path: root/include
2012-09-19ARM: omap: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the omap include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Kevin Hilman <khilman@ti.com> Cc: "Benoît Cousson" <b-cousson@ti.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Jean Pihet <j-pihet@ti.com> Cc: J Keerthy <j-keerthy@ti.com> Cc: linux-omap@vger.kernel.org
2012-09-16Merge tag 'omap-cleanup-sparseirq-for-v3.7' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup From Tony Lindgren: This branch contains changes needed to make omap2+ work properly with sparse IRQ. It also removes dependencies to mach/hardware.h. These help moving things towards ARM single zImage support. This branch is based on a commit in tty-next branch with omap-devel-gpmc-fixed-for-v3.7 and cleanup-omap-tags-for-v3.7 merged in to keep things compiling and sort out some merge conflicts. * tag 'omap-cleanup-sparseirq-for-v3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP1: Move SoC specific headers from plat to mach for omap1 ARM: OMAP2+ Move SoC specific headers to be local to mach-omap2 ARM: OMAP: Split plat/hardware.h, use local soc.h for omap2+ ARM: OMAP: Remove unused old gpio-switch.h ARM: OMAP1: Move plat/irqs.h to mach/irqs.h ARM: OMAP2+: Remove hardcoded IRQs and enable SPARSE_IRQ ARM: OMAP2+: Prepare for irqs.h removal W1: OMAP HDQ1W: Remove dependencies to mach/hardware.h Input: omap-keypad: Remove dependencies to mach includes ARM: OMAP: Move gpio.h to include/linux/platform_data ARM: OMAP2+: Remove hardcoded twl4030 gpio_base, irq_base and irq_end ARM: OMAP2+: Remove unused nand_irq for GPMC ARM: OMAP2+: Make INTCPS_NR_IRQS local for mach-omap2/irq.c ARM: OMAP1: Define OMAP1_INT_I2C locally ARM: OMAP1: Move define of OMAP_LCD_DMA to dma.h
2012-09-16Merge branch 'depends/tty-omap-serial' into next/cleanupOlof Johansson
This part of the tty tree (unfortunately with all the preceding patches as well) is a dependency for some of the OMAP cleanups, so we've pulled it in as a dependency based on agreement with Greg. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-16Merge tag 'cleanup-omap-tags-for-v3.7' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup From Tony Lindgren: Remove the ancient omap specific atags that are no longer needed. At some point we were planning to pass the bootloader information with custom atags that did not work out too well. There's no need for these any longer as the kernel has been booting fine without them for quite some time. And Now we have device tree support that can be used instead. * tag 'cleanup-omap-tags-for-v3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP: remove plat/board.h file ARM: OMAP: move debug_card_init() function ARM: OMAP1: move lcd pdata out of arch/arm/* ARM: OMAP1: move omap1_bl pdata out of arch/arm/* ARM: OMAP: remove the omap custom tags ARM: OMAP1: remove the crystal type tag parsing ARM: OMAP: remove the sti console workaround ARM: OMAP: omap3evm: cleanup revision bits ARM: OMAP: cleanup struct omap_board_config_kernel + sync to 3.6-rc5
2012-09-16Merge branch 'depends/tps6589x-dt' into next/cleanupOlof Johansson
Pull in a dependent branch from Mark Brown's regulator tree for the tegra/cleanup branch. * depends/tps6589x-dt: regulator: tps6586x: add support for SYS rail
2012-09-12Merge branch 'clk' of git://github.com/hzhuang1/linux into next/cleanupOlof Johansson
* 'clk' of git://github.com/hzhuang1/linux: ARM: mmp: remove unused definition in APBC and APMU ARM: mmp: move mmp2 clock definition to separated file arm: mmp: move pxa910 clock definition to separated file arm: mmp: move pxa168 clock definition to separated file arm: mmp: make private clock definition exclude from common clock + Linux 3.6-rc4
2012-09-12ARM: OMAP: Move gpio.h to include/linux/platform_dataTony Lindgren
This way we can remove includes of plat/gpio.h which won't work with the single zImage support. Note that we also remove the cpu_class_is_omap2() check in gpio-omap.c as the drivers should not call it as we need to make it local to arch/arm/mach-omap2 for single zImage support. While at it, arrange the related includes in the standard way. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: linux-mtd@lists.infradead.org Cc: alsa-devel@alsa-project.org Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-12ARM: OMAP2+: Remove hardcoded twl4030 gpio_base, irq_base and irq_endTony Lindgren
We can't use hardcoded interrupts for SPARSE_IRQ, and can replace the hardcoded gpio_base with twl_gpiochip.base after it's been allocated. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-12Merge tags 'omap-devel-gpmc-fixed-for-v3.7' and 'cleanup-omap-tags-for-v3.7' ↵Tony Lindgren
into cleanup-sparseirq Changes for GPMC (General Purpose Memory Controller) that take it closer for being just a regular device driver. Remove the ancient omap specific atags that are no longer needed. At some point we were planning to pass the bootloader information with custom atags that did not work out too well. There's no need for these any longer as the kernel has been booting fine without them for quite some time. And Now we have device tree support that can be used instead.
