path: root/include
2012-01-20PM / devfreq: fixed syntax errors.MyungJoo Ham
If devfreq.h was included without CONFIG_PM_DEVFREQ, there has been a compiler error with an additional semicolon added. This patch removes that errorneous semicolon. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-01-19KEYS: Permit key_serial() to be called with a const key pointerDavid Howells
Permit key_serial() to be called with a const key pointer. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-18Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (26 commits) target: Set additional sense length field in sense data target: Remove legacy device status check from transport_execute_tasks target: Remove __transport_execute_tasks() for each processing context target: Remove extra se_device->execute_task_lock access in fast path target: Drop se_device TCQ queue_depth usage from I/O path target: Fix possible NULL pointer with __transport_execute_tasks target: Remove TFO->check_release_cmd() fabric API caller tcm_fc: Convert ft_send_work to use target_submit_cmd target: Add target_submit_cmd() for process context fabric submission target: Make target_put_sess_cmd use target_release_cmd_kref target: Set response format in INQUIRY response target: tcm_mod_builder: small fixups Documentation/target: Fix tcm_mod_builder.py build breakage target: remove overagressive ____cacheline_aligned annoations tcm_loop: bump max_sectors target/configs: remove trailing newline from udev_path and alias iscsi-target: fix chap identifier simple_strtoul usage target: remove useless casts target: simplify target_check_cdb_and_preempt target: Move core_scsi3_check_cdb_abort_and_preempt ...
2012-01-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux This includes initial support for the recently published ACPI 5.0 spec. In particular, support for the "hardware-reduced" bit that eliminates the dependency on legacy hardware. APEI has patches resulting from testing on real hardware. Plus other random fixes. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (52 commits) acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi spec intel_idle: Split up and provide per CPU initialization func ACPI processor: Remove unneeded variable passed by acpi_processor_hotadd_init V2 ACPI processor: Remove unneeded cpuidle_unregister_driver call intel idle: Make idle driver more robust intel_idle: Fix a cast to pointer from integer of different size warning in intel_idle ACPI: kernel-parameters.txt : Add intel_idle.max_cstate intel_idle: remove redundant local_irq_disable() call ACPI processor: Fix error path, also remove sysdev link ACPI: processor: fix acpi_get_cpuid for UP processor intel_idle: fix API misuse ACPI APEI: Convert atomicio routines ACPI: Export interfaces for ioremapping/iounmapping ACPI registers ACPI: Fix possible alignment issues with GAS 'address' references ACPI, ia64: Use SRAT table rev to use 8bit or 16/32bit PXM fields (ia64) ACPI, x86: Use SRAT table rev to use 8bit or 32bit PXM fields (x86/x86-64) ACPI: Store SRAT table revision ACPI, APEI, Resolve false conflict between ACPI NVS and APEI ACPI, Record ACPI NVS regions ACPI, APEI, EINJ, Refine the fix of resource conflict ...
2012-01-18Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (57 commits) [media] as3645a: Fix compilation by including slab.h [media] s5p-fimc: Remove linux/version.h include from fimc-mdevice.c [media] s5p-mfc: Remove linux/version.h include from s5p_mfc.c [media] ds3000: using logical && instead of bitwise & [media] v4l2-ctrls: make control names consistent [media] DVB: dib0700, add support for Nova-TD LEDs [media] DVB: dib0700, add corrected Nova-TD frontend_attach [media] DVB: dib0700, separate stk7070pd initialization [media] DVB: dib0700, move Nova-TD Stick to a separate set [media] : add MODULE_FIRMWARE to dib0700 [media] DVB-CORE: remove superfluous DTV_CMDs [media] s5p-jpeg: adapt to recent videobuf2 changes [media] s5p-g2d: fixed a bug in controls setting function [media] s5p-mfc: Fix volatile controls setup [media] drivers/media/video/s5p-mfc/s5p_mfc.c: adjust double test [media] drivers/media/video/s5p-fimc/fimc-capture.c: adjust double test [media] s5p-fimc: Fix incorrect control ID assignment [media] dvb_frontend: Don't call get_frontend() if idle [media] DocBook/dvbproperty.xml: Remove DTV_MODULATION from ISDB-T [media] DocBook/dvbproperty.xml: Fix ISDB-T delivery system parameters ...
