path: root/include
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem update from James Morris: "Just some minor updates across the subsystem" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: ima: eliminate passing d_name.name to process_measurement() TPM: Retry SaveState command in suspend path tpm/tpm_i2c_infineon: Add small comment about return value of __i2c_transfer tpm/tpm_i2c_infineon.c: Add OF attributes type and name to the of_device_id table entries tpm_i2c_stm_st33: Remove duplicate inclusion of header files tpm: Add support for new Infineon I2C TPM (SLB 9645 TT 1.2 I2C) char/tpm: Convert struct i2c_msg initialization to C99 format drivers/char/tpm/tpm_ppi: use strlcpy instead of strncpy tpm/tpm_i2c_stm_st33: formatting and white space changes Smack: include magic.h in smackfs.c selinux: make security_sb_clone_mnt_opts return an error on context mismatch seccomp: allow BPF_XOR based ALU instructions. Fix NULL pointer dereference in smack_inode_unlink() and smack_inode_rmdir() Smack: add support for modification of existing rules smack: SMACK_MAGIC to include/uapi/linux/magic.h Smack: add missing support for transmute bit in smack_str_from_perm() Smack: prevent revoke-subject from failing when unseen label is written to it tomoyo: use DEFINE_SRCU() to define tomoyo_ss tomoyo: use DEFINE_SRCU() to define tomoyo_ss
2013-04-30Merge tag 'pm+acpi-3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael J Wysocki: - ARM big.LITTLE cpufreq driver from Viresh Kumar. - exynos5440 cpufreq driver from Amit Daniel Kachhap. - cpufreq core cleanup and code consolidation from Viresh Kumar and Stratos Karafotis. - cpufreq scalability improvement from Nathan Zimmer. - AMD "frequency sensitivity feedback" powersave bias for the ondemand cpufreq governor from Jacob Shin. - cpuidle code consolidation and cleanups from Daniel Lezcano. - ARM OMAP cpuidle fixes from Santosh Shilimkar and Daniel Lezcano. - ACPICA fixes and other improvements from Bob Moore, Jung-uk Kim, Lv Zheng, Yinghai Lu, Tang Chen, Colin Ian King, and Linn Crosetto. - ACPI core updates related to hotplug from Toshi Kani, Paul Bolle, Yasuaki Ishimatsu, and Rafael J Wysocki. - Intel Lynxpoint LPSS (Low-Power Subsystem) support improvements from Rafael J Wysocki and Andy Shevchenko. * tag 'pm+acpi-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (192 commits) cpufreq: Revert incorrect commit 5800043 cpufreq: MAINTAINERS: Add co-maintainer cpuidle: add maintainer entry ACPI / thermal: do not always return THERMAL_TREND_RAISING for active trip points ARM: s3c64xx: cpuidle: use init/exit common routine cpufreq: pxa2xx: initialize variables ACPI: video: correct acpi_video_bus_add error processing SH: cpuidle: use init/exit common routine ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=y ACPI: Fix wrong parameter passed to memblock_reserve cpuidle: fix comment format pnp: use %*phC to dump small buffers isapnp: remove debug leftovers ARM: imx: cpuidle: use init/exit common routine ARM: davinci: cpuidle: use init/exit common routine ARM: kirkwood: cpuidle: use init/exit common routine ARM: calxeda: cpuidle: use init/exit common routine ARM: tegra: cpuidle: use init/exit common routine for tegra3 ARM: tegra: cpuidle: use init/exit common routine for tegra2 ARM: OMAP4: cpuidle: use init/exit common routine ...
2013-04-30Merge tag 'for-v3.10' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery updates from Anton Vorontsov: "Highlights: - OpenFirmware/DeviceTree support for the Power Supply core: the core now automatically populates supplied_from hierarchy from the device tree. With these patches chargers and batteries can now lookup each other without the board files support shim. Rhyland Klein at NVIDIA did the work - New ST-Ericsson ABX500 hwmon driver. The driver is heavily using the AB85xx core and depends on some recent changes to it, so that is why the driver comes through the battery tree. It has an appropriate ack from the hwmon maintainer (i.e. Guenter Roeck). Martin Persson at ST-Ericsson and Hongbo Zhang at Linaro authored the driver - Final bits to sync AB85xx ST-Ericsson changes into mainline. The changes touch mfd parts, but these were acked by the appropriate MFD maintainer (ie Samuel Ortiz). Lee Jones at Linaro did most of the work and lead the submission process. Minor changes, but still worth mentioning: - Battery temperature reporting fix for Nokia N900 phones - Versatile Express poweroff driver moved into drivers/power/reset/ - Tree-wide: use devm_kzalloc() where appropriate - Tree-wide: dev_pm_ops cleanups/fixes" * tag 'for-v3.10' of git://git.infradead.org/battery-2.6: (112 commits) pm2301-charger: Fix suspend/resume charger-manager: Use kmemdup instead of kzalloc + memcpy power_supply: Populate supplied_from hierarchy from the device tree power_supply: Add core support for supplied_from power_supply: Define Binding for power-supplies rx51_battery: Fix reporting temperature hwmon: Add ST-Ericsson ABX500 hwmon driver ab8500_bmdata: Export abx500_res_to_temp tables for hwmon ab8500_{bmdata,fg}: Add const attributes to some data arrays ab8500_bmdata: Eliminate CamelCase warning of some variables ab8500_btemp: Make ab8500_btemp_get* interfaces public goldfish_battery: Use resource_size() lp8788-charger: Use PAGE_SIZE for the sysfs read operation max8925_power: Use devm_kzalloc() da9030_battery: Use devm_kzalloc() da9052-battery: Use devm_kzalloc() ds2760_battery: Use devm_kzalloc() ds2780_battery: Use devm_kzalloc() gpio-charger: Use devm_kzalloc() isp1704_charger: Use devm_kzalloc() ...
2013-04-30Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull first round of SCSI updates from James "Jej B" Bottomley: "The patch set is mostly driver updates (qla4, qla2 [ISF support updates], lpfc, aacraid [dual firmware image support]) and a few bug fixes" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (47 commits) [SCSI] iscsi_tcp: support PF_MEMALLOC/__GFP_MEMALLOC [SCSI] libiscsi: avoid unnecessary multiple NULL assignments [SCSI] qla4xxx: Update driver version to 5.03.00-k8 [SCSI] qla4xxx: Added print statements to display AENs [SCSI] qla4xxx: Use correct value for max flash node entries [SCSI] qla4xxx: Restrict logout from boot target session using session id [SCSI] qla4xxx: Use correct flash ddb offset for ISP40XX [SCSI] isci: add CONFIG_PM_SLEEP to suspend/resume functions [SCSI] scsi_dh_alua: Add module parameter to allow failover to non preferred path without STPG [SCSI] qla2xxx: Update the driver version to 8.05.00.03-k. [SCSI] qla2xxx: Obtain loopback iteration count from bsg request. [SCSI] qla2xxx: Add clarifying printk to thermal access fail cases. [SCSI] qla2xxx: Remove duplicated include form qla_isr.c [SCSI] qla2xxx: Enhancements to support ISPFx00. [SCSI] qla4xxx: Update driver version to 5.03.00-k7 [SCSI] qla4xxx: Replace dev type macros with generic portal type macros [SCSI] scsi_transport_iscsi: Declare portal type string macros for generic use [SCSI] qla4xxx: Add flash node mgmt support [SCSI] libiscsi: export function iscsi_switch_str_param [SCSI] scsi_transport_iscsi: Add flash node mgmt support ...
