Sasha Levin found a NULL pointer dereference that is due to a missing
page table lock, which in turn is due to the pmd entry in question being
a transparent huge-table entry.
The code - introduced in commit 1998cc048901 ("mm: make
madvise(MADV_WILLNEED) support swap file prefetch") - correctly checks
for this situation using pmd_none_or_trans_huge_or_clear_bad(), but it
turns out that that function doesn't work correctly.
pmd_none_or_trans_huge_or_clear_bad() expected that pmd_bad() would
trigger if the transparent hugepage bit was set, but it doesn't do that
if pmd_numa() is also set. Note that the NUMA bit only gets set on real
NUMA machines, so people trying to reproduce this on most normal
development systems would never actually trigger this.
Fix it by removing the very subtle (and subtly incorrect) expectation,
and instead just checking pmd_trans_huge() explicitly.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
[ Additionally remove the now stale test for pmd_trans_huge() inside the
pmd_bad() case - Linus ]
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen bugfixes from Konrad Rzeszutek Wilk:
- Fix balloon driver for auto-translate guests (PVHVM, ARM) to not use
scratch pages.
- Fix block API header for ARM32 and ARM64 to have proper layout
- On ARM when mapping guests, stick on PTE_SPECIAL
- When using SWIOTLB under ARM, don't call swiotlb functions twice
- When unmapping guests memory and if we fail, don't return pages which
failed to be unmapped.
- Grant driver was using the wrong address on ARM.
* tag 'stable/for-linus-3.13-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/balloon: Seperate the auto-translate logic properly (v2)
xen/block: Correctly define structures in public headers on ARM32 and ARM64
arm: xen: foreign mapping PTEs are special.
xen/arm64: do not call the swiotlb functions twice
xen: privcmd: do not return pages which we have failed to unmap
XEN: Grant table address, xen_hvm_resume_frames, is a phys_addr not a pfn
Pull perf fixes from Ingo Molnar:
"An ABI documentation fix, and a mixed-PMU perf-info-corruption fix"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf: Document the new transaction sample type
perf: Disable all pmus on unthrottling and rescheduling
Merge patches from Andrew Morton:
"23 fixes and a MAINTAINERS update"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (24 commits)
mm/hugetlb: check for pte NULL pointer in __page_check_address()
fix build with make 3.80
mm/mempolicy: fix !vma in new_vma_page()
MAINTAINERS: add Davidlohr as GPT maintainer
mm/memory-failure.c: recheck PageHuge() after hugetlb page migrate successfully
mm/compaction: respect ignore_skip_hint in update_pageblock_skip
mm/mempolicy: correct putback method for isolate pages if failed
mm: add missing dependency in Kconfig
sh: always link in helper functions extracted from libgcc
mm: page_alloc: exclude unreclaimable allocations from zone fairness policy
mm: numa: defer TLB flush for THP migration as long as possible
mm: numa: guarantee that tlb_flush_pending updates are visible before page table updates
mm: fix TLB flush race between migration, and change_protection_range
mm: numa: avoid unnecessary disruption of NUMA hinting during migration
mm: numa: clear numa hinting information on mprotect
sched: numa: skip inaccessible VMAs
mm: numa: avoid unnecessary work on the failure path
mm: numa: ensure anon_vma is locked to prevent parallel THP splits
mm: numa: do not clear PTE for pte_numa update
mm: numa: do not clear PMD during PTE update scan
table updates
According to documentation on barriers, stores issued before a LOCK can
complete after the lock implying that it's possible tlb_flush_pending
can be visible after a page table update. As per revised documentation,
this patch adds a smp_mb__before_spinlock to guarantee the correct
ordering.
Cc: <stable@vger.kernel.org>
There are a few subtle races, between change_protection_range (used by
mprotect and change_prot_numa) on one side, and NUMA page migration and
compaction on the other side.
The basic race is that there is a time window between when the PTE gets
made non-present (PROT_NONE or NUMA), and the TLB is flushed.
During that time, a CPU may continue writing to the page.
This is fine most of the time, however compaction or the NUMA migration
code may come in, and migrate the page away.
When that happens, the CPU may continue writing, through the cached
translation, to what is no longer the current memory location of the
process.
This only affects x86, which has a somewhat optimistic pte_accessible.
All other architectures appear to be safe, and will either always flush,
or flush whenever there is a valid mapping, even with no permissions
(SPARC).
The basic race looks like this:
CPU A CPU B CPU C
load TLB entry
make entry PTE/PMD_NUMA
fault on entry
read/write old page
start migrating page
change PTE/PMD to new page
read/write old page [*]
flush TLB
reload TLB from new entry
read/write new page
lose data
[*] the old page may belong to a new user at this point!
The obvious fix is to flush remote TLB entries, by making sure that
pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may
still be accessible if there is a TLB flush pending for the mm.
This should fix both NUMA migration and compaction.
[mgorman@suse.de: fix build]
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Alex Thorlton <athorlton@sgi.com>
do_huge_pmd_numa_page() handles the case where there is parallel THP
migration. However, by the time it is checked the NUMA hinting
information has already been disrupted. This patch adds an earlier
check with some helpers.
