Move features definitions to separate header so that linux/skbuff.h won't
need to include linux/netdevice.h after netdev_features_t is introduced.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Acked-by: Ben Hutchings <bhutchings@solarflare.com>
As all drivers are converted, we may now remove discrete offload setting
callback handling.
Add a new .bus_name to virtio_config_ops then modify virtio_net to
call through to it in an ethtool .get_drvinfo routine to report
bus_info in ethtool -i output which is consistent with other
emulated NICs and the output of lspci.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
This patch adds phy reset functionality to mdio-gpio driver. Now
mdio_gpio_platform_data has new member as function pointer which can be
filled at the bsp level for a callback from phy infrastructure. Also the
mdio-bitbang driver fills-in the reset function of mii_bus structure.
Without this patch the bsp level code has to takecare of the reseting
PHY's on the bus, which become bit hacky for every bsp and
phy-infrastructure is ignored aswell.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
One of the thing we discussed during netdev 2011 conference was the idea
to change some network drivers to allocate/populate their skb at RX
completion time, right before feeding the skb to network stack.
In old days, we allocated skbs when populating the RX ring.
This means bringing into cpu cache sk_buff and skb_shared_info cache
lines (since we clear/initialize them), then 'queue' skb->data to NIC.
By the time NIC fills a frame in skb->data buffer and host can process
it, cpu probably threw away the cache lines from its caches, because lot
of things happened between the allocation and final use.
So the deal would be to allocate only the data buffer for the NIC to
populate its RX ring buffer. And use build_skb() at RX completion to
attach a data buffer (now filled with an ethernet frame) to a new skb,
initialize the skb_shared_info portion, and give the hot skb to network
stack.
build_skb() is the function to allocate an skb, caller providing the
data buffer that should be attached to it. Drivers are expected to call
skb_reserve() right after build_skb() to adjust skb->data to the
Ethernet frame (usually skipping NET_SKB_PAD and NET_IP_ALIGN, but some
drivers might add a hardware provided alignment)
Data provided to build_skb() MUST have been allocated by a prior
kmalloc() call, with enough room to add SKB_DATA_ALIGN(sizeof(struct
skb_shared_info)) bytes at the end of the data without corrupting
incoming frame.
data = kmalloc(NET_SKB_PAD + NET_IP_ALIGN + 1536 +
SKB_DATA_ALIGN(sizeof(struct skb_shared_info)),
GFP_ATOMIC);
skb = build_skb(data);
if (!skb) {
recycle_data(data);
} else {
skb_reserve(skb, NET_SKB_PAD + NET_IP_ALIGN);
CC: Eilon Greenstein <eilong@broadcom.com>
CC: Ben Hutchings <bhutchings@solarflare.com>
CC: Tom Herbert <therbert@google.com>
CC: Jamal Hadi Salim <hadi@mojatatu.com>
CC: Stephen Hemminger <shemminger@vyatta.com>
CC: Thomas Graf <tgraf@infradead.org>
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Le mercredi 09 novembre 2011 à 16:21 -0500, David Miller a écrit :
> From: David Miller <davem@davemloft.net>
> Date: Wed, 09 Nov 2011 16:16:44 -0500 (EST)
> > From: Eric Dumazet <eric.dumazet@gmail.com>
> > Date: Wed, 09 Nov 2011 12:14:09 +0100
> >> unres_qlen is the number of frames we are able to queue per unresolved
> >> neighbour. Its default value (3) was never changed and is responsible
> >> for strange drops, especially if IP fragments are used, or multiple
> >> sessions start in parallel. Even a single tcp flow can hit this limit.
> > Ok, I've applied this, let's see what happens :-)
> Early answer, build fails.
> Please test build this patch with DECNET enabled and resubmit. The
> decnet neigh layer still refers to the removed ->queue_len member.
> Thanks.
Ouch, this was fixed on one machine yesterday, but not the other one I
used this morning, sorry.
[PATCH V5 net-next] neigh: new unresolved queue limits
$ arp -d 192.168.20.108 ; ping -c 2 -s 8000 192.168.20.108
PING 192.168.20.108 (192.168.20.108) 8000(8028) bytes of data.
