path: root/include
2011-01-13pps: trivial fixesAlexander Gordeev
Here are some very trivial fixes combined: - add macro definitions to protect header file from including several times - remove declaration for an unexistent array - fix typos Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13NFC: Driver for NXP Semiconductors PN544 NFC chip.Matti J. Aaltonen
Creates a new "Near Field Communication" subsystem in drivers/nfc. http://en.wikipedia.org/wiki/Near_Field_Communication is useful ;) This is a driver for the pn544 NFC device. The driver transfers ETSI messages between the device and the user space. Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13user_ns: improve the user_ns on-the-slab packagingPavel Emelyanov
Currently on 64-bit arch the user_namespace is 2096 and when being kmalloc-ed it resides on a 4k slab wasting 2003 bytes. If we allocate a separate cache for it and reduce the hash size from 128 to 64 chains the packaging becomes *much* better - the struct is 1072 bytes and the hole between is 98 bytes. [akpm@linux-foundation.org: s/__initcall/module_init/] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: add new idt sRIO switchesAlexandre Bounine
Add new sRIO switch device IDs and enable a basic support for them. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: add definitions of Component Tag fieldsAlexandre Bounine
Add definition of the unique device identifier field in the component tag. RIO_CTAG_UDEVID does not take all 32 bits of the component tag value to allow future extensions to the component tag use. Selected size of the RIO_CTAG_UDEVID field (17 bits) is sufficient to accommodate maximum number of endpoints in large RIO network (16-bit id) plus switches. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: integrate rio_switch into rio_devAlexandre Bounine
Convert RIO switches device structures (rio_dev + rio_switch) into a single allocation unit. This change is based on the fact that RIO switches are using common RIO device objects anyway. Allocating RIO switch objects as RIO devices with added space for switch information simplifies handling of RIO switch devices. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: use common destid storage for endpoints and switchesAlexandre Bounine
Change code to use one storage location common for switches and endpoints. This eliminates unnecessary device type checks during basic access operations. Logic that assigns destid to RIO devices stays unchanged - as before, switches use an associated destid because they do not have their own. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13fs/char_dev.c: remove unused cdev_index()Namhyung Kim
Commit 66fa12c571d3 ("ieee1394: remove the old IEEE 1394 driver stack") eliminated the only user of cdev_index(). So it can be removed too. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13gpiolib: add missing functions to generic fallbackWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13gpiolib: annotate gpio-intialization with __must_checkWolfram Sang
Because GPIOs can have crucial functions especially in embedded systems, we are better safe than sorry regarding their configuration. For gpio_request, the documentation is simply enforced: <quote>"The return value of gpio_request() must be checked."</quote> For gpio_direction_* and gpio_request_*, we now act accordingly. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13drivers/staging/olpc_dcon: convert to new cs5535 gpio APIAndres Salomon
Drop the old geode_gpio crud, as well as the raw outl() calls; instead, use the Linux GPIO API where possible, and the cs5535_gpio API in other places. Note that we don't actually clean up the driver properly yet (once loaded, it always remains loaded). That'll come later.. This patch is necessary for building the driver. Signed-off-by: Andres Salomon <dilinger@queued.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13drivers/gpio/cs5535-gpio.c: add some additional cs5535-specific GPIO ↵Andres Salomon
