* 'irq/threaded' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: fix devres.o build for GENERIC_HARDIRQS=n
genirq: provide old request_irq() for CONFIG_GENERIC_HARDIRQ=n
genirq: threaded irq handlers review fixups
genirq: add support for threaded interrupts to devres
genirq: add threaded interrupt handler support
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: pci_slot: grab refcount on slot's bus
PCI Hotplug: acpiphp: grab refcount on p2p subordinate bus
PCI: allow PCI core hotplug to remove PCI root bus
PCI: Fix oops in pci_vpd_truncate
PCI: don't corrupt enable_cnt when doing manual resource alignment
PCI: annotate pci_rescan_bus as __ref, not __devinit
PCI-IOV: fix missing kernel-doc
PCI: Setup disabled bridges even if buses are added
PCI: SR-IOV quirk for Intel 82576 NIC
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
loop: mutex already unlocked in loop_clr_fd()
cfq-iosched: don't let idling interfere with plugging
block: remove unused REQ_UNPLUG
cfq-iosched: kill two unused cfqq flags
cfq-iosched: change dispatch logic to deal with single requests at the time
mflash: initial support
cciss: change to discover first memory BAR
cciss: kernel scan thread for MSA2012
cciss: fix residual count for block pc requests
block: fix inconsistency in I/O stat accounting code
block: elevator quiescing helpers
The code that enables branch tracing for all (non-constant) branches
plays games with the preprocessor and #define's the C 'if ()' construct
to do tracing.
That's all fine, but it fails for some unusual but valid C code that is
sometimes used in macros, notably by the intel-iommu code:
if (i=drhd->iommu, drhd->ignored) ..
because now the preprocessor complains about multiple arguments to the
'if' macro.
So make the macro expansion of this particularly horrid trick use
varargs, and handle the case of comma-expressions in if-statements. Use
another macro to do it cleanly in just one place.
This replaces a patch by David (and acked by Steven) that did this all
inside that one already-too-horrid macro.
Tested-by: Ingo Molnar <mingo@elte.hu>
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
sata_mv: shorten register names
sata_mv: workaround errata SATA#13
sata_mv: cosmetic renames
sata_mv: workaround errata SATA#26
sata_mv: workaround errata PCI#7
sata_mv: replace 0x1f with ATA_PIO4 (v2)
sata_mv: fix irq mask races
sata_mv: revert SoC irq breakage
libata: ahci enclosure management bios workaround
ata: Add TRIM infrastructure
ata_piix: VGN-BX297XP wants the controller power up on suspend
libata: Remove some redundant casts from pata_octeon_cf.c
pata_artop: typo
* 'i2c-for-2630-v2' of git://aeryn.fluff.org.uk/bjdooks/linux:
i2c: imx: Make disable_delay a per-device variable
i2c: xtensa s6000 i2c driver
powerpc/85xx: i2c-mpc: use new I2C bindings for the Socates board
i2c: i2c-mpc: make I2C bus speed configurable
i2c: i2c-mpc: use dev based printout function
i2c: i2c-mpc: various coding style fixes
i2c: imx: Add missing request_mem_region in probe()
i2c: i2c-s3c2410: Initialise Samsung I2C controller early
i2c-s3c2410: Simplify bus frequency calculation
i2c-s3c2410: sda_delay should be in ns, not clock ticks
i2c: iMX/MXC support
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6:
hwmon: Add Asus ATK0110 support
hwmon: (lm95241) Convert to new-style i2c driver
PCI parallel port devices can IRQ share so we should stop them hogging
the line and making a mess on modern PC systems. We know the sharing
side works as the PCMCIA driver has shared the parallel port IRQ for
some time.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
(akpm: queued pending confirmation of the new major number)
[randy.dunlap@oracle.com: select SERIAL_CORE]
Signed-off-by: Christian Pellegrin <chripell@fsfe.org>
tty_driver_kref_get() should be static inline and not extern inline
(the latter even changed it's semantics in gcc >= 4.3).