2012-09-10ARM: OMAP1: move lcd pdata out of arch/arm/*Igor Grinberg
omap1 lcd platform data resides inside plat/board.h while it should be inside include/linux/... Move the omap1 lcd platform data to include/linux/omapfb.h. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-10ARM: OMAP1: move omap1_bl pdata out of arch/arm/*Igor Grinberg
omap1 backlight platform data resides inside plat/board.h while it should be inside include/linux/... Move the omap1 backlight platform data to include/linux/platform_data/. Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: linux-fbdev@vger.kernel.org Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-10serial: pl011: delete reset callbackLinus Walleij
Since commit 4fd0690bb0c3955983560bb2767ee82e2b197f9b "serial: pl011: implement workaround for CTS clear event issue" the PL011 UART is no longer at risk to hang up, so get rid of the callback altogether. Cc: Rajanikanth H.V <rajanikanth.hv@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-06tty_register_device_attr updated for tty-nextTomas Hlavacek
Added tty_device_create_release() and bound to dev->release in tty_register_device_attr(). Added tty_port_register_device_attr() and used in uart_add_one_port() instead of tty_register_device_attr(). Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-06Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull a hwmon fix from Guenter Roeck: "One patch, fixing DIV_ROUND_CLOSEST to support negative dividends. While the changes are not in the drivers/hwmon directory, the problem primarily affects hwmon drivers, and it makes sense to push the patch through the hwmon tree." * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: linux/kernel.h: Fix DIV_ROUND_CLOSEST to support negative dividends
2012-09-06tty: uartclk value from serial_core exposed to sysfsTomas Hlavacek
Added file /sys/devices/.../tty/ttySX/uartclk to allow reading uartclk value in struct uart_port in serial_core via sysfs. tty_register_device() has been generalized and refactored in order to add support for setting drvdata and attribute_group to the device. Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-06serial: add OMAP-specific definesFelipe Balbi
OMAP has some extra Interrupt types which can be really useful for SW. Let's define them so we can later use those in OMAP's serial driver. Tested-by: Shubhrajyoti D <shubhrajyoti@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05Merge tag 'mmc-fixes-for-3.6-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC fixes from Chris Ball: - a firmware bug on several Samsung MoviNAND eMMC models causes permanent corruption on the device when secure erase and secure trim requests are made, so we disable those requests on these eMMC devices. - atmel-mci: fix a hang with some SD cards by waiting for not-busy flag. - dw_mmc: low-power mode breaks SDIO interrupts; fix PIO error handling; fix handling of error interrupts. - mxs-mmc: fix deadlocks; fix compile error due to dma.h arch change. - omap: fix broken PIO mode causing memory corruption. - sdhci-esdhc: fix card detection. * tag 'mmc-fixes-for-3.6-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: omap: fix broken PIO mode mmc: card: Skip secure erase on MoviNAND; causes unrecoverable corruption. mmc: dw_mmc: Disable low power mode if SDIO interrupts are used mmc: dw_mmc: fix error handling in PIO mode mmc: dw_mmc: correct mishandling error interrupt mmc: dw_mmc: amend using error interrupt status mmc: atmel-mci: not busy flag has also to be used for read operations mmc: sdhci-esdhc: break out early if clock is 0 mmc: mxs-mmc: fix deadlock caused by recursion loop mmc: mxs-mmc: fix deadlock in SDIO IRQ case mmc: bfin_sdh: fix dma_desc_array build error
2012-09-06regulator: tps6586x: add support for SYS railLaxman Dewangan
Device have SYS rail which is always ON. It is system power bus. LDO5 and LDO_RTC get powered through this rail internally. Add support for this rail and make the LDO5/LDO_RTC supply by it. Update document accordingly. [swarren: Instantiate the sys regulator from board-harmony-power.c to avoid regression.] Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-09-05serial: add a new helper functionHuang Shijie
In most of the time, the driver needs to check if the cts flow control is enabled. But now, the driver checks the ASYNC_CTS_FLOW flag manually, which is not a grace way. So add a new wraper function to make the code tidy and clean. Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05serial: New serial driver SCCNXPAlexander Shiyan
This driver is a replacement for a SC26XX driver with a lot of improvements and new features. The main differences from the SC26XX driver: - Removed dependency on MIPS. Driver can be used on any platform. - Added support for SCC2681, SCC2691, SCC2692, SC28L91, SC28L92, SC28L202, SCC68681 and SCC68692 ICs. - Using devm_-related functions. - Improved error handling of serial port, improved FIFO handling. - Ability to load multiple instances of drivers. To avoid the possibility of regression, driver SC26XX left in the system to confirm the stability of the driver on platforms where it is being used. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05serial: diminish usage of struct serial_uart_configPaul Gortmaker
