path: root/include
2006-09-26[PATCH] trigger a syntax error if percpu macros are incorrectly usedJan Blunck
get_cpu_var()/per_cpu()/__get_cpu_var() arguments must be simple identifiers. Otherwise the arch dependent implementations might break. This patch enforces the correct usage of the macros by producing a syntax error if the variable is not a simple identifier. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [NetLabel]: update docs with website information [NetLabel]: rework the Netlink attribute handling (part 2) [NetLabel]: rework the Netlink attribute handling (part 1) [Netlink]: add nla_validate_nested() [NETLINK]: add nla_for_each_nested() to the interface list [NetLabel]: change the SELinux permissions [NetLabel]: make the CIPSOv4 cache spinlocks bottom half safe [NetLabel]: correct improper handling of non-NetLabel peer contexts [TCP]: make cubic the default [TCP]: default congestion control menu [ATM] he: Fix __init/__devinit conflict [NETFILTER]: Add dscp,DSCP headers to header-y [DCCP]: Introduce dccp_probe [DCCP]: Use constants for CCIDs [DCCP]: Introduce constants for CCID numbers [DCCP]: Allow default/fallback service code.
2006-09-25[PATCH] cpu to node relationship fixup: map cpu to nodeKAMEZAWA Hiroyuki
Assume that a cpu is *physically* offlined at boot time... Because smpboot.c::smp_boot_cpu_map() canoot find cpu's sapicid, numa.c::build_cpu_to_node_map() cannot build cpu<->node map for offlined cpu. For such cpus, cpu_to_node map should be fixed at cpu-hot-add. This mapping should be done before cpu onlining. This patch also handles cpu hotremove case. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[NetLabel]: rework the Netlink attribute handling (part 1)Paul Moore
At the suggestion of Thomas Graf, rewrite NetLabel's use of Netlink attributes to better follow the common Netlink attribute usage. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[Netlink]: add nla_validate_nested()Paul Moore
Add a new function, nla_validate_nested(), to validate nested Netlink attributes. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[NETLINK]: add nla_for_each_nested() to the interface listPaul Moore
At the top of include/net/netlink.h is a list of Netlink interfaces, however, the nla_for_each_nested() macro was not listed. This patch adds this interface to the list at the top of the header file. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[NetLabel]: correct improper handling of non-NetLabel peer contextsPaul Moore
Fix a problem where NetLabel would always set the value of sk_security_struct->peer_sid in selinux_netlbl_sock_graft() to the context of the socket, causing problems when users would query the context of the connection. This patch fixes this so that the value in sk_security_struct->peer_sid is only set when the connection is NetLabel based, otherwise the value is untouched. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[libata] No need for all those arch libata-portmap.h headersJeff Garzik
They all contain the same thing. Instead, have a single generic one in include/asm-generic, and permit an arch to override as needed. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-24[PATCH] SCSI gfp_t annotationsAl Viro
2006-09-24Merge master.kernel.org:/pub/scm/linux/kernel/git/acme/net-2.6David S. Miller
2006-09-24[NETFILTER]: Add dscp,DSCP headers to header-yYasuyuki Kozakai
This patch adds xt_dscp.h and xt_DSCP.h to the kernel headers which are exported via 'make headers_install'. These are necessary for userspace to add rules using dscp match and DSCP target. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-24[PATCH] fix iptables __user misannotationsAl Viro
2006-09-24[PATCH] netlabel gfp annotationsAl Viro
2006-09-24[PATCH] restore libata build on frvAl Viro
2006-09-24Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: (28 commits) ocfs2: Teach ocfs2_drop_lock() to use ->set_lvb() callback ocfs2: Remove ->unblock lockres operation ocfs2: move downconvert worker to lockres ops ocfs2: Remove unused dlmglue functions ocfs2: Have the metadata lock use generic dlmglue functions ocfs2: Add ->set_lvb callback in dlmglue ocfs2: Add ->check_downconvert callback in dlmglue ocfs2: Check for refreshing locks in generic unblock function ocfs2: don't unconditionally pass LVB flags ocfs2: combine inode and generic blocking AST functions ocfs2: Add ->get_osb() dlmglue locking operation ocfs2: remove ->unlock_ast() callback from ocfs2_lock_res_ops ocfs2: combine inode and generic AST functions ocfs2: Clean up lock resource refresh flags ocfs2: Remove i_generation from inode lock names ocfs2: Encode i_generation in the meta data lvb ocfs2: Free up some space in the lvb ocfs2: Remove special casing for inode creation in ocfs2_dentry_attach_lock() ocfs2: manually d_move() during ocfs2_rename() [PATCH] Allow file systems to manually d_move() inside of ->rename() ...