8008 bytes from 192.168.20.108: icmp_seq=2 ttl=64 time=0.322 ms
This patch adds support for frame fragmentation.
Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com>
Reading /proc/net/snmp6 on a machine with a lot of cpus is very
expensive (can be ~88000 us).
This is because ICMPV6MSG MIB uses 4096 bytes per cpu, and folding
values for all possible cpus can read 16 Mbytes of memory (32MBytes on
non x86 arches)
ICMP messages are not considered as fast path on a typical server, and
eventually few cpus handle them anyway. We can afford an atomic
operation instead of using percpu data.
This saves 4096 bytes per cpu and per network namespace.
This patch introduces new network device called team. It supposes to be
very fast, simple, userspace-driven alternative to existing bonding
driver.
Userspace library called libteam with couple of demo apps is available
here:
https://github.com/jpirko/libteam
Note it's still in its dipers atm.
team<->libteam use generic netlink for communication. That and rtnl
suppose to be the only way to configure team device, no sysfs etc.
Python binding of libteam was recently introduced.
Daemon providing arpmon/miimon active-backup functionality will be
introduced shortly. All what's necessary is already implemented in
kernel team driver.
v7->v8:
- check ndo_ndo_vlan_rx_[add/kill]_vid functions before calling
them.
- use dev_kfree_skb_any() instead of dev_kfree_skb()
v6->v7:
- transmit and receive functions are not checked in hot paths.
That also resolves memory leak on transmit when no port is
present
v5->v6:
- changed couple of _rcu calls to non _rcu ones in non-readers
v4->v5:
- team_change_mtu() uses team->lock while travesing though port
list
- mac address changes are moved completely to jurisdiction of
userspace daemon. This way the daemon can do FOM1, FOM2 and
possibly other weird things with mac addresses.
Only round-robin mode sets up all ports to bond's address then
enslaved.
- Extended Kconfig text
v3->v4:
- remove redundant synchronize_rcu from __team_change_mode()
- revert "set and clear of mode_ops happens per pointer, not per
byte"
- extend comment of function __team_change_mode()
v2->v3:
- team_change_mtu() uses rcu version of list traversal to unwind
- set and clear of mode_ops happens per pointer, not per byte
- port hashlist changed to be embedded into team structure
- error branch in team_port_enter() does cleanup now
- fixed rtln->rtnl
v1->v2:
- modes are made as modules. Makes team more modular and
extendable.
- several commenters' nitpicks found on v1 were fixed
- several other bugs were fixed.
- note I ignored Eric's comment about roundrobin port selector
as Eric's way may be easily implemented as another mode (mode
"random") in future.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Le lundi 07 novembre 2011 à 15:33 +0100, Eric Dumazet a écrit :
> At least, in recent kernels we dont change dst->refcnt in forwarding
> patch (usinf NOREF skb->dst)
> One particular point is the atomic_inc(dst->refcnt) we have to perform
> when queuing an UDP packet if socket asked PKTINFO stuff (for example a
> typical DNS server has to setup this option)
> I have one patch somewhere that stores the information in skb->cb[] and
> avoid the atomic_{inc|dec}(dst->refcnt).
OK I found it, I did some extra tests and believe its ready.
[PATCH net-next] ipv4: IP_PKTINFO doesnt need dst reference
When a socket uses IP_PKTINFO notifications, we currently force a dst
reference for each received skb. Reader has to access dst to get needed
information (rt_iif & rt_spec_dst) and must release dst reference.
We also forced a dst reference if skb was put in socket backlog, even
without IP_PKTINFO handling. This happens under stress/load.
We can instead store the needed information in skb->cb[], so that only
softirq handler really access dst, improving cache hit ratios.
This removes two atomic operations per packet, and false sharing as
well.
On a benchmark using a mono threaded receiver (doing only recvmsg()
calls), I can reach 720.000 pps instead of 570.000 pps.
IP_PKTINFO is typically used by DNS servers, and any multihomed aware
UDP application.
Reading /proc/net/snmp on a machine with a lot of cpus is very expensive
(can be ~88000 us).
This is because ICMPMSG MIB uses 4096 bytes per cpu, and folding values
for all possible cpus can read 16 Mbytes of memory.
Make clear that sk_clone() and inet_csk_clone() return a locked socket.
