesesary NULL check
serial: add support for OX16PCI958 card
serial: 68328serial.c: remove dead (ALMA_ANS | DRAGONIXVZ | M68EZ328ADS)
timbuart: use __devinit and __devexit macros for probe and remove
serial: MMIO32 support for 8250_early.c
serial: mcf: don't take spinlocks in already protected functions
serial: general fixes in the serial_rs485 structure
serial: fix missing bit coverage of ASYNC_FLAGS
serial: "altera_uart: simplify altera_uart_console_putc()" checkpatch fixes
serial: crisv10: formatting of pointers in printk()
vt: Fix warning: statement with no effect due to vt_kern.h
tty_io: remove casts from void*
Fix kernel-doc warnings in linux/usb.h:
Warning(include/linux/usb.h:185): No description found for parameter 'resetting_device'
Warning(include/linux/usb.h:1212): No description found for parameter 'stream_id'
The Logitech Harmony 700 series needs an extra delay during
initialization. This patch adds a USB quirk which enables such a delay
and adds the device to the quirks list.
Signed-off-by: Phil Dibowitz <phil@ipom.com>
Cc: stable <stable@kernel.org>
1) Introduce ulpi specific flags for control of the ulpi phy
2) Extend the generic ulpi driver with support for Function and
Interface control of upli phy
3) Update the platforms using the generic ulpi driver with new ulpi
flags
4) Remove the otg control flags not in use
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Fixes below compilation warning from ulpi.h
include/linux/usb/ulpi.h:145:
warning: 'struct otg_io_access_ops' declared inside parameter list
warning: its scope is only this definition or declaration,
which is probably not what you want
Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
This patch (as1395) adds code to hcd_pci_suspend() for handling wakeup
races. This is another general race pattern, similar to the "open
vs. unregister" race we're all familiar with. Here, the race is
between suspending a device and receiving a wakeup request from one of
the device's suspended children.
In particular, if a root-hub wakeup is requested at about the same
time as the corresponding USB controller is suspended, and if the
controller is enabled for wakeup, then the controller should either
fail to suspend or else wake right back up again.
During system sleep this won't happen very much, especially since host
controllers generally aren't enabled for wakeup during sleep. However
it is definitely an issue for runtime PM. Something like this will be
needed to prevent the controller from autosuspending while waiting for
a root-hub resume to take place. (That is, in fact, the common case,
for which there is an extra test.)
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1385) adds a "do_wakeup" parameter to the pci_suspend
method used by PCI-based host controller drivers. ehci-hcd in
particular needs to know whether or not to enable wakeup when
suspending a controller. Although that information is currently
available through device_may_wakeup(), when support is added for
runtime suspend this will no longer be true.
This patch (as1393) converts several of the single-bit fields in
struct usb_hcd to atomic flags. This is for safety's sake; not all
CPUs can update bitfield values atomically, and these flags are used
in multiple contexts.
The flag fields that are set only during registration or removal can
remain as they are, since non-atomic accesses at those times will not
cause any problems.
(Strictly speaking, the authorized_default flag should become atomic
as well. I didn't bother with it because it gets changed only via
sysfs. It can be done later, if anyone wants.)
Added a disconnect() callback to composite devices which
is called by composite glue when its disconnect callback
is called by gadget.
Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
usb_string_ids_tab() and usb_string_ids_n() functions added to
the composite framework. The first accepts an array of
usb_string object and for each registeres a string id and the
second registeres a given number of ids and returns the first.
This may simplify string ids registration since gadgets and
composite functions won't have to call usb_string_id() several
times and each time check for errer status -- all this will be
done with a single call.
FunctionFS had a bit unique name for function used to add it
to USB configuration. Renamed as to match naming convention
of other functions.
And audit all the users. None needed the BKL. That was easy
because there was only very few around.
Tested with allmodconfig build on x86-64
With this patch, the LPM capable EHCI host controller can put device
into L1 sleep state which is a mode that can enter/exit quickly, and
reduce power consumption.
Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com>
Signed-off-by: Alek Du <alek.du@intel.com>
EHCI 1.1 addendum introduced several energy efficiency extensions for
EHCI USB host controllers:
1. LPM (link power management)
2. Per-port change
3. Shorter periodic frame list
4. Hardware prefetching
This patch is intended to define the HW bits and debug interface for
EHCI 1.1 addendum. The LPM and Per-port change patches will be sent out
after this patch.
otg_io_write() function does not follow the declaration of
struct otg_io_access_ops.
