path: root/include
2008-07-31hpet: /dev/hpet - fixes and cleanupDavid Brownell
Minor /dev/hpet updates and bugfixes: * Remove dead code, mostly remnants of an incomplete/unusable kernel interface ... noted when addressing "sparse" warnings: + hpet_unregister() and a routine it calls + hpet_task and all references, including hpet_task_lock + hpet_data.hd_flags (and HPET_DATA_PLATFORM) * Correct and improve boot message: + displays *counter* (shared between comparators) bit width, not *timer* bit widths (which are often mixed) + relabel "timers" as "comparators"; this is less confusing, they are not independent like normal timers are (sigh) + display MHz not Hz; it's never less than 10 MHz. * Tighten and correct the userspace interface code + don't accidentally program comparators in 64-bit mode using 32-bit values ... always force comparators into 32-bit mode + provide the correct bit definition flagging comparators with periodic capability ... the ABI is unchanged * Update Documentation/hpet.txt + be more correct and current + expand description a bit + don't mention that now-gone kernel interface Plus, add a FIXME comment for something that could cause big trouble on systems with more capable HPETs than at least Intel seems to ship. It seems that few folk use this userspace interface; it's not very usable given the general lack of HPET IRQ routing. I'm told that the only real point of it any more is to mmap for fast timestamps; IMO that's handled better through the gettimeofday() vsyscall. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-31Merge branch 'linus' into timers/hpetIngo Molnar
2008-07-28Merge branch 'for-linus' of git://git.o-hand.com/linux-mfdLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-mfd: mfd: accept pure device as a parent, not only platform_device mfd: add platform_data to mfd_cell mfd: Coding style fixes mfd: Use to_platform_device instead of container_of
2008-07-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits) x86/PCI: use dev_printk when possible PCI: add D3 power state avoidance quirk PCI: fix bogus "'device' may be used uninitialized" warning in pci_slot PCI: add an option to allow ASPM enabled forcibly PCI: disable ASPM on pre-1.1 PCIe devices PCI: disable ASPM per ACPI FADT setting PCI MSI: Don't disable MSIs if the mask bit isn't supported PCI: handle 64-bit resources better on 32-bit machines PCI: rewrite PCI BAR reading code PCI: document pci_target_state PCI hotplug: fix typo in pcie hotplug output x86 gart: replace to_pages macro with iommu_num_pages x86, AMD IOMMU: replace to_pages macro with iommu_num_pages iommu: add iommu_num_pages helper function dma-coherent: add documentation to new interfaces Cris: convert to using generic dma-coherent mem allocator Sh: use generic per-device coherent dma allocator ARM: support generic per-device coherent dma mem Generic dma-coherent: fix DMA_MEMORY_EXCLUSIVE x86: use generic per-device dma coherent allocator ...
2008-07-29mfd: accept pure device as a parent, not only platform_deviceDmitry Baryshkov
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-07-28include/asm-generic/pgtable-nopmd.h: macros are noxious, reason #435Andrew Morton
arch/x86/mm/pgtable.c: In function 'pgd_mop_up_pmds': arch/x86/mm/pgtable.c:194: warning: unused variable 'pmd' Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28gpio: fix build on CONFIG_GPIO_SYSFS=nAtsushi Nemoto
If CONFIG_GENERIC_GPIO=y && CONFIG_GPIO_SYSFS=n, gpio_export() in asm-generic/gpio.h refers -ENOSYS and causes build error. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28vfs: pagecache usage optimization for pagesize!=blocksizeHisashi Hifumi
When we read some part of a file through pagecache, if there is a pagecache of corresponding index but this page is not uptodate, read IO is issued and this page will be uptodate. I think this is good for pagesize == blocksize environment but there is room for improvement on pagesize != blocksize environment. Because in this case a page can have multiple buffers and even if a page is not uptodate, some buffers can be uptodate. So I suggest that when all buffers which correspond to a part of a file that we want to read are uptodate, use this pagecache and copy data from this pagecache to user buffer even if a page is not uptodate. This can reduce read IO and improve system throughput. I wrote a benchmark program and got result number with this program. This benchmark do: 1: mount and open a test file. 2: create a 512MB file. 3: close a file and umount. 