2013-04-30Merge branch 'for-next-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target update from Nicholas Bellinger: "The highlights this round include: - Add fileio support for WRITE_SAME w/ UNMAP=1 discard (asias) - Add fileio support for UNMAP discard (asias) - Add tcm_vhost hotplug support to work with upstream QEMU vhost-scsi-pci code (asias + mst) - Check for aborted sequence in tcm_fc response path (mdr) - Add initial iscsit_transport support into iscsi-target code (nab) - Refactor iscsi-target RX PDU logic + export request PDU handling (nab) - Refactor iscsi-target TX queue logic + export response PDU creation (nab) - Add new iSCSI Extentions for RDMA (ISER) target driver (Or + nab) The biggest changes revolve around iscsi-target refactoring in order to support the iser-target driver. This includes the conversion of the iscsi-target data-path to use modern se_cmd->cmd_kref counting, and allowing transport independent aspects of RX/TX PDU request/response handling be shared across existing traditional iscsi-target code, and the new iser-target code. Thanks to Or Gerlitz + Mellanox for supporting the iser-target development effort!" * 'for-next-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (25 commits) iser-target: Add iSCSI Extensions for RDMA (iSER) target driver tcm_vhost: Enable VIRTIO_SCSI_F_HOTPLUG tcm_vhost: Add ioctl to get and set events missed flag tcm_vhost: Add hotplug/hotunplug support tcm_vhost: Refactor the lock nesting rule tcm_fc: Check for aborted sequence iscsi-target: Add iser network portal attribute iscsi-target: Refactor TX queue logic + export response PDU creation iscsi-target: Refactor RX PDU logic + export request PDU handling iscsi-target: Add per transport iscsi_cmd alloc/free iscsi-target: Add iser-target parameter keys + setup during login iscsi-target: Initial traditional TCP conversion to iscsit_transport iscsi-target: Add iscsit_transport API template target: Add export of target_get_sess_cmd symbol target: Change default sense key of NOT_READY target/file: Set is_nonrot attribute target: Add sbc_execute_unmap() helper target/iblock: Add iblock_do_unmap() helper target/file: Add fd_do_unmap() helper target/file: Add UNMAP emulation support ...
2013-04-30Merge tag 'nfs-for-3.10-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes and cleanups from Trond Myklebust: - NLM: stable fix for NFSv2/v3 blocking locks - NFSv4.x: stable fixes for the delegation recall error handling code - NFSv4.x: Security flavour negotiation fixes and cleanups by Chuck Lever - SUNRPC: A number of RPCSEC_GSS fixes and cleanups also from Chuck - NFSv4.x assorted state management and reboot recovery bugfixes - NFSv4.1: In cases where we have already looked up a file, and hold a valid filehandle, use the new open-by-filehandle operation instead of opening by name. - Allow the NFSv4.1 callback thread to freeze - NFSv4.x: ensure that file unlock waits for readahead to complete - NFSv4.1: ensure that the RPC layer doesn't override the NFS session table size negotiation by limiting the number of slots. - NFSv4.x: Fix SETATTR spec compatibility issues * tag 'nfs-for-3.10-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (67 commits) NFSv4: Warn once about servers that incorrectly apply open mode to setattr NFSv4: Servers should only check SETATTR stateid open mode on size change NFSv4: Don't recheck permissions on open in case of recovery cached open NFSv4.1: Don't do a delegated open for NFS4_OPEN_CLAIM_DELEG_CUR_FH modes NFSv4.1: Use the more efficient open_noattr call for open-by-filehandle NFS: Retry SETCLIENTID with AUTH_SYS instead of AUTH_NONE NFSv4: Ensure that we clear the NFS_OPEN_STATE flag when appropriate LOCKD: Ensure that nlmclnt_block resets block->b_status after a server reboot NFSv4: Ensure the LOCK call cannot use the delegation stateid NFSv4: Use the open stateid if the delegation has the wrong mode nfs: Send atime and mtime as a 64bit value NFSv4: Record the OPEN create mode used in the nfs4_opendata structure NFSv4.1: Set the RPC_CLNT_CREATE_INFINITE_SLOTS flag for NFSv4.1 transports SUNRPC: Allow rpc_create() to request that TCP slots be unlimited SUNRPC: Fix a livelock problem in the xprt->backlog queue NFSv4: Fix handling of revoked delegations by setattr NFSv4 release the sequence id in the return on close case nfs: remove unnecessary check for NULL inode->i_flock from nfs_delegation_claim_locks NFS: Ensure that NFS file unlock waits for readahead to complete NFS: Add functionality to allow waiting on all outstanding reads to complete ...
