path: root/include
2008-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/isdn/i4l/isdn_net.c fs/cifs/connect.c
2008-11-18Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: hold extra reference to bio in blk_rq_map_user_iov() relay: fix cpu offline problem Release old elevator on change elevator block: fix boot failure with CONFIG_DEBUG_BLOCK_EXT_DEVT=y and nash block/md: fix md autodetection block: make add_partition() return pointer to hd_struct block: fix add_partition() error path
2008-11-18Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kernel/profile.c: fix section mismatch warning function tracing: fix wrong pos computing when read buffer has been fulfilled tracing: fix mmiotrace resizing crash ring-buffer: no preempt for sched_clock() ring-buffer: buffer record on/off switch
2008-11-18block: make add_partition() return pointer to hd_structTejun Heo
Make add_partition() return pointer to the new hd_struct on success and ERR_PTR() value on failure. This change will be used to fix md autodetection bug. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) rtnetlink: propagate error from dev_change_flags in do_setlink() isdn: remove extra byteswap in isdn_net_ciscohdlck_slarp_send_reply Phonet: refuse to send bigger than MTU packets e1000e: fix IPMI traffic e1000e: fix warn_on reload after phy_id error phy: fix phy address bug e100: fix dma error in direction for mapping igb: use dev_printk instead of printk qla3xxx: Cleanup: Fix link print statements. igb: Use device_set_wakeup_enable e1000: Use device_set_wakeup_enable e1000e: Use device_set_wakeup_enable via-velocity: enable perfect filtering for multicast packets phy: Add support for Marvell 88E1118 PHY mlx4_en: Pause parameters per port phylib: fix premature freeing of struct mii_bus atl1: Do not enumerate options unsupported by chip atl1e: fix broken multicast by removing unnecessary crc inversion gianfar: Fix DMA unmap invocations net/ucc_geth: Fix oops in uec_get_ethtool_stats() ...
2008-11-16ematch: simpler tcf_em_unregister()Alexey Dobriyan
Simply delete ops from list and let list debugging do the job. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16dccp: Deprecate Ack Ratio sysctlGerrit Renker
This patch deprecates the Ack Ratio sysctl, since * Ack Ratio is entirely ignored by CCID-3 and CCID-4, * Ack Ratio currently doesn't work in CCID-2 (i.e. is always set to 1); * even if it would work in CCID-2, there is no point for a user to change it: - Ack Ratio is constrained by cwnd (RFC 4341, 6.1.2), - if Ack Ratio > cwnd, the system resorts to spurious RTO timeouts (since waiting for Acks which will never arrive in this window), - cwnd is not a user-configurable value. The only reasonable place for Ack Ratio is to print it for debugging. It is planned to do this later on, as part of e.g. dccp_probe. With this patch Ack Ratio is now under full control of feature negotiation: * Ack Ratio is resolved as a dependency of the selected CCID; * if the chosen CCID supports it (i.e. CCID == CCID-2), Ack Ratio is set to the default of 2, following RFC 4340, 11.3 - "New connections start with Ack Ratio 2 for both endpoints"; * what happens then is part of another patch set, since it concerns the dynamic update of Ack Ratio while the connection is in full flight. Thanks to Tomasz Grobelny for discussion leading up to this patch. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16dccp: Feature negotiation for minimum-checksum-coverageGerrit Renker
This provides feature negotiation for server minimum checksum coverage which so far has been missing. Since sender/receiver coverage values range only from 0...15, their type has also been reduced in size from u16 to u4. Feature-negotiation options are now generated for both sender and receiver coverage, i.e. when the peer has `forgotten' to enable partial coverage then feature negotiation will automatically enable (negotiate) the partial coverage value for this connection. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16dccp: Deprecate old setsockopt frameworkGerrit Renker