This structure might have made sense many years ago, but at this point it is only used in one specific driver, and referenced in stale comments elsewhere. Rather than change the sunsu.c driver, simply move the struct to be within the exclusive domain of that driver, so it won't get inadvertently picked up and used by other serial drivers going forward. The comments referencing the now driver specific struct are updated accordingly. Note that 8250.c has a struct that is similar in usage, with the name serial8250_config; but is 100% independent and untouched here. Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05tty: move the async flags from the serial code into the tty includesAlan Cox
These are used with the tty_port flags which are tty generic so move the flags into a more sensible place. This then makes it possible to add helpers such as those suggested by Huang Shijie. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-04mmc: card: Skip secure erase on MoviNAND; causes unrecoverable corruption.Ian Chen
For several MoviNAND eMMC parts, there are known issues with secure erase and secure trim. For these specific MoviNAND devices, we skip these operations. Specifically, there is a bug in the eMMC firmware that causes unrecoverable corruption when the MMC is erased with MMC_CAP_ERASE enabled. References: http://forum.xda-developers.com/showthread.php?t=1644364 https://plus.google.com/111398485184813224730/posts/21pTYfTsCkB#111398485184813224730/posts/21pTYfTsCkB Signed-off-by: Ian Chen <ian.cy.chen@samsung.com> Reviewed-by: Namjae Jeon <linkinjeon@gmail.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Cc: stable <stable@vger.kernel.org> [3.0+] Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04Merge branch 'cleanup/io-pci' into next/cleanupArnd Bergmann
The io-pci series has gained a merge to resolve a nontrivial conflict. * cleanup/io-pci: ARM: Fix ioremap() of address zero Also includes an update to Linux 3.6-rc3 Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-09-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) NLA_PUT* --> nla_put_* conversion got one case wrong in nfnetlink_log, fix from Patrick McHardy. 2) Missed error return check in ipw2100 driver, from Julia Lawall. 3) PMTU updates in ipv4 were setting the expiry time incorrectly, fix from Eric Dumazet. 4) SFC driver erroneously reversed src and dst when reporting filters via ethtool. 5) Memory leak in CAN protocol and wrong setting of IRQF_SHARED in sja1000 can platform driver, from Alexey Khoroshilov and Sven Schmitt. 6) Fix multicast traffic scaling regression in ipv4_dst_destroy, only take the lock when we really need to. From Eric Dumazet. 7) Fix non-root process spoofing in netlink, from Pablo Neira Ayuso. 8) CWND reduction in TCP is done incorrectly during non-SACK recovery, fix from Yuchung Cheng. 9) Revert netpoll change, and fix what was actually a driver specific problem. From Amerigo Wang. This should cure bootup hangs with netconsole some people reported. 10) Fix xen-netfront invoking __skb_fill_page_desc() with a NULL page pointer. From Ian Campbell. 11) SIP NAT fix for expectiontation creation, from Pablo Neira Ayuso. 12) __ip_rt_update_pmtu() needs RCU locking, from Eric Dumazet. 13) Fix usbnet deadlock on resume, can't use GFP_KERNEL in this situation. From Oliver Neukum. 14) The davinci ethernet driver triggers an OOPS on removal because it frees an MDIO object before unregistering it. Fix from Bin Liu. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (41 commits) net: qmi_wwan: add several new Gobi devices fddi: 64 bit bug in smt_add_para() net: ethernet: fix kernel OOPS when remove davinci_mdio module net/xfrm/xfrm_state.c: fix error return code net: ipv6: fix error return code net: qmi_wwan: new device: Foxconn/Novatel E396 usbnet: fix deadlock in resume cs89x0 : packet reception not working netfilter: nf_conntrack: fix racy timer handling with reliable events bnx2x: Correct the ndo_poll_controller call bnx2x: Move netif_napi_add to the open call ipv4: must use rcu protection while calling fib_lookup bnx2x: fix 57840_MF pci id net: ipv4: ipmr_expire_timer causes crash when removing net namespace e1000e: DoS while TSO enabled caused by link partner with small MSS l2tp: avoid to use synchronize_rcu in tunnel free function gianfar: fix default tx vlan offload feature flag netfilter: nf_nat_sip: fix incorrect handling of EBUSY for RTCP expectation xen-netfront: use __pskb_pull_tail to ensure linear area is big enough on RX netfilter: nfnetlink_log: fix error return code in init path ...