2013-04-30Merge tag 'metag-for-v3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull arch/metag update from James Hogan: - Various fixes for the interrupting perf counter handling in metag's perf backend. - Add OProfile support based on perf. - Sets up cache partitions for SMP so bootloader doesn't have to. - Patch from Paul Bolle to remove ARCH_POPULATES_NODE_MAP again (touches microblaze too). - Add TLS pointer regset to metag ptrace api. - Add exported metag DSP extended context handling header <asm/ech.h>. - Increase defconfig log buffer size to 128KiB. - Various fixes, typos, missing exports. * tag 'metag-for-v3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag: defconfigs: increase log buffer 8KiB => 128KiB metag: avoid unnecessary builtin dtb rebuilds metag: add exported <asm/ech.h> for extended context handling metag: export _metag_da_present and cpu_2_hwthread_id metag: ptrace: Implement NT_METAG_TLS memblock: Kill ARCH_POPULATES_NODE_MAP once more metag: cachepart: fix get_global_dcache_size() typo metag: cachepart: take into account small cache bits metag: smp: copy cache partition and enable GCOn metag: OProfile support metag: perf: prepare for use by oprofile metag: perf: don't reset TXTACTCYC metag: perf: use hard_processor_id() to get thread metag: perf: fix frequency sampling (dynamic period) metag: perf: add missing prev_count updates metag: perf: fixes for interrupting perf counters metag: perf: fix wrap handling in delta calculation metag: perf: fix core internal / perf channel mux
2013-04-30Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media update from Mauro Carvalho Chehab: - OF documentation and patches at core and drivers, to be used by for embedded media systems - some I2C drivers used on go7007 were rewritten/promoted from staging: sony-btf-mpx, tw2804, tw9903, tw9906, wis-ov7640, wis-uda1342 - add fimc-is driver (Exynos) - add a new radio driver: radio-si476x - add a two new tuners: r820t and tuner_it913x - split camera code on em28xx driver and add more models - the cypress firmware load is used outside dvb usb drivers. So, move it to a common directory to make easier to re-use it - siano media driver updated to work with sms2270 devices - several work done in order to promote go7007 and solo6x1x out of staging (still, there are some pending issues) - several API compliance fixes at v4l2 drivers that don't behave as expected - as usual, lots of driver fixes, improvements, cleanups and new device addition at the existing drivers. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (831 commits) [media] cx88: make core less verbose [media] em28xx: fix oops at em28xx_dvb_bus_ctrl() [media] s5c73m3: fix indentation of the help section in Kconfig [media] cx25821-alsa: get rid of a __must_check warning [media] cx25821-video: declare cx25821_vidioc_s_std as static [media] cx25821-video: remove maxw from cx25821_vidioc_try_fmt_vid_cap [media] r820t: Remove a warning for an unused value [media] dib0090: Fix a warning at dib0090_set_EFUSE [media] dib8000: fix a warning [media] dib8000: Fix sub-channel range [media] dib8000: store dtv_property_cache in a temp var [media] dib8000: warning fix: declare internal functions as static [media] r820t: quiet gcc warning on n_ring [media] r820t: memory leak in release() [media] r820t: precendence bug in r820t_xtal_check() [media] videodev2.h: Remove the unused old V4L1 buffer types [media] anysee: Grammar s/report the/report to/ [media] anysee: Initialize ret = 0 in anysee_frontend_attach() [media] media: videobuf2: fix the length check for mmap [media] em28xx: save isoc endpoint number for DVB only if endpoint has alt settings with xMaxPacketSize != 0 ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: - hid driver transport cleanup, finalizing the long-desired decoupling of core from transport layers, by Benjamin Tissoires and Henrik Rydberg - support for hybrid finger/pen multitouch HID devices, by Benjamin Tissoires - fix for long-standing issue in Logitech unifying driver sometimes not inializing properly due to device specifics, by Andrew de los Reyes - Wii remote driver updates to support 2nd generation of devices, by David Herrmann - support for Apple IR remote - roccat driver now supports new devices (Roccat Kone Pure, IskuFX), by Stefan Achatz - debugfs locking fixes in hid debug interface, by Jiri Kosina * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (43 commits) HID: protect hid_debug_list HID: debug: break out hid_dump_report() into hid-debug HID: Add PID for Japanese version of NE4K keyboard HID: hid-lg4ff add support for new version of DFGT wheel HID: icade: u16 which never < 0 HID: clarify Magic Mouse Kconfig description HID: appleir: add support for Apple ir devices HID: roccat: added media key support for Kone HID: hid-lenovo-tpkbd: remove doubled hid_get_drvdata HID: i2c-hid: fix length for set/get report in i2c hid HID: wiimote: parse reduced status reports HID: wiimote: add 2nd generation Wii Remote IDs HID: wiimote: use unique battery names HID: hidraw: warn if userspace headers are outdated HID: multitouch: force BTN_STYLUS for pen devices HID: multitouch: append " Pen" to the name of the stylus input HID: multitouch: add handling for pen in dual-sensors device HID: multitouch: change touch sensor detection in mt_input_configured() HID: multitouch: do not map usage from non used reports HID: multitouch: breaks out touch handling in specific functions ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-04-30Merge branch 'x86-ras-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 RAS changes from Ingo Molnar: - Add an Intel CMCI hotplug fix - Add AMD family 16h EDAC support - Make the AMD MCE banks code more flexible for virtual environments * 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: amd64_edac: Add Family 16h support x86/mce: Rework cmci_rediscover() to play well with CPU hotplug x86, MCE, AMD: Use MCG_CAP MSR to find out number of banks on AMD x86, MCE, AMD: Replace shared_bank array with is_shared_bank() helper
2013-04-30Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core timer updates from Ingo Molnar: "The main changes in this cycle's merge are: - Implement shadow timekeeper to shorten in kernel reader side blocking, by Thomas Gleixner. - Posix timers enhancements by Pavel Emelyanov: - allocate timer ID per process, so that exact timer ID allocations can be re-created be checkpoint/restore code. - debuggability and tooling (/proc/PID/timers, etc.) improvements. - suspend/resume enhancements by Feng Tang: on certain new Intel Atom processors (Penwell and Cloverview), there is a feature that the TSC won't stop in S3 state, so the TSC value won't be reset to 0 after resume. This can be taken advantage of by the generic via the CLOCK_SOURCE_SUSPEND_NONSTOP flag: instead of using the RTC to recover/approximate sleep time, the main (and precise) clocksource can be used. - Fix /proc/timer_list for 4096 CPUs by Nathan Zimmer: on so many CPUs the file goes beyond 4MB of size and thus the current simplistic seqfile approach fails. Convert /proc/timer_list to a proper seq_file with its own iterator. - Cleanups and refactorings of the core timekeeping code by John Stultz. - International Atomic Clock time is managed by the NTP code internally currently but not exposed externally. Separate the TAI code out and add CLOCK_TAI support and TAI support to the hrtimer and posix-timer code, by John Stultz. - Add deep idle support enhacement to the broadcast clockevents core timer code, by Daniel Lezcano: add an opt-in CLOCK_EVT_FEAT_DYNIRQ clockevents feature (which will be utilized by future clockevents driver updates), which allows the use of IRQ affinities to avoid spurious wakeups of idle CPUs - the right CPU with an expiring timer will be woken. - Add new ARM bcm281xx clocksource driver, by Christian Daudt - ... various other fixes and cleanups" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (52 commits) clockevents: Set dummy handler on CPU_DEAD shutdown timekeeping: Update tk->cycle_last in resume posix-timers: Remove unused variable clockevents: Switch into oneshot mode even if broadcast registered late timer_list: Convert timer list to be a proper seq_file timer_list: Split timer_list_show_tickdevices posix-timers: Show sigevent info in proc file posix-timers: Introduce /proc/PID/timers file posix timers: Allocate timer id per process (v2) timekeeping: Make sure to notify hrtimers when TAI offset changes hrtimer: Fix ktime_add_ns() overflow on 32bit architectures hrtimer: Add expiry time overflow check in hrtimer_interrupt timekeeping: Shorten seq_count region timekeeping: Implement a shadow timekeeper timekeeping: Delay update of clock->cycle_last timekeeping: Store cycle_last value in timekeeper struct as well ntp: Remove ntp_lock, using the timekeeping locks to protect ntp state timekeeping: Simplify tai updating from do_adjtimex timekeeping: Hold timekeepering locks in do_adjtimex and hardpps timekeeping: Move ADJ_SETOFFSET to top level do_adjtimex() ...
