path: root/include
2015-07-09cdc_ncm: Add support for moving NDP to end of NCM frameEnrico Mioso
NCM specs are not actually mandating a specific position in the frame for the NDP (Network Datagram Pointer). However, some Huawei devices will ignore our aggregates if it is not placed after the datagrams it points to. Add support for doing just this, in a per-device configurable way. While at it, update NCM subdrivers, disabling this functionality in all of them, except in huawei_cdc_ncm where it is enabled instead. We aren't making any distinction between different Huawei NCM devices, based on what the vendor driver does. Standard NCM devices are left unaffected: if they are compliant, they should be always usable, still stay on the safe side. This change has been tested and working with a Huawei E3131 device (which works regardless of NDP position), a Huawei E3531 (also working both ways) and an E3372 (which mandates NDP to be after indexed datagrams). V1->V2: - corrected wrong NDP acronym definition - fixed possible NULL pointer dereference - patch cleanup V2->V3: - Properly account for the NDP size when writing new packets to SKB Signed-off-by: Enrico Mioso <mrkiko.rs@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-08ipv4: add support for linkdown sysctl to netconfAndy Gospodarek
This kernel patch exports the value of the new ignore_routes_with_linkdown via netconf. v2: changes to notify userspace via netlink when sysctl values change and proposed for 'net' since this could be considered a bugfix Signed-off-by: Andy Gospodarek <gospo@cumulusnetworks.com> Suggested-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-02Merge tag 'module-builtin_driver-v4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull module_platform_driver replacement from Paul Gortmaker: "Replace module_platform_driver with builtin_platform driver in non modules. We see an increasing number of non-modular drivers using modular_driver() type register functions. There are several downsides to letting this continue unchecked: - The code can appear modular to a reader of the code, and they won't know if the code really is modular without checking the Makefile and Kconfig to see if compilation is governed by a bool or tristate. - Coders of drivers may be tempted to code up an __exit function that is never used, just in order to satisfy the required three args of the modular registration function. - Non-modular code ends up including the <module.h> which increases CPP overhead that they don't need. - It hinders us from performing better separation of the module init code and the generic init code. So here we introduce similar macros for builtin drivers. Then we convert builtin drivers (controlled by a bool Kconfig) by making the following type of mapping: module_platform_driver() ---> builtin_platform_driver() module_platform_driver_probe() ---> builtin_platform_driver_probe(). The set of drivers that are converted here are just the ones that showed up as relying on an implicit include of <module.h> during a pending header cleanup. So we convert them here vs adding an include of <module.h> to non-modular code to avoid compile fails. Additonal conversions can be done asynchronously at any time. Once again, an unused module_exit function that is removed here appears in the diffstat as an outlier wrt all the other changes" * tag 'module-builtin_driver-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: drivers/clk: convert sunxi/clk-mod0.c to use builtin_platform_driver drivers/power: Convert non-modular syscon-reboot to use builtin_platform_driver drivers/soc: Convert non-modular soc-realview to use builtin_platform_driver drivers/soc: Convert non-modular tegra/pmc to use builtin_platform_driver drivers/cpufreq: Convert non-modular s5pv210-cpufreq.c to use builtin_platform_driver drivers/cpuidle: Convert non-modular drivers to use builtin_platform_driver drivers/platform: Convert non-modular pdev_bus to use builtin_platform_driver platform_device: better support builtin boilerplate avoidance
2015-07-02Merge tag 'cpuinit-v4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull __cpuinit removal from Paul Gortmaker: "Remove __cpuinit macros and users. We removed the __cpuinit stuff in 3.11-rc1 with commit 22f0a2736774 ("init.h: remove __cpuinit sections from the kernel") but we left some no-op stubs as a courtesy to unmerged code. Here we get rid of the stubs as well, since (as can be seen in these changes) they are enabling use cases to sneak back in, primarily from older BSP code that has been living out of tree for some time prior to getting mainlined. So we get rid of these "new" users 1st and then get rid of the stubs. Obviously, getting rid of the stubs can't happen until all the users are gone, so I had to keep this together as a series, even though some of these commits since got picked up into maintainers trees as well. The nature of this change is such that it should have zero impact on the generated runtime. This is one of several independent cleanup branches aimed at enabling better organization in the init.h and module.h code. They have been getting coverage in the linux-next tree for the last month, in addition to my local testing, which also covers approximately a half dozen or more architectures" * tag 'cpuinit-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: init: delete the __cpuinit related stubs kernel/cpu.c: remove new instance of __cpuinit that crept back in sched/core: remove __cpuinit section tag that crept back in. mips/mm/tlbex: remove new instance of __cpuinit that crept back in mips/c-r4k: remove legacy __cpuinit section that crept in mips/bcm77xx: remove legacy __cpuinit sections that crept in mips/ath25: remove legacy __cpuinit section that crept in arm/mach-hisi: remove legacy __CPUINIT section that crept in arm/mach-rockchip: remove legacy __cpuinit section that crept in arm/mach-mvebu: remove legacy __cpuinit sections that crept in arm/mach-keystone: remove legacy __cpuinit sections that crept in
2015-07-01Merge tag 'devicetree-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux Pull devicetree updates from Grant Likely: "A whole lot of bug fixes. Nothing stands out here except the ability to enable CONFIG_OF on every architecture, and an import of a newer version of dtc" * tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: (22 commits) of/irq: Rename "intc_desc" to "of_intc_desc" to fix OF on sh of/irq: Fix pSeries boot failure Documentation: DT: Fix a typo in the filename "lantiq,<chip>-pinumx.txt" of: define of_find_node_by_phandle for !CONFIG_OF of/address: use atomic allocation in pci_register_io_range() of: Add vendor prefix for Zodiac Inflight Innovations dt/fdt: add empty versions of early_init_dt_*_memory_arch of: clean-up unnecessary libfdt include paths of: make unittest select OF_EARLY_FLATTREE instead of depend on it of: make CONFIG_OF user selectable MIPS: prepare for user enabling of CONFIG_OF of/fdt: fix argument name and add comments of unflatten_dt_node() of: return NUMA_NO_NODE from fallback of_node_to_nid() tps6507x.txt: Remove executable permission of/overlay: Grammar s/an negative/a negative/ of/fdt: Make fdt blob input parameters of unflatten functions const of: add helper function to retrive match data of: Grammar s/property exist/property exists/ of: Move OF flags to be visible even when !CONFIG_OF scripts/dtc: Update to upstream version 9d3649bd3be245c9 ...
2015-07-01Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: "This contains: - new driver for ST's LPC Watchdog - new driver for Conexant Digicolor CX92755 SoC - new driver for DA9062 watchdog - Addition of the watchdog registration deferral mechanism - several improvements on omap_wdt - several improvements and reboot-support for imgpdc_wdt - max63xx_wdt improvements - imx2_wdt improvements - dw_wdt improvements - and other small improvements and fixes" * git://www.linux-watchdog.org/linux-watchdog: (37 commits) watchdog: omap_wdt: early_enable module parameter watchdog: gpio_wdt: Add option for early registration watchdog: watchdog_core: Add watchdog registration deferral mechanism watchdog: max63xx: dynamically allocate device watchdog: imx2_wdt: Disable previously acquired clock on error path watchdog: imx2_wdt: Check for clk_prepare_enable() error watchdog: hpwdt: Add support for WDIOC_SETOPTIONS watchdog: docs: omap_wdt also understands nowayout watchdog: omap_wdt: implement get_timeleft watchdog: da9062: DA9062 watchdog driver watchdog: imx2_wdt: set watchdog parent device watchdog: mena21_wdt: Fix possible NULL pointer dereference watchdog: dw_wdt: keepalive the watchdog at write time watchdog: dw_wdt: No need for a spinlock watchdog: imx2_wdt: also set wdog->timeout to new_timeout watchdog: Allow compile test of GPIO consumers if !GPIOLIB watchdog: cadence: Add dependency on HAS_IOMEM watchdog: max63xx_wdt: Constify platform_device_id watchdog: MAX63XX_WATCHDOG does not depend on ARM watchdog: imgpdc: Add some documentation about the timeout ...
