Localize poison values into one header file for better documentation and
easier/quicker debugging and so that the same values won't be used for
multiple purposes.
Use these constants in core arch., mm, driver, and fs code.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Matt Mackall <mpm@selenic.com>
Cc: Andi Kleen <ak@muc.de>
Move the i386 VDSO down into a vma and thus randomize it.
Besides the security implications, this feature also helps debuggers, which
can COW a vma-backed VDSO just like a normal DSO and can thus do
single-stepping and other debugging features.
It's good for hypervisors (Xen, VMWare) too, which typically live in the same
high-mapped address space as the VDSO, hence whenever the VDSO is used, they
get lots of guest pagefaults and have to fix such guest accesses up - which
slows things down instead of speeding things up (the primary purpose of the
VDSO).
There's a new CONFIG_COMPAT_VDSO (default=y) option, which provides support
for older glibcs that still rely on a prelinked high-mapped VDSO. Newer
distributions (using glibc 2.3.3 or later) can turn this option off. Turning
it off is also recommended for security reasons: attackers cannot use the
predictable high-mapped VDSO page as syscall trampoline anymore.
There is a new vdso=[0|1] boot option as well, and a runtime
/proc/sys/vm/vdso_enabled sysctl switch, that allows the VDSO to be turned
on/off.
(This version of the VDSO-randomization patch also has working ELF
coredumping, the previous patch crashed in the coredumping code.)
This code is a combined work of the exec-shield VDSO randomization
code and Gerd Hoffmann's hypervisor-centric VDSO patch. Rusty Russell
started this patch and i completed it.
[akpm@osdl.org: cleanups]
[akpm@osdl.org: compile fix]
[akpm@osdl.org: compile fix 2]
[akpm@osdl.org: compile fix 3]
[akpm@osdl.org: revernt MAXMEM change]
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Cc: Gerd Hoffmann <kraxel@suse.de>
Cc: Zachary Amsden <zach@vmware.com>
Cc: Jan Beulich <jbeulich@novell.com>
Using C code for current_thread_info() lets the compiler optimize it.
With gcc 4.0.2, kernel is smaller:
3645212 555556 312024 4512792 44dc18 2.6.17-rc6-nb-post/vmlinux
3647276 555556 312024 4514856 44e428 2.6.17-rc6-nb/vmlinux
-2064
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
Move the phys_core_id and cpu_core_id to cpuinfo_x86 structure. Similar
patch for x86_64 is already accepted by Andi earlier this week.
[akpm@osdl.org: fix warning]
Signed-off-by: Rohit Seth <rohitseth@google.com>
Remove the limit of 256 interrupt vectors by changing the value stored in
orig_{e,r}ax to be the complemented interrupt vector. The orig_{e,r}ax
needs to be < 0 to allow the signal code to distinguish between return from
interrupt and return from syscall. With this change applied, NR_IRQS can
be > 256.
Xen extends the IRQ numbering space to include room for dynamically
allocated virtual interrupts (in the range 256-511), which requires a more
permissive interface to do_IRQ.
Signed-off-by: Ian Pratt <ian.pratt@xensource.com>
Signed-off-by: Christian Limpach <Christian.Limpach@cl.cam.ac.uk>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Cc: "Protasevich, Natalie" <Natalie.Protasevich@UNISYS.com>
With Goto-san's patch, we can add new pgdat/node at runtime. I'm now
considering node-hot-add with cpu + memory on ACPI.
I found acpi container, which describes node, could evaluate cpu before
memory. This means cpu-hot-add occurs before memory hot add.
In most part, cpu-hot-add doesn't depend on node hot add. But register_cpu(),
which creates symbolic link from node to cpu, requires that node should be
onlined before register_cpu(). When a node is onlined, its pgdat should be
there.
This patch-set holds off creating symbolic link from node to cpu
until node is onlined.
This removes node arguments from register_cpu().