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
2013-04-30Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "The main changes in this development cycle were: - full dynticks preparatory work by Frederic Weisbecker - factor out the cpu time accounting code better, by Li Zefan - multi-CPU load balancer cleanups and improvements by Joonsoo Kim - various smaller fixes and cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits) sched: Fix init NOHZ_IDLE flag sched: Prevent to re-select dst-cpu in load_balance() sched: Rename load_balance_tmpmask to load_balance_mask sched: Move up affinity check to mitigate useless redoing overhead sched: Don't consider other cpus in our group in case of NEWLY_IDLE sched: Explicitly cpu_idle_type checking in rebalance_domains() sched: Change position of resched_cpu() in load_balance() sched: Fix wrong rq's runnable_avg update with rt tasks sched: Document task_struct::personality field sched/cpuacct/UML: Fix header file dependency bug on the UML build cgroup: Kill subsys.active flag sched/cpuacct: No need to check subsys active state sched/cpuacct: Initialize cpuacct subsystem earlier sched/cpuacct: Initialize root cpuacct earlier sched/cpuacct: Allocate per_cpu cpuusage for root cpuacct statically sched/cpuacct: Clean up cpuacct.h sched/cpuacct: Remove redundant NULL checks in cpuacct_acount_field() sched/cpuacct: Remove redundant NULL checks in cpuacct_charge() sched/cpuacct: Add cpuacct_acount_field() sched/cpuacct: Add cpuacct_init() ...
2013-04-30Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Features: - Add "uretprobes" - an optimization to uprobes, like kretprobes are an optimization to kprobes. "perf probe -x file sym%return" now works like kretprobes. By Oleg Nesterov. - Introduce per core aggregation in 'perf stat', from Stephane Eranian. - Add memory profiling via PEBS, from Stephane Eranian. - Event group view for 'annotate' in --stdio, --tui and --gtk, from Namhyung Kim. - Add support for AMD NB and L2I "uncore" counters, by Jacob Shin. - Add Ivy Bridge-EP uncore support, by Zheng Yan - IBM zEnterprise EC12 oprofile support patchlet from Robert Richter. - Add perf test entries for checking breakpoint overflow signal handler issues, from Jiri Olsa. - Add perf test entry for for checking number of EXIT events, from Namhyung Kim. - Add perf test entries for checking --cpu in record and stat, from Jiri Olsa. - Introduce perf stat --repeat forever, from Frederik Deweerdt. - Add --no-demangle to report/top, from Namhyung Kim. - PowerPC fixes plus a couple of cleanups/optimizations in uprobes and trace_uprobes, by Oleg Nesterov. Various fixes and refactorings: - Fix dependency of the python binding wrt libtraceevent, from Naohiro Aota. - Simplify some perf_evlist methods and to allow 'stat' to share code with 'record' and 'trace', by Arnaldo Carvalho de Melo. - Remove dead code in related to libtraceevent integration, from Namhyung Kim. - Revert "perf sched: Handle PERF_RECORD_EXIT events" to get 'perf sched lat' back working, by Arnaldo Carvalho de Melo - We don't use Newt anymore, just plain libslang, by Arnaldo Carvalho de Melo. - Kill a bunch of die() calls, from Namhyung Kim. - Fix build on non-glibc systems due to libio.h absence, from Cody P Schafer. - Remove some perf_session and tracing dead code, from David Ahern. - Honor parallel jobs, fix from Borislav Petkov - Introduce tools/lib/lk library, initially just removing duplication among tools/perf and tools/vm. from Borislav Petkov ... and many more I missed to list, see the shortlog and git log for more details." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (136 commits) perf/x86/intel/P4: Robistify P4 PMU types perf/x86/amd: Fix AMD NB and L2I "uncore" support perf/x86/amd: Remove old-style NB counter support from perf_event_amd.c perf/x86: Check all MSRs before passing hw check perf/x86/amd: Add support for AMD NB and L2I "uncore" counters perf/x86/intel: Add Ivy Bridge-EP uncore support perf/x86/intel: Fix SNB-EP CBO and PCU uncore PMU filter management perf/x86: Avoid kfree() in CPU_{STARTING,DYING} uprobes/perf: Avoid perf_trace_buf_prepare/submit if ->perf_events is empty uprobes/tracing: Don't pass addr=ip to perf_trace_buf_submit() uprobes/tracing: Change create_trace_uprobe() to support uretprobes uprobes/tracing: Make seq_printf() code uretprobe-friendly uprobes/tracing: Make register_uprobe_event() paths uretprobe-friendly uprobes/tracing: Make uprobe_{trace,perf}_print() uretprobe-friendly uprobes/tracing: Introduce is_ret_probe() and uretprobe_dispatcher() uprobes/tracing: Introduce uprobe_{trace,perf}_print() helpers uprobes/tracing: Generalize struct uprobe_trace_entry_head uprobes/tracing: Kill the pointless local_save_flags/preempt_count calls uprobes/tracing: Kill the pointless seq_print_ip_sym() call uprobes/tracing: Kill the pointless task_pt_regs() calls ...
2013-04-30Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "The main changes in this cycle are mostly related to preparatory work for the full-dynticks work: - Remove restrictions on no-CBs CPUs, make RCU_FAST_NO_HZ take advantage of numbered callbacks, do callback accelerations based on numbered callbacks. Posted to LKML at https://lkml.org/lkml/2013/3/18/960 - RCU documentation updates. Posted to LKML at https://lkml.org/lkml/2013/3/18/570 - Miscellaneous fixes. Posted to LKML at https://lkml.org/lkml/2013/3/18/594" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) rcu: Make rcu_accelerate_cbs() note need for future grace periods rcu: Abstract rcu_start_future_gp() from rcu_nocb_wait_gp() rcu: Rename n_nocb_gp_requests to need_future_gp rcu: Push lock release to rcu_start_gp()'s callers rcu: Repurpose no-CBs event tracing to future-GP events rcu: Rearrange locking in rcu_start_gp() rcu: Make RCU_FAST_NO_HZ take advantage of numbered callbacks rcu: Accelerate RCU callbacks at grace-period end rcu: Export RCU_FAST_NO_HZ parameters to sysfs rcu: Distinguish "rcuo" kthreads by RCU flavor rcu: Add event tracing for no-CBs CPUs' grace periods rcu: Add event tracing for no-CBs CPUs' callback registration rcu: Introduce proper blocking to no-CBs kthreads GP waits rcu: Provide compile-time control for no-CBs CPUs rcu: Tone down debugging during boot-up and shutdown. rcu: Add softirq-stall indications to stall-warning messages rcu: Documentation update rcu: Make bugginess of code sample more evident rcu: Fix hlist_bl_set_first_rcu() annotation rcu: Delete unused rcu_node "wakemask" field ...