2015-07-01Merge tag 'clk-for-linus-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull clock framework updates from Michael Turquette: "The changes to the common clock framework for 4.2 are dominated by new drivers and updates to existing ones, as usual. There are some fixes to the framework itself and several cleanups for sparse warnings, etc" * tag 'clk-for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (135 commits) clk: stm32: Add clock driver for STM32F4[23]xxx devices dt-bindings: Document the STM32F4 clock bindings cpufreq: exynos: remove Exynos4210 specific cpufreq driver support ARM: Exynos: switch to using generic cpufreq driver for Exynos4210 clk: samsung: exynos4: add cpu clock configuration data and instantiate cpu clock clk: samsung: add infrastructure to register cpu clocks clk: add CLK_RECALC_NEW_RATES clock flag for Exynos cpu clock support doc: dt: add documentation for lpc1850-ccu clk driver clk: add lpc18xx ccu clk driver doc: dt: add documentation for lpc1850-cgu clk driver clk: add lpc18xx cgu clk driver clk: keystone: add support for post divider register for main pll clk: mvebu: flag the crypto clk as CLK_IGNORE_UNUSED clk: cygnus: remove Cygnus dummy clock binding clk: cygnus: add clock support for Broadcom Cygnus clk: Change bcm clocks build dependency clk: iproc: add initial common clock support clk: iproc: define Broadcom iProc clock binding MAINTAINERS: update email for Michael Turquette clk: meson: add some error handling in meson_clk_register_cpu() ...
2015-07-01Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem updates from Bryan Wu: "In this cycle, we finished to merge patches for LED Flash class driver. Other than that we have some bug fixes and new drivers for LED controllers" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (33 commits) leds:lp55xx: fix firmware loading error leds: fix max77693-led build errors leds: fix aat1290 build errors leds: aat1290: pass flags parameter to devm_gpiod_get leds: ktd2692: pass flags parameter to devm_gpiod_get drivers/leds: don't use module_init in non-modular leds-cobalt-raq.c leds: aat1290: add support for V4L2 Flash sub-device DT: aat1290: Document handling external strobe sources leds: max77693: add support for V4L2 Flash sub-device media: Add registration helpers for V4L2 flash sub-devices v4l: async: Add a pointer to of_node to struct v4l2_subdev, match it Documentation: leds: Add description of v4l2-flash sub-device leds: add BCM6358 LED driver leds: add DT binding for BCM6358 LED controller leds: fix brightness changing when software blinking is active Documentation: leds-lp5523: describe master fader attributes leds: lp5523: add master_fader support leds: leds-gpio: Allow compile test if !GPIOLIB leds: leds-gpio: Add missing #include <linux/of.h> gpiolib: Add missing dummies for the unified device properties interface ...
2015-07-01Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - the rest of MM - scripts/gdb updates - ipc/ updates - lib/ updates - MAINTAINERS updates - various other misc things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (67 commits) genalloc: rename of_get_named_gen_pool() to of_gen_pool_get() genalloc: rename dev_get_gen_pool() to gen_pool_get() x86: opt into HAVE_COPY_THREAD_TLS, for both 32-bit and 64-bit MAINTAINERS: add zpool MAINTAINERS: BCACHE: Kent Overstreet has changed email address MAINTAINERS: move Jens Osterkamp to CREDITS MAINTAINERS: remove unused nbd.h pattern MAINTAINERS: update brcm gpio filename pattern MAINTAINERS: update brcm dts pattern MAINTAINERS: update sound soc intel patterns MAINTAINERS: remove website for paride MAINTAINERS: update Emulex ocrdma email addresses bcache: use kvfree() in various places libcxgbi: use kvfree() in cxgbi_free_big_mem() target: use kvfree() in session alloc and free IB/ehca: use kvfree() in ipz_queue_{cd}tor() drm/nouveau/gem: use kvfree() in u_free() drm: use kvfree() in drm_free_large() cxgb4: use kvfree() in t4_free_mem() cxgb3: use kvfree() in cxgb_free_mem() ...
2015-07-01Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: "This contains: - a series of fixes for interrupt drivers to prevent a potential race when installing a chained interrupt handler - a fix for cpumask pointer misuse - a fix for using the wrong interrupt number from struct irq_data - removal of unused code and outdated comments - a few new helper functions which allow us to cleanup the interrupt handling code further in 4.3 I decided against doing the cleanup at the end of this merge window and rather do the preparatory steps for 4.3, so we can run the final ABI change at the end of the 4.3 merge window with less risk" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits) ARM/LPC32xx: Use irq not hwirq for __irq_set_handler_locked() genirq: Implement irq_set_handler_locked()/irq_set_chip_handler_name_locked() genirq: Introduce helper irq_desc_get_irq() genirq: Remove irq_node() genirq: Clean up outdated comments related to include/linux/irqdesc.h mn10300: Fix incorrect use of irq_data->affinity MIPS/ralink: Fix race in installing chained IRQ handler MIPS/pci: Fix race in installing chained IRQ handler MIPS/ath25: Fix race in installing chained IRQ handler MIPS/ath25: Fix race in installing chained IRQ handler m68k/psc: Fix race in installing chained IRQ handler avr32/at32ap: Fix race in installing chained IRQ handler sh/intc: Fix race in installing chained IRQ handler sh/intc: Fix potential race in installing chained IRQ handler pinctrl/sun4i: Fix race in installing chained IRQ handler pinctrl/samsung: Fix race in installing chained IRQ handler pinctrl/samsung: Fix race in installing chained IRQ handler pinctrl/exynos: Fix race in installing chained IRQ handler pinctrl/st: Fix race in installing chained IRQ handler pinctrl/adi2: Fix race in installing chained IRQ handler ...