4: mount and again open a test file. 5: pwrite randomly 300000 times on a test file. offset is aligned by IO size(1024bytes). 6: measure time of preading randomly 100000 times on a test file. The result was: 2.6.26 330 sec 2.6.26-patched 226 sec Arch:i386 Filesystem:ext3 Blocksize:1024 bytes Memory: 1GB On ext3/4, a file is written through buffer/block. So random read/write mixed workloads or random read after random write workloads are optimized with this patch under pagesize != blocksize environment. This test result showed this. The benchmark program is as follows: #include <stdio.h> #include <sys/types.h> #include <sys/stat.h> #include <fcntl.h> #include <unistd.h> #include <time.h> #include <stdlib.h> #include <string.h> #include <sys/mount.h> #define LEN 1024 #define LOOP 1024*512 /* 512MB */ main(void) { unsigned long i, offset, filesize; int fd; char buf[LEN]; time_t t1, t2; if (mount("/dev/sda1", "/root/test1/", "ext3", 0, 0) < 0) { perror("cannot mount\n"); exit(1); } memset(buf, 0, LEN); fd = open("/root/test1/testfile", O_CREAT|O_RDWR|O_TRUNC); if (fd < 0) { perror("cannot open file\n"); exit(1); } for (i = 0; i < LOOP; i++) write(fd, buf, LEN); close(fd); if (umount("/root/test1/") < 0) { perror("cannot umount\n"); exit(1); } if (mount("/dev/sda1", "/root/test1/", "ext3", 0, 0) < 0) { perror("cannot mount\n"); exit(1); } fd = open("/root/test1/testfile", O_RDWR); if (fd < 0) { perror("cannot open file\n"); exit(1); } filesize = LEN * LOOP; for (i = 0; i < 300000; i++){ offset = (random() % filesize) & (~(LEN - 1)); pwrite(fd, buf, LEN, offset); } printf("start test\n"); time(&t1); for (i = 0; i < 100000; i++){ offset = (random() % filesize) & (~(LEN - 1)); pread(fd, buf, LEN, offset); } time(&t2); printf("%ld sec\n", t2-t1); close(fd); if (umount("/root/test1/") < 0) { perror("cannot umount\n"); exit(1); } } Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Hellwig <hch@infradead.org> Cc: Jan Kara <jack@ucw.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28spi_s3c24xx: really assign busnumBen Dooks
The original "Pass the bus number we expect the S3C24XX SPI driver to attach to via the platform data." [1] patch was mis-sent, and missed two important parts of the diff, which was to actually set the bus_num field and add the relevant field to the platform data. The previous commit 50f426b55d919dd017af35bb6a08753d1f262920 promised to add a bus_num field, but failed to include the two hunks that added this field to include/asm-arm/arch-s3c2410/spi.h and then pass it to the spi core when creating the new master field in drivers/spi/spi_s3c24xx.c. [1] git commit 50f426b55d919dd017af35bb6a08753d1f262920 Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28mmu-notifiers: coreAndrea Arcangeli
With KVM/GFP/XPMEM there isn't just the primary CPU MMU pointing to pages. There are secondary MMUs (with secondary sptes and secondary tlbs) too. sptes in the kvm case are shadow pagetables, but when I say spte in mmu-notifier context, I mean "secondary pte". In GRU case there's no actual secondary pte and there's only a secondary tlb because the GRU secondary MMU has no knowledge about sptes and every secondary tlb miss event in the MMU always generates a page fault that has to be resolved by the CPU (this is not the case of KVM where the a secondary tlb miss will walk sptes in hardware and it will refill the secondary tlb transparently to software if the corresponding spte is present). The same way zap_page_range has to invalidate the pte before freeing the page, the spte (and secondary tlb) must also be invalidated before any page is freed and reused. Currently we take a page_count pin on every page mapped by sptes, but that means the pages can't be swapped whenever they're mapped by any spte because they're part of the guest working set. Furthermore a spte unmap event can immediately lead to a page to be freed when the pin is released (so requiring the same complex and relatively slow tlb_gather smp safe logic we have in zap_page_range and that can be avoided completely if the spte unmap event doesn't require an unpin of the page previously mapped in the secondary MMU). The mmu notifiers allow kvm/GRU/XPMEM to attach to the tsk->mm and know when the VM is swapping