Signed-off-by: Adrian Bunk <bunk@kernel.org>
After a review of user's feedback for finding out other compatibility
issues, I found nilfs improperly initializes timestamps in inode;
CURRENT_TIME was used there instead of CURRENT_TIME_SEC even though nilfs
didn't have nanosecond timestamps on disk. A few users gave us the report
that the tar program sometimes failed to expand symbolic links on nilfs,
and it turned out to be the cause.
Instead of applying the above displacement, I've decided to support
nanosecond timestamps on this occation. Fortunetaly, a needless 64-bit
field was in the nilfs_inode struct, and I found it's available for this
purpose without impact for the users.
So, this will do the enhancement and resolve the tar problem.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
The former versions didn't have extra super blocks. This improves the
weak point by introducing another super block at unused region in tail of
the partition.
This doesn't break disk format compatibility; older versions just ingore
the secondary super block, and new versions just recover it if it doesn't
exist. The partition created by an old mkfs may not have unused region,
but in that case, the secondary super block will not be added.
This doesn't make more redundant copies of the super block; it is a future
work.
Nilfs creates checkpoints even for garbage collection or metadata updates
such as checkpoint mode change. So, user often sees checkpoints created
only by such internal operations.
This is inconvenient in some situations. For example, application that
monitors checkpoints and changes them to snapshots, will fall into an
infinite loop because it cannot distinguish internally created
checkpoints.
This patch solves this sort of problem by adding a flag to checkpoint for
identification.
The sketch file is a file to mark checkpoints with user data. It was
experimentally introduced in the original implementation, and now
obsolete. The file was handled differently with regular files; the file
size got truncated when a checkpoint was created.
This stops the special treatment and will treat it as a regular file.
Most users are not affected because mkfs.nilfs2 no longer makes this file.
This adds a new argument to the nilfs_sustat structure.
The extended field allows to delete volatile active state of segments,
which was needed to protect freshly-created segments from garbage
collection but has confused code dealing with segments. This
extension alleviates the mess and gives room for further
simplifications.
The volatile active flag is not persistent, so it's eliminable on this
occasion without affecting compatibility other than the ioctl change.
This removes compat code from the nilfs ioctls and applies the same
function for both .ioctl and .compat_ioctl file operations.
Nilfs ioctl had structures not having fixed sized types such as:
struct nilfs_argv {
void *v_base;
size_t v_nmembs;
size_t v_size;
int v_index;
int v_flags;
Further, some of them are wrongly aligned:
e.g.
struct nilfs_cpmode {
__u64 cm_cno;
int cm_mode;
The size of wrongly aligned structures varies depending on
architectures, and it breaks the identity of ioctl commands, which
leads to arch dependent errors.
Previously, these are compensated by using compat_ioctl.
This fixes these problems and allows removal of compat ioctl.
Since this will change sizes of those structures, binary compatibility
for the past utilities will once break; new utilities have to be used
instead. However, it would be helpful to avoid platform dependent
problems in the long term.
This removes NILFS_IOCTL_TIMEDWAIT command from ioctl interface along
with the related flags and wait queue.
The command is terrible because it just sleeps in the ioctl. I prefer
to avoid this by devising means of event polling in userland program.
By reconsidering the userland GC daemon, I found this is possible
without changing behaviour of the daemon and sacrificing efficiency.
This adds a header file which specifies the on-disk format and ioctl
interface of the nilfs2 file system.
Signed-off-by: Koji Sato <sato.koji@lab.ntt.co.jp>
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Largely inspired from ipc/ipc_sysctl.c. This patch isolates the mqueue
sysctl stuff in its own file.
[akpm@linux-foundation.org: build fix]
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net>
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Implement multiple mounts of the mqueue file system, and link it to usage
of CLONE_NEWIPC.
Each ipc ns has a corresponding mqueuefs superblock. When a user does
clone(CLONE_NEWIPC) or unshare(CLONE_NEWIPC), the unshare will cause an
internal mount of a new mqueuefs sb linked to the new ipc ns.
When a user does 'mount -t mqueue mqueue /dev/mqueue', he mounts the
Posix message queues can be worked with both through the mq_* system calls
(see mq_overview(7)), and through the VFS through the mqueue mount. Any
usage of mq_open() and friends will work with the acting task's ipc
namespace. Any actions through the VFS will work with the mqueuefs in
which the file was created. So if a user doesn't remount mqueuefs after
unshare(CLONE_NEWIPC), mq_open("/ab") will not be reflected in "ls
/dev/mqueue".