2012-01-18Merge tag 'scsi-misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6 SCSI updates on 20120118 * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (49 commits) [SCSI] libfc: remove redundant timer init for fcp [SCSI] fcoe: Move fcoe_debug_logging from fcoe.h to fcoe.c [SCSI] libfc: Declare local functions static [SCSI] fcoe: fix regression on offload em matching function for initiator/target [SCSI] qla4xxx: Update driver version to 5.02.00-k12 [SCSI] qla4xxx: Cleanup modinfo display [SCSI] qla4xxx: Update license [SCSI] qla4xxx: Clear the RISC interrupt bit during FW init [SCSI] qla4xxx: Added error logging for firmware abort [SCSI] qla4xxx: Disable generating pause frames in case of FW hung [SCSI] qla4xxx: Temperature monitoring for ISP82XX core. [SCSI] megaraid: fix sparse warnings [SCSI] sg: convert to kstrtoul_from_user() [SCSI] don't change sdev starvation list order without request dispatched [SCSI] isci: fix, prevent port from getting stuck in the 'configuring' state [SCSI] isci: fix start OOB [SCSI] isci: fix io failures while wide port links are coming up [SCSI] isci: allow more time for wide port targets [SCSI] isci: enable wide port targets [SCSI] isci: Fix IO fails when pull cable from phy in x4 wideport in MPC mode. ...
2012-01-18Merge git://git.infradead.org/users/willy/linux-nvmeLinus Torvalds
* git://git.infradead.org/users/willy/linux-nvme: (105 commits) NVMe: Set number of queues correctly NVMe: Version 0.8 NVMe: Set queue flags correctly NVMe: Simplify nvme_unmap_user_pages NVMe: Mark the end of the sg list NVMe: Fix DMA mapping for admin commands NVMe: Rename IO_TIMEOUT to NVME_IO_TIMEOUT NVMe: Merge the nvme_bio and nvme_prp data structures NVMe: Change nvme_completion_fn to take a dev NVMe: Change get_nvmeq to take a dev instead of a namespace NVMe: Simplify completion handling NVMe: Update Identify Controller data structure NVMe: Implement doorbell stride capability NVMe: Version 0.7 NVMe: Don't probe namespace 0 Fix calculation of number of pages in a PRP List NVMe: Create nvme_identify and nvme_get_features functions NVMe: Fix memory leak in nvme_dev_add() NVMe: Fix calls to dma_unmap_sg NVMe: Correct sg list setup in nvme_map_user_pages ...
2012-01-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) tg3: Fix single-vector MSI-X code openvswitch: Fix multipart datapath dumps. ipv6: fix per device IP snmp counters inetpeer: initialize ->redirect_genid in inet_getpeer() net: fix NULL-deref in WARN() in skb_gso_segment() net: WARN if skb_checksum_help() is called on skb requiring segmentation caif: Remove bad WARN_ON in caif_dev caif: Fix typo in Vendor/Product-ID for CAIF modems bnx2x: Disable AN KR work-around for BCM57810 bnx2x: Remove AutoGrEEEn for BCM84833 bnx2x: Remove 100Mb force speed for BCM84833 bnx2x: Fix PFC setting on BCM57840 bnx2x: Fix Super-Isolate mode for BCM84833 net: fix some sparse errors net: kill duplicate included header net: sh-eth: Fix build error by the value which is not defined net: Use device model to get driver name in skb_gso_segment() bridge: BH already disabled in br_fdb_cleanup() net: move sock_update_memcg outside of CONFIG_INET mwl8k: Fixing Sparse ENDIAN CHECK warning ...
2012-01-18Merge branches 'einj', 'intel_idle', 'misc', 'srat' and 'turbostat-ivb' into ↵Len Brown
release
2012-01-18acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi specTony Luck
ACPI 5.0 provides extensions to the EINJ mechanism to specify the target for the error injection - by APICID for cpu related errors, by address for memory related errors, and by segment/bus/device/function for PCIe related errors. Also extensions for vendor specific error injections. Tested-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-18Merge branch 'atomicio-remove' into releaseLen Brown
2012-01-18Merge branch 'apei' into releaseLen Brown
2012-01-17intel_idle: Split up and provide per CPU initialization funcThomas Renninger
Function split up, should have no functional change. Provides entry point for physically hotplugged CPUs to initialize and activate cpuidle. Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Deepthi Dharwar <deepthi@linux.vnet.ibm.com> CC: Shaohua Li <shaohua.li@intel.com> CC: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits) ARM: mach-shmobile: specify CHCLR registers on SH7372 dma: shdma: fix runtime PM: clear channel buffers on reset dma/imx-sdma: save irq flags when use spin_lock in sdma_tx_submit dmaengine/ste_dma40: clear LNK on channel startup dmaengine: intel_mid_dma: remove legacy pm interface ASoC: mxs: correct 'direction' of device_prep_dma_cyclic dmaengine: intel_mid_dma: error path fix dmaengine: intel_mid_dma: locking and freeing fixes mtd: gpmi-nand: move to dma_transfer_direction mtd: fix compile error for gpmi-nand mmc: mxs-mmc: fix the dma_transfer_direction migration dmaengine: add DMA_TRANS_NONE to dma_transfer_direction dma: mxs-dma: Don't use CLKGATE bits in CTRL0 to disable DMA channels dma: mxs-dma: make mxs_dma_prep_slave_sg() multi user safe dma: mxs-dma: Always leave mxs_dma_init() with the clock disabled. dma: mxs-dma: fix a typo in comment DMA: PL330: Remove pm_runtime_xxx calls from pl330 probe/remove video i.MX IPU: Fix display connections i.MX IPU DMA: Fix wrong burstsize settings dmaengine/ste_dma40: allow fixed physical channel ... Fix up conflicts in drivers/dma/{Kconfig,mxs-dma.c,pl330.c} The conflicts looked pretty trivial, but I'll ask people to verify them.
