This commit adds a CONFIG_RCU_EXPEDITE_BOOT Kconfig parameter
that emulates a very early boot rcu_expedite_gp(). A late-boot
call to rcu_end_inkernel_boot() will provide the corresponding
rcu_unexpedite_gp(). The late-boot call to rcu_end_inkernel_boot()
should be made just before init is spawned.
According to Arjan:
> To show the boot time, I'm using the timestamp of the "Write protecting"
> line, that's pretty much the last thing we print prior to ring 3 execution.
> A kernel with default RCU behavior (inside KVM, only virtual devices)
> looks like this:
> [ 0.038724] Write protecting the kernel read-only data: 10240k
> a kernel with expedited RCU (using the command line option, so that I
> don't have to recompile between measurements and thus am completely
> oranges-to-oranges)
> [ 0.031768] Write protecting the kernel read-only data: 10240k
> which, in percentage, is an 18% improvement.
Reported-by: Arjan van de Ven <arjan@linux.intel.com>
Tested-by: Arjan van de Ven <arjan@linux.intel.com>
Currently, expediting of normal synchronous grace-period primitives
(synchronize_rcu() and friends) is controlled by the rcu_expedited()
boot/sysfs parameter. This works well, but does not handle nesting.
This commit therefore provides rcu_expedite_gp() to enable expediting
and rcu_unexpedite_gp() to cancel a prior rcu_expedite_gp(), both of
which support nesting.
Pull more vfs updates from Al Viro:
"Assorted stuff from this cycle. The big ones here are multilayer
overlayfs from Miklos and beginning of sorting ->d_inode accesses out
from David"
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (51 commits)
autofs4 copy_dev_ioctl(): keep the value of ->size we'd used for allocation
procfs: fix race between symlink removals and traversals
debugfs: leave freeing a symlink body until inode eviction
Documentation/filesystems/Locking: ->get_sb() is long gone
trylock_super(): replacement for grab_super_passive()
fanotify: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions
Cachefiles: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions
VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)
SELinux: Use d_is_positive() rather than testing dentry->d_inode
Smack: Use d_is_positive() rather than testing dentry->d_inode
TOMOYO: Use d_is_dir() rather than d_inode and S_ISDIR()
Apparmor: Use d_is_positive/negative() rather than testing dentry->d_inode
Apparmor: mediated_filesystem() should use dentry->d_sb not inode->i_sb
VFS: Split DCACHE_FILE_TYPE into regular and special types
VFS: Add a fallthrough flag for marking virtual dentries
VFS: Add a whiteout dentry type
VFS: Introduce inode-getting helpers for layered/unioned fs environments
Infiniband: Fix potential NULL d_inode dereference
posix_acl: fix reference leaks in posix_acl_create
autofs4: Wrong format for printing dentry
Split DCACHE_FILE_TYPE into DCACHE_REGULAR_TYPE (dentries representing regular
files) and DCACHE_SPECIAL_TYPE (representing blockdev, chardev, FIFO and
socket files).
d_is_reg() and d_is_special() are added to detect these subtypes and
d_is_file() is left as the union of the two.
This allows a number of places that use S_ISREG(dentry->d_inode->i_mode) to
use d_is_reg(dentry) instead.
Add a DCACHE_FALLTHRU flag to indicate that, in a layered filesystem, this is
a virtual dentry that covers another one in a lower layer that should be used
instead. This may be recorded on medium if directory integration is stored
there.
The flag can be set with d_set_fallthru() and tested with d_is_fallthru().
Original-author: Valerie Aurora <vaurora@redhat.com>
Add DCACHE_WHITEOUT_TYPE and provide a d_is_whiteout() accessor function. A
d_is_miss() accessor is also added for ordinary cache misses and
d_is_negative() is modified to indicate either an ordinary miss or an enforced
miss (whiteout).
Introduce some function for getting the inode (and also the dentry) in an
environment where layered/unioned filesystems are in operation.
The problem is that we have places where we need *both* the union dentry and
the lower source or workspace inode or dentry available, but we can only have
a handle on one of them. Therefore we need to derive the handle to the other
from that.
The idea is to introduce an extra field in struct dentry that allows the union
dentry to refer to and pin the lower dentry.
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for MIPS:
- a number of fixes that didn't make the 3.19 release.
- a number of cleanups.
- preliminary support for Cavium's Octeon 3 SOCs which feature up to
48 MIPS64 R3 cores with FPU and hardware virtualization.
- support for MIPS R6 processors.
Revision 6 of the MIPS architecture is a major revision of the MIPS
architecture which does away with many of original sins of the
architecture such as branch delay slots. This and other changes in
R6 require major changes throughout the entire MIPS core
architecture code and make up for the lion share of this pull
request.
- finally some preparatory work for eXtendend Physical Address
support, which allows support of up to 40 bit of physical address
space on 32 bit processors"
[ Ahh, MIPS can't leave the PAE brain damage alone. It's like
every CPU architect has to make that mistake, but pee in the snow
by changing the TLA. But whether it's called PAE, LPAE or XPA,
it's horrid crud - Linus ]
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (114 commits)
MIPS: sead3: Corrected get_c0_perfcount_int
MIPS: mm: Remove dead macro definitions
MIPS: OCTEON: irq: add CIB and other fixes
MIPS: OCTEON: Don't do acknowledge operations for level triggered irqs.
MIPS: OCTEON: More OCTEONIII support
MIPS: OCTEON: Remove setting of processor specific CVMCTL icache bits.
MIPS: OCTEON: Core-15169 Workaround and general CVMSEG cleanup.
MIPS: OCTEON: Update octeon-model.h code for new SoCs.
MIPS: OCTEON: Implement DCache errata workaround for all CN6XXX
MIPS: OCTEON: Add little-endian support to asm/octeon/octeon.h
MIPS: OCTEON: Implement the core-16057 workaround
MIPS: OCTEON: Delete unused COP2 saving code
MIPS: OCTEON: Use correct instruction to read 64-bit COP0 register
MIPS: OCTEON: Save and restore CP2 SHA3 state
MIPS: OCTEON: Fix FP context save.
