path: root/include
2009-06-18memcg: add interface to reset limitsDaisuke Nishimura
We don't have an interface to reset mem.limit or memsw.limit now. This patch allows to reset mem.limit or memsw.limit when they are being set to -1. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18memcg: fix swap accountingKAMEZAWA Hiroyuki
This patch fixes mis-accounting of swap usage in memcg. In the current implementation, memcg's swap account is uncharged only when swap is completely freed. But there are several cases where swap cannot be freed cleanly. For handling that, this patch changes that memcg uncharges swap account when swap has no references other than cache. By this, memcg's swap entry accounting can be fully synchronous with the application's behavior. This patch also changes memcg's hooks for swap-out. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18memcg: remove unneeded forward declaration from sched.hLi Zefan
This forward declaration seems pointless. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18memcg: remove mem_cgroup_cache_charge_swapin()Daisuke Nishimura
mem_cgroup_cache_charge_swapin() isn't used any more, so remove no-op definition of it in header file. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18memcg: add file-based RSS accountingBalbir Singh
Add file RSS tracking per memory cgroup We currently don't track file RSS, the RSS we report is actually anon RSS. All the file mapped pages, come in through the page cache and get accounted there. This patch adds support for accounting file RSS pages. It should 1. Help improve the metrics reported by the memory resource controller 2. Will form the basis for a future shared memory accounting heuristic that has been proposed by Kamezawa. Unfortunately, we cannot rename the existing "rss" keyword used in memory.stat to "anon_rss". We however, add "mapped_file" data and hope to educate the end user through documentation. [hugh.dickins@tiscali.co.uk: fix mem_cgroup_update_mapped_file_stat oops] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.cn> Cc: Paul Menage <menage@google.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18reiserfs: fix warnings with gcc 4.4Jeff Mahoney
Several code paths in reiserfs have a construct like: if (is_direntry_le_ih(ih = B_N_PITEM_HEAD(src, item_num))) ... which, in addition to being ugly, end up causing compiler warnings with gcc 4.4.0. Previous compilers didn't issue a warning. fs/reiserfs/do_balan.c:1273: warning: operation on `aux_ih' may be undefined fs/reiserfs/lbalance.c:393: warning: operation on `ih' may be undefined fs/reiserfs/lbalance.c:421: warning: operation on `ih' may be undefined fs/reiserfs/lbalance.c:777: warning: operation on `ih' may be undefined I believe this is due to the ih being passed to macros which evaluate the argument more than once. This is old code and we haven't seen any problems with it, but this patch eliminates the warnings. It converts the multiple evaluation macros to static inlines and does a preassignment for the cases that were causing the warnings because that code is just ugly. Reported-by: Chris Mason <mason@oracle.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18pca953x: support GPIOLIB GPIO namingDaniel Silverstone
Add support to the PCA953x driver to use the GPIOLIB naming facility for GPIOs. Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk> Cc: Ben Gardner <bgardner@wabtec.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18mpc52xx_psc_spi: convert to cs_control callbackAnton Vorontsov
mpc52xx_psc_spi driver is the last user of the legacy activate_cs and deactivate_cs callbacks, so convert the driver to the cs_control hook and remove the legacy callbacks from fsl_spi_platform_data struct. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18spi: move more spi_setup() functionality into coreDavid Brownell
Move some common spi_setup() error checks into the SPI framework from the spi_master controller drivers: - Add a new "mode_bits" field to spi_master - Use that in spi_setup to validate the spi->mode value being requested. Setting this new field is now mandatory for any controller supporting more than vanilla SPI_MODE_0. - Update all spi_master drivers to: * Initialize that field * Remove current spi_setup() checks using that value. This is a net minor code shrink. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18spi: move common spi_setup() functionality into coreDavid Brownell