2015-07-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) mlx4 driver bug fixes (TX queue wakeups, csum complete indications) from Ido Shamay, Eran Ben Elisha, and Or Gerlitz. 2) Missing unlock in error path of PTP support in renesas driver, from Dan Carpenter. 3) Add Vitesse 8641 phy IDs to vitesse PHY driver, from Shaohui Xie. 4) Bnx2x driver bug fixes (linearization of encap packets, scratchpad parity error notifications, flow-control and speed settings) from Yuval Mintz, Manish Chopra, Shahed Shaikh, and Ariel Elior. 5) ipv6 extension header parsing in the igb chip has a HW errata, disable it. Frm Todd Fujinaka. 6) Fix PCI link state locking issue in e1000e driver, from Yanir Lubetkin. 7) Cure panics during MTU change in i40e, from Mitch Williams. 8) Don't leak promisc refs in DSA slave driver, from Gilad Ben-Yossef. 9) Add missing HAS_DMA dep to VIA Rhine driver, from Geery Uytterhoeven. 10) Make sure DMA map/unmap calls are symmetric in bnx2x driver, from Michal Schmidt. 11) Workaround for MDIO access problems in bcm7xxx devices, from FLorian Fainelli. 12) Fix races in SCTP protocol between OTTB responses and route removals, from Alexander Sverdlin. 13) Fix jumbo frame checksum issue with some mvneta devices, from Simon Guinot. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (58 commits) sock_diag: don't broadcast kernel sockets net: mvneta: disable IP checksum with jumbo frames for Armada 370 ARM: mvebu: update Ethernet compatible string for Armada XP net: mvneta: introduce compatible string "marvell, armada-xp-neta" api: fix compatibility of linux/in.h with netinet/in.h net: icplus: fix typo in constant name sis900: Trivial: Fix typos in enums stmmac: Trivial: fix typo in constant name sctp: Fix race between OOTB responce and route removal net-Liquidio: Delete unnecessary checks before the function call "vfree" vmxnet3: Bump up driver version number amd-xgbe: Add the __GFP_NOWARN flag to Rx buffer allocation net: phy: mdio-bcm-unimac: workaround initial read failures for integrated PHYs net: bcmgenet: workaround initial read failures for integrated PHYs net: phy: bcm7xxx: workaround MDIO management controller initial read bnx2x: fix DMA API usage net: via: VIA_RHINE and VIA_VELOCITY should depend on HAS_DMA net/phy: tune get_phy_c45_ids to support more c45 phy bnx2x: fix lockdep splat net: fec: don't access RACC register when not available ...
2015-07-01Merge tag 'pm+acpi-4.2-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael Wysocki: "These are fixes that didn't make it to the previous PM+ACPI pull request or are fixing issues introduced by it. Specifics: - Fix a recently added memory leak in an error path in the ACPI resources management code (Dan Carpenter) - Fix a build warning triggered by an ACPI video header function that should be static inline (Borislav Petkov) - Change names of helper function converting struct fwnode_handle pointers to either struct device_node or struct acpi_device pointers so they don't conflict with local variable names (Alexander Sverdlin) - Make the hibernate core re-enable nonboot CPUs on failures to disable them as expected (Vitaly Kuznetsov) - Increase the default timeout of the device suspend watchdog to prevent it from triggering too early on some systems (Takashi Iwai) - Prevent the cpuidle powernv driver from registering idle states with CPUIDLE_FLAG_TIMER_STOP set if CONFIG_TICK_ONESHOT is unset which leads to boot hangs (Preeti U Murthy)" * tag 'pm+acpi-4.2-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: tick/idle/powerpc: Do not register idle states with CPUIDLE_FLAG_TIMER_STOP set in periodic mode PM / sleep: Increase default DPM watchdog timeout to 60 PM / hibernate: re-enable nonboot cpus on disable_nonboot_cpus() failure ACPI / OF: Rename of_node() and acpi_node() to to_of_node() and to_acpi_node() ACPI / video: Inline acpi_video_set_dmi_backlight_type ACPI / resources: free memory on error in add_region_before()
2015-07-01Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Main excitement here is Peter Zijlstra's lockless rbtree optimization to speed module address lookup. He found some abusers of the module lock doing that too. A little bit of parameter work here too; including Dan Streetman's breaking up the big param mutex so writing a parameter can load another module (yeah, really). Unfortunately that broke the usual suspects, !CONFIG_MODULES and !CONFIG_SYSFS, so those fixes were appended too" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (26 commits) modules: only use mod->param_lock if CONFIG_MODULES param: fix module param locks when !CONFIG_SYSFS. rcu: merge fix for Convert ACCESS_ONCE() to READ_ONCE() and WRITE_ONCE() module: add per-module param_lock module: make perm const params: suppress unused variable error, warn once just in case code changes. modules: clarify CONFIG_MODULE_COMPRESS help, suggest 'N'. kernel/module.c: avoid ifdefs for sig_enforce declaration kernel/workqueue.c: remove ifdefs over wq_power_efficient kernel/params.c: export param_ops_bool_enable_only kernel/params.c: generalize bool_enable_only kernel/module.c: use generic module param operaters for sig_enforce kernel/params: constify struct kernel_param_ops uses sysfs: tightened sysfs permission checks module: Rework module_addr_{min,max} module: Use __module_address() for module_address_lookup() module: Make the mod_tree stuff conditional on PERF_EVENTS || TRACING module: Optimize __module_address() using a latched RB-tree rbtree: Implement generic latch_tree seqlock: Introduce raw_read_seqcount_latch() ...
2015-07-01Merge tag 'arc-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC architecture updates from Vineet Gupta: - support for HS38 cores based on ARCv2 ISA ARCv2 is the next generation ISA from Synopsys and basis for the HS3{4,6,8} families of processors which retain the traditional ARC mantra of low power and configurability and are now more performant and feature rich. HS38x is a 10 stage pipeline core which supports MMU (with huge pages) and SMP (upto 4 cores) among other features. + www.synopsys.com/dw/ipdir.php?ds=arc-hs38-processor + http://news.synopsys.com/2014-10-14-New-DesignWare-ARC-HS38-Processor-Doubles-Performance-for-Embedded-Linux-Applications + http://www.embedded.com/electronics-news/4435975/Synopsys-ARC-HS38-core-gives-2X-boost-to-Linux-based-apps - support for ARC SDP (Software Development platform): Main Board + CPU Cards = AXS101: CPU Card with ARC700 in silicon @ 700 MHz = AXS103: CPU Card with HS38x in FPGA - refactoring of ARCompact port to accomodate new ARCv2 ISA - misc updates/cleanups * tag 'arc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: (72 commits) ARC: Fix build failures for ARCompact in linux-next after ARCv2 support ARCv2: Allow older gcc to cope with new regime of ARCv2/ARCompact support ARCv2: [vdk] dts files and defconfig for HS38 VDK ARCv2: [axs103] Support ARC SDP FPGA platform for HS38x cores ARC: [axs101] Prepare for AXS103 ARCv2: [nsim*hs*] Support simulation platforms for HS38x cores ARCv2: All bits in place, allow ARCv2 builds ARCv2: SLC: Handle explcit flush for DMA ops (w/o IO-coherency) ARCv2: STAR 9000837815 workaround hardware exclusive transactions livelock ARC: Reduce bitops lines of code using macros ARCv2: barriers arch: conditionally define smp_{mb,rmb,wmb} ARC: add smp barriers around atomics per Documentation/atomic_ops.txt ARC: add compiler barrier to LLSC based cmpxchg ARCv2: SMP: intc: IDU 2nd level intc for dynamic IRQ distribution ARCv2: SMP: clocksource: Enable Global Real Time counter ARCv2: SMP: ARConnect debug/robustness ARCv2: SMP: Support ARConnect (MCIP) for Inter-Core-Interrupts et al ARC: make plat_smp_ops weak to allow over-rides ARCv2: clocksource: Introduce 64bit local RTC counter ...