Add _lock() prefix and kerneldoc.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Fast retransmission after changing the last address
with ASCONF negotiation
Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits)
forcedeth: fix a few sparse warnings (variable shadowing)
forcedeth: Improve stats counters
forcedeth: remove unneeded stats updates
forcedeth: Acknowledge only interrupts that are being processed
forcedeth: fix race when unloading module
MAINTAINERS/rds: update maintainer
wanrouter: Remove kernel_lock annotations
usbnet: fix oops in usbnet_start_xmit
ixgbe: Fix compile for kernel without CONFIG_PCI_IOV defined
etherh: Add MAINTAINERS entry for etherh
bonding: comparing a u8 with -1 is always false
sky2: fix regression on Yukon Optima
netlink: clarify attribute length check documentation
netlink: validate NLA_MSECS length
i825xx:xscale:8390:freescale: Fix Kconfig dependancies
macvlan: receive multicast with local address
tg3: Update version to 3.121
tg3: Eliminate timer race with reset_task
tg3: Schedule at most one tg3_reset_task run
tg3: Obtain PCI function number from device
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux:
cpuidle: Single/Global registration of idle states
cpuidle: Split cpuidle_state structure and move per-cpu statistics fields
cpuidle: Remove CPUIDLE_FLAG_IGNORE and dev->prepare()
cpuidle: Move dev->last_residency update to driver enter routine; remove dev->last_state
ACPI: Fix CONFIG_ACPI_DOCK=n compiler warning
ACPI: Export FADT pm_profile integer value to userspace
thermal: Prevent polling from happening during system suspend
ACPI: Drop ACPI_NO_HARDWARE_INIT
ACPI atomicio: Convert width in bits to bytes in __acpi_ioremap_fast()
PNPACPI: Simplify disabled resource registration
ACPI: Fix possible recursive locking in hwregs.c
ACPI: use kstrdup()
mrst pmu: update comment
tools/power turbostat: less verbose debugging
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (40 commits)
vmwgfx: Snoop DMA transfers with non-covering sizes
vmwgfx: Move the prefered mode first in the list
vmwgfx: Unreference surface on cursor error path
vmwgfx: Free prefered mode on error path
vmwgfx: Use pointer return error codes
vmwgfx: Fix hw cursor position
vmwgfx: Infrastructure for explicit placement
vmwgfx: Make the preferred autofit mode have a 60Hz vrefresh
vmwgfx: Remove screen object active list
vmwgfx: Screen object cleanups
drm/radeon/kms: consolidate GART code, fix segfault after GPU lockup V2
drm/radeon/kms: don't poll forever if MC GDDR link training fails
drm/radeon/kms: fix DP setup on TRAVIS bridges
drm/radeon/kms: set HPD polarity in hpd_init()
drm/radeon/kms: add MSI module parameter
drm/radeon/kms: Add MSI quirk for Dell RS690
drm/radeon/kms: Add MSI quirk for HP RS690
drm/radeon/kms: split MSI check into a separate function
vmwgfx: Reinstate the update_layout ioctl
drm/radeon/kms: always do extended edid probe
* git://git.infradead.org/mtd-2.6: (226 commits)
mtd: tests: annotate as DANGEROUS in Kconfig
mtd: tests: don't use mtd0 as a default
mtd: clean up usage of MTD_DOCPROBE_ADDRESS
jffs2: add compr=lzo and compr=zlib options
jffs2: implement mount option parsing and compression overriding
mtd: nand: initialize ops.mode
mtd: provide an alias for the redboot module name
mtd: m25p80: don't probe device which has status of 'disabled'
mtd: nand_h1900 never worked
mtd: Add DiskOnChip G3 support
mtd: m25p80: add EON flash EN25Q32B into spi flash id table
mtd: mark block device queue as non-rotational
mtd: r852: make r852_pm_ops static
mtd: m25p80: add support for at25df321a spi data flash
mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks
mtd: nand: switch `check_pattern()' to standard `memcmp()'
mtd: nand: invalidate cache on unaligned reads
mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set
mtd: nand: wait to set BBT version
mtd: nand: scrub BBT on ECC errors
Fix up trivial conflicts:
- arch/arm/mach-at91/board-usb-a9260.c
Merged into board-usb-a926x.c
- drivers/mtd/maps/lantiq-flash.c
add_mtd_partitions -> mtd_device_register vs changed to use
mtd_device_parse_register.
