David says "884b4aaaa242a2db8c8252796f0118164a680ab5 should be reverted. It
added an rtc_merge_alarm() call to the 2.6.20 kernel, which hasn't yet been
used by any in-tree driver; this patch obviates the need for that call, and
uses a more robust approach."
Cc: Scott Wood <scottwood@freescale.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
I finally got around to testing the updated wakeup event hooks for rtc-cmos,
and they follow in two patches:
- Interface update ... when a simple enable_irq_wake() doesn't suffice,
the platform data can hold suspend/resume callback hooks.
- ACPI implementation ... provides callback hooks to do ACPI magic, and
eliminate the legacy /proc/acpi/alarm file.
The interface update could go into 2.6.21, but that's not essential; they
will be NOPs on most PCs, without the ACPI stuff.
I suspect the ACPI folk may have opinions about how to merge that second
patch, and how to obsolete that legacy procfs file. I'd like to see that
merge into 2.6.22 if possible...
As for how to kick it in ... two ways:
- The appended "rtcwake" program; updated since the last time it was
posted, it deals much better with timezones and DST.
- Write the /sys/class/rtc/.../wakealarm file, then go to sleep.
For some reason RTC wake from "swsusp" stopped working on a system where
it previously worked; the alarm setting appears to get clobbered. But
on the bright side, RTC wake from "standby" worked on a system that had
never been able to resume from that state before ... IDEACPI is my guess
as to why it finally started to work. It's the old "two steps forward,
one step back" dance, I guess.
- Dave
/* gcc -Wall -Os -o rtcwake rtcwake.c */
#include <stdio.h>
#include <getopt.h>
#include <fcntl.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <errno.h>
#include <time.h>
#include <sys/ioctl.h>
#include <sys/time.h>
#include <sys/types.h>
#include <linux/rtc.h>
/* constants from legacy PC/AT hardware */
#define RTC_PF 0x40
#define RTC_AF 0x20
#define RTC_UF 0x10
* rtcwake -- enter a system sleep state until specified wakeup time.
* This uses cross-platform Linux interfaces to enter a system sleep state,
* and leave it no later than a specified time. It uses any RTC framework
* driver that supports standard driver model wakeup flags.
* This is normally used like the old "apmsleep" utility, to wake from a
* suspend state like ACPI S1 (standby) or S3 (suspend-to-RAM). Most
* platforms can implement those without analogues of BIOS, APM, or ACPI.
* On some systems, this can also be used like "nvram-wakeup", waking
* from states like ACPI S4 (suspend to disk). Not all systems have
* persistent media that are appropriate for such suspend modes.
* The best way to set the system's RTC is so that it holds the current
* time in UTC. Use the "-l" flag to tell this program that the system
* RTC uses a local timezone instead (maybe you dual-boot MS-Windows).
static char *progname;
#ifdef DEBUG
#define VERSION "1.0 dev (" __DATE__ " " __TIME__ ")"
#else
#define VERSION "0.9"
#endif
static unsigned verbose;
static int rtc_is_utc = -1;
static int may_wakeup(const char *devname)
char buf[128], *s;
FILE *f;
snprintf(buf, sizeof buf, "/sys/class/rtc/%s/device/power/wakeup",
devname);
f = fopen(buf, "r");
if (!f) {
perror(buf);
return 0;
fgets(buf, sizeof buf, f);
fclose(f);
s = strchr(buf, '\n');
if (!s)
return 0;
*s = 0;
/* wakeup events could be disabled or not supported */
return strcmp(buf, "enabled") == 0;
/* all times should be in UTC */
static time_t sys_time;
static time_t rtc_time;
static int get_basetimes(int fd)
struct tm tm;
struct rtc_time rtc;
/* this process works in RTC time, except when working
* with the system clock (which always uses UTC).
if (rtc_is_utc)
setenv("TZ", "UTC", 1);
tzset();
/* read rtc and system clocks "at the same time", or as
* precisely (+/- a second) as we can read them.
if (ioctl(fd, RTC_RD_TIME, &rtc) < 0) {
perror("read rtc time");
return 0;
sys_time = time(0);
if (sys_time == (time_t)-1) {
perror("read system time");
return 0;
/* convert rtc_time to normal arithmetic-friendly form,
* updating tm.tm_wday as used by asctime().