Now, register_cpu() requires 'struct node' as its argument. But the array of
struct node is now unified in driver/base/node.c now (By Goto's node hotplug
patch). We can get struct node in generic way. So, this argument is not
necessary now.
This patch also guarantees add cpu under node only when node is onlined. It
is necessary for node-hot-add vs. cpu-hot-add patch following this.
Moreover, register_cpu calculates cpu->node_id by cpu_to_node() without regard
to its 'struct node *root' argument. This patch removes it.
Also modify callers of register_cpu()/unregister_cpu, whose args are changed
by register-cpu-remove-node-struct patch.
[Brice.Goglin@ens-lyon.org: fix it]
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Ashok Raj <ashok.raj@intel.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org>
pgdat and per node data
This is a patch to allocate pgdat and per node data area for ia64. The size
for them can be calculated by compute_pernodesize().
Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
address array
This is to refresh node_data[] array for ia64. As I mentioned previous
patches, ia64 has copies of information of pgdat address array on each node as
per node data.
At v2 of node_add, this function used stop_machine_run() to update them. (I
wished that they were copied safety as much as possible.) But, in this patch,
this arrays are just copied simply, and set node_online_map bit after
completion of pgdat initialization.
So, kernel must touch NODE_DATA() macro after checking node_online_map().
(Current code has already done it.) This is more simple way for just
hot-add.....
Note : It will be problem when hot-remove will occur,
because, even if online_map bit is set, kernel may
touch NODE_DATA() due to race condition. :-(
When new node becomes enable by hot-add, new sysfs file must be created for
new node. So, if new node is enabled by add_memory(), register_one_node() is
called to create it. In addition, I386's arch_register_node() and a part of
register_nodes() of powerpc are consolidated to register_one_node() as a
generic_code().
This is tested by Tiger4(IPF) with node hot-plug emulation.
Signed-off-by: Keiichiro Tokunaga <tokuanga.keiich@jp.fujitsu.com>
This patch allows hot-add memory which is not aligned to section.
Now, hot-added memory has to be aligned to section size. Considering big
section sized archs, this is not useful.
When hot-added memory is registerd as iomem resoruce by iomem resource
patch, we can make use of that information to detect valid memory range.
Note: With this, not-aligned memory can be registerd. To allow hot-add
memory with holes, we have to do more work around add_memory().
(It doesn't allows add memory to already existing mem section.)
When node is hot-added, kswapd for the node should start. This export kswapd
start function as kswapd_run() to use at add_memory().
[akpm@osdl.org: daemonize() isn't needed when using the kthread API]
Cc: "Brown, Len" <len.brown@intel.com>
Refresh NODE_DATA() for generic archs. In this case, NODE_DATA(nid) ==
node_data[nid]. node_data[] is array of address of pgdat. So, refresh is
quite simple.
For node hotplug, basically we have to allocate new pgdat. But, there are
several types of implementations of pgdat.
1. Allocate only pgdat.
This style allocate only pgdat area.
And its address is recorded in node_data[].
It is most popular style.
2. Static array of pgdat
In this case, all of pgdats are static array.
Some archs use this style.
3. Allocate not only pgdat, but also per node data.
To increase performance, each node has copy of some data as
a per node data. So, this area must be allocated too.
Ia64 is this style. Ia64 has the copies of node_data[] array
on each per node data to increase performance.
In this series of patches, treat (1) as generic arch.
generic archs can use generic function. (2) and (3) should have
its own if necessary.
This patch defines pgdat allocator.
Updating NODE_DATA() macro function is in other patch.
Signed-off-by: Yasonori Goto <y-goto@jp.fujitsu.com>
This is to find node id from acpi's handle of memory_device in DSDT. _PXM for
the new node can be found by acpi_get_pxm() by using new memory's handle. So,
node id can be found by pxm_to_nid_map[].
This patch becomes simpler than v2 of node hot-add patch.