2015-06-30Merge tag 'xfs-for-linus-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs Pul xfs updates from Dave Chinner: "There's a couple of small API changes to the core DAX code which required small changes to the ext2 and ext4 code bases, but otherwise everything is within the XFS codebase. This update contains: - A new sparse on-disk inode record format to allow small extents to be used for inode allocation when free space is fragmented. - DAX support. This includes minor changes to the DAX core code to fix problems with lock ordering and bufferhead mapping abuse. - transaction commit interface cleanup - removal of various unnecessary XFS specific type definitions - cleanup and optimisation of freelist preparation before allocation - various minor cleanups - bug fixes for - transaction reservation leaks - incorrect inode logging in unwritten extent conversion - mmap lock vs freeze ordering - remote symlink mishandling - attribute fork removal issues" * tag 'xfs-for-linus-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: (49 commits) xfs: don't truncate attribute extents if no extents exist xfs: clean up XFS_MIN_FREELIST macros xfs: sanitise error handling in xfs_alloc_fix_freelist xfs: factor out free space extent length check xfs: xfs_alloc_fix_freelist() can use incore perag structures xfs: remove xfs_caddr_t xfs: use void pointers in log validation helpers xfs: return a void pointer from xfs_buf_offset xfs: remove inst_t xfs: remove __psint_t and __psunsigned_t xfs: fix remote symlinks on V5/CRC filesystems xfs: fix xfs_log_done interface xfs: saner xfs_trans_commit interface xfs: remove the flags argument to xfs_trans_cancel xfs: pass a boolean flag to xfs_trans_free_items xfs: switch remaining xfs_trans_dup users to xfs_trans_roll xfs: check min blks for random debug mode sparse allocations xfs: fix sparse inodes 32-bit compile failure xfs: add initial DAX support xfs: add DAX IO path support ...
2015-06-30Merge branch 'for-linus-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs updates from Chris Mason: "Outside of our usual batch of fixes, this integrates the subvolume quota updates that Qu Wenruo from Fujitsu has been working on for a few releases now. He gets an extra gold star for making btrfs smaller this time, and fixing a number of quota corners in the process. Dave Sterba tested and integrated Anand Jain's sysfs improvements. Outside of exporting a symbol (ack'd by Greg) these are all internal to btrfs and it's mostly cleanups and fixes. Anand also attached some of our sysfs objects to our internal device management structs instead of an object off the super block. It will make device management easier overall and it's a better fit for how the sysfs files are used. None of the existing sysfs files are moved around. Thanks for all the fixes everyone" * 'for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (87 commits) btrfs: delayed-ref: double free in btrfs_add_delayed_tree_ref() Btrfs: Check if kobject is initialized before put lib: export symbol kobject_move() Btrfs: sysfs: add support to show replacing target in the sysfs Btrfs: free the stale device Btrfs: use received_uuid of parent during send Btrfs: fix use-after-free in btrfs_replay_log btrfs: wait for delayed iputs on no space btrfs: qgroup: Make snapshot accounting work with new extent-oriented qgroup. btrfs: qgroup: Add the ability to skip given qgroup for old/new_roots. btrfs: ulist: Add ulist_del() function. btrfs: qgroup: Cleanup the old ref_node-oriented mechanism. btrfs: qgroup: Switch self test to extent-oriented qgroup mechanism. btrfs: qgroup: Switch to new extent-oriented qgroup mechanism. btrfs: qgroup: Switch rescan to new mechanism. btrfs: qgroup: Add new qgroup calculation function btrfs_qgroup_account_extents(). btrfs: backref: Add special time_seq == (u64)-1 case for btrfs_find_all_roots(). btrfs: qgroup: Add new function to record old_roots. btrfs: qgroup: Record possible quota-related extent for qgroup. btrfs: qgroup: Add function qgroup_update_counters(). ...
2015-06-30genalloc: rename of_get_named_gen_pool() to of_gen_pool_get()Vladimir Zapolskiy
To be consistent with other kernel interface namings, rename of_get_named_gen_pool() to of_gen_pool_get(). In the original function name "_named" suffix references to a device tree property, which contains a phandle to a device and the corresponding device driver is assumed to register a gen_pool object. Due to a weak relation and to avoid any confusion (e.g. in future possible scenario if gen_pool objects are named) the suffix is removed. [sfr@canb.auug.org.au: crypto/marvell/cesa - fix up for of_get_named_gen_pool() rename] Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Philipp Zabel <p.zabel@pengutronix.de> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30genalloc: rename dev_get_gen_pool() to gen_pool_get()Vladimir Zapolskiy
To be consistent with other genalloc interface namings, rename dev_get_gen_pool() to gen_pool_get(). The original omitted "dev_" prefix is removed, since it points to argument type of the function, and so it does not bring any useful information. [akpm@linux-foundation.org: update arch/arm/mach-socfpga/pm.c] Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Philipp Zabel <p.zabel@pengutronix.de> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Mark Brown <broonie@kernel.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Alan Tull <atull@opensource.altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Kevin Hilman <khilman@linaro.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30drm: use kvfree() in drm_free_large()Pekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Cc: David Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30drivers/scsi/scsi_debug.c: resolve sg buffer const-ness issueDave Gordon
do_device_access() takes a separate parameter to indicate the direction of data transfer, which it used to use to select the appropriate function out of sg_pcopy_{to,from}_buffer(). However these two functions now have So this patch makes it bypass these wrappers and call the underlying function sg_copy_buffer() directly; this has the same calling style as do_device_access() i.e. a separate direction-of-transfer parameter and no pointers-to-const, so skipping the wrappers not only eliminates the warning, it also make the code simpler :) [akpm@linux-foundation.org: fix very broken build] Signed-off-by: Dave Gordon <david.s.gordon@intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30lib/scatterlist: mark input buffer parameters as 'const'Dave Gordon
The 'buf' parameter of sg(p)copy_from_buffer() can and should be const-qualified, although because of the shared implementation of _to_buffer() and _from_buffer(), we have to cast this away internally. This means that callers who have a 'const' buffer containing the data to be copied to the sg-list no longer have to cast away the const-ness themselves. It also enables improved coverage by code analysis tools. Signed-off-by: Dave Gordon <david.s.gordon@intel.com> Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30kernel/panic/kexec: fix "crash_kexec_post_notifiers" option issue in oops pathHATAYAMA Daisuke
Commit f06e5153f4ae2e ("kernel/panic.c: add "crash_kexec_post_notifiers" option for kdump after panic_notifers") introduced "crash_kexec_post_notifiers" kernel boot option, which toggles wheather panic() calls crash_kexec() before panic_notifiers and dump kmsg or after. The problem is that the commit overlooks panic_on_oops kernel boot option. If it is enabled, crash_kexec() is called directly without going through panic() in oops path. To fix this issue, this patch adds a check to "crash_kexec_post_notifiers" in the condition of kexec_should_crash(). Also, put a comment in kexec_should_crash() to explain not obvious things on this patch. Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Acked-by: Baoquan He <bhe@redhat.com> Tested-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: finish initialisation of struct pages before basic setupMel Gorman
Waiman Long reported that 24TB machines hit OOM during basic setup when struct page initialisation was deferred. One approach is to initialise memory on demand but it interferes with page allocator paths. This patch creates dedicated threads to initialise memory before basic setup. It then blocks on a rw_semaphore until completion as a wait_queue and counter is overkill. This may be slower to boot but it's simplier overall and also gets rid of a section mangling which existed so kswapd could do the initialisation. [akpm@linux-foundation.org: include rwsem.h, use DECLARE_RWSEM, fix comment, remove unneeded cast] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Waiman Long <waiman.long@hp.com Cc: Nathan Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Scott Norton <scott.norton@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: initialise a subset of struct pages if ↵Mel Gorman
CONFIG_DEFERRED_STRUCT_PAGE_INIT is set This patch initalises all low memory struct pages and 2G of the highest zone on each node during memory initialisation if CONFIG_DEFERRED_STRUCT_PAGE_INIT is set. That config option cannot be set but will be available in a later patch. Parallel initialisation of struct page depends on some features from memory hotplug and it is necessary to alter alter section annotations. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: inline some helper functionsMel Gorman