This patch (as1390) fixes a problem that crops up when a UHCI host
controller is unbound from uhci-hcd while there are still some active
URBs. The URBs have to be unlinked when the root hub is unregistered,
and uhci-hcd relies upon root-hub status polls as part of its
unlinking procedure. But usb_hcd_poll_rh_status() won't make those
status calls if hcd->rh_registered is clear, and the flag is cleared
_before_ the unregistration takes place.
Since hcd->rh_registered is used for other things and needs to be
cleared early, the solution is to add a new flag (rh_pollable) and use
it instead. It gets cleared _after_ the root hub is unregistered.
Now that the status polls don't end too soon, we have to make sure
they also don't occur too late -- after the root hub's usb_device
structure or the HCD's private structures are deallocated. Therefore
the patch adds usb_get_device() and usb_put_device() calls to protect
the root hub structure, and it adds an extra del_timer_sync() to
prevent the root-hub timer from causing an unexpected status poll.
This additional complexity would not be needed if the HCD framework
had provided separate stop() and release() callbacks instead of just
stop(). This lack could be fixed at some future time (although it
would require changes to every host controller driver); when that
happens this patch won't be needed any more.
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing
* 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing:
staging: Pushdown bkl to easycap ioctl handlers
autofs/autofs4: Move compat_ioctl handling into fs
v4l: Convert v4l2-dev to unlocked_ioctl
ia64/perfmon: Convert to unlocked_ioctl
sunrpc: Remove duplicated #include
ncpfs: Remove duplicated #include
UART Features extract from STEricsson U6715 data-sheet (arm926 SoC for mobile phone):
* Fully compatible with industry standard 16C550 and 16C450 from various
manufacturers
* RX and TX 64 byte FIFO reduces CPU interrupts
* Full double buffering
* Modem control signals include CTS, RTS, (and DSR, DTR on UART1 only)
* Automatic baud rate selection
* Manual or automatic RTS/CTS smart hardware flow control
* Programmable serial characteristics:
– Baud rate generation (50 to 3.25M baud)
– 5, 6, 7 or 8-bit characters
– Even, odd or no-parity bit generation and detection
– 1, 1.5 or 2 stop bit generation
* Independent control of transmit, receive, line status, data set interrupts and FIFOs
* Full status-reporting capabilities
* Separate DMA signaling for RX and TX
* Timed interrupt to spread receive interrupt on known duration
* DMA time-out interrupt to allow detection of end of reception
* Carkit pulse coding and decoding compliant with USB carkit control interface [40]
In 16550A auto-configuration, if the fifo size is 64 then it's an U6 16550A port
Add set_termios hook & export serial8250_do_set_termios to change uart
clock following baudrate
Signed-off-by: Philippe Langlais <philippe.langlais@stericsson.com>
Acked-by: Alan Cox <alan@linux.intel.com>
This is a PCI & UART driver, which suppors both PIO and DMA mode
UART operation. It has 3 identical UART ports and one internal
DMA controller.
Current FW will export 4 pci devices for hsu: 3 uart ports and 1
dma controller, each has one IRQ line. And we need to discuss the
device model, one PCI device covering whole HSU should be a better
model, but there is a problem of how to export the 4 IRQs info
Current driver set the highest baud rate to 2746800bps, which is
easy to scale down to 115200/230400.... To suport higher baud rate,
we need add special process, change DLAB/DLH/PS/DIV/MUL registers
all together.
921600 is the highest baud rate that has been tested with Bluetooth
modem connected to HSU port 0. Will test more when there is right
BT firmware.
Current version contains several work around for A0's Silicon bugs
Signed-off-by: Feng Tang <feng.tang@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Fix several issues related to the RS485 interface:
- It adds the flag SER_RS485_RTS_BEFORE_SEND that was missing from the
serial_rs485 structure (even if "delay_rts_before_send" was existing)
- It adds a further "delay_rts_after_send" field for those drivers that
can have a delay after send (e.g., atmel_serial)
- It fixes the usage of the structure in the atmel_serial driver (where
"delay_rts_before_send" should be used instead of "delay_rts_after_send").
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
Signed-off-by: Bernhard Roth <br@pwrnet.de>
Cc: Philippe De Muyter <phdm@macqel.be>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
It seems that currently ASYNC_FLAGS is one bit short of covering all the
bits of the ASYNC user flags. In particular it does not cover the
ASYNC_AUTOPROBE bit.
ASYNCB_LAST_USER and ASYNCB_AUTOPROBE are both equal to 15.