If task a mounts mqueue for ipc_ns:1, then clones task b with a new ipcns,
ipcns:2, and then task a is the last task in ipc_ns:1 to exit, then (1)
ipc_ns:1 will be freed, (2) it's superblock will live on until task b
umounts the corresponding mqueuefs, and vfs actions will continue to
succeed, but (3) sb->s_fs_info will be NULL for the sb corresponding to
the deceased ipc_ns:1.
To make this happen, we must protect the ipc reference count when
a) a task exits and drops its ipcns->count, since it might be dropping
it to 0 and freeing the ipcns
b) a task accesses the ipcns through its mqueuefs interface, since it
bumps the ipcns refcount and might race with the last task in the ipcns
exiting.
So the kref is changed to an atomic_t so we can use
atomic_dec_and_lock(&ns->count,mq_lock), and every access to the ipcns
through ns = mqueuefs_sb->s_fs_info is protected by the same lock.
Move mqueue vfsmount plus a few tunables into the ipc_namespace struct.
The CONFIG_IPC_NS boolean and the ipc_namespace struct will serve both the
posix message queue namespaces and the SYSV ipc namespaces.
The sysctl code will be fixed separately in patch 3. After just this
patch, making a change to posix mqueue tunables always changes the values
in the initial ipc namespace.
The mqueuefs filesystem will use this helper as well. Proc's main get_sb
could also be made to use it, but that will require a bit more rework.
Cc: Cedric Le Goater <clg@fr.ibm.com>
The I2C functionality provided by the i2c-voodoo3 driver is moved into the
tdfxfb (frame buffer driver for Voodoo3 cards). This way there is no
conflict between the i2c driver and the fb driver.
The tdfxfb does not make use from the DDC functionality yet but provides
all the functionality of the i2c-voodoo3 driver.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Acked-by: Jean Delvare <khali@linux-fr.org>
Add disable/enable_kretprobe() and disable/enable_jprobe().
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Add disable_kprobe() and enable_kprobe() to disable/enable kprobes
temporarily.
disable_kprobe() asynchronously disables probe handlers of specified
kprobe. So, after calling it, some handlers can be called at a while.
enable_kprobe() enables specified kprobe.
aggr_pre_handler and aggr_post_handler check disabled probes. On the
other hand aggr_break_handler and aggr_fault_handler don't check it
because these handlers will be called while executing pre or post handlers
and usually those help error handling.
Fix comment style in kprobes.h.
Some SPI controllers have restrictions on DMAable buffers alignemt.
Currently if the buffer supplied by protocol driver is not properly
aligned, the controller silently performs transfer in PIO mode. Addition
of dma_alignment field to spi_master allows protocol drivers to perform
proper alignment.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Cc: Bryan Wu <bryan.wu@analog.com>
Cc: David Brownell <david-b@pacbell.net>
Add /proc entries to give the admin the ability to control the minimum and
maximum number of pdflush threads. This allows finer control of pdflush
on both large and small machines.
The rationale is simply one size does not fit all. Admins on large and/or
small systems may want to tune the min/max pdflush thread count to best
suit their needs. Right now the min/max is hardcoded to 2/8. While
probably a fair estimate for smaller machines, large machines with large
numbers of CPUs and large numbers of filesystems/block devices may benefit
from larger numbers of threads working on different block devices.
Even if the background flushing algorithm is radically changed, it is
still likely that multiple threads will be involved and admins would still
desire finer control on the min/max other than to have to recompile the
kernel.
The patch adds '/proc/sys/vm/nr_pdflush_threads_min' and
'/proc/sys/vm/nr_pdflush_threads_max' with r/w permissions.
The minimum value for nr_pdflush_threads_min is 1 and the maximum value is
the current value of nr_pdflush_threads_max. This minimum is required
since additional thread creation is performed in a pdflush thread itself.
The minimum value for nr_pdflush_threads_max is the current value of
nr_pdflush_threads_min and the maximum value can be 1000.
Documentation/sysctl/vm.txt is also updated.