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'upstream/jump-label-noearly' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
jump-label: initialize jump-label subsystem much earlier
x86/jump_label: add arch_jump_label_transform_static()
s390/jump-label: add arch_jump_label_transform_static()
jump_label: add arch_jump_label_transform_static() to optimise non-live code updates
sparc/jump_label: drop arch_jump_label_text_poke_early()
x86/jump_label: drop arch_jump_label_text_poke_early()
jump_label: if a key has already been initialized, don't nop it out
stop_machine: make stop_machine safe and efficient to call early
jump_label: use proper atomic_t initializer
- arch/x86/kernel/jump_label.c
Added __init_or_module to arch_jump_label_text_poke_early vs
removal of that function entirely
- kernel/stop_machine.c
same patch ("stop_machine: make stop_machine safe and efficient
to call early") merged twice, with whitespace fix in one version
* 'upstream/xen-settime' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xen/dom0: set wallclock time in Xen
xen: add dom0_op hypercall
xen/acpi: Domain0 acpi parser related platform hypercall
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux
* 'writeback-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: Add a 'reason' to wb_writeback_work
writeback: send work item to queue_io, move_expired_inodes
writeback: trace event balance_dirty_pages
writeback: trace event bdi_dirty_ratelimit
writeback: fix ppc compile warnings on do_div(long long, unsigned long)
writeback: per-bdi background threshold
writeback: dirty position control - bdi reserve area
writeback: control dirty pause time
writeback: limit max dirty pause time
writeback: IO-less balance_dirty_pages()
writeback: per task dirty rate limit
writeback: stabilize bdi->dirty_ratelimit
writeback: dirty rate control
writeback: add bg_threshold parameter to __bdi_update_bandwidth()
writeback: account per-bdi accumulated dirtied pages
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
target: use ->exectute_task for all CDB emulation
target: remove SCF_EMULATE_CDB_ASYNC
target: refactor transport_emulate_control_cdb
target: pass the se_task to the CDB emulation callback
target: split core_scsi3_emulate_pr
target: split core_scsi2_emulate_crh
target: Add generic active I/O shutdown logic
target: add back error handling in transport_complete_task
target/pscsi: blk_make_request() returns an ERR_PTR()
target: Remove core TRANSPORT_FREE_CMD_INTR usage
target: Make TFO->check_stop_free return free status
iscsi-target: Fix non-immediate TMR handling
iscsi-target: Add missing CMDSN_LOWER_THAN_EXP check in iscsit_handle_scsi_cmd
target: Avoid double list_del for aborted se_tmr_req
target: Minor cleanups to core_tmr_drain_tmr_list
target: Fix wrong se_tmr being added to drain_tmr_list
target: Fix incorrect se_cmd assignment in core_tmr_drain_tmr_list
target: Check -ENOMEM to signal QUEUE_FULL from fabric callbacks
tcm_loop: Add explict read buffer memset for SCF_SCSI_CONTROL_SG_IO_CDB
target: Fix compile warning w/ missing module.h include
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/vmalloc-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
net: xen-netback: use API provided by xenbus module to map rings
block: xen-blkback: use API provided by xenbus module to map rings
xen: use generic functions instead of xen_{alloc, free}_vm_area()
This patch makes the cpuidle_states structure global (single copy)
instead of per-cpu. The statistics needed on per-cpu basis
by the governor are kept per-cpu. This simplifies the cpuidle
subsystem as state registration is done by single cpu only.
Having single copy of cpuidle_states saves memory. Rare case
of asymmetric C-states can be handled within the cpuidle driver
and architectures such as POWER do not have asymmetric C-states.
Having single/global registration of all the idle states,
dynamic C-state transitions on x86 are handled by
the boot cpu. Here, the boot cpu would disable all the devices,
re-populate the states and later enable all the devices,
irrespective of the cpu that would receive the notification first.