Commit 1b3a5d02ee07 ("reboot: move arch/x86 reboot= handling to generic
kernel") moved reboot= handling to generic code. In the process it also
removed the code in native_machine_shutdown() which are moving reboot
process to reboot_cpu/cpu0.
I guess that thought must have been that all reboot paths are calling
migrate_to_reboot_cpu(), so we don't need this special handling. But
kexec reboot path (kernel_kexec()) is not calling
migrate_to_reboot_cpu() so above change broke kexec. Now reboot can
happen on non-boot cpu and when INIT is sent in second kerneo to bring
up BP, it brings down the machine.
So start calling migrate_to_reboot_cpu() in kexec reboot path to avoid
this problem.
Bisected by WANG Chao.
Reported-by: Matthew Whitehead <mwhitehe@redhat.com>
Reported-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Tested-by: Baoquan He <bhe@redhat.com>
Tested-by: WANG Chao <chaowang@redhat.com>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Pull drm fixes from Dave Airlie:
"Definitely seems quieter this week,
Radeon, intel, intel broadwell, vmwgfx, ttm, armada, and a couple of
core fixes, one revert in radeon
Most of these are either going to stable or fixes for things
introduced in the merge window"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (30 commits)
drm/edid: add quirk for BPC in Samsung NP700G7A-S01PL notebook
drm/ttm: Fix accesses through vmas with only partial coverage
drm/nouveau: only runtime suspend by default in optimus configuration
drm: don't double-free on driver load error
Revert "drm/radeon: Implement radeon_pci_shutdown"
drm/radeon: add missing display tiling setup for oland
drm/radeon: fix typo in cik_copy_dma
drm/radeon/cik: plug in missing blit callback
drm/radeon/dpm: Fix hwmon crash
drm/radeon: Fix sideport problems on certain RS690 boards
drm/i915: don't update the dri1 breadcrumb with modesetting
DRM: Armada: prime refcounting bug fix
DRM: Armada: fix printing of phys_addr_t/dma_addr_t
DRM: Armada: destroy framebuffer after helper
DRM: Armada: implement lastclose() for fbhelper
drm/i915: Repeat eviction search after idling the GPU
drm/vmwgfx: Add max surface memory param
drm/i915: Fix use-after-free in do_switch
drm/i915: fix pm init ordering
drm/i915: Hold mutex across i915_gem_release
Pull scheduler fixes from Ingo Molnar:
"Three fixes for scheduler crashes, each triggers in relatively rare,
hardware environment dependent situations"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/fair: Rework sched_fair time accounting
math64: Add mul_u64_u32_shr()
sched: Remove PREEMPT_NEED_RESCHED from generic code
sched: Initialize power_orig for overlapping groups
Commit fdfbbd07e91f8fe3871 ("perf: Add generic transaction flags")
added support for PERF_SAMPLE_TRANSACTION but forgot to add documentation
for the sample type to include/uapi/linux/perf_event.h
Signed-off-by: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1312131548450.10372@pianoman.cluster.toy
Pull networking fixes from David Miller:
1) Revert CHECKSUM_COMPLETE optimization in pskb_trim_rcsum(), I can't
figure out why it breaks things.
2) Fix comparison in netfilter ipset's hash_netnet4_data_equal(), it
was basically doing "x == x", from Dave Jones.
3) Freescale FEC driver was DMA mapping the wrong number of bytes, from
Sebastian Siewior.
4) Blackhole and prohibit routes in ipv6 were not doing the right thing
because their ->input and ->output methods were not being assigned
correctly. Now they behave properly like their ipv4 counterparts.
From Kamala R.
5) Several drivers advertise the NETIF_F_FRAGLIST capability, but
really do not support this feature and will send garbage packets if
fed fraglist SKBs. From Eric Dumazet.
6) Fix long standing user triggerable BUG_ON over loopback in RDS
protocol stack, from Venkat Venkatsubra.
7) Several not so common code paths can potentially try to invoke
packet scheduler actions that might be NULL without checking. Shore
things up by either 1) defining a method as mandatory and erroring
on registration if that method is NULL 2) defininig a method as
optional and the registration function hooks up a default
implementation when NULL is seen. From Jamal Hadi Salim.
8) Fix fragment detection in xen-natback driver, from Paul Durrant.
9) Kill dangling enter_memory_pressure method in cg_proto ops, from
Eric W Biederman.
10) SKBs that traverse namespaces should have their local_df cleared,
from Hannes Frederic Sowa.
11) IOCB file position is not being updated by macvtap_aio_read() and
tun_chr_aio_read(). From Zhi Yong Wu.
12) Don't free virtio_net netdev before releasing all of the NAPI
instances. From Andrey Vagin.
13) Procfs entry leak in xt_hashlimit, from Sergey Popovich.
14) IPv6 routes that are no cached routes should not count against the
garbage collection limits. We had this almost right, but were
missing handling addrconf generated routes properly. From Hannes
Frederic Sowa.
15) fib{4,6}_rule_suppress() have to consider potentially seeing NULL
route info when they are called, from Stefan Tomanek.
16) TUN and MACVTAP have had truncated packet signalling for some time,
fix from Jason Wang.