MIPS: OCTEON: Save/Restore wider multiply registers in OCTEON III CPUs
MIPS: boot: Provide more uImage options
MIPS: Remove unneeded #ifdef __KERNEL__ from asm/processor.h
MIPS: ip22-gio: Remove legacy suspend/resume support
mips: pci: Add ifdef around pci_proc_domain
Pull more NFS client updates from Trond Myklebust:
"Highlights include:
- Fix a use-after-free in decode_cb_sequence_args()
- Fix a compile error when #undef CONFIG_PROC_FS
- NFSv4.1 backchannel spinlocking issue
- Cleanups in the NFS unstable write code requested by Linus
- NFSv4.1 fix issues when the server denies our backchannel request
- Cleanups in create_session and bind_conn_to_session"
* tag 'nfs-for-3.20-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
NFSv4.1: Clean up bind_conn_to_session
NFSv4.1: Always set up a forward channel when binding the session
NFSv4.1: Don't set up a backchannel if the server didn't agree to do so
NFSv4.1: Clean up create_session
pnfs: Refactor the *_layout_mark_request_commit to use pnfs_layout_mark_request_commit
NFSv4: Kill unused nfs_inode->delegation_state field
NFS: struct nfs_commit_info.lock must always point to inode->i_lock
nfs: Can call nfs_clear_page_commit() instead
nfs: Provide and use helper functions for marking a page as unstable
SUNRPC: Always manipulate rpc_rqst::rq_bc_pa_list under xprt->bc_pa_lock
SUNRPC: Fix a compile error when #undef CONFIG_PROC_FS
NFSv4.1: Convert open-coded array allocation calls to kmalloc_array()
NFSv4.1: Fix a kfree() of uninitialised pointers in decode_cb_sequence_args
Pull followup block layer updates from Jens Axboe:
"Two things in this pull request:
- A block throttle oops fix (marked for stable) from Thadeu.
- The NVMe fixes/features queued up for 3.20, but merged later in the
process. From Keith. We should have gotten this merged earlier,
we're ironing out the kinks in the process. Will be ready for the
initial pull next series"
* 'for-linus' of git://git.kernel.dk/linux-block:
blk-throttle: check stats_cpu before reading it from sysfs
NVMe: Fix potential corruption on sync commands
NVMe: Remove unused variables
NVMe: Fix scsi mode select llbaa setting
NVMe: Fix potential corruption during shutdown
NVMe: Asynchronous controller probe
NVMe: Register management handle under nvme class
NVMe: Update SCSI Inquiry VPD 83h translation
NVMe: Metadata format support
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"The highlights this round include:
- Update vhost-scsi to support F_ANY_LAYOUT using mm/iov_iter.c
logic, and signal VERSION_1 support (MST + Viro + nab)
- Fix iscsi/iser-target to remove problematic active_ts_set usage
(Gavin Guo)
- Update iscsi/iser-target to support multi-sequence sendtargets
(Sagi)
- Fix original PR_APTPL_BUF_LEN 8k size limitation (Martin Svec)
- Add missing WRITE_SAME end-of-device sanity check (Bart)
- Check for LBA + sectors wrap-around in sbc_parse_cdb() (nab)
- Other various minor SPC/SBC compliance fixes based upon Ronnie
Sahlberg test suite (nab)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (32 commits)
target: Set LBPWS10 bit in Logical Block Provisioning EVPD
target: Fail UNMAP when emulate_tpu=0
target: Fail WRITE_SAME w/ UNMAP=1 when emulate_tpws=0
target: Add sanity checks for DPO/FUA bit usage
target: Perform PROTECT sanity checks for WRITE_SAME
target: Fail I/O with PROTECT bit when protection is unsupported
target: Check for LBA + sectors wrap-around in sbc_parse_cdb
target: Add missing WRITE_SAME end-of-device sanity check
iscsi-target: Avoid IN_LOGOUT failure case for iser-target
target: Fix PR_APTPL_BUF_LEN buffer size limitation
iscsi-target: Drop problematic active_ts_list usage
iscsi/iser-target: Support multi-sequence sendtargets text response
iser-target: Remove duplicate function names
vhost/scsi: potential memory corruption
vhost/scsi: Global tcm_vhost -> vhost_scsi rename
vhost/scsi: Drop left-over scsi_tcq.h include
vhost/scsi: Set VIRTIO_F_ANY_LAYOUT + VIRTIO_F_VERSION_1 feature bits
vhost/scsi: Add ANY_LAYOUT support in vhost_scsi_handle_vq
vhost/scsi: Add ANY_LAYOUT iov -> sgl mapping prerequisites
vhost/scsi: Change vhost_scsi_map_to_sgl to accept iov ptr + len
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull more input updates from Dmitry Torokhov:
"The second round of updates for the input subsystem.