Start moving some spi_setup() functionality into the SPI core from the various spi_master controller drivers: - Make that function stop being an inline; - Move two common idioms from drivers into that new function: * Default bits_per_word to 8 if that field isn't set * Issue a standardized dev_dbg() message This is a net minor source code shrink, and supports enhancments found in some follow-up patches. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18softirq: introduce statistics for softirqKeika Kobayashi
Statistics for softirq doesn't exist. It will be helpful like statistics for interrupts. This patch introduces counting the number of softirq, which will be exported in /proc/softirqs. When softirq handler consumes much CPU time, /proc/stat is like the following. $ while :; do cat /proc/stat | head -n1 ; sleep 10 ; done cpu 88 0 408 739665 583 28 2 0 0 cpu 450 0 1090 740970 594 28 1294 0 0 ^^^^ softirq In such a situation, /proc/softirqs shows us which softirq handler is invoked. We can see the increase rate of softirqs. <before> $ cat /proc/softirqs CPU0 CPU1 CPU2 CPU3 HI 0 0 0 0 TIMER 462850 462805 462782 462718 NET_TX 0 0 0 365 NET_RX 2472 2 2 40 BLOCK 0 0 381 1164 TASKLET 0 0 0 224 SCHED 462654 462689 462698 462427 RCU 3046 2423 3367 3173 <after> $ cat /proc/softirqs CPU0 CPU1 CPU2 CPU3 HI 0 0 0 0 TIMER 463361 465077 465056 464991 NET_TX 53 0 1 365 NET_RX 3757 2 2 40 BLOCK 0 0 398 1170 TASKLET 0 0 0 224 SCHED 463074 464318 464612 463330 RCU 3505 2948 3947 3673 When CPU TIME of softirq is high, the rates of increase is the following. TIMER : 220/sec : CPU1-3 NET_TX : 5/sec : CPU0 NET_RX : 120/sec : CPU0 SCHED : 40-200/sec : all CPU RCU : 45-58/sec : all CPU The rates of increase in an idle mode is the following. TIMER : 250/sec SCHED : 250/sec RCU : 2/sec It seems many softirqs for receiving packets and rcu are invoked. This gives us help for checking system. Signed-off-by: Keika Kobayashi <kobayashi.kk@ncos.nec.co.jp> Reviewed-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-17Delete pcibios_select_rootMatthew Wilcox
This function was only used by pci_claim_resource(), and the last commit deleted that use. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-17Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Convert ia64 to use int-ll64.h [IA64] Fix build error in paravirt_patchlist.c [IA64] ia64 does not need umount2() syscall [IA64] hook up new rt_tgsigqueueinfo syscall [IA64] msi_ia64.c dmar_msi_type should be static [IA64] remove obsolete hw_interrupt_type [IA64] remove obsolete irq_desc_t typedef [IA64] remove obsolete no_irq_type [IA64] unexport fpswa.h
2009-06-17Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: mfd: early init for MFD running regulators mfd: fix tmio related warnings mfd: asic3: enable SD/SDIO cell mfd: asic3: enable DS1WM cell mfd: asic3: remove SD/SDIO controller register definitions mfd: asic3: use resource_size macro instead of local variable mfd: add ASIC3 IRQ numbers mfd: asic3: add clock handling for MFD cells mfd: asic3: add asic3_set_register common operation mfd: Fix Kconfig help text for WM8350 mfd: add PCAP driver mfd: add U300 AB3100 core support drivers/mfd: remove obsolete irq_desc_t typedef mfd/pcf50633-gpio.c: add MODULE_LICENSE mfd: Mark WM8350 mask revision as readable to match silicon mfd: Mark clocks_init as non-init in twl4030-core.c mfd: Correct readability of WM8350 register 227
2009-06-17mfd: fix tmio related warningsSamuel Ortiz
We can not have .driver_data as const since platform_set_drvdata() doesnt take a const. The hclk mmc_data field can be const though. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-17mfd: asic3: remove SD/SDIO controller register definitionsPhilipp Zabel
Only the base addresses remain, as they are needed to set up the IOMEM resources. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-17mfd: add ASIC3 IRQ numbersPhilipp Zabel
IRQ number definitions for PWM, LED, SPI and OWM (ds1wm). Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-17mfd: asic3: add asic3_set_register common operationPhilipp Zabel
Used to configure single bits of the SDHWCTRL_SDCONF and EXTCF_RESET/SELECT registers needed for DS1WM, MMC/SDIO and PCMCIA functionality. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-17mfd: add PCAP driverDaniel Ribeiro
