Now that sys_sysctl is a compatiblity wrapper around /proc/sys
all sysctl strategy routines, and all ctl_name and strategy
entries in the sysctl tables are unused, and can be
revmoed.
In addition neigh_sysctl_register has been modified to no longer
take a strategy argument and it's callers have been modified not
to pass one.
Cc: "David Miller" <davem@davemloft.net>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: netdev@vger.kernel.org
The ctl_name and strategy fields are unused, now that sys_sysctl
is a compatibility wrapper around /proc/sys. No longer looking
at them in the generic code is effectively what we are doing
now and provides the guarantee that during further cleanups
we can just remove references to those fields and everything
will work ok.
Now that all of the architectures use compat_sys_sysctl do_sysctl
can become static.
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM: Remove some debug messages producing too much noise
PM: Fix warning on suspend errors
PM / Hibernate: Add newline to load_image() fail path
PM / Hibernate: Fix error handling in save_image()
PM / Hibernate: Fix blkdev refleaks
PM / yenta: Split resume into early and late parts (rev. 4)
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits)
mac80211: check interface is down before type change
cfg80211: fix NULL ptr deref
libertas if_usb: Fix crash on 64-bit machines
mac80211: fix reason code output endianness
mac80211: fix addba timer
ath9k: fix misplaced semicolon on rate control
b43: Fix DMA TX bounce buffer copying
mac80211: fix BSS leak
rt73usb.c : more ids
ipw2200: fix oops on missing firmware
gre: Fix dev_addr clobbering for gretap
sky2: set carrier off in probe
net: fix sk_forward_alloc corruption
pcnet_cs: add cis of PreMax PE-200 ethernet pcmcia card
r8169: Fix card drop incoming VLAN tagged MTU byte large jumbo frames
ibmtr: possible Read buffer overflow?
net: Fix RPF to work with policy routing
net: fix kmemcheck annotations
e1000e: rework disable K1 at 1000Mbps for 82577/82578
e1000e: config PHY via software after resets
Commit 0c570cdeb8fdfcb354a3e9cd81bfc6a09c19de0c
(PM / yenta: Fix cardbus suspend/resume regression) caused resume to
fail on systems with two CardBus bridges. While the exact nature
of the failure is not known at the moment, it can be worked around by
splitting the yenta resume into an early part, executed during the
early phase of resume, that will only resume the socket and power it
up if there was a card in it during suspend, and a late part,
executed during "regular" resume, that will carry out all of the
remaining yenta resume operations.
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=14334, which is a
listed regression from 2.6.31.
Acked-by: Dominik Brodowski <linux@dominikbrodowski.net>
Reported-by: Stephen J. Gowdy <gowdy@cern.ch>
Tested-by: Jose Marino <braket@hotmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9p: fix readdir corner cases
9p: fix readlink
9p: fix a small bug in readdir for long directories
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf tools: Remove -Wcast-align
perf tools: Fix compatibility with libelf 0.8 and autodetect
perf events: Don't generate events for the idle task when exclude_idle is set
perf events: Fix swevent hrtimer sampling by keeping track of remaining time when enabling/disabling swevent hrtimers
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing: Remove cpu arg from the rb_time_stamp() function
tracing: Fix comment typo and documentation example
tracing: Fix trace_seq_printf() return value
tracing: Update *ppos instead of filp->f_pos
The patch below also addresses a couple of other corner cases in readdir
seen with a large (e.g. 64k) msize. I'm not sure what people think of
my co-opting of fid->aux here. I'd be happy to rework if there's a better
way.
When the size of the user supplied buffer passed to readdir is smaller
than the data returned in one go by the 9P read request, v9fs_dir_readdir()
currently discards extra data so that, on the next call, a 9P read
request will be issued with offset < previous offset + bytes returned,
which voilates the constraint described in paragraph 3 of read(5) description.
This patch preseves the leftover data in fid->aux for use in the next call.
Signed-off-by: Jim Garlick <garlick@llnl.gov>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
Platform drivers registered via platform_driver_probe() can be bound
to devices only once, upon registration, because discard their probe()
routines to save memory. Unbinding the driver through sysfs 'unbind'
leaves the device stranded and confuses users so let's not create
bind and unbind attributes for such drivers.
Cc: Éric Piel <eric.piel@tremplin-utc.net>
On UDP sockets, we must call skb_free_datagram() with socket locked,
or risk sk_forward_alloc corruption. This requirement is not respected
in SUNRPC.