Updates to ALPS an bfin_roraty drivers and a couple oother fixups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: psmouse - use IS_ENABLED instead of homegrown code
Input: bfin_rotary - introduce open and close methods
Input: bfin_rotary - convert to use managed resources
Input: bfin_rotary - use generic IO functions
Input: bfin_rotary - move pin lists into into platform data
Input: bfin_rotary - move platform header to linux/platform_data
Input: bfin_rotary - mark suspend and resume code as __maybe_unused
Input: bfin_rotary - fix potential oops in interrupt handler
Input: ALPS - move v7 packet info to Documentation and v6 packet info
Input: ALPS - fix confusing comment in protocol data
Input: ALPS - do not mix trackstick and external PS/2 mouse data
Input: ALPS - fix trackstick detection on some Dell Latitudes
Input: ALPS - consolidate setting protocol parameters
Input: ALPS - split protocol data from model info
Input: ALPS - make Rushmore a separate protocol
Input: ALPS - renumber protocol numbers
Input: adi - remove an unnecessary check
Input: pxa27x_keypad - remove an unneeded NULL check
Input: soc_button_array - use "Windows" key for "Home"
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull InfiniBand/RDMA updates from Roland Dreier:
- Re-enable on-demand paging changes with stable ABI
- Fairly large set of ocrdma HW driver fixes
- Some qib HW driver fixes
- Other miscellaneous changes
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (43 commits)
IB/qib: Add blank line after declaration
IB/qib: Fix checkpatch warnings
IB/mlx5: Enable the ODP capability query verb
IB/core: Add on demand paging caps to ib_uverbs_ex_query_device
IB/core: Add support for extended query device caps
RDMA/cxgb4: Don't hang threads forever waiting on WR replies
RDMA/ocrdma: Fix off by one in ocrdma_query_gid()
RDMA/ocrdma: Use unsigned for bit index
RDMA/ocrdma: Help gcc generate better code for ocrdma_srq_toggle_bit
RDMA/ocrdma: Update the ocrdma module version string
RDMA/ocrdma: set vlan present bit for user AH
RDMA/ocrdma: remove reference of ocrdma_dev out of ocrdma_qp structure
RDMA/ocrdma: Add support for interrupt moderation
RDMA/ocrdma: Honor return value of ocrdma_resolve_dmac
RDMA/ocrdma: Allow expansion of the SQ CQEs via buddy CQ expansion of the QP
RDMA/ocrdma: Discontinue support of RDMA-READ-WITH-INVALIDATE
RDMA/ocrdma: Host crash on destroying device resources
RDMA/ocrdma: Report correct state in ibv_query_qp
RDMA/ocrdma: Debugfs enhancments for ocrdma driver
RDMA/ocrdma: Report correct count of interrupt vectors while registering ocrdma device
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Summary:
- legacy PM code removed from the core, there were no users anymore
(thanks to Lars-Peter Clausen)
- new driver for Broadcom iProc
- bigger driver updates for designware, rk3x, cadence, ocores
- a bunch of smaller updates and bugfixes"
* 'i2c/for-3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (31 commits)
i2c: ocores: rework clk code to handle NULL cookie
i2c: designware-baytrail: another fixup for proper Kconfig dependencies
i2c: fix reference to functionality constants definition
i2c: iproc: Add Broadcom iProc I2C Driver
i2c: designware-pci: update Intel copyright line
i2c: ocores: add common clock support
i2c: hix5hd2: add COMPILE_TEST
i2c: clarify comments about the dev_released completion
i2c: ocores: fix clock-frequency binding usage
i2c: tegra: Maintain CPU endianness
i2c: designware-baytrail: use proper Kconfig dependencies
i2c: designware: Do not calculate SCL timing parameters needlessly
i2c: do not try to load modules for of-registered devices
i2c: designware: Add Intel Baytrail PMIC I2C bus support
i2c: designware: Add i2c bus locking support
of: i2c: Add i2c-mux-idle-disconnect DT property to PCA954x mux driver
i2c: designware: use {readl|writel}_relaxed instead of readl/writel
i2c: designware-pci: no need to provide clk_khz
i2c: designware-pci: remove Moorestown support
i2c: imx: whitespace and checkpatch cleanup
git://git.linaro.org/people/mike.turquette/linux
Pull clock framework updates from Mike Turquette:
"The clock framework changes contain the usual driver additions,
enhancements and fixes mostly for ARM32, ARM64, MIPS and Power-based
devices.
Additionally the framework core underwent a bit of surgery with two
major changes:
- The boundary between the clock core and clock providers (e.g clock
drivers) is now more well defined with dedicated provider helper
functions. struct clk no longer maps 1:1 with the hardware clock
but is a true per-user cookie which helps us tracker users of
hardware clocks and debug bad behavior.
- The addition of rate constraints for clocks. Rate ranges are now
supported which are analogous to the voltage ranges in the
regulator framework.
Unfortunately these changes to the core created some breakeage. We
think we fixed it all up but for this reason there are lots of last
minute commits trying to undo the damage"
* tag 'clk-for-linus-3.20' of git://git.linaro.org/people/mike.turquette/linux: (113 commits)
clk: Only recalculate the rate if needed
Revert "clk: mxs: Fix invalid 32-bit access to frac registers"
clk: qoriq: Add support for the platform PLL
powerpc/corenet: Enable CLK_QORIQ
clk: Replace explicit clk assignment with __clk_hw_set_clk
clk: Add __clk_hw_set_clk helper function
clk: Don't dereference parent clock if is NULL
MIPS: Alchemy: Remove bogus args from alchemy_clk_fgcs_detr
clkdev: Always allocate a struct clk and call __clk_get() w/ CCF
clk: shmobile: div6: Avoid division by zero in .round_rate()
clk: omap: compile legacy omap3 clocks conditionally
clkdev: Export clk_register_clkdev
clk: Add rate constraints to clocks
clk: remove clk-private.h
pci: xgene: do not use clk-private.h
arm: omap2+ remove dead clock code
clk: Make clk API return per-user struct clk instances
clk: tegra: Define PLLD_DSI and remove dsia(b)_mux
clk: tegra: Add support for the Tegra132 CAR IP block
Pull VFIO updates from Alex Williamson:
- IOMMU updates based on trace analysis
- VFIO device request interface
* tag 'vfio-v3.20-rc1' of git://github.com/awilliam/linux-vfio:
vfio-pci: Add device request interface
vfio-pci: Generalize setup of simple eventfds
vfio: Add and use device request op for vfio bus drivers
vfio: Tie IOMMU group reference to vfio group
vfio: Add device tracking during unbind
vfio/type1: Add conditional rescheduling
vfio/type1: Chunk contiguous reserved/invalid page mappings
vfio/type1: DMA unmap chunking
Pull scheduler fixes from Ingo Molnar:
"Thiscontains misc fixes: preempt_schedule_common() and io_schedule()
recursion fixes, sched/dl fixes, a completion_done() revert, two
sched/rt fixes and a comment update patch"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/rt: Avoid obvious configuration fail
sched/autogroup: Fix failure to set cpu.rt_runtime_us
sched/dl: Do update_rq_clock() in yield_task_dl()
sched: Prevent recursion in io_schedule()
sched/completion: Serialize completion_done() with complete()
sched: Fix preempt_schedule_common() triggering tracing recursion
sched/dl: Prevent enqueue of a sleeping task in dl_task_timer()
sched: Make dl_task_time() use task_rq_lock()
sched: Clarify ordering between task_rq_lock() and move_queued_task()
The use of READ_ONCE() causes lots of warnings witht he pending paravirt
spinlock fixes, because those ends up having passing a member to a
'const' structure to READ_ONCE().