2012-09-01linux/kernel.h: Fix DIV_ROUND_CLOSEST to support negative dividendsGuenter Roeck
DIV_ROUND_CLOSEST returns a bad result for negative dividends: DIV_ROUND_CLOSEST(-2, 2) = 0 Most of the time this does not matter. However, in the hardware monitoring subsystem, DIV_ROUND_CLOSEST is sometimes used on integers which can be negative (such as temperatures). Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-09-01time: Move ktime_t overflow checking into timespec_valid_strictJohn Stultz
Andreas Bombe reported that the added ktime_t overflow checking added to timespec_valid in commit 4e8b14526ca7 ("time: Improve sanity checking of timekeeping inputs") was causing problems with X.org because it caused timeouts larger then KTIME_T to be invalid. Previously, these large timeouts would be clamped to KTIME_MAX and would never expire, which is valid. This patch splits the ktime_t overflow checking into a new timespec_valid_strict function, and converts the timekeeping codes internal checking to use this more strict function. Reported-and-tested-by: Andreas Bombe <aeb@debian.org> Cc: Zhouping Liu <zliu@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-31Merge branch 'master' of git://1984.lsi.us.es/nfDavid S. Miller
2012-08-31netfilter: nf_conntrack: fix racy timer handling with reliable eventsPablo Neira Ayuso
Existing code assumes that del_timer returns true for alive conntrack entries. However, this is not true if reliable events are enabled. In that case, del_timer may return true for entries that were just inserted in the dying list. Note that packets / ctnetlink may hold references to conntrack entries that were just inserted to such list. This patch fixes the issue by adding an independent timer for event delivery. This increases the size of the ecache extension. Still we can revisit this later and use variable size extensions to allocate this area on demand. Tested-by: Oliver Smith <olipro@8.c.9.b.0.7.4.0.1.0.0.2.ip6.arpa> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-08-30bnx2x: fix 57840_MF pci idYuval Mintz
Commit c3def943c7117d42caaed3478731ea7c3c87190e have added support for new pci ids of the 57840 board, while failing to change the obsolete value in 'pci_ids.h'. This patch does so, allowing the probe of such devices. Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "A bunch of scattered fixes ati/intel/nouveau, couple of core ones, nothing too shocking or different." * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm: Add EDID_QUIRK_FORCE_REDUCED_BLANKING for ASUS VW222S gma500: Consider CRTC initially active. drm/radeon: fix dig encoder selection on DCE61 drm/radeon: fix double free in radeon_gpu_reset drm/radeon: force dma32 to fix regression rs4xx,rs6xx,rs740 drm/radeon: rework panel mode setup drm/radeon/atom: powergating fixes for DCE6 drm/radeon/atom: rework DIG modesetting on DCE3+ drm/radeon: don't disable plls that are in use by other crtcs drm/radeon: add proper checking of RESOLVE_BOX command for r600-r700 drm/radeon: initialize tracked CS state drm/radeon: fix reading CB_COLORn_MASK from the CS drm/nvc0/copy: check PUNITS to determine which copy engines are disabled i915: Quirk no_lvds on Gigabyte GA-D525TUD ITX motherboard drm/i915: Use the correct size of the GTT for placing the per-process entries drm: Check for invalid cursor flags drm: Initialize object type when using DRM_MODE() macro drm/i915: fix color order for BGR formats on IVB drm/i915: fix wrong order of parameters in port checking functions
2012-08-27Merge 3.6-rc3 into tty-nextGreg Kroah-Hartman
This picks up all of the different fixes in Linus's tree that we also need here. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-25Merge tag 'fixes-3.6-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull arm-soc fixes from Arnd Bergmann: "Bug fixes for various ARM platforms. About half of these are for OMAP and submitted before but did not make it into v3.6-rc2." * tag 'fixes-3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (39 commits) ARM: ux500: don't select LEDS_GPIO for snowball ARM: imx: build i.MX6 functions only when needed ARM: imx: select CPU_FREQ_TABLE when needed ARM: imx: fix ksz9021rn_phy_fixup ARM: imx: build pm-imx5 code only when PM is enabled ARM: omap: allow building omap44xx without SMP ARM: dts: imx51-babbage: fix esdhc cd/wp properties ARM: imx6: spin the cpu until hardware takes it down ARM: ux500: Ensure probing of Audio devices when Device Tree is enabled ARM: ux500: Fix merge error, no matching driver name for 'snd_soc_u8500' ARM i.MX6q: Add virtual 1/3.5 dividers in the LDB clock path ARM: Kirkwood: fix Makefile.boot ARM: Kirkwood: Fix iconnect leds ARM: Orion: Set eth packet size csum offload limit ARM: mv78xx0: fix win_cfg_base prototype ARM: OMAP: dmtimers: Fix locking issue in omap_dm_timer_request*() ARM: mmp: fix potential NULL dereference ARM: OMAP4: Register the OPP table only for 4430 device cpufreq: OMAP: Handle missing frequency table on SMP systems ARM: OMAP4: sleep: Save the complete used register stack frame ...