[akpm@linux-foundation.org: fix comment, fix whitespace, use __read_mostly]
Signed-off-by: Peter W Morreale <pmorreale@novell.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (28 commits)
powerpc: Fix oops when loading modules
powerpc: Wire up preadv and pwritev
powerpc/ftrace: Fix printf format warning
powerpc/ftrace: Fix #if that should be #ifdef
powerpc: Fix ptrace compat wrapper for FPU register access
powerpc: Print information about mapping hw irqs to virtual irqs
powerpc: Correct dependency of KEXEC
powerpc: Disable VSX or current process in giveup_fpu/altivec
powerpc/pseries: Enable relay in pseries_defconfig
powerpc/pseries: Fix ibm,client-architecture comment
powerpc/pseries: Scan for all events in rtasd
powerpc/pseries: Add dispatch dispersion statistics
powerpc: Clean up some prom printouts
powerpc: Print progress of ibm,client-architecture method
powerpc: Remove duplicated #include's
powerpc/pmac: Fix internal modem IRQ on Wallstreet PowerBook
powerpc/wdrtas: Update wdrtas_get_interval to use rtas_data_buf
fsl-diu-fb: Pass the proper device for dma mapping routines
powerpc/pq2fads: Update device tree for use with device-tree-aware u-boot.
cpm_uart: Disable CPM udbg when re-initing CPM uart, even if not the console.
Asus boards have an ACPI interface for interacting with the hwmon (fan,
temperatures, voltages) subsystem; this driver exposes the relevant
information via the standard sysfs interface.
There are two different ACPI interfaces:
- an old one (based on RVLT/RFAN/RTMP)
- a new one (GGRP/GITM)
Both may be present but there a few cases (my board, sigh) where the
new interface is just an empty stub; the driver defaults to the old one
when both are present.
The old interface has received a considerable testing, but I'm still
awaiting confirmation from my tester that the new one is working as
expected (hence the debug code is still enabled).
Currently all the attributes are read-only, though a (partial) control
should be possible with a bit more work.
Signed-off-by: Luca Tettamanti <kronos.it@gmail.com>
Support for the s6000 on-chip i2c controller.
Signed-off-by: Oskar Schirmer <os@emlix.com>
Signed-off-by: Daniel Glöckner <dg@emlix.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
The request inherits the unplug flag from the bio, but it isn't actually
used. The bio flag stops at __make_request(), which tells it to unplug
after submission. Passing it on to the request doesn't make any sense.
This driver supports mflash IO mode for linux.
Mflash is embedded flash drive and mainly targeted mobile and consumer
electronic devices.
Internally, mflash has nand flash and other hardware logics and supports 2
different operation (ATA, IO) modes. ATA mode doesn't need any new driver
and currently works well under standard IDE subsystem. Actually it's one
chip SSD. IO mode is ATA-like custom mode for the host that doesn't have
IDE interface.
Followings are brief descriptions about IO mode.
A. IO mode based on ATA protocol and uses some custom command. (read confirm,
write confirm)
B. IO mode uses SRAM bus interface.
C. IO mode supports 4kB boot area, so host can boot from mflash.
This driver is quitely similar to a standard ATA driver, but because of
following reasons it is currently seperated with ATA layer.
1. ATA layer deals standard ATA protocol. ATA layer have many low-
level device specific interface, but data transfer keeps ATA rule.
But, mflash IO mode doesn't.
2. Even though currently not used in mflash driver code, mflash has
some custom command and modes. (nand fusing, firmware patch, etc) If
this feature supported in linux kernel, ATA layer more altered.
3. Currently PATA platform device driver doesn't support interrupt.
(I'm not sure) But, mflash uses interrupt (polling mode is just for
debug).
4. mflash is somewhat under-develop product. Even though some company
already using mflash their own product, I think more time is needed for
standardization of custom command and mode. That time (maybe October)
I will talk to with ATA people. If they accept integration, I will
integrate.