early_pfn_in_nid() and meminit_pfn_in_nid() are small functions that are unnecessarily visible outside memory initialisation. As well as unnecessary visibility, it's unnecessary function call overhead when initialising pages. This patch moves the helpers inline. [akpm@linux-foundation.org: fix build] [mhocko@suse.cz: fix build] Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: make __early_pfn_to_nid SMP-safe and introduce meminit_pfn_in_nidMel Gorman
__early_pfn_to_nid() use static variables to cache recent lookups as memblock lookups are very expensive but it assumes that memory initialisation is single-threaded. Parallel initialisation of struct pages will break that assumption so this patch makes __early_pfn_to_nid() SMP-safe by requiring the caller to cache recent search information. early_pfn_to_nid() keeps the same interface but is only safe to use early in boot due to the use of a global static variable. meminit_pfn_in_nid() is an SMP-safe version that callers must maintain their own state for. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: only set page reserved in the memblock regionNathan Zimmer
Currently each page struct is set as reserved upon initialization. This patch leaves the reserved bit clear and only sets the reserved bit when it is known the memory was allocated by the bootmem allocator. This makes it easier to distinguish between uninitialised struct pages and reserved struct pages in later patches. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Nathan Zimmer <nzimmer@sgi.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30memblock: introduce a for_each_reserved_mem_region iteratorRobin Holt
Struct page initialisation had been identified as one of the reasons why large machines take a long time to boot. Patches were posted a long time ago to defer initialisation until they were first used. This was rejected on the grounds it should not be necessary to hurt the fast paths. This series reuses much of the work from that time but defers the initialisation of memory to kswapd so that one thread per node initialises memory local to that node. After applying the series and setting the appropriate Kconfig variable I see this in the boot log on a 64G machine [ 7.383764] kswapd 0 initialised deferred memory in 188ms [ 7.404253] kswapd 1 initialised deferred memory in 208ms [ 7.411044] kswapd 3 initialised deferred memory in 216ms [ 7.411551] kswapd 2 initialised deferred memory in 216ms On a 1TB machine, I see [ 8.406511] kswapd 3 initialised deferred memory in 1116ms [ 8.428518] kswapd 1 initialised deferred memory in 1140ms [ 8.435977] kswapd 0 initialised deferred memory in 1148ms [ 8.437416] kswapd 2 initialised deferred memory in 1148ms Once booted the machine appears to work as normal. Boot times were measured from the time shutdown was called until ssh was available again. In the 64G case, the boot time savings are negligible. On the 1TB machine, the savings were 16 seconds. Nate Zimmer said: : On an older 8 TB box with lots and lots of cpus the boot time, as : measure from grub to login prompt, the boot time improved from 1484 : seconds to exactly 1000 seconds. Waiman Long said: : I ran a bootup timing test on a 12-TB 16-socket IvyBridge-EX system. From : grub menu to ssh login, the bootup time was 453s before the patch and 265s : after the patch - a saving of 188s (42%). Daniel Blueman said: : On a 7TB, 1728-core NumaConnect system with 108 NUMA nodes, we're seeing : stock 4.0 boot in 7136s. This drops to 2159s, or a 70% reduction with : this patchset. Non-temporal PMD init (https://lkml.org/lkml/2015/4/23/350) : drops this to 1045s. This patch (of 13): As part of initializing struct page's in 2MiB chunks, we noticed that at the end of free_all_bootmem(), there was nothing which had forced the reserved/allocated 4KiB pages to be initialized. This helper function will be used for that expansion. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Nate Zimmer <nzimmer@sgi.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30Merge remote-tracking branch 'robh/for-next' into devicetree/nextGrant Likely
2015-06-29api: fix compatibility of linux/in.h with netinet/in.hStephen Hemminger
u This fixes breakage to iproute2 build with recent kernel headers caused by: commit a263653ed798216c0069922d7b5237ca49436007 Author: Pablo Neira Ayuso <pablo@netfilter.org> Date: Wed Jun 17 10:28:27 2015 -0500 netfilter: don't pull include/linux/netfilter.h from netns headers The issue is that definitions in linux/in.h overlap with those in netinet/in.h. This patch solves this by introducing the same mechanism as was used to solve the same problem with linux/in6.h Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-29Merge tag 'md/4.2' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from Neil Brown: "A mixed bag - a few bug fixes - some performance improvement that decrease lock contention - some clean-up Nothing major" * tag 'md/4.2' of git://neil.brown.name/md: md: clear Blocked flag on failed devices when array is read-only. md: unlock mddev_lock on an error path. md: clear mddev->private when it has been freed. md: fix a build warning md/raid5: ignore released_stripes check md/raid5: per hash value and exclusive wait_for_stripe md/raid5: split wait_for_stripe and introduce wait_for_quiescent wait: introduce wait_event_exclusive_cmd md: convert to kstrto*() md/raid10: make sync_request_write() call bio_copy_data()
2015-06-29Fix kmalloc slab creation sequenceChristoph Lameter
This patch restores the slab creation sequence that was broken by commit 4066c33d0308f8 and also reverts the portions that introduced the KMALLOC_LOOP_XXX macros. Those can never really work since the slab creation is much more complex than just going from a minimum to a maximum number. The latest upstream kernel boots cleanly on my machine with a 64 bit x86 configuration under KVM using either SLAB or SLUB. Fixes: 4066c33d0308f8 ("support the slub_debug boot option") Reported-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-29Merge tag 'libnvdimm-for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm Pull libnvdimm subsystem from Dan Williams: "The libnvdimm sub-system introduces, in addition to the libnvdimm-core, 4 drivers / enabling modules: NFIT: Instantiates an "nvdimm bus" with the core and registers memory devices (NVDIMMs) enumerated by the ACPI 6.0 NFIT (NVDIMM Firmware Interface table). After registering NVDIMMs the NFIT driver then registers "region" devices. A libnvdimm-region defines an access mode and the boundaries of persistent memory media. A region may span multiple NVDIMMs that are interleaved by the hardware memory controller. In turn, a libnvdimm-region can be carved into a "namespace" device and bound to the PMEM or BLK driver which will attach a Linux block device (disk) interface to the memory. PMEM: Initially merged in v4.1 this driver for contiguous spans of persistent memory address ranges is re-worked to drive PMEM-namespaces emitted by the libnvdimm-core. In this update the PMEM driver, on x86, gains the ability to assert that writes to persistent memory have been flushed all the way through the caches and buffers in the platform to persistent media. See memcpy_to_pmem() and wmb_pmem(). BLK: This new driver enables access to persistent memory media through "Block Data Windows" as defined by the NFIT. The primary difference of this driver to PMEM is that only a small window of persistent memory is mapped into system address space at any given point in time. Per-NVDIMM windows are reprogrammed at run time, per-I/O, to access different portions of the media. BLK-mode, by definition, does not support DAX. BTT: This is a library, optionally consumed by either PMEM or BLK, that converts a byte-accessible namespace into a disk with atomic sector update semantics (prevents sector tearing on crash or power loss). The sinister aspect of sector tearing is that most applications do not know they have a atomic sector dependency. At least today's disk's rarely ever tear sectors and if they do one almost certainly gets a CRC error on access. NVDIMMs will always tear and always silently. Until an application is audited to be robust in the presence of sector-tearing the usage of BTT is recommended. Thanks to: Ross Zwisler, Jeff Moyer, Vishal Verma, Christoph Hellwig, Ingo Molnar, Neil Brown, Boaz Harrosh, Robert Elliott, Matthew Wilcox, Andy Rudoff, Linda Knippers, Toshi Kani, Nicholas Moulin, Rafael Wysocki, and Bob Moore" * tag 'libnvdimm-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm: (33 commits) arch, x86: pmem api for ensuring durability of persistent memory updates libnvdimm: Add sysfs numa_node to NVDIMM devices libnvdimm: Set numa_node to NVDIMM devices acpi: Add acpi_map_pxm_to_online_node() libnvdimm, nfit: handle unarmed dimms, mark namespaces read-only pmem: flag pmem block devices as non-rotational libnvdimm: enable iostat pmem: make_request cleanups libnvdimm, pmem: fix up max_hw_sectors libnvdimm, blk: add support for blk integrity libnvdimm, btt: add support for blk integrity fs/block_dev.c: skip rw_page if bdev has integrity libnvdimm: Non-Volatile Devices tools/testing/nvdimm: libnvdimm unit test infrastructure libnvdimm, nfit, nd_blk: driver for BLK-mode access persistent memory nd_btt: atomic sector updates libnvdimm: infrastructure for btt devices libnvdimm: write blk label set libnvdimm: write pmem label set libnvdimm: blk labels and namespace instantiation ...