2012-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: integrity: digital signature config option name change lib: Removed MPILIB, MPILIB_EXTRA, and SIGNATURE prompts lib: MPILIB Kconfig description update lib: digital signature dependency fix lib: digital signature config option name change encrypted-keys: fix rcu and sparse messages keys: fix trusted/encrypted keys sparse rcu_assign_pointer messages KEYS: Add missing smp_rmb() primitives to the keyring search code TOMOYO: Accept \000 as a valid character. security: update MAINTAINERS file with new git repo
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit: (29 commits) audit: no leading space in audit_log_d_path prefix audit: treat s_id as an untrusted string audit: fix signedness bug in audit_log_execve_info() audit: comparison on interprocess fields audit: implement all object interfield comparisons audit: allow interfield comparison between gid and ogid audit: complex interfield comparison helper audit: allow interfield comparison in audit rules Kernel: Audit Support For The ARM Platform audit: do not call audit_getname on error audit: only allow tasks to set their loginuid if it is -1 audit: remove task argument to audit_set_loginuid audit: allow audit matching on inode gid audit: allow matching on obj_uid audit: remove audit_finish_fork as it can't be called audit: reject entry,always rules audit: inline audit_free to simplify the look of generic code audit: drop audit_set_macxattr as it doesn't do anything audit: inline checks for not needing to collect aux records audit: drop some potentially inadvisable likely notations ... Use evil merge to fix up grammar mistakes in Kconfig file. Bad speling and horrible grammar (and copious swearing) is to be expected, but let's keep it to commit messages and comments, rather than expose it to users in config help texts or printouts.
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (62 commits) Btrfs: use larger system chunks Btrfs: add a delalloc mutex to inodes for delalloc reservations Btrfs: space leak tracepoints Btrfs: protect orphan block rsv with spin_lock Btrfs: add allocator tracepoints Btrfs: don't call btrfs_throttle in file write Btrfs: release space on error in page_mkwrite Btrfs: fix btrfsck error 400 when truncating a compressed Btrfs: do not use btrfs_end_transaction_throttle everywhere Btrfs: add balance progress reporting Btrfs: allow for resuming restriper after it was paused Btrfs: allow for canceling restriper Btrfs: allow for pausing restriper Btrfs: add skip_balance mount option Btrfs: recover balance on mount Btrfs: save balance parameters to disk Btrfs: soft profile changing mode (aka soft convert) Btrfs: implement online profile changing Btrfs: do not reduce profile in do_chunk_alloc() Btrfs: virtual address space subset filter ... Fix up trivial conflict in fs/btrfs/ioctl.c due to the use of the new mnt_drop_write_file() helper.