2012-08-25Merge tag 'stable/for-linus-3.6-rc3-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull three xen bug-fixes from Konrad Rzeszutek Wilk: - Revert the kexec fix which caused on non-kexec shutdowns a race. - Reuse existing P2M leafs - instead of requiring to allocate a large area of bootup virtual address estate. - Fix a one-off error when adding PFNs for balloon pages. * tag 'stable/for-linus-3.6-rc3-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/setup: Fix one-off error when adding for-balloon PFNs to the P2M. xen/p2m: Reuse existing P2M leafs if they are filled with 1:1 PFNs or INVALID. Revert "xen PVonHVM: move shared_info to MMIO before kexec"
2012-08-25Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block-related fixes from Jens Axboe: - Improvements to the buffered and direct write IO plugging from Fengguang. - Abstract out the mapping of a bio in a request, and use that to provide a blk_bio_map_sg() helper. Useful for mapping just a bio instead of a full request. - Regression fix from Hugh, fixing up a patch that went into the previous release cycle (and marked stable, too) attempting to prevent a loop in __getblk_slow(). - Updates to discard requests, fixing up the sizing and how we align them. Also a change to disallow merging of discard requests, since that doesn't really work properly yet. - A few drbd fixes. - Documentation updates. * 'for-linus' of git://git.kernel.dk/linux-block: block: replace __getblk_slow misfix by grow_dev_page fix drbd: Write all pages of the bitmap after an online resize drbd: Finish requests that completed while IO was frozen drbd: fix drbd wire compatibility for empty flushes Documentation: update tunable options in block/cfq-iosched.txt Documentation: update tunable options in block/cfq-iosched.txt Documentation: update missing index files in block/00-INDEX block: move down direct IO plugging block: remove plugging at buffered write time block: disable discard request merge temporarily bio: Fix potential memory leak in bio_find_or_create_slab() block: Don't use static to define "void *p" in show_partition_start() block: Add blk_bio_map_sg() helper block: Introduce __blk_segment_map_sg() helper fs/block-dev.c:fix performance regression in O_DIRECT writes to md block devices block: split discard into aligned requests block: reorganize rounding of max_discard_sectors
2012-08-23Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: "Mostly small fixes for the fallout of the timekeeping overhaul in 3.6 along with stable fixes to address an accumulation problem and missing sanity checks for RTC readouts and user space provided values." * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: time: Avoid making adjustments if we haven't accumulated anything time: Avoid potential shift overflow with large shift values time: Fix casting issue in timekeeping_forward_now time: Ensure we normalize the timekeeper in tk_xtime_add time: Improve sanity checking of timekeeping inputs
2012-08-24drm: Check for invalid cursor flagsJakob Bornecrantz
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-08-24drm: Initialize object type when using DRM_MODE() macroVille Syrjälä
DRM_MODE() macro doesn't initialize the type of the base drm object. When a copy is made of the mode, the object type is overwritten with zero, and the the object can no longer be found by drm_mode_object_find() due to the type check failing. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-08-23Merge branch 'randconfig/mach' into fixesArnd Bergmann
Small platform specific bug fixes for problems found in randconfig builds. * randconfig/mach: ARM: ux500: don't select LEDS_GPIO for snowball ARM: imx: build i.MX6 functions only when needed ARM: imx: select CPU_FREQ_TABLE when needed ARM: imx: fix ksz9021rn_phy_fixup ARM: imx: build pm-imx5 code only when PM is enabled ARM: omap: allow building omap44xx without SMP Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-23ARM: omap: allow building omap44xx without SMPArnd Bergmann
The new omap4 cpuidle implementation currently requires ARCH_NEEDS_CPU_IDLE_COUPLED, which only works on SMP. This patch makes it possible to build a non-SMP kernel for that platform. This is not normally desired for end-users but can be useful for testing. Without this patch, building rand-0y2jSKT results in: drivers/cpuidle/coupled.c: In function 'cpuidle_coupled_poke': drivers/cpuidle/coupled.c:317:3: error: implicit declaration of function '__smp_call_function_single' [-Werror=implicit-function-declaration] It's not clear if this patch is the best solution for the problem at hand. I have made sure that we can now build the kernel in all configurations, but that does not mean it will actually work on an OMAP44xx. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Cc: Tony Lindgren <tony@atomide.com>
2012-08-23Merge branch 'imx/fixes-for-3.6' of ↵Arnd Bergmann