The PCAP Asic as present on EZX phones is a multi function device with voltage regulators, ADC, touch screen controller, RTC, USB transceiver, leds controller, and audio codec. It has two SPI ports, typically one is connected to the application processor and another to the baseband, this driver provides read/write functions to its registers, irq demultiplexer and ADC queueing/abstraction. This chip is used on a lot of Motorola phones, it was manufactured by TI as a custom product with the name PTWL93017, later this design evolved into the ATLAS PMIC from Freescale (MC13783). Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-17mfd: add U300 AB3100 core supportLinus Walleij
This adds a core driver for the AB3100 mixed-signal circuit found in the ST-Ericsson U300 series platforms. This driver is a singleton proxy for all accesses to the AB3100 sub-drivers which will be merged on top of this one, RTC, regulators, battery and system power control, vibrator, LEDs, and an ALSA codec. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Reviewed-by: Mike Rapoport <mike@compulab.co.il> Reviewed-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic79xx: make driver respect nvram for IU and QAS settings [SCSI] don't attach ULD to Dell Universal Xport [SCSI] lpfc 8.3.3 : Update driver version to 8.3.3 [SCSI] lpfc 8.3.3 : Add support for Target Reset handler entrypoint [SCSI] lpfc 8.3.3 : Fix a couple of spin_lock and memory issues and a crash [SCSI] lpfc 8.3.3 : FC/FCOE discovery fixes [SCSI] lpfc 8.3.3 : Fix various SLI-3 vs SLI-4 differences [SCSI] qla2xxx: Resolve a performance issue in interrupt [SCSI] cnic, bnx2i: Fix build failure when CONFIG_PCI is not set. [SCSI] nsp_cs: time_out reaches -1 [SCSI] qla2xxx: fix printk format warnings [SCSI] ncr53c8xx: div reaches -1 [SCSI] compat: don't perform unneeded copy in sg_io code [SCSI] zfcp: Update FC pass-through support [SCSI] zfcp: Add FC pass-through support [SCSI] FC Pass Thru support
2009-06-17Merge branch 'linux-next' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubi-2.6: (21 commits) UBI: add reboot notifier UBI: handle more error codes UBI: fix multiple spelling typos UBI: fix kmem_cache_free on error patch UBI: print amount of reserved PEBs UBI: improve messages in the WL worker UBI: make gluebi a separate module UBI: remove built-in gluebi UBI: add notification API UBI: do not switch to R/O mode on read errors UBI: fix and clean-up error paths in WL worker UBI: introduce new constants UBI: fix race condition UBI: minor serialization fix UBI: do not panic if volume check fails UBI: add dump_stack in checking code UBI: fix races in I/O debugging checks UBI: small debugging code optimization UBI: improve debugging messages UBI: re-name volumes_mutex to device_mutex ...
2009-06-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: SLUB: Fix early boot GFP_DMA allocations SLUB: Don't print out OOM warning for __GFP_NOFAIL SLUB: fix build when !SLUB_DEBUG SLUB: Out-of-memory diagnostics slab: document kzfree() zeroing behavior slab: fix generic PAGE_POISONING conflict with SLAB_RED_ZONE slob: use PG_slab for identifying SLOB pages
2009-06-17Pull for-2.6.31 into releaseTony Luck
2009-06-17[IA64] Convert ia64 to use int-ll64.hMatthew Wilcox
It is generally agreed that it would be beneficial for u64 to be an unsigned long long on all architectures. ia64 (in common with several other 64-bit architectures) currently uses unsigned long. Migrating piecemeal is too painful; this giant patch fixes all compilation warnings and errors that come as a result of switching to use int-ll64.h. Note that userspace will still see __u64 defined as unsigned long. This is important as it affects C++ name mangling. [Updated by Tony Luck to change efi.h:efi_freemem_callback_t to use u64 for start/end rather than unsigned long] Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: get rid of BKL in fs/sysv get rid of BKL in fs/minix get rid of BKL in fs/efs befs ->pust_super() doesn't need BKL Cleanup of adfs headers 9P doesn't need BKL in ->umount_begin() fuse doesn't need BKL in ->umount_begin() No instance of ->bmap() needs BKL remove unlock_kernel() left accidentally ext4: avoid unnecessary spinlock in critical POSIX ACL path ext3: avoid unnecessary spinlock in critical POSIX ACL path
2009-06-17Merge branches 'slab/documentation', 'slab/fixes', 'slob/cleanups' and ↵Pekka Enberg
'slub/fixes' into for-linus
2009-06-17Cleanup of adfs headersAl Viro
2009-06-16Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/radeon: switch to using late_initcall radeon legacy chips: tv dac bg/dac adj updates drm/radeon: introduce kernel modesetting for radeon hardware drm: Add the TTM GPU memory manager subsystem. drm: Memory fragmentation from lost alignment blocks drm/radeon: fix mobility flags on new PCI IDs.
