path: root/include
2008-05-23cpumask: make for_each_cpu_mask a bit smallerAlexander van Heukelum
The for_each_cpu_mask loop is used quite often in the kernel. It makes use of two functions: first_cpu and next_cpu. This patch changes for_each_cpu_mask to use only the latter. Because next_cpu finds the next eligible cpu _after_ the given one, the iteration variable has to be initialized to -1 and next_cpu has to be called with this value before the first iteration. An x86_64 defconfig kernel (from sched/latest) is about 2500 bytes smaller with this patch applied: text data bss dec hex filename 6222517 917952 749932 7890401 7865e1 vmlinux.orig 6219922 917952 749932 7887806 785bbe vmlinux The same size reduction is seen for defconfig+MAXSMP text data bss dec hex filename 6241772 2563968 1492716 10298456 9d2458 vmlinux.orig 6239211 2563968 1492716 10295895 9d1a57 vmlinux Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23x86: use performance variant for_each_cpu_mask_nrMike Travis
Change references from for_each_cpu_mask to for_each_cpu_mask_nr where appropriate Reviewed-by: Paul Jackson <pj@sgi.com> Reviewed-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> commit 2d474871e2fb092eb46a0930aba5442e10eb96cc Author: Mike Travis <travis@sgi.com> Date: Mon May 12 21:21:13 2008 +0200
2008-05-23x86: Add performance variants of cpumask operatorsMike Travis
* Increase performance for systems with large count NR_CPUS by limiting the range of the cpumask operators that loop over the bits in a cpumask_t variable. This removes a large amount of wasted cpu cycles. * Add performance variants of the cpumask operators: int cpus_weight_nr(mask) Same using nr_cpu_ids instead of NR_CPUS int first_cpu_nr(mask) Number lowest set bit, or nr_cpu_ids int next_cpu_nr(cpu, mask) Next cpu past 'cpu', or nr_cpu_ids for_each_cpu_mask_nr(cpu, mask) for-loop cpu over mask using nr_cpu_ids * Modify following to use performance variants: #define num_online_cpus() cpus_weight_nr(cpu_online_map) #define num_possible_cpus() cpus_weight_nr(cpu_possible_map) #define num_present_cpus() cpus_weight_nr(cpu_present_map) #define for_each_possible_cpu(cpu) for_each_cpu_mask_nr((cpu), ...) #define for_each_online_cpu(cpu) for_each_cpu_mask_nr((cpu), ...) #define for_each_present_cpu(cpu) for_each_cpu_mask_nr((cpu), ...) * Comment added to include/linux/cpumask.h: Note: The alternate operations with the suffix "_nr" are used to limit the range of the loop to nr_cpu_ids instead of NR_CPUS when NR_CPUS > 64 for performance reasons. If NR_CPUS is <= 64 then most assembler bitmask operators execute faster with a constant range, so the operator will continue to use NR_CPUS. Another consideration is that nr_cpu_ids is initialized to NR_CPUS and isn't lowered until the possible cpus are discovered (including any disabled cpus). So early uses will span the entire range of NR_CPUS. (The net effect is that for systems with 64 or less CPU's there are no functional changes.) For inclusion into sched-devel/latest tree. Based on: git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git + sched-devel/latest .../mingo/linux-2.6-sched-devel.git Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Reviewed-by: Paul Jackson <pj@sgi.com> Reviewed-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: The world is not perfect patch. tcp: Make prior_ssthresh a u32 xfrm_user: Remove zero length key checks. net/ipv4/arp.c: Use common hex_asc helpers cassini: Only use chip checksum for ipv4 packets. tcp: TCP connection times out if ICMP frag needed is delayed netfilter: Move linux/types.h inclusions outside of #ifdef __KERNEL__ af_key: Fix selector family initialization. libertas: Fix ethtool statistics mac80211: fix NULL pointer dereference in ieee80211_compatible_rates mac80211: don't claim iwspy support orinoco_cs: add ID for SpeedStream wireless adapters hostap_cs: add ID for Conceptronic CON11CPro rtl8187: resource leak in error case ath5k: Fix loop variable initializations
2008-05-21tcp: Make prior_ssthresh a u32Ilpo Järvinen
If previous window was above representable values of u16, strange things will happen if undo with the truncated value is called for. Alternatively, this could be fixed by some max trickery but that would limit undoing high-speed undos. Adds 16-bit hole but there isn't anything to fill it with. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-21netfilter: Move linux/types.h inclusions outside of #ifdef __KERNEL__Patrick McHardy
Greg Steuck <greg@nest.cx> points out that some of the netfilter headers can't be used in userspace without including linux/types.h first. The headers include their own linux/types.h include statements, these are stripped by make headers-install because they are inside #ifdef __KERNEL__ however. Move them out to fix this. Reported and Tested by Greg Steuck. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20Merge branch 'for-2.6.26' of git://linux-nfs.org/~bfields/linuxtip-x86-xsave-2008-05-26_08_54_Montip-x86-cpu-2008-05-26_08_53_MonLinus Torvalds