functionality This adds (well, re-adds actually) handling for events/IRQs through cs5535 GPIOs. In the wild and wooly world of CS5535, setup_event() is for assigning an IRQ to a GPIO filter/event pair, and set_irq() sets up the pair to trigger IRQs. These should really only be used in highly platform-specific drivers (such as OLPC's DCON driver). Sadly, because set_irq() uses MSRs, this causes the driver to become X86-specific. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Daniel Drake <dsd@laptop.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13binfmt_elf: cleanupsMikael Pettersson
This cleans up a few bits in binfmt_elf.c and binfmts.h: - the hasvdso field in struct linux_binfmt is unused, so remove it and the only initialization of it - the elf_map CPP symbol is not defined anywhere in the kernel, so remove an unnecessary #ifndef elf_map - reduce excessive indentation in elf_format's initializer - add missing spaces, remove extraneous spaces No functional changes, but tested on x86 (32 and 64 bit), powerpc (32 and 64 bit), sparc64, arm, and alpha. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13epoll: convert max_user_watches to longRobin Holt
On a 16TB machine, max_user_watches has an integer overflow. Convert it to use a long and handle the associated fallout. Signed-off-by: Robin Holt <holt@sgi.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13include/linux/printk.h: use tab not spaces for indentJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13include/linux/printk.h: organize printk_ratelimited macrosJoe Perches
- Use no_printk for !CONFIG_PRINTK printk_ratelimited. - Whitespace cleanup. Signed-off-by: Joe Perches <joe@perches.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13include/linux/printk.h lib/hexdump.c: neatening and add CONFIG_PRINTK guardJoe Perches
- Move prototypes and align arguments. - Add CONFIG_PRINTK guard for print_hex functions Signed-off-by: Joe Perches <joe@perches.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13include/linux/printk.h: add pr_<level>_once macrosJoe Perches
- Move printk_once definitions and add an #ifdef CONFIG_PRINTK - Add pr_<level>_once so printks can use pr_fmt Signed-off-by: Joe Perches <joe@perches.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13include/linux/printk.h: use and neaten no_printkJoe Perches
- Move no_printk above first CONFIG_PRINTK block so it can be used by printk_once. - Convert statement expression if (0) printk macros to no_printk. - Convert printk_once(x...) to more normally used (fmt, ...) fmt, ##__VA_ARGS__. - Standardize __attribute__ use. - Expand single line inline functions. - Remove space before pointer. Signed-off-by: Joe Perches <joe@perches.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13include/linux/printk.h: use space after #defineJoe Perches
2011-01-13include/linux/printk.h: move console functions and variables togetherJoe Perches
There are many uses of printk_once(KERN_<level>, so add pr_<level>_once macros to avoid printk_once(KERN_<level> pr_fmt(fmt). Add an #ifdef CONFIG_PRINTK for print_hex_dump and static inline void functions for the #else cases to reduce embedded code size. Neaten and organize the rest of the code. This patch: Move console functions and variables together. Signed-off-by: Joe Perches <joe@perches.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13kptr_restrict for hiding kernel pointers from unprivileged usersDan Rosenberg
Add the %pK printk format specifier and the /proc/sys/kernel/kptr_restrict sysctl. The %pK format specifier is designed to hide exposed kernel pointers, specifically via /proc interfaces. Exposing these pointers provides an easy target for kernel write vulnerabilities, since they reveal the locations of writable structures containing easily triggerable function pointers. The behavior of %pK depends on the kptr_restrict sysctl. If kptr_restrict is set to 0, no deviation from the standard %p behavior occurs. If kptr_restrict is set to 1, the default, if the current user (intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG (currently in the LSM tree), kernel pointers using %pK are printed as 0's. If kptr_restrict is set to 2, kernel pointers using %pK are printed as 0's regardless of privileges. Replacing with 0's was chosen over the default "(null)", which cannot be parsed by userland %p, which expects "(nil)". [akpm@linux-foundation.org: check for IRQ context when !kptr_restrict, save an indent level, s/WARN/WARN_ONCE/] [akpm@linux-foundation.org: coding-style fixup] [randy.dunlap@oracle.com: fix kernel/sysctl.c warning] Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: James Morris <jmorris@namei.