Because old add_memory() function doesn't have node id parameter.
So, kernel must find its handle by physical address via DSDT again.
But, v3 just give node id to add_memory() now.
Change the name of old add_memory() to arch_add_memory. And use node id to
get pgdat for the node at NODE_DATA().
Note: Powerpc's old add_memory() is defined as __devinit. However,
add_memory() is usually called only after bootup.
I suppose it may be redundant. But, I'm not well known about powerpc.
So, I keep it. (But, __meminit is better at least.)
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 3657/1: S3C24XX: Documentation update of Overview.txt
[ARM] Update mach-types
[ARM] 3656/1: S3C2412: Add S3C2412 and S3C2413 documenation
[ARM] 3654/1: add ajeco 1arm sbc support
[ARM] fix drivers/mfd/ucb1x00-core.c IRQ probing bug
[ARM] 3651/1: S3C24XX: Make arch list more detailed
[ARM] 3650/1: S3C2412: Update s3c2410_defconfig
[ARM] 3649/1: S3C24XX: Fix capitalisation of CPU on SMDK2440
[ARM] 3612/1: make pci bus optional for ixp4xx platform
[ARM] Remove MODE_(SVC|IRQ|FIQ|USR) and DEFAULT_FIQ
[ARM] Remove save_lr/restore_pc macros
[ARM] Remove partial non-v6 binutils compatibility
[ARM] Remove LOADREGS macro
[ARM] Remove RETINSTR macro
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial:
typo fixes
Clean up 'inline is not at beginning' warnings for usb storage
Storage class should be first
i386: Trivial typo fixes
ixj: make ixj_set_tone_off() static
spelling fixes
fix paniced->panicked typos
Spelling fixes for Documentation/atomic_ops.txt
move acknowledgment for Mark Adler to CREDITS
remove the bouncing email address of David Campbell
This reverts commit c7b2eff059fcc2d1b7085ee3d84b79fd657a537b.
Hugh Dickins explains:
"It seems too little tested: "losetup -d /dev/loop0" fails with
EINVAL because nothing sets lo_thread; but even when you patch
loop_thread() to set lo->lo_thread = current, it can't survive
more than a few dozen iterations of the loop below (with a tmpfs
mounted on /tst):
j=0
cp /dev/zero /tst
while :
do
let j=j+1
echo "Doing pass $j"
losetup /dev/loop0 /tst/zero
mkfs -t ext2 -b 1024 /dev/loop0 >/dev/null 2>&1
mount -t ext2 /dev/loop0 /mnt
umount /mnt
done
it collapses with failed ioctl then BUG_ON(!bio).
I think the original lo_done completion was more subtle and safe
than the kthread conversion has allowed for."
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits)
kbuild: trivial fixes in Makefile
kbuild: adding symbols in Kconfig and defconfig to TAGS
kbuild: replace abort() with exit(1)
kbuild: support for %.symtypes files
kbuild: fix silentoldconfig recursion
kbuild: add option for stripping modules while installing them
kbuild: kill some false positives from modpost
kbuild: export-symbol usage report generator
kbuild: fix make -rR breakage
kbuild: append -dirty for updated but uncommited changes
kbuild: append git revision for all untagged commits
kbuild: fix module.symvers parsing in modpost
kbuild: ignore make's built-in rules & variables
kbuild: bugfix with initramfs
kbuild: modpost build fix
kbuild: check license compatibility when building modules
kbuild: export-type enhancement to modpost.c
kbuild: add dependency on kernel.release to the package targets
kbuild: `make kernelrelease' speedup
kconfig: KCONFIG_OVERWRITECONFIG
* master.kernel.org:/pub/scm/linux/kernel/git/herbert/crypto-2.6:
[CRYPTO] tcrypt: Forbid tcrypt from being built-in
[CRYPTO] aes: Add wrappers for assembly routines
[CRYPTO] tcrypt: Speed benchmark support for digest algorithms
[CRYPTO] tcrypt: Return -EAGAIN from module_init()