There should certainly be nothing wrong with using READ_ONCE() with a
const source, but the helper function __read_once_size() would cause
warnings because it would drop the 'const' qualifier, but also because
the destination would be marked 'const' too due to the use of 'typeof'.
Use a union of types in READ_ONCE() to avoid this issue.
Also make sure to use parenthesis around the macro arguments to avoid
possible operator precedence issues.
Tested-by: Ingo Molnar <mingo@kernel.org>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
into for-linus
Merge 3.20 NVMe changes from Keith.
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb
Pull kgdb/kdb updates from Jason Wessel:
"KGDB/KDB New:
- KDB: improved searching
- No longer enter debug core on panic if panic timeout is set
KGDB/KDB regressions / cleanups
- fix pdf doc build errors
- prevent junk characters on kdb console from printk levels"
* tag 'for_linux-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb:
kgdb, docs: Fix <para> pdfdocs build errors
debug: prevent entering debug mode on panic/exception.
kdb: Const qualifier for kdb_getstr's prompt argument
kdb: Provide forward search at more prompt
kdb: Fix a prompt management bug when using | grep
kdb: Remove stack dump when entering kgdb due to NMI
kdb: Avoid printing KERN_ levels to consoles
kdb: Fix off by one error in kdb_cpu()
kdb: fix incorrect counts in KDB summary command output
git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal
Pull more thermal managament updates from Zhang Rui:
"Specifics:
- Exynos thermal driver refactoring. Several cleanups, code
optimization, unused symbols removal, and unused feature removal in
Exynos thermal driver. Thanks Lukasz for this effort.
- Exynos thermal driver support to OF thermal. After the code
refactoring, the driver earned the support to OF thermal. Chip
thermal data were moved from driver code to DTS, reducing the code
footprint. Thanks Lukasz for this.
- After receiving the OF thermal support, the exynos thermal driver
now must allow modular build. Thanks Arnd for detecting, reporting
and fixing this.
- Exynos thermal driver support to Exynos 7 SoC. Thanks Abhilash for
this.
- Accurate temperature reporting on Rockchip thermal driver, thanks
to Caesar.
- Fix on how OF thermal enables its zones, thanks Lukasz for fixing.
- Fixes in OF thermal examples under Documentation/. Thanks Srinivas
for fixing"
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal:
thermal: exynos: Add TMU support for Exynos7 SoC
dts: Documentation: Add documentation for Exynos7 SoC thermal bindings
cpufreq: exynos: allow modular build
thermal: Fix examples in DT documentation
thermal: exynos: Correct sanity check at exynos_report_trigger() function
thermal: Kconfig: Remove config for not used EXYNOS_THERMAL_CORE
thermal: exynos: Remove exynos_tmu_data.c file
thermal: rockchip: make temperature reporting much more accurate
thermal: exynos: Remove exynos_thermal_common.[c|h] files
thermal: samsung: core: Exynos TMU rework to use device tree for configuration
dts: Documentation: Update exynos-thermal.txt example for Exynos5440
dts: Documentation: Extending documentation entry for exynos-thermal
cpufreq: exynos: Use device tree to determine if cpufreq cooling should be registered
thermal: exynos: Modify exynos thermal code to use device tree for cpu cooling configuration
thermal: exynos: Provide thermal_exynos.h file to be included in device tree files
thermal: exynos: cosmetic: Correct comment format
thermal: of: Enable thermal_zoneX when sensor is correctly added
The driver has to end unreturned commands at some point even if the
controller has not provided a completion. The driver tried to be safe by
deleting IO queues prior to ending all unreturned commands. That should
cause the controller to internally abort inflight commands, but IO queue
deletion request does not have to be successful, so all bets are off. We
still have to make progress, so to be extra safe, this patch doesn't
clear a queue to release the dma mapping for a command until after the
pci device has been disabled.
This patch removes the special handling during device initialization
so controller recovery can be done all the time. This is possible since
initialization is not inlined with pci probe anymore.
Reported-by: Nilish Choudhury <nilesh.choudhury@oracle.com>
Signed-off-by: Keith Busch <keith.busch@intel.com>
This performs the longest parts of nvme device probe in scheduled work.
This speeds up probe significantly when multiple devices are in use.
This creates a new class type for nvme devices to register their
management character devices with. This is so we do not rely on miscdev
to provide enough minors for as many nvme devices some people plan to
use. The previous limit was approximately 60 NVMe controllers, depending
on the platform and kernel. Now the limit is 1M, which ought to be enough
for anybody.
Since we have a new device class, it makes sense to attach the block
devices under this as well, so part of this patch moves the management
handle initialization prior to the namespaces discovery.
The original translation created collisions on Inquiry VPD 83 for many
existing devices. Newer specifications provide other ways to translate
based on the device's version can be used to create unique identifiers.
Version 1.1 provides an EUI64 field that uniquely identifies each
namespace, and 1.2 added the longer NGUID field for the same reason.
Both follow the IEEE EUI format and readily translate to the SCSI device
identification EUI designator type 2h. For devices implementing either,
the translation will use this type, defaulting to the EUI64 8-byte type if
implemented then NGUID's 16 byte version if not. If neither are provided,
the 1.0 translation is used, and is updated to use the SCSI String format
to guarantee a unique identifier.
Knowing when to use the new fields depends on the nvme controller's
revision. The NVME_VS macro was not decoding this correctly, so that is
fixed in this patch and moved to a more appropriate place.
Since the Identify Namespace structure required an update for the NGUID
field, this patch adds the remaining new 1.2 fields to the structure.
Adds support for NVMe metadata formats and exposes block devices for
all namespaces regardless of their format. Namespace formats that are
unusable will have disk capacity set to 0, but a handle to the block
device is created to simplify device management. A namespace is not
usable when the format requires host interleave block and metadata in
single buffer, has no provisioned storage, or has better data but failed
to register with blk integrity.
The namespace has to be scanned in two phases to support separate
metadata formats. The first establishes the sector size and capacity
prior to invoking add_disk. If metadata is required, the capacity will
be temporarilly set to 0 until it can be revalidated and registered with
the integrity extenstions after add_disk completes.