* 'for-2.6.26' of git://linux-nfs.org/~bfields/linux: (25 commits) svcrdma: Verify read-list fits within RPCSVC_MAXPAGES svcrdma: Change svc_rdma_send_error return type to void svcrdma: Copy transport address and arm CQ before calling rdma_accept svcrdma: Set rqstp transport address in rdma_read_complete function svcrdma: Use ib verbs version of dma_unmap svcrdma: Cleanup queued, but unprocessed I/O in svc_rdma_free svcrdma: Move the QP and cm_id destruction to svc_rdma_free svcrdma: Add reference for each SQ/RQ WR svcrdma: Move destroy to kernel thread svcrdma: Shrink scope of spinlock on RQ CQ svcrdma: Use standard Linux lists for context cache svcrdma: Simplify RDMA_READ deferral buffer management svcrdma: Remove unused READ_DONE context flags bit svcrdma: Return error from rdma_read_xdr so caller knows to free context svcrdma: Fix error handling during listening endpoint creation svcrdma: Free context on post_recv error in send_reply svcrdma: Free context on ib_post_recv error svcrdma: Add put of connection ESTABLISHED reference in rdma_cma_handler svcrdma: Fix return value in svc_rdma_send svcrdma: Fix race with dto_tasklet in svc_rdma_send ...
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) pktgen: make sure that pktgen_thread_worker has been executed [VLAN]: Propagate selected feature bits to VLAN devices drivers/atm/: remove CVS keywords vlan: Correctly handle device notifications for layered VLAN devices net: Fix call to ->change_rx_flags(dev, IFF_MULTICAST) in dev_change_flags() net_sched: cls_api: fix return value for non-existant classifiers ipsec: Use the correct ip_local_out function ipv6 addrconf: Allow infinite prefix lifetime. ipv6 route: Fix lifetime in netlink. ipv6 addrconf: Fix route lifetime setting in corner case. ndisc: Add missing strategies for per-device retrans timer/reachable time settings. ipv6: Move <linux/in6.h> from header-y to unifdef-y. l2tp: avoid skb truesize bug if headroom is increased wireless: Create 'device' symlink in sysfs wireless, airo: waitbusy() won't delay libertas: fix command timeout after firmware failure mac80211: Add RTNL version of ieee80211_iterate_active_interfaces mac80211 : Association with 11n hidden ssid ap. hostap: fix "registers" registration in procfs isdn/capi: Return proper errnos on module init. ...
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Add global register dumping facility. sparc: remove CVS keywords sparc64: remove CVS keywords
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: CDC WDM driver USB: ehci-orion: the Orion EHCI root hub does have a Transaction Translator USB: serial: ch341: New VID/PID for CH341 USB-serial USB: build fix USB: pxa27x_udc - Fix Oops USB: OPTION: fix name of Onda MSA501HS HSDPA modem USB: add TELIT HDSPA UC864-E modem to option driver usb-serial: Use ftdi_sio driver for RATOC REX-USB60F
2008-05-20[VLAN]: Propagate selected feature bits to VLAN devicesPatrick McHardy
Propagate feature bits from the NETDEV_FEAT_CHANGE notifier. For now only TSO is propagated for devices that announce their ability to support TSO in combination with VLAN accel by setting the NETIF_F_VLAN_TSO flag. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20USB: CDC WDM driverOliver Neukum
Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20Driver core: add device_create_vargs and device_create_drvdataGreg Kroah-Hartman
We want to have the drvdata field set properly when creating the device as sysfs callbacks can assume it is present and it can race the later setting of this field. So, create two new functions, deviec_create_vargs() and device_create_drvdata() that take this new field. device_create_drvdata() will go away in 2.6.27 as the drvdata field will just be moved to the device_create() call as it should be. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20Fix a deadlock in the bttv driverArjan van de Ven
vidiocgmbuf() does this: mutex_lock(&fh->cap.vb_lock); retval = videobuf_mmap_setup(&fh->cap, gbuffers, gbufsize, V4L2_MEMORY_MMAP); and videobuf_mmap_setup() then just does mutex_lock(&q->vb_lock); ret = __videobuf_mmap_setup(q, bcount, bsize, memory); mutex_unlock(&q->vb_lock); which is an obvious double-take deadlock. This patch fixes this by having vidiocgmbuf() just call the __videobuf_mmap_setup function instead. Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Reported-by: Koos Vriezen <koos.vriezen@gmail.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: remove CVS keywords HID: Add iMON LCDs to blacklist HID: add Microchip PICKit 1 and PICkit 2 to blacklist HID: split Numlock emulation quirk from HID_QUIRK_APPLE_HAS_FN.