17) Fix use after frrr in __udp4_lib_rcv(), from Eric Dumazet.
18) xen-netback does not interpret the NAPI budget properly for TX work,
fix from Paul Durrant.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (132 commits)
igb: Fix for issue where values could be too high for udelay function.
i40e: fix null dereference
xen-netback: fix gso_prefix check
net: make neigh_priv_len in struct net_device 16bit instead of 8bit
drivers: net: cpsw: fix for cpsw crash when build as modules
xen-netback: napi: don't prematurely request a tx event
xen-netback: napi: fix abuse of budget
sch_tbf: use do_div() for 64-bit divide
udp: ipv4: must add synchronization in udp_sk_rx_dst_set()
net:fec: remove duplicate lines in comment about errata ERR006358
Revert "8390 : Replace ei_debug with msg_enable/NETIF_MSG_* feature"
xen-netback: make sure skb linear area covers checksum field
net: smc91x: Fix device tree based configuration so it's usable
udp: ipv4: fix potential use after free in udp_v4_early_demux()
macvtap: signal truncated packets
tun: unbreak truncated packet signalling
net: sched: htb: fix the calculation of quantum
net: sched: tbf: fix the calculation of max_size
micrel: add support for KSZ8041RNLI
Pull x86 fixes from Peter Anvin:
"This is a pretty small batch:
The biggest single change is to stop using EFI time services on 32-bit
platforms. This matches our current behavior on 64-bit platforms as
we already had ruled them out there as being too unreliable. Turns
out that affects 32-bit platforms, too.
One NULL pointer fix for SGI UV.
Two minor build fixes, one of which only affects icc and the other
which affects icc and future versions or nonstandard default settings
of gcc"
* 'x86/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, efi: Don't use (U)EFI time services on 32 bit
x86, build, icc: Remove uninitialized_var() from compiler-intel.h
x86/UV: Fix NULL pointer dereference in uv_flush_tlb_others() if the 'nobau' boot option is used
x86, build: Pass in additional -mno-mmx, -mno-sse options
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI device hotplug
- Move device_del() from pci_stop_dev() to pci_destroy_dev() (Rafael
Wysocki)
Host bridge drivers
- Update maintainers for DesignWare, i.MX6, Armada, R-Car (Bjorn
Helgaas)
- mvebu: Return 'unsupported' for Interrupt Line and Interrupt Pin
(Jason Gunthorpe)
Miscellaneous
- Avoid unnecessary CPU switch when calling .probe() (Alexander
Duyck)
- Revert "workqueue: allow work_on_cpu() to be called recursively"
(Bjorn Helgaas)
- Disable Bus Master only on kexec reboot (Khalid Aziz)
- Omit PCI ID macro strings to shorten quirk names for LTO (Michal
Marek)"
* tag 'pci-v3.13-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
MAINTAINERS: Add DesignWare, i.MX6, Armada, R-Car PCI host maintainers
PCI: Disable Bus Master only on kexec reboot
PCI: mvebu: Return 'unsupported' for Interrupt Line and Interrupt Pin
PCI: Omit PCI ID macro strings to shorten quirk names
PCI: Move device_del() from pci_stop_dev() to pci_destroy_dev()
PCI: Avoid unnecessary CPU switch when calling driver .probe() method
On ARM (32 bits and 64 bits), the double-word is 8-bytes aligned. This will
result on different structure from Xen and Linux repositories.
As Linux is using __packed__ attribute, it must have a 4-bytes padding before
each "id" field.
This change breaks guest block support with older kernel. IMHO, it's acceptable
because Xen on ARM is still on Tech Preview and the hypercall ABI is not yet
freezed.
Only one architecture (x86_32) doesn't have 64-bit ABI for the block interface.
Don't add padding if Linux is compiled for this architecture.
Signed-off-by: Julien Grall <julien.grall@linaro.org>
Acked-by: Roger Pau Monne <roger.pau@citrix.com>
Acked-by: David Vrabel <david.vrabel@citrix.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Ian Campbell <ian.campbell@citrix.com>
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
[I had asked for confirmation that it did not break x86 and Ian went
beyound the call of duty to confirm it. Also a internal regression
bucket with 32/64 dom0 with 32/64 domU (PV and HVM) confirmed no
regressions. ABI changes are a drag..]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
"13 fixes"
mm: memcg: do not allow task about to OOM kill to bypass the limit
mm: memcg: fix race condition between memcg teardown and swapin
thp: move preallocated PTE page table on move_huge_pmd()
mfd/rtc: s5m: fix register updating by adding regmap for RTC
rtc: s5m: enable IRQ wake during suspend
rtc: s5m: limit endless loop waiting for register update
rtc: s5m: fix unsuccesful IRQ request during probe
drivers/rtc/rtc-s5m.c: fix info->rtc assignment
include/linux/kernel.h: make might_fault() a nop for !MMU
drivers/rtc/rtc-at91rm9200.c: correct alarm over day/month wrap
procfs: also fix proc_reg_get_unmapped_area() for !MMU case
mm: memcg: do not declare OOM from __GFP_NOFAIL allocations
include/linux/hugetlb.h: make isolate_huge_page() an inline
Rename old regmap field of "struct sec_pmic_dev" to "regmap_pmic" and
add new regmap for RTC.
