path: root/include
2005-06-27[PATCH] acpi bridge hotadd: Export the interface to get PCI id for an ACPI ↵Rajesh Shah
handle Export an acpi interface to get PCI domain/bus/devfn information from the corresponding namespace handle. Used by acpiphp code to transpate the device handle of the hot-plugged root bridge to the corresponding pci location information. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] acpi bridge hotadd: Allow ACPI .add and .start operations to be done ↵Rajesh Shah
independently Create new interfaces to recursively add an acpi namespace object to the acpi device list, and recursively start the namespace object. This is needed for ACPI based hotplug of a root bridge hierarchy where the add operation must be performed first and the start operation must be performed separately after the hot-plugged devices have been properly configured. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] acpi bridge hotadd: ACPI based root bridge hot-addRajesh Shah
When you hot-plug a (root) bridge hierarchy, it may have p2p bridges and devices attached to it that have not been configured by firmware. In this case, we need to configure the devices before starting them. This patch separates device start from device scan so that we can introduce the configuration step in the middle. I kept the existing semantics for pci_scan_bus() since there are a huge number of callers to that function. Also, I have no way of testing the changes I made to the parisc files, so this needs review by those folks. Sorry for the massive cross-post, this touches files in many different places. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-26Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2005-06-26Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-06-26[ATALK]: Include asm/byteorder.h in linux/atalk.hDavid S. Miller
We're using __be16 in userland visible types, so we have to include asm/byteorder.h so that works. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-26bonding: xor/802.3ad improved slave hashJay Vosburgh
Add support for alternate slave selection algorithms to bonding balance-xor and 802.3ad modes. Default mode (what we have now: xor of MAC addresses) is "layer2", new choice is "layer3+4", using IP and port information for hashing to select peer. Originally submitted by Jason Gabler for balance-xor mode; modified by Jay Vosburgh to additionally support 802.3ad mode. Jason's original comment is as follows: The attached patch to the Linux Etherchannel Bonding driver modifies the driver's "balance-xor" mode as follows: - alternate hashing policy support for mode 2 * Added kernel parameter "xmit_policy" to allow the specification of different hashing policies for mode 2. The original mode 2 policy is the default, now found in xmit_hash_policy_layer2(). * Added xmit_hash_policy_layer34() This patch was inspired by hashing policies implemented by Cisco, Foundry and IBM, which are explained in Foundry documentation found at: http://www.foundrynet.com/services/documentation/sribcg/Trunking.html#112750 Signed-off-by: Jason Gabler <jygabler@lbl.gov> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
2005-06-26[PATCH] ARM: 2756/1: add ixp2000 msf mappingLennert Buytenhek
Patch from Lennert Buytenhek Add a mapping for the ixp2400 and ixp2800 msf unit. The msf is the ixp2000's 'media and switch fabric' unit, which handles the networking part of the chip. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-26[PATCH] ARM: 2755/1: describe ixp2000 virtual memory map layoutLennert Buytenhek
Patch from Lennert Buytenhek Add a comment to asm/arch-ixp2000/ixp2000-regs.h describing the ixp2000 virtual memory map layout. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-26[PATCH] ARM: 2754/1: move ixp2000 VMALLOC_END upLennert Buytenhek
Patch from Lennert Buytenhek As the ixdp cpld mappings now live at 0xfe000000, we can push VMALLOC_END upwards to 0xfb000000, where the first iotable mapping begins. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-26[PATCH] ARM: 2753/1: move ixdp* cpld mappingsLennert Buytenhek
Patch from Lennert Buytenhek All ixdp platforms currently have a cpld mapped in at 0xfafff000. Since this address is not 1M-aligned, a regular page mapping will be used instead of a section mapping, which opens up the possibility of triggering ixp2400 erratum #66 as we only do the XCB=101 workaround thing for section mappings. There is still a lot of space higher up in the virtual memory map for 1M mappings, so move the cpld mapping to 0xfe000000 and make it 1M big so that a section mapping will be used for it. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-25Merge Christoph's freeze cleanup patchLinus Torvalds
2005-06-25[PATCH] Cleanup patch for process freezingChristoph Lameter