memset(&tm, 0, sizeof tm);
tm.tm_sec = rtc.tm_sec;
tm.tm_min = rtc.tm_min;
tm.tm_hour = rtc.tm_hour;
tm.tm_mday = rtc.tm_mday;
tm.tm_mon = rtc.tm_mon;
tm.tm_year = rtc.tm_year;
tm.tm_isdst = rtc.tm_isdst; /* stays unspecified? */
rtc_time = mktime(&tm);
if (rtc_time == (time_t)-1) {
perror("convert rtc time");
return 0;
if (verbose) {
if (!rtc_is_utc) {
printf("\ttzone = %ld\n", timezone);
printf("\ttzname = %s\n", tzname[daylight]);
gmtime_r(&rtc_time, &tm);
printf("\tsystime = %ld, (UTC) %s",
(long) sys_time, asctime(gmtime(&sys_time)));
printf("\trtctime = %ld, (UTC) %s",
(long) rtc_time, asctime(&tm));
return 1;
static int setup_alarm(int fd, time_t *wakeup)
struct tm *tm;
struct rtc_wkalrm wake;
tm = gmtime(wakeup);
wake.time.tm_sec = tm->tm_sec;
wake.time.tm_min = tm->tm_min;
wake.time.tm_hour = tm->tm_hour;
wake.time.tm_mday = tm->tm_mday;
wake.time.tm_mon = tm->tm_mon;
wake.time.tm_year = tm->tm_year;
wake.time.tm_wday = tm->tm_wday;
wake.time.tm_yday = tm->tm_yday;
wake.time.tm_isdst = tm->tm_isdst;
/* many rtc alarms only support up to 24 hours from 'now' ... */
if ((rtc_time + (24 * 60 * 60)) > *wakeup) {
if (ioctl(fd, RTC_ALM_SET, &wake.time) < 0) {
perror("set rtc alarm");
return 0;
if (ioctl(fd, RTC_AIE_ON, 0) < 0) {
perror("enable rtc alarm");
return 0;
/* ... so use the "more than 24 hours" request only if we must */
} else {
/* avoid an extra AIE_ON call */
wake.enabled = 1;
if (ioctl(fd, RTC_WKALM_SET, &wake) < 0) {
perror("set rtc wake alarm");
return 0;
return 1;
static void suspend_system(const char *suspend)
FILE *f = fopen("/sys/power/state", "w");
if (!f) {
perror("/sys/power/state");
return;
fprintf(f, "%s\n", suspend);
fflush(f);
/* this executes after wake from suspend */
fclose(f);
int main(int argc, char **argv)
static char *devname = "rtc0";
static unsigned seconds = 0;
static char *suspend = "standby";
int t;
int fd;
time_t alarm = 0;
progname = strrchr(argv[0], '/');
if (progname)
progname++;
else
progname = argv[0];
if (chdir("/dev/") < 0) {
perror("chdir /dev");
return 1;
while ((t = getopt(argc, argv, "d:lm:s:t:uVv")) != EOF) {
switch (t) {
case 'd':
devname = optarg;
break;
case 'l':
rtc_is_utc = 0;
break;
/* what system power mode to use? for now handle only
* standardized mode names; eventually when systems define
* their own state names, parse /sys/power/state.
* "on" is used just to test the RTC alarm mechanism,
* bypassing all the wakeup-from-sleep infrastructure.
case 'm':
if (strcmp(optarg, "standby") == 0
|| strcmp(optarg, "mem") == 0
|| strcmp(optarg, "disk") == 0
|| strcmp(optarg, "on") == 0
suspend = optarg;
break;
printf("%s: unrecognized suspend state '%s'\n",
progname, optarg);
goto usage;
/* alarm time, seconds-to-sleep (relative) */
case 's':
t = atoi(optarg);
if (t < 0) {
printf("%s: illegal interval %s seconds\n",
progname, optarg);
goto usage;
seconds = t;
break;
/* alarm time, time_t (absolute, seconds since 1/1 1970 UTC) */
case 't':
t = atoi(optarg);
if (t < 0) {
printf("%s: illegal time_t value %s\n",
progname, optarg);
goto usage;
alarm = t;
break;
case 'u':
rtc_is_utc = 1;
break;
case 'v':
verbose++;
break;
case 'V':
printf("%s: version %s\n", progname, VERSION);
break;
default:
usage:
printf("usage: %s [options]"
"\n\t"
"-d rtc0|rtc1|...\t(select rtc)"
"\n\t"
"-l\t\t\t(RTC uses local timezone)"
"\n\t"
"-m standby|mem|...\t(sleep mode)"
"\n\t"
"-s seconds\t\t(seconds to sleep)"
"\n\t"
"-t time_t\t\t(time to wake)"
"\n\t"
"-u\t\t\t(RTC uses UTC)"
"\n\t"
"-v\t\t\t(verbose messages)"
"\n\t"
"-V\t\t\t(show version)"
"\n",
progname);
return 1;
if (!alarm && !seconds) {
printf("%s: must provide wake time\n", progname);
goto usage;
/* REVISIT: if /etc/adjtime exists, read it to see what
* the util-linux version of hwclock assumes.