Therefore:
ASYNC_AUTOPROBE = 1000 0000 0000 0000
ASYNC_FLAGS = 0111 1111 1111 1111
So ASYNC_FLAGS is not covering the ASYNC_AUTOPROBE bit.
This patch fixes the issue and with the patch the values will be:
ASYNC_FLAGS = 1111 1111 1111 1111
As a side note, doing a "git grep" I didn't find any use of
ASYNC_AUTOPROBE or ASYNCB_AUTOPROBE in the kernel, besides this include
file.
Signed-off-by: John Villalovos <john.l.villalovos@intel.com>
Using:
gcc (GCC) 4.5.0 20100610 (prerelease)
with CONFIG_CONSOLE_TRANSLATIONS=n, the following warnings are seen:
drivers/char/vt_ioctl.c: In function ‘vt_ioctl’:
drivers/char/vt_ioctl.c:1309:4: warning: statement with no effect
drivers/char/vt.c: In function ‘vc_allocate’:
drivers/char/vt.c:774:3: warning: statement with no effect
drivers/video/console/vgacon.c: In function ‘vgacon_init’:
drivers/video/console/vgacon.c:587:3: warning: statement with no effect
drivers/video/console/vgacon.c: In function ‘vgacon_deinit’:
drivers/video/console/vgacon.c:606:2: warning: statement with no effect
drivers/video/console/fbcon.c: In function ‘fbcon_init’:
drivers/video/console/fbcon.c:1087:3: warning: statement with no effect
drivers/video/console/fbcon.c:1089:3: warning: statement with no effect
drivers/video/console/fbcon.c: In function ‘fbcon_set_disp’:
drivers/video/console/fbcon.c:1369:3: warning: statement with no effect
drivers/video/console/fbcon.c:1371:3: warning: statement with no effect
This is because several functions in include/linux/vt_kern.h are
defined to (0). Convert them to static inline functions to
silence the warnings and gain a bit of type safety.
Signed-off-by: Kevin Winchester <kjwinchester@gmail.com>
At the moment there is only one platform type supported and there is is
hard wired, but with these changes the infrastructure is now there for
anyone else to provide methods for their hardware.
The tty locking now follows the rules for mutexes, so
we can replace the BKL usage with a new subsystem
wide mutex.
Using a regular mutex here will change the behaviour
when blocked on the BTM from spinning to sleeping,
but that should not be visible to the user.
Using the mutex also means that all the BTM is now
covered by lockdep.
This changes all remaining users of tty_lock_nested
to be non-recursive, which lets us kill this function.
As a consequence, we won't need to keep the lock count
any more, which allows more simplifications later.
Calling wait_event_interruptible implicitly
releases the BKL when it sleeps, but we need
to do this explcitly when we have converted
it to a mutex.
As a preparation for replacing the big kernel lock
in the TTY layer, wrap all the callers in new
macros tty_lock, tty_lock_nested and tty_unlock.
This takes all the tty references through the expected interface points so
we can refcount them.
The vt layer isn't safely handling reference counts to tty object on the input
side. Add a tty port structure to the vt layer in order to implement this using
the standard helpers.
Pass down the ldisc number so that the drivers don't have to peek into the
tty object themselves. This lets us get rid of another case of back referencing
port to tty which we don't want (because of races versus hangup/close).
This lets us avoid problems with races on the flag changes
Jesse's initial patch commit said:
"At panic time (i.e. when oops_in_progress is set) we should try a bit
harder to update the screen and make sure output gets to the VT, since
some drivers are capable of flipping back to it.
So make sure we try to unblank and update the display if called from a
panic context."
I've enhanced this to add a flag to the vc that console layer can set to
indicate they want this behaviour to occur. This also adds support to
fbcon for that flag and adds an fb flag for drivers to indicate they want
to use the support. It enables this for KMS drivers.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Acked-by: James Simmons <jsimmons@infradead.org>
This patch is against the 2.6.34 source.
Paraphrased from the 1989 BSD patch by David Borman @ cray.com:
These are the changes needed for the kernel to support
LINEMODE in the server.
There is a new bit in the termios local flag word, EXTPROC.
When this bit is set, several aspects of the terminal driver
are disabled. Input line editing, character echo, and mapping
of signals are all disabled. This allows the telnetd to turn
off these functions when in linemode, but still keep track of
what state the user wants the terminal to be in.
New ioctl:
TIOCSIG Generate a signal to processes in the
current process group of the pty.