Reference:
https://lkml.org/lkml/2011/4/25/83
Signed-off-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Signed-off-by: Trinabh Gupta <g.trinabh@gmail.com>
Tested-by: Jean Pihet <j-pihet@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Kevin Hilman <khilman@ti.com>
Signed-off-by: Len Brown <len.brown@intel.com>
This is the first step towards global registration of cpuidle
states. The statistics used primarily by the governor are per-cpu
and have to be split from rest of the fields inside cpuidle_state,
which would be made global i.e. single copy. The driver_data field
is also per-cpu and moved.
The cpuidle_device->prepare() mechanism causes updates to the
cpuidle_state[].flags, setting and clearing CPUIDLE_FLAG_IGNORE
to tell the governor not to chose a state on a per-cpu basis at
run-time. State demotion is now handled by the driver and it returns
the actual state entered. Hence, this mechanism is not required.
Also this removes per-cpu flags from cpuidle_state enabling
it to be made global.
Reference:
https://lkml.org/lkml/2011/3/25/52
Signed-off-by: Deepthi Dharwar <deepthi@linux.vnet.ibm>
dev->last_state
Cpuidle governor only suggests the state to enter using the
governor->select() interface, but allows the low level driver to
override the recommended state. The actual entered state
may be different because of software or hardware demotion. Software
demotion is done by the back-end cpuidle driver and can be accounted
correctly. Current cpuidle code uses last_state field to capture the
actual state entered and based on that updates the statistics for the
state entered.
Ideally the driver enter routine should update the counters,
and it should return the state actually entered rather than the time
spent there. The generic cpuidle code should simply handle where
the counters live in the sysfs namespace, not updating the counters.
Reference:
Recently the ACPI ops structs were constified but the inline version
of register_hotplug_dock_device() was overlooked (see also commit
9c8b04b, June 25 2011). Update the inline function
register_hotplug_dock_device() that is enabled with
CONFIG_ACPI_DOCK=n too. This patch fixes at least the following
compiler warnings:
drivers/ata/libata-acpi.c: In function .ata_acpi_associate.:
drivers/ata/libata-acpi.c:266:11: warning: passing argument 2 of .register_hotplug_dock_device. discards qualifiers from pointer target type
include/acpi/acpi_drivers.h:146:19: note: expected .struct acpi_dock_ops *. but argument is of type .const struct acpi_dock_ops *.
drivers/ata/libata-acpi.c:275:11: warning: passing argument 2 of .register_hotplug_dock_device. discards qualifiers from pointer target type
Cc: stable@vger.kernel.org
ACPI_NO_HARDWARE_INIT is only used by acpi_early_init() and
acpi_bus_init() when calling acpi_enable_subsystem(), but
acpi_enable_subsystem() doesn't check that flag, so it can be
dropped.
* git://github.com/rustyrussell/linux:
module,bug: Add TAINT_OOT_MODULE flag for modules not built in-tree
module: Enable dynamic debugging regardless of taint
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits)
powerpc/p3060qds: Add support for P3060QDS board
powerpc/83xx: Add shutdown request support to MCU handling on MPC8349 MITX
powerpc/85xx: Make kexec to interate over online cpus
powerpc/fsl_booke: Fix comment in head_fsl_booke.S
powerpc/85xx: issue 15 EOI after core reset for FSL CoreNet devices
powerpc/8xxx: Fix interrupt handling in MPC8xxx GPIO driver
powerpc/85xx: Add 'fsl,pq3-gpio' compatiable for GPIO driver
powerpc/86xx: Correct Gianfar support for GE boards
powerpc/cpm: Clear muram before it is in use.
drivers/virt: add ioctl for 32-bit compat on 64-bit to fsl-hv-manager
powerpc/fsl_msi: add support for "msi-address-64" property
powerpc/85xx: Setup secondary cores PIR with hard SMP id
powerpc/fsl-booke: Fix settlbcam for 64-bit
powerpc/85xx: Adding DCSR node to dtsi device trees
powerpc/85xx: clean up FPGA device tree nodes for Freecsale QorIQ boards
powerpc/85xx: fix PHYS_64BIT selection for P1022DS
powerpc/fsl-booke: Fix setup_initial_memory_limit to not blindly map
powerpc: respect mem= setting for early memory limit setup
powerpc: Update corenet64_smp_defconfig
powerpc: Update mpc85xx/corenet 32-bit defconfigs
Fix up trivial conflicts in:
- arch/powerpc/configs/40x/hcu4_defconfig
removed stale file, edited elsewhere
- arch/powerpc/include/asm/udbg.h, arch/powerpc/kernel/udbg.c:
added opal and gelic drivers vs added ePAPR driver
- drivers/tty/serial/8250.c
moved UPIO_TSI to powerpc vs removed UPIO_DWAPB support
Use of the GPL or a compatible licence doesn't necessarily make the code
any good. We already consider staging modules to be suspect, and this
should also be true for out-of-tree modules which may receive very
little review.