The previous setsockopt interface, which passed socket options via struct dccp_so_feat, is complicated/difficult to use. Continuing to support it leads to ugly code since the old approach did not distinguish between NN and SP values. This patch removes the old setsockopt interface and replaces it with two new functions to register NN/SP values for feature negotiation. These are essentially wrappers around the internal __feat_register functions, with checking added to avoid * wrong usage (type); * changing values while the connection is in progress. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16virtio_net: VIRTIO_NET_F_MSG_RXBUF (imprive rcv buffer allocation)Mark McLoughlin
If segmentation offload is enabled by the host, we currently allocate maximum sized packet buffers and pass them to the host. This uses up 20 ring entries, allowing us to supply only 20 packet buffers to the host with a 256 entry ring. This is a huge overhead when receiving small packets, and is most keenly felt when receiving MTU sized packets from off-host. The VIRTIO_NET_F_MRG_RXBUF feature flag is set by hosts which support using receive buffers which are smaller than the maximum packet size. In order to transfer large packets to the guest, the host merges together multiple receive buffers to form a larger logical buffer. The number of merged buffers is returned to the guest via a field in the virtio_net_hdr. Make use of this support by supplying single page receive buffers to the host. On receive, we extract the virtio_net_hdr, copy 128 bytes of the payload to the skb's linear data buffer and adjust the fragment offset to point to the remaining data. This ensures proper alignment and allows us to not use any paged data for small packets. If the payload occupies multiple pages, we simply append those pages as fragments and free the associated skbs. This scheme allows us to be efficient in our use of ring entries while still supporting large packets. Benchmarking using netperf from an external machine to a guest over a 10Gb/s network shows a 100% improvement from ~1Gb/s to ~2Gb/s. With a local host->guest benchmark with GSO disabled on the host side, throughput was seen to increase from 700Mb/s to 1.7Gb/s. Based on a patch from Herbert Xu. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (use netdev_priv) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16net: make sure struct dst_entry refcount is aligned on 64 bytesEric Dumazet
As found in the past (commit f1dd9c379cac7d5a76259e7dffcd5f8edc697d17 [NET]: Fix tbench regression in 2.6.25-rc1), it is really important that struct dst_entry refcount is aligned on a cache line. We cannot use __atribute((aligned)), so manually pad the structure for 32 and 64 bit arches. for 32bit : offsetof(truct dst_entry, __refcnt) is 0x80 for 64bit : offsetof(truct dst_entry, __refcnt) is 0xc0 As it is not possible to guess at compile time cache line size, we use a generic value of 64 bytes, that satisfies many current arches. (Using 128 bytes alignment on 64bit arches would waste 64 bytes) Add a BUILD_BUG_ON to catch future updates to "struct dst_entry" dont break this alignment. "tbench 8" is 4.4 % faster on a dual quad core (HP BL460c G1), Intel E5450 @3.00GHz (2350 MB/s instead of 2250 MB/s) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16net: Convert TCP & DCCP hash tables to use RCU / hlist_nullsEric Dumazet
RCU was added to UDP lookups, using a fast infrastructure : - sockets kmem_cache use SLAB_DESTROY_BY_RCU and dont pay the price of call_rcu() at freeing time. - hlist_nulls permits to use few memory barriers. This patch uses same infrastructure for TCP/DCCP established and timewait sockets. Thanks to SLAB_DESTROY_BY_RCU, no slowdown for applications using short lived TCP connections. A followup patch, converting rwlocks to spinlocks will even speedup this case. __inet_lookup_established() is pretty fast now we dont have to dirty a contended cache line (read_lock/read_unlock) Only established and timewait hashtable are converted to RCU (bind table and listen table are still using traditional locking) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16udp: Use hlist_nulls in UDP RCU codeEric Dumazet
This is a straightforward patch, using hlist_nulls infrastructure. RCUification already done on UDP two weeks ago. Using hlist_nulls permits us to avoid some memory barriers, both at lookup time and delete time. Patch is large because it adds new macros to include/net/sock.h. These macros will be used by TCP & DCCP in next patch. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16rcu: Introduce hlist_nulls variant of hlistEric Dumazet