if (rtc_is_utc == -1) {
printf("%s: assuming RTC uses UTC ...\n", progname);
rtc_is_utc = 1;
/* this RTC must exist and (if we'll sleep) be wakeup-enabled */
fd = open(devname, O_RDONLY);
if (fd < 0) {
perror(devname);
return 1;
if (strcmp(suspend, "on") != 0 && !may_wakeup(devname)) {
printf("%s: %s not enabled for wakeup events\n",
progname, devname);
return 1;
/* relative or absolute alarm time, normalized to time_t */
if (!get_basetimes(fd))
return 1;
if (verbose)
printf("alarm %ld, sys_time %ld, rtc_time %ld, seconds %u\n",
alarm, sys_time, rtc_time, seconds);
if (alarm) {
if (alarm < sys_time) {
printf("%s: time doesn't go backward to %s",
progname, ctime(&alarm));
return 1;
alarm += sys_time - rtc_time;
} else
alarm = rtc_time + seconds + 1;
if (setup_alarm(fd, &alarm) < 0)
return 1;
sync();
printf("%s: wakeup from \"%s\" using %s at %s",
progname, suspend, devname,
ctime(&alarm));
fflush(stdout);
usleep(10 * 1000);
if (strcmp(suspend, "on") != 0)
suspend_system(suspend);
else {
unsigned long data;
do {
t = read(fd, &data, sizeof data);
if (t < 0) {
perror("rtc read");
break;
if (verbose)
printf("... %s: %03lx\n", devname, data);
} while (!(data & RTC_AF));
if (ioctl(fd, RTC_AIE_OFF, 0) < 0)
perror("disable rtc alarm interrupt");
close(fd);
return 0;
This patch:
Make rtc-cmos do the relevant magic so this RTC can wake the system from a
sleep state. That magic comes in two basic flavors:
- Straightforward: enable_irq_wake(), the way it'd work on most SOC chips;
or generally with system sleep states which don't disable core IRQ logic.
- Roundabout, using non-IRQ platform hooks. This is needed with ACPI and
one almost-clone chip which uses a special wakeup-only alarm. (That's
the RTC used on Footbridge boards, FWIW, which don't do PM in Linux.)
A separate patch implements those hooks for ACPI platforms, so that rtc_cmos
can issue system wakeup events (and its sysfs "wakealarm" attribute works on
at least some systems).
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Len Brown <lenb@kernel.org>
Finish converting the RTC framework so it no longer uses class_device.
Acked-By: Alessandro Zummo <a.zummo@towertech.it>
This patch removes class_device from the programming interface that the RTC
framework exposes to the rest of the kernel. Now an rtc_device is passed,
which is more type-safe and streamlines all the relevant code.
This simplifies the /dev support by removing a superfluous class_device (the
/sys/class/rtc-dev stuff) and the class_interface that hooks it into the rtc
core. Accordingly, if it's configured then /dev support is now part of the
RTC core, and is never a separate module.
It's another step towards being able to remove "struct class_device".
[bunk@stusta.de: drivers/rtc/rtc-dev.c should #include "rtc-core.h"]
Implement utimensat(2) which is an extension to futimesat(2) in that it
a) supports nano-second resolution for the timestamps
b) allows to selectively ignore the atime/mtime value
c) allows to selectively use the current time for either atime or mtime
d) supports changing the atime/mtime of a symlink itself along the lines
of the BSD lutimes(3) functions
For this change the internally used do_utimes() functions was changed to
accept a timespec time value and an additional flags parameter.
Additionally the sys_utime function was changed to match compat_sys_utime
which already use do_utimes instead of duplicating the work.
Also, the completely missing futimensat() functionality is added. We have
such a function in glibc but we have to resort to using /proc/self/fd/* which
not everybody likes (chroot etc).