1. Establish a simple API for process freezing defined in linux/include/sched.h: frozen(process) Check for frozen process freezing(process) Check if a process is being frozen freeze(process) Tell a process to freeze (go to refrigerator) thaw_process(process) Restart process frozen_process(process) Process is frozen now 2. Remove all references to PF_FREEZE and PF_FROZEN from all kernel sources except sched.h 3. Fix numerous locations where try_to_freeze is manually done by a driver 4. Remove the argument that is no longer necessary from two function calls. 5. Some whitespace cleanup 6. Clear potential race in refrigerator (provides an open window of PF_FREEZE cleared before setting PF_FROZEN, recalc_sigpending does not check PF_FROZEN). This patch does not address the problem of freeze_processes() violating the rule that a task may only modify its own flags by setting PF_FREEZE. This is not clean in an SMP environment. freeze(process) is therefore not SMP safe! Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] drivers/block/ll_rw_blk.c: cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global code static - remove the following unused global functions: - blkdev_scsi_issue_flush_fn - __blk_attempt_remerge - remove the following unused EXPORT_SYMBOL's: - blk_phys_contig_segment - blk_hw_contig_segment - blkdev_scsi_issue_flush_fn - __blk_attempt_remerge Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] drivers/char/nvram.c: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the needlessly global function __nvram_set_checksum static - #if 0 the unused global function nvram_set_checksum - remove the EXPORT_SYMBOL's for both functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Use ALIGN to remove duplicate codeNick Wilson
This patch makes use of ALIGN() to remove duplicate round-up code. Signed-off-by: Nick Wilson <njw@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec code cleanupManeesh Soni
o Following patch provides purely cosmetic changes and corrects CodingStyle guide lines related certain issues like below in kexec related files o braces for one line "if" statements, "for" loops, o more than 80 column wide lines, o No space after "while", "for" and "switch" key words o Changes: o take-2: Removed the extra tab before "case" key words. o take-3: Put operator at the end of line and space before "*/" Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Use real pt_regs from exceptionAlexander Nyberg
Makes kexec_crashdump() take a pt_regs * as an argument. This allows to get exact register state at the point of the crash. If we come from direct panic assertion NULL will be passed and the current registers saved before crashdump. This hooks into two places: die(): check the conditions under which we will panic when calling do_exit and go there directly with the pt_regs that caused the fatal fault. die_nmi(): If we receive an NMI lockup while in the kernel use the pt_regs and go directly to crash_kexec(). We're probably nested up badly at this point so this might be the only chance to escape with proper information. Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Access dump file in elf format (/proc/vmcore)Vivek Goyal
From: "Vivek Goyal" <vgoyal@in.ibm.com> o Support for /proc/vmcore interface. This interface exports elf core image either in ELF32 or ELF64 format, depending on the format in which elf headers have been stored by crashed kernel. o Added support for CONFIG_VMCORE config option. o Removed the dependency on /proc/kcore. From: "Eric W. Biederman" <ebiederm@xmission.com> This patch has been refactored to more closely match the prevailing style in the affected files. And to clearly indicate the dependency between /proc/kcore and proc/vmcore.c From: Hariprasad Nellitheertha <hari@in.ibm.com> This patch contains the code that provides an ELF format interface to the previous kernel's memory post kexec reboot. Signed off by Hariprasad Nellitheertha <hari@in.ibm.com> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Retrieve elfcorehdr address from command lineVivek Goyal
This patch adds support for retrieving the address of elf core header if one is passed in command line. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Routines for copying dump pagesVivek Goyal
This patch provides the interfaces necessary to read the dump contents, treating it as a high memory device. Signed off by Hariprasad Nellitheertha <hari@in.ibm.com> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Retrieve saved max pfnVivek Goyal
This patch retrieves the max_pfn being used by previous kernel and stores it in a safe location (saved_max_pfn) before it is overwritten due to user defined memory map. This pfn is used to make sure that user does not try to read the physical memory beyond saved_max_pfn. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Kdump: Export crash notes section address through sysfsVivek Goyal
o Following patch exports kexec global variable "crash_notes" to user space through sysfs as kernel attribute in /sys/kernel. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: s390 supportHeiko Carstens