2009-06-16Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (425 commits) V4L/DVB (11870): gspca - main: VIDIOC_ENUM_FRAMESIZES ioctl added. V4L/DVB (12004): poll method lose race condition V4L/DVB (11894): flexcop-pci: dmesg visible names broken V4L/DVB (11892): Siano: smsendian - declare function as extern V4L/DVB (11891): Siano: smscore - bind the GPIO SMS protocol V4L/DVB (11890): Siano: smscore - remove redundant code V4L/DVB (11889): Siano: smsdvb - add DVB v3 events V4L/DVB (11888): Siano: smsusb - remove redundant ifdef V4L/DVB (11887): Siano: smscards - add board (target) events V4L/DVB (11886): Siano: smscore - fix some new GPIO definitions names V4L/DVB (11885): Siano: Add new GPIO management interface V4L/DVB (11884): Siano: smssdio - revert to stand alone module V4L/DVB (11883): Siano: cards - add two additional (USB) devices V4L/DVB (11824): Siano: smsusb - change exit func debug msg V4L/DVB (11823): Siano: smsusb - fix typo in module description V4L/DVB (11822): Siano: smscore - bug fix at get_device_mode V4L/DVB (11821): Siano: smscore - fix isdb-t firmware name V4L/DVB (11820): Siano: smscore - fix byte ordering bug V4L/DVB (11819): Siano: smscore - fix get_common_buffer bug V4L/DVB (11818): Siano: smscards - assign gpio to HPG targets ...
2009-06-16Merge branch 'akpm'Linus Torvalds
* akpm: (182 commits) fbdev: bf54x-lq043fb: use kzalloc over kmalloc/memset fbdev: *bfin*: fix __dev{init,exit} markings fbdev: *bfin*: drop unnecessary calls to memset fbdev: bfin-t350mcqb-fb: drop unused local variables fbdev: blackfin has __raw I/O accessors, so use them in fb.h fbdev: s1d13xxxfb: add accelerated bitblt functions tcx: use standard fields for framebuffer physical address and length fbdev: add support for handoff from firmware to hw framebuffers intelfb: fix a bug when changing video timing fbdev: use framebuffer_release() for freeing fb_info structures radeon: P2G2CLK_ALWAYS_ONb tested twice, should 2nd be P2G2CLK_DAC_ALWAYS_ONb? s3c-fb: CPUFREQ frequency scaling support s3c-fb: fix resource releasing on error during probing carminefb: fix possible access beyond end of carmine_modedb[] acornfb: remove fb_mmap function mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OF mb862xxfb: restrict compliation of platform driver to PPC Samsung SoC Framebuffer driver: add Alpha Channel support atmel-lcdc: fix pixclock upper bound detection offb: use framebuffer_alloc() to allocate fb_info struct ... Manually fix up conflicts due to kmemcheck in mm/slab.c
2009-06-16fbdev: blackfin has __raw I/O accessors, so use them in fb.hMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: s1d13xxxfb: add accelerated bitblt functionsKristoffer Ericson
Add accelerated bitblt functions to s1d13xxx based video chipsets, more specificly functions copyarea and fillrect. It has only been tested and activated for 13506 chipsets but is expected to work for the majority of s1d13xxx based chips. This patch also cleans up the driver with respect of whitespaces and other formatting issues. We update the current status comments. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: add support for handoff from firmware to hw framebuffersDave Airlie
With KMS we have ran into an issue where we really want the KMS fb driver to be the one running the console, so panics etc can be shown by switching out of X etc. However with vesafb/efifb built-in, we end up with those on fb0 and the KMS fb driver on fb1, driving the same piece of hw, so this adds an fb info flag to denote a firmware fbdev, and adds a new aperture base/size range which can be compared when the hw drivers are installed to see if there is a conflict with a firmware driver, and if there is the firmware driver is unregistered and the hw driver takes over. It uses new aperture_base/size members instead of comparing on the fix smem_start/length, as smem_start/length might for example only cover the first 1MB of the PCI aperture, and we could allocate the kms fb from 8MB into the aperture, thus they would never overlap. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Airlie <airlied@redhat.com> Acked-by: Peter Jones <pjones@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: move logo externs to header fileGeert Uytterhoeven
Now we have __initconst, we can finally move the external declarations for the various Linux logo structures to <linux/linux_logo.h>. James' ack dates back to the previous submission (way to long ago), when the logos were still __initdata, which caused failures on some platforms with some toolchain versions. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: James Simmons <jsimmons@infradead.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16lis3: add click functionDaniel Mack