2008-05-20x86: strengthen 64-bit p?d_bad()Hugh Dickins
The x86_64 pgd_bad(), pud_bad(), pmd_bad() inlines have differed from their x86_32 counterparts in a couple of ways: they've been unnecessarily weak (e.g. letting 0 or 1 count as good), and were typed as unsigned long. Strengthen them and return int. The PAE pmd_bad was too weak before, allowing any junk in the upper half; but got strengthened by the patch correcting its ~PAGE_MASK to ~PTE_MASK. The PAE pud_bad already said ~PTE_MASK; and since it folds into pgd_bad, and we don't set the protection bits at that level, it'll do as is. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20xen: use PTE_MASK in pte_mfn()Jeremy Fitzhardinge
Use PTE_MASK to extract mfn from pte. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: use PTE_MASK rather than ad-hoc maskJeremy Fitzhardinge
Use ~PTE_MASK to extract the non-pfn parts of the pte (ie, the pte flags), rather than constructing an ad-hoc mask. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: clarify use of _PAGE_CHG_MASKJeremy Fitzhardinge
_PAGE_CHG_MASK is defined as the set of bits not updated by pte_modify(); specifically, the pfn itself, and the Accessed and Dirty bits (which are updated by hardware). Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: use PTE_MASK in pgtable_32.hJeremy Fitzhardinge
2008-05-20x86: use PTE_MASK in 32-bit PAEJeremy Fitzhardinge
Use PTE_MASK in 3-level pagetables (ie, 32-bit PAE). Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: rearrange __(VIRTUAL|PHYSICAL)_MASKJeremy Fitzhardinge
Put the definitions of __(VIRTUAL|PHYSICAL)_MASK before their uses. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: fix warning on 32-bit non-PAEJeremy Fitzhardinge
Fix the warning: include2/asm/pgtable.h: In function `pte_modify': include2/asm/pgtable.h:290: warning: left shift count >= width of type On 32-bit PAE the virtual and physical addresses are both 32-bits, so it ends up evaluating 1<<32. Do the shift as a 64-bit shift then cast to the appropriate size. This should all be done at compile time, and so have no effect on generated code. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: define PTE_MASK in a universally useful wayJeremy Fitzhardinge
Define PTE_MASK so that it contains a meaningful value for all x86 pagetable configurations. Previously it was defined as a "long" which means that it was too short to cover a 32-bit PAE pte entry. It is now defined as a pteval_t, which is an integer type long enough to contain a full pte (or pmd, pud, pgd). This fixes an Xorg crash on 32-bit x86 with PAE due to corruption of the NX bit in mprotect due to the incorrect type/value of PTE_MASK reported by Hugh Dickins: "Yes, thanks Jeremy: I've checked that each stage builds and runs X on my boxes here, x86_32 and x86_32+PAE and x86_64. (So even 1/8 is enough to fix the PAT pte_modify issue, though 2/8 then fixes compiler warnings.)" Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20HID: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-05-20HID: split Numlock emulation quirk from HID_QUIRK_APPLE_HAS_FN.Diego 'Flameeyes' Petteno
Since 2.6.25 the HID_QUIRK_APPLE_HAS_FN quirk is enabled even for non-laptop Apple keyboards of the Aluminium series. The USB version of these don't need Numlock emulation, like the laptop (and Aluminium Wireless) do, as they have a proper keypad. This patch splits the Numlock emulation for Apple keyboards in a different quirk flag, so that it can be enabled for all the keyboards but the Aluminium USB ones. If the Numlock emulation is enabled for Aluminium USB keyboards, the JKL and UIO keys become the numeric pad, and the rest of the keyboard is disabled, included the key used to disable Numlock. Additionally, these keyboard should not have a Numlock at all, as the Numlock key is instead replaced by the 'Clear' key as usual for Apple USB keyboards. Signed-off-by: Diego 'Flameeyes' Petteno <flameeyes@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-05-20sparc64: Add global register dumping facility.David S. Miller