The driver relies on the integrity extensions to provide the metadata
buffer. NVMe requires this be a single physically contiguous region,
so only one integrity segment is allowed per command. If the metadata
is used for T10 PI, the driver provides mappings to save and restore
the reftag physical block translation. The driver provides no-op
functions for generate and verify if metadata is not used for protection
information. This way the setup is always provided by the block layer.
If a request does not supply a required metadata buffer, the command
is failed with bad address. This could only happen if a user manually
disables verify/generate on such a disk. The only exception to where
this is okay is if the controller is capable of stripping/generating
the metadata, which is possible on some types of formats.
The metadata scatter gather list now occupies the spot in the nvme_iod
that used to be used to link retryable IOD's, but we don't do that
anymore, so the field was unused.
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs updates from Chris Mason:
"This pull is mostly cleanups and fixes:
- The raid5/6 cleanups from Zhao Lei fixup some long standing warts
in the code and add improvements on top of the scrubbing support
from 3.19.
- Josef has round one of our ENOSPC fixes coming from large btrfs
clusters here at FB.
- Dave Sterba continues a long series of cleanups (thanks Dave), and
Filipe continues hammering on corner cases in fsync and others
This all was held up a little trying to track down a use-after-free in
btrfs raid5/6. It's not clear yet if this is just made easier to
trigger with this pull or if its a new bug from the raid5/6 cleanups.
Dave Sterba is the only one to trigger it so far, but he has a
consistent way to reproduce, so we'll get it nailed shortly"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (68 commits)
Btrfs: don't remove extents and xattrs when logging new names
Btrfs: fix fsync data loss after adding hard link to inode
Btrfs: fix BUG_ON in btrfs_orphan_add() when delete unused block group
Btrfs: account for large extents with enospc
Btrfs: don't set and clear delalloc for O_DIRECT writes
Btrfs: only adjust outstanding_extents when we do a short write
btrfs: Fix out-of-space bug
Btrfs: scrub, fix sleep in atomic context
Btrfs: fix scheduler warning when syncing log
Btrfs: Remove unnecessary placeholder in btrfs_err_code
btrfs: cleanup init for list in free-space-cache
btrfs: delete chunk allocation attemp when setting block group ro
btrfs: clear bio reference after submit_one_bio()
Btrfs: fix scrub race leading to use-after-free
Btrfs: add missing cleanup on sysfs init failure
Btrfs: fix race between transaction commit and empty block group removal
btrfs: add more checks to btrfs_read_sys_array
btrfs: cleanup, rename a few variables in btrfs_read_sys_array
btrfs: add checks for sys_chunk_array sizes
btrfs: more superblock checks, lower bounds on devices and sectorsize/nodesize
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph changes from Sage Weil:
"On the RBD side, there is a conversion to blk-mq from Christoph,
several long-standing bug fixes from Ilya, and some cleanup from
Rickard Strandqvist.
On the CephFS side there is a long list of fixes from Zheng, including
improved session handling, a few IO path fixes, some dcache management
correctness fixes, and several blocking while !TASK_RUNNING fixes.
The core code gets a few cleanups and Chaitanya has added support for
TCP_NODELAY (which has been used on the server side for ages but we
somehow missed on the kernel client).
There is also an update to MAINTAINERS to fix up some email addresses
and reflect that Ilya and Zheng are doing most of the maintenance for
RBD and CephFS these days. Do not be surprised to see a pull request
come from one of them in the future if I am unavailable for some
reason"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (27 commits)
MAINTAINERS: update Ceph and RBD maintainers
libceph: kfree() in put_osd() shouldn't depend on authorizer
libceph: fix double __remove_osd() problem
rbd: convert to blk-mq
ceph: return error for traceless reply race
ceph: fix dentry leaks
ceph: re-send requests when MDS enters reconnecting stage
ceph: show nocephx_require_signatures and notcp_nodelay options
libceph: tcp_nodelay support
rbd: do not treat standalone as flatten
ceph: fix atomic_open snapdir
ceph: properly mark empty directory as complete
client: include kernel version in client metadata
ceph: provide seperate {inode,file}_operations for snapdir
ceph: fix request time stamp encoding
ceph: fix reading inline data when i_size > PAGE_SIZE
ceph: avoid block operation when !TASK_RUNNING (ceph_mdsc_close_sessions)
ceph: avoid block operation when !TASK_RUNNING (ceph_get_caps)
ceph: avoid block operation when !TASK_RUNNING (ceph_mdsc_sync)
rbd: fix error paths in rbd_dev_refresh()
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal managament updates from Zhang Rui:
"Specifics:
- Abstract the code and introduce helper functions for all int340x
thermal drivers. From: Srinivas Pandruvada.
- Reorganize the ACPI LPAT table support code so that it can be
shared for both ACPI PMIC driver and int340x thermal driver.
- Add support for Braswell in intel_soc_dts thermal driver.
- a couple of small fixes/cleanups for step_wise governor and int340x
thermal driver"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux:
Thermal/int340x_thermal: remove unused uuids.
thermal: step_wise: spelling fixes
thermal: int340x: fix sparse warning
Thermal/int340x: LPAT conversion for temperature
ACPI / PMIC: Use common LPAT table handling functions
ACPI / LPAT: Common table processing functions
thermal: Intel SoC DTS: Add Braswell support
Thermal/int340x/int3402: Provide notification support
Thermal/int340x/processor_thermal: Add thermal zone support
Thermal/int340x/int3403: Use int340x thermal API
Thermal/int340x/int3402: Use int340x thermal API
Thermal/int340x: Add common thermal zone handler
Currently when kdb traps printk messages then the raw log level prefix
(consisting of '\001' followed by a numeral) does not get stripped off
before the message is issued to the various I/O handlers supported by
kdb. This causes annoying visual noise as well as causing problems
grepping for ^. It is also a change of behaviour compared to normal usage
of printk() usage. For example <SysRq>-h ends up with different output to
that of kdb's "sr h".
This patch addresses the problem by stripping log levels from messages
before they are issued to the I/O handlers. printk() which can also
act as an i/o handler in some cases is special cased; if the caller
provided a log level then the prefix will be preserved when sent to
printk().