Test application (the syscall number will need per-arch editing):
#include <errno.h>
#include <fcntl.h>
#include <time.h>
#include <stddef.h>
#include <syscall.h>
#define __NR_utimensat 280
#define UTIME_NOW ((1l << 30) - 1l)
#define UTIME_OMIT ((1l << 30) - 2l)
int
main(void)
int status = 0;
int fd = open("ttt", O_RDWR|O_CREAT|O_EXCL, 0666);
if (fd == -1)
error (1, errno, "failed to create test file \"ttt\"");
struct stat64 st1;
if (fstat64 (fd, &st1) != 0)
error (1, errno, "fstat failed");
struct timespec t[2];
t[0].tv_sec = 0;
t[0].tv_nsec = 0;
t[1].tv_sec = 0;
t[1].tv_nsec = 0;
if (syscall(__NR_utimensat, AT_FDCWD, "ttt", t, 0) != 0)
error (1, errno, "utimensat failed");
struct stat64 st2;
if (fstat64 (fd, &st2) != 0)
if (st2.st_atim.tv_sec != 0 || st2.st_atim.tv_nsec != 0)
puts ("atim not reset to zero");
status = 1;
if (st2.st_mtim.tv_sec != 0 || st2.st_mtim.tv_nsec != 0)
puts ("mtim not reset to zero");
status = 1;
if (status != 0)
goto out;
t[0] = st1.st_atim;
t[1].tv_sec = 0;
t[1].tv_nsec = UTIME_OMIT;
if (st2.st_atim.tv_sec != st1.st_atim.tv_sec
|| st2.st_atim.tv_nsec != st1.st_atim.tv_nsec)
puts ("atim not set");
status = 1;
puts ("mtim changed from zero");
status = 1;
if (status != 0)
goto out;
t[0].tv_sec = 0;
t[0].tv_nsec = UTIME_OMIT;
t[1] = st1.st_mtim;
puts ("mtim changed from original time");
status = 1;
if (st2.st_mtim.tv_sec != st1.st_mtim.tv_sec
|| st2.st_mtim.tv_nsec != st1.st_mtim.tv_nsec)
puts ("mtim not set");
status = 1;
if (status != 0)
goto out;
sleep (2);
t[0].tv_sec = 0;
t[0].tv_nsec = UTIME_NOW;
t[1].tv_sec = 0;
t[1].tv_nsec = UTIME_NOW;
struct timeval tv;
gettimeofday(&tv,NULL);
if (st2.st_atim.tv_sec <= st1.st_atim.tv_sec
|| st2.st_atim.tv_sec > tv.tv_sec)
puts ("atim not set to NOW");
status = 1;
if (st2.st_mtim.tv_sec <= st1.st_mtim.tv_sec
|| st2.st_mtim.tv_sec > tv.tv_sec)
puts ("mtim not set to NOW");
status = 1;
if (symlink ("ttt", "tttsym") != 0)
error (1, errno, "cannot create symlink");
t[0].tv_sec = 0;
t[0].tv_nsec = 0;
t[1].tv_sec = 0;
t[1].tv_nsec = 0;
if (syscall(__NR_utimensat, AT_FDCWD, "tttsym", t, AT_SYMLINK_NOFOLLOW) != 0)
if (lstat64 ("tttsym", &st2) != 0)
error (1, errno, "lstat failed");
puts ("symlink atim not reset to zero");
status = 1;
puts ("symlink mtim not reset to zero");
status = 1;
if (status != 0)
goto out;
t[0].tv_sec = 1;
t[0].tv_nsec = 0;
t[1].tv_sec = 1;
t[1].tv_nsec = 0;
if (syscall(__NR_utimensat, fd, NULL, t, 0) != 0)
if (st2.st_atim.tv_sec != 1 || st2.st_atim.tv_nsec != 0)
puts ("atim not reset to one");
status = 1;
if (st2.st_mtim.tv_sec != 1 || st2.st_mtim.tv_nsec != 0)
puts ("mtim not reset to one");
status = 1;
if (status == 0)
puts ("all OK");
out:
close (fd);
unlink ("ttt");
unlink ("tttsym");
return status;
[akpm@linux-foundation.org: add missing i386 syscall table entry]
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Cc: Alexey Dobriyan <adobriyan@openvz.org>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
Cc: <linux-arch@vger.kernel.org>
I noticed expensive divides done in try_to_wakeup() and
find_busiest_group() on a bi dual core Opteron machine (total of 4 cores),
moderatly loaded (15.000 context switch per second)
oprofile numbers :
CPU: AMD64 processors, speed 2600.05 MHz (estimated)
Counted CPU_CLK_UNHALTED events (Cycles outside of halt state) with a unit
mask of 0x00 (No unit mask) count 50000
samples % symbol name
613914 1.0498 try_to_wake_up
834 0.0013 :ffffffff80227ae1: div %rcx
77513 0.1191 :ffffffff80227ae4: mov %rax,%r11
608893 1.0413 find_busiest_group
1841 0.0031 :ffffffff802260bf: div %rdi
140109 0.2394 :ffffffff802260c2: test %sil,%sil
Some of these divides can use the reciprocal divides we introduced some
time ago (currently used in slab AFAIK)
We can assume a load will fit in a 32bits number, because with a
SCHED_LOAD_SCALE=128 value, its still a theorical limit of 33554432
When/if we reach this limit one day, probably cpus will have a fast
hardware divide and we can zap the reciprocal divide trick.