2015-06-29Merge tag 'dmaengine-4.2-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time we have support for few new devices, few new features and odd fixes spread thru the subsystem. New devices added: - support for CSRatlas7 dma controller - Allwinner H3(sun8i) controller - TI DMA crossbar driver on DRA7x - new pxa driver New features added: - memset support is bought back now that we have a user in xdmac controller - interleaved transfers support different source and destination strides - supporting DMA routers and configuration thru DT - support for reusing descriptors - xdmac memset and interleaved transfer support - hdmac support for interleaved transfers - omap-dma support for memcpy Others: - Constify platform_device_id - mv_xor fixes and improvements" * tag 'dmaengine-4.2-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (46 commits) dmaengine: xgene: fix file permission dmaengine: fsl-edma: clear pending interrupts on initialization dmaengine: xdmac: Add memset support Documentation: dmaengine: document DMA_CTRL_ACK dmaengine: virt-dma: don't always free descriptor upon completion dmaengine: Revert "drivers/dma: remove unused support for MEMSET operations" dmaengine: hdmac: Implement interleaved transfers dmaengine: Move icg helpers to global header dmaengine: mv_xor: improve descriptors list handling and reduce locking dmaengine: mv_xor: Enlarge descriptor pool size dmaengine: mv_xor: add support for a38x command in descriptor mode dmaengine: mv_xor: Rename function for consistent naming dmaengine: mv_xor: bug fix for racing condition in descriptors cleanup dmaengine: pl330: fix wording in mcbufsz message dmaengine: sirf: add CSRatlas7 SoC support dmaengine: xgene-dma: Fix "incorrect type in assignement" warnings dmaengine: fix kernel-doc documentation dmaengine: pxa_dma: add support for legacy transition dmaengine: pxa_dma: add debug information dmaengine: pxa: add pxa dmaengine driver ...
2015-06-29watchdog: watchdog_core: Add watchdog registration deferral mechanismJean-Baptiste Theou
Currently, watchdog subsystem require the misc subsystem to register a watchdog. This may not be the case in case of an early registration of a watchdog, which can be required when the watchdog cannot be disabled. This patch introduces a deferral mechanism to remove this requirement. Signed-off-by: Jean-Baptiste Theou <jtheou@adeneo-embedded.us> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2015-06-28net: Kill sock->sk_protinfoDavid Miller
No more users, so it can now be removed. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-28ax25: Stop using sock->sk_protinfo.David Miller
Just make a ax25_sock structure that provides the ax25_cb pointer. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-28param: fix module param locks when !CONFIG_SYSFS.Rusty Russell
As Dan Streetman points out, the entire point of locking for is to stop sysfs accesses, so they're elided entirely in the !SYSFS case. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-06-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "The main change in this kernel is Casey's generalized LSM stacking work, which removes the hard-coding of Capabilities and Yama stacking, allowing multiple arbitrary "small" LSMs to be stacked with a default monolithic module (e.g. SELinux, Smack, AppArmor). See https://lwn.net/Articles/636056/ This will allow smaller, simpler LSMs to be incorporated into the mainline kernel and arbitrarily stacked by users. Also, this is a useful cleanup of the LSM code in its own right" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits) tpm, tpm_crb: fix le64_to_cpu conversions in crb_acpi_add() vTPM: set virtual device before passing to ibmvtpm_reset_crq tpm_ibmvtpm: remove unneccessary message level. ima: update builtin policies ima: extend "mask" policy matching support ima: add support for new "euid" policy condition ima: fix ima_show_template_data_ascii() Smack: freeing an error pointer in smk_write_revoke_subj() selinux: fix setting of security labels on NFS selinux: Remove unused permission definitions selinux: enable genfscon labeling for sysfs and pstore files selinux: enable per-file labeling for debugfs files. selinux: update netlink socket classes signals: don't abuse __flush_signals() in selinux_bprm_committed_creds() selinux: Print 'sclass' as string when unrecognized netlink message occurs Smack: allow multiple labels in onlycap Smack: fix seq operations in smackfs ima: pass iint to ima_add_violation() ima: wrap event related data to the new ima_event_data structure integrity: add validity checks for 'path' parameter ...
2015-06-27Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: - Improvements to the tlb_dump code - KVM fixes - Add support for appended DTB - Minor improvements to the R12000 support - Minor improvements to the R12000 support - Various platform improvments for BCM47xx - The usual pile of minor cleanups - A number of BPF fixes and improvments - Some improvments to the support for R3000 and DECstations - Some improvments to the ATH79 platform support - A major patchset for the JZ4740 SOC adding support for the CI20 platform - Add support for the Pistachio SOC - Minor BMIPS/BCM63xx platform support improvments. - Avoid "SYNC 0" as memory barrier when unlocking spinlocks - Add support for the XWR-1750 board. - Paul's __cpuinit/__cpuinitdata cleanups. - New Malta CPU board support large memory so enable ZONE_DMA32. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (131 commits) MIPS: spinlock: Adjust arch_spin_lock back-off time MIPS: asmmacro: Ensure 64-bit FP registers are used with MSA MIPS: BCM47xx: Simplify handling SPROM revisions MIPS: Cobalt Don't use module_init in non-modular MTD registration. MIPS: BCM47xx: Move NVRAM driver to the drivers/firmware/ MIPS: use for_each_sg() MIPS: BCM47xx: Don't select BCMA_HOST_PCI MIPS: BCM47xx: Add helper variable for storing NVRAM length MIPS: IRQ/IP27: Move IRQ allocation API to platform code. MIPS: Replace smp_mb with release barrier function in unlocks. MIPS: i8259: DT support MIPS: Malta: Basic DT plumbing MIPS: include errno.h for ENODEV in mips-cm.h MIPS: Define GCR_GIC_STATUS register fields MIPS: BPF: Introduce BPF ASM helpers MIPS: BPF: Use BPF register names to describe the ABI MIPS: BPF: Move register definition to the BPF header MIPS: net: BPF: Replace RSIZE with SZREG MIPS: BPF: Free up some callee-saved registers MIPS: Xtalk: Update xwidget.h with known Xtalk device numbers ...