Add kexec support for s390 architecture. From: Milton Miller <miltonm@bga.com> - Fix passing of first argument to relocate_kernel assembly. - Fix Kconfig description. - Remove wrong comment and comments that describe obvious things. - Allow only KEXEC_TYPE_DEFAULT as image type -> dump not supported. Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] ppc64: kexec support for ppc64R Sharada
This patch implements the kexec support for ppc64 platforms. A couple of notes: 1) We copy the pages in virtual mode, using the full base kernel and a statically allocated stack. At kexec_prepare time we scan the pages and if any overlap our (0, _end[]) range we return -ETXTBSY. On PowerPC 64 systems running in LPAR (logical partitioning) mode, only a small region of memory, referred to as the RMO, can be accessed in real mode. Since Linux runs with only one zone of memory in the memory allocator, and it can be orders of magnitude more memory than the RMO, looping until we allocate pages in the source region is not feasible. Copying in virtual means we don't have to write a hash table generation and call hypervisor to insert translations, instead we rely on the pinned kernel linear mapping. The kernel already has move to linked location built in, so there is no requirement to load it at 0. If we want to load something other than a kernel, then a stub can be written to copy a linear chunk in real mode. 2) The start entry point gets passed parameters from the kernel. Slaves are started at a fixed address after copying code from the entry point. All CPUs get passed their firmware assigned physical id in r3 (most calling conventions use this register for the first argument). This is used to distinguish each CPU from all other CPUs. Since firmware is not around, there is no other way to obtain this information other than to pass it somewhere. A single CPU, referred to here as the master and the one executing the kexec call, branches to start with the address of start in r4. While this can be calculated, we have to load it through a gpr to branch to this point so defining the register this is contained in is free. A stack of unspecified size is available at r1 (also common calling convention). All remaining running CPUs are sent to start at absolute address 0x60 after copying the first 0x100 bytes from start to address 0. This convention was chosen because it matches what the kernel has been doing itself. (only gpr3 is defined). Note: This is not quite the convention of the kexec bootblock v2 in the kernel. A stub has been written to convert between them, and we may adjust the kernel in the future to allow this directly without any stub. 3) Destination pages can be placed anywhere, even where they would not be accessible in real mode. This will allow us to place ram disks above the RMO if we choose. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: R Sharada <sharada@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] ppc64 kexec: native hash clearR Sharada
Add code to clear the hash table and invalidate the tlb for native (SMP, non-LPAR) mode. Supports 16M and 4k pages. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: R Sharada <sharada@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: kexec ppc supportEric W. Biederman
I have tweaked this patch slightly to handle an empty list of pages to relocate passed to relocate_new_kernel. And I have added ppc_md.machine_crash_shutdown. To keep up with the changes in the generic kexec infrastructure. From: Albert Herranz <albert_herranz@yahoo.es> The following patch adds support for kexec on the ppc32 platform. Non-OpenFirmware based platforms are likely to work directly without additional changes on the kernel side. The kexec-tools userland package may need to be slightly updated, though. For OpenFirmware based machines, additional work is still needed on the kernel side before kexec support is ready. Benjamin Herrenschmidt is kindly working on that part. In order for a ppc platform to use the kexec kernel services it must implement some ppc_md hooks. Otherwise, kexec will be explicitly disabled, as suggested by benh. There are 3+1 new ppc_md hooks that a platform supporting kexec may implement. Two of them are mandatory for kexec to work. See include/asm-ppc/machdep.h for details. - machine_kexec_prepare(image) This function is called to make any arrangements to the image before it is loaded. This hook _MUST_ be provided by a platform in order to activate kexec support for that platform. Otherwise, the platform is considered to not support kexec and the kexec_load system call will fail (that makes all existing platforms by default non-kexec'able). - machine_kexec_cleanup(image) This function is called to make any cleanups on image after the loaded image data it is freed. This hook is optional. A platform may or may not provide this hook. - machine_kexec(image) This