or freeing or doing anything on the primary MMU so that the secondary MMU code can drop sptes before the pages are freed, avoiding all page pinning and allowing 100% reliable swapping of guest physical address space. Furthermore it avoids the code that teardown the mappings of the secondary MMU, to implement a logic like tlb_gather in zap_page_range that would require many IPI to flush other cpu tlbs, for each fixed number of spte unmapped. To make an example: if what happens on the primary MMU is a protection downgrade (from writeable to wrprotect) the secondary MMU mappings will be invalidated, and the next secondary-mmu-page-fault will call get_user_pages and trigger a do_wp_page through get_user_pages if it called get_user_pages with write=1, and it'll re-establishing an updated spte or secondary-tlb-mapping on the copied page. Or it will setup a readonly spte or readonly tlb mapping if it's a guest-read, if it calls get_user_pages with write=0. This is just an example. This allows to map any page pointed by any pte (and in turn visible in the primary CPU MMU), into a secondary MMU (be it a pure tlb like GRU, or an full MMU with both sptes and secondary-tlb like the shadow-pagetable layer with kvm), or a remote DMA in software like XPMEM (hence needing of schedule in XPMEM code to send the invalidate to the remote node, while no need to schedule in kvm/gru as it's an immediate event like invalidating primary-mmu pte). At least for KVM without this patch it's impossible to swap guests reliably. And having this feature and removing the page pin allows several other optimizations that simplify life considerably. Dependencies: 1) mm_take_all_locks() to register the mmu notifier when the whole VM isn't doing anything with "mm". This allows mmu notifier users to keep track if the VM is in the middle of the invalidate_range_begin/end critical section with an atomic counter incraese in range_begin and decreased in range_end. No secondary MMU page fault is allowed to map any spte or secondary tlb reference, while the VM is in the middle of range_begin/end as any page returned by get_user_pages in that critical section could later immediately be freed without any further ->invalidate_page notification (invalidate_range_begin/end works on ranges and ->invalidate_page isn't called immediately before freeing the page). To stop all page freeing and pagetable overwrites the mmap_sem must be taken in write mode and all other anon_vma/i_mmap locks must be taken too. 2) It'd be a waste to add branches in the VM if nobody could possibly run KVM/GRU/XPMEM on the kernel, so mmu notifiers will only enabled if CONFIG_KVM=m/y. In the current kernel kvm won't yet take advantage of mmu notifiers, but this already allows to compile a KVM external module against a kernel with mmu notifiers enabled and from the next pull from kvm.git we'll start using them. And GRU/XPMEM will also be able to continue the development by enabling KVM=m in their config, until they submit all GRU/XPMEM GPLv2 code to the mainline kernel. Then they can also enable MMU_NOTIFIERS in the same way KVM does it (even if KVM=n). This guarantees nobody selects MMU_NOTIFIER=y if KVM and GRU and XPMEM are all =n. The mmu_notifier_register call can fail because mm_take_all_locks may be interrupted by a signal and return -EINTR. Because mmu_notifier_reigster is used when a driver startup, a failure can be gracefully handled. Here an example of the change applied to kvm to register the mmu notifiers. Usually when a driver startups other allocations are required anyway and -ENOMEM failure paths exists already. struct kvm *kvm_arch_create_vm(void) { struct kvm *kvm = kzalloc(sizeof(struct kvm), GFP_KERNEL); + int err; if (!kvm) return ERR_PTR(-ENOMEM); INIT_LIST_HEAD(&kvm->arch.active_mmu_pages); + kvm->arch.mmu_notifier.ops = &kvm_mmu_notifier_ops; + err = mmu_notifier_register(&kvm->arch.mmu_notifier, current->mm); + if (err) { + kfree(kvm); + return ERR_PTR(err); + } + return kvm; } mmu_notifier_unregister returns void and it's reliable. The patch also adds a few needed but missing includes that would prevent kernel to compile after these changes on non-x86 archs (x86 didn't need them by luck). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix mm/filemap_xip.c build] [akpm@linux-foundation.org: fix mm/mmu_notifier.c build] Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kanoj Sarcar <kanojsarcar@yahoo.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: Steve Wise <swise@opengridcomputing.com> Cc: Avi Kivity <avi@qumranet.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Chris Wright <chrisw@redhat.com> Cc: Marcelo Tosatti <marcelo@kvack.org> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Izik Eidus <izike@qumranet.com> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28mmu-notifiers: add mm_take_all_locks() operationAndrea Arcangeli