Add a convenient helper, skb_free_datagram_locked() and use it in SUNRPC
Reported-by: Francis Moreau <francis.moro@gmail.com>
Policy routing is not looked up by mark on reverse path filtering.
This fixes it.
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
struct sk_buff kmemcheck annotations enlarged this structure by 8/16 bytes
Fix this by moving 'protocol' inside flags1 bitfield,
and queue_mapping inside flags2 bitfield.
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-param-fixes:
param: fix setting arrays of bool
param: fix NULL comparison on oom
param: fix lots of bugs with writing charp params from sysfs, by leaking mem.
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison-2.6.32' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6:
HWPOISON: fix invalid page count in printk output
HWPOISON: Allow schedule_on_each_cpu() from keventd
HWPOISON: fix/proc/meminfo alignment
HWPOISON: fix oops on ksm pages
HWPOISON: Fix page count leak in hwpoison late kill in do_swap_page
HWPOISON: return early on non-LRU pages
HWPOISON: Add brief hwpoison description to Documentation
HWPOISON: Clean up PR_MCE_KILL interface
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Move drop_futex_key_refs out of spinlock'ed region
rcu: Fix TREE_PREEMPT_RCU CPU_HOTPLUG bad-luck hang
rcu: Stopgap fix for synchronize_rcu_expedited() for TREE_PREEMPT_RCU
rcu: Prevent RCU IPI storms in presence of high call_rcu() load
futex: Check for NULL keys in match_futex
futex: Handle spurious wake up
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Do less agressive buddy clearing
sched: Disable SD_PREFER_LOCAL for MC/CPU domains
The IBM Saturn serial card has only one port. Without that fixup,
the kernel thinks it has two, which confuses userland setup and
admin tools as well.
[akpm@linux-foundation.org: fix pci-ids.h layout]
Acked-by: Alan Cox <alan@linux.intel.com>
Cc: Michael Reed <mreed10@us.ibm.com>
Cc: <stable@kernel.org>
pci_ids.h
Add support for ADDI-DATA GmbH PCI-Express communication cards:
APCIe-7300
APCIe-7420
APCIe-7500
APCIe-7800
Warning: 8250_pci.c depends on pci_ids.h. 8250_pci.c
Signed-off-by: Krauth Julien <Krauth.Julien@addi-data.com>
strstrip() can return a modified value of its input argument, when
removing elading whitesapce. So it is surely bug for this function's
return value to be ignored. The caller is probably going to use the
incorrect original pointer.
So mark it __must_check to prevent this frm happening (as it has before).
When CONFIG_CPU_FREQ is disabled, cpufreq_get() needs a stub. Used by kvm
(although it looks like a bit of the kvm code could be omitted when
CONFIG_CPU_FREQ is disabled).
arch/x86/built-in.o: In function `kvm_arch_init':
(.text+0x10de7): undefined reference to `cpufreq_get'
(Needed in linux-next's KVM tree, but it's correct in 2.6.32).
Tested-by: Eric Paris <eparis@redhat.com>
Cc: Jiri Slaby <jirislaby@gmail.com>
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
e180a6b7759a "param: fix charp parameters set via sysfs" fixed the case
where charp parameters written via sysfs were freed, leaving drivers
accessing random memory.
Unfortunately, storing a flag in the kparam struct was a bad idea: it's
rodata so setting it causes an oops on some archs. But that's not all:
1) module_param_array() on charp doesn't work reliably, since we use an
uninitialized temporary struct kernel_param.
2) there's a fundamental race if a module uses this parameter and then
it's changed: they will still access the old, freed, memory.
The simplest fix (ie. for 2.6.32) is to never free the memory. This
prevents all these problems, at cost of a memory leak. In practice, there
are only 18 places where a charp is writable via sysfs, and all are
root-only writable.
Reported-by: Takashi Iwai <tiwai@suse.de>
Cc: Sitsofe Wheeler <sitsofe@yahoo.com>
Cc: Christof Schmitt <christof.schmitt@de.ibm.com>
Cc: stable@kernel.org
The cpu argument is not used inside the rb_time_stamp() function.
Plus fix a typo.
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
LKML-Reference: <20091023233647.118547500@goodmis.org>
Make the hrtimer based events work for sysprof.
Whenever a swevent is scheduled out, the hrtimer is canceled.
When it is scheduled back in, the timer is restarted. This
happens every scheduler tick, which means the timer never
expired because it was getting repeatedly restarted over and
over with the same period.