Reviewed-by: Dave Jones <davej@redhat.com>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (patched oops-tracing.txt)
* 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM / Freezer: Revert 27920651fe "PM / Freezer: Make fake_signal_wake_up() wake TASK_KILLABLE tasks too"
PM / Freezer: Reimplement wait_event_freezekillable using freezer_do_not_count/freezer_count
USB: Update last_busy time after autosuspend fails
PM / Runtime: Automatically retry failed autosuspends
PM / QoS: Remove redundant check
PM / OPP: Fix build when CONFIG_PM_OPP is not set
PM / Runtime: Fix runtime accounting calculation error
PM / Sleep: Update freezer documentation
PM / Sleep: Remove unused symbol 'suspend_cpu_hotplug'
PM / Sleep: Fix race between CPU hotplug and freezer
ACPI / PM: Add Sony VPCEB17FX to nonvs blacklist
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (45 commits)
[SCSI] Fix block queue and elevator memory leak in scsi_alloc_sdev
[SCSI] scsi_dh_alua: Fix the time inteval for alua rtpg commands
[SCSI] scsi_transport_iscsi: Fix documentation os parameter
[SCSI] mv_sas: OCZ RevoDrive3 & zDrive R4 support
[SCSI] libfc: improve flogi retries to avoid lport stuck
[SCSI] libfc: avoid exchanges collision during lport reset
[SCSI] libfc: fix checking FC_TYPE_BLS
[SCSI] edd: Treat "XPRS" host bus type the same as "PCI"
[SCSI] isci: overriding max_concurr_spinup oem parameter by max(oem, user)
[SCSI] isci: revert bcn filtering
[SCSI] isci: Fix hard reset timeout conditions.
[SCSI] isci: No need to manage the pending reset bit on pending requests.
[SCSI] isci: Remove redundant isci_request.ttype field.
[SCSI] isci: Fix task management for SMP, SATA and on dev remove.
[SCSI] isci: No task_done callbacks in error handler paths.
[SCSI] isci: Handle task request timeouts correctly.
[SCSI] isci: Fix tag leak in tasks and terminated requests.
[SCSI] isci: Immediately fail I/O to removed devices.
[SCSI] isci: Lookup device references through requests in completions.
[SCSI] ipr: add definitions for additional adapter
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (63 commits)
dmaengine: mid_dma: mask_peripheral_interrupt only when dmac is idle
dmaengine/ep93xx_dma: add module.h include
pch_dma: Reduce wasting memory
pch_dma: Fix suspend issue
dma/timberdale: free_irq() on an error path
dma: shdma: transfer based runtime PM
dmaengine: shdma: protect against the IRQ handler
dmaengine i.MX DMA/SDMA: add missing include of linux/module.h
dmaengine: delete redundant chan_id and chancnt initialization in dma drivers
dmaengine/amba-pl08x: Check txd->llis_va before freeing dma_pool
dmaengine/amba-pl08x: Add support for sg len greater than one for slave transfers
serial: sh-sci: don't filter on DMA device, use only channel ID
ARM: SAMSUNG: Remove Samsung specific enum type for dma direction
ASoC: Samsung: Update DMA interface
spi/s3c64xx: Merge dma control code
spi/s3c64xx: Add support DMA engine API
ARM: SAMSUNG: Remove S3C-PL330-DMA driver
ARM: S5P64X0: Use generic DMA PL330 driver
ARM: S5PC100: Use generic DMA PL330 driver
ARM: S5PV210: Use generic DMA PL330 driver
Fix up fairly trivial conflicts in
- arch/arm/mach-exynos4/{Kconfig,clock.c}
- arch/arm/mach-s5p64x0/dma.c
* 'for-3.2/drivers' of git://git.kernel.dk/linux-block: (30 commits)
virtio-blk: use ida to allocate disk index
hpsa: add small delay when using PCI Power Management to reset for kump
cciss: add small delay when using PCI Power Management to reset for kump
xen/blkback: Fix two races in the handling of barrier requests.