mm_take_all_locks holds off reclaim from an entire mm_struct. This allows mmu notifiers to register into the mm at any time with the guarantee that no mmu operation is in progress on the mm. This operation locks against the VM for all pte/vma/mm related operations that could ever happen on a certain mm. This includes vmtruncate, try_to_unmap, and all page faults. The caller must take the mmap_sem in write mode before calling mm_take_all_locks(). The caller isn't allowed to release the mmap_sem until mm_drop_all_locks() returns. mmap_sem in write mode is required in order to block all operations that could modify pagetables and free pages without need of altering the vma layout (for example populate_range() with nonlinear vmas). It's also needed in write mode to avoid new anon_vmas to be associated with existing vmas. A single task can't take more than one mm_take_all_locks() in a row or it would deadlock. mm_take_all_locks() and mm_drop_all_locks are expensive operations that may have to take thousand of locks. mm_take_all_locks() can fail if it's interrupted by signals. When mmu_notifier_register returns, we must be sure that the driver is notified if some task is in the middle of a vmtruncate for the 'mm' where the mmu notifier was registered (mmu_notifier_invalidate_range_start/end is run around the vmtruncation but mmu_notifier_register can run after mmu_notifier_invalidate_range_start and before mmu_notifier_invalidate_range_end). Same problem for rmap paths. And we've to remove page pinning to avoid replicating the tlb_gather logic inside KVM (and GRU doesn't work well with page pinning regardless of needing tlb_gather), so without mm_take_all_locks when vmtruncate frees the page, kvm would have no way to notice that it mapped into sptes a page that is going into the freelist without a chance of any further mmu_notifier notification. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kanoj Sarcar <kanojsarcar@yahoo.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: Steve Wise <swise@opengridcomputing.com> Cc: Avi Kivity <avi@qumranet.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Chris Wright <chrisw@redhat.com> Cc: Marcelo Tosatti <marcelo@kvack.org> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Izik Eidus <izike@qumranet.com> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28mmu-notifiers: add list_del_init_rcu()Andrea Arcangeli
Introduce list_del_init_rcu() and document it. Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kanoj Sarcar <kanojsarcar@yahoo.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: Steve Wise <swise@opengridcomputing.com> Cc: Avi Kivity <avi@qumranet.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Chris Wright <chrisw@redhat.com> Cc: Marcelo Tosatti <marcelo@kvack.org> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Izik Eidus <izike@qumranet.com> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-29mfd: add platform_data to mfd_cellMike Rapoport
Adding platform_data to mfd_cell allows passing of platform data directly to the platform_device created for each cell and thus reuse of existing drivers. On the other side it can be used as a hook to mfd_cell itself removing the need in mfd_get_cell method. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-07-28Merge branch 'core/generic-dma-coherent' of ↵Jesse Barnes
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip into for-linus
2008-07-28PCI: add D3 power state avoidance quirkAlan Cox
Libata has some hacks to deal with certain controllers going silly in D3 state. The right way to handle this is to keep a PCI device flag for such devices. That can then be generalised for no ATA devices with power problems. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-07-29Merge branch 'linus' into core/generic-dma-coherentIngo Molnar