To fix that, save the remaining time when disabling; when
reenabling, use that saved time as the period instead of the
user-specified sampling period.
Also, move the starting and stopping of the hrtimers to helper
functions instead of duplicating the code.
Signed-off-by: Søren Sandmann Pedersen <sandmann@redhat.com>
LKML-Reference: <ye8vdi7mluz.fsf@camel16.daimi.au.dk>
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
move virtrng_remove to .devexit.text
move virtballoon_remove to .devexit.text
virtio_blk: Revert serial number support
virtio: let header files include virtio_ids.h
virtio_blk: revert QUEUE_FLAG_VIRT addition
niu: VLAN_ETH_HLEN should be used to make sure that the whole MAC header was copied to the head buffer in the Vlan packets case
KS8851: Fix ks8851_set_rx_mode() for IFF_MULTICAST
KS8851: Fix MAC address write order
KS8851: Add soft reset at probe time
net: fix section mismatch in fec.c
net: Fix struct inet_timewait_sock bitfield annotation
tcp: Try to catch MSG_PEEK bug
net: Fix IP_MULTICAST_IF
bluetooth: static lock key fix
bluetooth: scheduling while atomic bug fix
tcp: fix TCP_DEFER_ACCEPT retrans calculation
tcp: reduce SYN-ACK retrans for TCP_DEFER_ACCEPT
tcp: accept socket after TCP_DEFER_ACCEPT period
Revert "tcp: fix tcp_defer_accept to consider the timeout"
AF_UNIX: Fix deadlock on connecting to shutdown socket
ethoc: clear only pending irqs
ethoc: inline regs access
vmxnet3: use dev_dbg, fix build for CONFIG_BLOCK=n
virtio_net: use dev_kfree_skb_any() in free_old_xmit_skbs()
be2net: fix support for PCI hot plug
This reverts "Add serial number support for virtio_blk, V4a".
Turns out that virtio_pci, lguest and s/390 all have an 8 bit limit
on virtio config space, so noone could ever use this.
This is coming back later in a cleaner form.
Cc: john cooper <john.cooper@redhat.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Rusty,
commit 3ca4f5ca73057a617f9444a91022d7127041970a
virtio: add virtio IDs file
moved all device IDs into a single file. While the change itself is
a very good one, it can break userspace applications. For example
if a userspace tool wanted to get the ID of virtio_net it used to
include virtio_net.h. This does no longer work, since virtio_net.h
does not include virtio_ids.h.
This patch moves all "#include <linux/virtio_ids.h>" from the C
files into the header files, making the header files compatible with
the old ones.
In addition, this patch exports virtio_ids.h to userspace.
CC: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit 9e337b0f (net: annotate inet_timewait_sock bitfields)
added 4/8 bytes in struct inet_timewait_sock.
Fix this by declaring tw_ipv6_offset in the 'flags' bitfield
The 14 bits hole is named tw_pad to make it cleary apparent.
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
sata_mv: Prevent PIO commands to be defered too long if traffic in progress.
pata_sc1200: Fix crash on boot
libata: fix internal command failure handling
libata: fix PMP initialization
sata_nv: make sure link is brough up online when skipping hardreset
ahci / atiixp / pci quirks: rename AMD SB900 into Hudson-2
ahci: Add the AHCI controller Linux Device ID for NVIDIA chipsets.
pata_via: extend the rev_max for VT6330
This patch renames the code name SB900 into Hudson-2
Signed-off-by: Shane Huang <shane.huang@amd.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (53 commits)
vmxnet: fix 2 build problems
net: add support for STMicroelectronics Ethernet controllers.
net: ks8851_mll uses mii interfaces
net/fec_mpc52xx: Fix kernel panic on FEC error
net: Fix OF platform drivers coldplug/hotplug when compiled as modules
TI DaVinci EMAC: Clear statistics register properly.
r8169: partial support and phy init for the 8168d
irda/sa1100_ir: check return value of startup hook
udp: Fix udp_poll() and ioctl()
WAN: fix Cisco HDLC handshaking.
3c574_cs: spin_lock the set_multicast_list function
net: Teach pegasus driver to ignore bluetoother adapters with clashing Vendor:Product IDs
netxen: fix pci bar mapping
ethoc: fix warning from 32bit build
libertas: fix build
net: VMware virtual Ethernet NIC driver: vmxnet3
net: Fix IXP 2000 network driver building.
libertas: fix build
mac80211: document ieee80211_rx() context requirement
For the short term, map synchronize_rcu_expedited() to
synchronize_rcu() for TREE_PREEMPT_RCU and to
synchronize_sched_expedited() for TREE_RCU.