Ingo suggested to rename cpu_power to __cpu_power to make clear it should
not be modified without changing its reciprocal value too.
I did not convert the divide in cpu_avg_load_per_task(), because tracking
nr_running changes may be not worth it ? We could use a static table of 32
reciprocal values but it would add a conditional branch and table lookup.
[akpm@linux-foundation.org: !SMP build fix]
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Fix the process idle load balancing in the presence of dynticks. cpus for
which ticks are stopped will sleep till the next event wakes it up.
Potentially these sleeps can be for large durations and during which today,
there is no periodic idle load balancing being done.
This patch nominates an owner among the idle cpus, which does the idle load
balancing on behalf of the other idle cpus. And once all the cpus are
completely idle, then we can stop this idle load balancing too. Checks added
in fast path are minimized. Whenever there are busy cpus in the system, there
will be an owner(idle cpu) doing the system wide idle load balancing.
Open items:
1. Intelligent owner selection (like an idle core in a busy package).
2. Merge with rcu's nohz_cpu_mask?
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
the isdn_divertif contains kernel-only references so I've wrapped them in
__KERNEL__ and add proper #include statements.
Cc: Karsten Keil <kkeil@suse.de>
Acked-by: Karsten Keil <kkeil@suse.de>
Here is a driver for the Alchemy au1550 PSC (Programmable Serial
Controller) in SPI master mode.
It supports dma transfers using the Alchemy descriptor based dma controller
for 4-8 bits per word SPI transfers. For 9-24 bits per word transfers, pio
irq based mode is used to avoid setup of dma channels from scratch on each
number of bits per word change.
Tested with au1550; this may also work on other MIPS Alchemy cpus, like
au1200/au1210/au1250. Used extensively with SD card connected via SPI;
this handles 8.1MHz SPI clock transfers using dma without any problem (the
highest SPI clock freq possible with au1550 running on 324MHz).
The driver supports sharing of SPI bus by multiple devices. All features
of Alchemy SPI mode are supported (all SPI modes, msb/lsb first, bits per
word in 4-24 range).
As the SPI clock of the controller depends on main input clock that shall
be configured externally, platform data structure for au1550 SPI controller
driver contains mainclk_hz attribute to define the input clock rate. From
this value, dividers of the controller for SPI clock are set up for
required frequency.
Signed-off-by: Jan Nikitenko <jan.nikitenko@gmail.com>
Whitespace and section fixups. Remove partial workaround for platform
setup bug in dma_mask setup; it couldn't work with multiple controllers.
Various documentation updates for the SPI infrastructure, to clarify things
that may not have been clear, to cope with lack of editing, and fix
omissions.
Also, plug SPI into the kernel-api DocBook template, and fix all the
resulting glitches in document generation.
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
Add a filesystem API for <linux/spi/spi.h> stack. The initial version of
this interface is purely synchronous.
dbrownell@users.sourceforge.net:
Cleaned up, bugfixed; much simplified; added preliminary documentation.
Works with mdev given CONFIG_SYSFS_DEPRECATED; and presumably udev.
Updated SPI_IOC_MESSAGE ioctl to full spi_message semantics, supporting
groups of one or more transfers (each of which may be full duplex if
desired).
This is marked as EXPERIMENTAL with an explicit disclaimer that the API
(notably the ioctls) is subject to change.
Signed-off-by: Andrea Paterniani <a.paterniani@swapp-eng.it>
Fix misnamed fields of 'struct clock_event_device' in the kernel-doc
comment. Convert the acronyms to uppercase, while at it...
Acked-by: Jan Kara <jack@ucw.cz>
Add taskstats.h to include/linux/Kbuild, make headers_install would then
pickup taskstats.h. This needs to be done as taskstats.h is a user
interface header.