Conflicts: arch/x86/Kconfig Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-28PCI: disable ASPM on pre-1.1 PCIe devicesShaohua Li
Disable ASPM on pre-1.1 PCIe devices, as many of them don't implement it correctly. Tested-by: Jack Howarth <howarth@bromo.msbb.uc.edu> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-07-28PCI: disable ASPM per ACPI FADT settingShaohua Li
The ACPI FADT table includes an ASPM control bit. If the bit is set, do not enable ASPM since it may indicate that the platform doesn't actually support the feature. Tested-by: Jack Howarth <howarth@bromo.msbb.uc.edu> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-07-28Merge branch 'linus' into cpus4096Ingo Molnar
Conflicts: kernel/stop_machine.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-28Merge branch 'x86/iommu' of ↵Jesse Barnes
2008-07-28cpu masks: optimize and clean up cpumask_of_cpu()Linus Torvalds
Clean up and optimize cpumask_of_cpu(), by sharing all the zero words. Instead of stupidly generating all possible i=0...NR_CPUS 2^i patterns creating a huge array of constant bitmasks, realize that the zero words can be shared. In other words, on a 64-bit architecture, we only ever need 64 of these arrays - with a different bit set in one single world (with enough zero words around it so that we can create any bitmask by just offsetting in that big array). And then we just put enough zeroes around it that we can point every single cpumask to be one of those things. So when we have 4k CPU's, instead of having 4k arrays (of 4k bits each, with one bit set in each array - 2MB memory total), we have exactly 64 arrays instead, each 8k bits in size (64kB total). And then we just point cpumask(n) to the right position (which we can calculate dynamically). Once we have the right arrays, getting "cpumask(n)" ends up being: static inline const cpumask_t *get_cpu_mask(unsigned int cpu) { const unsigned long *p = cpu_bit_bitmap[1 + cpu % BITS_PER_LONG]; p -= cpu / BITS_PER_LONG; return (const cpumask_t *)p; } This brings other advantages and simplifications as well: - we are not wasting memory that is just filled with a single bit in various different places - we don't need all those games to re-create the arrays in some dense format, because they're already going to be dense enough. if we compile a kernel for up to 4k CPU's, "wasting" that 64kB of memory is a non-issue (especially since by doing this "overlapping" trick we probably get better cache behaviour anyway). [ mingo@elte.hu: Converted Linus's mails into a commit. See: http://lkml.org/lkml/2008/7/27/156 http://lkml.org/lkml/2008/7/28/320 Also applied a family filter - which also has the side-effect of leaving out the bits where Linus calls me an idio... Oh, never mind ;-) ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: add driver for Atmel integrated touchscreen controller Input: ads7846 - optimize order of calculating Rt in ads7846_rx() Input: ads7846 - fix sparse endian warnings Input: uinput - remove duplicate include Input: serio - offload resume to kseriod Input: serio - mark serio_register_driver() __must_check
2008-07-28mfd: Coding style fixesBen Dooks
Fix some coding style fixes in the mfd core driver. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-07-28Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (25 commits) powerpc: Disable 64K hugetlb support when doing 64K SPU mappings powerpc/powermac: Fixup default serial port device for pmac_zilog powerpc/powermac: Use sane default baudrate for SCC debugging powerpc/mm: Implement _PAGE_SPECIAL & pte_special() for 64-bit powerpc: Show processor cache information in sysfs powerpc: Make core id information available to userspace powerpc: Make core sibling information available to userspace powerpc/vio: More fallout from dma_mapping_error API change ibmveth: Fix multiple errors with dma_mapping_error conversion powerpc/pseries: Fix CMO sysdev attribute API change fallout powerpc: Enable tracehook for the architecture powerpc: Add TIF_NOTIFY_RESUME support for tracehook powerpc: Add asm/syscall.h with the tracehook entry points powerpc: Make syscall tracing use tracehook.h helpers powerpc: Call tracehook_signal_handler() when setting up signal frames powerpc: Update cpu_sibling_maps dynamically powerpc: register_cpu_online should be __cpuinit powerpc: kill useless SMT code in prom_hold_cpus powerpc: Fix 8xx build failure powerpc: Fix vio build warnings ...