The addition of non-printable characters to the output of kdb commands is a
regression, albeit and extremely elderly one, introduced by commit
04d2c8c83d0e ("printk: convert the format for KERN_<LEVEL> to a 2 byte
pattern"). Note also that this patch does *not* restore the original
behaviour from v3.5. Instead it makes printk() from within a kdb command
display the message without any prefix (i.e. like printk() normally does).
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Joe Perches <joe@perches.com>
Cc: stable@vger.kernel.org
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
TCP_NODELAY socket option set on connection sockets,
disables Nagle’s algorithm and improves latency characteristics.
tcp_nodelay(default)/notcp_nodelay option flags provided to
enable/disable setting the socket option.
Signed-off-by: Chaitanya Huilgol <chaitanya.huilgol@sandisk.com>
[idryomov@redhat.com: NO_TCP_NODELAY -> TCP_NODELAY, minor adjustments]
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
mark session as readonly and wake up all cap waiters.
Signed-off-by: Yan, Zheng <zyan@redhat.com>
On Mon, Dec 22, 2014 at 5:35 PM, Sage Weil <sage@newdream.net> wrote:
> On Mon, 22 Dec 2014, Ilya Dryomov wrote:
>> Actually, pool op stuff has been unused for over two years - looks like
>> it was added for rbd create_snap and that got ripped out in 2012. It's
>> unlikely we'd ever need to manage pools or snaps from the kernel client
>> so I think it makes sense to nuke it. Sage?
> Yep!
We don't need to fake up an entire session in order retrieve the arguments.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Don't decode directly into the shared struct session
Pull file locking fixes from Jeff Layton:
"A small set of patches to fix problems with the recent file locking
changes that we discussed earlier this week"
* tag 'locks-v3.20-2' of git://git.samba.org/jlayton/linux:
locks: fix list insertion when lock is split in two
locks: remove conditional lock release in middle of flock_lock_file
locks: only remove leases associated with the file being closed
Revert "locks: keep a count of locks on the flctx lists"
After the clk API change to return a per-user clock instance, both the
struct clk_core and struct clk pointers from the hw clock needs to be
assigned to clock that share the same state.
In the future the struct clk_core will be removed and this is going to
change again so to avoid having to change the assignments twice in all
the drivers, add a helper function to have an indirection level.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Michael Turquette <mturquette@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"OK, this has the big virtio 1.0 implementation, as specified by OASIS.
On top of tht is the major rework of lguest, to use PCI and virtio
1.0, to double-check the implementation.
Then comes the inevitable fixes and cleanups from that work"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (80 commits)
virtio: don't set VIRTIO_CONFIG_S_DRIVER_OK twice.
virtio_net: unconditionally define struct virtio_net_hdr_v1.
tools/lguest: don't use legacy definitions for net device in example launcher.
virtio: Don't expose legacy net features when VIRTIO_NET_NO_LEGACY defined.
tools/lguest: use common error macros in the example launcher.
tools/lguest: give virtqueues names for better error messages
tools/lguest: more documentation and checking of virtio 1.0 compliance.
lguest: don't look in console features to find emerg_wr.
tools/lguest: don't start devices until DRIVER_OK status set.
tools/lguest: handle indirect partway through chain.
tools/lguest: insert driver references from the 1.0 spec (4.1 Virtio Over PCI)
tools/lguest: insert device references from the 1.0 spec (4.1 Virtio Over PCI)
tools/lguest: rename virtio_pci_cfg_cap field to match spec.
tools/lguest: fix features_accepted logic in example launcher.
tools/lguest: handle device reset correctly in example launcher.
virtual: Documentation: simplify and generalize paravirt_ops.txt
lguest: remove NOTIFY call and eventfd facility.
lguest: remove NOTIFY facility from demonstration launcher.
lguest: use the PCI console device's emerg_wr for early boot messages.
lguest: always put console in PCI slot #1.
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"Changes to existing drivers:
- fixr platform device collision; da9052, wm8994-core
- regmap configuration amendments; tps65218
- fix runtime PM deadlock; rtsx_usb
- remove unused/superfluous code; db8500-prcmu, omap-usb-host
- enable watchdog timer; lpc_sch
- add start/stop RX URBs helpers; dln2
- remove platform device (DT only); max77686, max77802
- support suspend and resume; dln2
- add Device Tree support; da9063
- extra error checking; intel_soc_pmic
- const'ify all the things; 88pm860x, hi6421-pmic, intel_soc_pmic,
max77686, lm3533, retu, pcf50633,
davinci_voicecodec, smsc-ece1099,
tps65218, mc13xxx, tps65217, twl-core,
twl6040
New drivers/supported devices:
- new driver for Richtek RT5033
- new driver for DA9150 Charger and FuelGauge
- new driver for Qualcomm Resource Power Manager (RPM)
- add support for the ir-clk into sun6i-prcm
- add support for FuelGauge into axp20x"
* tag 'mfd-for-linus-3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (32 commits)
mfd: intel_soc_pmic: Add missing error check for devm_kzalloc
mfd: rtsx_usb: Defer autosuspend while card exists
mfd: devicetree: Add bindings for DA9063
mfd: da9063: Add device tree support
regulator: qcom-rpm: Add missing state flag in call to RPM
mfd: qcom-rpm: Driver for the Qualcomm RPM
mfd: devicetree: bindings: Add Qualcomm RPM DT binding
mfd: max77686/802: Remove support for board files
mfd: omap-usb-host: Remove some unused functions
mfd: twl6040: Constify struct regmap_config and reg_default array
mfd: twl-core: Constify struct regmap_config and reg_default array
mfd: tps65217: Constify struct regmap_config
mfd: mc13xxx: i2c/spi: Constify struct regmap_config
mfd: tps65218: Constify struct regmap_config
mfd: smsc-ece1099: Constify struct regmap_config
mfd: davinci_voicecodec: Constify struct regmap_config
mfd: pcf50633: Constify struct regmap_config
mfd: retu: Constify struct regmap_config
mfd: lm3533: Constify struct regmap_config
mfd: max77686: Constify struct regmap_config
Pull dmaengine updates from Vinod Koul:
"This update brings:
- the big cleanup up by Maxime for device control and slave
capabilities. This makes the API much cleaner.