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Don Zickus <dzickus@redhat.com>
Add sensable phantom driver
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Matt Reimer <mreimer@vpop.net>
[akpm@linux-foundation.org: kconfig update]
Signed-off-by: Matt Reimer <mreimer@vpop.net>
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Eliminate 19439 (!!) sparse warnings like:
include/linux/mm.h:321:22: warning: constant 0xffff810000000000 is so big it is unsigned long
Eliminate 56 sparse warnings like:
arch/x86_64/kernel/setup.c:248:16: warning: constant 0xffffffff80000000 is so big it is unsigned long
Eliminate 5 sparse warnings like:
arch/x86_64/kernel/module.c:49:13: warning: constant 0xfffffffffff00000 is so big it is unsigned long
Eliminate 23 sparse warnings like:
arch/x86_64/mm/init.c:551:37: warning: constant 0xffffc20000000000 is so big it is unsigned long
Eliminate 6 sparse warnings like:
arch/x86_64/kernel/module.c:49:13: warning: constant 0xffffffff88000000 is so big it is unsigned long
arch/x86_64/mm/init.c:552:6: warning: constant 0xffffe1ffffffffff is so big it is unsigned long
Eliminate 3 sparse warnings like:
arch/x86_64/kernel/e820.c:186:17: warning: constant 0x3fffffffffff is so big it is long
Cc: Andi Kleen <ak@suse.de>
Make a global linux/const.h header file instead of having multiple,
per-arch files, and convert current users of asm/const.h to use
linux/const.h.
Built on x86_64 and sparc64.
[akpm@linux-foundation.org: fix include/asm-x86_64/Kbuild]
It seems that the recent Windows changed specification, and it's
undocumented. Windows doesn't update ->free_clusters correctly.
This patch doesn't use ->free_clusters by default. (instead, add "usefree"
for forcing to use it)
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Juergen Beisert <juergen127@kreuzholzen.de>
Cc: Andreas Schwab <schwab@suse.de>
Most architectures defined three macros, MK_IOSPACE_PFN(), GET_IOSPACE()
and GET_PFN() in pgtable.h. However, the only callers of any of these
macros are in Sparc specific code, either in arch/sparc, arch/sparc64 or
drivers/sbus.
This patch removes the redundant macros from all architectures except
sparc and sparc64.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
A patch that stores inode flags such as S_IMMUTABLE, S_APPEND, etc. from
i_flags to EXT3_I(inode)->i_flags when inode is written to disk. The same
thing is done on GETFLAGS ioctl.
Quota code changes these flags on quota files (to make it harder for
sysadmin to screw himself) and these changes were not correctly propagated
into the filesystem (especially, lsattr did not show them and users were
wondering...).
Propagate flags such as S_APPEND, S_IMMUTABLE, etc. from i_flags into
ext3-specific i_flags. Hence, when someone sets these flags via a
different interface than ioctl, they are stored correctly.
Cc: <linux-ext4@vger.kernel.org>
Apparently it's not cool anymore to use SPIN/RW_LOCK_UNLOCKED. There's
some mention of this in Documentation/spinlocks.txt, but that only talks
about dynamic initialisation.
A comment in the code mentioning the preferred usage would be good IMHO.
[akpm@linux-foundation.org: add reason for deprecation]
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
There are many places in the kernel where the construction like
foo = list_entry(head->next, struct foo_struct, list);
are used.
The code might look more descriptive and neat if using the macro
list_first_entry(head, type, member) \
list_entry((head)->next, type, member)
Here is the macro itself and the examples of its usage in the generic code.
If it will turn out to be useful, I can prepare the set of patches to
inject in into arch-specific code, drivers, networking, etc.
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Zach Brown <zach.brown@oracle.com>
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: John McCutchan <ttb@tentacle.dhs.org>
Cc: john stultz <johnstul@us.ibm.com>
Cc: Ram Pai <linuxram@us.ibm.com>
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com>
We used to warn unless the EFI system table major revision was exactly 1.
But EFI 2.00 firmware is starting to appear, and the 2.00 changes don't
affect anything in Linux.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
We've had various reports of some legacy "probe the hardware" style
platform drivers having nasty problems with hotplug support.
The core issue is that those legacy drivers don't fully conform to the
driver model. They assume a role that should be the responsibility of
infrastructure code: creating device nodes.
The "modprobe" step in hotplugging relies on drivers to have split those
roles into different modules. The lack of this split causes the problems.