Signed-off-by: unsik Kim <donari75@gmail.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
This forces in_flight to be zero when turning off or on the I/O stat
accounting and stops updating I/O stats in attempt_merge() when
accounting is turned off.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into merge
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (120 commits)
cx231xx: Convert to snd_card_create()
V4L/DVB (11440): PWC: fix build error when CONFIG_INPUT=m
V4L/DVB (11439): UVC: uvc_status_cleanup(): undefined reference to `input_unregister_device'
V4L/DVB (11438): au0828: fix Kconfig dependance
V4L/DVB (11437): pvrusb2: Drop client_register/unregister stubs
V4L/DVB (11436): radio-mr800: convert to to v4l2_device
V4L/DVB (11435): dsbr100 radio: convert to to v4l2_device
V4L/DVB: zr364xx: remove unused #include <version.h>
V4L/DVB: usbvision: remove unused #include <version.h>
V4L/DVB (11427): gspca - m5602: Minor cleanups
V4L/DVB (11426): gspca - m5602: Don't touch hflip/vflip register on Read/Modify/Write
V4L/DVB (11425): gspca - m5602: Move the vflip quirk to probe stage.
V4L/DVB (11424): gspca - m5602-ov9650: Use the local ctrl cache. Adjust image on vflip.
V4L/DVB (11423): gspca - m5602-ov9650: Add a disconnect hook, setup a ctrl cache ctrl.
V4L/DVB (11422): gspca - m5602-ov9650: Replace a magic constant with a define
V4L/DVB (11421): gspca - m5602-ov9650: Synthesize modesetting.
V4L/DVB (11420): gspca - m5602: Improve error handling in the ov9650 driver
V4L/DVB (11419): gspca - m5602-ov9650: Don't read exposure data from COM1.
V4L/DVB (11418): gspca - m5602-ov9650: Auto white balancing is on by default
V4L/DVB (11417): gspca - m5602-ov9650: Autogain is on by default
Add support to the SQ-905 driver to pass back to user space the
sensor orientation information obtained from the camera during init.
Modifies gspca and the videodev2.h header to create the necessary
API.
[mchehab@redhat.com: Changed "Output is" to "Frames are" at the comments, as suggested at LMML]
Signed-off-by: Adam Baker <linux@baker-net.org.uk>
Remove support for the debug call VIDIOC_INT_S_AUDIO_ROUTING from cx18
and ivtv. These internal ioctls shouldn't be exposed. These were only
used through the cx18-ctl and ivtv-ctl utilities, and only when testing
a new card variant.
This cleanup allows the removal of this ioctl from v4l2-common.h.
Cc: Andy Walls <awalls@radix.net>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
It is no longer needed to use a struct pointer as argument, since v4l2_subdev
doesn't require that ioctl-like approach anymore. Instead just pass the input,
output and config (new!) arguments directly.
v4l2_subdev.
With all the v4l2_subdev changes that were made to these drivers it is a
good idea to increase the version number of each driver.
It's just the patch level that is increased, except for the zoran and saa7146
drivers where the minor number was increased due to the more substantial
changes that were made to those two drivers.
possible i2c addrs.
Rather than duplicating this list everywhere, just put it in tvaudio.h.
to new_(probed)_subdev
The functions v4l2_i2c_new_subdev and v4l2_i2c_new_probed_subdev relied on
i2c_get_adapdata to return the v4l2_device. However, this is not always
possible on embedded platforms. So modify the API to pass the v4l2_device
pointer explicitly.
Add utility function to probe for a single address, rather than a list
of addresses.
< 2.6.22
Originally the intention was to switch to the new style i2c API starting with
the introduction of the API in 2.6.22. However, the i2c_new_probed_device()
function has a lethal bug that wasn't fixed until 2.6.25. Or more accurately,
it was only fixed in the stable series of 2.6.25 and 2.6.26.
Given the fact that the new i2c API also changed starting with 2.6.26 (the
addition of i2c_device_id), it is easiest to switch APIs starting with
2.6.26.
This patch updates all the legacy code accordingly.
s_std didn't belong in the tuner ops. Stricly speaking it should be part of
the video ops, but it is used by audio and tuner devices as well, so it is
more efficient to make it part of the core ops.
core->init.
The init callback was used in several places to load firmware. Make a separate
load_fw callback for that. This makes the code a lot more understandable.
s_standby is only used to put the tuner in powersaving mode, so move it
from core to tuner.