2008-07-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (72 commits) sh: SuperH Mobile CEU and camera platform data for AP325RXA sh: Update smc911x platform data for AP325RXA sh: SuperH Mobile LCDC platform data for AP325RXA sh: Add SuperH Mobile CEU platform data for Migo-R sh: Add SuperH Mobile LCDC platform data for Migo-R sh: Move asid_cache() out of ifdef to fix SH-3/4 nommu build. sh: Workaround for __put_user_asm() bug with gcc 4.x on big-endian. sh: Wire up new syscalls. sh: fix uImage Entry Point sh_keysc: remove request_mem_region() and release_mem_region() sh: Don't miss pending signals returning to user mode after signal processing sh: Use clk_always_enable() on sh7366 sh: Use clk_always_enable() on sh7343 / SE77343 sh: Use clk_always_enable() on sh7722 / Migo-R / SE7722 sh: Use clk_always_enable() on sh7723 / ap325rxa sh: Introduce clk_always_enable() function sh: Show all clocks and their state in /proc/clocks sh: Merge sh7343 and sh7722 clock code sh: Add SuperH Mobile MSTPCR bits to clock framework sh: Use arch_flags to simplify sh7722 siu clock code ...
2008-07-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: stop_machine: fix up ftrace.c stop_machine: Wean existing callers off stop_machine_run() stop_machine(): stop_machine_run() changed to use cpu mask Hotplug CPU: don't check cpu_online after take_cpu_down Simplify stop_machine stop_machine: add ALL_CPUS option module: fix build warning with !CONFIG_KALLSYMS
2008-07-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (98 commits) V4L/DVB (8549): mxl5007: Fix an error at include file V4L/DVB (8548): pwc: Fix compilation V4L/DVB (8546): add tuner-3036 and dpc7146 drivers to feature-removal-schedule.txt V4L/DVB (8546): saa7146: fix read from uninitialized memory V4L/DVB (8544): gspca: probe/open race. V4L/DVB (8543): em28xx: Rename #define for Compro VideoMate ForYou/Stereo V4L/DVB (8542): em28xx: AMD ATI TV Wonder HD 600 entry at cards struct is duplicated V4L/DVB (8541): em28xx: HVR-950 entry is duplicated. V4L/DVB (8540): em28xx-cards: Add Compro VideoMate ForYou/Stereo model V4L/DVB (8539): em28xx-cards: New supported IDs for analog models V4L/DVB (8538): em28xx-cards: Add GrabBeeX+ USB2800 model V4L/DVB (8534): remove select's of FW_LOADER V4L/DVB (8522): videodev2: Fix merge conflict V4L/DVB (8532): mxl5007t: remove excessive locks V4L/DVB (8531): mxl5007t: move i2c gate handling outside of mutex protected code blocks V4L/DVB (8530): au0828: add support for new revision of HVR950Q V4L/DVB (8529): mxl5007t: enable _init and _sleep power management functionality V4L/DVB (8528): add support for MaxLinear MxL5007T silicon tuner V4L/DVB (8526): saa7146: fix VIDIOC_ENUM_FMT V4L/DVB (8525): fix a few assorted spelling mistakes. ...
2008-07-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: Set CONFIG_HAVE_ARCH_TRACEHOOK sparc: Add task_pt_regs(). sparc: Add call to tracehook_signal_handler(). sparc: Create and use TIF_NOTIFY_RESUME. sparc: Use tracehook routines in syscall_trace(). sparc64: tracehook: CONFIG_HAVE_ARCH_TRACEHOOK sparc: Add user_stack_pointer(). sparc64: tracehook_signal_handler sparc64: tracehook: TIF_NOTIFY_RESUME sparc: Add asm/syscall.h sparc64: tracehook syscall sparc: enable headers_export again sparc, sparc64: use arch/sparc/include
2008-07-28i2c: S3C2410: Pass the I2C bus number via drivers platform dataBen Dooks
Allow the platform data to specify the bus bumber that the new I2C bus will be given. This is to allow the use of the board registration mechanism to specify the new style of I2C device registration which allows boards to provide a list of attached devices. Note, as discussed on the mailing list, we have dropped backwards compatibility of adding an dynamic bus number as it should not affect most boards to have the bus pinned to 0 if they have either not specified platform data for driver. Any board supplying platform data will automatically have the bus_num field set to 0, and anyone who needs the driver on a different bus number can supply platform data to set bus_num. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-28sh: Add SuperH Mobile CEU platform data for Migo-RMagnus Damm
Add Migo-R specific platform data for on-chip sh7722 CEU and ov772x camera. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add SuperH Mobile LCDC platform data for Migo-RMagnus Damm
Add WVGA and QVGA LCD panel support to Migo-R. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Move asid_cache() out of ifdef to fix SH-3/4 nommu build.Paul Mundt