[CRYPTO] api: Allow replacement when registering new algorithms
[CRYPTO] api: Removed const from cra_name/cra_driver_name
[CRYPTO] api: Added cra_init/cra_exit
[CRYPTO] api: Fixed incorrect passing of context instead of tfm
[CRYPTO] padlock: Rearrange context structure to reduce code size
[CRYPTO] all: Pass tfm instead of ctx to algorithms
[CRYPTO] digest: Remove unnecessary zeroing during init
[CRYPTO] aes-i586: Get rid of useless function wrappers
[CRYPTO] digest: Add alignment handling
[CRYPTO] khazad: Use 32-bit reads on key
* master.kernel.org:/pub/scm/linux/kernel/git/dtor/input:
Input: iforce - remove some pointless casts
Input: psmouse - add support for Intellimouse 4.0
Input: atkbd - fix HANGEUL/HANJA keys
Input: fix misspelling of Hangeul key
Input: via-pmu - add input device support
Input: rearrange exports
Input: fix formatting to better follow CodingStyle
Input: reset name, phys and uniq when unregistering
Input: return correct size when reading modalias attribute
Input: change my e-mail address in MAINTAINERS file
Input: fix potential overflows in driver/input/keyboard
Input: fix potential overflows in driver/input/touchscreen
Input: fix potential overflows in driver/input/joystick
Input: fix potential overflows in driver/input/mouse
Input: fix accuracy of fixp-arith.h
Input: iforce - use ENOSPC instead of ENOMEM
Input: constify drivers/char/keyboard.c
Remove board specific base RAM conditionals from page_offset.h
With the Kconfig time configurable RAM setup none of this is required.
It is all based on the Kconfig (CONFIG_RAMBASE) option now.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb:
V4L/DVB (4227): Update this driver for recent header file movement.
V4L/DVB (4223): Add V4L2_CID_MPEG_STREAM_VBI_FMT control
V4L/DVB (4222): Always switch tuner mode when calling VIDIOC_S_FREQUENCY.
V4L/DVB (4221): Add HM12 YUV format define.
V4L/DVB (4219): Av7110: analog sound output of DVB-C rev 2.3
V4L/DVB (4217): Fix a misplaced closing bracket/else, which caused swzigzag not to be called
V4L/DVB (4215): Make VIDEO_CX88_BLACKBIRD a separate build option
V4L/DVB (4214): Make VIDEO_CX2341X a selectable build option
V4L/DVB (4213): Cx88: cleanups
V4L/DVB (4211): Fix an Oops for all fe that have get_frontend_algo == NULL
* x86-64: (83 commits)
[PATCH] x86_64: x86_64 stack usage debugging
[PATCH] x86_64: (resend) x86_64 stack overflow debugging
[PATCH] x86_64: msi_apic.c build fix
[PATCH] x86_64: i386/x86-64 Add nmi watchdog support for new Intel CPUs
[PATCH] x86_64: Avoid broadcasting NMI IPIs
[PATCH] x86_64: fix apic error on bootup
[PATCH] x86_64: enlarge window for stack growth
[PATCH] x86_64: Minor string functions optimizations
[PATCH] x86_64: Move export symbols to their C functions
[PATCH] x86_64: Standardize i386/x86_64 handling of NMI_VECTOR
[PATCH] x86_64: Fix modular pc speaker
[PATCH] x86_64: remove sys32_ni_syscall()
[PATCH] x86_64: Do not use -ffunction-sections for modules
[PATCH] x86_64: Add cpu_relax to apic_wait_icr_idle
[PATCH] x86_64: adjust kstack_depth_to_print default
[PATCH] i386/x86-64: adjust /proc/interrupts column headings
[PATCH] x86_64: Fix race in cpu_local_* on preemptible kernels
[PATCH] x86_64: Fix fast check in safe_smp_processor_id
[PATCH] x86_64: x86_64 setup.c - printing cmp related boottime information
[PATCH] i386/x86-64/ia64: Move polling flag into thread_info_status
Manual resolve of trivial conflict in arch/i386/kernel/Makefile
Applies to git & 2.6.17-rc6 after CONFIG_DEBUG_STACKOVERFLOW patch
uses same stack-zeroing mechanism as on i386 to discover maximum stack
excursions.