- new IMG MDC driver by Andrew
- new Renesas R-Car Gen2 DMA Controller driver by Laurent along with
bunch of fixes on rcar drivers
- odd fixes and updates spread over driver"
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (130 commits)
dmaengine: pl330: add DMA_PAUSE feature
dmaengine: pl330: improve pl330_tx_status() function
dmaengine: rcar-dmac: Disable channel 0 when using IOMMU
dmaengine: rcar-dmac: Work around descriptor mode IOMMU errata
dmaengine: rcar-dmac: Allocate hardware descriptors with DMAC device
dmaengine: rcar-dmac: Fix oops due to unintialized list in error ISR
dmaengine: rcar-dmac: Fix spinlock issues in interrupt
dmaenegine: edma: fix sparse warnings
dmaengine: rcar-dmac: Fix uninitialized variable usage
dmaengine: shdmac: extend PM methods
dmaengine: shdmac: use SET_RUNTIME_PM_OPS()
dmaengine: pl330: fix bug that cause start the same descs in cyclic
dmaengine: at_xdmac: allow muliple dwidths when doing slave transfers
dmaengine: at_xdmac: simplify channel configuration stuff
dmaengine: at_xdmac: introduce save_cc field
dmaengine: at_xdmac: wait for in-progress transaction to complete after pausing a channel
ioat: fail self-test if wait_for_completion times out
dmaengine: dw: define DW_DMA_MAX_NR_MASTERS
dmaengine: dw: amend description of dma_dev field
dmatest: move src_off, dst_off, len inside loop
Pull watchdog updates from Wim Van Sebroeck:
"This adds the following new drivers:
- ImgTec PDC Watchdog Timer Driver,
- Mediatek SoC integrated watchdog
Add support for BCM5301X, IT8783, NCT6791 and NCT6792 WDT's
Add bcm47xx_wdt and da9063 restart handlers and contains overall
improvements and fixes"
* git://www.linux-watchdog.org/linux-watchdog:
watchdog: bcm47xx_wdt.c: allow enabling on BCM5301X arch
watchdog: jz4740: Add DT support
dt: watchdog: Add DT binding documentation for jz4740 watchdog timer
watchdog: dw_wdt: Try to get a 30 second watchdog by default
watchdog: dw_wdt: pat the watchdog before enabling it
watchdog: w83627hf_wdt: Add support for NCT6791 and NCT6792
watchdog: bcm47xx_wdt.c: add restart handler support
watchdog: gpio_wdt: Add "always_running" feature to GPIO watchdog
watchdog: da9063: Add restart handler support
ARM: mediatek: dts: Add bindings for watchdog
watchdog: Add driver for Mediatek watchdog
watchdog: Fix omap watchdogs to enable the magic close bit
watchdog: rt2880_wdt: minor clean up
watchdog: hpwdt: Fix initialization message in hpwdt.c
watchdog: it87_wdt: add IT8783 ID
watchdog: imx2: Constify struct regmap_config and watchdog_ops
DT: watchdog: Add ImgTec PDC Watchdog Timer binding documentation
watchdog: ImgTec PDC Watchdog Timer Driver
Add on-demand paging capabilities reporting to the extended query device verb.
Yann Droneaud writes:
Note: as offsetof() is used to retrieve the size of the lower chunk
of the response, beware that it only works if the upper chunk
is right after, without any implicit padding. And, as the size of
the latter chunk is added to the base size, implicit padding at the
end of the structure is not taken in account. Both point must be
taken in account when extending the uverbs functionalities.
Signed-off-by: Haggai Eran <haggaie@mellanox.com>
Reviewed-by: Yann Droneaud <ydroneaud@opteya.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Add extensible query device capabilities verb to allow adding new features.
ib_uverbs_ex_query_device is added and copy_query_dev_fields is used to copy
capability fields to be used by both ib_uverbs_query_device and
ib_uverbs_ex_query_device.
Following the discussion about this patch [1], the code now validates
the command's comp_mask is zero, returning -EINVAL for unknown values,
in order to allow extending the verb in the future.
The verb also checks the user-space provided response buffer size and
only fills in capabilities that will fit in the buffer. In attempt to
follow the spirit of presentation [2] by Tzahi Oved that was presented
during OpenFabrics Alliance International Developer Workshop 2013, the
comp_mask bits will only describe which fields are valid. Furthermore,
fields that can simply be cleared when they are not supported, do not
require a comp_mask bit at all. The verb returns a response_length
field containing the actual number of bytes written by the kernel, so
that a newer version running on an older kernel can tell which fields
were actually returned.
[1] [PATCH v1 0/5] IB/core: extended query device caps cleanup for v3.19
http://thread.gmane.org/gmane.linux.kernel.api/7889/
[2] https://www.openfabrics.org/images/docs/2013_Dev_Workshop/Tues_0423/2013_Workshop_Tues_0830_Tzahi_Oved-verbs_extensions_ofa_2013-tzahio.pdf
Signed-off-by: Eli Cohen <eli@mellanox.com>
Pull MTD updates from Brian Norris:
"NAND:
- Add new Hisilicon NAND driver for Hip04
- Add default reboot handler, to ensure all outstanding erase
transactions complete in time
- jz4740: convert to use GPIO descriptor API
- Atmel: add support for sama5d4
- Change default bitflip threshold to 75% of correction strength
- Miscellaneous cleanups and bugfixes
SPI NOR:
- Freescale QuadSPI:
- Fix a few probe() and remove() issues
- Add a MAINTAINERS entry for this driver
- Tweak transfer size to increase read performance
- Add suspend/resume support
- Add Micron quad I/O support
- ST FSM SPI: miscellaneous fixes
JFFS2:
- gracefully handle corrupted 'offset' field found on flash
Other:
- bcm47xxpart: add tweaks for a few new devices
- mtdconcat: set return lengths properly for mtd_write_oob()
- map_ram: enable use with mtdoops
- maps: support fallback to ROM/UBI for write-protected NOR flash"
* tag 'for-linus-20150216' of git://git.infradead.org/linux-mtd: (46 commits)
mtd: hisilicon: && vs & typo
jffs2: fix handling of corrupted summary length
mtd: hisilicon: add device tree binding documentation
mtd: hisilicon: add a new NAND controller driver for hisilicon hip04 Soc
mtd: avoid registering reboot notifier twice
mtd: concat: set the return lengths properly
mtd: kconfig: replace PPC_OF with PPC
mtd: denali: remove unnecessary stubs
mtd: nand: remove redundant local variable
MAINTAINERS: add maintainer entry for FREESCALE QUAD SPI driver
mtd: fsl-quadspi: improve read performance by increase AHB transfer size
mtd: fsl-quadspi: Remove unnecessary 'map_failed' label
mtd: fsl-quadspi: Remove unneeded success/error messages
mtd: fsl-quadspi: Fix the error paths
mtd: nand: omap: drop condition with no effect
mtd: nand: jz4740: Convert to GPIO descriptor API
mtd: nand: Request strength instead of bytes for soft BCH
mtd: nand: default bitflip-reporting threshold to 75% of correction strength
mtd: atmel_nand: introduce a new compatible string for sama5d4 chip
mtd: atmel_nand: return max bitflips in all sectors in pmecc_correction()
Merge cleanups requested by Linus.