Longer term, there needs to be a real expedited grace period for
TREE_PREEMPT_RCU, but candidate patches to date are considerably
more complex and intrusive.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
Cc: npiggin@suse.de
Cc: jens.axboe@oracle.com
LKML-Reference: <12555405592331-git-send-email->
It basically turns a delayed work into an immediate work, and then waits
for it to finish.
Yanmin reported that both tbench and hackbench were significantly
hurt by trying to keep tasks local on these domains, esp on small
cache machines.
So disable it in order to promote spreading outside of the cache
domains.
Reported-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com>
CC: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1255083400.8802.15.camel@laptop>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
cciss: Add cciss_allow_hpsa module parameter
cciss: Fix multiple calls to pci_release_regions
blk-settings: fix function parameter kernel-doc notation
writeback: kill space in debugfs item name
writeback: account IO throttling wait as iowait
elv_iosched_store(): fix strstrip() misuse
cfq-iosched: avoid probable slice overrun when idling
cfq-iosched: apply bool value where we return 0/1
cfq-iosched: fix think time allowed for seekers
cfq-iosched: fix the slice residual sign
cfq-iosched: abstract out the 'may this cfqq dispatch' logic
block: use proper BLK_RW_ASYNC in blk_queue_start_tag()
block: Seperate read and write statistics of in_flight requests v2
block: get rid of kblock_schedule_delayed_work()
cfq-iosched: fix possible problem with jiffies wraparound
cfq-iosched: fix issue with rq-rq merging and fifo list ordering
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes:
kbuild: revert "save ARCH & CROSS_COMPILE ..."
warn about use of uninstalled kernel headers
kbuild: mkcompile_h: trivial cleanups
kbuild: fix warning when domainname is not available
kbuild: Fix size_append issue for bzip2/lzma kernel
kbuild,scripts: use non-builtin echo for '-e'
kbuild: fix the binrpm-pkg target to work with KBUILD_OUTPUT set
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: Prevent AER driver from being loaded on non-root port PCIE devices
PCI: get larger bridge ranges when space is available
PCI: pci.c: fix kernel-doc notation
PCI quirk: TI XIO200a erroneously reports support for fast b2b transfers
PCI PM: Read device power state from register after updating it
PCI: remove pci_assign_resource_fixed()
PCI: PCIe portdrv: remove "-driver" from driver name
ieee80211_rx() must be called with softirqs disabled
since the networking stack requires this for netif_rx()
and some code in mac80211 can assume that it can not
be processing its own tasklet and this call at the same
time.
It may be possible to remove this requirement after a
careful audit of mac80211 and doing any needed locking
improvements in it along with disabling softirqs around
netif_rx(). An alternative might be to push all packet
processing to process context in mac80211, instead of
to the tasklet, and add other synchronisation.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Since commit a98b65a3 (net: annotate struct sock bitfield), we lost
8 bytes in struct sock on 64bit arches because of
kmemcheck_bitfield_end(flags) misplacement.
Fix this by putting together sk_shutdown, sk_no_check, sk_userlocks,
sk_protocol and sk_type in the 'flags' 32bits bitfield
User applications frequently hit problems when they try to use
the kernel headers directly, rather than the exported headers.
This adds an explicit warning for this case, and points to
a URL holding an explanation of why this is wrong and what
to do about it.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (21 commits)
[S390] dasd: fix race condition in resume code
[S390] Add EX_TABLE for addressing exception in usercopy functions.
[S390] 64-bit register support for 31-bit processes
[S390] hibernate: Use correct place for CPU address in lowcore
[S390] pm: ignore time spend in suspended state
[S390] zcrypt: Improve some comments
[S390] zcrypt: Fix sparse warning.
[S390] perf_counter: fix vdso detection
[S390] ftrace: drop nmi protection
[S390] compat: fix truncate system call wrapper
[S390] Provide arch specific mdelay implementation.
[S390] Fix enabled udelay for short delays.
[S390] cio: allow setting boxed devices offline
[S390] cio: make not operational handling consistent
[S390] cio: make disconnected handling consistent
[S390] Fix memory leak in /proc/cio_ignore
[S390] cio: channel path memory leak
[S390] module: fix memory leak in s390 module loader
[S390] Enable kmemleak on s390.