xen/blkback: Check for proper operation.
xen/blkback: Fix the inhibition to map pages when discarding sector ranges.
xen/blkback: Report VBD_WSECT (wr_sect) properly.
xen/blkback: Support 'feature-barrier' aka old-style BARRIER requests.
xen-blkfront: plug device number leak in xlblk_init() error path
xen-blkfront: If no barrier or flush is supported, use invalid operation.
xen-blkback: use kzalloc() in favor of kmalloc()+memset()
xen-blkback: fixed indentation and comments
xen-blkfront: fix a deadlock while handling discard response
xen-blkfront: Handle discard requests.
xen-blkback: Implement discard requests ('feature-discard')
xen-blkfront: add BLKIF_OP_DISCARD and discard request struct
drivers/block/loop.c: remove unnecessary bdev argument from loop_clr_fd()
drivers/block/loop.c: emit uevent on auto release
drivers/block/cpqarray.c: use pci_dev->revision
loop: always allow userspace partitions and optionally support automatic scanning
Fic up trivial header file includsion conflict in drivers/block/loop.c
* 'for-3.2/core' of git://git.kernel.dk/linux-block: (29 commits)
block: don't call blk_drain_queue() if elevator is not up
blk-throttle: use queue_is_locked() instead of lockdep_is_held()
blk-throttle: Take blkcg->lock while traversing blkcg->policy_list
blk-throttle: Free up policy node associated with deleted rule
block: warn if tag is greater than real_max_depth.
block: make gendisk hold a reference to its queue
blk-flush: move the queue kick into
blk-flush: fix invalid BUG_ON in blk_insert_flush
block: Remove the control of complete cpu from bio.
block: fix a typo in the blk-cgroup.h file
block: initialize the bounce pool if high memory may be added later
block: fix request_queue lifetime handling by making blk_queue_cleanup() properly shutdown
block: drop @tsk from attempt_plug_merge() and explain sync rules
block: make get_request[_wait]() fail if queue is dead
block: reorganize throtl_get_tg() and blk_throtl_bio()
block: reorganize queue draining
block: drop unnecessary blk_get/put_queue() in scsi_cmd_ioctl() and blk_get_tg()
block: pass around REQ_* flags instead of broken down booleans during request alloc/free
block: move blk_throtl prototypes to block/blk.h
block: fix genhd refcounting in blkio_policy_parse_and_set()
Fix up trivial conflicts due to "mddev_t" -> "struct mddev" conversion
and making the request functions be of type "void" instead of "int" in
- drivers/md/{faulty.c,linear.c,md.c,md.h,multipath.c,raid0.c,raid1.c,raid10.c,raid5.c}
- drivers/staging/zram/zram_drv.c
slave->duplex is a u8 type so the in bond_info_show_slave() when we
check "if (slave->duplex == -1)", it's always false.
The documentation for how the length of attributes
is checked is wrong ("Exact length" isn't true, the
policy checks are for "minimum length") and a bit
misleading. Make it more complete and explain what
really happens.
Cc: Thomas Graf <tgraf@suug.ch>
Commit 27920651fe "PM / Freezer: Make fake_signal_wake_up() wake
TASK_KILLABLE tasks too" updated fake_signal_wake_up() used by freezer
to wake up KILLABLE tasks. Sending unsolicited wakeups to tasks in
killable sleep is dangerous as there are code paths which depend on
tasks not waking up spuriously from KILLABLE sleep.
For example. sys_read() or page can sleep in TASK_KILLABLE assuming
that wait/down/whatever _killable can only fail if we can not return
to the usermode. TASK_TRACED is another obvious example.
The offending commit was to resolve freezer hang during system PM
operations caused by KILLABLE sleeps in network filesystems.
wait_event_freezekillable(), which depends on the spurious KILLABLE
wakeup, was added by f06ac72e92 "cifs, freezer: add
wait_event_freezekillable and have cifs use it" to be used to
implement killable & freezable sleeps in network filesystems.