On S5M8767A registers were not properly updated and read due to usage of
the same regmap as the PMIC. This could be observed in various hangs,
e.g. in infinite loop during waiting for UDR field change.
On this chip family the RTC has different I2C address than PMIC so
additional regmap is needed.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Mark Brown <broonie@linaro.org>
Acked-by: Sangbeom Kim <sbkim73@samsung.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Liam Girdwood <lgirdwood@gmail.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
The machine cannot fault if !MUU, so make might_fault() a nop for !MMU.
This fixes below build error if
!CONFIG_MMU && (CONFIG_PROVE_LOCKING=y || CONFIG_DEBUG_ATOMIC_SLEEP=y):
arch/arm/kernel/built-in.o: In function `arch_ptrace':
arch/arm/kernel/ptrace.c:852: undefined reference to `might_fault'
arch/arm/kernel/built-in.o: In function `restore_sigframe':
arch/arm/kernel/signal.c:173: undefined reference to `might_fault'
arch/arm/kernel/built-in.o:arch/arm/kernel/signal.c:177: more undefined references to `might_fault' follow
make: *** [vmlinux] Error 1
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
With CONFIG_HUGETLBFS=n:
mm/migrate.c: In function `do_move_page_to_node_array':
include/linux/hugetlb.h:140:33: warning: statement with no effect [-Wunused-value]
#define isolate_huge_page(p, l) false
mm/migrate.c:1170:4: note: in expansion of macro `isolate_huge_page'
isolate_huge_page(page, &pagelist);
Reported-by: Borislav Petkov <bp@alien8.de>
Tested-by: Borislav Petkov <bp@alien8.de>
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: David Rientjes <rientjes@google.com>
git://people.freedesktop.org/~thomash/linux into drm-fixes
Part of a driver stack fix that fixes surface overcommiting on single execbuf calls.
* 'vmwgfx-fixes-3.13' of git://people.freedesktop.org/~thomash/linux:
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Still a slightly high amount of changes than wished, but they are all
good regression and/or device-specific fixes. Majority of commits are
for HD-audio, an HDMI ctl index fix that hits old graphics boards,
regression fixes for AD codecs and a few quirks.
Other than that, two major fixes are included: a 64bit ABI fix for
compress offload, and 64bit dma_addr_t truncation fix, which had hit
on PAE kernels"
* tag 'sound-3.13-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Add static DAC/pin mapping for AD1986A codec
ALSA: hda - One more Dell headset detection quirk
ALSA: hda - hdmi: Fix IEC958 ctl indexes for some simple HDMI devices
ALSA: hda - Mute all aamix inputs as default
ALSA: compress: Fix 64bit ABI incompatibility
ALSA: memalloc.h - fix wrong truncation of dma_addr_t
ALSA: hda - Another Dell headset detection quirk
ALSA: hda - A Dell headset detection quirk
ALSA: hda - Remove quirk for Dell Vostro 131
ALSA: usb-audio: fix uninitialized variable compile warning
ALSA: hda - fix mic issues on Acer Aspire E-572
neigh_priv_len is defined as u8. With all debug enabled struct
ipoib_neigh has 200 bytes. The largest part is sk_buff_head with 96
bytes and here the spinlock with 72 bytes.
The size value still fits in this u8 leaving some room for more.
On -RT struct ipoib_neigh put on weight and has 392 bytes. The main
reason is sk_buff_head with 288 and the fatty here is spinlock with 192
bytes. This does no longer fit into into neigh_priv_len and gcc
complains.
This patch changes neigh_priv_len from being 8bit to 16bit. Since the
following element (dev_id) is 16bit followed by a spinlock which is
aligned, the struct remains with a total size of 3200 (allmodconfig) /
2048 (with as much debug off as possible) bytes on x86-64.
On x86-32 the struct is 1856 (allmodconfig) / 1216 (with as much debug
off as possible) bytes long. The numbers were gained with and without
the patch to prove that this change does not increase the size of the
struct.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"A dvb core deadlock fix, a couple videobuf2 fixes an a series of media
driver fixes"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (30 commits)
[media] videobuf2-dma-sg: fix possible memory leak
[media] vb2: regression fix: always set length field.
[media] mt9p031: Include linux/of.h header
[media] rtl2830: add parent for I2C adapter
[media] media: marvell-ccic: use devm to release clk
[media] ths7303: Declare as static a private function
[media] em28xx-video: Swap release order to avoid lock nesting
[media] usbtv: Add support for PAL video source
[media] media_tree: Fix spelling errors
[media] videobuf2: Add support for file access mode flags for DMABUF exporting
[media] radio-shark2: Mark shark_resume_leds() inline to kill compiler warning
[media] radio-shark: Mark shark_resume_leds() inline to kill compiler warning
[media] af9035: unlock on error in af9035_i2c_master_xfer()
[media] af9033: fix broken I2C
[media] v4l: omap3isp: Don't check for missing get_fmt op on remote subdev
[media] af9035: fix broken I2C and USB I/O
[media] wm8775: fix broken audio routing
[media] marvell-ccic: drop resource free in driver remove
[media] tef6862/radio-tea5764: actually assign clamp result
[media] cx231xx: use after free on error path in probe
Whilst architectures may be able to do better than this (which they can,
by simply defining their own macro), this is a generic stab at a
zero_bytemask implementation for the asm-generic, big-endian
word-at-a-time implementation.