function is called to perform the _actual_ kexec. This hook _MUST_ be provided by a platform in order to activate kexec support for that platform. If a platform provides machine_kexec_prepare but forgets to provide machine_kexec, a kexec will fall back to a reboot. A ready-to-use machine_kexec_simple() generic function is provided to, hopefully, simplify kexec adoption for embedded platforms. A platform may call this function from its specific machine_kexec hook, like this: void myplatform_kexec(struct kimage *image) { machine_kexec_simple(image); } - machine_shutdown() This function is called to perform any machine specific shutdowns, not already done by drivers. This hook is optional. A platform may or may not provide this hook. An example (trimmed) platform specific module for a platform supporting kexec through the existing machine_kexec_simple follows: /* ... */ #ifdef CONFIG_KEXEC int myplatform_kexec_prepare(struct kimage *image) { /* here, we can place additional preparations */ return 0; /* yes, we support kexec */ } void myplatform_kexec(struct kimage *image) { machine_kexec_simple(image); } #endif /* CONFIG_KEXEC */ /* ... */ void __init platform_init(unsigned long r3, unsigned long r4, unsigned long r5, unsigned long r6, unsigned long r7) { /* ... */ #ifdef CONFIG_KEXEC ppc_md.machine_kexec_prepare = myplatform_kexec_prepare; ppc_md.machine_kexec = myplatform_kexec; #endif /* CONFIG_KEXEC */ /* ... */ } The kexec ppc kernel support has been heavily tested on the GameCube Linux port, and, as reported in the fastboot mailing list, it has been tested too on a Moto 82xx ppc by Rick Richardson. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: x86_64 kexec implementationEric W. Biederman
This is the x86_64 implementation of machine kexec. 32bit compatibility support has been implemented, and machine_kexec has been enhanced to not care about the changing internal kernel paget table structures. From: Alexander Nyberg <alexn@dsv.su.se> build fix Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: x86 kexec coreEric W. Biederman
This is the i386 implementation of kexec. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: add kexec syscallsEric W. Biederman
This patch introduces the architecture independent implementation the sys_kexec_load, the compat_sys_kexec_load system calls. Kexec on panic support has been integrated into the core patch and is relatively clean. In addition the hopefully architecture independent option crashkernel=size@location has been docuemented. It's purpose is to reserve space for the panic kernel to live, and where no DMA transfer will ever be setup to access. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: x86_64: add CONFIG_PHYSICAL_STARTEric W. Biederman
For one kernel to report a crash another kernel has created we need to have 2 kernels loaded simultaneously in memory. To accomplish this the two kernels need to built to run at different physical addresses. This patch adds the CONFIG_PHYSICAL_START option to the x86_64 kernel so we can do just that. You need to know what you are doing and the ramifications are before changing this value, and most users won't care so I have made it depend on CONFIG_EMBEDDED bzImage kernels will work and run at a different address when compiled with this option but they will still load at 1MB. If you need a kernel loaded at a different address as well you need to boot a vmlinux. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: x86: add CONFIG_PYSICAL_STARTEric W. Biederman
For one kernel to report a crash another kernel has created we need to have 2 kernels loaded simultaneously in memory. To accomplish this the two kernels need to built to run at different physical addresses. This patch adds the CONFIG_PHYSICAL_START option to the x86 kernel so we can do just that. You need to know what you are doing and the ramifications are before changing this value, and most users won't care so I have made it depend on CONFIG_EMBEDDED bzImage kernels will work and run at a different address when compiled with this option but they will still load at 1MB. If you need a kernel loaded at a different address as well you need to boot a vmlinux. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: vmlinux: fix physical addressesEric W. Biederman
In vmlinux.lds.h the code is carefull to define every section so vmlinux properly reports the correct physical load address of code, as well as it's virtual address. The new SECURITY_INIT definition fails to follow that convention and and causes incorrect physical address to appear in the vmlinux if there are any security initcalls. This patch updates the SECURITY_INIT to follow the convention in the rest of the file. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: x86_64: restore apic virtual wire mode on shutdownEric W. Biederman