2013-04-30Merge branch 'devel-for-v3.10' into v4l_for_linusMauro Carvalho Chehab
* patchwork: (831 commits) [media] cx88: make core less verbose [media] em28xx: fix oops at em28xx_dvb_bus_ctrl() [media] s5c73m3: fix indentation of the help section in Kconfig [media] cx25821-alsa: get rid of a __must_check warning [media] cx25821-video: declare cx25821_vidioc_s_std as static [media] cx25821-video: remove maxw from cx25821_vidioc_try_fmt_vid_cap [media] r820t: Remove a warning for an unused value [media] dib0090: Fix a warning at dib0090_set_EFUSE [media] dib8000: fix a warning [media] dib8000: Fix sub-channel range [media] dib8000: store dtv_property_cache in a temp var [media] dib8000: warning fix: declare internal functions as static [media] r820t: quiet gcc warning on n_ring [media] r820t: memory leak in release() [media] r820t: precendence bug in r820t_xtal_check() [media] videodev2.h: Remove the unused old V4L1 buffer types [media] anysee: Grammar s/report the/report to/ [media] anysee: Initialize ret = 0 in anysee_frontend_attach() [media] media: videobuf2: fix the length check for mmap [media] em28xx: save isoc endpoint number for DVB only if endpoint has alt settings with xMaxPacketSize != 0 ... Conflicts: drivers/media/pci/cx25821/cx25821-video.c drivers/media/platform/Kconfig
2013-04-30Merge branch 'for-3.10/mt-hybrid-finger-pen' into for-linusJiri Kosina
Conflicts: drivers/hid/hid-multitouch.c
2013-04-30Merge branches 'for-3.10/appleir', 'for-3.10/hid-debug', ↵Jiri Kosina
'for-3.10/hid-driver-transport-cleanups', 'for-3.10/i2c-hid' and 'for-3.10/logitech' into for-linus
2013-04-30HID: protect hid_debug_listJiri Kosina
Accesses to hid_device->hid_debug_list are not serialized properly, which could result in SMP concurrency issues when HID debugfs events are accessesed by multiple userspace processess. Serialize all the list operations by a mutex. Spotted by Al Viro. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-04-30HID: debug: break out hid_dump_report() into hid-debugBenjamin Tissoires
No semantic changes, but hid_dump_report should be in hid-debug.c, not in hid-core.c Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-04-29Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge second batch of fixes from Andrew Morton: - various misc bits - some printk updates - a new "SRAM" driver. - MAINTAINERS updates - the backlight driver queue - checkpatch updates - a few init/ changes - a huge number of drivers/rtc changes - fatfs updates - some lib/idr.c work - some renaming of the random driver interfaces * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (285 commits) net: rename random32 to prandom net/core: remove duplicate statements by do-while loop net/core: rename random32() to prandom_u32() net/netfilter: rename random32() to prandom_u32() net/sched: rename random32() to prandom_u32() net/sunrpc: rename random32() to prandom_u32() scsi: rename random32() to prandom_u32() lguest: rename random32() to prandom_u32() uwb: rename random32() to prandom_u32() video/uvesafb: rename random32() to prandom_u32() mmc: rename random32() to prandom_u32() drbd: rename random32() to prandom_u32() kernel/: rename random32() to prandom_u32() mm/: rename random32() to prandom_u32() lib/: rename random32() to prandom_u32() x86: rename random32() to prandom_u32() x86: pageattr-test: remove srandom32 call uuid: use prandom_bytes() raid6test: use prandom_bytes() sctp: convert sctp_assoc_set_id() to use idr_alloc_cyclic() ...
2013-04-29Merge branch 'for-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - Fixes and a lot of cleanups. Locking cleanup is finally complete. cgroup_mutex is no longer exposed to individual controlelrs which used to cause nasty deadlock issues. Li fixed and cleaned up quite a bit including long standing ones like racy cgroup_path(). - device cgroup now supports proper hierarchy thanks to Aristeu. - perf_event cgroup now supports proper hierarchy. - A new mount option "__DEVEL__sane_behavior" is added. As indicated by the name, this option is to be used for development only at this point and generates a warning message when used. Unfortunately, cgroup interface currently has too many brekages and inconsistencies to implement a consistent and unified hierarchy on top. The new flag is used to collect the behavior changes which are necessary to implement consistent unified hierarchy. It's likely that this flag won't be used verbatim when it becomes ready but will be enabled implicitly along with unified hierarchy. The option currently disables some of broken behaviors in cgroup core and also .use_hierarchy switch in memcg (will be routed through -mm), which can be used to make very unusual hierarchy where nesting is partially honored. It will also be used to implement hierarchy support for blk-throttle which would be impossible otherwise without introducing a full separate set of control knobs. This is essentially versioning of interface which isn't very nice but at this point I can't see any other options which would allow keeping the interface the same while moving towards hierarchy behavior which is at least somewhat sane. The planned unified hierarchy is likely to require some level of adaptation from userland anyway, so I think it'd be best to take the chance and update the interface such that it's supportable in the long term. Maintaining the existing interface does complicate cgroup core but shouldn't put too much strain on individual controllers and I think it'd be manageable for the foreseeable future. Maybe we'll be able to drop it in a decade. Fix up conflicts (including a semantic one adding a new #include to ppc that was uncovered by header the file changes) as per Tejun. * 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (45 commits) cpuset: fix compile warning when CONFIG_SMP=n cpuset: fix cpu hotplug vs rebuild_sched_domains() race cpuset: use rebuild_sched_domains() in cpuset_hotplug_workfn() cgroup: restore the call to eventfd->poll() cgroup: fix use-after-free when umounting cgroupfs cgroup: fix broken file xattrs devcg: remove parent_cgroup. memcg: force use_hierarchy if sane_behavior cgroup: remove cgrp->top_cgroup cgroup: introduce sane_behavior mount option move cgroupfs_root to include/linux/cgroup.h cgroup: convert cgroupfs_root flag bits to masks and add CGRP_ prefix cgroup: make cgroup_path() not print double slashes Revert "cgroup: remove bind() method from cgroup_subsys." perf: make perf_event cgroup hierarchical cgroup: implement cgroup_is_descendant() cgroup: make sure parent won't be destroyed before its children cgroup: remove bind() method from cgroup_subsys. devcg: remove broken_hierarchy tag cgroup: remove cgroup_lock_is_held() ...