Signed-off-by: Eric Sandeen <sandeen@sgi.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Intel now has support for Architectural Performance Monitoring Counters
( Refer to IA-32 Intel Architecture Software Developer's Manual
http://www.intel.com/design/pentium4/manuals/253669.htm ). This
feature is present starting from Intel Core Duo and Intel Core Solo processors.
What this means is, the performance monitoring counters and some performance
monitoring events are now defined in an architectural way (using cpuid).
And there will be no need to check for family/model etc for these architectural
events.
Below is the patch to use this performance counters in nmi watchdog driver.
Patch handles both i386 and x86-64 kernels.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
On some i386/x86_64 systems, sending an NMI IPI as a broadcast will
reset the system. This seems to be a BIOS bug which affects machines
where one or more cpus are not under OS control. It occurs on HT
systems with a version of the OS that is not compiled without HT
support. It also occurs when a system is booted with max_cpus=n where
2 <= n < cpus known to the BIOS. The fix is to always send NMI IPI as
a mask instead of as a broadcast.
Signed-off-by: Keith Owens <kaos@sgi.com>
x86_64 and i386 behave inconsistently when sending an IPI on vector 2
(NMI_VECTOR). Make both behave the same, so IPI 2 is sent as NMI.
The crash code was abusing send_IPI_allbutself() by passing a code
instead of a vector, it only worked because crash knew about the
internal code of send_IPI_allbutself(). Change crash to use NMI_VECTOR
instead, and remove the comment about how crash was abusing the function.
This patch is a pre-requisite for fixing the problem where sending an
IPI as NMI would reboot some Dell Xeon systems. I cannot fix that
problem while crash continus to abuse send_IPI_allbutself().
It also removes the inconsistency between i386 and x86_64 for
NMI_VECTOR. That will simplify all the RAS code that needs to bring
all the cpus to a clean stop, even when one or more cpus are spinning
disabled.
This one is adding a cpu_relax() that already existed in the i386 version.
Signed-off-by: Andreas Mohr <andi@lisas.de>
When a process changes CPUs while doing the non atomic cpu_local_*
operations it might operate on the local_t of a different CPUs.
Fix that by disabling preemption.
Pointed out by Christopher Lameter
During some profiling I noticed that default_idle causes a lot of
memory traffic. I think that is caused by the atomic operations
to clear/set the polling flag in thread_info. There is actually
no reason to make this atomic - only the idle thread does it
to itself, other CPUs only read it. So I moved it into ti->status.
Converted i386/x86-64/ia64 for now because that was the easiest
way to fix ACPI which also manipulates these flags in its idle
function.
Cc: Nick Piggin <npiggin@novell.com>
Cc: Len Brown <len.brown@intel.com>
Add support for mce threshold registers found in future
AMD family 0x10 processors. Backwards compatible with
family 0xF hardware.
AK: fixed build on !SMP
Signed-off-by: Jacob Shin <jacob.shin@amd.com>
Get rid of /sys/devices/system/threshold directory and move
mce_amd thresholding files into the machine sysfs directory --
/sys/devices/system/machinecheck.
AK: Fixed warning
Add support for extended APIC LVT found in future AMD processors.
This patch adds the X86_FEATURE_RDTSCP #define, so that kernel code can
check for the feature easily and also fixes the location of the "rdtscp"
string in the cpuinfo tables.