When a cpu really is stuck in the kernel, it can be often impossible to figure out which cpu is stuck where. The worst case is when the stuck cpu has interrupts disabled. Therefore, implement a global cpu state capture that uses SMP message interrupts which are not disabled by the normal IRQ enable/disable APIs of the kernel. As long as we can get a sysrq 'y' to the kernel, we can get a dump. Even if the console interrupt cpu is wedged, we can trigger it from userspace using /proc/sysrq-trigger The output is made compact so that this facility is more useful on high cpu count systems, which is where this facility will likely find itself the most useful :) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
2008-05-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] return to old errno choice in mkdir() et.al. [Patch] fs/binfmt_elf.c: fix wrong return values [PATCH] get rid of leak in compat_execve() [Patch] fs/binfmt_elf.c: fix a wrong free [PATCH] avoid multiplication overflows and signedness issues for max_fds [PATCH] dup_fd() part 4 - race fix [PATCH] dup_fd() - part 3 [PATCH] dup_fd() part 2 [PATCH] dup_fd() fixes, part 1 [PATCH] take init_files to fs/file.c
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: Blackfin SPORTS UART Driver: converting BFIN->BLACKFIN Blackfin serial driver: add extra IRQ flag for 8250 serial driver 8250 Serial Driver: Added support for 8250-class UARTs in HV Sistemas H8606 board Blackfin arch: Fix bug - USB fails to build for BF524/BF526 Blackfin arch: update boards defconfig files Blackfin arch: IO Port functions to read/write unalligned memory Blackfin arch: enable a choice to provide 4M DMA memory Blackfin arch: cleanup the icplb/dcplb multiple hit checks Blackfin arch: Add workaround to read edge triggered GPIOs Blackfin arch: Sync channel defines with struct dma_register dma_io_base_addr. Blackfin arch: Check for Anomaly 05000182 [Blackfin] arch: rename bf5xx-flash to bfin-async-flash [Blackfin] arch: Blackfin checksum annotations
2008-05-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Fix up restorer in debug_trap exception return path. sh: Make is_valid_bugaddr() more intelligent on nommu. sh: use the common ascii hex helpers sh: fix sh7785 master clock value sh: Fix up thread info pointer in syscall_badsys resume path. sh: Fix up optimized SH-4 memcpy on big endian. sh: disable initrd defaults in .empty_zero_page. sh: display boot params by default on entry.
2008-05-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-2.6
2008-05-19Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (28 commits) drivers/ata: trim trailing whitespace Fixups to ATA ACPI hotplug libata: ignore SIMG4726 config pseudo device sata_sil24: don't use NCQ if marvell 4140 PMP is attached libata: don't schedule LPM action seperately during probing libata: make sure PMP notification is turned off during recovery libata: increase PMP register access timeout to 3s libata: ignore recovered PHY errors libata: kill hotplug related race condition libata: move reset freeze/thaw handling into ata_eh_reset() libata: reorganize ata_eh_reset() no reset method path libata: fix sata_link_hardreset() @online out parameter handling sata_promise: other cleanups sata_promise: mmio access cleanups sata_promise: fix irq clearing buglets ata: remove FIT() macro sata_mv: ensure empty request queue for FBS-NCQ EH sata_mv: cache main_irq_mask register in hpriv sata_mv: disregard masked irqs sata_mv: fix pmp drives not found ...