2013-04-29Merge branch 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue updates from Tejun Heo: "A lot of activities on workqueue side this time. The changes achieve the followings. - WQ_UNBOUND workqueues - the workqueues which are per-cpu - are updated to be able to interface with multiple backend worker pools. This involved a lot of churning but the end result seems actually neater as unbound workqueues are now a lot closer to per-cpu ones. - The ability to interface with multiple backend worker pools are used to implement unbound workqueues with custom attributes. Currently the supported attributes are the nice level and CPU affinity. It may be expanded to include cgroup association in future. The attributes can be specified either by calling apply_workqueue_attrs() or through /sys/bus/workqueue/WQ_NAME/* if the workqueue in question is exported through sysfs. The backend worker pools are keyed by the actual attributes and shared by any workqueues which share the same attributes. When attributes of a workqueue are changed, the workqueue binds to the worker pool with the specified attributes while leaving the work items which are already executing in its previous worker pools alone. This allows converting custom worker pool implementations which want worker attribute tuning to use workqueues. The writeback pool is already converted in block tree and there are a couple others are likely to follow including btrfs io workers. - WQ_UNBOUND's ability to bind to multiple worker pools is also used to make it NUMA-aware. Because there's no association between work item issuer and the specific worker assigned to execute it, before this change, using unbound workqueue led to unnecessary cross-node bouncing and it couldn't be helped by autonuma as it requires tasks to have implicit node affinity and workers are assigned randomly. After these changes, an unbound workqueue now binds to multiple NUMA-affine worker pools so that queued work items are executed in the same node. This is turned on by default but can be disabled system-wide or for individual workqueues. Crypto was requesting NUMA affinity as encrypting data across different nodes can contribute noticeable overhead and doing it per-cpu was too limiting for certain cases and IO throughput could be bottlenecked by one CPU being fully occupied while others have idle cycles. While the new features required a lot of changes including restructuring locking, it didn't complicate the execution paths much. The unbound workqueue handling is now closer to per-cpu ones and the new features are implemented by simply associating a workqueue with different sets of backend worker pools without changing queue, execution or flush paths. As such, even though the amount of change is very high, I feel relatively safe in that it isn't likely to cause subtle issues with basic correctness of work item execution and handling. If something is wrong, it's likely to show up as being associated with worker pools with the wrong attributes or OOPS while workqueue attributes are being changed or during CPU hotplug. While this creates more backend worker pools, it doesn't add too many more workers unless, of course, there are many workqueues with unique combinations of attributes. Assuming everything else is the same, NUMA awareness costs an extra worker pool per NUMA node with online CPUs. There are also a couple things which are being routed outside the workqueue tree. - block tree pulled in workqueue for-3.10 so that writeback worker pool can be converted to unbound workqueue with sysfs control exposed. This simplifies the code, makes writeback workers NUMA-aware and allows tuning nice level and CPU affinity via sysfs. - The conversion to workqueue means that there's no 1:1 association between a specific worker, which makes writeback folks unhappy as they want to be able to tell which filesystem caused a problem from backtrace on systems with many filesystems mounted. This is resolved by allowing work items to set debug info string which is printed when the task is dumped. As this change involves unifying implementations of dump_stack() and friends in arch codes, it's being routed through Andrew's -mm tree." * 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (84 commits) workqueue: use kmem_cache_free() instead of kfree() workqueue: avoid false negative WARN_ON() in destroy_workqueue() workqueue: update sysfs interface to reflect NUMA awareness and a kernel param to disable NUMA affinity workqueue: implement NUMA affinity for unbound workqueues workqueue: introduce put_pwq_unlocked() workqueue: introduce numa_pwq_tbl_install() workqueue: use NUMA-aware allocation for pool_workqueues workqueue: break init_and_link_pwq() into two functions and introduce alloc_unbound_pwq() workqueue: map an unbound workqueues to multiple per-node pool_workqueues workqueue: move hot fields of workqueue_struct to the end workqueue: make workqueue->name[] fixed len workqueue: add workqueue->unbound_attrs workqueue: determine NUMA node of workers accourding to the allowed cpumask workqueue: drop 'H' from kworker names of unbound worker pools workqueue: add wq_numa_tbl_len and wq_numa_possible_cpumask[] workqueue: move pwq_pool_locking outside of get/put_unbound_pool() workqueue: fix memory leak in apply_workqueue_attrs() workqueue: fix unbound workqueue attrs hashing / comparison workqueue: fix race condition in unbound workqueue free path workqueue: remove pwq_lock which is no longer used ...
2013-04-29Merge branch 'for-3.10-async' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq Pull async update from Tejun Heo: "This contains three cleanup patches for async from Lai. All three patches are essentially cosmetic." * 'for-3.10-async' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: async: rename and redefine async_func_ptr async: remove unused @node from struct async_domain async: simplify lowest_in_progress()
2013-04-29net: rename random32 to prandomAkinobu Mita
Commit 496f2f93b1cc ("random32: rename random32 to prandom") renamed random32() and srandom32() to prandom_u32() and prandom_seed() respectively. net_random() and net_srandom() need to be redefined with prandom_* in order to finish the naming transition. While I'm at it, enclose macro argument of net_srandom() with parenthesis. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29inotify: convert inotify_add_to_idr() to use idr_alloc_cyclic()Jeff Layton
Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: John McCutchan <john@johnmccutchan.com> Cc: Robert Love <rlove@rlove.org> Cc: Eric Paris <eparis@parisplace.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29idr: introduce idr_alloc_cyclic()Jeff Layton
As Tejun points out, there are several users of the IDR facility that attempt to use it in a cyclic fashion. These users are likely to see -ENOSPC errors after the counter wraps one or more times however. This patchset adds a new idr_alloc_cyclic routine and converts several of these users to it. Many of these users are in obscure parts of the kernel, and I don't have a good way to test some of them. The change is pretty straightforward though, so hopefully it won't be an issue. There is one other cyclic user of idr_alloc that I didn't touch in ipc/util.c. That one is doing some strange stuff that I didn't quite understand, but it looks like it should probably be converted later somehow. This patch: Thus spake Tejun Heo: Ooh, BTW, the cyclic allocation is broken. It's prone to -ENOSPC after the first wraparound. There are several cyclic users in the kernel and I think it probably would be best to implement cyclic support in idr. This patch does that by adding new idr_alloc_cyclic function that such users in the kernel can use. With this, there's no need for a caller to keep track of the last value used as that's now tracked internally. This should prevent the ENOSPC problems that can hit when the "last allocated" counter exceeds INT_MAX. Later patches will convert existing cyclic users to the new interface. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Eric Paris <eparis@parisplace.org> Cc: Jack Morgenstein <jackm@dev.mellanox.co.il> Cc: John McCutchan <john@johnmccutchan.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Robert Love <rlove@rlove.org> Cc: Roland Dreier <roland@purestorage.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Cc: Steve Wise <swise@opengridcomputing.com> Cc: Tom Tucker <tom@opengridcomputing.com> Cc: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29fat: restructure export_operationsNamjae Jeon