The LIS302DL accelerometer chip has a 'click' feature which can be used to detect sudden motion on any of the three axis. Configuration data is passed via spi platform_data and no action is taken if that's not specified, so it won't harm any existing platform. To make the configuration effective, the IRQ lines need to be set up appropriately. This patch also adds a way to do that from board support code. The DD_* definitions were factored out to an own enum because they are specific to LIS3LV02D devices. Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16drivers: add support for the TI VLYNQ busFlorian Fainelli
Add support for the TI VLYNQ high-speed, serial and packetized bus. This bus allows external devices to be connected to the System-on-Chip and appear in the main system memory just like any memory mapped peripheral. It is widely used in TI's networking and multimedia SoC, including the AR7 SoC. Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru> Signed-off-by: Florian Fainelli <florian@openwrt.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16syscalls.h: remove duplicated declarations for sys_pipe2Masatake YAMATO
sys_pipe2 is declared twice in include/linux/syscalls.h. Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16kmap_types: make most arches use generic header fileRandy Dunlap
Convert most arches to use asm-generic/kmap_types.h. Move the KM_FENCE_ macro additions into asm-generic/kmap_types.h, controlled by __WITH_KM_FENCE from each arch's kmap_types.h file. Would be nice to be able to add custom KM_types per arch, but I don't yet see a nice, clean way to do that. Built on x86_64, i386, mips, sparc, alpha(tonyb), powerpc(tonyb), and 68k(tonyb). Note: avr32 should be able to remove KM_PTE2 (since it's not used) and then just use the generic kmap_types.h file. Get avr32 maintainer approval. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Bryan Wu <cooloney@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "Luck Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16remove put_cpu_no_resched()Thomas Gleixner
put_cpu_no_resched() is an optimization of put_cpu() which unfortunately can cause high latencies. The nfs iostats code uses put_cpu_no_resched() in a code sequence where a reschedule request caused by an interrupt between the get_cpu() and the put_cpu_no_resched() can delay the reschedule for at least HZ. The other users of put_cpu_no_resched() optimize correctly in interrupt code, but there is no real harm in using the put_cpu() function which is an alias for preempt_enable(). The extra check of the preemmpt count is not as critical as the potential source of missing a reschedule. Debugged in the preempt-rt tree and verified in mainline. Impact: remove a high latency source [akpm@linux-foundation.org: build fix] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Tony Luck <tony.luck@intel.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16drbd: add major number to major.hPhilipp Reisner
Since we have had a LANANA major number for years, and it is documented in devices.txt, I think that this first patch can go upstream. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16headers: move module_bug_finalize()/module_bug_cleanup() definitions into ↵Andrew Morton
module.h They're in linux/bug.h at present, which causes include order tangles. In particular, linux/bug.h cannot be used by linux/atomic.h because, according to Nikanth: linux/bug.h pulls in linux/module.h => linux/spinlock.h => asm/spinlock.h (which uses atomic_inc) => asm/atomic.h. bug.h is a pretty low-level thing and module.h is a higher-level thing, IMO. Cc: Nikanth Karthikesan <knikanth@novell.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16poll: avoid extra wakeups in select/pollEric Dumazet
After introduction of keyed wakeups Davide Libenzi did on epoll, we are able to avoid spurious wakeups in poll()/select() code too. For example, typical use of poll()/select() is to wait for incoming network frames on many sockets. But TX completion for UDP/TCP frames call sock_wfree() which in turn schedules thread. When scheduled, thread does a full scan of all polled fds and can sleep again, because nothing is really available. If number of fds is large, this cause significant load. This patch makes select()/poll() aware of keyed wakeups and useless wakeups are avoided. This reduces number of context switches by about 50% on some setups, and work performed by sofirq handlers. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16utsname.h: make new_utsname fields use the proper length constantDan Smith