2006-09-24[S390] Unexport <asm/z90crypt.h>, export <asm/zcrypt.h> in its place.David Woodhouse
2006-09-24Remove dead netfilter_logging.h from include/linux/KbuildDavid Woodhouse
2006-09-24Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2006-09-24[DCCP]: Introduce constants for CCID numbersIan McDonald
Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-09-24[PATCH] Allow file systems to manually d_move() inside of ->rename()Mark Fasheh
Some file systems want to manually d_move() the dentries involved in a rename. We can do this by making use of the FS_ODD_RENAME flag if we just have nfs_rename() unconditionally do the d_move(). While there, we rename the flag to be more descriptive. OCFS2 uses this to protect that part of the rename operation with a cluster lock. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-09-24[DCCP]: Allow default/fallback service code.Gerrit Renker
This has been discussed on dccp@vger and removes the necessity for applications to supply service codes in each and every case. If an application does not want to provide a service code, that's fine, it will be given 0. Otherwise, service codes can be set via socket options as before. This patch has been tested using various client/server configurations (including listening on multiple service codes). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: (50 commits) [libata] Delete pata_it8172 driver [PATCH] libata: improve handling of diagostic fail (and hardware that misreports it) [PATCH] libata: fix non-uniform ports handling Fix libata resource conflict for legacy mode [libata] ata_piix: build fix [PATCH] pata_amd: Check enable bits on Nvidia [PATCH] Update SiS PATA [libata] Add pata_jmicron driver to Kconfig, Makefile [libata #pata-drivers] Trim trailing whitespace. [libata] Trim trailing whitespace. [libata] Add a bunch of PATA drivers. Rename libata-bmdma.c to libata-sff.c. libata: Grand renaming. Clean up drivers/ata/Kconfig a bit. [PATCH] CONFIG_PM=n slim: drivers/scsi/sata_sil* [PATCH] sata_via: Add SATA support for vt8237a [PATCH] libata: change path to libata in libata.tmpl [PATCH] libata: s/CONFIG_SCSI_SATA/CONFIG_[S]ATA/g in pci/quirks.c libata: Make sure drivers/ata is a separate Kconfig menu [libata] ata_piix: add missing kfree() ...
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (217 commits) net/ieee80211: fix more crypto-related build breakage [PATCH] Spidernet: add ethtool -S (show statistics) [NET] GT96100: Delete bitrotting ethernet driver [PATCH] mv643xx_eth: restrict to 32-bit PPC_MULTIPLATFORM [PATCH] Cirrus Logic ep93xx ethernet driver r8169: the MMIO region of the 8167 stands behin BAR#1 e1000, ixgb: Remove pointless wrappers [PATCH] Remove powerpc specific parts of 3c509 driver [PATCH] s2io: Switch to pci_get_device [PATCH] gt96100: move to pci_get_device API [PATCH] ehea: bugfix for register access functions [PATCH] e1000 disable device on PCI error drivers/net/phy/fixed: #if 0 some incomplete code drivers/net: const-ify ethtool_ops declarations [PATCH] ethtool: allow const ethtool_ops [PATCH] sky2: big endian [PATCH] sky2: fiber support [PATCH] sky2: tx pause bug fix drivers/net: Trim trailing whitespace [PATCH] ehea: IBM eHEA Ethernet Device Driver ... Manually resolved conflicts in drivers/net/ixgb/ixgb_main.c and drivers/net/sky2.c related to CHECKSUM_HW/CHECKSUM_PARTIAL changes by commit 84fa7933a33f806bbbaae6775e87459b1ec584c0 that just happened to be next to unrelated changes in this update.
2006-09-24Move several *_SUPER_MAGIC symbols to include/linux/magic.h.Jeff Garzik
2006-09-24Merge branch 'master' into upstreamJeff Garzik
2006-09-23Merge mulgrave-w:git/linux-2.6James Bottomley
Conflicts: include/linux/blkdev.h Trivial merge to incorporate tag prototypes.