2012-01-18lib: digital signature config option name changeDmitry Kasatkin
It was reported that DIGSIG is confusing name for digital signature module. It was suggested to rename DIGSIG to SIGNATURE. Requested-by: Linus Torvalds <torvalds@linux-foundation.org> Suggested-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-18keys: fix trusted/encrypted keys sparse rcu_assign_pointer messagesMimi Zohar
Define rcu_assign_keypointer(), which uses the key payload.rcudata instead of payload.data, to resolve the CONFIG_SPARSE_RCU_POINTER message: "incompatible types in comparison expression (different address spaces)" Replace the rcu_assign_pointer() calls in encrypted/trusted keys with rcu_assign_keypointer(). Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-17Fix compile breakage with kref.hJames Bottomley
This set of build failures just started appearing on parisc: In file included from drivers/input/serio/serio_raw.c:12: include/linux/kref.h: In function 'kref_get': include/linux/kref.h:40: error: 'TAINT_WARN' undeclared (first use in this function) include/linux/kref.h:40: error: (Each undeclared identifier is reported only once include/linux/kref.h:40: error: for each function it appears in.) include/linux/kref.h: In function 'kref_sub': include/linux/kref.h:65: error: 'TAINT_WARN' undeclared (first use in this function) It happens because TAINT_WARN is defined in kernel.h and this particular compile doesn't seem to include it (no idea why it's just manifesting .. probably some #include file untangling exposed it). Fix by adding #include <linux/kernel.h> to linux/kref.h Signed-off-by: James Bottomley <JBottomley@Parallels.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-17audit: comparison on interprocess fieldsPeter Moody
This allows audit to specify rules in which we compare two fields of a process. Such as is the running process uid != to the running process euid? Signed-off-by: Peter Moody <pmoody@google.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: implement all object interfield comparisonsPeter Moody
This completes the matrix of interfield comparisons between uid/gid information for the current task and the uid/gid information for inodes. aka I can audit based on differences between the euid of the process and the uid of fs objects. Signed-off-by: Peter Moody <pmoody@google.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: allow interfield comparison between gid and ogidEric Paris
Allow audit rules to compare the gid of the running task to the gid of the inode in question. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: allow interfield comparison in audit rulesEric Paris
We wish to be able to audit when a uid=500 task accesses a file which is uid=0. Or vice versa. This patch introduces a new audit filter type AUDIT_FIELD_COMPARE which takes as an 'enum' which indicates which fields should be compared. At this point we only define the task->uid vs inode->uid, but other comparisons can be added. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: remove task argument to audit_set_loginuidEric Paris
The function always deals with current. Don't expose an option pretending one can use it for something. You can't. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: allow audit matching on inode gidEric Paris
Much like the ability to filter audit on the uid of an inode collected, we should be able to filter on the gid of the inode. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: allow matching on obj_uidEric Paris
Allow syscall exit filter matching based on the uid of the owner of an inode used in a syscall. aka: auditctl -a always,exit -S open -F obj_uid=0 -F perm=wa Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: remove audit_finish_fork as it can't be calledEric Paris
Audit entry,always rules are not allowed and are automatically changed in exit,always rules in userspace. The kernel refuses to load such rules. Thus a task in the middle of a syscall (and thus in audit_finish_fork()) can only be in one of two states: AUDIT_BUILD_CONTEXT or AUDIT_DISABLED. Since the current task cannot be in AUDIT_RECORD_CONTEXT we aren't every going to actually use the code in audit_finish_fork() since it will return without doing anything. Thus drop the code. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: inline audit_free to simplify the look of generic codeEric Paris
make the conditional a static inline instead of doing it in generic code. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: drop audit_set_macxattr as it doesn't do anythingEric Paris
unused. deleted. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: inline checks for not needing to collect aux recordsEric Paris
A number of audit hooks make function calls before they determine that auxilary records do not need to be collected. Do those checks as static inlines since the most common case is going to be that records are not needed and we can skip the function call overhead. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: inline audit_syscall_entry to reduce burden on archsEric Paris
Every arch calls: if (unlikely(current->audit_context)) audit_syscall_entry() which requires knowledge about audit (the existance of audit_context) in the arch code. Just do it all in static inline in audit.h so that arch's can remain blissfully ignorant. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17Audit: push audit success and retcode into arch ptrace.hEric Paris