Signed-off-by: Vojtech Pavlik <vojtech@suse.cz>
Rename oem_force_hpet_timer to apic_is_clustered_box, to give the
function a better fitting name - it really isn't at all about HPET.
In timekeeping code, one often does need to use conversion constants. Naming
these leads to code that's easier to understand, showing the reader between
which units the conversion is made.
Most of the fields of cpuinfo are defined in cpuinfo_x86 structure.
This patch moves the phys_proc_id and cpu_core_id for each processor to
cpuinfo_x86 structure as well.
This patch hooks Calgary into the build, the x86-64 IOMMU
initialization paths, and introduces the Calgary specific bits. The
implementation draws inspiration from both PPC (which has support for
the same chip but requires firmware support which we don't have on
x86-64) and gart. Calgary is different from gart in that it support a
translation table per PHB, as opposed to the single gart aperture.
Changes from previous version:
* Addition of boot-time disablement for bus-level translation/isolation
(e.g, enable userspace DMA for things like X)
* Usage of newer IOMMU abstraction functions
Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com>
Signed-off-by: Jon Mason <jdmason@us.ibm.com>
This patch creates a new interface for IOMMUs by adding a centralized
location for IOMMU allocation (for translation tables/apertures) and
IOMMU initialization. In creating these, code was moved around for
abstraction, uniformity, and consiceness.
Take note of the move of the iommu_setup bootarg parsing code to
__setup. This is enabled by moving back the location of the aperture
allocation/detection to mem init (which while ugly, was already the
location of the swiotlb_init).
While a slight departure from the previous patch, I belive this provides
the true intention of the previous versions of the patch which changed
this code. It also makes the addition of the upcoming calgary code much
cleaner than previous patches.
[AK: Removed one broken change. iommu_setup still has to be called
early]
Based on Andi Kleen's comments on the original Calgary patch, move
valid_dma_direction into the calling functions.
swiotlb relies on the gart specific iommu_aperture variable to know if
we discovered a hardware IOMMU before swiotlb initialization. Introduce
iommu_detected to do the same thing, but in a HW IOMMU neutral manner,
in preparation for adding the Calgary HW IOMMU.
Signed-Off-By: Muli Ben-Yehuda <muli@il.ibm.com>
Signed-Off-By: Jon Mason <jdmason@us.ibm.com>
pud_offset_k() equivalent to pud_offset() now. Pointed out by Jan Beulich
Similar for __pud_offset_ok, which needs a small change in the callers.
Add proper conditionals to be able to build with CONFIG_MODULES=n.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
If no unwinding is possible at all for a certain exception instance,
fall back to the old style call trace instead of not showing any trace
at all.
Also, allow setting the stack trace mode at the command line.
To increase the usefulness of reliable stack unwinding, this adds CFI
unwind annotations to many low-level i386 routines.
These are the i386-specific pieces to enable reliable stack traces. This is
going to be even more useful once CFI annotations get added to he assembly
code, namely to entry.S.
These are the x86_64-specific pieces to enable reliable stack traces. The
only restriction with this is that it currently cannot unwind across the
interrupt->normal stack boundary, as that transition is lacking proper
annotation.
These are the generic bits needed to enable reliable stack traces based
on Dwarf2-like (.eh_frame) unwind information. Subsequent patches will
enable x86-64 and i386 to make use of this.
Thanks to Andi Kleen and Ingo Molnar, who pointed out several possibilities
for improvement.
- Rename the GART_IOMMU option to IOMMU to make clear it's not
just for AMD
- Rewrite the help text to better emphatise this fact
- Make it an embedded option because too many people get it wrong.
To my astonishment I discovered the aacraid driver tests this
symbol directly. This looks quite broken to me - it's an internal
implementation detail of the PCI DMA API. Can the maintainer
please clarify what this test was intended to do?
Cc: linux-scsi@vger.kernel.org
Cc: alan@redhat.com
Cc: markh@osdl.org