2015-06-27Merge branch 'for-4.2' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "A relatively quiet cycle, with a mix of cleanup and smaller bugfixes" * 'for-4.2' of git://linux-nfs.org/~bfields/linux: (24 commits) sunrpc: use sg_init_one() in krb5_rc4_setup_enc/seq_key() nfsd: wrap too long lines in nfsd4_encode_read nfsd: fput rd_file from XDR encode context nfsd: take struct file setup fully into nfs4_preprocess_stateid_op nfsd: refactor nfs4_preprocess_stateid_op nfsd: clean up raparams handling nfsd: use swap() in sort_pacl_range() rpcrdma: Merge svcrdma and xprtrdma modules into one svcrdma: Add a separate "max data segs macro for svcrdma svcrdma: Replace GFP_KERNEL in a loop with GFP_NOFAIL svcrdma: Keep rpcrdma_msg fields in network byte-order svcrdma: Fix byte-swapping in svc_rdma_sendto.c nfsd: Update callback sequnce id only CB_SEQUENCE success nfsd: Reset cb_status in nfsd4_cb_prepare() at retrying svcrdma: Remove svc_rdma_xdr_decode_deferred_req() SUNRPC: Move EXPORT_SYMBOL for svc_process uapi/nfs: Add NFSv4.1 ACL definitions nfsd: Remove dead declarations nfsd: work around a gcc-5.1 warning nfsd: Checking for acl support does not require fetching any acls ...
2015-06-26Merge branch 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue updates from Tejun Heo: "Most of the changes are around implementing and fixing fallouts from sysfs and internal interface to limit the CPUs available to all unbound workqueues to help isolating CPUs. It needs more work as ordered workqueues can roam unrestricted but still is a significant improvement" * 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix typos in comments workqueue: move flush_scheduled_work() to workqueue.h workqueue: remove the lock from wq_sysfs_prep_attrs() workqueue: remove the declaration of copy_workqueue_attrs() workqueue: ensure attrs changes are properly synchronized workqueue: separate out and refactor the locking of applying attrs workqueue: simplify wq_update_unbound_numa() workqueue: wq_pool_mutex protects the attrs-installation workqueue: fix a typo workqueue: function name in the comment differs from the real function name workqueue: fix trivial typo in Documentation/workqueue.txt workqueue: Allow modifying low level unbound workqueue cpumask workqueue: Create low-level unbound workqueues cpumask workqueue: split apply_workqueue_attrs() into 3 stages
2015-06-26Merge branch 'for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - threadgroup_lock got reorganized so that its users can pick the actual locking mechanism to use. Its only user - cgroups - is updated to use a percpu_rwsem instead of per-process rwsem. This makes things a bit lighter on hot paths and allows cgroups to perform and fail multi-task (a process) migrations atomically. Multi-task migrations are used in several places including the unified hierarchy. - Delegation rule and documentation added to unified hierarchy. This will likely be the last interface update from the cgroup core side for unified hierarchy before lifting the devel mask. - Some groundwork for the pids controller which is scheduled to be merged in the coming devel cycle. * 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: add delegation section to unified hierarchy documentation cgroup: require write perm on common ancestor when moving processes on the default hierarchy cgroup: separate out cgroup_procs_write_permission() from __cgroup_procs_write() kernfs: make kernfs_get_inode() public MAINTAINERS: add a cgroup core co-maintainer cgroup: fix uninitialised iterator in for_each_subsys_which cgroup: replace explicit ss_mask checking with for_each_subsys_which cgroup: use bitmask to filter for_each_subsys cgroup: add seq_file forward declaration for struct cftype cgroup: simplify threadgroup locking sched, cgroup: replace signal_struct->group_rwsem with a global percpu_rwsem sched, cgroup: reorganize threadgroup locking cgroup: switch to unsigned long for bitmasks cgroup: reorganize include/linux/cgroup.h cgroup: separate out include/linux/cgroup-defs.h cgroup: fix some comment typos
2015-06-26Merge tag 'dma-buf-for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sumits/dma-buf Pull dma-buf updates from Sumit Semwal: "Minor changes for 4.2 - add ref-counting for kernel modules as exporters - minor code style fixes" * tag 'dma-buf-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/sumits/dma-buf: dma-buf: Minor coding style fixes dma-buf: add ref counting for module as exporter
2015-06-26Merge tag 'usb-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB updates from Greg KH: "Here's the big USB patchset for 4.2-rc1. As is normal these days, the majority of changes are in the gadget drivers, with a bunch of other small driver changes. All of these have been in linux-next with no reported issues" * tag 'usb-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (175 commits) usb: dwc3: Use ASCII space in Kconfig usb: chipidea: add work-around for Marvell HSIC PHY startup usb: chipidea: allow multiple instances to use default ci_default_pdata dt-bindings: Consolidate ChipIdea USB ci13xxx bindings phy: add Marvell HSIC 28nm PHY phy: Add Marvell USB 2.0 OTG 28nm PHY dt-bindings: Add Marvell PXA1928 USB and HSIC PHY bindings USB: ssb: use devm_kzalloc USB: ssb: fix error handling in ssb_hcd_create_pdev() usb: isp1760: check for null return from kzalloc cdc-acm: Add support of ATOL FPrint fiscal printers usb: chipidea: usbmisc_imx: Remove unneeded semicolon USB: usbtmc: add device quirk for Rigol DS6104 USB: serial: mos7840: Use setup_timer phy: twl4030-usb: add ABI documentation phy: twl4030-usb: remove incorrect pm_runtime_get_sync() in probe function. phy: twl4030-usb: remove pointless 'suspended' test in 'suspend' callback. phy: twl4030-usb: make runtime pm more reliable. drivers:usb:fsl: Fix compilation error for fsl ehci drv usb: renesas_usbhs: Don't disable the pipe if Control write status stage ...
2015-06-26Merge tag 'tty-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver updates from Greg KH: "Here's the tty and serial driver patches for 4.2-rc1. A number of individual driver updates, some code cleanups, and other minor things, full details in the shortlog. All have been in linux-next for a while with no reported issues" * tag 'tty-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (152 commits) Doc: serial-rs485.txt: update RS485 driver interface Doc: tty.txt: remove mention of the BKL MAINTAINERS: tty: add serial docs directory serial: sprd: check for NULL after calling devm_clk_get serial: 8250_pci: Correct uartclk for xr17v35x expansion chips serial: 8250_pci: Add support for 12 port Exar boards serial: 8250_uniphier: add bindings document for UniPhier UART serial: core: cleanup in uart_get_baud_rate() serial: stm32-usart: Add STM32 USART Driver tty/serial: kill off set_irq_flags usage tty: move linux/gsmmux.h to uapi doc: dt: add documentation for nxp,lpc1850-uart serial: 8250: add LPC18xx/43xx UART driver serial: 8250_uniphier: add UniPhier serial driver serial: 8250_dw: support ACPI platforms with integrated DMA engine serial: of_serial: check the return value of clk_prepare_enable() serial: of_serial: use devm_clk_get() instead of clk_get() serial: earlycon: Add support for big-endian MMIO accesses serial: sirf: use hrtimer for data rx serial: sirf: correct the fifo empty_bit ...