The members of the new_utsname structure are defined with magic numbers that *should* correspond to the constant __NEW_UTS_LEN+1. Everywhere else, code assumes this and uses the constant, so this patch makes the structure match. Originally suggested by Serge here: https://lists.linux-foundation.org/pipermail/containers/2009-March/016258.html Signed-off-by: Dan Smith <danms@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: count the number of times zone_reclaim() scans and failsMel Gorman
On NUMA machines, the administrator can configure zone_reclaim_mode that is a more targetted form of direct reclaim. On machines with large NUMA distances for example, a zone_reclaim_mode defaults to 1 meaning that clean unmapped pages will be reclaimed if the zone watermarks are not being met. There is a heuristic that determines if the scan is worthwhile but it is possible that the heuristic will fail and the CPU gets tied up scanning uselessly. Detecting the situation requires some guesswork and experimentation so this patch adds a counter "zreclaim_failed" to /proc/vmstat. If during high CPU utilisation this counter is increasing rapidly, then the resolution to the problem may be to set /proc/sys/vm/zone_reclaim_mode to 0. [akpm@linux-foundation.org: name things consistently] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: report vm_flags in page_referenced()Wu Fengguang
Collect vma->vm_flags of the VMAs that actually referenced the page. This is preparing for more informed reclaim heuristics, eg. to protect executable file pages more aggressively. For now only the VM_EXEC bit will be used by the caller. Thanks to Johannes, Peter and Minchan for all the good tips. Acked-by: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm cleanup: shmem_file_setup: 'char *' -> 'const char *' for name argumentSergei Trofimovich
As function shmem_file_setup does not modify/allocate/free/pass given filename - mark it as const. Signed-off-by: Sergei Trofimovich <slyfox@inbox.ru> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: remove file argument from swap_readpage()Minchan Kim
The file argument resulted from address_space's readpage long time ago. We don't use it any more. Let's remove unnecessary argement. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: remove __invalidate_mapping_pages variantMike Waychison
Remove __invalidate_mapping_pages atomic variant now that its sole caller can sleep (fixed in eccb95cee4f0d56faa46ef22fb94dd4a3578d3eb ("vfs: fix lock inversion in drop_pagecache_sb()")). This fixes softlockups that can occur while in the drop_caches path. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Jan Kara <jack@suse.cz> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16oom: move oom_adj value from task_struct to mm_structDavid Rientjes
The per-task oom_adj value is a characteristic of its mm more than the task itself since it's not possible to oom kill any thread that shares the mm. If a task were to be killed while attached to an mm that could not be freed because another thread were set to OOM_DISABLE, it would have needlessly been terminated since there is no potential for future memory freeing. This patch moves oomkilladj (now more appropriately named oom_adj) from struct task_struct to struct mm_struct. This requires task_lock() on a task to check its oom_adj value to protect against exec, but it's already necessary to take the lock when dereferencing the mm to find the total VM size for the badness heuristic. This fixes a livelock if the oom killer chooses a task and another thread sharing the same memory has an oom_adj value of OOM_DISABLE. This occurs because oom_kill_task() repeatedly returns 1 and refuses to kill the chosen task while select_bad_process() will repeatedly choose the same task during the next retry. Taking task_lock() in select_bad_process() to check for OOM_DISABLE and in oom_kill_task() to check for threads sharing the same memory will be removed in the next patch in this series where it will no longer be necessary. Writing to /proc/pid/oom_adj for a kthread will now return -EINVAL since these threads are immune from oom killing already. They simply report an oom_adj value of OOM_DISABLE. Cc: Nick Piggin <npiggin@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