To prepare for reverting of 27920651fe, this patch reimplements
wait_event_freezekillable() using freezer_do_not_count/freezer_count()
so that it doesn't depend on the spurious KILLABLE wakeup. This isn't
very nice but should do for now.
[tj: Refreshed patch to apply to linus/master and updated commit
description on Rafael's request.]
Commit 03ca370fbf7b76d6d002380dbdc2cdc2319f9c80 (PM / OPP: Add
OPP availability change notifier) does not compile if CONFIG_PM_OPP
is not set:
arch/arm/plat-omap/omap-pm-noop.o: In function `opp_get_notifier':
include/linux/opp.h:103: multiple definition of `opp_get_notifier'
include/linux/opp.h:103: first defined here
Also fix incorrect comment.
Remove the suspend_cpu_hotplug declaration, which doesn't correspond
to an existing variable.
[rjw: Added the changelog.]
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
* 'nfs-for-3.2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (25 commits)
nfs: set vs_hidden on nfs4_callback_version4 (try #2)
pnfs-obj: Support for RAID5 read-4-write interface.
pnfs-obj: move to ore 03: Remove old raid engine
pnfs-obj: move to ore 02: move to ORE
pnfs-obj: move to ore 01: ore_layout & ore_components
pnfs-obj: Rename objlayout_io_state => objlayout_io_res
pnfs-obj: Get rid of objlayout_{alloc,free}_io_state
pnfs-obj: Return PNFS_NOT_ATTEMPTED in case of read/write_pagelist
pnfs-obj: Remove redundant EOF from objlayout_io_state
nfs: Remove unused variable from write.c
nfs: Fix unused variable warning from file.c
NFS: Remove no-op less-than-zero checks on unsigned variables.
NFS: Clean up nfs4_xdr_dec_secinfo()
NFS: Fix documenting comment for nfs_create_request()
NFS4: fix cb_recallany decode error
nfs4: serialize layoutcommit
SUNRPC: remove rpcbind clients destruction on module cleanup
SUNRPC: remove rpcbind clients creation during service registering
NFSd: call svc rpcbind cleanup explicitly
SUNRPC: cleanup service destruction
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
The warning really shouldn't happen, but until we
find the reason why it does don't spew it all the
time, just once is enough to know we've hit it.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (144 commits)
[media] saa7134.h: Suppress compiler warnings when CONFIG_VIDEO_SAA7134_RC is not set
[media] it913x [VER 1.07] Support for single ITE 9135 devices
[media] Support for Terratec G1
[media] cx25821: off by one in cx25821_vidioc_s_input()
[media] media: tea5764: reconcile Kconfig symbol and macro
[media] omap_vout: Add poll() support
[media] omap3isp: preview: Add crop support on the sink pad
[media] omap3isp: preview: Rename min/max input/output sizes defines
[media] omap3isp: preview: Remove horizontal averager support
[media] omap3isp: Report the ISP revision through the media controller API
[media] omap3isp: ccdc: remove redundant operation
[media] omap3isp: Fix memory leaks in initialization error paths
[media] omap3isp: Add missing mutex_destroy() calls
[media] omap3isp: Move *_init_entities() functions to the init/cleanup section
[media] omap3isp: Move media_entity_cleanup() from unregister() to cleanup()
[media] MFC: Change MFC firmware binary name
[media] vb2: add vb2_get_unmapped_area in vb2 core
[media] v4l: Add v4l2 subdev driver for S5K6AAFX sensor
[media] v4l: Add AUTO option for the V4L2_CID_POWER_LINE_FREQUENCY control
[media] media: ov6650: stylistic improvements
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6:
dt: add empty of_machine_is_compatible
ahci: add DT binding for Calxeda AHCI controller
dt/platform: minor cleanup
dt: add empty of_alias_get_id() for non-dt builds
All ->execute_task instances now need to complete the I/O explicitly,
which can either happen synchronously or asynchronously.
Note that a lot of the CDB emulations appear to return success even if
some lowlevel operations failed. Given that this is an existing issue
this patch doesn't change that fact.
(nab: Adding missing switch breaks in PR-IN + PR_OUT)