git://git.linaro.org/people/shawnguo/linux-2.6 into fixes * 'imx/fixes-for-3.6' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: dts: imx51-babbage: fix esdhc cd/wp properties ARM: imx6: spin the cpu until hardware takes it down ARM i.MX6q: Add virtual 1/3.5 dividers in the LDB clock path Also updates to Linux 3.6-rc2 Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-22Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Intel: edid fixes, power consumption fix, s/r fix, haswell fix Radeon: BIOS loading fixes for UEFI and Thunderbolt machines, better MSAA validation, lockup timeout fixes, modesetting fixes One udl dpms fix, one vmwgfx fix, a couple of trivial core changes. There is an export added to ACPI as part of the radeon bios fixes. I've also included the fbcon flashing cursor vs deinit race fix, that seems the simplest place to start" Trivial conflict in drivers/video/console/fbcon.c due to me having already applied the fbcon flashing cursor vs deinit race fix, and Dave had added a comment in there too. * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (22 commits) fbcon: fix race condition between console lock and cursor timer (v1.1) drm: Add missing static storage class specifiers in drm_proc.c file drm/udl: dpms off the crtc when disabled. drm: Remove two unused fields from struct drm_display_mode drm: stop vmgfx driver explosion drm/radeon/ss: use num_crtc rather than hardcoded 6 Revert "drm/radeon: fix bo creation retry path" drm/i915: use hsw rps tuning values everywhere on gen6+ drm/radeon: split ATRM support out from the ATPX handler (v3) drm/radeon: convert radeon vfct code to use acpi_get_table_with_size ACPI: export symbol acpi_get_table_with_size drm/radeon: implement ACPI VFCT vbios fetch (v3) drm/radeon/kms: extend the Fujitsu D3003-S2 board connector quirk to cover later silicon stepping drm/radeon: fix checking of MSAA renderbuffers on r600-r700 drm/radeon: allow CMASK and FMASK in the CS checker on r600-r700 drm/radeon: init lockup timeout on ring init drm/radeon: avoid turning off spread spectrum for used pll drm/i915: fall back to bit-banging if GMBUS fails in CRT EDID reads drm/i915: extract connector update from intel_ddc_get_modes() for reuse drm/i915: fix hsw uncached pte ...
2012-08-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull SCSI target fixes from Nicholas Bellinger: "The executive summary includes: - Post-merge review comments for tcm_vhost (MST + nab) - Avoid debugging overhead when not debugging for tcm-fc(FCoE) (MDR) - Fix NULL pointer dereference bug on alloc_page failulre (Yi Zou) - Fix REPORT_LUNs regression bug with pSCSI export (AlexE + nab) - Fix regression bug with handling of zero-length data CDBs (nab) - Fix vhost_scsi_target structure alignment (MST) Thanks again to everyone who contributed a bugfix patch, gave review feedback on tcm_vhost code, and/or reported a bug during their own testing over the last weeks. There is one other outstanding bug reported by Roland recently related to SCSI transfer length overflow handling, for which the current proposed bugfix has been left in queue pending further testing with other non iscsi-target based fabric drivers. As the patch is verified with loopback (local SGL memory from SCSI LLD) + tcm_qla2xxx (TCM allocated SGL memory mapped to PCI HW) fabric ports, it will be included into the next 3.6-rc-fixes PULL request." * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target: Remove unused se_cmd.cmd_spdtl tcm_fc: rcu_deref outside rcu lock/unlock section tcm_vhost: Fix vhost_scsi_target structure alignment target: Fix regression bug with handling of zero-length data CDBs target/pscsi: Fix bug with REPORT_LUNs handling for SCSI passthrough tcm_vhost: Change vhost_scsi_target->vhost_wwpn to char * target: fix NULL pointer dereference bug alloc_page() fails to get memory tcm_fc: Avoid debug overhead when not debugging tcm_vhost: Post-merge review changes requested by MST tcm_vhost: Fix incorrect IS_ERR() usage in vhost_scsi_map_iov_to_sgl
2012-08-22Merge tag 'nfs-for-3.6-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: - NFSv3 mounts need to fail if the FSINFO rpc call fails - Ensure that the NFS commit cache gets torn down when we unload the NFS module. - Fix memory scribble issues when interrupting a LAYOUTGET rpc call - Fix NFSv4 legacy idmapper regressions - Fix issues with the NFSv4 getacl command - Fix a regression when using the legacy "mount -t nfs4" * tag 'nfs-for-3.6-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv3: Ensure that do_proc_get_root() reports errors correctly NFSv4: Ensure that nfs4_alloc_client cleans up on error. NFS: return -ENOKEY when the upcall fails to map the name NFS: Clear key construction data if the idmap upcall fails NFSv4: Don't use private xdr_stream fields in decode_getacl NFSv4: Fix the acl cache size calculation NFSv4: Fix pointer arithmetic in decode_getacl NFS: Alias the nfs module to nfs4 NFS: Fix a regression when loading the NFS v4 module NFSv4.1: Remove a bogus BUG_ON() in nfs4_layoutreturn_done pnfs-obj: Better IO pattern in case of unaligned offset NFS41: add pg_layout_private to nfs_pageio_descriptor pnfs: nfs4_proc_layoutget returns void pnfs: defer release of pages in layoutget nfs: tear down caches in nfs_init_writepagecache when allocation fails