When coming out of apic mode attempt to set the appropriate apic back into virtual wire mode. This improves on previous versions of this patch by by never setting bot the local apic and the ioapic into veritual wire mode. This code looks at data from the mptable to see if an ioapic has an ExtInt input to make this decision. A future improvement is to figure out which apic or ioapic was in virtual wire mode at boot time and to remember it. That is potentially a more accurate method, of selecting which apic to place in virutal wire mode. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: x86: resture apic virtual wire mode on shutdownEric W. Biederman
2005-06-25[PATCH] kexec: x86: local apic fixEric W. Biederman
From: "Maciej W. Rozycki" <macro@linux-mips.org> Fix a kexec problem whcih causes local APIC detection failure. The problem is detect_init_APIC() is called early, before the command line have been processed. Therefore "lapic" (and "nolapic") have not been seen, yet. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: x86: rename APIC_MODE_EXINTEric W. Biederman
From: "Maciej W. Rozycki" <macro@linux-mips.org> Rename APIC_MODE_EXINT to APIC_MODE_EXTINT - I think it should be named after what the mode is called in documentation. From: "Eric W. Biederman" <ebiederm@lnxi.com> I have reduced this patch to just the name change in the header. And integrated the changes into the patches that add those lines. Otherwise I ran into some ugly dependencies. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sched: voluntary kernel preemptionIngo Molnar
This patch adds a new preemption model: 'Voluntary Kernel Preemption'. The 3 models can be selected from a new menu: (X) No Forced Preemption (Server) ( ) Voluntary Kernel Preemption (Desktop) ( ) Preemptible Kernel (Low-Latency Desktop) we still default to the stock (Server) preemption model. Voluntary preemption works by adding a cond_resched() (reschedule-if-needed) call to every might_sleep() check. It is lighter than CONFIG_PREEMPT - at the cost of not having as tight latencies. It represents a different latency/complexity/overhead tradeoff. It has no runtime impact at all if disabled. Here are size stats that show how the various preemption models impact the kernel's size: text data bss dec hex filename 3618774 547184 179896 4345854 424ffe vmlinux.stock 3626406 547184 179896 4353486 426dce vmlinux.voluntary +0.2% 3748414 548640 179896 4476950 445016 vmlinux.preempt +3.5% voluntary-preempt is +0.2% of .text, preempt is +3.5%. This feature has been tested for many months by lots of people (and it's also included in the RHEL4 distribution and earlier variants were in Fedora as well), and it's intended for users and distributions who dont want to use full-blown CONFIG_PREEMPT for one reason or another. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Dynamic sched domains: sched changesDinakar Guniguntala
The following patches add dynamic sched domains functionality that was extensively discussed on lkml and lse-tech. I would like to see this added to -mm o The main advantage with this feature is that it ensures that the scheduler load balacing code only balances against the cpus that are in the sched domain as defined by an exclusive cpuset and not all of the cpus in the system. This removes any overhead due to load balancing code trying to pull tasks outside of the cpu exclusive cpuset only to be prevented by the tasks' cpus_allowed mask. o cpu exclusive cpusets are useful for servers running orthogonal workloads such as RT applications requiring low latency and HPC applications that are throughput sensitive o It provides a new API partition_sched_domains in sched.c that makes dynamic sched domains possible. o cpu_exclusive cpusets sets are now associated with a sched domain. Which means that the users can dynamically modify the sched domains through the cpuset file system interface o ia64 sched domain code has been updated to support this feature as well o Currently, this does not support hotplug. (However some of my tests indicate hotplug+preempt is currently broken) o I have tested it extensively on x86. o This should have very minimal impact on performance as none of the fast paths are affected Signed-off-by: Dinakar Guniguntala <dino@in.ibm.com> Acked-by: Paul Jackson <pj@sgi.com> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sched: consolidate sbe sbfNick Piggin
Consolidate balance-on-exec with balance-on-fork. This is made easy by the sched-domains RCU patches. As well as the general goodness of code reduction, this allows the runqueues to be unlocked during balance-on-fork. schedstats is a problem. Maybe just have balance-on-event instead of distinguishing fork and exec? Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sched: cleanup context switch lockingNick Piggin