When a driver creates nodes for devices that don't exist (sending a hotplug
event), then exits (aborting one modprobe) before the "modprobe $MODALIAS"
step completes (by failing, since it's in the middle of a modprobe), the
result can be an endless loop of modprobe invocations ... badness.
This fix uses the newish per-device flag controlling issuance of "add"
events. (A previous version of this patch used a per-device "driver can
hotplug" flag, which only scrubbed $MODALIAS from the environment rather
than suppressing the entire hotplug event.) It also shrinks that flag to
one bit, saving a word in "struct device".
So the net of this patch is removing some nasty failures with legacy
drivers, while retaining hotplug capability for the majority of platform
drivers.
Cc: Greg KH <gregkh@suse.de>
Cc: Andres Salomon <dilinger@debian.org>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Merge all compat ioctl handling into compat_ioctl.c instead of splitting it
over compat.c and compat_ioctl.c. This also allows to get rid of ioctl32.h
Looks-good-to: Andi Kleen <ak@suse.de>
We noticed a drop in n/w performance due to the irq_desc being cacheline
aligned rather than internode aligned. We see 50% of expected performance
when two e1000 nics local to two different nodes have consecutive irq
descriptors allocated, due to false sharing.
Note that this patch does away with cacheline padding for the UP case, as
it does not seem useful for UP configurations.
Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org>
Signed-off-by: Shai Fultheim <shai@scalex86.org>
Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com>
Now that there is no arch-specific compat ioctl handling left there is not
point in having a separate copat_ioctl.h, so merge it into compat_ioctl.c
linux/module.h
-> linux/elf.h
-> asm-i386/elf.h
-> linux/utsname.h
-> linux/sched.h
Noticeably cut the number of files which are rebuild upon touching sched.h
and cut down pulled junk from every module.h inclusion.
The deprecation of the SA_xxx interrupt flags did not emit deprecated
warnings. Andrew said about the removal of the deprecated flag defines:
> This is going to break a lot of external stuff. We should have found
> a way to make usage of SA_* emit deprecated warnings (or _some_
> warning) to warn people of impending doom. But I can't immediately
> find a way of doing that. if we _can_ find a way of doing this, I
> suspect we'll need to do it, and give people another six months. It's
> going to get ugly out there. We shall see...
Define the deprecated flags as a call to a __deprecated inline function
so a warning is emitted on compile time.
Extend the reprieve of out of tree drivers to 9/2007.
Same story as with cat /proc/*/wchan race vs rmmod race, only
/proc/slab_allocators want more info than just symbol name.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
kallsyms_lookup() can go iterating over modules list unprotected which is OK
for emergency situations (oops), but not OK for regular stuff like
/proc/*/wchan.
Introduce lookup_symbol_name()/lookup_module_symbol_name() which copy symbol
name into caller-supplied buffer or return -ERANGE. All copying is done with
module_mutex held, so...
module_get_kallsym() leaks "struct module *" outside of module_mutex which is
no-no, because module can dissapear right after mutex unlock.
Copy all needed information from inside module_mutex into caller-supplied
space.
[bunk@stusta.de: is_exported() can now become static]
module_get_kallsym() could in theory truncate module symbol name to fit in
buffer, but nobody does this. Always use KSYM_NAME_LEN + 1 bytes for name.
Suggested by lg^WRusty.
Teach PNPACPI how to hook up its devices to their ACPI nodes, so that
pnpdev->dev.archdata points to the parallel acpi device node. Previously
this only worked for PCI, leaving a notable hole.
Export "acpi_bus_type" so this can work.
Remove some extraneous whitespace.
Cc: Adam Belay <ambx1@neo.rr.com>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Greg KH <greg@kroah.com>
In certain cases like when the real return address can't be found or when
the number of tracked calls to a kretprobed function is less than the
number of returns, we may not be able to find the correct return address
after processing a kretprobe. Currently we just do a BUG_ON, but no
information is provided about the actual failing kretprobe.
Print out details of the kretprobe before calling BUG().
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com>
Cc: Jim Keniston <jkenisto@us.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: Maneesh Soni <maneesh@in.ibm.com>
Currently the size of the per-cpu region reserved to save crash notes is
set by the per-architecture value MAX_NOTE_BYTES. Which in turn is
currently set to 1024 on all supported architectures.
While testing ia64 I recently discovered that this value is in fact too
small. The particular setup I was using actually needs 1172 bytes. This
lead to very tedious failure mode where the tail of one elf note would
overwrite the head of another if they ended up being alocated sequentially
by kmalloc, which was often the case.