2008-07-28sh: Workaround for __put_user_asm() bug with gcc 4.x on big-endian.Yoshinori Sato
I think this problem is GCC(4.1.2) bug. Syscall "getdents" returned "dirent->d_off" is always 0. I think other EB enviroment have same problem. Problem code 0c03c954 <filldir>: : c03c97a: 58 f7 mov.l @(28,r15),r8 !-> offset (high) c03c97c: 59 f8 mov.l @(32,r15),r9 !-> offset (low) c03c97e: 53 f9 mov.l @(36,r15),r3 c03c980: 54 fa mov.l @(40,r15),r4 : c03c9a0: 21 82 mov.l r8,@r1 !offset(high) -> dirent->d_off It's workaround patch. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Wire up new syscalls.Paul Mundt
This wires up the signalfd4, eventfd2, epoll_create1, dup3, pipe2, and inotify_init1 syscalls. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Use clk_always_enable() on sh7343 / SE77343Magnus Damm
Use clk_always_enable() on the sh7343 processor and in the board code for Solution Engine 7343. Remove duplicate MSTPCR register definitions. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Use clk_always_enable() on sh7722 / Migo-R / SE7722Magnus Damm
Use clk_always_enable() on the sh7722 processor and in the board code for Migo-R and Solution Engine 7722. Remove duplicate MSTPCR register definitions. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Introduce clk_always_enable() functionMagnus Damm
Add SuperH specific funcion clk_always_enable(), useful to enable MSTPCR bits in processor or board specific code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add SuperH Mobile MSTPCR bits to clock frameworkMagnus Damm
Handle module stop clock bits in MSTPCRn through the clock framework. The clocks are named after the bits in the data sheet. The association between bit number and hardware block is processor specific. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add arch_flags to struct clkMagnus Damm
Add arch_flags to struct clk so we can keep per-clock private data somewhere and share code between multiple clocks. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Renesas R0P7785LC0011RL board supportYoshihiro Shimoda
This adds initial support for the Renesas R0P7785LC0011RL board. This patch supports 29bit address mode only. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add memory chunks to SH-Mobile UIO devicesMagnus Damm
This patch adds physically contiguous memory chunks to the UIO devices. The same strategy can be used in the future for the CEU as well. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: update Solution Engine 7343Yoshihiro Shimoda
updated the following codes for Solution Endine 7343: - fix compile error in arch/sh/boards/se/7343/irq.c - add nor flash physmaps - update defconfig Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: update sh7343 codeYoshihiro Shimoda
updated the following codes for SH7343: - add register_intc_controller() - add EARLY_SCIF_CONSOLE_PORT - add define of CPG register Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: add interrupt ack code to sh4aYoshihiro Shimoda
This patch is based on interrupt acknowledge code for external interrupt sources on sh3 processors and adds on sh4a processors. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Optimized flush_icache_range() implementation.Chris Smith
Add implementation of flush_icache_range() suitable for signal handler and kprobes. Remove flush_cache_sigtramp() and change signal.c to use flush_icache_range(). Signed-off-by: Chris Smith <chris.smith@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Stub in silicon cut in CPU info.Stuart Menefy
Signed-off-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Clean up code of Solution Engine 770xNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Solution Enginge 7710/7712 SH-Ether supportNobuhiro Iwamatsu
Add support SH-Ether for Hitachi Solution Engine. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh/kernel/ cleanupsAdrian Bunk
This patch contains the following cleanups: - make the following needlessly global code static: - cf-enabler.c: cf_init() - cpu/clock.c: __clk_enable() - cpu/clock.c: __clk_disable() - process_32.c: default_idle() - time_32.c: struct clocksource_sh - timers/timer-tmu.c: struct tmu_timer_ops - remove the following unused functions (no CONFIG_BLK_DEV_FD on sh): - process_{32,64}.c: disable_hlt() - process_{32,64}.c: enable_hlt() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