On arm64, a clz instruction is used to implement the fls efficiently.
When explicitly hashing the end of a string with the word-at-a-time
interface, we have to be careful which end of the word we pick up.
On big-endian CPUs, the upper-bits will contain the data we're after, so
ensure we generate our masks accordingly (and avoid hashing whatever
random junk may have been sitting after the string).
This patch adds a new dcache helper, bytemask_from_count, which creates
a mask appropriate for the CPU endianness.
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
Pull misc keyrings fixes from David Howells:
"These break down into five sets:
- A patch to error handling in the big_key type for huge payloads.
If the payload is larger than the "low limit" and the backing store
allocation fails, then big_key_instantiate() doesn't clear the
payload pointers in the key, assuming them to have been previously
cleared - but only one of them is.
Unfortunately, the garbage collector still calls big_key_destroy()
when sees one of the pointers with a weird value in it (and not
NULL) which it then tries to clean up.
- Three patches to fix the keyring type:
* A patch to fix the hash function to correctly divide keyrings off
from keys in the topology of the tree inside the associative
array. This is only a problem if searching through nested
keyrings - and only if the hash function incorrectly puts the a
keyring outside of the 0 branch of the root node.
* A patch to fix keyrings' use of the associative array. The
__key_link_begin() function initially passes a NULL key pointer
to assoc_array_insert() on the basis that it's holding a place in
the tree whilst it does more allocation and stuff.
This is only a problem when a node contains 16 keys that match at
that level and we want to add an also matching 17th. This should
easily be manufactured with a keyring full of keyrings (without
chucking any other sort of key into the mix) - except for (a)
above which makes it on average adding the 65th keyring.
* A patch to fix searching down through nested keyrings, where any
keyring in the set has more than 16 keyrings and none of the
first keyrings we look through has a match (before the tree
iteration needs to step to a more distal node).
Test in keyutils test suite:
http://git.kernel.org/cgit/linux/kernel/git/dhowells/keyutils.git/commit/?id=8b4ae963ed92523aea18dfbb8cab3f4979e13bd1
- A patch to fix the big_key type's use of a shmem file as its
backing store causing audit messages and LSM check failures. This
is done by setting S_PRIVATE on the file to avoid LSM checks on the
file (access to the shmem file goes through the keyctl() interface
and so is gated by the LSM that way).
This isn't normally a problem if a key is used by the context that
generated it - and it's currently only used by libkrb5.
http://git.kernel.org/cgit/linux/kernel/git/dhowells/keyutils.git/commit/?id=d9a53cbab42c293962f2f78f7190253fc73bd32e
- A patch to add a generated file to .gitignore.
- A patch to fix the alignment of the system certificate data such
that it it works on s390. As I understand it, on the S390 arch,
symbols must be 2-byte aligned because loading the address discards
the least-significant bit"
* tag 'keys-devel-20131210' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs:
KEYS: correct alignment of system_certificate_list content in assembly file
Ignore generated file kernel/x509_certificate_list
security: shmem: implement kernel private shmem inodes
KEYS: Fix searching of nested keyrings
KEYS: Fix multiple key add into associative array
KEYS: Fix the keyring hash function
KEYS: Pre-clear struct key on allocation
Renesas R-Car development boards use KSZ8041RNLI PHY which for some reason has
ID of 0x00221537 that is not documented for KSZ8041-family PHYs and does not
match the documented ID of 0x0022151x (where 'x' is the revision). We have
to add the new #define PHY_ID_* and new ksphy_driver[] entry, almost the same
as KSZ8041 one, differing only in the 'phy_id' and 'name' fields.
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Christian suffers from a bad BIOS that wrecks his i5's TSC sync. This
results in him occasionally seeing time going backwards - which
crashes the scheduler ...
Most of our time accounting can actually handle that except the most
common one; the tick time update of sched_fair.
There is a further problem with that code; previously we assumed that
because we get a tick every TICK_NSEC our time delta could never
exceed 32bits and math was simpler.
However, ever since Frederic managed to get NO_HZ_FULL merged; this is
no longer the case since now a task can run for a long time indeed
without getting a tick. It only takes about ~4.2 seconds to overflow
our u32 in nanoseconds.
This means we not only need to better deal with time going backwards;
but also means we need to be able to deal with large deltas.
This patch reworks the entire code and uses mul_u64_u32_shr() as
proposed by Andy a long while ago.
We express our virtual time scale factor in a u32 multiplier and shift
right and the 32bit mul_u64_u32_shr() implementation reduces to a
single 32x32->64 multiply if the time delta is still short (common
case).
For 64bit a 64x64->128 multiply can be used if ARCH_SUPPORTS_INT128.