hlist uses NULL value to finish a chain. hlist_nulls variant use the low order bit set to 1 to signal an end-of-list marker. This allows to store many different end markers, so that some RCU lockless algos (used in TCP/UDP stack for example) can save some memory barriers in fast paths. Two new files are added : include/linux/list_nulls.h - mimics hlist part of include/linux/list.h, derived to hlist_nulls variant include/linux/rculist_nulls.h - mimics hlist part of include/linux/rculist.h, derived to hlist_nulls variant Only four helpers are declared for the moment : hlist_nulls_del_init_rcu(), hlist_nulls_del_rcu(), hlist_nulls_add_head_rcu() and hlist_nulls_for_each_entry_rcu() prefetches() were removed, since an end of list is not anymore NULL value. prefetches() could trigger useless (and possibly dangerous) memory transactions. Example of use (extracted from __udp4_lib_lookup()) struct sock *sk, *result; struct hlist_nulls_node *node; unsigned short hnum = ntohs(dport); unsigned int hash = udp_hashfn(net, hnum); struct udp_hslot *hslot = &udptable->hash[hash]; int score, badness; rcu_read_lock(); begin: result = NULL; badness = -1; sk_nulls_for_each_rcu(sk, node, &hslot->head) { score = compute_score(sk, net, saddr, hnum, sport, daddr, dport, dif); if (score > badness) { result = sk; badness = score; } } /* * if the nulls value we got at the end of this lookup is * not the expected one, we must restart lookup. * We probably met an item that was moved to another chain. */ if (get_nulls_value(node) != hash) goto begin; if (result) { if (unlikely(!atomic_inc_not_zero(&result->sk_refcnt))) result = NULL; else if (unlikely(compute_score(result, net, saddr, hnum, sport, daddr, dport, dif) < badness)) { sock_put(result); goto begin; } } rcu_read_unlock(); return result; Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16TPROXY: implemented IP_RECVORIGDSTADDR socket optionBalazs Scheidler
In case UDP traffic is redirected to a local UDP socket, the originally addressed destination address/port cannot be recovered with the in-kernel tproxy. This patch adds an IP_RECVORIGDSTADDR sockopt that enables a IP_ORIGDSTADDR ancillary message in recvmsg(). This ancillary message contains the original destination address/port of the packet being received. Signed-off-by: Balazs Scheidler <bazsi@balabit.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16phylib: make mdio-gpio work without OF (v4)Paulius Zaleckas
make mdio-gpio work with non OpenFirmware gpio implementation. Aditional changes to mdio-gpio: - use gpio_request() and gpio_free() - place irq[] array in struct mdio_gpio_info - add module description, author and license - add note about compiling this driver as module - rename mdc and mdio function (were ugly names) - change MII to MDIO in bus name - add __init __exit to module (un)loading functions - probe fails if no phys added to the bus - kzalloc bitbang with sizeof(*bitbang) Changes since v3: - keep bus naming "%x" to be compatible with existing drivers. Changes since v2: - more #ifdefs reduction - platform driver will be registered on OF platforms also - unified platform and OF bus_id to phy%i Changes since v1: - removed NO_IRQ - reduced #idefs Laurent, please test this driver under OF. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: don't grab devices with no input HID: fix radio-mr800 hidquirks HID: fix kworld fm700 radio hidquirks HID: fix start/stop cycle in usbhid driver HID: use single threaded work queue for hid_compat HID: map macbook keys for "Expose" and "Dashboard" HID: support for new unibody macbooks HID: fix locking in hidraw_open()
2008-11-15Fix inotify watch removal/umount racesAl Viro
Inotify watch removals suck violently. To kick the watch out we need (in this order) inode->inotify_mutex and ih->mutex. That's fine if we have a hold on inode; however, for all other cases we need to make damn sure we don't race with umount. We can *NOT* just grab a reference to a watch - inotify_unmount_inodes() will happily sail past it and we'll end with reference to inode potentially outliving its superblock. Ideally we just want to grab an active reference to superblock if we can; that will make sure we won't go into inotify_umount_inodes() until we are done. Cleanup is just deactivate_super(). However, that leaves a messy case - what if we *are* racing with umount() and active references to superblock can't be acquired anymore? We can bump ->s_count, grab ->s_umount, which will almost certainly wait until the