2006-09-23[SCSI] SPI transport class: misc DV fixesJames Bottomley
Key more of the domain validation settings off the inquiry data from the disk (in particular, don't try IU or DT unless the disk claims to support them. Also add a new dv_in_progress flag to prevent recursive DV. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-23Merge branch 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa: (148 commits) [ALSA] intel8x0m - Free irq in suspend [ALSA] Move CONFIG_SND_AC97_POWER_SAVE to pci/Kconfig [ALSA] usb-audio: add mixer control names for the Aureon 5.1 MkII [ALSA] ES1938: remove duplicate field initialization [ALSA] usb-audio: increase number of packets per URB [ALSA] hda-codec - Fix headphone auto-toggle on sigmatel codec [ALSA] hda-intel - A slight cleanup of timeout check in azx_get_response() [ALSA] hda-codec - Fix mic input with STAC92xx codecs [ALSA] mixart: Use SEEK_{SET,CUR,END} instead of hardcoded values [ALSA] gus: Use SEEK_{SET,CUR,END} instead of hardcoded values [ALSA] opl4: Use SEEK_{SET,CUR,END} instead of hardcoded values [ALSA] sound core: Use SEEK_{SET,CUR,END} instead of hardcoded values [ALSA] hda-codec - Support multiple headphone pins [ALSA] hda_intel prefer 24bit instead of 20bit [ALSA] hda-codec - Add vendor ids for Motorola and Conexant [ALSA] hda-codec - Add device id for Motorola si3054-compatible codec [ALSA] Add missing compat ioctls for ALSA control API [ALSA] powermac - Fix Oops when conflicting with aoa driver [ALSA] aoa: add locking to tas codec [ALSA] hda-intel - Fix suspend/resume with MSI ...
2006-09-23Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (74 commits) NFS: unmark NFS direct I/O as experimental NFS: add comments clarifying the use of nfs_post_op_update() NFSv4: rpc_mkpipe creating socket inodes w/out sk buffers NFS: Use SEEK_END instead of hardcoded value NFSv4: When mounting with a port=0 argument, substitute port=2049 NFSv4: Poll more aggressively when handling NFS4ERR_DELAY NFSv4: Handle the condition NFS4ERR_FILE_OPEN NFSv4: Retry lease recovery if it failed during a synchronous operation. NFS: Don't invalidate the symlink we just stuffed into the cache NFS: Make read() return an ESTALE if the file has been deleted NFSv4: It's perfectly legal for clp to be NULL here.... NFS: nfs_lookup - don't hash dentry when optimising away the lookup SUNRPC: Fix Oops in pmap_getport_done SUNRPC: Add refcounting to the struct rpc_xprt SUNRPC: Clean up soft task error handling SUNRPC: Handle ENETUNREACH, EHOSTUNREACH and EHOSTDOWN socket errors SUNRPC: rpc_delay() should not clobber the rpc_task->tk_status Fix a referral error Oops NFS: NFS_ROOT should use the new rpc_create API NFS: Fix up compiler warnings on 64-bit platforms in client.c ... Manually resolved conflict in net/sunrpc/xprtsock.c
2006-09-23Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (353 commits) [IPV6] ADDRCONF: Mobile IPv6 Home Address support. [IPV6] ADDRCONF: Allow non-DAD'able addresses. [IPV6] NDISC: Fix is_router flag setting. [IPV6] ADDRCONF: Convert addrconf_lock to RCU. [IPV6] NDISC: Add proxy_ndp sysctl. [IPV6] NDISC: Set per-entry is_router flag in Proxy NA. [IPV6] NDISC: Avoid updating neighbor cache for proxied address in receiving NA. [IPV6]: Don't forward packets to proxied link-local address. [IPV6] NDISC: Handle NDP messages to proxied addresses. [NETFILTER]: PPTP conntrack: fix another GRE keymap leak [NETFILTER]: PPTP conntrack: fix GRE keymap leak [NETFILTER]: PPTP conntrack: fix PPTP_IN_CALL message types [NETFILTER]: PPTP conntrack: check call ID before changing state [NETFILTER]: PPTP conntrack: clean up debugging cruft [NETFILTER]: PPTP conntrack: consolidate header parsing [NETFILTER]: PPTP conntrack: consolidate header size checks [NETFILTER]: PPTP conntrack: simplify expectation handling [NETFILTER]: PPTP conntrack: remove unnecessary cid/pcid header pointers [NETFILTER]: PPTP conntrack: fix header definitions [NETFILTER]: PPTP conntrack: remove more dead code ...