Reported-and-Tested-by: Christian Engelmayer <cengelma@gmx.at>
Cc: fweisbec@gmail.com
Cc: Paul Turner <pjt@google.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Link: http://lkml.kernel.org/r/20131118172706.GI3866@twins.programming.kicks-ass.net
Introduce mul_u64_u32_shr() as proposed by Andy a while back; it
allows using 64x64->128 muls on 64bit archs and recent GCC
which defines __SIZEOF_INT128__ and __int128.
(This new method will be used by the scheduler.)
Link: http://lkml.kernel.org/n/tip-hxjoeuzmrcaumR0uZwjpe2pv@git.kernel.org
While hunting a preemption issue with Alexander, Ben noticed that the
currently generic PREEMPT_NEED_RESCHED stuff is horribly broken for
load-store architectures.
We currently rely on the IPI to fold TIF_NEED_RESCHED into
PREEMPT_NEED_RESCHED, but when this IPI lands while we already have
a load for the preempt-count but before the store, the store will erase
the PREEMPT_NEED_RESCHED change.
The current preempt-count only works on load-store archs because
interrupts are assumed to be completely balanced wrt their preempt_count
fiddling; the previous preempt_count load will match the preempt_count
state after the interrupt and therefore nothing gets lost.
This patch removes the PREEMPT_NEED_RESCHED usage from generic code and
pushes it into x86 arch code; the generic code goes back to relying on
TIF_NEED_RESCHED.
Boot tested on x86_64 and compile tested on ppc64.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Reported-and-Tested-by: Alexander Graf <agraf@suse.de>
Link: http://lkml.kernel.org/r/20131128132641.GP10022@twins.programming.kicks-ass.net
Currently, sctp associations latch a sockets autoclose value to an association
at association init time, subject to capping constraints from the max_autoclose
sysctl value. This leads to an odd situation where an application may set a
socket level autoclose timeout, but sliently sctp will limit the autoclose
timeout to something less than that.
Fix this by modifying the autoclose setsockopt function to check the limit, cap
it and warn the user via syslog that the timeout is capped. This will allow
getsockopt to return valid autoclose timeout values that reflect what subsequent
associations actually use.
While were at it, also elimintate the assoc->autoclose variable, it duplicates
whats in the timeout array, which leads to multiple sources for the same
information, that may differ (as the former isn't subject to any capping). This
gives us the timeout information in a canonical place and saves some space in
the association structure as well.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
CC: Wang Weidong <wangweidong1@huawei.com>
CC: David Miller <davem@davemloft.net>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: netdev@vger.kernel.org
unix_dgram_recvmsg() will hold the readlock of the socket until recv
is complete.
In the same time, we may try to setsockopt(SO_PEEK_OFF) which will hang until
unix_dgram_recvmsg() will complete (which can take a while) without allowing
us to break out of it, triggering a hung task spew.
Instead, allow set_peek_off to fail, this way userspace will not hang.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
When compiling with icc, <linux/compiler-gcc.h> ends up included
because the icc environment defines __GNUC__. Thus, we neither need
nor want to have this macro defined in both compiler-gcc.h and
compiler-intel.h, and the fact that they are inconsistent just makes
the compiler spew warnings.
Reported-by: Sunil K. Pandey <sunil.k.pandey@intel.com>
Cc: Kevin B. Smith <kevin.b.smith@intel.com>
Link: http://lkml.kernel.org/n/tip-0mbwou1zt7pafij09b897lg3@git.kernel.org
snd_pcm_uframes_t is defined as unsigned long so it would take
different sizes depending on 32 or 64bit architectures. As we don't
want this ABI incompatibility, and there is no real 64bit user yet,
let's make it the fixed size with __u32.
Also bump the protocol version number to 0.1.2.
Acked-by: Vinod Koul <vinod.koul@intel.com>
When running a 32bit kernel the hda_intel driver is still reporting
a 64bit dma_mask if the HW supports it.
From sound/pci/hda/hda_intel.c:
/* allow 64bit DMA address if supported by H/W */
if ((gcap & ICH6_GCAP_64OK) && !pci_set_dma_mask(pci, DMA_BIT_MASK(64)))
pci_set_consistent_dma_mask(pci, DMA_BIT_MASK(64));
else {
pci_set_dma_mask(pci, DMA_BIT_MASK(32));
pci_set_consistent_dma_mask(pci, DMA_BIT_MASK(32));
which means when there is a call to dma_alloc_coherent from
snd_malloc_dev_pages a machine address bigger than 32bit can be returned.
This can be true in particular if running the 32bit kernel as a pv dom0
under the Xen Hypervisor or PAE on bare metal.
The problem is that when calling setup_bdle to program the BLE the
dma_addr_t returned from the dma_alloc_coherent is wrongly truncated
from snd_sgbuf_get_addr if running a 32bit kernel:
static inline dma_addr_t snd_sgbuf_get_addr(struct snd_dma_buffer *dmab,
size_t offset)
struct snd_sg_buf *sgbuf = dmab->private_data;
dma_addr_t addr = sgbuf->table[offset >> PAGE_SHIFT].addr;
addr &= PAGE_MASK;
return addr + offset % PAGE_SIZE;
where PAGE_MASK in a 32bit kernel is zeroing the upper 32bit af addr.