2015-06-26Merge tag 'staging-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver updates from Greg KH: "Here's the big, really big, staging tree patches for 4.2-rc1. Loads of stuff in here, almost all just coding style fixes / churn, and a few new drivers as well, one of which I just disabled from the build a few minutes ago due to way too many build warnings. Other than the one "disable this driver" patch, all of these have been in linux-next for quite a while with no reported issues" * tag 'staging-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1163 commits) staging: wilc1000: disable driver due to build warnings Staging: rts5208: fix CHANGE_LINK_STATE value Staging: sm750fb: ddk750_swi2c.c: Insert spaces before parenthesis Staging: sm750fb: ddk750_swi2c.c: Place braces on correct lines Staging: sm750fb: ddk750_swi2c.c: Insert spaces around operators Staging: sm750fb: ddk750_swi2c.c: Replace spaces with tabs Staging: sm750fb: ddk750_swi2c.h: Shorten lines to under 80 characters Staging: sm750fb: ddk750_swi2c.h: Replace spaces with tabs Staging: sm750fb: modedb.h: Shorten lines to under 80 characters Staging: sm750fb: modedb.h: Replace spaces with tabs staging: comedi: addi_apci_3120: rename 'this_board' variables staging: comedi: addi_apci_1516: rename 'this_board' variables staging: comedi: ni_atmio: cleanup ni_getboardtype() staging: comedi: vmk80xx: sanity check context used to get the boardinfo staging: comedi: vmk80xx: rename 'boardinfo' variables staging: comedi: dt3000: rename 'this_board' variables staging: comedi: adv_pci_dio: rename 'this_board' variables staging: comedi: cb_pcidas64: rename 'thisboard' variables staging: comedi: cb_pcidas: rename 'thisboard' variables staging: comedi: me4000: rename 'thisboard' variables ...
2015-06-26Merge tag 'driver-core-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here is the driver core / firmware changes for 4.2-rc1. A number of small changes all over the place in the driver core, and in the firmware subsystem. Nothing really major, full details in the shortlog. Some of it is a bit of churn, given that the platform driver probing changes was found to not work well, so they were reverted. All of these have been in linux-next for a while with no reported issues" * tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits) Revert "base/platform: Only insert MEM and IO resources" Revert "base/platform: Continue on insert_resource() error" Revert "of/platform: Use platform_device interface" Revert "base/platform: Remove code duplication" firmware: add missing kfree for work on async call fs: sysfs: don't pass count == 0 to bin file readers base:dd - Fix for typo in comment to function driver_deferred_probe_trigger(). base/platform: Remove code duplication of/platform: Use platform_device interface base/platform: Continue on insert_resource() error base/platform: Only insert MEM and IO resources firmware: use const for remaining firmware names firmware: fix possible use after free on name on asynchronous request firmware: check for file truncation on direct firmware loading firmware: fix __getname() missing failure check drivers: of/base: move of_init to driver_init drivers/base: cacheinfo: fix annoying typo when DT nodes are absent sysfs: disambiguate between "error code" and "failure" in comments driver-core: fix build for !CONFIG_MODULES driver-core: make __device_attach() static ...
2015-06-26Merge tag 'char-misc-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver pull request for 4.2-rc1. Lots of mei, extcon, coresight, uio, mic, and other driver updates in here. Full details in the shortlog. All of these have been in linux-next for some time with no reported problems" * tag 'char-misc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (176 commits) mei: me: wait for power gating exit confirmation mei: reset flow control on the last client disconnection MAINTAINERS: mei: add mei_cl_bus.h to maintained file list misc: sram: sort and clean up included headers misc: sram: move reserved block logic out of probe function misc: sram: add private struct device and virt_base members misc: sram: report correct SRAM pool size misc: sram: bump error message level on unclean driver unbinding misc: sram: fix device node reference leak on error misc: sram: fix enabled clock leak on error path misc: mic: Fix reported static checker warning misc: mic: Fix randconfig build error by including errno.h uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from config uio: pruss: Add CONFIG_HAS_IOMEM dependence uio: pruss: Include <linux/sizes.h> extcon: Redefine the unique id of supported external connectors without 'enum extcon' type char:xilinx_hwicap:buffer_icap - change 1/0 to true/false for bool type variable in function buffer_icap_set_configuration(). Drivers: hv: vmbus: Allocate ring buffer memory in NUMA aware fashion parport: check exclusive access before register w1: use correct lock on error in w1_seq_show() ...
2015-06-26Merge tag 'trace-v4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "This patch series contains several clean ups and even a new trace clock "monitonic raw". Also some enhancements to make the ring buffer even faster. But the biggest and most noticeable change is the renaming of the ftrace* files, structures and variables that have to deal with trace events. Over the years I've had several developers tell me about their confusion with what ftrace is compared to events. Technically, "ftrace" is the infrastructure to do the function hooks, which include tracing and also helps with live kernel patching. But the trace events are a separate entity altogether, and the files that affect the trace events should not be named "ftrace". These include: include/trace/ftrace.h -> include/trace/trace_events.h include/linux/ftrace_event.h -> include/linux/trace_events.h Also, functions that are specific for trace events have also been renamed: ftrace_print_*() -> trace_print_*() (un)register_ftrace_event() -> (un)register_trace_event() ftrace_event_name() -> trace_event_name() ftrace_trigger_soft_disabled() -> trace_trigger_soft_disabled() ftrace_define_fields_##call() -> trace_define_fields_##call() ftrace_get_offsets_##call() -> trace_get_offsets_##call() Structures have been renamed: ftrace_event_file -> trace_event_file ftrace_event_{call,class} -> trace_event_{call,class} ftrace_event_buffer -> trace_event_buffer ftrace_subsystem_dir -> trace_subsystem_dir ftrace_event_raw_##call -> trace_event_raw_##call ftrace_event_data_offset_##call-> trace_event_data_offset_##call ftrace_event_type_funcs_##call -> trace_event_type_funcs_##call And a few various variables and flags have also been updated. This has been sitting in linux-next for some time, and I have not heard a single complaint about this rename breaking anything. Mostly because these functions, variables and structures are mostly internal to the tracing system and are seldom (if ever) used by anything external to that" * tag 'trace-v4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (33 commits) ring_buffer: Allow to exit the ring buffer benchmark immediately ring-buffer-benchmark: Fix the wrong type ring-buffer-benchmark: Fix the wrong param in module_param ring-buffer: Add enum names for the context levels ring-buffer: Remove useless unused tracing_off_permanent() ring-buffer: Give NMIs a chance to lock the reader_lock ring-buffer: Add trace_recursive checks to ring_buffer_write() ring-buffer: Allways do the trace_recursive checks ring-buffer: Move recursive check to per_cpu descriptor ring-buffer: Add unlikelys to make fast path the default tracing: Rename ftrace_get_offsets_##call() to trace_event_get_offsets_##call() tracing: Rename ftrace_define_fields_##call() to trace_event_define_fields_##call() tracing: Rename ftrace_event_type_funcs_##call to trace_event_type_funcs_##call tracing: Rename ftrace_data_offset_##call to trace_event_data_offset_##call tracing: Rename ftrace_raw_##call event structures to trace_event_raw_##call tracing: Rename ftrace_trigger_soft_disabled() to trace_trigger_soft_disabled() tracing: Rename FTRACE_EVENT_FL_* flags to EVENT_FILE_FL_* tracing: Rename struct ftrace_subsystem_dir to trace_subsystem_dir tracing: Rename ftrace_event_name() to trace_event_name() tracing: Rename FTRACE_MAX_EVENT to TRACE_EVENT_TYPE_MAX ...