superblock is shut down and the watch in question is pining for fjords. That's fine, but there is a problem - we might have hit the window between ->s_active getting to 0 / ->s_count - below S_BIAS (i.e. the moment when superblock is past the point of no return and is heading for shutdown) and the moment when deactivate_super() acquires ->s_umount. We could just do drop_super() yield() and retry, but that's rather antisocial and this stuff is luser-triggerable. OTOH, having grabbed ->s_umount and having found that we'd got there first (i.e. that ->s_root is non-NULL) we know that we won't race with inotify_umount_inodes(). So we could grab a reference to watch and do the rest as above, just with drop_super() instead of deactivate_super(), right? Wrong. We had to drop ih->mutex before we could grab ->s_umount. So the watch could've been gone already. That still can be dealt with - we need to save watch->wd, do idr_find() and compare its result with our pointer. If they match, we either have the damn thing still alive or we'd lost not one but two races at once, the watch had been killed and a new one got created with the same ->wd at the same address. That couldn't have happened in inotify_destroy(), but inotify_rm_wd() could run into that. Still, "new one got created" is not a problem - we have every right to kill it or leave it alone, whatever's more convenient. So we can use idr_find(...) == watch && watch->inode->i_sb == sb as "grab it and kill it" check. If it's been our original watch, we are fine, if it's a newcomer - nevermind, just pretend that we'd won the race and kill the fscker anyway; we are safe since we know that its superblock won't be going away. And yes, this is far beyond mere "not very pretty"; so's the entire concept of inotify to start with. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-15Merge branch 'sh/for-2.6.28' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh/for-2.6.28' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: serial: sh-sci: Reorder the SCxTDR write after the TDxE clear. sh: __copy_user function can corrupt the stack in case of exception sh: Fixed the TMU0 reload value on resume sh: Don't factor in PAGE_OFFSET for valid_phys_addr_range() check. sh: early printk port type fix i2c: fix i2c-sh_mobile rx underrun sh: Provide a sane valid_phys_addr_range() to prevent TLB reset with PMB. usb: r8a66597-hcd: fix wrong data access in SuperH on-chip USB fix sci type for SH7723 serial: sh-sci: fix cannot work SH7723 SCIFA sh: Handle fixmap TLB eviction more coherently.
2008-11-15Add 'pr_fmt()' format modifier to pr_xyz macros.Martin Schwidefsky
A common reason for device drivers to implement their own printk macros is the lack of a printk prefix with the standard pr_xyz macros. Introduce a pr_fmt() macro that is applied for every pr_xyz macro to the format string. The most common use of the pr_fmt macro would be to add the name of the device driver to all pr_xyz messages in a source file. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-13lockdep: include/linux/lockdep.h - fix warning in net/bluetooth/af_bluetooth.cIngo Molnar
fix this warning: net/bluetooth/af_bluetooth.c:60: warning: ‘bt_key_strings’ defined but not used net/bluetooth/af_bluetooth.c:71: warning: ‘bt_slock_key_strings’ defined but not used this is a lockdep macro problem in the !LOCKDEP case. We cannot convert it to an inline because the macro works on multiple types, but we can mark the parameter used. [ also clean up a misaligned tab in sock_lock_init_class_and_name() ] [ also remove #ifdefs from around af_family_clock_key strings - which were certainly added to get rid of the ugly build warnings. ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-13pkt_sched: Remove qdisc->ops->requeue() etc.Jarek Poplawski
After implementing qdisc->ops->peek() and changing sch_netem into classless qdisc there are no more qdisc->ops->requeue() users. This patch removes this method with its wrappers (qdisc_requeue()), and also unused qdisc->requeue structure. There are a few minor fixes of warnings (htb_enqueue()) and comments btw. The idea to kill ->requeue() and a similar patch were first developed by David S. Miller. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-13tcp: remove an unnecessary field in struct tcp_skb_cbPetr Tesarik