Without this patch the HW will fetch the 32bit truncated address,
which is not the one obtained from dma_alloc_coherent and will result
to a non working audio but can corrupt host memory at a random location.
The current patch apply to v3.13-rc3-74-g6c843f5
Signed-off-by: Stefano Panella <stefano.panella@citrix.com>
Reviewed-by: Frediano Ziglio <frediano.ziglio@citrix.com>
Pull power management fixup from Rafael Wysocki:
"This reverts two cpufreq commits that fixed issues for some people,
but broke things for others, so revert them and we'll need to fix the
original problems differently"
* tag 'pm-3.13-rc3-fixup' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
Revert "cpufreq: fix garbage kobjects on errors during suspend/resume"
Revert "cpufreq: suspend governors on system suspend/hibernate"
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"An update to ALPS to support devices on Dell XT2 (hopefully working
better this time around and although it is largish it should not
affect any other ALPS devices) and a tiny update to Elantech driver to
support newer devices as well.
Also a coupe of new input event codes have been defined"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: ALPS - add support for DualPoint device on Dell XT2 model
Input: elantech - add support for newer (August 2013) devices
Input: add SW_MUTE_DEVICE switch definition
Input: usbtouchscreen - separate report and transmit buffer size handling
Input: sur40 - suppress false uninitialized variable warning
Input: add key code for ambient light sensor button
Input: keyboard - "keycode & KEY_MAX" changes some keycode values
Pull crypto fix from Herbert Xu:
"Unfortunately the last push that fixed a crash in the crypto
scatterwalk code introduced a new crash when SG debugging is enabled.
This fixes that"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: scatterwalk - Use sg_chain_ptr on chain entries
Currently it is not possible for userspace to map a DMABUF exported buffer
with write permissions. This patch allows to also pass O_RDONLY/O_RDWR when
exporting the buffer, so that userspace may map it with write permissions.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Now that scatterwalk_sg_chain sets the chain pointer bit the sg_page
call in scatterwalk_sg_next hits a BUG_ON when CONFIG_DEBUG_SG is
enabled. Use sg_chain_ptr instead of sg_page on a chain entry.
Cc: stable@vger.kernel.org
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Userspace uses this to workaround overcommit issues
by flushing the command stream early.
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver fixes from Greg KH:
"Here are some bugfixes for the staging and IIO drivers for 3.13-rc3.
The resolve the vm memory issue in the tidspbridge driver, fix a
much-reported build failure in an ARM driver, and some other IIO
bugfixes that have been reported"
* tag 'staging-3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
Staging: TIDSPBRIDGE: Use vm_iomap_memory for mmap-ing instead of remap_pfn_range
Fix build failure for gp2ap020a00f.c
iio: hid-sensors: Fix power and report state
HID: hid-sensor-hub: Add logical min and max
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg KH:
"Nothing huge, just a few small bugfixes for problems reported, and a
device id update"
* tag 'char-misc-3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
mei: add 9 series PCH mei device ids
drivers/char/i8k.c: add Dell XPLS L421X
MAINTAINERS: add HSI subsystem
misc: mic: Suppress memory space sparse warnings
misc: mic: Fix endianness issues.
misc: mic: Fix user space namespace pollution from mic_common.h.
misc: mic: Bug fix for sysfs poll usage.
misc: mic: Minor bug fix in 'retry' loops.
misc: mic: Change mic_notify(...) to return true.
extcon: remove freed groups caused the panic or warning in unregister flow
extcon: arizona: Get pdata from arizona structure not device
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a bunch of USB fixes for 3.13-rc3.
Nothing major, but we seem to have an argument about a XHCI fix, so
I'm not including a revert that Sarah requested, because that breaks a
USB network driver, and I can't revert the USB network driver fix
without reintroducing other bugs that it fixed. So as it is,
everything should now be working. Worse case, I can revert the XHCI
fix before 3.13-final is out, but it seems to work well here with my
testing, so all should be good.
Other than that, some driver updates based on reports"
* tag 'usb-3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (40 commits)
usb: hub: Use correct reset for wedged USB3 devices that are NOTATTACHED
usb: ohci-pxa27x: include linux/dma-mapping.h
USB: cdc-acm: Added support for the Lenovo RD02-D400 USB Modem
usb: tools: fix a regression issue that gcc can't link to pthread
USB: switch maintainership of chipidea to Peter
USB: pl2303: fixed handling of CS5 setting
USB: ftdi_sio: fixed handling of unsupported CSIZE setting
USB: mos7840: correct handling of CS5 setting
USB: spcp8x5: correct handling of CS5 setting
usb: wusbcore: fix deadlock in wusbhc_gtk_rekey
usb: wusbcore: do device lookup while holding the hc mutex
usb: wusbcore: send keepalives to unauthenticated devices
USB: option: support new huawei devices
USB: serial: option: blacklist interface 1 for Huawei E173s-6
usb: xhci: Link TRB must not occur within a USB payload burst
usb: gadget: f_mass_storage: call try_to_freeze only when its safe
usb: gadget: tcm_usb_gadget: mark bot_cleanup_old_alt static
usb: gadget: ffs: fix sparse warning
usb: gadget: zero: module parameters can be static
usb: gadget: storage: fix sparse warning
Commit 5a87182aa21d (cpufreq: suspend governors on system
suspend/hibernate) causes hibernation problems to happen on
Bjørn Mork's and Paul Bolle's systems, so revert it.