The audit system previously expected arches calling to audit_syscall_exit to supply as arguments if the syscall was a success and what the return code was. Audit also provides a helper AUDITSC_RESULT which was supposed to simplify things by converting from negative retcodes to an audit internal magic value stating success or failure. This helper was wrong and could indicate that a valid pointer returned to userspace was a failed syscall. The fix is to fix the layering foolishness. We now pass audit_syscall_exit a struct pt_reg and it in turns calls back into arch code to collect the return value and to determine if the syscall was a success or failure. We also define a generic is_syscall_success() macro which determines success/failure based on if the value is < -MAX_ERRNO. This works for arches like x86 which do not use a separate mechanism to indicate syscall failure. We make both the is_syscall_success() and regs_return_value() static inlines instead of macros. The reason is because the audit function must take a void* for the regs. (uml calls theirs struct uml_pt_regs instead of just struct pt_regs so audit_syscall_exit can't take a struct pt_regs). Since the audit function takes a void* we need to use static inlines to cast it back to the arch correct structure to dereference it. The other major change is that on some arches, like ia64, MIPS and ppc, we change regs_return_value() to give us the negative value on syscall failure. THE only other user of this macro, kretprobe_example.c, won't notice and it makes the value signed consistently for the audit functions across all archs. In arch/sh/kernel/ptrace_64.c I see that we were using regs[9] in the old audit code as the return value. But the ptrace_64.h code defined the macro regs_return_value() as regs[3]. I have no idea which one is correct, but this patch now uses the regs_return_value() function, so it now uses regs[3]. For powerpc we previously used regs->result but now use the regs_return_value() function which uses regs->gprs[3]. regs->gprs[3] is always positive so the regs_return_value(), much like ia64 makes it negative before calling the audit code when appropriate. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> [for x86 portion] Acked-by: Tony Luck <tony.luck@intel.com> [for ia64] Acked-by: Richard Weinberger <richard@nod.at> [for uml] Acked-by: David S. Miller <davem@davemloft.net> [for sparc] Acked-by: Ralf Baechle <ralf@linux-mips.org> [for mips] Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [for ppc]
2012-01-17seccomp: audit abnormal end to a process due to seccompEric Paris
The audit system likes to collect information about processes that end abnormally (SIGSEGV) as this may me useful intrusion detection information. This patch adds audit support to collect information when seccomp forces a task to exit because of misbehavior in a similar way. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17tty: remove unused tty_driver->termios_lockedKonstantin Khlebnikov
This field is unused since 2.6.28 (commit fe6e29fdb1a7: "tty: simplify ktermios allocation", to be exact) Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-17Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
2012-01-17net: fix some sparse errorsEric Dumazet
make C=2 CF="-D__CHECK_ENDIAN__" M=net And fix flowi4_init_output() prototype for sport Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-17bcma: connect the bcma bus suspend/resume to the bcma driver suspend/resumeLinus Torvalds
Now the low-level driver actually gets informed that it is getting suspended and resumed. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-17ACPI: Export interfaces for ioremapping/iounmapping ACPI registersMyron Stowe
Export remapping and unmapping interfaces - acpi_os_map_generic_address() and acpi_os_unmap_generic_address() - for ACPI generic registers that are backed by memory mapped I/O (MMIO). The acpi_os_map_generic_address() and acpi_os_unmap_generic_address() declarations may more properly belong in include/acpi/acpiosxf.h next to acpi_os_read_memory() but I believe that would require the ACPI CA making them an official part of the ACPI CA - OS interface. ACPI Generic Address Structure (GAS) reference (ACPI's fixed/generic hardware registers use the GAS format): ACPI Specification, Revision 4.0, Section 5.2.3.1, "Generic Address Structure" Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI: Store SRAT table revisionKurt Garloff
In SRAT v1, we had 8bit proximity domain (PXM) fields; SRAT v2 provides 32bits for these. The new fields were reserved before. According to the ACPI spec, the OS must disregrard reserved fields. In order to know whether or not, we must know what version the SRAT table has. This patch stores the SRAT table revision for later consumption by arch specific __init functions. Signed-off-by: Kurt Garloff <kurt@garloff.de> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI, Record ACPI NVS regionsHuang Ying
Some firmware will access memory in ACPI NVS region via APEI. That is, instructions in APEI ERST/EINJ table will read/write ACPI NVS region. The original resource conflict checking in APEI code will check memory/ioport accessed by APEI via general resource management mechanism. But ACPI NVS region is marked as busy already, so that the false resource conflict will prevent APEI ERST/EINJ to work. To fix this, this patch record ACPI NVS regions, so that we can avoid request resources for memory region inside it. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPICA: Update to version 20120111Bob Moore
Version 20120111. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPICA: Add support for region address conflict checkingLin Ming
Allows drivers to determine if any memory or I/O addresses will conflict with addresses used by ACPI operation regions. Introduces a new interface, acpi_check_address_range. http://marc.info/?t=132251388700002&r=1&w=2 Reported-and-tested-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPICA: Update to version 20111123Bob Moore
This version contains full support for the ACPI 5.0 specification. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI 5.0: Allow _AEI method in walk resourcesZhang Rui
_AEI contains a resource template, this change adds support for the walk resources function. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI 5.0: New interface, acpi_buffer_to_resourceBob Moore
This interface converts an AML buffer to an internal ACPI_RESOURCE. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI 5.0: New interface, acpi_get_event_resourcesBob Moore
Executes _AEI and formats the result, similar to acpi_get_current_resources, etc. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI 5.0: Support for all new resource descriptorsLin Ming
FixedDMA, GPIO descriptors, SerialBus descriptors Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI 5.0: Support for GeneralPurposeIo and GenericSerialBus operation regionBob Moore
2012-01-17ACPI 5.0: Implement Connection() and AccessAs() changesBob Moore
Support within the interpreter and operation region dispatch. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