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Thomas Graf <tgraf@infradead.org> Cc: Eugene Teo <eugeneteo@kernel.org> Cc: Kees Cook <kees.cook@canonical.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13include/asm-generic/vmlinux.lds.h: make readmostly section correctly alignShaohua Li
The readmostly section should end at a cacheline aligned address, otherwise the last several data might share cachline with other data and make the readmostly data still have cache bounce. For example, in ia64, secpath_cachep is the last readmostly data, and it shares cacheline with init_uts_ns. a000000100e80480 d secpath_cachep a000000100e80488 D init_uts_ns Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13include/linux/unaligned/packed_struct.h: use __packedAndrew Morton
Cc: Will Newton <will.newton@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13toshiba.h: hide a function prototypes behind __KERNEL__ macroAlexander Shishkin
Currently, tosh_smm() prototype is present in a header file exported to userland. This patch fixes it. Signed-off-by: Alexander Shishkin <virtuoso@slind.org> Cc: Jonathan Buzzard <jonathan@buzzard.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13include/linux/kernel.h: abs(): fix handling of 32-bit unsigneds on 64-bitAndrew Morton
Michal reports: In the framebuffer subsystem the abs() macro is often used as a part of the calculation of a Manhattan metric, which in turn is used as a measure of similarity between video modes. The arguments of abs() are sometimes unsigned numbers. This worked fine until commit a49c59c0 ("Make sure the value in abs() does not get truncated if it is greater than 2^32:) , which changed the definition of abs() to prevent truncation. As a result of this change, in the following piece of code: u32 a = 0, b = 1; u32 c = abs(a - b); 'c' will end up with a value of 0xffffffff instead of the expected 0x1. A problem caused by this change and visible by the end user is that framebuffer drivers relying on functions from modedb.c will fail to find high resolution video modes similar to that explicitly requested by the user if an exact match cannot be found (see e.g. Fix this by special-casing `long' types within abs(). This patch reduces x86_64 code size a bit - drivers/video/uvesafb.o shrunk by 15 bytes, presumably because it is doing abs() on 4-byte quantities, and expanding those to 8-byte longs adds code. testcase: #define oldabs(x) ({ \ long __x = (x); \ (__x < 0) ? -__x : __x; \ }) #define newabs(x) ({ \ long ret; \ if (sizeof(x) == sizeof(long)) { \ long __x = (x); \ ret = (__x < 0) ? -__x : __x; \ } else { \ int __x = (x); \ ret = (__x < 0) ? -__x : __x; \ } \ ret; \ }) typedef unsigned int u32; main() { u32 a = 0; u32 b = 1; u32 oldc = oldabs(a - b); u32 newc = newabs(a - b); printf("%u %u\n", oldc, newc); } akpm:/home/akpm> gcc t.c akpm:/home/akpm> ./a.out 4294967295 1 Reported-by: Michal Januszewski <michalj@gmail.com> Cc: Rolf Eike Beer <eike-kernel@sf-tec.de Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13kmsg_dump: add kmsg_dump() calls to the reboot, halt, poweroff and ↵Seiji Aguchi
emergency_restart paths We need to know the reason why system rebooted in support service. However, we can't inform our customers of the reason because final messages are lost on current Linux kernel. This patch improves the situation above because the final messages are saved by adding kmsg_dump() to reboot, halt, poweroff and emergency_restart path. Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Marco Stornelli <marco.stornelli@gmail.com> Reviewed-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13leds-lp5521: modify the way of setting led device nameArun Murthy