Define two nfs export_operation structures,one for 'stale_rw' mounts and the other for 'nostale_ro'. The latter uses i_pos as a basis for encoding and decoding file handles. Also, assign i_pos to kstat->ino. The logic for rebuilding the inode is added in the subsequent patches. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Ravishankar N <ravi.n1@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29drivers/rtc/class.c: use struct device as the first argument for ↵Jingoo Han
devm_rtc_device_register() Other devm_* APIs use 'struct device *dev' as the first argument. Thus, in order to sync with other devm_* functions, struct device is used as the first argument for devm_rtc_device_register(). Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Tejun Heo <tj@kernel.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: add devm_rtc_device_{register,unregister}()Jingoo Han
These functions allow the driver core to automatically clean up any allocation made by rtc drivers. Thus it simplifies the error paths. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29lib, net: make isodigit() public and use itAndy Shevchenko
There are at least two users of isodigit(). Let's make it a public function of ctype.h. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29drivers/video/backlight/tps65217_bl.c add default brightness value optionMatus Ujhelyi
Signed-off-by: Matus Ujhelyi <matus.ujhelyi@streamunlimited.com> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29backlight: lp855x: remove duplicate platform dataKim, Milo
The 'load_new_rom_data' was used for checking whether new ROM data should be updated or not. However, we can decide it with 'size_program' data. If the size is greater than 0, it means updating ROM area is required. Otherwise, the default ROM data will be used. Therefore, this duplicate platform data can be removed. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29backlight: lp855x: fix initial brightness typeKim, Milo
Valid range of the brightness is from 0 to 255, so initial brightness is changed from integer to u8. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29backlight: lp855x: move backlight mode platform dataKim, Milo
The brightness of LP855x devices is controlled by I2C register or PWM input . This mode was selected through the platform data, but it can be chosen by the driver internally without platform data configuration. How to decide the control mode: If the PWM period has specific value, the mode is PWM input. On the other hand, the mode is register-based. This mode selection is done on the _probe(). Move 'mode' from a header file to the driver private data structure, 'lp855 x'. And correlated code was replaced. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29backlight: lp855x: convert a type of device nameKim, Milo
Configurable data, backlight device name is set to constant character type. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29drivers/video/backlight/platform_lcd.c: introduce probe callbackAndrew Bresticker
Platform LCD devices may need to do some device-specific initialization before they can be used (regulator or GPIO setup, for example), but currently the driver does not support any way of doing this. This patch adds a probe() callback to plat_lcd_data which platform LCD devices can set to indicate that device-specific initialization is needed. Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Reviewed-by: Doug Anderson <dianders@chromium.org> Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29include/linux/printk.h: include stdarg.hAndrew Morton
printk.h uses va_list but doesn't include stdarg.h. Hence printk.h is unusable unless its includer has already included kernel.h (which includes stdarg.h). Remove the dependency by including stdarg.h in printk.h Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29early_printk: consolidate random copies of identical codeThomas Gleixner
The early console implementations are the same all over the place. Move the print function to kernel/printk and get rid of the copies. [akpm@linux-foundation.org: arch/mips/kernel/early_printk.c needs kernel.h for va_list] [paul.gortmaker@windriver.com: sh4: make the bios early console support depend on EARLY_PRINTK] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Reviewed-by: Ingo Molnar <mingo@kernel.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29printk/tracing: rework console tracingzhangwei(Jovi)
Commit 7ff9554bb578 ("printk: convert byte-buffer to variable-length record buffer") removed start and end parameters from call_console_drivers, but those parameters still exist in include/trace/events/printk.h. Without start and end parameters handling, printk tracing became more simple as: trace_console(text, len); Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Kay Sievers <kay@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29gcc4: disable __compiletime_object_size for GCC 4.6+Guenter Roeck
__builtin_object_size is known to be broken on gcc 4.6+. See http://gcc.gnu.org/bugzilla/show_bug.cgi?id=48880 for details. This causes unnecssary build warnings and errors such as In function 'copy_from_user', inlined from 'sb16_copy_from_user' at sound/oss/sb_audio.c:878:22: arch/x86/include/asm/uaccess_32.h:211:26: error: call to 'copy_from_user_overflow' declared with attribute error: copy_from_user() buffer size is not provably correct make[3]: [sound/oss/sb_audio.o] Error 1 (ignored) Disable it where broken. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29media: coda: use genalloc APIPhilipp Zabel
This patch depends on "genalloc: add devres support, allow to find a managed pool by device", which provides the of_get_named_gen_pool and dev_get_gen_pool functions. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Acked-by: Javier Martin <javier.martin@vista-silicon.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: Michal Simek <monstr@monstr.eu> Cc: Dong Aisheng <dong.aisheng@linaro.org> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Huang Shijie <shijie8@gmail.com> Cc: Matt Porter <mporter@ti.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29genalloc: add devres support, allow to find a managed pool by devicePhilipp Zabel
This patch adds three exported functions to lib/genalloc.c: devm_gen_pool_create, dev_get_gen_pool, and of_get_named_gen_pool. devm_gen_pool_create is a managed version of gen_pool_create that keeps track of the pool via devres and allows the management code to automatically destroy it after device removal. dev_get_gen_pool retrieves the gen_pool for a given device, if it was created with devm_gen_pool_create, using devres_find. of_get_named_gen_pool retrieves the gen_pool for a given device node and property name, where the property must contain a phandle pointing to a platform device node. The corresponding platform device is then fed into dev_get_gen_pool and the resulting gen_pool is returned. [akpm@linux-foundation.org: make the of_get_named_gen_pool() stub static, fixing a zillion link errors] [akpm@linux-foundation.org: squish "struct device declared inside parameter list" warning] Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Michal Simek <monstr@monstr.eu> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Matt Porter <mporter@ti.com> Cc: Dong Aisheng <dong.aisheng@linaro.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Javier Martin <javier.martin@vista-silicon.com> Cc: Huang Shijie <shijie8@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Merge first batch of fixes from Andrew Morton: - A couple of kthread changes - A few minor audit patches - A number of fbdev patches. Florian remains AWOL so I'm picking up some of these. - A few kbuild things - ocfs2 updates - Almost all of the MM queue (And in the meantime, I already have the second big batch from Andrew pending in my mailbox ;^) * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (149 commits) memcg: take reference before releasing rcu_read_lock mem hotunplug: fix kfree() of bootmem memory mmKconfig: add an option to disable bounce mm, nobootmem: do memset() after memblock_reserve() mm, nobootmem: clean-up of free_low_memory_core_early() fs/buffer.c: remove unnecessary init operation after allocating buffer_head. numa, cpu hotplug: change links of CPU and node when changing node number by onlining CPU mm: fix memory_hotplug.c printk format warning mm: swap: mark swap pages writeback before queueing for direct IO swap: redirty page if page write fails on swap file mm, memcg: give exiting processes access to memory reserves thp: fix huge zero page logic for page with pfn == 0 memcg: avoid accessing memcg after releasing reference fs: fix fsync() error reporting memblock: fix missing comment of memblock_insert_region() mm: Remove unused parameter of pages_correctly_reserved() firmware, memmap: fix firmware_map_entry leak mm/vmstat: add note on safety of drain_zonestat mm: thp: add split tail pages to shrink page list in page reclaim mm: allow for outstanding swap writeback accounting ...