Instead of requiring architecture code to interact with the scheduler's locking implementation, provide a couple of defines that can be used by the architecture to request runqueue unlocked context switches, and ask for interrupts to be enabled over the context switch. Also replaces the "switch_lock" used by these architectures with an oncpu flag (note, not a potentially slow bitflag). This eliminates one bus locked memory operation when context switching, and simplifies the task_running function. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sched: sched tuningNick Piggin
Do some basic initial tuning. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sched: schedstats update for balance on forkNick Piggin
Add SCHEDSTAT statistics for sched-balance-fork. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sched: balance on forkNick Piggin
Reimplement the balance on exec balancing to be sched-domains aware. Use this to also do balance on fork balancing. Make x86_64 do balance on fork over the NUMA domain. The problem that the non sched domains aware blancing became apparent on dual core, multi socket opterons. What we want is for the new tasks to be sent to a different socket, but more often than not, we would first load up our sibling core, or fill two cores of a single remote socket before selecting a new one. This gives large improvements to STREAM on such systems. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sched: no aggressive idle balancingNick Piggin
Remove the very aggressive idle stuff that has recently gone into 2.6 - it is going against the direction we are trying to go. Hopefully we can regain performance through other methods. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sched: balance timersNick Piggin
Do CPU load averaging over a number of different intervals. Allow each interval to be chosen by sending a parameter to source_load and target_load. 0 is instantaneous, idx > 0 returns a decaying average with the most recent sample weighted at 2^(idx-1). To a maximum of 3 (could be easily increased). So generally a higher number will result in more conservative balancing. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] RCU: clean up a few remaining synchronize_kernel() callsPaul E. McKenney
2.6.12-rc6-mm1 has a few remaining synchronize_kernel()s, some (but not all) in comments. This patch changes these synchronize_kernel() calls (and comments) to synchronize_rcu() or synchronize_sched() as follows: - arch/x86_64/kernel/mce.c mce_read(): change to synchronize_sched() to handle races with machine-check exceptions (synchronize_rcu() would not cut it given RCU implementations intended for hardcore realtime use. - drivers/input/serio/i8042.c i8042_stop(): change to synchronize_sched() to handle races with i8042_interrupt() interrupt handler. Again, synchronize_rcu() would not cut it given RCU implementations intended for hardcore realtime use. - include/*/kdebug.h comments: change to synchronize_sched() to handle races with NMIs. As before, synchronize_rcu() would not cut it... - include/linux/list.h comment: change to synchronize_rcu(), since this comment is for list_del_rcu(). - security/keys/key.c unregister_key_type(): change to synchronize_rcu(), since this is interacting with RCU read side. - security/keys/process_keys.c install_session_keyring(): change to synchronize_rcu(), since this is interacting with RCU read side. Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] s390: debug feature changesMichael Holzheu
This patch changes the memory allocation method for the s390 debug feature. Trace buffers had been allocated using the get_free_pages() function before. Therefore it was not possible to get big memory areas in a running system due to memory fragmentation. Now the trace buffers are subdivided into several subbuffers with pagesize. Therefore it is now possible to allocate more memory for the trace buffers and more trace records can be written. In addition to that, dynamic specification of the size of the trace buffers is implemented. It is now possible to change the size of a trace buffer using a new debugfs file instance. When writing a number into this file, the trace buffer size is changed to 'number * pagesize'. In the past all the traces could be obtained from userspace by accessing files in the "proc" filesystem. Now with debugfs we have a new filesystem which should be used for debugging purposes. This patch moves the debug feature from procfs to debugfs. Since the interface of debug_register() changed, all device drivers, which use the debug feature had to be adjusted. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] s390: add vmcp interfaceChristian Borntraeger
Add interface to issue VM control program commands. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] s390: improved machine check handlingHeiko Carstens
Improved machine check handling. Kernel is now able to receive machine checks while in kernel mode (system call, interrupt and program check handling). Also register validation is now performed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