It seems to me that a far better approach is to caclculate the size that
the area needs to be. This patch does just that.
If a simpler stop-gap patch for ia64 to be squeezed into 2.6.21(.X) is
needed then this should be as easy as making MAX_NOTE_BYTES larger in
arch/asm-ia64/kexec.h. Perhaps 2048 would be a good choice. However, I
think that the approach in this patch is a much more robust idea.
Acked-by: Vivek Goyal <vgoyal@in.ibm.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
Remove artificial maximum 256 loop device that can be created due to a
legacy device number limit. Searching through lkml archive, there are
several instances where users complained about the artificial limit that
the loop driver impose. There is no reason to have such limit.
This patch rid the limit entirely and make loop device and associated block
queue instantiation on demand. With on-demand instantiation, it also gives
the benefit of not wasting memory if these devices are not in use (compare
to current implementation that always create 8 loop devices), a net
improvement in both areas. This version is both tested with creation of
large number of loop devices and is compatible with existing losetup/mount
user land tools.
There are a number of people who worked on this and provided valuable
suggestions, in no particular order, by:
Jens Axboe
Jan Engelhardt
Christoph Hellwig
Thomas M
Signed-off-by: Ken Chen <kenchen@google.com>
Cc: Jan Engelhardt <jengelh@linux01.gwdg.de>
Add touch_all_softlockup_watchdogs() to allow the softlockup watchdog
timers on all cpus to be updated. This is used to prevent sysrq-t from
generating a spurious watchdog message when generating lots of output.
Softlockup watchdogs use sched_clock() as its timebase, which is inherently
per-cpu (at least, when it is measuring unstolen time). Because of this,
it isn't possible for one CPU to directly update the other CPU's timers,
but it is possible to tell the other CPUs to do update themselves
appropriately.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Acked-by: Chris Lalancette <clalance@redhat.com>
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Cc: Rick Lindsley <ricklind@us.ibm.com>
Move the timekeeping code out of kernel/timer.c and into
kernel/time/timekeeping.c. I made no cleanups or other changes in transit.
[akpm@linux-foundation.org: build fix]
Signed-off-by: John Stultz <johnstul@us.ibm.com>
struct clocksource is a critical data structure.
Most of its fields are read only, some of them are heavily modified at each
timer interrupt.
It makes sense to separate those fields and make sure they all share one
cache line, or at least the minimum for machines with small cache lines.
Acked-by: John Stultz <johnstul@us.ibm.com>
sysdev.h uses THIS_MODULE so should include <linux/module.h>.
[akpm@linux-foundation.org: couple of fixes]
Add a new deferrable delayed work init. This can be used to schedule work
that are 'unimportant' when CPU is idle and can be called later, when CPU
eventually comes out of idle.
Use this init in cpufreq ondemand governor.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Introduce a new flag for timers - deferrable: Timers that work normally
when system is busy. But, will not cause CPU to come out of idle (just to
service this timer), when CPU is idle. Instead, this timer will be
serviced when CPU eventually wakes up with a subsequent non-deferrable
timer.
The main advantage of this is to avoid unnecessary timer interrupts when
CPU is idle. If the routine currently called by a timer can wait until
next event without any issues, this new timer can be used to setup timer
event for that routine. This, with dynticks, allows CPUs to be lazy,
allowing them to stay in idle for extended period of time by reducing
unnecesary wakeup and thereby reducing the power consumption.
This patch:
Builds this new timer on top of existing timer infrastructure. It uses
last bit in 'base' pointer of timer_list structure to store this deferrable
timer flag. __next_timer_interrupt() function skips over these deferrable
timers when CPU looks for next timer event for which it has to wake up.
This is exported by a new interface init_timer_deferrable() that can be
called in place of regular init_timer().
[akpm@linux-foundation.org: Privatise a #define]
Currently a parport_driver can't get a handle on the device node for the
underlying parport (PNPACPI, PCI, etc). That prevents correct placement of
sysfs child nodes, which can affect things like power management.
This patch adds a field to "struct parport" pointing to that device node, and
updates non-legacy port drivers to initialize that device pointer. That field
replaces the analagous PCI-only support in parport_pc.
[akpm@linux-foundation.org: fix powerpc build]
Delete the unused header file include/linux/awe_voice.h, as well as
its corresponding Kbuild entry.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
remove_inode_dquot_ref() can now become static.
Acked-by: Jan Kara <jack@suse.cz>