Currently the led device name is fetched from the device_type in I2C_BOARD_INFO which comes from the platform data. This name is in turn used to create an entry in sysfs. If there exists two or more lp5521 on a particular platform, the device_type in I2C_BOARD_INFO has to be the same, else lp5521 driver probe wont be called and if used so, results in run time warning "cannot create sysfs with same name" and hence a failure. The name that is used to create sysfs entry is to be passed by the struct led_platform_data. Hence adding an element of type const char * and change in lp5521 driver to use this name in creating the led device if present else use the name obtained by I2C_BOARD_INFO. Signed-off-by: Arun Murthy <arun.murthy@stericsson.com> Acked-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13leds: leds-lp5523: modify the way of setting led device nameSamu Onkalo
Currently all leds channels begins with string lp5523. Patch adds a possibility to provide name via platform data. This makes it possible to have several chips without overlapping sysfs names. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Arun Murthy <arun.murthy@stericsson.com> Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12Merge branch 'stable/xenbus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/xenbus' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/xenbus: making backend support modular is too complex xen/pci: Make xen-pcifront be dependent on XEN_XENBUS_FRONTEND xen/xenbus: fixup checkpatch issues in xenbus_probe* xen/netfront: select XEN_XENBUS_FRONTEND xen/xenbus: clean up noise in xenbus_probe_frontend.c xen/xenbus: clean up noise in xenbus_probe_backend.c xen/xenbus: clean up noise in xenbus_probe.c xen/xenbus: cleanup debug noise in xenbus_comms.c xen/xenbus: clean up error handling xen/xenbus: make frontend bus GPL xen/xenbus: make sure backend bus is registered earlier xenbus/frontend: register bus earlier xen: remove xen/evtchn.h xen: add backend driver support xen: separate out frontend xenbus
2011-01-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (67 commits) cxgb4vf: recover from failure in cxgb4vf_open() netfilter: ebtables: make broute table work again netfilter: fix race in conntrack between dump_table and destroy ah: reload pointers to skb data after calling skb_cow_data() ah: update maximum truncated ICV length xfrm: check trunc_len in XFRMA_ALG_AUTH_TRUNC ehea: Increase the skb array usage net/fec: remove config FEC2 as it's used nowhere pcnet_cs: add new_id tcp: disallow bind() to reuse addr/port net/r8169: Update the function of parsing firmware net: ppp: use {get,put}_unaligned_be{16,32} CAIF: Fix IPv6 support in receive path for GPRS/3G arp: allow to invalidate specific ARP entries net_sched: factorize qdisc stats handling mlx4: Call alloc_etherdev to allocate RX and TX queues net: Add alloc_netdev_mqs function caif: don't set connection request param size before copying data cxgb4vf: fix mailbox data/control coherency domain race qlcnic: change module parameter permissions ...
2011-01-11Merge branch 'master' of git://1984.lsi.us.es/net-2.6David S. Miller
2011-01-11Merge branch 'nfs-for-2.6.38' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.38' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (89 commits) NFS fix the setting of exchange id flag NFS: Don't use vm_map_ram() in readdir NFSv4: Ensure continued open and lockowner name uniqueness NFS: Move cl_delegations to the nfs_server struct NFS: Introduce nfs_detach_delegations() NFS: Move cl_state_owners and related fields to the nfs_server struct NFS: Allow walking nfs_client.cl_superblocks list outside client.c pnfs: layout roc code pnfs: update nfs4_callback_recallany to handle layouts pnfs: add CB_LAYOUTRECALL handling pnfs: CB_LAYOUTRECALL xdr code pnfs: change lo refcounting to atomic_t pnfs: check that partial LAYOUTGET return is ignored pnfs: add layout to client list before sending rpc pnfs: serialize LAYOUTGET(openstateid) pnfs: layoutget rpc code cleanup pnfs: change how lsegs are removed from layout list pnfs: change layout state seqlock to a spinlock pnfs: add prefix to struct pnfs_layout_hdr fields pnfs: add prefix to struct pnfs_layout_segment fields ...