2008-05-19ndisc: Add missing strategies for per-device retrans timer/reachable time ↵YOSHIFUJI Hideaki
settings. Noticed from Al Viro <viro@ftp.linux.org.uk> via David Miller <davem@davemloft.net>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-19libata: ignore SIMG4726 config pseudo deviceTejun Heo
I was hoping ATA_HORKAGE_NODMA | ATA_HORKAGE_SKIP_PM could keep it happy but no even this doesn't work under certain configurations and it's not like we can do anything useful with the cofig device anyway. Replace ATA_HORKAGE_SKIP_PM with ATA_HORKAGE_DISABLE and use it for the config device. This makes the device completely ignored by libata. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-19libata: increase PMP register access timeout to 3sTejun Heo
This timeout was set low because previously PMP register access was done via polling and register access timeouts could stack up. This is no longer the case. One timeout will make all following accesses fail immediately. In rare cases both marvell and SIMG PMPs need almost a second. Bump it to 3s. While at it, rename it to SATA_PMP_RW_TIMEOUT. It's not specific to SCR access. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-19ata: remove FIT() macroHarvey Harrison
Use the kernel-provided clamp_val() macro. FIT was always applied to a member of struct ata_timing (unsigned short) and two constants. clamp_val will not cast to short anymore. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-19ipv6: Move <linux/in6.h> from header-y to unifdef-y.Robert P. J. Day
Given that <linux/in6.h> contains a __KERNEL__ test, it should be unifdef-ed. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm: dlm: <linux/dlm_plock.h> should be "unifdef"ed. dlm: fix plock dev_write return value dlm: tcp_connect_to_sock should check for -EINVAL, not EINVAL dlm: section mismatch warning fix dlm: convert connections_lock in a mutex
2008-05-19Merge branch 'kvm-updates-2.6.26' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'kvm-updates-2.6.26' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: KVM: LAPIC: ignore pending timers if LVTT is disabled KVM: Update MAINTAINERS for new mailing lists KVM: Fix kvm_vcpu_block() task state race KVM: ia64: Set KVM_IOAPIC_NUM_PINS to 48 KVM: ia64: fix GVMM module including position-dependent objects KVM: ia64: Define new kvm_fpreg struture to replace ia64_fpreg KVM: PIT: take inject_pending into account when emulating hlt s390: KVM guest: fix compile error KVM: x86 emulator: fix writes to registers with modrm encodings
2008-05-19dlm: <linux/dlm_plock.h> should be "unifdef"ed.Robert P. J. Day
Given that <linux/dlm_plock.h> contains a conditional __KERNEL__ test, it should be moved from header-y to unifdef-y. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: David Teigland <teigland@redhat.com>
2008-05-19svcrdma: Change svc_rdma_send_error return type to voidTom Tucker
The svc_rdma_send_error function is called when an RPCRDMA protocol error is detected. This function attempts to post an error reply message. Since an error posting to a transport in error is ignored, change the return type to void. Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-05-19svcrdma: Move destroy to kernel threadTom Tucker
Some providers may wait while destroying adapter resources. Since it is possible that the last reference is put on the dto_tasklet, the actual destroy must be scheduled as a work item. Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-05-19svcrdma: Use standard Linux lists for context cacheTom Tucker
Replace the one-off linked list implementation used to implement the context cache with the standard Linux list_head lists. Add a context counter to catch resource leaks. A WARN_ON will be added later to ensure that we've freed all contexts. Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-05-19svcrdma: Simplify RDMA_READ deferral buffer managementTom Tucker
An NFS_WRITE requires a set of RDMA_READ requests to fetch the write data from the client. There are two principal pieces of data that need to be tracked: the list of pages that comprise the completed RPC and the SGE of dma mapped pages to refer to this list of pages. Previously this whole bit was managed as a linked list of contexts with the context containing the page list buried in this list. This patch simplifies this processing by not keeping a linked list, but rather only a pionter from the last submitted RDMA_READ's context to the context that maps the set of pages that describe the RPC. This significantly simplifies this code path. SGE contexts are cleaned up inline in the DTO path instead of at read completion time. Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-05-19svcrdma: Remove unused READ_DONE context flags bitTom Tucker
The RDMACTXT_F_READ_DONE bit is not longer used. Remove it. Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-05-18Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c/max6875: Really prevent 24RF08 corruption i2c-amd756: Fix functionality flags i2c: Kill the old driver matching scheme i2c: Convert remaining new-style drivers to use module aliasing i2c: Switch pasemi to the new device/driver matching scheme i2c: Clean up Blackfin BF527 I2C device declarations i2c-nforce2: Disable the second SMBus channel on the DFI Lanparty NF4 Expert i2c: New co-maintainer
2008-05-18m68k: Prefix ISA type with ISA_TYPE_Geert Uytterhoeven
The *_ISA type defines are quite generic and cause namespace conflicts (e.g. with `AMIGAHW_DECLARE(GG2_ISA)' in <asm/amigahw.h>) for some kernel configurations. Use ISA_TYPE_* to avoid such conflicts. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: export m68k_mmutypeGeert Uytterhoeven
UIO needs m68k_mmutype: ERROR: "m68k_mmutype" [drivers/uio/uio.ko] undefined! (noticed by Christian T. Steigies) Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