There is a new mode for packet driver, the TIOCPKT_IOCTL bit.
When packet mode is turned on in the pty, and the EXTPROC bit
is set, then whenever the state of the pty is changed, the
next read on the master side of the pty will have the TIOCPKT_IOCTL
bit set. This allows the process on the server side of the pty
to know when the state of the terminal has changed; it can then
issue the appropriate ioctl to retrieve the new state.
Since the original BSD patches accompanied the source code for telnet
I've left that reference here, but obviously the feature is useful for
any remote terminal protocol, including ssh.
The corresponding feature has existed in the BSD tty driver since 1989.
For historical reference, a good copy of the relevant files can be found
here:
http://anonsvn.mit.edu/viewvc/krb5/trunk/src/appl/telnet/?pathrev=17741
Signed-off-by: Howard Chu <hyc@symas.com>
Remove Hayes ESP ioctls
The Hayes ESP driver has been removed from the tree:
commit f53a2ade0bb9f2a81f473e6469155172a96b7c38
("tty: esp: remove broken driver")
so its ioctls aren't needed any more.
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
* 'writable_limits' of git://decibel.fi.muni.cz/~xslaby/linux:
unistd: add __NR_prlimit64 syscall numbers
rlimits: implement prlimit64 syscall
rlimits: switch more rlimit syscalls to do_prlimit
rlimits: redo do_setrlimit to more generic do_prlimit
rlimits: add rlimit64 structure
rlimits: do security check under task_lock
rlimits: allow setrlimit to non-current tasks
rlimits: split sys_setrlimit
rlimits: selinux, do rlimits changes under task_lock
rlimits: make sure ->rlim_max never grows in sys_setrlimit
rlimits: add task_struct to update_rlimit_cpu
rlimits: security, add task_struct to setrlimit
Fix up various system call number conflicts. We not only added fanotify
system calls in the meantime, but asm-generic/unistd.h added a wait4
along with a range of reserved per-architecture system calls.
* git://git.infradead.org/mtd-2.6: (79 commits)
mtd: Remove obsolete <mtd/compatmac.h> include
mtd: Update copyright notices
jffs2: Update copyright notices
mtd-physmap: add support users can assign the probe type in board files
mtd: remove redwood map driver
mxc_nand: Add v3 (i.MX51) Support
mxc_nand: support 8bit ecc
mxc_nand: fix correct_data function
mxc_nand: add V1_V2 namespace to registers
mxc_nand: factor out a check_int function
mxc_nand: make some internally used functions overwriteable
mxc_nand: rework get_dev_status
mxc_nand: remove 0xe00 offset from registers
mtd: denali: Add multi connected NAND support
mtd: denali: Remove set_ecc_config function
mtd: denali: Remove unuseful code in get_xx_nand_para functions
mtd: denali: Remove device_info_tag structure
mtd: m25p80: add support for the Winbond W25Q32 SPI flash chip
mtd: m25p80: add support for the Intel/Numonyx {16,32,64}0S33B SPI flash chips
mtd: m25p80: add support for the EON EN25P{32, 64} SPI flash chips
Fix up trivial conflicts in drivers/mtd/maps/{Kconfig,redwood.c} due to
redwood driver removal.
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits)
fanotify: use both marks when possible
fsnotify: pass both the vfsmount mark and inode mark
fsnotify: walk the inode and vfsmount lists simultaneously
fsnotify: rework ignored mark flushing
fsnotify: remove global fsnotify groups lists
fsnotify: remove group->mask
fsnotify: remove the global masks
fsnotify: cleanup should_send_event
fanotify: use the mark in handler functions
audit: use the mark in handler functions
dnotify: use the mark in handler functions
inotify: use the mark in handler functions
fsnotify: send fsnotify_mark to groups in event handling functions
fsnotify: Exchange list heads instead of moving elements
fsnotify: srcu to protect read side of inode and vfsmount locks
fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called
fsnotify: use _rcu functions for mark list traversal
fsnotify: place marks on object in order of group memory address
vfs/fsnotify: fsnotify_close can delay the final work in fput
fsnotify: store struct file not struct path
Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
These form the basis of the basic WRITE etc primitives, so we
need them to be always visible. Otherwise we see errors like:
mm/filemap.c:2164: error: 'REQ_WRITE' undeclared
fs/read_write.c:362: error: 'REQ_WRITE' undeclared
fs/splice.c:1108: error: 'REQ_WRITE' undeclared
fs/aio.c:1496: error: 'REQ_WRITE' undeclared
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