2011-01-11netfilter: ebtables: make broute table work againFlorian Westphal
broute table init hook sets up the "br_should_route_hook" pointer, which then gets called from br_input. commit a386f99025f13b32502fe5dedf223c20d7283826 (bridge: add proper RCU annotation to should_route_hook) introduced a typedef, and then changed this to: br_should_route_hook_t *rhook; [..] rhook = rcu_dereference(br_should_route_hook); if (*rhook(skb)) problem is that "br_should_route_hook" contains the address of the function, so calling *rhook() results in kernel panic. Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-01-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (44 commits) ext4: fix trimming starting with block 0 with small blocksize ext4: revert buggy trim overflow patch ext4: don't pass entire map to check_eofblocks_fl ext4: fix memory leak in ext4_free_branches ext4: remove ext4_mb_return_to_preallocation() ext4: flush the i_completed_io_list during ext4_truncate ext4: add error checking to calls to ext4_handle_dirty_metadata() ext4: fix trimming of a single group ext4: fix uninitialized variable in ext4_register_li_request ext4: dynamically allocate the jbd2_inode in ext4_inode_info as necessary ext4: drop i_state_flags on architectures with 64-bit longs ext4: reorder ext4_inode_info structure elements to remove unneeded padding ext4: drop ec_type from the ext4_ext_cache structure ext4: use ext4_lblk_t instead of sector_t for logical blocks ext4: replace i_delalloc_reserved_flag with EXT4_STATE_DELALLOC_RESERVED ext4: fix 32bit overflow in ext4_ext_find_goal() ext4: add more error checks to ext4_mkdir() ext4: ext4_ext_migrate should use NULL not 0 ext4: Use ext4_error_file() to print the pathname to the corrupted inode ext4: use IS_ERR() to check for errors in ext4_error_file ...
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext2: Resolve 'dereferencing pointer to incomplete type' when enabling EXT2_XATTR_DEBUG ext3: Remove redundant unlikely() ext2: Remove redundant unlikely() ext3: speed up file creates by optimizing rec_len functions ext2: speed up file creates by optimizing rec_len functions ext3: Add more journal error check ext3: Add journal error check in resize.c quota: Use %pV and __attribute__((format (printf in __quota_error and fix fallout ext3: Add FITRIM handling ext3: Add batched discard support for ext3 ext3: Add journal error check into ext3_rename() ext3: Use search_dirblock() in ext3_dx_find_entry() ext3: Avoid uninitialized memory references with a corrupted htree directory ext3: Return error code from generic_check_addressable ext3: Add journal error check into ext3_delete_entry() ext3: Add error check in ext3_mkdir() fs/ext3/super.c: Use printf extension %pV fs/ext2/super.c: Use printf extension %pV ext3: don't update sb journal_devnum when RO dev
2011-01-11ah: update maximum truncated ICV lengthNicolas Dichtel
For SHA256, RFC4868 requires to truncate ICV length to 128 bits, hence MAX_AH_AUTH_LEN should be updated to 16. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-11NFS fix the setting of exchange id flagAndy Adamson
Indicate support for referrals. Do not set any PNFS roles. Check the flags returned by the server for validity. Do not use exchange flags from an old client ID instance when recovering a client ID. Update the EXCHID4_FLAG_XXX set to RFC 5661. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-11Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix Moorestown VRTC fixmap placement x86/gpio: Implement x86 gpio_to_irq convert function x86, UV: Fix APICID shift for Westmere processors x86: Use PCI method for enabling AMD extended config space before MSR method x86: tsc: Prevent delayed init if initial tsc calibration failed x86, lapic-timer: Increase the max_delta to 31 bits x86: Fix sparse non-ANSI function warnings in smpboot.c x86, numa: Fix CONFIG_DEBUG_PER_CPU_MAPS without NUMA emulation x86, AMD, PCI: Add AMD northbridge PCI device id for CPU families 12h and 14h x86, numa: Fix cpu to node mapping for sparse node ids x86, numa: Fake node-to-cpumask for NUMA emulation x86, numa: Fake apicid and pxm mappings for NUMA emulation x86, numa: Avoid compiling NUMA emulation functions without CONFIG_NUMA_EMU x86, numa: Reduce minimum fake node size to 32M Fix up trivial conflict in arch/x86/kernel/apic/x2apic_uv_x.c
2011-01-11Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rtc: Namespace fixup RTC: Remove UIE emulation RTC: Rework RTC code to use timerqueue for events Fix up trivial conflict in drivers/rtc/rtc-dev.c
2011-01-11Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits) perf session: Fix infinite loop in __perf_session__process_events perf evsel: Support perf_evsel__open(cpus > 1 && threads > 1) perf sched: Use PTHREAD_STACK_MIN to avoid pthread_attr_setstacksize() fail perf tools: Emit clearer message for sys_perf_event_open ENOENT return perf stat: better error message for unsupported events perf sched: Fix allocation result check perf, x86: P4 PMU - Fix unflagged overflows handling dynamic debug: Fix build issue with older gcc tracing: Fix TRACE_EVENT power tracepoint creation tracing: Fix preempt count leak tracepoint: Add __rcu annotation tracing: remove duplicate null-pointer check in skb tracepoint tracing/trivial: Add missing comma in TRACE_EVENT comment tracing: Include module.h in define_trace.h x86: Save rbp in pt_regs on irq entry x86, dumpstack: Fix unused variable warning x86, NMI: Clean-up default_do_nmi() x86, NMI: Allow NMI reason io port (0x61) to be processed on any CPU x86, NMI: Remove DIE_NMI_IPI x86, NMI: Add priorities to handlers ...