2006-09-23Merge mulgrave-w:git/scsi-misc-2.6James Bottomley
Conflicts: drivers/scsi/iscsi_tcp.c drivers/scsi/iscsi_tcp.h Pretty horrible merge between crypto hash consolidation and crypto_digest_...->crypto_hash_... conversion Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-23[PATCH] #elif that should've been #elif definedAl Viro
#elif CONFIG_44x in ibm4xx.h should've been #elif defined(CONFIG_44x) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-23[KERNEL] Do not truncate to 'int' in ALIGN() macro.David Miller
Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-23[ALSA] ak4xxx - Remove bogus IPGA controlsTakashi Iwai
Remove IPGA volume controls and merge the IPGA range to ADC volume controls. These two volumes are not really independent but connected simply in different ranges 0-0x7f and 0x80-max. It doesn't make sense to provide two controls. Since both 0x7f and 0x80 specify 0dB, a hack is needed for IPGA range to skip 0x80 (increment one) for such controls. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Add pcm_class attribute to PCM sysfs entryTakashi Iwai
This patch adds a new attribute, pcm_class, to each PCM sysfs entry. It's useful to detect what kind of PCM stream is, for example, HAL can check whether it's a modem or not. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Add definition of TLV dB range compoundTakashi Iwai
Added the definition of TLV dB range compound. It contains one or more dB-range or linear-volume TLV entries with min/max ranges. Used for volume controls with non-linear curves. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Clean up and add TLV support to AK4xxx i2c driverTakashi Iwai
- Clean up the code in AK4xxx-ADDA i2c code. - Fix capture gain controls for AK5365 - Changed the static table for DAC/ADC mixer labels to use structs - Implemented TLV entries for each AK codec The volumes in AK4524, AK4528 and AK5365 are corrected with a table to be suitable for dB conversion. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Add the definition of linear volume TLVTakashi Iwai
Added the definition of linear volume TLV type. Some DSP chips and codecs (e.g. AK codec) use linear volume control. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Add dB scale information to vxpocket and vx222 driversTakashi Iwai
Added the dB scale information to vxpocket and vx222 drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Add dB scale information to ad1848 driverTakashi Iwai
Added the dB scale information to ad1848 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Revolution 5.1 - add AK5365 ADC supportJochen Voss
Add support for the AK5365 ADC. Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Fix control/status mmap with shared PCM substreamTakashi Iwai
The flag to avoid 32bit-incompatible mmap for control/status records should be outside the pcm substream instance since a substream can be shared among multiple opens. Now it's flagged in pcm_file list that is directly assigned to file->private_data. Also, removed snd_pcm_add_file() and remove_file() functions and substream.files field that are not really used in the code. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] snd-emu10k1: Implement dB gain infomation.James Courtier-Dutton
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Remove unused tlv_rw field from struct snd_kcontrolTakashi Iwai
Remove unused tlv_rw field from struct snd_kcontrol. The callback is set in tlv.c field, instead. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Control API - more robust TLV implementationJaroslav Kysela
- added callback option - added READ/WRITE/COMMAND flags to access member - added WRITE/COMMAND ioctls - added SNDRV_CTL_EVENT_MASK_TLV for TLV change notifications - added TLV support to ELEM_ADD ioctl Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Add experimental support of aggressive AC97 power-saving modeTakashi Iwai
Added CONFIG_SND_AC97_POWER_SAVE kernel config to enable the support of aggressive AC97 power-saving mode. In this mode, the AC97 powerdown register bits are dynamically controlled at each open/close of PCM streams. The mode is activated via power_save option for snd-ac97-codec driver. As default it's off. It can be turned on/off on the fly via sysfs, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Deprecate snd_card_free_in_thread()Takashi Iwai
Deprecated snd_card_free_in_thread(), replaced with snd_card_free_when_closed(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Unregister device files at disconnectionTakashi Iwai
Orignally proposed by Sam Revitch <sam.revitch@gmail.com>. Unregister device files at disconnection to avoid the futher accesses. Also, the dev_unregister callback is removed and replaced with the combination of disconnect + free. A new function snd_card_free_when_closed() is introduced, which is used in USB disconnect callback. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Fix disconnection of proc interfaceTakashi Iwai
- Add the linked list to each proc entry to enable a single-shot disconnection (unregister) - Deprecate snd_info_unregister(), use snd_info_free_entry() - Removed NULL checks of snd_info_free_entry() Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Control API - TLV implementation for additional information like dB scaleJaroslav Kysela
This patch implements a TLV mechanism to transfer an additional information like dB scale to the user space. The types might be extended in future. Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