* cleanups: (3 commits)
io_schedule() calls blk_flush_plug() which, depending on the
contents of current->plug, can initiate arbitrary blk-io requests.
Note that this contrasts with blk_schedule_flush_plug() which requires
all non-trivial work to be handed off to a separate thread.
This makes it possible for io_schedule() to recurse, and initiating
block requests could possibly call mempool_alloc() which, in times of
memory pressure, uses io_schedule().
Apart from any stack usage issues, io_schedule() will not behave
correctly when called recursively as delayacct_blkio_start() does
not allow for repeated calls.
So:
- use ->in_iowait to detect recursion. Set it earlier, and restore
it to the old value.
- move the call to "raw_rq" after the call to blk_flush_plug().
As this is some sort of per-cpu thing, we want some chance that
we are on the right CPU
- When io_schedule() is called recurively, use blk_schedule_flush_plug()
which cannot further recurse.
- as this makes io_schedule() a lot more complex and as io_schedule()
must match io_schedule_timeout(), but all the changes in io_schedule_timeout()
and make io_schedule a simple wrapper for that.
Signed-off-by: NeilBrown <neilb@suse.de>
[ Moved the now rudimentary io_schedule() into sched.h. ]
Cc: Tony Battersby <tonyb@cybernetics.com>
Link: http://lkml.kernel.org/r/20150213162600.059fffb2@notabene.brown
Pull networking updates from David Miller:
1) Missing netlink attribute validation in nft_lookup, from Patrick
McHardy.
2) Restrict ipv6 partial checksum handling to UDP, since that's the
only case it works for. From Vlad Yasevich.
3) Clear out silly device table sentinal macros used by SSB and BCMA
drivers. From Joe Perches.
4) Make sure the remote checksum code never creates a situation where
the remote checksum is applied yet the tunneling metadata describing
the remote checksum transformation is still present. Otherwise an
external entity might see this and apply the checksum again. From
Tom Herbert.
5) Use msecs_to_jiffies() where applicable, from Nicholas Mc Guire.
6) Don't explicitly initialize timer struct fields, use setup_timer()
and mod_timer() instead. From Vaishali Thakkar.
7) Don't invoke tg3_halt() without the tp->lock held, from Jun'ichi
Nomura.
8) Missing __percpu annotation in ipvlan driver, from Eric Dumazet.
9) Don't potentially perform skb_get() on shared skbs, also from Eric
Dumazet.
10) Fix COW'ing of metrics for non-DST_HOST routes in ipv6, from Martin
KaFai Lau.
11) Fix merge resolution error between the iov_iter changes in vhost and
some bug fixes that occurred at the same time. From Jason Wang.
12) If rtnl_configure_link() fails we have to perform a call to
->dellink() before unregistering the device. From WANG Cong.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (39 commits)
net: dsa: Set valid phy interface type
rtnetlink: call ->dellink on failure when ->newlink exists
com20020-pci: add support for eae single card
vhost_net: fix wrong iter offset when setting number of buffers
net: spelling fixes
net/core: Fix warning while make xmldocs caused by dev.c
net: phy: micrel: disable NAND-tree for KSZ8021, KSZ8031, KSZ8051, KSZ8081
ipv6: fix ipv6_cow_metrics for non DST_HOST case
openvswitch: Fix key serialization.
r8152: restore hw settings
hso: fix rx parsing logic when skb allocation fails
tcp: make sure skb is not shared before using skb_get()
bridge: netfilter: Move sysctl-specific error code inside #ifdef
ipv6: fix possible deadlock in ip6_fl_purge / ip6_fl_gc
ipvlan: add a missing __percpu pcpu_stats
tg3: Hold tp->lock before calling tg3_halt() from tg3_init_one()
bgmac: fix device initialization on Northstar SoCs (condition typo)
qlcnic: Delete existing multicast MAC list before adding new
net/mlx5_core: Fix configuration of log_uar_page_sz
sunvnet: don't change gso data on clones
Pull lazytime mount option support from Al Viro:
"Lazytime stuff from tytso"
* 'lazytime' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
ext4: add optimization for the lazytime mount option
vfs: add find_inode_nowait() function
vfs: add support for a lazytime mount option
Pull iov_iter updates from Al Viro:
"More iov_iter work - missing counterpart of iov_iter_init() for
bvec-backed ones and vfs_read_iter()/vfs_write_iter() - wrappers for
sync calls of ->read_iter()/->write_iter()"
* 'iov_iter' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: add vfs_iter_{read,write} helpers
new helper: iov_iter_bvec()
Pull getname/putname updates from Al Viro:
"Rework of getname/getname_kernel/etc., mostly from Paul Moore. Gets
rid of quite a pile of kludges between namei and audit..."
* 'getname2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
audit: replace getname()/putname() hacks with reference counters
audit: fix filename matching in __audit_inode() and __audit_inode_child()
audit: enable filename recording via getname_kernel()
simpler calling conventions for filename_mountpoint()
fs: create proper filename objects using getname_kernel()
fs: rework getname_kernel to handle up to PATH_MAX sized filenames
cut down the number of do_path_lookup() callers