2011-01-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (39 commits) mmc: davinci: add support for SDIO irq handling mmc: fix division by zero in MMC core mmc: tmio_mmc: fix CMD irq handling mmc: tmio_mmc: handle missing HW interrupts mfd: sh_mobile_sdhi: activate SDIO IRQ for tmio_mmc mmc: tmio_mmc: implement SDIO IRQ support mfd: sdhi: require the tmio-mmc driver to bounce unaligned buffers mmc: tmio_mmc: silence compiler warnings mmc: tmio_mmc: implement a bounce buffer for unaligned DMA mmc: tmio_mmc: merge the private header into the driver mmc: tmio_mmc: fix PIO fallback on DMA descriptor allocation failure mmc: tmio_mmc: allow multi-element scatter-gather lists mmc: Register debugfs dir before calling card probe function. mmc: MMC_BLOCK_MINORS should depend on MMC_BLOCK. mmc: Explain why we make adjacent mmc_bus_{put,get} calls during rescan. mmc: Fix sd/sdio/mmc initialization frequency retries mmc: fix mmc_set_bus_width_ddr() call without bus-width-test cap mmc: dw_mmc: Add Synopsys DesignWare mmc host driver. mmc: add sdhci-tegra driver for Tegra SoCs mmc: sdhci: add quirk for max len ADMA descriptors ...
2011-01-10Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (390 commits) drm/radeon/kms: disable underscan by default drm/radeon/kms: only enable hdmi features if the monitor supports audio drm: Restore the old_fb upon modeset failure drm/nouveau: fix hwmon device binding radeon: consolidate asic-specific function decls for pre-r600 vga_switcheroo: comparing too few characters in strncmp() drm/radeon/kms: add NI pci ids drm/radeon/kms: don't enable pcie gen2 on NI yet drm/radeon/kms: add radeon_asic struct for NI asics drm/radeon/kms/ni: load default sclk/mclk/vddc at pm init drm/radeon/kms: add ucode loader for NI drm/radeon/kms: add support for DCE5 display LUTs drm/radeon/kms: add ni_reg.h drm/radeon/kms: add bo blit support for NI drm/radeon/kms: always use writeback/events for fences on NI drm/radeon/kms: adjust default clock/vddc tracking for pm on DCE5 drm/radeon/kms: add backend map workaround for barts drm/radeon/kms: fill gpu init for NI asics drm/radeon/kms: add disabled vbios accessor for NI asics drm/radeon/kms: handle NI thermal controller ...