2012-08-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull assorted fixes - mostly vfs - from Al Viro: "Assorted fixes, with an unexpected detour into vfio refcounting logics (fell out when digging in an analog of eventpoll race in there)." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: task_work: add a scheduling point in task_work_run() fs: fix fs/namei.c kernel-doc warnings eventpoll: use-after-possible-free in epoll_create1() vfio: grab vfio_device reference *before* exposing the sucker via fd_install() vfio: get rid of vfio_device_put()/vfio_group_get_device* races vfio: get rid of open-coding kref_put_mutex introduce kref_put_mutex() vfio: don't dereference after kfree... mqueue: lift mnt_want_write() outside ->i_mutex, clean up a bit
2012-08-22introduce kref_put_mutex()Al Viro
equivalent of mutex_lock(mutex); if (!kref_put(kref, release)) mutex_unlock(mutex); Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-08-21Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge fixes from Andrew Morton. Random drivers and some VM fixes. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (17 commits) mm: compaction: Abort async compaction if locks are contended or taking too long mm: have order > 0 compaction start near a pageblock with free pages rapidio/tsi721: fix unused variable compiler warning rapidio/tsi721: fix inbound doorbell interrupt handling drivers/rtc/rtc-rs5c348.c: fix hour decoding in 12-hour mode mm: correct page->pfmemalloc to fix deactivate_slab regression drivers/rtc/rtc-pcf2123.c: initialize dynamic sysfs attributes mm/compaction.c: fix deferring compaction mistake drivers/misc/sgi-xp/xpc_uv.c: SGI XPC fails to load when cpu 0 is out of IRQ resources string: do not export memweight() to userspace hugetlb: update hugetlbpage.txt checkpatch: add control statement test to SINGLE_STATEMENT_DO_WHILE_MACRO mm: hugetlbfs: correctly populate shared pmd cciss: fix incorrect scsi status reporting Documentation: update mount option in filesystem/vfat.txt mm: change nr_ptes BUG_ON to WARN_ON cs5535-clockevt: typo, it's MFGPT, not MFPGT
2012-08-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking update from David Miller: "A couple weeks of bug fixing in there. The largest chunk is all the broken crap Amerigo Wang found in the netpoll layer." 1) netpoll and it's users has several serious bugs: a) uses GFP_KERNEL with locks held b) interfaces requiring interrupts disabled are called with them enabled c) and vice versa d) VLAN tag demuxing, as per all other RX packet input paths, is not applied All from Amerigo Wang. 2) Hopefully cure the ipv4 mapped ipv6 address TCP early demux bugs for good, from Neal Cardwell. 3) Unlike AF_UNIX, AF_PACKET sockets don't set a default credentials when the user doesn't specify one explicitly during sendmsg(). Instead we attach an empty (zero) SCM credential block which is definitely not what we want. Fix from Eric Dumazet. 4) IPv6 illegally invokes netdevice notifiers with RCU lock held, fix from Ben Hutchings. 5) inet_csk_route_child_sock() checks wrong inet options pointer, fix from Christoph Paasch. 6) When AF_PACKET is used for transmit, packet loopback doesn't behave properly when a socket fanout is enabled, from Eric Leblond. 7) On bluetooth l2cap channel create failure, we leak the socket, from Jaganath Kanakkassery. 8) Fix all the netprio file handling bugs found by Al Viro, from John Fastabend. 9) Several error return and NULL deref bug fixes in networking drivers from Julia Lawall. 10) A large smattering of struct padding et al. kernel memory leaks to userspace found of Mathias Krause. 11) Conntrack expections in netfilter can access an uninitialized timer, fix from Pablo Neira Ayuso. 12) Several netfilter SIP tracker bug fixes from Patrick McHardy. 13) IPSEC ipv6 routes are not initialized correctly all the time, resulting in an OOPS in inet_putpeer(). Also from Patrick McHardy. 14) Bridging does rcu_dereference() outside of RCU protected area, from Stephen Hemminger. 15) Fix routing cache removal performance regression when looking up output routes that have a local destination. From Zheng Yan. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits) af_netlink: force credentials passing [CVE-2012-3520] ipv4: fix ip header ident selection in __ip_make_skb() ipv4: Use newinet->inet_opt in inet_csk_route_child_sock() tcp: fix possible socket refcount problem net: tcp: move sk_rx_dst_set call after tcp_create_openreq_child() net/core/dev.c: fix kernel-doc warning netconsole: remove a redundant netconsole_target_put() net: ipv6: fix oops in inet_putpeer() net/stmmac: fix issue of clk_get for Loongson1B. caif: Do not dereference NULL in chnl_recv_cb() af_packet: don't emit packet on orig fanout group drivers/net/irda: fix error return code drivers/net/wan/dscc4.c: fix error return code drivers/net/wimax/i2400m/fw.c: fix error return code smsc75xx: add missing entry to MAINTAINERS net: qmi_wwan: new devices: UML290 and K5006-Z net: sh_eth: Add eth support for R8A7779 device netdev/phy: skip disabled mdio-mux nodes dt: introduce for_each_available_child_of_node, of_get_next_available_child net: netprio: fix cgrp create and write priomap race ...