Fixes: 5a87182aa21d (cpufreq: suspend governors on system suspend/hibernate)
Reported-by: Bjørn Mork <bjorn@mork.no>
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Add a flag to tell the PCI subsystem that kernel is shutting down in
preparation to kexec a kernel. Add code in PCI subsystem to use this flag
to clear Bus Master bit on PCI devices only in case of kexec reboot.
This fixes a power-off problem on Acer Aspire V5-573G and likely other
machines and avoids any other issues caused by clearing Bus Master bit on
PCI devices in normal shutdown path. The problem was introduced by
b566a22c2332 ("PCI: disable Bus Master on PCI device shutdown").
This patch is based on discussion at
http://marc.info/?l=linux-pci&m=138425645204355&w=2
Link: https://bugzilla.kernel.org/show_bug.cgi?id=63861
Reported-by: Chang Liu <cl91tp@gmail.com>
Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: stable@vger.kernel.org # v3.5+
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is a set of nine fixes (and one author update).
The libsas one should fix discovery in eSATA devices, the WRITE_SAME
one is the largest, but it should fix a lot of problems we've been
getting with the emulated RAID devices (they've been effectively lying
about support and then firmware has been choking on the commands).
The rest are various crash, hang or warn driver fixes"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
[SCSI] bfa: Fix crash when symb name set for offline vport
[SCSI] enclosure: fix WARN_ON in dual path device removing
[SCSI] pm80xx: Tasklets synchronization fix.
[SCSI] pm80xx: Resetting the phy state.
[SCSI] pm80xx: Fix for direct attached device.
[SCSI] pm80xx: Module author addition
[SCSI] hpsa: return 0 from driver probe function on success, not 1
[SCSI] hpsa: do not discard scsi status on aborted commands
[SCSI] Disable WRITE SAME for RAID and virtual host adapter drivers
[SCSI] libsas: fix usage of ata_tf_to_fis
Pull power management fixes from Rafael Wysocki:
- cpufreq regression fix from Bjørn Mork restoring the pre-3.12
behavior of the framework during system suspend/hibernation to avoid
garbage sysfs files from being left behind in case of a suspend error
- PNP regression fix to restore the correct states of devices after
resume from hibernation broken in 3.12. From Dmitry Torokhov.
- cpuidle fix to prevent cpuidle device unregistration from crashing
due to a NULL pointer dereference if cpuidle has been disabled from
the kernel command line. From Konrad Rzeszutek Wilk.
- intel_idle fix for the C6 state definition on Intel Avoton/Rangeley
processors from Arne Bockholdt.
- Power capping framework fix to make the energy_uj sysfs attribute
work in accordance with the documentation. From Srinivas Pandruvada.
- epoll fix to make it ignore the EPOLLWAKEUP flag if the kernel has
been compiled with CONFIG_PM_SLEEP unset (in which case that flag
should not have any effect). From Amit Pundir.
- cpufreq fix to prevent governor sysfs files from being lost over
system suspend/resume in some (arguably unusual) situations. From
Viresh Kumar.
* tag 'pm-3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PowerCap: Fix mode for energy counter
PNP: fix restoring devices after hibernation
cpuidle: Check for dev before deregistering it.
epoll: drop EPOLLWAKEUP if PM_SLEEP is disabled
intel_idle: Fixed C6 state on Avoton/Rangeley processors
kill memcg_tcp_enter_memory_pressure. The only function of
memcg_tcp_enter_memory_pressure was to reduce deal with the
unnecessary abstraction that was tcp_memcontrol. Now that struct
tcp_memcontrol is gone remove this unnecessary function, the
unnecessary function pointer, and modify sk_enter_memory_pressure to
set this field directly, just as sk_leave_memory_pressure cleas this
field directly.
This fixes a small bug I intruduced when killing struct tcp_memcontrol
that caused memcg_tcp_enter_memory_pressure to never be called and
thus failed to ever set cg_proto->memory_pressure.
Remove the cg_proto enter_memory_pressure function as it now serves
no useful purpose.
Don't test cg_proto->memory_presser in sk_leave_memory_pressure before
clearing it. The test was originally there to ensure that the pointer
was non-NULL. Now that cg_proto is not a pointer the pointer does not
matter.
The code to detect fragments in checksum_setup() was missing for IPv4 and
too eager for IPv6. (It transpires that Windows seems to send IPv6 packets
with a fragment header even if they are not a fragment - i.e. offset is zero,
and M bit is not set).
This patch also incorporates a fix to callers of maybe_pull_tail() where
skb->network_header was being erroneously added to the length argument.
Signed-off-by: Paul Durrant <paul.durrant@citrix.com>
Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com>
Cc: Wei Liu <wei.liu2@citrix.com>
Cc: David Vrabel <david.vrabel@citrix.com>
cc: David Miller <davem@davemloft.net>
Acked-by: Wei Liu <wei.liu2@citrix.com>