[S390] 3270 console build fix
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (32 commits)
USB: serial: no unnecessary GFP_ATOMIC in oti6858
USB: serial: fix race between unthrottle and completion handler in visor
USB: serial: fix assumption that throttle/unthrottle cannot sleep
USB: serial: fix race between unthrottle and completion handler in symbolserial
USB: serial: fix race between unthrottle and completion handler in opticon
USB: ehci: Fix isoc scheduling boundary checking.
USB: storage: When a device returns no sense data, call it a Hardware Error
USB: small fix in error case of suspend in generic usbserial code
USB: visor: fix trivial accounting bug in visor driver
USB: Fix throttling in generic usbserial driver
USB: cp210x: Add support for the DW700 UART
USB: ipaq: fix oops when device is plugged in
USB: isp1362: fix build warnings on 64-bit systems
USB: gadget: imx_udc: Use resource size
USB: storage: iRiver P7 UNUSUAL_DEV patch
USB: musb: make HAVE_CLK support optional
USB: xhci: Fix dropping endpoints from the xHC schedule.
USB: xhci: Don't wait for a disable slot cmd when HC dies.
USB: xhci: Handle canceled URBs when HC dies.
USB: xhci: Stop debugging polling loop when HC dies.
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (34 commits)
[SCSI] qla2xxx: Fix NULL ptr deref bug in fail path during queue create
[SCSI] st: fix possible memory use after free after MTSETBLK ioctl
[SCSI] be2iscsi: Moving to pci_pools v3
[SCSI] libiscsi: iscsi_session_setup to allow for private space
[SCSI] be2iscsi: add 10Gbps iSCSI - BladeEngine 2 driver
[SCSI] zfcp: Fix hang when offlining device with offline chpid
[SCSI] zfcp: Fix lockdep warning when offlining device with offline chpid
[SCSI] zfcp: Fix oops during shutdown of offline device
[SCSI] zfcp: Fix initial device and cfdc for delayed adapter allocation
[SCSI] zfcp: correctly initialize unchained requests
[SCSI] mpt2sas: Bump version 02.100.03.00
[SCSI] mpt2sas: Support dev remove when phy status is MPI2_EVENT_SAS_TOPO_PHYSTATUS_VACANT
[SCSI] mpt2sas: Timeout occurred within the HANDSHAKE logic while waiting on firmware to ACK.
[SCSI] mpt2sas: Call init_completion on a per request basis.
[SCSI] mpt2sas: Target Reset will be issued from Interrupt context.
[SCSI] mpt2sas: Added SCSIIO, Internal and high priority memory pools to support multiple TM
[SCSI] mpt2sas: Copyright change to 2009.
[SCSI] mpt2sas: Added mpi2_history.txt for MPI2 headers.
[SCSI] mpt2sas: Update driver to MPI2 REV K headers.
[SCSI] bfa: Brocade BFA FC SCSI driver
This patch (as1295) fixes a recently-added bug in the USB serial core.
If certain kinds of errors occur during probing, the core may call a
serial driver's release method without previously calling the attach
method. This causes some drivers (io_ti in particular) to perform an
invalid memory access.
The patch adds a new flag to keep track of whether or not attach has
been called.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Jean-Denis Girard <jd.girard@sysnux.pf>
CC: stable <stable@kernel.org>
Since the beginnings in aafe4dbed0bf6cbdb2e9f03e1d42f8a540d8541d
("asm-generic: add generic versions of common headers") the generic
version of <asm/hardirq.h> defined __softirq_pending as unsigned long.
Which is different from other architectures for no apparent good reason
and was causing the following warning:
kernel/time/tick-sched.c: In function 'tick_nohz_stop_sched_tick':
kernel/time/tick-sched.c:261: warning: format '%02x' expects type 'unsigned int', but argument 2 has type 'long unsigned int'
Reported and initial patch by Wu Zhangjin <wuzhangjin@gmail.com>.
[ Arnd points out that we really should make sure parisc and alpha are
ok with this, since they have also been converted to use the generic
hardirq.h file. But neither seems to use it, although parisc does
build a IRQSTAT_SIRQ_PEND #define into asm-offsets - but that also
appears unused.. - Linus ]
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: i8042 - print debug data when testing AUX IRQ delivery
Input: libps2 - fix dependancy on i8042
Input: fix rx51 board keymap
Input: ad7879 - pass up error codes from probe functions
Input: xpad - add BigBen Interactive XBOX 360 Controller
Input: rotary_encoder - fix relative axis support
Input: sparkspkr - move remove() functions to .devexit.text
Input: wistron_btns - add DMI entry for Medion WIM2030 laptop