The urg_ptr field is not used anywhere and is merely confusing. Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-13USB: don't register endpoints for interfaces that are going awayAlan Stern
This patch (as1155) fixes a bug in usbcore. When interfaces are deleted, either because the device was disconnected or because of a configuration change, the extra attribute files and child endpoint devices may get left behind. This is because the core removes them before calling device_del(). But during device_del(), after the driver is unbound the core will reinstall altsetting 0 and recreate those extra attributes and children. The patch prevents this by adding a flag to record when the interface is in the midst of being unregistered. When the flag is set, the attribute files and child devices will not be created. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> [2.6.27, 2.6.26, 2.6.25] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13slab: document SLAB_DESTROY_BY_RCUPeter Zijlstra
Explain this SLAB_DESTROY_BY_RCU thing... [hugh@veritas.com: add a pointer to comment in mm/slab.c] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-11-13HID: map macbook keys for "Expose" and "Dashboard"Henrik Rydberg
On macbooks there are specific keys for the user-space functions Expose and Dashboard, which currently has no counterpart in input.h. This patch adds KEY_SCALE and KEY_DASHBOARD, and maps the keyboard accordingly. Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-11-12net: ifdef struct sock::sk_async_wait_queueAlexey Dobriyan
Every user is under CONFIG_NET_DMA already, so ifdef field as well. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12Add c2 port supportRodolfo Giometti
C2port implements a two wire serial communication protocol (bit banging) designed to enable in-system programming, debugging, and boundary-scan testing on low pin-count Silicon Labs devices. Currently this code supports only flash programming through sysfs interface but extensions shoud be easy to add. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12rtc: rtc-wm8350: add support for WM8350 RTCMark Brown
This adds support for the RTC provided by the Wolfson Microelectronics WM8350. This driver was originally written by Graeme Gregory and Liam Girdwood, though it has been modified since then to update it to current mainline coding standards and for API completeness. [akpm@linux-foundation.org: s/schedule_timeout_interruptible/schedule_timeout_uninterruptible/ to prevent bogus timeout when signal_pending()] Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Liam Girdwood <linux@wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12remove ratelimt()Andrew Morton
It mistakenly assumes that a static local in an inlined function is a kernel-wide singleton. It also has no callers, so let's remove it. Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12atmel_lcdfb: change irq_base definition to allow error reportingNicolas Ferre
Changed because old the definition of unsigned long cannot be negative. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Reported-by: Roel Kluin <roel.kluin@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimer: clean up unused callback modes
2008-11-12Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (47 commits) ACPI: pci_link: remove acpi_irq_balance_set() interface fujitsu-laptop: Add DMI callback for Lifebook S6420 ACPI: EC: Don't do transaction from GPE handler in poll mode. ACPI: EC: lower interrupt storm treshold ACPICA: Use spinlock for acpi_{en|dis}able_gpe ACPI: EC: restart failed command ACPI: EC: wait for last write gpe ACPI: EC: make kernel messages more useful when GPE storm is detected ACPI: EC: revert msleep patch thinkpad_acpi: fingers off backlight if video.ko is serving this functionality sony-laptop: fingers off backlight if video.ko is serving this functionality msi-laptop: fingers off backlight if video.ko is serving this functionality fujitsu-laptop: fingers off backlight if video.ko is serving this functionality eeepc-laptop: fingers off backlight if video.ko is serving this functionality compal: fingers off backlight if video.ko is serving this functionality asus-acpi: fingers off backlight if video.ko is serving this functionality Acer-WMI: fingers off backlight if video.ko is serving this functionality ACPI video: if no ACPI backlight support, use vendor drivers ACPI: video: Ignore devices that aren't present in hardware Delete an unwanted return statement at evgpe.c ...