2011-01-10Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c: Constify i2c_client where possible i2c-algo-bit: Complain about masters which can't read SCL i2c-algo-bit: Refactor adapter registration i2c: Add generic I2C multiplexer using GPIO API i2c-nforce2: Remove unnecessary cast of pci_get_drvdata i2c-i801: Include <linux/slab.h>
2011-01-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (52 commits) Blackfin: encode cpu-rev into uImage name Blackfin: bf54x: don't ack GPIO ints when unmasking them Blackfin: sram_free_with_lsl: do not ignore return value of sram_free Blackfin: boards: add missing "static" to peripheral lists Blackfin: DNP5370: new board port Blackfin: bf518f-ezbrd: fix dsa resources Blackfin: move "-m elf32bfin" to general LDFLAGS Blackfin: kgdb_test: make sure to initialize num2 Blackfin: kgdb: disable preempt schedule when running single step in kgdb Blackfin: kgdb: disable interrupt when single stepping in ADEOS Blackfin: SMP: kgdb: apply anomaly 257 work around Blackfin: fix building IPIPE code when XIP is enabled Blackfin: SMP: kgdb: flush core internal write buffer before flushinv Blackfin: sport_uart resources: remove unused secondary RX/TX pins Blackfin: tll6527m: fix spelling in unused code (struct name) Blackfin: bf527-ezkit: add adau1373 chip address Blackfin: no-mpu: fix masking of small uncached dma region Blackfin: pm: drop irq save/restore in standby and suspend to mem callback MAINTAINERS: update Analog Devices support info Blackfin: dpmc.h: pull in new pll.h ...
2011-01-10arp: allow to invalidate specific ARP entriesMaxim Levitsky
IPv4 over firewire needs to be able to remove ARP entries from the ARP cache that belong to nodes that are removed, because IPv4 over firewire uses ARP packets for private information about nodes. This information becomes invalid as soon as node drops off the bus and when it reconnects, its only possible to start talking to it after it responded to an ARP packet. But ARP cache prevents such packets from being sent. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: driver core: Document that device_rename() is only for networking sysfs: remove useless test from sysfs_merge_group driver-core: merge private parts of class and bus driver core: fix whitespace in class_attr_string
2011-01-10net_sched: factorize qdisc stats handlingEric Dumazet
HTB takes into account skb is segmented in stats updates. Generalize this to all schedulers. They should use qdisc_bstats_update() helper instead of manipulating bstats.bytes and bstats.packets Add bstats_update() helper too for classes that use gnet_stats_basic_packed fields. Note : Right now, TCQ_F_CAN_BYPASS shortcurt can be taken only if no stab is setup on qdisc. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10net: Add alloc_netdev_mqs functionTom Herbert
Added alloc_netdev_mqs function which allows the number of transmit and receive queues to be specified independenty. alloc_netdev_mq was changed to a macro to call the new function. Also added alloc_etherdev_mqs with same purpose. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (510 commits) staging: speakup: fix failure handling staging: usbip: remove double giveback of URB Staging: batman-adv: Remove batman-adv from staging Staging: hv: Use only one txf buffer per channel and kmalloc/GFP_KERNEL on initialize staging: hv: remove unneeded osd_schedule_callback staging: hv: convert channel_mgmt.c to not call osd_schedule_callback staging: hv: convert vmbus_on_msg_dpc to not call osd_schedule_callback staging: brcm80211: Fix WL_<type> logging macros Staging: IIO: DDS: AD9833 / AD9834 driver Staging: IIO: dds.h convenience macros Staging: IIO: Direct digital synthesis abi documentation staging: brcm80211: Convert ETHER_TYPE_802_1X to ETH_P_PAE staging: brcm80211: Remove unused ETHER_TYPE_<foo> #defines staging: brcm80211: Remove ETHER_HDR_LEN, use ETH_HLEN staging: brcm80211: Convert ETHER_ADDR_LEN to ETH_ALEN staging: brcm80211: Convert ETHER_IS<FOO> to is_<foo>_ether_addr staging: brcm80211: Remove unused ether_<foo> #defines and struct staging: brcm80211: Convert ETHER_IS_MULTI to is_multicast_ether_addr staging: brcm80211: Remove unused #defines ETHER_<foo>_LOCALADDR Staging: comedi: Fix checkpatch.pl issues in file s526.c ... Fix up trivial conflict in drivers/video/udlfb.c