2013-04-29Merge tag 'clk-for-linus-3.10' of git://git.linaro.org/people/mturquette/linuxLinus Torvalds
Pull clock framework update from Michael Turquette: "The common clock framework changes for 3.10 include many fixes for existing platforms, as well as adoption of the framework by new platforms and devices. Some long-needed fixes to the core framework are here as well as new features such as improved initialization of clocks from DT as well as framework reentrancy for nested clock operations." * tag 'clk-for-linus-3.10' of git://git.linaro.org/people/mturquette/linux: (44 commits) clk: add clk_ignore_unused option to keep boot clocks on clk: ux500: fix mismatched types clk: vexpress: Add separate SP810 driver clk: si5351: make clk-si5351 depend on CONFIG_OF clk: export __clk_get_flags for modular clock providers clk: vt8500: Missing breaks in vtwm_pll_round_rate/_set_rate. clk: sunxi: Unify oscillator clock clk: composite: allow fixed rates & fixed dividers clk: composite: rename 'div' references to 'rate' clk: add si5351 i2c common clock driver clk: add device tree fixed-factor-clock binding support clk: Properly handle notifier return values clk: ux500: abx500: Define clock tree for ab850x clk: ux500: Add support for sysctrl clocks clk: mvebu: Fix valid value range checking for cpu_freq_select clk: Fixup locking issues for clk_set_parent clk: Fixup errorhandling for clk_set_parent clk: Restructure code for __clk_reparent clk: sunxi: drop an unnecesary kmalloc clk: sunxi: drop CLK_IGNORE_UNUSED ...
2013-04-29Merge tag 'spi-v3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi updates from Mark Brown: "A fairly quiet release for SPI, mainly driver work. A few highlights: - Supports bits per word compatibility checking in the core. - Allow use of the IP used in Freescale SPI controllers outside Freescale SoCs. - DMA support for the Atmel SPI driver. - New drivers for the BCM2835 and Tegra114" * tag 'spi-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (68 commits) spi-topcliff-pch: fix to use list_for_each_entry_safe() when delete list items spi-topcliff-pch: missing platform_driver_unregister() on error in pch_spi_init() ARM: dts: add pinctrl property for spi node for atmel SoC ARM: dts: add spi nodes for the atmel boards ARM: dts: add spi nodes for atmel SoC ARM: at91: add clocks for spi dt entries spi/spi-atmel: add dmaengine support spi/spi-atmel: add flag to controller data for lock operations spi/spi-atmel: add physical base address spi/sirf: fix MODULE_DEVICE_TABLE MAINTAINERS: Add git repository and update my address spi/s3c64xx: Check for errors in dmaengine prepare_transfer() spi/s3c64xx: Fix non-dmaengine usage spi: omap2-mcspi: fix error return code in omap2_mcspi_probe() spi/s3c64xx: let device core setup the default pin configuration MAINTAINERS: Update Grant's email address and maintainership spi: omap2-mcspi: Fix transfers if DMADEVICES is not set spi: s3c64xx: move to generic dmaengine API spi-gpio: init CS before spi_bitbang_setup() spi: spi-mpc512x-psc: let transmiter/receiver enabled when in xfer loop ...
2013-04-29Merge tag 'regulator-v3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates from Mark Brown: "The diffstat and changelog here is dominated by Lee Jones' heroic efforts to sync the ab8500 driver that's been maintained out of tree with mainline (plus Axel's cleanup work on the results) but there's a few other things here: - Axel Lin added regulator_map_voltage_ascend() optimising a common pattern for drivers using the core code. - Milo Kim tought the regulator core to handle regulators sharing an enable GPIO, avoiding the need to do hacks to support such systems. - Andrew Bresticker added code to handle missing supplies for regulators more sensibly for device tree systems, reducing the need for stubbing there. plus the usual batch of driver specific updates and fixes" * tag 'regulator-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (152 commits) regulator: mc13892: Fix MC13892_SWITCHERS0_SWxHI bit in set_voltage_sel regulator: Remove NULL test before calling regulator_unregister() regulator: mc13783: Add device tree probe support regulator: mc13xxx: Add warning of incorrect names of regulators regulator: max77686: Don't update max77686->opmode if update register fails regulator: max8952: Add missing config.of_node setting for regulator register regulator: ab3100: Fix regulator register error handling regulator: tps6524x: Use regulator_map_voltage_ascend regulator: lp8788-buck: Use regulator_map_voltage_ascend regulator: lp872x: Use regulator_map_voltage_ascend regulator: mc13892: Use regulator_map_voltage_ascend for mc13892_sw_regulator_ops regulator: tps65023: Use regulator_map_voltage_ascend regulator: tps65023: Merge tps65020 ldo1 and ldo2 vsel table regulator: tps6507x: Use regulator_map_voltage_ascend regulator: mc13892: Fix MC13892_SWITCHERS0_SWxHI bit in set_voltage_sel regulator: ab3100: device tree support regulator: ab3100: refactor probe to use IDs regulator: max8973: Don't override control1 variable when set ramp delay bits regulator: tps80031: Convert tps80031_dcdc_ops to [get|set]_voltage_sel_regmap regulator: tps80031: Fix LDO2 track mode for TPS80031 or TPS80032-ES1.0 ...
2013-04-29Merge tag 'regmap-v3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap updates from Mark Brown: "In user visible terms just a couple of enhancements here, though there was a moderate amount of refactoring required in order to support the register cache sync performance improvements. - Support for block and asynchronous I/O during register cache syncing; this provides a use case dependant performance improvement. - Additional debugfs information on the memory consuption and register set" * tag 'regmap-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: (23 commits) regmap: don't corrupt work buffer in _regmap_raw_write() regmap: cache: Fix format specifier in dev_dbg regmap: cache: Make regcache_sync_block_raw static regmap: cache: Write consecutive registers in a single block write regmap: cache: Split raw and non-raw syncs regmap: cache: Factor out block sync regmap: cache: Factor out reg_present support from rbtree cache regmap: cache: Use raw I/O to sync rbtrees if we can regmap: core: Provide regmap_can_raw_write() operation regmap: cache: Provide a get address of value operation regmap: Cut down on the average # of nodes in the rbtree cache regmap: core: Make raw write available to regcache regmap: core: Warn on invalid operation combinations regmap: irq: Clarify error message when we fail to request primary IRQ regmap: rbtree Expose total memory consumption in the rbtree debugfs entry regmap: debugfs: Add a registers `range' file regmap: debugfs: Simplify calculation of `c->max_reg' regmap: cache: Store caches in native register format where possible regmap: core: Split out in place value parsing regmap: cache: Use regcache_get_value() to check if we updated ...
2013-04-29mm, nobootmem: clean-up of free_low_memory_core_early()Joonsoo Kim
Remove unused argument and make function static, because there is no user outside of nobootmem.c Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Yinghai Lu <yinghai@kernel.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Jiang Liu <liuj97@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