2012-08-21mm: compaction: Abort async compaction if locks are contended or taking too longMel Gorman
Jim Schutt reported a problem that pointed at compaction contending heavily on locks. The workload is straight-forward and in his own words; The systems in question have 24 SAS drives spread across 3 HBAs, running 24 Ceph OSD instances, one per drive. FWIW these servers are dual-socket Intel 5675 Xeons w/48 GB memory. I've got ~160 Ceph Linux clients doing dd simultaneously to a Ceph file system backed by 12 of these servers. Early in the test everything looks fine procs -------------------memory------------------ ---swap-- -----io---- --system-- -----cpu------- r b swpd free buff cache si so bi bo in cs us sy id wa st 31 15 0 287216 576 38606628 0 0 2 1158 2 14 1 3 95 0 0 27 15 0 225288 576 38583384 0 0 18 2222016 203357 134876 11 56 17 15 0 28 17 0 219256 576 38544736 0 0 11 2305932 203141 146296 11 49 23 17 0 6 18 0 215596 576 38552872 0 0 7 2363207 215264 166502 12 45 22 20 0 22 18 0 226984 576 38596404 0 0 3 2445741 223114 179527 12 43 23 22 0 and then it goes to pot procs -------------------memory------------------ ---swap-- -----io---- --system-- -----cpu------- r b swpd free buff cache si so bi bo in cs us sy id wa st 163 8 0 464308 576 36791368 0 0 11 22210 866 536 3 13 79 4 0 207 14 0 917752 576 36181928 0 0 712 1345376 134598 47367 7 90 1 2 0 123 12 0 685516 576 36296148 0 0 429 1386615 158494 60077 8 84 5 3 0 123 12 0 598572 576 36333728 0 0 1107 1233281 147542 62351 7 84 5 4 0 622 7 0 660768 576 36118264 0 0 557 1345548 151394 59353 7 85 4 3 0 223 11 0 283960 576 36463868 0 0 46 1107160 121846 33006 6 93 1 1 0 Note that system CPU usage is very high blocks being written out has dropped by 42%. He analysed this with perf and found perf record -g -a sleep 10 perf report --sort symbol --call-graph fractal,5 34.63% [k] _raw_spin_lock_irqsave | |--97.30%-- isolate_freepages | compaction_alloc | unmap_and_move | migrate_pages | compact_zone | compact_zone_order | try_to_compact_pages | __alloc_pages_direct_compact | __alloc_pages_slowpath | __alloc_pages_nodemask | alloc_pages_vma | do_huge_pmd_anonymous_page | handle_mm_fault | do_page_fault | page_fault | | | |--87.39%-- skb_copy_datagram_iovec | | tcp_recvmsg | | inet_recvmsg | | sock_recvmsg | | sys_recvfrom | | system_call | | __recv | | | | | --100.00%-- (nil) | | | --12.61%-- memcpy --2.70%-- [...] There was other data but primarily it is all showing that compaction is contended heavily on the zone->lock and zone->lru_lock. commit [b2eef8c0: mm: compaction: minimise the time IRQs are disabled while isolating pages for migration] noted that it was possible for migration to hold the lru_lock for an excessive amount of time. Very broadly speaking this patch expands the concept. This patch introduces compact_checklock_irqsave() to check if a lock is contended or the process needs to be scheduled. If either condition is true then async compaction is aborted and the caller is informed. The page allocator will fail a THP allocation if compaction failed due to contention. This patch also introduces compact_trylock_irqsave() which will acquire the lock only if it is not contended and the process does not need to schedule. Reported-by: Jim Schutt <jaschut@sandia.gov> Tested-by: Jim Schutt <jaschut@sandia.gov> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-21string: do not export memweight() to userspaceWANG Cong
Fix the following warning: usr/include/linux/string.h:8: userspace cannot reference function or variable defined in the kernel Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