2008-11-12net: Cleanup of neighbour codeEric Dumazet
Using read_pnet() and write_pnet() in neighbour code ease the reading of code. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12hrtimer: clean up unused callback modesPeter Zijlstra
Impact: cleanup git grep HRTIMER_CB_IRQSAFE revealed half the callback modes are actually unused. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12net: ib_net pointer should depends on CONFIG_NET_NSEric Dumazet
We can shrink size of "struct inet_bind_bucket" by 50%, using read_pnet() and write_pnet() Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12net: Introduce read_pnet() and write_pnet() helpersEric Dumazet
This patch introduces two helpers that deal with reading and writing struct net pointers in various network structures. Their implementation depends on CONFIG_NET_NS For symmetry, both functions work with "struct net **pnet". Their usage should reduce the number of #ifdef CONFIG_NET_NS, without adding many helpers for each network structure that hold a "struct net *pointer" Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12dccp: Query supported CCIDsGerrit Renker
This provides a data structure to record which CCIDs are locally supported and three accessor functions: - a test function for internal use which is used to validate CCID requests made by the user; - a copy function so that the list can be used for feature-negotiation; - documented getsockopt() support so that the user can query capabilities. The data structure is a table which is filled in at compile-time with the list of available CCIDs (which in turn depends on the Kconfig choices). Using the copy function for cloning the list of supported CCIDs is useful for feature negotiation, since the negotiation is now with the full list of available CCIDs (e.g. {2, 3}) instead of the default value {2}. This means negotiation will not fail if the peer requests to use CCID3 instead of CCID2. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12serial: sh-sci: fix cannot work SH7723 SCIFAYoshihiro Shimoda
SH7723 has SCIFA. This module is similer SCI register map, but it has FIFO. So this patch adds new type(PORT_SCIFA) and change some type checking. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-11-11Merge branch 'ec' into releaseLen Brown
2008-11-11Merge branch 'processor-256' into releaseLen Brown
2008-11-11Merge branch 'video' into releaseLen Brown
Conflicts: Documentation/kernel-parameters.txt Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-11Merge branch 'misc' into releaseLen Brown
2008-11-11Merge branch 'bugzilla-11312' into releaseLen Brown
2008-11-11net: remove struct dst_entry::entry_sizeAlexey Dobriyan
Unused after kmem_cache_zalloc() conversion. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-11net: remove struct neigh_table::pdeAlexey Dobriyan
->pde isn't actually needed, since name is stashed in ->id. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/message/fusion/mptlan.c drivers/net/sfc/ethtool.c net/mac80211/debugfs_sta.c
2008-11-11ACPICA: Use spinlock for acpi_{en|dis}able_gpeAlexey Starikovskiy
Disabling gpe might interfere with gpe detection/handling, thus producing "interrupt not handled" errors. Ironically, disabling of GPE from interrupt context is already under spinlock, so only userspace needs to start using it. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-11Merge branch 'devel' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into tracing/urgent
2008-11-11ring-buffer: buffer record on/off switchSteven Rostedt
Impact: enable/disable ring buffer recording API added Several kernel developers have requested that there be a way to stop recording into the ring buffers with a simple switch that can also be enabled from userspace. This patch addes a new kernel API to the ring buffers called: tracing_on() tracing_off() When tracing_off() is called, all ring buffers will not be able to record into their buffers. tracing_on() will enable the ring buffers again. These two act like an on/off switch. That is, there is no counting of the number of times tracing_off or tracing_on has been called. A new file is added to the debugfs/tracing directory called tracing_on This allows for userspace applications to also flip the switch. echo 0 > debugfs/tracing/tracing_on disables the tracing. echo 1 > /debugfs/tracing/tracing_on enables it. Note, this does not disable or enable any tracers. It only sets or clears a flag that needs to be set in order for the ring buffers to write to their buffers. It is a global flag, and affects all ring buffers. The buffers start out with tracing_on enabled. There are now three flags that control recording into the buffers: tracing_on: which affects all ring buffer tracers. buffer->record_disabled: which affects an allocated buffer, which may be set if an anomaly is detected, and tracing is disabled. cpu_buffer->record_disabled: which is set by tracing_stop() or if an anomaly is detected. tracing_start can not reenable this if an anomaly occurred. The userspace debugfs/tracing/tracing_enabled is implemented with tracing_stop() but the user space code can not enable it if the kernel called tracing_stop(). Userspace can enable the tracing_on even if the kernel disabled it. It is just a switch used to stop tracing if a condition was hit. tracing_on is not for protecting critical areas in the kernel nor is it for stopping tracing if an anomaly occurred. This is because userspace can reenable it at any time. Side effect: With this patch, I discovered a dead variable in ftrace.c called tracing_on. This patch removes it. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
